sieht so aus als ob heute neue Macbook Pro kommen..da der Apple Store schon seit mehreren Stunden down ist!
Gerüchten zufolgen die Daten der neuen Books:
Purported MacBook Pro Specifications
• 2.2GHz Intel Core 2 Duo processor; 4MB shared level 2 cache
• 2GB of 667MHz DDR2 SDRAM (PC2-5300)
• 120GB 5400-rpm hard drive
• 15.4-inch (diagonal) TFT widescreen display; 1440 by 900 pixels
• NVIDIA GeForce 8600M GT with 128MB of GDDR3 SDRAM
• Built-in iSight video camera
• Slot-loading 8x SuperDrive (DVD+R DL/DVD±RW/CD-RW)
• ExpressCard/34 slot, FireWire 400 port, FireWire 800 port, two USB 2.0 ports
• DVI portl DVI to VGA adapter included
• Optical digital audio input/line in, optical digital audio output/headphone out
• Built-in 10/100/1000BASE-T Ethernet
• Built in AirPort Extreme
• Built-in Bluetooth 2.0 + EDR(Enhanced Data Rate)
• Backlit illuminated keyboard and ambient light sensor
• Apple Remote
• Preinstalled Max OS X and other bundled software
• Size and weight: 14.1 by 9.6 by 1.0 inches (35.7 by 24.3 by 2.59 cm); 5.4 pounds (2.45 kg)
• Meets ENERGY STAR requirements
• Model No. A1226
• Manufacturers Part No. MA895LL/A
• $1999
• 2.4GHz Intel Core 2 Duo processor; 4MB shared level 2 cache
• 160GB 5400-rpm hard drive
• NVIDIA GeForce 8600M GT with 256MB of GDDR3 SDRAM
• Apple Remote
• Model No. A1226
• Manufacturers Part No. MA896LL/A
• $2499
• Apple Remote
• Model No. A1226
• $1999
• Apple Remote
• Model No. A1226
• $2499
