starkpc.com
P5N32-SLI Premium/WiFi-AP
- Quad-SLI Ready
- Intel® Core™2 Extreme / Core™2 Duo Ready
- Intel® Pentium® Extreme / Pentium® D / Pentium® 4 / Celeron® D Ready
- NVIDIA nForce® 590 SLI™ Intel Edition
- Dual-channel DDR2 800(OC) /667/533
- SupremeFX/ DTS Connect/ Array Mic/ Noise Filter
- AI NOS™ / AI Gear / AI Nap
- 8 Phase Power Design
Fotos:
- Quad-SLI Ready
Fotos:
- CPU:
LGA775 socket for Intel® Core™2 Extreme / Core™2 Duo /
Pentium® Extreme / Pentium® D / Pentium® 4 / Celeron® D Processors
Compatible with Intel® 06/05B/05A processors
* Refer to www.asus.com for Intel CPU support list
- Chipset:
* Enhanced Performance Profile Technology
- Front Side Bus:
1066 / 800 / 533 MHz
- Memory:
Dual channel memory architecture
4 x DIMM, max. 8GB, DDR2-800(OC)/667/533, non-ECC, un-buffered memory
* Refer to www.asus.com or user manual for Memory QVL (Qualify Vendor List)
- Expansion Slots
2 x PCI Express x16 slot, support NVIDIA® SLI™ technology, at full x16, x16 speed(blue and black)
1 x PCI Express x16, at x8 speed(middle)
1 x PCI Express x1
2 x PCI 2.2
- SLI:
Support two identical NVIDIA SLI-Ready graphics cards (both at x16 mode)
ASUS PEG Link
- Storage:
South bridge supports:
* 1 x Ultra DMA 133 / 100 / 66 / 33
* 6 x Serial ATA 3.0Gb/s
* NVIDIA MediaShield™ RAID supports RAID 0, 1, 0+1, 5 and JBOD span cross Serial ATA drives
Silicon Image® 3132 SATA controller supports
* 2 x External Serial ATA 3.0Gb/s port on back I/O (SATA On-the-Go)
- LAN:
NVIDIA nForce® 590 SLI™ built-in dual Gigabit MAC with external Marvell PHY
Support NVIDIA DualNet® technology
- Wireless LAN:
ASUS WiFi-AP Solo
54 Mbps IEEE 802.11g and backwards compatible with 11 Mbps IEEE 802.11b
* Software Access point mode
* Station mode : Infrastructure mode and Ad-Hoc mode
- Audio:
SupremeFX Audio Card
* ADI 1988B 8-channel High Definition Audio CODEC
* Support Jack-Sensing, Enumeration, Multi-streaming and Jack-Retasking
* Noise Filter
Coaxial, Optical S/PDIF out
DTS® Connect
ASUS Array Mic
- IEEE 1394a:
VIA6308P controller supports 2 x 1394a ports
- USB:
max. 8 USB2.0/1.1 ports(4 ports at mid-board, 4 ports at back panel)
- Overclocking Features:
Intelligent overclocking tools:
* AI NOS™ (Non-delay Overclocking System)
* AI Overclocking (intelligent CPU frequency tuner)
* ASUS PEG Link - automatically performance tuning for graphics cards
* ASUS AI Booster Utility
Precision Tweaker
Overclocking Protection:
* ASUS C.P.R.(CPU Parameter Recall)
- ASUS AI Lifestyle Features:
ASUS Quiet Thermal Solution:
* AI Gear
* AI Nap
* ASUS 8-Phase Power Design
* ASUS Fanless Design: Heat-pipe solution
* ASUS Fanless Design: Stack Cool 2
* ASUS Q-Fan 2
* ASUS Optional Fan for Water-cooling or Passive-Cooling only
ASUS EZ DIY:
* ASUS Q-Connector
* ASUS O.C. Profile
* ASUS Music Alarm
* ASUS EZ Flash2
* ASUS MyLogo3
- Back Panel I/O Ports:
1 x PS/2 Keyboard port(purple)
1 x PS/2 Mouse port(green)
1 x Optical + 1 x Coaxial S/PDIF Output
2 x External SATA
2 x LAN (RJ45) port
4 x USB 2.0/1.1 ports
1 x IEEE1394a port
1 x WiFi-AP Solo™ antenna jack
- Internal I/O Connectors:
2 x USB 2.0 connectors supports additional 4 USB 2.0 ports
1 x Floppy disk drive connector
1 x IDE connector for two devices
6 x SATA connectors
1 x CPU / 1 x SPS / 3 x Chassis Fan connector
1 x IEEE1394a connector
1 x Com port connector
1 x S/PDIF output connector
1 x Chassis Intrusion connector
24-pin ATX Power connector
8-pin ATX 12V Power connector
System panel connector
- BIOS:
8Mb Award BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.3, Multi-Language BIOS
- Manageability:
WOL by PME, WOR by PME, Chasis Intrusion, PXE
- Accessories:
SLI bridge
ASUS Array Mic
ASUS Optional Fan
3 in 1 ASUS Q-Connector Kit
UltraDMA 133/100/66 cable
Floppy disk drive cable
SATA cables
SATA power cables
2-port USB2.0 module
IEEE1394a module
I/O Shield
ASUS WiFi-AP Solo omni-directional antenna
InterVideo® Media Launcher (OEM version only)
User's manual
- Support CD:
Drivers
ASUS PC Probe II
ASUS Update
ASUS AI Booster
ASUS AI Suite
ASUS WiFi-AP Solo Wizard
Anti-Virus Software
- Form Factor:
ATX Form Factor, 12"x 9.6" (30.5cm x 24.5cm)
muahaha
Viele betreibt es doch schon SLI auf Intelchip. Und ich bald auch
, dann wartet doch bitte auf den Nvidia i680chipset.
