[Sammelthread] AMD K8/K9 - Sockel 939 | 940 | 754
@stunned_guy
Is this the earliest sample there is or did you see earlier weeks as well?
Interesting batch as well.
Its not a 3700+, but a 3400+ 0432, so way earlier.
Ich wusste die Sache hat einen Haken 😄
Kann dann noch einen 4000+ , sollte ja SanDiego sein, aus 0505 zeigen.
Yes I meant San Diego. I actually have 2003 A64’s…
That 0505 cpu is nice. I would love to see results of that cpu.
Interesting sample. Despite being socket 939, it has HT 800MHz (4x multi) and it's an OEM part. Speaking of old, I have one of the oldest A64 :d
P.S. does anyone have early samples that have a serial number starting with "F" or "RFB"? Photo would be very helpful.
I have 2 starting with an F.
- FX-55 Clawhammer (AAA2C), F485562I40073. Week: 0437.
- FX-60 F49899C60803. Week 0611
The oldest cpu I have is an FX51, week 0342. Numer starts with a 9.
I have 2 ES cpu’s with a number starting with 100.
- FX-57, week 0516.
- A64 4400+, week 0517.
No photo’s for now.
- FX-57, week 0516.
No photo’s for now.
Athlon 64 4400+
AMD FX-51 (week 0342) / FX-53
AMD FX-55
AMD FX-57
FX-60
When was it born?
2002 :d From what I've seen 0248 is the oldest Athlon marking. Anything before had ES markings only.
Why do you think it's ES? Because it doesn't have X2 marking on it?
Thank you for the info! Looks like all 754/939/940 starting with F.. are pre-release samples. Maybe the ones with 100... too.
FC53 AS AAABC 0409 Serial F44...
Seems like pre-release too.
I don't think Sparks X2 4400+ is an ES, stunned_guy once mentioned that ES CPUs show duplicate letters for the first two characters, that would fit the FX-57 but not the 4400+.
Additionally, things like the "1.40V" voltage marking on the FX-57 to me would be the most notable indicator for a sample chip besides the stepping starting with AA.
The missing X2 designation was probably not uncommon during the early X2 weeks. My X2 4800+ for example is missing the X2 marking as well and I see chips like that every now and then.
Oh, and I think I can provide an example for a 939 CPU starting with F that's not a pre-release / early week version:
Because of the AA and relatively early week.
All early samples did indeed have no X2 on it.
Oh and starting with 100 indeed.
Do you have a description of how to decipher stepping codes (what they mean)? And the part after the date too. I've seen only one source so far.
Also I've made a modBIOS for AsRock K8A780LM for benching purposes.
  • benchBIOS v1.0.zip
@Tzk Ich mach mal hier weiter mit den Ergebnissen.
Mittlerweile habe ich die Corsair Pros auf 310MHz durch SuperPi 8M bekommen. Allerdings mit sehr entschärften Timings, 2T Command Rate und 32M ist und bleibt instabil.
Ich teste jetzt nochmal die UltraX dagegen, und wenn ich dann noch Lust habe, eine andere CPU/IMC.
Aktuell sieht es so aus, als würde TCCD OC auf dem Epox schon ganz gut funktionieren, aber man muss im Vergleich zum DFI NF4 jedes Subtiming und jedes Setting einzeln einstellen. Mit Skews und Co habe ich auch noch nicht groß rumgetestet, irgendwo muss Schluss sein.
Oder die Sticks sind einfach nicht die besten, das kann auch sein. Aber die Lücke zu den Ergebnissen im NF4 Thread ist schon deutlich, deswegen tippe ich erstmal aufs Board.
Die UltraX Winbonds muss ich auch noch auf dem Epox testen, das dürfte aber deutlich schneller gehen und da habe ich Vergleichswerte durch die letzten 3-4 Pärchen. Editiere ich dann hier.
Edit: Hier der Winbond-Vergleich. Alle BH5, außer ganz links die Geil UltraX400 mit UTTs.
Ich würde generell die Versuche auf 1T beschränken, außer es geht im Max. MHz Validierungen. Du wirst für hohen Takt alle Timings händisch einstellen müssen, daran führt kein Weg vorbei. Die meisten Timings haben Fenster in denen sie funktionieren, sprich was bei 200Mhz passt muss nicht bei 250 oder 270 funktionieren. Du musst dich also langsam vorarbeiten und Schritt für Schritt anpassen bis du den Zieltakt stabil hast.
Bei den BH gibt’s ein paar Spezialitäten, weil manche Riegel ab 3.4V kaum noch skalieren, andere Riegel mögen kleine TRC und TRFC Werte nicht. Wieder andere streiken bei kleiner TRAS und dann gibt’s natürlich Kombinationen daraus. Generell sind 3.2V nicht viel für BH, sehr gute Riegel machen 250Mhz stabil. Der Schnitt sollte aber zwischen 240 und 250 liegen. 512er Riegel laufen wegen der Menge an Chips tendenziell schlechter als 256er, du hast wegen Bank Interleaving aber mehr Performance.
Aus diesen Gründen habe ich meine BH Riegel auf Sockel A mit niedrigen Timings (trc 9, TRFC 12) und 3.3V gebinnt. Das langt um die guten Sticks zu finden, die niedrige Timings vertragen. Teils hatte ich sticks die damit bei 230Mhz nicht stabil waren, mit 13/15 aber locker 250 liefen.
@stunned_guy
Dead on arrival...
Edit: Code 44 and 45
Code 45: Detect and Init. math coprocessor
Edit 2: I managed to repair it: I cleaned all pins and now it posts!
The long shot worked out. Wow
Edit 3: It still sometimes won't post...
Edit 4: No great OC, far from.
So I tested another 4000+ on cold today. Just for validation. It did a 3741MHz validation.
I now have these CPU's for validation:
- KABYE 0543: 4023MHz
- KAB1E 0626 (0010): 3687MHz
- KAB1E 0626 (0411): 3741MHz
- KAB1E 0631: 3442 (tested outside with 5C, should do 3500MHz on "cold").
- KABYE 0538: 3480MHz
I can start my own ranking for top 10
It is crazy how different the OC back in the days was! Today you search for a gap around 100- 300Mhz for max. OC between CPUs..:d
Non have a coldbug post, but they all suffer from coldbug boot.
And that is that fsb max gets when lowering temps.
Those b1 have an ideal temp of -5C to -20C and BY in the -40C and -60C range.
I made an exact list of best temps per cpu.
