[Sammelthread] MSI MEG X570(S) Unify (X MAX) / ACE (MAX) (AM4)
product_10_20191002132606_5d9434ee62129.pngproduct_9_20190723092258_5d3661724d540.pngproduct_1629079667f4b88b2d70e858818adcfd4767cd52a2.pngproduct_1629094385a72f0a5d4a37c30deff6b3dcba91659c.png
Sammelthread für das MSI MEG x570 Unify/ACE
Herstellerseite:
MEG X570 UNIFY
Herstellerseite: MEG X570 ACE
Herstellerseite: MEG X570S ACE MAX
Herstellerseite: MEG X570S UNIFY-X MAX
Reviews:
MSI MEG X570 UNIFY Review - Introduction
MSI MEG X570 Unify motherboard (updated)
MSI MEG X570 Unify: An All-Black Motherboard
MSI MEG X570 Unify kommt ohne RGB aus
MSI MEG X570 Unify | Tom's Hardware
MSI MEG X570 ACE Infinity | Hardwareluxx
MSI MEG X570 Ace Motherboard Review
MSI MEG X570 Ace - Review 2019 - PCMag UK
MSI MEG X570 ACE - Hardware Journal
MSI MEG X570 ACE - Review
MSI MEG X570S ACE MAX - digideutsche
MSI MEG X570S ACE MAX - wccftech
MSI MEG X570S ACE MAX - IT Info
MSI MEG X570S UNIFY-X MAX - geeknetic
Besonderheiten:
  • Supports 2nd and 3rd Gen AMD Ryzen™ / Ryzen™ with Radeon™ Vega Graphics and 2nd Gen AMD Ryzen™ with Radeon™ Graphics Desktop Processors for AM4 socket
  • Supports DDR4 Memory, up to 5000+(OC) MHz
  • Aluminum Cover with Extended Heatsink: All-metal extended heatsink cover enlarge the surface of heat dissipation, ensures even high-end processors to run in full speed.
  • Lightning Fast Game Experience: PCIe 4.0, Triple Lightning Gen4 x4 M.2 with M.2 Shield Frozr, StoreMI, AMD Turbo USB 3.2 Gen2.
  • 2.5G Gaming LAN with Latest Wi-Fi 6 Solution: Onboard 2.5G LAN with gaming LAN manager, combining latest Wi-Fi 6 solution which supports MU-MIMO and BSS color technology, delivering the best online gaming experience.
  • Frozr Heatsink Design: Designed with the patented fan and double ball bearings to provide the best performance for enthusiast gamers and prosumers.
  • Audio Boost HD: Isolated audio with dedicated processor combining ESS audio DAC with amplifier, deliver the breathtaking, game-changing sound to create the most exciting gameplay.
  • Pre-installed I/O Shielding: Better EMI protection and more convenience for installation
  • ACE: Mystic Light Infinity, Dual LAN, Extended Heat-pipe Design
Spezifikationen Unify/ACE/ACE MAX/Unify X:
SOCKET:
AM4
CPU (MAX SUPPORT): Ryzen 9
CHIPSET:
AMD® X570 Chipset
DDR4 MEMORY: 1866/ 2133/ 2400/ 2667/ 2800/2933 /3000 /3066 /3200 /3466 /3600 /3733 /3866 /4000 /4133 /4266 /4400 /4533 /4600 /4733 /4800 /5000+ Mhz by JEDEC and A-XMP OC MODE
MEMORY CHANNEL: Dual
DIMM SLOTS: 2/4
MAX MEMORY (GB): 128GB
PCI-E X16: 3
PCI-E X1: 2
SATAIII: 4
M.2 SLOT: 3/4/6
RAID: 0/1/10
TPM (HEADER): 1
LAN UNIFY/UNIFY X: 1x Realtek® RTL8125 2.5 Gbps
LAN ACE/ACE MAX: 1x Intel® WGI211AT Gigabit / Intel® Wi-Fi 6E AX210, 1x Realtek® RTL8125 2.5 Gbps
USB 3.2 PORTS (FRONT): 1(Gen2, Type C), 4(Gen1, Type A)
USB 3.2 PORTS (REAR): 1(Gen2, Type C), 3(Gen2, Type A), 2(Gen1, Type A)
USB 2.0 PORTS (FRONT): 4
USB 2.0 PORTS (REAR): 2
AUDIO PORTS (REAR): 5+ Optical S/PDIF (Realtek® ALC1220 Codec)
DIRECTX: 12
FORM FACTOR: ATX
SLI: Y
CROSSFIRE: Y
OPERATING SYSTEM: Support for Windows® 10 64-bit
MSI Support bei hwluxx.
Hier ein paar Bilder zu denn Boards:
Kann mir jemand mit einer RX 6000 oder RX 7000 GPU kurz bestätigen, ob im idle die Bandbreite der PCIe Anbindung (GPU) auf 2.0 oder 1.1 runtertaktet?
Bei mir ist meine 7800XT dauerhaft mit 4.0x16 angebunden. Zum Testen habe ich eine GTX1060 und R9 380, bei beiden wird ordnungsgemäß auf 1.1x16 runtergeschaltet. Ich vermute, dass es daher nicht an den Einstellungen (OS oder BIOS) liegen kann. Aber vielleicht an der BIOS Version.
Bei mir werkelt noch die AB0, weil stabil.
@talha777 Wenn du mir sagst, wo das zu sehen sein soll? In GPU-Z sehe ich nichts von irgendwelchem runtertakten vom PCIe
In GPU-Z unterhalb der Device ID gibt es den Punkt Bus Interface.
Dort steht links immer das, was unterstützt wird und rechts immer die aktuelle Anbindung.
Für üblich schaltet das Interface insbesondere im Desktopbetrieb runter bis auf 1.1. In meinem Fall jedoch bleibt es dauerhaft bei 4.0.
Wie gesagt, hier taktet auch nichts runter. Habe ich auch noch nie gesehen.
Okay, dann bin ich wohl nicht alleine. Hatte im Netz noch einen anderen Beitrag gefunden (den ich grad leider nicht wiederfinde), wo auch darüber diskutiert wurde. Da gab es wiederum einige, bei denen es funktionierte. Will da auch nicht zu viel Energie reinstecken, aber das Ding hat halt Einfluss auf die Leistungsaufnahme im idle und es wäre interessant, was für einen Unterschied das macht.
Abgesehen davon wäre es trotzdem interessant zu wissen, warum dieser Fallbackmodus plötzlich nicht mehr da ist. Sollte ich mehr erfahren, werde ich es posten.
Hallo, kennt jemand das Problem, dass pci-e unter win10 nicht gefunden werden oder aber auftauchen und nicht voll initialisiert werden.
Meg x570 unify
Sb Ae-5 oder 10gbe netzwerkkarte sind oft nur nach zig reboots ansprechbar.
Jetzt getestet unter win11 passiert das bisher nicht.
Vg
das mit der SB AE5 kommt mir bekannt vor. hatte ich auch mit älteren BIOS versionen.
MSIx570 ACE
MSIx570 ACE
Lösung gefunden?
Hab aktuelles bios drauf.
Komisch ist das die karten im gerätemanager zu sehen sind nur das Tiiming stimmt wohl nicht.
Bei win 11 sehe ich richtig wie auf dem logiscreen die netzwerkverbindung immer erst nach paar Sekunden steht.
schon länger her- glaube hab die PCIe gen runtergestellt bzw. manuell zugewiesen. Sound braucht ja nur geringe Bandbreite,
Also 100% ist das alles nicht. Keine Ahnung woran es liegt. Es scheint aber eher am X570 im allgemeinen zu liegen und das Problem mit den genutzen PCI-E.
Es ist jetzt aber zumindest 95% stabil. Will heißen, dass nur noch jeder 10-20. reboot dazu führt, dass entweder Sound AE-5 oder Broadcom 10Gbe nicht gefunden werden.
Ich nutze die 4x1er Slots auf dem Board nicht mehr und habe im BIOS auf 8x8x4 umgestellt.
Schön ist dies alles nicht. Das ganze Lane Sharing und Chipset Lanes Aufteilung ist auch sehr schwierig im Detail je Board zu finden, zumal es immer ein bisschen anders sein könnte, vor allem wenn man die NVMes dazu nimmt.
NVMes habe ich die 1 und 2 belegt, so dass sich jetzt die 2. NVME mit der Soundkarte über den Chipsatz die Lanes teilt.
Ich finde meine Config nun nicht so abwegig, aber im Grunde darf man nur 1 PCI-e extra zur GPU nutzen um nicht beschnitten zu werden, dann kann man sich bei der Masse der Boards auch die ganzen Slots sparen. Auch die extra NVMe Karten bringen nichts wenn es mehr als 2 NVMe auf der Karte gibt oder man muss die dann im PCI-E 1 stecken und die GPU wandert nach unten.
Mein Traumboard wäre.
1 PCI-e 4x16 GPU
2-3 NVMe
1 onboard > 5Gbe
1 PCI-e 3x1 für Sound (Onboardsound egal da Realtek und Nahimic vollkommen suckt, am besten ohne)
2-4 Sata Ports
2 USB für Keyboard / Mouse
4 USB 3
1 Thunderbolt
Wifi 6 / BT
Das einzige was in die Richtung geht und aktuell bezahlbar ist, wäre das ASUS X570 Formula, alles andere hat entweder nur 2,5gbe oder 1gbe oder ist viel zu teuer. Benötigt man Sound und 10Gbe Land muss man gezwungen Sound auslagern oder 10Gbe über Thunderbolt oder so realisieren um nicht Probleme mit den Lanes zu bekommen.
Mal abwarten ob ich das Unify behalte.
also ich hatte ja das ACE, aber da hat das zuletzt mit aktuellem bios funktioniert.
oder steigst gleich auf AM5 um, da habe ich mit aktuell mit 4 Nvme keinerlei Sharing probleme. Deswegen bin ich auch umgestiegen
Aber der Kostensprung ist mir zu groß bei mässig Verbesserung gegenüber eines 5800x3d mit einer 3080ti und 64gb ddr4 die mit 3600 cl14 laufen.
Das ist keine Überlegung wert. Aber ich bin mega unzufrieden mit der aktuellen Situation.
INTEL verkauft Heizungen und AM4 bietet einfach für meinen Bedarf an Leistung nicht den Sprung der e rechtfertigt irgendetwas zu tun.
Also im Grunde kann man sich AM5 und RDNA3 und 40er Nvidia komplett sparen, wenn man nicht gewillt ist auf eine 4090 zu gehen mit einem 7800x3d zb. Aber die Preise sind absurd. die ganzen 4070er sind für die Tonne wenn man eine 3080-3090 besitzt vor allem bei allem Richtung 4k ohne Framegeneration.
So. Ich habe mir jetzt für relative wenig Geld ein z490 und ein 11900kf gesichert und teste mal ein altes ausgereiftes System auf pci-e Nutzbarkeit. Es nervt, das die netztwerkkarte die auf dem z170 und auf einem b450 immer gefunden wird auf dem x570 zwar gefunden wird, aber nicht über dhcp eine Verbindung bekommt. Mit einem alten bios lief es noch, da konnte ich im bios. 8/8/4 einstellen, diese Option ist jetzt weg. Das UniFy ist super für ram und läuft super stabil, aber man sollte nicht mehr benötigen als es mitbringt und naja nahimic ist auch Schrott, also Sound ist deaktiv und über ae-5 geregelt und das geht komischer Weise . Das lanesharing scheint aber auf vielen x570 Probleme zu machen. Das habe ich so nicht erwartet.
Jetzt gibt es ein Gigabyte z490 Aorus Extreme das hätte theoretisch alles on Board was ich brauche, inkl 10gbe und Thunderbolt. Wenn das läuft, wandert das UniFy in einen Familienrechner.
Ob ich nun einen 11900k oder einen 5800x3d nutze bleibt wohl gleich, außer etwas mehr Stromverbrauch.
update:
mein Unify ist weg und ich bin auf Asus z690 mit 13700k könnte nicht glücklicher sein. Wobei das MSI Bios einfach aufgeräumter ist.
Da hilft nur täglich die Website checken und wer es sieht, teilt es hier ...
Freiwillige vor :bigok:
neues Bios verfügbar: 7C35vAK
Fixed CVE-2024-36877 security issue
Direkt mal flashen, bei dem Wetter ist mir eh alles egal :P
Hier nicht, CO Einstellungen laufen exakt wie vorher auch. Nehme mal an das außer dem Sicherheitspatch auch nicht viel geändert wurde.
Hm, ich kann das zweite Übertaktungsprofil nicht speichern.
Profil 1, 3, 4, 5 und 6 funktionieren einwandfrei.
Neues Beta-BIOS verfügbar:
2024-08-09
7C35vAL1
Beschreibung:
- AGESA ComboAm4v2PI 1.2.0.Cc update.
- Added security issue of SMM Lock Bypass uCode fix aka “Sinkclose”.
hey,
hat schon mal jemand beim x570 ACE die Wärmeleitpaste beim Chipsatz gewechselt? hat das bei dem Board auch viel gebracht?
mein ist beim youtub schauen schon bei 57 grad
hey,
Wollte ich mal machen, aber habe ich mir erspart. 57 Grad sind ja auch nichts, ist vollkommen im Rahmen. Ich würde mir die Mühe deswegen nicht machen.
Einfach die flossen davon lassen. Hab den Lüfter auf Minimum und alles fein. Irgendwas mit paar und sechzig Grad. Deine 57 sind voll im Rahmen.
Was heist „nur“ handwarm? Der Winter naht ? Dann Lüfter ausstecken 😬
Bei meinem x570 Gaming Plus war die Chipsatz Temp von Anfang an immer knapp an den 60°C und beim Zocken stark schwankend rund um die 65°C
Mit veränderter Lüfterkurve aber nie unter 51-52°C.
Hab beim Einbau einer neuen AiO, nach ca 1,5 Jahren Betrieb des MB's die Paste gewechselt (Noctua NT-H2 -> die alte war steinhart), was aber nur
eine geringe Verbesserung von +- 4°C gebracht hat. Binnen kürzester Zeit ist die Temp aber wieder auf durchnittlich 51°C gestiegen und da ist sie bis heute geblieben.
Durschnitt laut HWinfo
- Desktop 51,5°C
- Gaming / Rendering 57°C
--> Lüfter 0 - 60°C = 2500 U/min & ein 140mm Fan in der Front bläst dauerhaft mit 900 U/min am Chipsatz vorbei unter die Graka rein.
Neue Paste am Chipsatz lohnt sich meiner Meinung erst wenn ein deutlicher Temp-Anstieg im Idle/Last von 60°C+ (bei laufenden ChipsatzLüfter) zu verzeichnen ist ;-)
Ähnliche Themen
