Ich hab mir die Fehlermeldung nochmal angeguckt... Ja. Du hats recht. Habe ich überlesen.
Jedoch bekomme ich jetzt diesen Fehler...
das ist der Docker log:
[7/20/2023] [4:20:17 PM] [Nginx    ] › ℹ  info      Reloading Nginx
[7/20/2023] [4:20:22 PM] [SSL      ] › ℹ  info      Requesting Let'sEncrypt certificates for Cert #7: gitlab.domain.de
[7/20/2023] [4:20:22 PM] [SSL      ] › ℹ  info      Command: certbot certonly --config "/etc/letsencrypt.ini" --work-dir "/tmp/letsencrypt-lib" --logs-dir "/tmp/letsencrypt-log" --cert-name "npm-7" --agree-tos --authenticator webroot --email "
xxx@gmail.com" --preferred-challenges "dns,http" --domains "gitlab.domain.de"
[7/20/2023] [4:20:25 PM] [Nginx    ] › ⬤  debug     Deleting file: /data/nginx/temp/letsencrypt_7.conf
[7/20/2023] [4:20:25 PM] [Nginx    ] › ℹ  info      Reloading Nginx
[7/20/2023] [4:20:25 PM] [Express  ] › ⚠  warning   Command failed: certbot certonly --config "/etc/letsencrypt.ini" --work-dir "/tmp/letsencrypt-lib" --logs-dir "/tmp/letsencrypt-log" --cert-name "npm-7" --agree-tos --authenticator webroot --email "
Saving debug log to /tmp/letsencrypt-log/letsencrypt.log
Some challenges have failed.
Ask for help or search for solutions at
https://community.letsencrypt.org. See the logfile /tmp/letsencrypt-log/letsencrypt.log or re-run Certbot with -v for more details.
und hier der log von let´s encrypt:
2023-07-20 16:30:02,134
EBUG:certbot._internal.main:certbot version: 2.5.0
2023-07-20 16:30:02,135
EBUG:certbot._internal.main:Location of certbot entry point: /usr/bin/certbot
EBUG:certbot._internal.main:Arguments: ['--config', '/etc/letsencrypt.ini', '--work-dir', '/tmp/letsencrypt-lib', '--logs-dir', '/tmp/letsencrypt-log', '--cert-name', 'npm-9', '--agree-tos', '--authenticator', 'webroot', '--email', '
xxx@gmail.com', '--preferred-challenges', 'dns,http', '--domains', 'gitlab.domain.de']
iscovered plugins: PluginsRegistry(PluginEntryPoint#manual,PluginEntryPoint#null,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
2023-07-20 16:30:02,149
EBUG:certbot._internal.log:Root logging level set at 30
2023-07-20 16:30:02,150
EBUG:certbot._internal.plugins.selection:Requested authenticator webroot and installer None
2023-07-20 16:30:02,153
EBUG:certbot._internal.plugins.selection:Single candidate plugin: * webroot
Description: Saves the necessary validation files to a .well-known/acme-challenge/ directory within the nominated webroot path. A seperate HTTP server must be running and serving files from the webroot path. HTTP challenge only (wildcards not supported).
Interfaces: Authenticator, Plugin
Entry point: webroot = certbot._internal.plugins.webroot:Authenticator
Initialized: <certbot._internal.plugins.webroot.Authenticator object at 0x7faeea0a6fd0>
Prep: True
EBUG:certbot._internal.plugins.selection:Selected authenticator <certbot._internal.plugins.webroot.Authenticator object at 0x7faeea0a6fd0> and installer None
2023-07-20 16:30:02,153:INFO:certbot._internal.plugins.selection:Plugins selected: Authenticator webroot, Installer None
2023-07-20 16:30:02,177
EBUG:certbot._internal.main:Picked account: <Account(RegistrationResource(body=Registration(key=None, contact=(), agreement=None, status=None, terms_of_service_agreed=None, only_return_existing=None, external_account_binding=None), uri='
https://acme-v02.api.letsencrypt.org/acme/acct/1216148837', new_authzr_uri=None, terms_of_service=None), 1dbab4fd97b8b94814bea25391fcebab, Meta(creation_dt=datetime.datetime(2023, 7, 20, 14, 0, 25, tzinfo=<UTC>), creation_host='8f55bdca7970', register_to_eff=None))>
2023-07-20 16:30:02,178
EBUG:acme.client:Sending GET request to
https://acme-v02.api.letsencrypt.org/directory.
2023-07-20 16:30:02,180
EBUG:urllib3.connectionpool:Starting new HTTPS connection (1): acme-v02.api.letsencrypt.org:443
2023-07-20 16:30:02,601
https://acme-v02.api.letsencrypt.org:443 "GET /directory HTTP/1.1" 200 752
2023-07-20 16:30:02,602
EBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Thu, 20 Jul 2023 16:30:02 GMT
Content-Type: application/json
Content-Length: 752
Connection: keep-alive
Cache-Control: public, max-age=0, no-cache
X-Frame-Options: DENY
Strict-Transport-Security: max-age=604800
  "D5laZGjKUfc": "
https://community.letsencrypt.org/t/adding-random-entries-to-the-directory/33417",
  "keyChange": "
https://acme-v02.api.letsencrypt.org/acme/key-change",
  "meta": {
    "caaIdentities": [
      "letsencrypt.org"
    "termsOfService": "
https://letsencrypt.org/documents/LE-SA-v1.3-September-21-2022.pdf",
    "website": "
https://letsencrypt.org"
  "newAccount": "
https://acme-v02.api.letsencrypt.org/acme/new-acct",
  "newNonce": "
https://acme-v02.api.letsencrypt.org/acme/new-nonce",
  "newOrder": "
https://acme-v02.api.letsencrypt.org/acme/new-order",
  "renewalInfo": "
https://acme-v02.api.letsencrypt.org/draft-ietf-acme-ari-01/renewalInfo/",
  "revokeCert": "
https://acme-v02.api.letsencrypt.org/acme/revoke-cert"
2023-07-20 16:30:02,603
EBUG:certbot._internal.display.obj:Notifying user: Requesting a certificate for gitlab.domain.de
2023-07-20 16:30:02,609
EBUG:acme.client:Requesting fresh nonce
EBUG:acme.client:Sending HEAD request to
https://acme-v02.api.letsencrypt.org/acme/new-nonce.
2023-07-20 16:30:02,751
https://acme-v02.api.letsencrypt.org:443 "HEAD /acme/new-nonce HTTP/1.1" 200 0
2023-07-20 16:30:02,752
HTTP 200
Server: nginx
Link: <
https://acme-v02.api.letsencrypt.org/directory>;rel="index"
Replay-Nonce: 853FtgPbMVmvqmf3YaF_fjU7fahi0NPSm9kQbyQgGn_dTz0
EBUG:acme.client:Storing nonce: 853FtgPbMVmvqmf3YaF_fjU7fahi0NPSm9kQbyQgGn_dTz0
EBUG:acme.client:JWS payload:
b'{\n  "identifiers": [\n    {\n      "type": "dns",\n      "value": "gitlab.domain.de"\n    }\n  ]\n}'
2023-07-20 16:30:02,754
EBUG:acme.client:Sending POST request to
https://acme-v02.api.letsencrypt.org/acme/new-order:
  "protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvMTIxNjE0ODgzNyIsICJub25jZSI6ICI4NTNGdGdQYk1WbXZxbWYzWWFGX2ZqVTdmYWhpME5QU205a1FieVFnR25fZFR6MCIsICJ1cmwiOiAiaHR0cHM6Ly9hY21lLXYwMi5hcGkubGV0c2VuY3J5cHQub3JnL2FjbWUvbmV3LW9yZGVyIn0",
  "signature": "TTZhGgRUoybTuTZRpvNrJ9qkz6VxAUN96bqNFMza3eG1Cxa1x_I2YZhciZ7GXdCGNpuN4M-T5pSuVc-LzbbvOFoYbnDRJMR6iNmLakNoaCh-AUxOCBvsMIhj1w5qWuinqKiCCzlxX4Xe6ceE07h4HtplQ5tPgyiPufKEMnDjp7ADI_vKopdTqadhgaE7s5oy1yhFcf9EIeggH2KAcVANRRiJqHaxS2Y4aKGIoh7hk4M0myp4Hbl59a3GHAlOWsIxAB4eRoxl-hAVPpMKRKhEw6phLcBCpINKOKV72hbswuI92GsY5wAX-4mkPDcq6KbwKUqsOIEvVLmE93rYpiDtTg",
  "payload": "ewogICJpZGVudGlmaWVycyI6IFsKICAgIHsKICAgICAgInR5cGUiOiAiZG5zIiwKICAgICAgInZhbHVlIjogImdpdGxhYi50ZWNoYmxhemUuZGUiCiAgICB9CiAgXQp9"
2023-07-20 16:30:02,931
https://acme-v02.api.letsencrypt.org:443 "POST /acme/new-order HTTP/1.1" 201 345
2023-07-20 16:30:02,932
HTTP 201
Server: nginx
Content-Length: 345
Boulder-Requester: 1216148837
Link: <
https://acme-v02.api.letsencrypt.org/acme/order/1216148837/196178140397
Replay-Nonce: 2712KCasdvOGBA71TclMQOXh7tN3IZJM8ZBkAQSOTELD5sE
  "status": "pending",
  "expires": "2023-07-27T16:30:02Z",
  "identifiers": [
      "type": "dns",
  "authorizations": [
https://acme-v02.api.letsencrypt.org/acme/authz-v3/247364224947"
  "finalize": "
https://acme-v02.api.letsencrypt.org/acme/finalize/1216148837/196178140397"
EBUG:acme.client:Storing nonce: 2712KCasdvOGBA71TclMQOXh7tN3IZJM8ZBkAQSOTELD5sE
b''
2023-07-20 16:30:02,934
https://acme-v02.api.letsencrypt.org/acme/authz-v3/247364224947:
  "protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvMTIxNjE0ODgzNyIsICJub25jZSI6ICIyNzEyS0Nhc2R2T0dCQTcxVGNsTVFPWGg3dE4zSVpKTThaQmtBUVNPVEVMRDVzRSIsICJ1cmwiOiAiaHR0cHM6Ly9hY21lLXYwMi5hcGkubGV0c2VuY3J5cHQub3JnL2FjbWUvYXV0aHotdjMvMjQ3MzY0MjI0OTQ3In0",
  "signature": "TR7HBBQU6Dmi_ikS5at4LBzWSMEpoRxULOsBO6mGGfiBfHSQU46QmRCb1PJFV0zgmOej5vX-YxWKIe4SKn98GczFqwnQsZUkp0XON_Ud7E1il_DgIPz1ioAtrO6w9MuEVIuJhnpyzuEB7G5m1MOEs1mfGvO1anWdwPyqIFN1dl6kOzceF2_xSTN_bT4AxPsdaqHdn4-OYFMUpqdUCvunPMB1zi_-RezsVkxR5No3baCT5gR5CLQAvgELMVSX-Vwfwju6PMVGGw_usaPFmwZq0l2wbfPxL9hVzlzAi286ofKWPT5EcRe60JadjT45Sr4z9WZ8Ze0DdGcNjA6ADKiifg",
  "payload": ""
2023-07-20 16:30:03,077
https://acme-v02.api.letsencrypt.org:443 "POST /acme/authz-v3/247364224947 HTTP/1.1" 200 803
HTTP 200
Server: nginx
Date: Thu, 20 Jul 2023 16:30:03 GMT
Content-Length: 803
Link: <
Replay-Nonce: 2712TwM-km-9z0UIXAusVIChUNRacMA6uKHsMpYr3JumDcM
  "identifier": {
    "type": "dns",
  "challenges": [
      "type": "http-01",
      "url": "
https://acme-v02.api.letsencrypt.org/acme/chall-v3/247364224947/Plia0Q",
      "token": "JyMzJfoSPJ-WsZeQYR14d6EU6MJ-1nZWCUl4nuV02tc"
      "type": "dns-01",
      "url": "
https://acme-v02.api.letsencrypt.org/acme/chall-v3/247364224947/XtPb2g",
      "type": "tls-alpn-01",
      "url": "
https://acme-v02.api.letsencrypt.org/acme/chall-v3/247364224947/W6ut4Q",
2023-07-20 16:30:03,078
EBUG:acme.client:Storing nonce: 2712TwM-km-9z0UIXAusVIChUNRacMA6uKHsMpYr3JumDcM
2023-07-20 16:30:03,078:INFO:certbot._internal.auth_handler:Performing the following challenges:
2023-07-20 16:30:03,078:INFO:certbot._internal.auth_handler:http-01 challenge for gitlab.domain.de
2023-07-20 16:30:03,079:INFO:certbot._internal.plugins.webroot:Using the webroot path /data/letsencrypt-acme-challenge for all unmatched domains.
EBUG:certbot._internal.plugins.webroot:Creating root challenges validation dir at /data/letsencrypt-acme-challenge/.well-known/acme-challenge
2023-07-20 16:30:03,081
EBUG:certbot._internal.plugins.webroot:Attempting to save validation to /data/letsencrypt-acme-challenge/.well-known/acme-challenge/JyMzJfoSPJ-WsZeQYR14d6EU6MJ-1nZWCUl4nuV02tc
2023-07-20 16:30:03,083
b'{}'
2023-07-20 16:30:03,084
https://acme-v02.api.letsencrypt.org/acme/chall-v3/247364224947/Plia0Q:
  "protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvMTIxNjE0ODgzNyIsICJub25jZSI6ICIyNzEyVHdNLWttLTl6MFVJWEF1c1ZJQ2hVTlJhY01BNnVLSHNNcFlyM0p1bURjTSIsICJ1cmwiOiAiaHR0cHM6Ly9hY21lLXYwMi5hcGkubGV0c2VuY3J5cHQub3JnL2FjbWUvY2hhbGwtdjMvMjQ3MzY0MjI0OTQ3L1BsaWEwUSJ9",
  "signature": "vxYnGIwrPtHEs7ISTbu0MUwmAseiC0s_9oWKNjFJbNWQNfd4EWbtyF-cTCyrR-vcoMt31O322-0UlroEihRDmkVgU49CZ-oUf6iSXOB1AiC-Yb6zzgr7pi8VFonkgiesPiSPqjBRKlrRRKoyiTRVyo4v6e2ZOH4MDnerSRzNyomUghL_Txi0cN45UK9ZYXMOiuarf3hCfYJyKV4mffgvkqxZyiVVIU3_KY4LlWGhJu9heZNjW5ax3Oh_fkG78F83p1wqzkKfaY9Ng38g7-mH4MNlnYb6PxQmnlyPKMZi1lFIrthZp1IzWwSYUYKjVpCM-RCP4yrtgOB0blp4mNLaKw",
  "payload": "e30"
2023-07-20 16:30:03,232
https://acme-v02.api.letsencrypt.org:443 "POST /acme/chall-v3/247364224947/Plia0Q HTTP/1.1" 200 187
2023-07-20 16:30:03,233
HTTP 200
Server: nginx
Content-Length: 187
Link: <
https://acme-v02.api.letsencrypt.org/directory>;rel="index", <
https://acme-v02.api.letsencrypt.org/acme/authz-v3/247364224947>;rel="up"
Replay-Nonce: 2712xKnxNrZfBr5DxuaYWOlbaaHyfnHkXp3_6aFcoTFRXcc
  "type": "http-01",
  "url": "
EBUG:acme.client:Storing nonce: 2712xKnxNrZfBr5DxuaYWOlbaaHyfnHkXp3_6aFcoTFRXcc
2023-07-20 16:30:03,234:INFO:certbot._internal.auth_handler:Waiting for verification...
2023-07-20 16:30:04,235
b''
2023-07-20 16:30:04,237
  "protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvMTIxNjE0ODgzNyIsICJub25jZSI6ICIyNzEyeEtueE5yWmZCcjVEeHVhWVdPbGJhYUh5Zm5Ia1hwM182YUZjb1RGUlhjYyIsICJ1cmwiOiAiaHR0cHM6Ly9hY21lLXYwMi5hcGkubGV0c2VuY3J5cHQub3JnL2FjbWUvYXV0aHotdjMvMjQ3MzY0MjI0OTQ3In0",
  "signature": "yRW43CMZz-b6bsBIu14w9aRKbwuETYGY-J2d3RECUivnGR58uoBLloNgytq2pgUqEdyPYctfd2RovYzrEhwuKsUbW9SxqBSk4QW0xjMNkiuKgEUAVpqYpVusZgws0UhaAkohFVCWThzudNP_zRK0ZJPpUv7PxF906SKXsQIIgfuB-hoUIY7HfrqOwZlJFzHvkRLiVXpyahkr2CixlZlkcupkyC4Xp6weUwe9ep9qIS0-Vkab21ZTqqw6GS86d4aUYtzM65DeiyhQ9_kLH6zIPxk_bs9xBKy_rwGfATQ_oMA8JJBcUaykylaccgabbsXS19fr-vPA3dIHkFD4NCNzEw",
  "payload": ""
2023-07-20 16:30:04,380
https://acme-v02.api.letsencrypt.org:443 "POST /acme/authz-v3/247364224947 HTTP/1.1" 200 1044
2023-07-20 16:30:04,381
HTTP 200
Server: nginx
Date: Thu, 20 Jul 2023 16:30:04 GMT
Content-Length: 1044
Link: <
Replay-Nonce: 2712bLg_oFWMAlk_Rt4ukCOnyloR9tZn3yGKDciqLZ36Ads
  "identifier": {
    "type": "dns",
  "status": "invalid",
  "challenges": [
      "type": "http-01",
      "error": {
        "type": "urn:ietf
arams:acme:error:unauthorized",
        "detail": "212.227.xx.xx: Invalid response from
http://gitlab.domain.de/.well-known/acme-challenge/JyMzJfoSPJ-WsZeQYR14d6EU6MJ-1nZWCUl4nuV02tc: 502",
        "status": 403
      "url": "
      "token": "JyMzJfoSPJ-WsZeQYR14d6EU6MJ-1nZWCUl4nuV02tc",
      "validationRecord": [
          "url": "
http://gitlab.domain.de/.well-known/acme-challenge/JyMzJfoSPJ-WsZeQYR14d6EU6MJ-1nZWCUl4nuV02tc",
          "hostname": "gitlab.domain.de",
          "port": "80",
          "addressesResolved": [
            "212.227.xx.xx"
          "addressUsed": "212.227.xx.xx"
      "validated": "2023-07-20T16:30:03Z"
EBUG:acme.client:Storing nonce: 2712bLg_oFWMAlk_Rt4ukCOnyloR9tZn3yGKDciqLZ36Ads
2023-07-20 16:30:04,381:INFO:certbot._internal.auth_handler:Challenge failed for domain gitlab.domain.de
2023-07-20 16:30:04,382:INFO:certbot._internal.auth_handler:http-01 challenge for gitlab.domain.de
Certbot failed to authenticate some domains (authenticator: webroot). The Certificate Authority reported these problems:
  Domain: gitlab.domain.de
  Type:   unauthorized
  Detail: 212.227.xx.xx: Invalid response from
Hint: The Certificate Authority failed to download the temporary challenge files created by Certbot. Ensure that the listed domains serve their content from the provided --webroot-path/-w and that files created there can be downloaded from the internet.
EBUG:certbot._internal.error_handler:Encountered exception:
Traceback (most recent call last):
  File "/opt/certbot/lib/python3.7/site-packages/certbot/_internal/auth_handler.py", line 108, in handle_authorizations
    self._poll_authorizations(authzrs, max_retries, max_time_mins, best_effort)
  File "/opt/certbot/lib/python3.7/site-packages/certbot/_internal/auth_handler.py", line 212, in _poll_authorizations
    raise errors.AuthorizationError('Some challenges have failed.')
certbot.errors.AuthorizationError: Some challenges have failed.
EBUG:certbot._internal.error_handler:Calling registered functions
2023-07-20 16:30:04,382:INFO:certbot._internal.auth_handler:Cleaning up challenges
2023-07-20 16:30:04,383
EBUG:certbot._internal.plugins.webroot:Removing /data/letsencrypt-acme-challenge/.well-known/acme-challenge/JyMzJfoSPJ-WsZeQYR14d6EU6MJ-1nZWCUl4nuV02tc
EBUG:certbot._internal.plugins.webroot:All challenges cleaned up
EBUG:certbot._internal.log:Exiting abnormally:
  File "/usr/bin/certbot", line 8, in <module>
    sys.exit(main())
  File "/opt/certbot/lib/python3.7/site-packages/certbot/main.py", line 19, in main
    return internal_main.main(cli_args)
  File "/opt/certbot/lib/python3.7/site-packages/certbot/_internal/main.py", line 1864, in main
    return config.func(config, plugins)
  File "/opt/certbot/lib/python3.7/site-packages/certbot/_internal/main.py", line 1597, in certonly
    lineage = _get_and_save_cert(le_client, config, domains, certname, lineage)
  File "/opt/certbot/lib/python3.7/site-packages/certbot/_internal/main.py", line 141, in _get_and_save_cert
    lineage = le_client.obtain_and_enroll_certificate(domains, certname)
  File "/opt/certbot/lib/python3.7/site-packages/certbot/_internal/client.py", line 516, in obtain_and_enroll_certificate
    cert, chain, key, _ = self.obtain_certificate(domains)
  File "/opt/certbot/lib/python3.7/site-packages/certbot/_internal/client.py", line 428, in obtain_certificate
    orderr = self._get_order_and_authorizations(csr.data, self.config.allow_subset_of_names)
  File "/opt/certbot/lib/python3.7/site-packages/certbot/_internal/client.py", line 496, in _get_order_and_authorizations
    authzr = self.auth_handler.handle_authorizations(orderr, self.config, best_effort)
2023-07-20 16:30:04,384:ERROR:certbot._internal.log:Some challenges have failed.
