[Sammelthread] MSI MEG X570(S) Unify (X MAX) / ACE (MAX) (AM4)
product_10_20191002132606_5d9434ee62129.pngproduct_9_20190723092258_5d3661724d540.pngproduct_1629079667f4b88b2d70e858818adcfd4767cd52a2.pngproduct_1629094385a72f0a5d4a37c30deff6b3dcba91659c.png
Sammelthread für das MSI MEG x570 Unify/ACE
Herstellerseite:
MEG X570 UNIFY
Herstellerseite: MEG X570 ACE
Herstellerseite: MEG X570S ACE MAX
Herstellerseite: MEG X570S UNIFY-X MAX
Reviews:
MSI MEG X570 UNIFY Review - Introduction
MSI MEG X570 Unify motherboard (updated)
MSI MEG X570 Unify: An All-Black Motherboard
MSI MEG X570 Unify kommt ohne RGB aus
MSI MEG X570 Unify | Tom's Hardware
MSI MEG X570 ACE Infinity | Hardwareluxx
MSI MEG X570 Ace Motherboard Review
MSI MEG X570 Ace - Review 2019 - PCMag UK
MSI MEG X570 ACE - Hardware Journal
MSI MEG X570 ACE - Review
MSI MEG X570S ACE MAX - digideutsche
MSI MEG X570S ACE MAX - wccftech
MSI MEG X570S ACE MAX - IT Info
MSI MEG X570S UNIFY-X MAX - geeknetic
Besonderheiten:
  • Supports 2nd and 3rd Gen AMD Ryzen™ / Ryzen™ with Radeon™ Vega Graphics and 2nd Gen AMD Ryzen™ with Radeon™ Graphics Desktop Processors for AM4 socket
  • Supports DDR4 Memory, up to 5000+(OC) MHz
  • Aluminum Cover with Extended Heatsink: All-metal extended heatsink cover enlarge the surface of heat dissipation, ensures even high-end processors to run in full speed.
  • Lightning Fast Game Experience: PCIe 4.0, Triple Lightning Gen4 x4 M.2 with M.2 Shield Frozr, StoreMI, AMD Turbo USB 3.2 Gen2.
  • 2.5G Gaming LAN with Latest Wi-Fi 6 Solution: Onboard 2.5G LAN with gaming LAN manager, combining latest Wi-Fi 6 solution which supports MU-MIMO and BSS color technology, delivering the best online gaming experience.
  • Frozr Heatsink Design: Designed with the patented fan and double ball bearings to provide the best performance for enthusiast gamers and prosumers.
  • Audio Boost HD: Isolated audio with dedicated processor combining ESS audio DAC with amplifier, deliver the breathtaking, game-changing sound to create the most exciting gameplay.
  • Pre-installed I/O Shielding: Better EMI protection and more convenience for installation
  • ACE: Mystic Light Infinity, Dual LAN, Extended Heat-pipe Design
Spezifikationen Unify/ACE/ACE MAX/Unify X:
SOCKET:
AM4
CPU (MAX SUPPORT): Ryzen 9
CHIPSET:
AMD® X570 Chipset
DDR4 MEMORY: 1866/ 2133/ 2400/ 2667/ 2800/2933 /3000 /3066 /3200 /3466 /3600 /3733 /3866 /4000 /4133 /4266 /4400 /4533 /4600 /4733 /4800 /5000+ Mhz by JEDEC and A-XMP OC MODE
MEMORY CHANNEL: Dual
DIMM SLOTS: 2/4
MAX MEMORY (GB): 128GB
PCI-E X16: 3
PCI-E X1: 2
SATAIII: 4
M.2 SLOT: 3/4/6
RAID: 0/1/10
TPM (HEADER): 1
LAN UNIFY/UNIFY X: 1x Realtek® RTL8125 2.5 Gbps
LAN ACE/ACE MAX: 1x Intel® WGI211AT Gigabit / Intel® Wi-Fi 6E AX210, 1x Realtek® RTL8125 2.5 Gbps
USB 3.2 PORTS (FRONT): 1(Gen2, Type C), 4(Gen1, Type A)
USB 3.2 PORTS (REAR): 1(Gen2, Type C), 3(Gen2, Type A), 2(Gen1, Type A)
USB 2.0 PORTS (FRONT): 4
USB 2.0 PORTS (REAR): 2
AUDIO PORTS (REAR): 5+ Optical S/PDIF (Realtek® ALC1220 Codec)
DIRECTX: 12
FORM FACTOR: ATX
SLI: Y
CROSSFIRE: Y
OPERATING SYSTEM: Support for Windows® 10 64-bit
MSI Support bei hwluxx.
Hier ein paar Bilder zu denn Boards:
Naja, für den Chipsatz und SoC.
kann mir jemand sagen wie die kleinen plastik teile heiten die im PCIe slot sitzen wo die grafikkarte einklickt damit sie fest sitzt ? ich würde gern eine nachkaufen
Edit: Tjoa... man sollte auch das Bios der GraKa aktualisieren - tut´s jetzt ;)
Mh... ich bekomme die Resizable Bar nicht aktiviert.
Daten:
MSI MEG X570 Unify
AMD Ryzen 5900
NVidia RTX 3080 FE
Bios-Version: 7C35vAx (neueste vom August diesen Jahres)
GraKa-Treiber Version: 527.56 (laut GeForce Experience auch die neueste Version)
Einstellungen im Bios:
RBar enabled
Mining enabled
Boot-Option UEFI
GPU-Z als auch GeForce Systemeinstellungen zeigen mir RBar als nicht aktiv an. Ersteres sagt, dass das im Bios nicht aktiviert wurde (was es aber ist):
Einmal cmos reset durchführen
Danach mal bitte einen Screenshot von der BIOS Seite mit rebar posten
Hi Leute ich mal wieder.
Ich habe seltsames Phänomen bei meinem Unify.
Ich habe es bei AE Beta2 und AE Final Bios.
Ich habe Kombostirke 3 Aktiv.
Die CPU fragt 4,5 Ghz in single von Core 0 ab effektiv werde 4,45Ghz gefahren ohne OC
Ich fahre Bclk OC mit 4,55 allcore.
Die CPU fragt 4,65 Ghz im Single von Core 0 ab effektiv werden 4,45 gefahren.
Alle Cores laufen auf 4,55 außer Core 0 dieser wieder mit 4,45
Als wäre der Takt festgesetzt.
Hat jemand eine Idee dazu?
Ich musste mein Bios der Grafikkarte updaten um Resizable Bar verwenden zu können. Hatte meine 3080 TUF im Dezember nach Release gekauft und das Bios war nicht auf dem neusten Stand. Wenn deine 3080 schon älter ist oder einer der ersten Batches ist könnte es daran liegen.
Über das Handy werden die Signaturen glaube ich nicht angezeigt, daher meine Nachfrage.
Keine Ahnung was der Takt genau bei dir macht, aber meine persönliche Empfehlung wäre den 5800x3d einfach Stock ohne irgendwelche unnötigen Veränderunge laufen zu lassen.
AFAIK kann man durch Combostrike oder UV (je nachdem was am MB freigeschalten ist) keinen relevanten Performance-Boost erreichen.
Hiho,
eventuell für den einen oder anderen ganz interessant:
MSI has very insecure Secure Boot defaults​
Kann man das irgendwie beheben?
ja kannst du...
Hatte gestern meinen Custom Loop mehrfach zerlegt und verschiedene Kombinationen und Durchflussmengen gemessen... Am Ende wieder alles zusammen und noch ein paar Benches laufen lassen, alles okay soweit. Seit heute mittag hatte ich jetzt freezes und jetzt gehen meine Rams nur noch in den A-Slots. Timings etc sind egal, habe 2x16GB Gskil FlareX B-Dies und mit dem 5800X3D jetzt immer XMP auf 3200 CL14 an, um den Idle Verbrauch zu senken.
Egal in welcher Kombi, in den B-Slots geht keiner der 2 Riegel, egal welche Timings. Er springt von Post Code 15 auf 0D und verharrt dann da. Habe Sie jetzt beide in den A-Slots (XMP an geht auch), also nur Single Channel, aber das funktioniert.
Hab ich mir irgendwie mit einem Spritzer Wasser irgendwo das Board zerlegt? Bin etwas ratlos :/
Hi ich würde ich CPU nochmals aus dem Sockel nehmen alle Pins überprüfen und den Kühler wieder frisch aufsetzen.
Sowas kann auch durch zuviel Anpressdruck kommen.
Hab Mal den kühler lockerer und wieder fester gedreht, das hat nichts geändert. Hab den Rechner dann 2 Tage stehen lassen und dann lief es wieder. Ka was das war, hoffe es kommt nicht wieder :fresse:
Für das MEG X570 UNIFY und ACE hat MSI nun ein neues Beta-BIOS mit AGESA 1.2.0.8 veröffentlicht.
Das ist auch das MEG X570S UNIFY-X MAX. Doch auch für dieses Modell sollte es bald losgehen.
ja. Keine Auffälligkeiten. Für den X3D ist nun der Curve Optimizer verfügbar.
Wie siehts mit PPT, EDC und TDC aus?
Naben, habe mir einen 5800x3d geholt und habe auf die beta der AGESA 1.2.0.8 geflasht. Wenn ich jetzt im Bios den CO benutze limitiert das Mainboard automatisch meine EDC der CPU von 140 auf 130 A. Ist das vielleicht ein Bug oder so gewollt? PTT, TDC und EDC kann man nicht einstellen. Vielleicht hat ja wer von euch auch so eine Beobachtung gemacht.
Hallo zusammen, weis einer ob man mit dem neuen Beta Bios vom ACE PBO und curve optimizer beim x3d nutzen kann?
Beim Unify kann man nur den Curve Optimizer anschalten und die Werte setzen. PTT,TDC und EDC kann man nichts verstellen. Das wird beim ACE nicht anders sein.
ja solangs das menü gibt mit dem Curve Optimizer, kann man das auch für jeden kern einstellen?
Ähnliche Themen
