[Sammelthread] Sammelthread für Temperaturvergleich 4090 Kühler
hithunter
Testprogramm:
MSI Kombuster 4.1.17.0
Benchmark:
Preset 2160
Auflösung:
UHD
Testzeit:
10 Minuten
Sensoren:
GPU Einlass
GPU Auslass (optional)
Tabelle
UserKühlungModellWasserkühlerPØ [W]GPU Takt [MHz]VRAM Takt [MHz]Durchfluss [L/h]Gehäuselufttemp. [°C]Ansaug Luftemperatur [°C]Wasser GPU Einlass [°C]Wasser GPU Auslass [°C]GPU Speicher [°C]GPU [°C]Hotspot [°C]dT Speicher [K]dT GPU [K]dT GPU 350 W Boardpower [K]dT GPU 400 W Boardpower [K]dT GPU 450 W Boardpower [K]dT GPU 600 W Boardpower [K]
"hithunter"LuftINNO3D iChill X3
425​
2820​
10502​
26​
68​
71,5​
80,9​
42​
45,5​
35,6​
43,1​
50,7​
73,4​
"hithunter"WasserINNO3D iChill X3Alphacool Referenz
410​
2850​
10502​
177​
24​
33,8​
35,8​
44​
49,7​
60,2​
10,2​
15,9​
13,1​
15,8​
18,6​
26,8​
BesterinoWasserINNO3D FrostbiteINNO3D (Alphacool)
412​
2850​
10502​
176​
31​
25,5​
27,8​
44​
48,2​
56,6​
16,2​
20,4​
16,7​
20,2​
23,7​
34,2​
405​
2850​
10502​
140​
31​
25,5​
27,9​
44​
49,6​
58,4​
16,1​
21,7​
18,2​
22,0​
25,8​
37,1​
Felix The CatWasserMSI RTX 4090 SUPRIM X 24GPhanteks Glacier G40 MSI
432​
2805​
10502​
246​
25,4​
28,7​
42​
53​
63,2​
13,3​
24,3​
18,5​
22,5​
26,5​
38,4​
HisNWasserAsus TUFPhanteks Glacier
385​
2760​
10502​
24​
28​
48​
56,7​
20​
18,1​
21,7​
25,4​
36,4​
dante`afkWasserFEEKWB Vector2 + active BP
410​
2760​
10502​
244​
25,6​
27​
34​
45​
53​
8,4​
19,4​
16,0​
19,3​
22,7​
32,7​
LDWasserAsus StrixEKWB Vector2
410​
2745​
10501​
135​
26,9​
23​
27,6​
29,8​
48​
48,5​
50,8​
20,4​
20,9​
17,2​
20,8​
24,4​
35,2​
MoebiusbandWasserZotac Trinity OCBykski
441​
2805​
10702​
186​
20​
29,3​
30,5​
52​
49,5​
56,6​
22,7​
20,2​
14,9​
18,2​
21,4​
31,1​
1972erWasserKFA2Alphacool Ref.
388​
2745​
10501​
118​
24​
32​
40​
50​
58​
8​
18​
16,1​
19,3​
22,6​
32,5​
1972erWasserKFA2Alphacool Referenz
395​
2970​
11501​
122​
22​
22,1​
30​
41​
47,6​
7,9​
18,9​
16,4​
19,8​
23,2​
33,4​
AhrimaanWasserZotac Trinity UVBykski
371​
2955​
11702​
123​
21​
28,2​
48​
45​
53​
19,8​
16,8​
16,0​
19,2​
22,4​
32,0​
carapaoWasserAsus Tuf OCEKWB Vector2
386​
2775​
10501​
91​
24,3​
28​
47​
53​
64​
22,7​
28,7​
25,8​
31,1​
36,3​
52,1​
postmymindWasserAsus TUFEKWB Vector²
403​
2775​
10502​
140​
27,2​
21​
27,6​
48​
56,2​
69,3​
20,4​
28,6​
24,2​
29,2​
34,2​
49,3​
xl_digitWasserFEEKWB Vector2
409​
2760​
10502​
189​
21,1​
24,7​
26,8​
42​
43,3​
54,8​
17,3​
18,6​
15,4​
18,6​
21,8​
31,5​
YoungtimerLuftAsus TUF
427​
2700​
10502​
20​
62​
62,7​
73,4​
42​
42,7​
33,1​
40,2​
47,3​
68,5​
timOCWasser + G48Inno3D X3 OCBykski Referenz
388​
2745​
10502​
72​
22​
32,7​
36,7​
58​
52,9​
63,4​
25,3​
20,2​
18,0​
21,7​
25,4​
36,4​
rzlr_hwlxWasserFEEKWB Vector²
363​
2760​
10502​
230​
20,5​
24,6​
26​
36​
44,1​
52,9​
11,4​
19,5​
19,1​
22,9​
26,7​
38,0​
lmarkuslWasserAsus TUFEKWB Vector²
430​
3015​
12101​
130​
32,9​
46​
61​
72,8​
13,1​
28,1​
21,6​
26,2​
30,8​
44,7​
366​
2760​
10501​
130​
32,6​
46​
56,3​
66,4​
13,4​
23,7​
23,0​
27,6​
32,1​
45,9​
Samy355WasserZotac 4090 AMPBykski
440​
2775​
10501​
190​
25​
48​
49​
59,4​
23,0​
24,0​
17,8​
21,7​
25,5​
37,1​
Samy355WasserZotac 4090 AMPBykski (modifiziert)
440​
2775​
10501​
190​
24,9​
36​
39,2​
47,6​
11,1​
14,3​
10,6​
12,9​
15,2​
22,1​
bisonigorWasserAsus Strix OC (stock)EKWB Vector²
428​
2760​
10502​
195​
26,5​
28,4​
42​
48,2​
57​
15,5​
21,7​
16,8​
20,4​
24,0​
34,7​
bisonigorWasserAsus Strix OC (uv)EKWB Vector²
359​
2730​
10502​
194​
26,7​
28,3​
40​
42,7​
49,9​
13,3​
16​
15,9​
19,1​
22,2​
31,7​
bisonigorWasserAsus Strix OC (oc)EKWB Vector²
525​
3090​
12250​
197​
28,7​
31​
48​
55,3​
66,2​
19,3​
26,6​
14,9​
18,5​
22,1​
32,8​
HalogengurkeWasserAsus Strix OCEKWB Vector²
393,5​
2775​
10502​
189​
31,3​
23,4​
31,4​
33,2​
40​
46,4​
52,5​
8,6​
15​
13,1​
15,8​
18,5​
26,6​
Hast du einfach "stock" Werte genommen? Also alles wie out-of-the-box und mit Standard 100% Power Limit?
solltest dann auch hinschreiben ob mit stock oder OC Settings.
@hithunter: wie lässt Du denn das Ding 10Min am Stück laufen? Bin zu blöd... und welchen Stress test nimmst Du? "(GL) msi-01"?
Kein Stresstest, einfach die Auflösung einstellen und dann auf den Button "Benchmark - Preset 2160" drücken und fertig. Nach 10 Minuten einfach Escape drücken.
425​
2820​
10502​
26​
68​
71,5​
80,9​
42​
45,5​
410​
2850​
10502​
177​
24​
33,8​
35,5​
44​
49,7​
60,2​
10,2​
15,9​
(Alphacool)
4052850105021763125,527,84448,256,6
Anmerkungen:
Wasser-Auslass (inkl. CPU und Netzwerkkarte im Kreislauf): 32°C
GPU Einlass gemessen ist noch vor 3x DDC.
Radi: 2 Mora3/420 mit 16x 200er Noctuas, Lüfter auf volle Pulle.
Mit meinen normalen Settings (lüfter lautlos, Durchfluss ca. 140l/h) zum Vergleich:
425​
2820​
10502​
26​
68​
71,5​
80,9​
42​
45,5​
410​
2850​
10502​
177​
24​
33,8​
35,5​
44​
49,7​
60,2​
10,2​
15,9​
(Alphacool)
4122850105021763125,527,84448,256,6
BesterinoWasserINNO3D FrostbiteINNO3D (Alphacool)4052850105021403125,527,94449,658,4
Dann lieber lautlos. :d
Das ist mein erster Test. Aktuell mit 1x Mora 420 und 1x 480er intern.
Kommt noch ein Mora 360 dazu. Noch Pumpen mit 100% um Luft aus dem System zu bekommen.
Der Phanteks scheint auf jeden Fall schlechter als der Alphacool zu sein. Hoffe der für die MSI kommt auch bald. ;)
425​
2820​
10502​
26​
68​
71,5​
80,9​
42​
45,5​
410​
2850​
10502​
177​
24​
33,8​
35,5​
44​
49,7​
60,2​
10,2​
15,9​
(Alphacool)
Felix The CatWasserMSI RTX 4090 SUPRIM X 24GPhanteks Glacier G40 MSI43228051050224625,428,7425363,214,224,3
Aber nach einer Minute ist der Benchmark durch, dann kommt das "Submit"-Fenster, und dann geht die Temperatur deutlich runter. Ist das von Dir gewollt?
Also ich habe den Stress-Test gemacht, weil der Benchmark halt dann einfach vorbei war.
Der Benchmark läuft ca. eine Minute mit ~ 2800 Mhz und 420 - 440 W. Das Submit Fenster aber mit konstant 2850 Mhz und durchschnittlich ziemlich konstant mit 410 W. Aber vielleicht limitiert auch deine CPU zu stark oder die Auflösung stimmt nicht. Dann einfach einen vergleichbaren Test.
Wenn Du das so möchtest, dann ist das doch gut. Dann mach ich das genau so wie Du es beschrieben hast. War übrigens mein Fehler. Framelimiter bei 118 FPS, die im Stresstest genügen für 100% Load, aber danach nicht mehr^^
425​
2820​
10502​
26​
68​
71,5​
80,9​
42​
45,5​
410​
2850​
10502​
177​
24​
33,8​
35,5​
44​
49,7​
60,2​
10,2​
15,9​
(Alphacool)
HisNWasserAsus TUFPhanteks Glacier38527601050224284856,720
"hithunter"LuftINNO3D iChill X3425282010502266871,580,94245,5
"hithunter"WasserINNO3D iChill X3Alphacool Referenz4102850105021772433,835,54449,760,210,215,9
(Alphacool)
dante`afkWasserFEEKWB Vector2 + active BP41027601050224425.627344553919
BesterinoWasserINNO3D FrostbiteINNO3D (Alphacool)4122850105021763125,527,84448,256,616,220,4
BesterinoWasserINNO3D FrostbiteINNO3D (Alphacool)4052850105021403125,527,94449,658,416,121,7
Felix The CatWasserMSI RTX 4090 SUPRIM X 24GPhanteks Glacier G40 MSI43228051050224625,428,7425363,213,324,3
dante`afkWasserFEEKWB Vector2 + active BP41027601050224425,6273445538,419,4
LDWasser Asus StrixEKWB Vector241027451050113526,92327.629.84848.558.520,420.9
hmm, lande hier eher bei GPU 57 Grad. :confused: Asus Tuf mit EKWB Vector 2. Gekühlt mit einem MO-RA 420 und einem 360er internen Radi
LDWasserAsus StrixEKWB Vector241027451050113526,92327.629.84848.558.520,420.9
MoebiusbandWasserZotac Trinity OCBykski4412805107021862029,330,55249,556,621,519
1972erWasserKFA2Alphacool Ref.3882745105011182432405058818
Mal mit anderer Paste auf den Rams und Mosfets und etwas OC. Chiller an.
1972erWasserKFA2
KFA2 OC (moderat)
Alphacool Ref.388
395
2745
2970
10501
11501
118
122
24
22
32
22.1
40
30
50
41
58
47,6
8
7,9
18
18,9
1972erWasserKFA2
KFA2 OC (moderat)
Alphacool Ref.388
395
2745
2970
10501
11501
118
122
24
22
32
22.1
40
30
50
41
58
47,6
8
7,9
18
18,9
AhrimaanWasserZotac Trinity UVBykski3712955117021232128,24845532017
1972erWasserKFA2
KFA2 OC (moderat)
Alphacool Ref.388
395
2745
2970
10501
11501
118
122
24
22
32
22.1
40
30
50
41
58
47,6
8
7,9
18
18,9
carapaoWasserAsus Tuf OCEKWB Vector238627751050191284753641925
1972erWasserKFA2
KFA2 OC (moderat)
Alphacool Ref.388
395
2745
2970
10501
11501
118
122
24
22
32
22.1
40
30
50
41
58
47,6
8
7,9
18
18,9
postmymindWasserAsus TUFEKWB Vector²40327751050214027,22127,64856,269,320,428,6
1972erWasserKFA2
KFA2 OC (moderat)
Alphacool Ref.388
395
2745
2970
10501
11501
118
122
24
22
32
22.1
40
30
50
41
58
47,6
8
7,9
18
18,9
xl_digitWasserFEEKWB Vector240927601050218921.124.726.84243.454.8
17.3
18.7
@xl_digit Du hast eine alte Version der Tabelle genommen.
habe es korrigiert.
1972erWasserKFA2
KFA2 OC (moderat)
Alphacool Ref.388
395
2745
2970
10501
11501
118
122
24
22
32
22.1
40
30
50
41
58
47,6
8
7,9
18
18,9
17.3
18.7
YoungtimerLuftAsus TUF427270010502206262,773,44253,4
Meine TUF ist gestern von Alphacool zurück gekommen. Dort wurde sie auseinander und wieder zusammen gebaut. Wollte die Werte hier mal einfließen lassen.
Beim Kombustor habe ich noch ne Frage. Stellt Resoltion auf 3840x2160 und dann RUN stress test. Oder einfach Benchmark - Preset 2160 und lasst nach dem Benchmark noch ein paar Minuten das Bild weiter laufen?
1972erWasserKFA2
KFA2 OC (moderat)
Alphacool Ref.388
395
2745
2970
10501
11501
118
122
24
22
32
22.1
40
30
50
41
58
47,6
8
7,9
18
18,9
17.3
18.7
timOCWasser + G48Inno3D X3 OCBykski Referenz388274510502722232.736.75852.963.425.320.2
Ganz schön hohe Vram Temps. Die Bykski Pads sind echt nicht gut, die tausche ich beizeiten noch mal aus.
Habe LM von Thermal Grizzly verwendet.
Für die Backplate habe ich die Original Pads der Inno3D Backplate wiederverwendet. Die wird auch recht heiß im Betrieb... von wegen da werden keine Pads benötigt.
Beachtet, dass GPU-Einlass-Temp vor der CPU ist, also könnte man noch ca. 0,3K bei den Deltas abziehen.
Kühler war Selbstimport aus China für 80€ mit ca. 2 Wochen Versandzeit. Kam überraschenderweise per Luftpost ohne Extrakosten.
1972erWasserKFA2
KFA2 OC (moderat)
Alphacool Ref.388
395
2745
2970
10501
11501
118
122
24
22
32
22.1
40
30
50
41
58
47,6
8
7,9
18
18,9
17.3
18.7
rzlr_hwlxWasserFEEKWB Vector²36327601050223020,5263644,152,9
Can das 2160 preset nicht starten weil 3440x1440. Can man den Laden nicht dazu forcieren in 4k zu starten?
@rzlr_hwlx magst du noch deine Deltas nachtragen? ;)
