Driver Easy TXT Report
Binaries
Driver Easy version v5.7.0
Overview
Machine MSI - MS-7972
Operating System Microsoft Windows 10 Pro (64-bit)
Memory 16 GB
Processor Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz
Motherboard MSI - B150M MORTAR (MS-7972)
Video Cards Radeon (TM) RX 480 Graphics
Monitors OMEN X 25f
Hard Disk Samsung SSD 750 EVO 250GB (250,0 GB)
Network Card Realtek PCIe GbE Family Controller
CPU
Processor
Name Intel Core i5 6500
Code Name Skylake
TDP 65 W
Package Socket 1151 LGA
Technology 14 nm
Core Voltage 1,19 V
Specification Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz
Family 6
Model --
Stepping --
Ext. Family --
Ext. Model --
Revision R0
Instructions MMX , SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, x86-64, NX, VMX, AES, AVX, AVX2, FMA3, TSX
Clocks
Core Speed 3393,4 MHz
Multiplier x 34
Bus Speed 99,8 MHz
QPILink --
Cache
L1 Data 4 x 32 KBytes
L1 Inst 4 x 32 KBytes
Level 2 4 x 256 KBytes
Level3 6144 KBytes
Motherboard
Motherboard
Manufacturer MSI
Model B150M MORTAR (MS-7972) 2.0
Chipset Intel Skylake
Revision 07
Southbrige Intel B150
Revision 31
LPCIO --
BIOS
Core Speed American Megatrends Inc.
Version C.50
Date 05/17/2016
Graphic Interface
Version --
Transfer Rate --
Max. Supported --
Memory
General
Type DDR4
Size 16384 MBytes
Channel# --
DC Model --
NB Frequency --
Timings
DRAM Frequency 1064,6 MHz
FSB
RAM --
CAS# Latency(CL) 15 clocks
RAS# to CAS# Delay(tRCD) 15 clocks
RAS# Precharge(tRP) 15 clocks
Cycle Time(rRAS) 35 clocks
Bank Cycle Time(tRC) --
Command Rate(CR) 2 clocks
Graphics
GPU
Name Radeon (TM) RX 480 Graphics
Code Name Polaris
Technology 14 nm
Revision --
Clocks
Core --
Shader --
Memory --
Memory
Size 8192 MBytes
Type 8
Bus Width --
Binaries
Overview
Memory 16 GB
Monitors OMEN X 25f
CPU
Processor
Code Name Skylake
TDP 65 W
Technology 14 nm
Core Voltage 1,19 V
Family 6
Model --
Stepping --
Ext. Family --
Ext. Model --
Revision R0
Clocks
Multiplier x 34
Bus Speed 99,8 MHz
QPILink --
Cache
Level3 6144 KBytes
Motherboard
Motherboard
Manufacturer MSI
Revision 07
Revision 31
LPCIO --
BIOS
Version C.50
Date 05/17/2016
Graphic Interface
Version --
Transfer Rate --
Max. Supported --
Memory
General
Type DDR4
Size 16384 MBytes
Channel# --
DC Model --
NB Frequency --
Timings
FSB
RAM --CAS# Latency(CL) 15 clocks
Graphics
GPU
Code Name Polaris
Technology 14 nm
Revision --
Clocks
Core --
Shader --
Memory --
Memory
Size 8192 MBytes
Type 8
Bus Width --
