[Sammelthread] MSI MEG X570(S) Unify (X MAX) / ACE (MAX) (AM4)
product_10_20191002132606_5d9434ee62129.pngproduct_9_20190723092258_5d3661724d540.pngproduct_1629079667f4b88b2d70e858818adcfd4767cd52a2.pngproduct_1629094385a72f0a5d4a37c30deff6b3dcba91659c.png
Sammelthread für das MSI MEG x570 Unify/ACE
Herstellerseite:
MEG X570 UNIFY
Herstellerseite: MEG X570 ACE
Herstellerseite: MEG X570S ACE MAX
Herstellerseite: MEG X570S UNIFY-X MAX
Reviews:
MSI MEG X570 UNIFY Review - Introduction
MSI MEG X570 Unify motherboard (updated)
MSI MEG X570 Unify: An All-Black Motherboard
MSI MEG X570 Unify kommt ohne RGB aus
MSI MEG X570 Unify | Tom's Hardware
MSI MEG X570 ACE Infinity | Hardwareluxx
MSI MEG X570 Ace Motherboard Review
MSI MEG X570 Ace - Review 2019 - PCMag UK
MSI MEG X570 ACE - Hardware Journal
MSI MEG X570 ACE - Review
MSI MEG X570S ACE MAX - digideutsche
MSI MEG X570S ACE MAX - wccftech
MSI MEG X570S ACE MAX - IT Info
MSI MEG X570S UNIFY-X MAX - geeknetic
Besonderheiten:
  • Supports 2nd and 3rd Gen AMD Ryzen™ / Ryzen™ with Radeon™ Vega Graphics and 2nd Gen AMD Ryzen™ with Radeon™ Graphics Desktop Processors for AM4 socket
  • Supports DDR4 Memory, up to 5000+(OC) MHz
  • Aluminum Cover with Extended Heatsink: All-metal extended heatsink cover enlarge the surface of heat dissipation, ensures even high-end processors to run in full speed.
  • Lightning Fast Game Experience: PCIe 4.0, Triple Lightning Gen4 x4 M.2 with M.2 Shield Frozr, StoreMI, AMD Turbo USB 3.2 Gen2.
  • 2.5G Gaming LAN with Latest Wi-Fi 6 Solution: Onboard 2.5G LAN with gaming LAN manager, combining latest Wi-Fi 6 solution which supports MU-MIMO and BSS color technology, delivering the best online gaming experience.
  • Frozr Heatsink Design: Designed with the patented fan and double ball bearings to provide the best performance for enthusiast gamers and prosumers.
  • Audio Boost HD: Isolated audio with dedicated processor combining ESS audio DAC with amplifier, deliver the breathtaking, game-changing sound to create the most exciting gameplay.
  • Pre-installed I/O Shielding: Better EMI protection and more convenience for installation
  • ACE: Mystic Light Infinity, Dual LAN, Extended Heat-pipe Design
Spezifikationen Unify/ACE/ACE MAX/Unify X:
SOCKET:
AM4
CPU (MAX SUPPORT): Ryzen 9
CHIPSET:
AMD® X570 Chipset
DDR4 MEMORY: 1866/ 2133/ 2400/ 2667/ 2800/2933 /3000 /3066 /3200 /3466 /3600 /3733 /3866 /4000 /4133 /4266 /4400 /4533 /4600 /4733 /4800 /5000+ Mhz by JEDEC and A-XMP OC MODE
MEMORY CHANNEL: Dual
DIMM SLOTS: 2/4
MAX MEMORY (GB): 128GB
PCI-E X16: 3
PCI-E X1: 2
SATAIII: 4
M.2 SLOT: 3/4/6
RAID: 0/1/10
TPM (HEADER): 1
LAN UNIFY/UNIFY X: 1x Realtek® RTL8125 2.5 Gbps
LAN ACE/ACE MAX: 1x Intel® WGI211AT Gigabit / Intel® Wi-Fi 6E AX210, 1x Realtek® RTL8125 2.5 Gbps
USB 3.2 PORTS (FRONT): 1(Gen2, Type C), 4(Gen1, Type A)
USB 3.2 PORTS (REAR): 1(Gen2, Type C), 3(Gen2, Type A), 2(Gen1, Type A)
USB 2.0 PORTS (FRONT): 4
USB 2.0 PORTS (REAR): 2
AUDIO PORTS (REAR): 5+ Optical S/PDIF (Realtek® ALC1220 Codec)
DIRECTX: 12
FORM FACTOR: ATX
SLI: Y
CROSSFIRE: Y
OPERATING SYSTEM: Support for Windows® 10 64-bit
MSI Support bei hwluxx.
Hier ein paar Bilder zu denn Boards:
Freiwillige vor ;)
Hat sich nichts gegen der Beta verändert, läuft so weit man das sagen kann nach so kurzer Zeit.
Läuft alles problemlos auf Ubuntu und Windows. CO Einstellungen und Flck 1800 mit strammen Timings läuft wie bisher sehr gut.
Moin,
hab die Version auch installiert, mein System startet jetzt mit ca. 5° höherer CPU Temperatur.
Im PBO kann man jetzt den max. Boost Clock Overdrive positiv oder negativ wählen?
Wird bei mir auch so angezeigt, würde mich aber nicht weiter beunruhigen. Meine Grafikkarte steckt ebenfalls ganz oben (bzw. rechts) und wird korrekt mit PCIe 4.0 x16 angebunden.
Der Anzeigefehler im Board-Explorer ist zumindest bei mir mit dem neuen BIOS ebenfalls gefixt. Davon ab läuft auch der Rest weiterhin reibungslos. ;)
Du setzt das PBO, bzw. Boost Clock Overdrive auf Positive oder Negative und gibst dann bei Magnitude einfach den gewünschten Wert ein, ohne + oder - davor.
Ist mir nie aufgefallen dass man das da auswählen konnte!
Vielleicht ist es das Alter 🙄
Moin,
Meine CPU Temperatur ist auch ca. 5° höher mit dem neuen Bios.
Bei mir gibt es bei der CPU-Temp keinerlei Unterschiede. Seid ihr euch sicher, dass ihr das BIOS exakt wie vorher eingestellt habt?
Jup. Vielleicht liegt es ja am Win11, da ist ja was extra angepasst worden von MSI.
Mir fällt auch auf, dass meine CPU PPT ohne Last rund 8W niedriger in HWINFO angezeigt wird, hatte mit der älteren Version immer ein min. von 25-26 Watt, nun 17-18W.
Eher nicht, denn das Einzige, was MSI verändert hat ist, dass automatisch fTPM und Secure-Boot aktiviert ist. Dies war auch bereits bei den vorangegangenen Beta-Versionen nach der A.A0-Final der Fall.
Ist es denn auch tatsächlich an jetzt? Ich weiß noch, dass bei der Beta TPM an sein soll, es aber nicht war.
Bei mir war beides an, habe es allerdings ausgeschaltet, da ich vorerst bei Windows 10 bleibe.
Es gibt aber Änderungen in den SMUs. Gegenüber der AB3/AB1 mit agesa 1203c hat sich bei der aktuellen Final die SMU in allen 2000er APUs, 3000/4000/5000er APUs und CPUs geändert.
Zusätzlich auch die Chipset SMU von 47.25.0 auf 47.27.0.
Laut diversen Beiträgen im Netz hat man schon Veränderungen in der Telemetrie festgestellt.
Selbst wenn, dies tangiert mich (noch) nicht, da ich auf Windows 11 zunächst dankend verzichte. ;)
Verstehe nicht ganz, was das mit Win11 zu tun hat ?
Edit: Ich meine die Telemetrie des Boards, nicht vom Betriebssystem.
Es ist bekannt, dass es da Probleme gibt, doch AMD schweigt darüber seit eh und je und die Mainboardhersteller dürfen wahrscheinlich auch nichts sagen.
Weil auf die Änderungen mit "Support Windows 11" eingegangen wurde, das hat es mit Windows 11 zu tun.
ACE geflsht und alles top bisher.
Hatte allerdings erhofft, das meine Energieoptionen im Modus "Energiesparmodus" wieder so funzen wie unter WIN10.
Leider geht das immer noch nicht.
Geflasht auf dem Unify. Läuft bisher unauffällig gut in Win10. CB23 spuckt mir ca. 200Punkte mehr im Multicore aus. Keine Ahnung woher das kommt.
An der Telemetrie gibt es leichte Verbesserungen. Die PRD unter hwinfo zeigt bei CB23 sogar im singlecore um die 100% an. (Auch wenn die Angabe nur bei Vollast aussagekräftig ist).
Bei Multicore um die 95%. Das ist, zumindest bei mir mit einem 3700X ggü. allen anderen bios Versionen ein großer Schritt nach vorne. Der Wert sollte im Idealfall bei 100% liegen. Liegt es drunter, denkt das MB, dass es zu wenig Power liefert. Liegt es drüber, dann dass es zu viel Power liefert. Beides will man nicht.
Ansonsten hat sich an den Temperaturen auch nichts geändert.
Auf dem X570S Unify-X nach wie vor noch 1.2.0.3 auf der MSI Site.
Konnten diejenigen, welche schon auf 1.2.0.5 geflasht haben, eine Änderungen erkennen hinsichtlich Temperaturschwankungen im IDLE und dem Fabric Clock (WHEA)?
Einige haben Temperaturunterschiede bemerkt, bei mir ist das jedoch nicht der Fall. Zu der WHEA-Fabric-Geschichte kann ich nichts beisteuern, da ich nur mit 1.800 MHz unterwegs bin.
Irgendwie noch nicht... Ich könnte mir höchstens vorstellen, dass die bekannten "Probleme" noch ausmerzen wollen.
Ich schau jeden Tag nach ob ein neues Bios gibt...ich hoffe es dauert länger weil die die USB Problematik in den Griff bekommen wollen..
Ähnliche Themen
