[Sammelthread] MSI MEG X570(S) Unify (X MAX) / ACE (MAX) (AM4)
product_10_20191002132606_5d9434ee62129.pngproduct_9_20190723092258_5d3661724d540.pngproduct_1629079667f4b88b2d70e858818adcfd4767cd52a2.pngproduct_1629094385a72f0a5d4a37c30deff6b3dcba91659c.png
Sammelthread für das MSI MEG x570 Unify/ACE
Herstellerseite:
MEG X570 UNIFY
Herstellerseite: MEG X570 ACE
Herstellerseite: MEG X570S ACE MAX
Herstellerseite: MEG X570S UNIFY-X MAX
Reviews:
MSI MEG X570 UNIFY Review - Introduction
MSI MEG X570 Unify motherboard (updated)
MSI MEG X570 Unify: An All-Black Motherboard
MSI MEG X570 Unify kommt ohne RGB aus
MSI MEG X570 Unify | Tom's Hardware
MSI MEG X570 ACE Infinity | Hardwareluxx
MSI MEG X570 Ace Motherboard Review
MSI MEG X570 Ace - Review 2019 - PCMag UK
MSI MEG X570 ACE - Hardware Journal
MSI MEG X570 ACE - Review
MSI MEG X570S ACE MAX - digideutsche
MSI MEG X570S ACE MAX - wccftech
MSI MEG X570S ACE MAX - IT Info
MSI MEG X570S UNIFY-X MAX - geeknetic
Besonderheiten:
  • Supports 2nd and 3rd Gen AMD Ryzen™ / Ryzen™ with Radeon™ Vega Graphics and 2nd Gen AMD Ryzen™ with Radeon™ Graphics Desktop Processors for AM4 socket
  • Supports DDR4 Memory, up to 5000+(OC) MHz
  • Aluminum Cover with Extended Heatsink: All-metal extended heatsink cover enlarge the surface of heat dissipation, ensures even high-end processors to run in full speed.
  • Lightning Fast Game Experience: PCIe 4.0, Triple Lightning Gen4 x4 M.2 with M.2 Shield Frozr, StoreMI, AMD Turbo USB 3.2 Gen2.
  • 2.5G Gaming LAN with Latest Wi-Fi 6 Solution: Onboard 2.5G LAN with gaming LAN manager, combining latest Wi-Fi 6 solution which supports MU-MIMO and BSS color technology, delivering the best online gaming experience.
  • Frozr Heatsink Design: Designed with the patented fan and double ball bearings to provide the best performance for enthusiast gamers and prosumers.
  • Audio Boost HD: Isolated audio with dedicated processor combining ESS audio DAC with amplifier, deliver the breathtaking, game-changing sound to create the most exciting gameplay.
  • Pre-installed I/O Shielding: Better EMI protection and more convenience for installation
  • ACE: Mystic Light Infinity, Dual LAN, Extended Heat-pipe Design
Spezifikationen Unify/ACE/ACE MAX/Unify X:
SOCKET:
AM4
CPU (MAX SUPPORT): Ryzen 9
CHIPSET:
AMD® X570 Chipset
DDR4 MEMORY: 1866/ 2133/ 2400/ 2667/ 2800/2933 /3000 /3066 /3200 /3466 /3600 /3733 /3866 /4000 /4133 /4266 /4400 /4533 /4600 /4733 /4800 /5000+ Mhz by JEDEC and A-XMP OC MODE
MEMORY CHANNEL: Dual
DIMM SLOTS: 2/4
MAX MEMORY (GB): 128GB
PCI-E X16: 3
PCI-E X1: 2
SATAIII: 4
M.2 SLOT: 3/4/6
RAID: 0/1/10
TPM (HEADER): 1
LAN UNIFY/UNIFY X: 1x Realtek® RTL8125 2.5 Gbps
LAN ACE/ACE MAX: 1x Intel® WGI211AT Gigabit / Intel® Wi-Fi 6E AX210, 1x Realtek® RTL8125 2.5 Gbps
USB 3.2 PORTS (FRONT): 1(Gen2, Type C), 4(Gen1, Type A)
USB 3.2 PORTS (REAR): 1(Gen2, Type C), 3(Gen2, Type A), 2(Gen1, Type A)
USB 2.0 PORTS (FRONT): 4
USB 2.0 PORTS (REAR): 2
AUDIO PORTS (REAR): 5+ Optical S/PDIF (Realtek® ALC1220 Codec)
DIRECTX: 12
FORM FACTOR: ATX
SLI: Y
CROSSFIRE: Y
OPERATING SYSTEM: Support for Windows® 10 64-bit
MSI Support bei hwluxx.
Hier ein paar Bilder zu denn Boards:
Andere Firmware ist hier das Stichwort. Aber ob einem das einen weiteren Mainboard-Kauf wert ist? Mir jedenfalls nicht.
Dann lass ich die Information auf Seite 1 jetzt ohne X570S unter Chipset. Rest sollte sonst passen so weit. Also mir wäre ein es einen Wechsel wert, weil mehr M2 was ich brauche und eben wegen USB 3.2 2x2 was nun 20Gbits kann und nicht nur 10Gbits was für meine externe M2 schon ein großer Vorteil ist.
Ich habe schon aus kleineren Gründen neue Hardware gekauft. :fresse:
Sollte das ACE MAX unter 400 Euro liegen schlag ich zu, befürchte aber das es teurer wird. Das neue UNIFY X finde ich hingegen nicht so toll. Hat zwar mehr M2 aber optisch spricht es mich nicht an.
Ich habe auf ein Mini/Micro-ITX des Unify gehofft, wie es einige für Intel gibt.
Beim Live Stream hatte man erklärt warum es kein Mini/Micro geben wird. Sollte noch Online sein der Stream.
Also der 20Gbit/s USB-Speed bezieht sich ja nur auf den USB-C der rest ist gleich geblieben was usb betrifft sehe ich das richtig?
Ja, ein USB-3.2-Gen2x2-Anschluss mit bis zu 20 GBit/s über einen dedizierten Controller ist nun mit dabei. Ist aber für mich eher nice to have als must have. Ich finde sogar, dass sich die neuen Modelle verschlechtert haben in Sachen Lane-Sharing. Gerade das schätze ich am X570 UNIFY, dass generell kein Sharing bei den Storage-Anschlüssen existiert.
Sehe ich auch so bin mit der jetzigen Version super zufrieden.
Im Zuge des Chipset-Treiberupdates ist mir aufgefallen, dass bei mir im Geräte Manager gar kein "AMD PSP Device" angezeigt wird. Wäre hilfreich wenn einige mal bei sich nachschauen könnten, ob das auch so ist.
Moin.
Problem: habe 2x16GB Corsair 3600 balistix RAM verbaut.
Läuft mit 3800 IF 1900 absolut stabil.
Aber, mein PCi für die graka setzt sich auf 8x4,0 runter??? anstatt 16x4,0.
seltsam,oder? Kennt das jemand?
Grüße
Und wie siehts beim IF1800 aus? Das würde ich mal versuchen denn das klingt schon sehr nach CPU.
3800 und IF 1800?
Moin.
Grüße
Steckt was im mittleren der 3 Pcie slots?
Ich hab in dem PCI X1 , dem kleinen Port , eine Soundkarte Und 3x Nvme
Eigentlich hängen die 1x am Chipsatz.... Sollte also nix ausmachen. Von den 1x ist halt nur einer nutzbar
Die Lanes der CPU teilen sich nur der obere und mittlere mechanische 16x (16x oben oder 8x/8x bei 2 belegten)
Nimm mal alle Karten raus und tu nur die graka rein zum test
Zuerst/vorher setz das RAM aber mal auf 2133 und check ob sich was ändert
Wenn beides nicht hilft guck mal ob evtl ein Fremdkörper im mittleren pcie ist
Bei mir ist er noch da:
also mit dem XMP profil vom RAM geht ja alles. Ist nur wenn ich suf 3800/1900 setze.
Und die Soundkarte ist ja wie du sagst am chipsatz angebunden....
PCI steckplätze sind sauber.
Komisch ist, das sich der PCI16 mit der graka sich auch manchmal auf 16x 3,0 setzt... anstatt 16x4.0 ...hmm. aber nur wenn IF1900
Edit: Das AMD PSP hab ich auch nicht!!
Hm habe die gleichen Probleme sowohl mit meinem b550 unify x sowie mit meinem Gigabyte b550i
Aber erst seid ein paar neueren agesa
das problem wie ich?? mit dem PCI16x
Ja genau das Problem mit dem PCIe 16x Slot. Pcie 3.0 Schafft abhilfe aber nicht das gewünschte Ergebnis, da nach einem Bios Reset das ganze wieder zum Glückspiel wird.
Habe mit dem 5600g z.b keine Probleme auf den Brettern. Auf meinem Dark Hero mit alten Agesa auch nicht ;)
Es kann nur noch am Agesa liegen, da es vorher lief und seid ich die neuen auf den beiden B550 drauf habe diese Probleme entstehen. Habe auch schon mein B550 Unify x austauschen lassen, ging 4 mal Cmos setzen dann nicht mehr....
Im Netz tauchen auch immer mehr leute auf mit dem selben Problem.
@Chris1975 @talha777: liegt wohl einfach daran, dass die Funktion im BIOS deaktiviert ist. -> Settings -> Security -> Trusted Computing -> Security Device Support -> Enable/Disable
interessand
Vieleicht mal hier den MSI support anschreiben.
Bei mir installiert er nicht AMD PSP. Im Bios ist es auf Enable gestellt und Chipsatz Treiber nochmal neu installiert.
Im Computer Base Forum habe das Problem auch viele, aber fast nur mit MSI Motherboards.
Bei mir übrigens das Gleiche, PSP ist nicht unter Sicherheitsgeräte aufgeführt.
Wäre interessant zu wissen, welche BIOS bzw. AGESA Version du hast.
Nein. Was du beschrieben hast ist das fTPM was man einschaltet und dann auch im Geräte Manager als Sicherheitsgerät aufgeführt wird. Doch im Normalfall sollte auch bei deaktiviertem fTPM das AMD PSP Device aufgeführt werden. Den PSP kann man nicht ein- oder abschalten.
Die Frage ist nur, ob das ein msi spezifisches Bios Ding ist, dass er im Geräte Manager nicht aufgeführt wird.
Ähnliche Themen
