[Sammelthread] MSI MEG X570(S) Unify (X MAX) / ACE (MAX) (AM4)
product_10_20191002132606_5d9434ee62129.pngproduct_9_20190723092258_5d3661724d540.pngproduct_1629079667f4b88b2d70e858818adcfd4767cd52a2.pngproduct_1629094385a72f0a5d4a37c30deff6b3dcba91659c.png
Sammelthread für das MSI MEG x570 Unify/ACE
Herstellerseite:
MEG X570 UNIFY
Herstellerseite: MEG X570 ACE
Herstellerseite: MEG X570S ACE MAX
Herstellerseite: MEG X570S UNIFY-X MAX
Reviews:
MSI MEG X570 UNIFY Review - Introduction
MSI MEG X570 Unify motherboard (updated)
MSI MEG X570 Unify: An All-Black Motherboard
MSI MEG X570 Unify kommt ohne RGB aus
MSI MEG X570 Unify | Tom's Hardware
MSI MEG X570 ACE Infinity | Hardwareluxx
MSI MEG X570 Ace Motherboard Review
MSI MEG X570 Ace - Review 2019 - PCMag UK
MSI MEG X570 ACE - Hardware Journal
MSI MEG X570 ACE - Review
MSI MEG X570S ACE MAX - digideutsche
MSI MEG X570S ACE MAX - wccftech
MSI MEG X570S ACE MAX - IT Info
MSI MEG X570S UNIFY-X MAX - geeknetic
Besonderheiten:
  • Supports 2nd and 3rd Gen AMD Ryzen™ / Ryzen™ with Radeon™ Vega Graphics and 2nd Gen AMD Ryzen™ with Radeon™ Graphics Desktop Processors for AM4 socket
  • Supports DDR4 Memory, up to 5000+(OC) MHz
  • Aluminum Cover with Extended Heatsink: All-metal extended heatsink cover enlarge the surface of heat dissipation, ensures even high-end processors to run in full speed.
  • Lightning Fast Game Experience: PCIe 4.0, Triple Lightning Gen4 x4 M.2 with M.2 Shield Frozr, StoreMI, AMD Turbo USB 3.2 Gen2.
  • 2.5G Gaming LAN with Latest Wi-Fi 6 Solution: Onboard 2.5G LAN with gaming LAN manager, combining latest Wi-Fi 6 solution which supports MU-MIMO and BSS color technology, delivering the best online gaming experience.
  • Frozr Heatsink Design: Designed with the patented fan and double ball bearings to provide the best performance for enthusiast gamers and prosumers.
  • Audio Boost HD: Isolated audio with dedicated processor combining ESS audio DAC with amplifier, deliver the breathtaking, game-changing sound to create the most exciting gameplay.
  • Pre-installed I/O Shielding: Better EMI protection and more convenience for installation
  • ACE: Mystic Light Infinity, Dual LAN, Extended Heat-pipe Design
Spezifikationen Unify/ACE/ACE MAX/Unify X:
SOCKET:
AM4
CPU (MAX SUPPORT): Ryzen 9
CHIPSET:
AMD® X570 Chipset
DDR4 MEMORY: 1866/ 2133/ 2400/ 2667/ 2800/2933 /3000 /3066 /3200 /3466 /3600 /3733 /3866 /4000 /4133 /4266 /4400 /4533 /4600 /4733 /4800 /5000+ Mhz by JEDEC and A-XMP OC MODE
MEMORY CHANNEL: Dual
DIMM SLOTS: 2/4
MAX MEMORY (GB): 128GB
PCI-E X16: 3
PCI-E X1: 2
SATAIII: 4
M.2 SLOT: 3/4/6
RAID: 0/1/10
TPM (HEADER): 1
LAN UNIFY/UNIFY X: 1x Realtek® RTL8125 2.5 Gbps
LAN ACE/ACE MAX: 1x Intel® WGI211AT Gigabit / Intel® Wi-Fi 6E AX210, 1x Realtek® RTL8125 2.5 Gbps
USB 3.2 PORTS (FRONT): 1(Gen2, Type C), 4(Gen1, Type A)
USB 3.2 PORTS (REAR): 1(Gen2, Type C), 3(Gen2, Type A), 2(Gen1, Type A)
USB 2.0 PORTS (FRONT): 4
USB 2.0 PORTS (REAR): 2
AUDIO PORTS (REAR): 5+ Optical S/PDIF (Realtek® ALC1220 Codec)
DIRECTX: 12
FORM FACTOR: ATX
SLI: Y
CROSSFIRE: Y
OPERATING SYSTEM: Support for Windows® 10 64-bit
MSI Support bei hwluxx.
Hier ein paar Bilder zu denn Boards:
Mal abwarten, es gibt noch keine Infos zu denn Boards. Nur bei keinen Lüfter wird es sicher nicht bleiben. Kann mir vorstellen schnelleres USB 3.2 (4.x) die nun 20gb/s können statt bisher nur 10gb/s, 4 M2 statt 3 M2 wie bei der B550 Reihe, 2 Ram Slots statt 4 für schnelleren Speicher. Gibt also einiges was man verbessern könnte.
Moin,
sorry wenn ich diesen Threads enter, aber es scheinen ja mehrere auch mehr als einen Steckplatz zu verwenden und mich würde mal interessieren wie sich diese 3 M.2 Plätze sinnvoll nutzen lassen.
Für meinen ersten PC build für Videoschnitt und Bildbearbeitung, evtl. auch bisserl OC und spielen in Zukunft, schiele ich auch auf dieses Board.
Eine für das System / Programme, oder Programme auf eine zweite Platte? Video- / Bildmaterial/Spiele zum Bearbeiten auf die Dritte, oder ggf. Auf SATA SSD "auslagern"?
Falscher Thread @W124 . Außerdem ergibt deine Frage keinen Sinn. Wer soll dir sagen wie du deine M2 aufteilst, das musst du schon selber Wissen.
Na ich denke es gibt ja hier sicher sehr viele Erfahrungen, was Sinn und sich bewährt hat und warum so ein Board die Möglichkeit von 3 M.2 Plätzen bietet.
Sorry für das falsche Thema, evtl. mag ein Mod zu nett sein und das an die passende Stelle verschieben, merci.
Falscher Thread wie gesagt. Auch als Anfänger sollte man erst mal Lesen worum es in dem Thread geht bevor man dann was postet. Jeder User hat da eigene Präferenzen wie er seine SSD aufteilt. Da gibt es kein richtig oder flasch.
@W124
Ich habe dein Anliegen mal in den Sammelthread verschoben.
@W124 Ich hatte im ersten Steckplatz eine 1TB M.2 4.0 für System und Programme die oft geladen werden und im zweiten M.2 Steckplatz eine 2TB M.2 3.0 für Programme und Daten Spiele die ich nicht so oft brauche. Der Rest ist immer auf einem NAS bei mir, das als Netzlaufwerk gemappt ist. Wie du dir das einrichtest musst du für dich selber rausfinden, jedenfalls kann man ohne Probleme alle drei M.2 Steckplätze verwenden.
Vielen Dank.
Merkt man denn auch einen Performance Unterschied, wenn man das aufteilt?
Nutze seit Jahren nur ein altes MacBook Mid 2012, da hab ich halt nur eine Platte drin für alles, dazu ein externes Datengrab. Die interne HDD hatte ich mal gegen eine SSD getauscht, das gab ja richtig Schub.
Würde es denn auch Unterschiede machen den Steckplatz an der CPU zu nutzen, oder am Chipsatz? Muß man damit rechnen, dass der Chipsatz Lüfter aktiver wird?
Sorry für die Nachfragen, ist mein erster PC den ich zusammen bauen möchte.
Einen Unterschied zwischen S-ATA SSD, M.2 S-ATA oder M.2 PCIe SSD kann man durchaus messen, aber für mich ist es nicht spürbar. Ich schiebe jetzt allerdings auch nicht exzessiv Daten hin und her. Ist eher so eine Kopfsache, das man das technisch bessere haben will, auch wenn es persönlich nichts bringt.
Dann werde ich hier wohl mal mit einer einzelnen M.2 PCIe SSD starten, wenn da der Unterschied nicht so signifikant ausfällt.
Verwendet jemand die Arctic Liquid Freezer 2 AIO mit dem Meg Unify?
Ich überlege umzubauen und bin dabei auf die AIO Rev.3 gestoßen die wohl die Kompatibilität verbessert, frage mich aber ob ich das mit meinem Board brauche.
Es gibt auch eine Revision 4.
Seit Revision 3 kann man den Kühler speziell für am4 Sockel versetzt anbringen, was die Kühlleistung verbessert. Revision 4 ist exakt gleich, außer, dass die Metallteile etwas schlanker geworden sind um mehr Kompatibilität mit darunter liegenden m.2 slots zu gewährleisten.
Den versetzten kühler auf der cpu hat gamers Nexus getestet, falls es dich interessiert.
Ich habe die Liquid Freezer II 280 - leider noch Rev. 2 was die Montage recht bescheiden macht, aber ab Revision 3 ist alles im grünen Bereich.
Hab grad festgestellt das Arctic einen eigenen Shop hat und dort nachgefragt welche Revision Arctic selber ausliefert.
Bei den üblichen Online Händler scheint es ja eher ein "Glücksspiel" zu sein.
MSI hat die finale BIOS-Version mit AGESA 1.2.0.3b für das UNIFY veröffentlicht :wink:
Kann mir Mal jemand schnell helfen.
Board bleibt bei Code 94 stehen und fängt immer wieder von vorn an zu Testen.
MSI Ace 570. Kein Bild nach einem Neustart.
Zuvor hatte ich extreme laks unter Windows
3800/IF1600 ;) - CMOS Reset
Batterie Mal raus... Wieder rein. Leider nicht geholfen.
Ob da die Grafikkarte hinüber ist..... AMD6900
Auch einen richtigen CMOS-Reset durchgeführt und Standart-Einstellungen geladen?
Benutzt du ein Riser-Kabel für die Grafikkarte?
Die Grafikkarte schon in einem anderen PCIe-Slot probiert?
Hast du die Möglichkeit eine andere Grafikkarte zum Testen einzubauen?
Vorher New World gespielt? :fire:
Mal eben schnell ist wohl leider nicht -besser einen eigenen Thread aufmachen.
New world ist gut :d
Mit einer uralt Radeon 570 geht's.
Leider doch graka... Sehr ärgerlich, ist ne Power color, bin Mal gespannt wegen Garantie da wakü Umbau.
Grüße
BIOS-Flashback könnte man ebenfalls noch versuchen.
CMOS mit dem Knopf hinten und aktuelles BIOS hat das Problem gelöst--
DANKE
Freut mich das es geklappt hat. Manchmal verhalten sich Boards echt seltsam. Vorhin konnte ich meines nicht mehr einschalten und der Power-Knopf auf dem Board blinkte. 10 Minuten stehen lassen, ging wieder - ich habe keine Ahnung ;)
stimmt- hatte jetzt schon ein paar solcher sachen, auch einschalt probleme etc.
Ja, schon merkwürdig. Derartiges habe ich mit meinem System noch nicht erlebt. Das System startet stets ordnungsgemäß. ;)
Nun wurde die finale BIOS-Version mit AGESA 1.2.0.3b auch für das ACE veröffentlicht :wink:
Ähnliche Themen
