| Date,Time,"Virtual Memory Commited [MB]","Virtual Memory Available [MB]","Virtual Memory Load [%]","Physical Memory Used [MB]","Physical Memory Available [MB]","Physical Memory Load [%]","Page File Usage [%]","Core 0 VID [V]","Core 1 VID [V]","Core 2 VID [V]","Core 3 VID [V]","Core 4 VID [V]","Core 5 VID [V]","Core 6 VID [V]","Core 7 VID [V]","Core 0 Clock (perf #1/) [MHz]","Core 1 Clock (perf #1/) [MHz]","Core 2 Clock (perf #4/) [MHz]","Core 3 Clock (perf #2/) [MHz]","Core 4 Clock (perf #3/) [MHz]","Core 5 Clock (perf #7/) [MHz]","Core 6 Clock (perf #5/) [MHz]","Core 7 Clock (perf #6/) [MHz]","Bus Clock [MHz]","Core 0 T0 Effective Clock [MHz]","Core 0 T1 Effective Clock [MHz]","Core 1 T0 Effective Clock [MHz]","Core 1 T1 Effective Clock [MHz]","Core 2 T0 Effective Clock [MHz]","Core 2 T1 Effective Clock [MHz]","Core 3 T0 Effective Clock [MHz]","Core 3 T1 Effective Clock [MHz]","Core 4 T0 Effective Clock [MHz]","Core 4 T1 Effective Clock [MHz]","Core 5 T0 Effective Clock [MHz]","Core 5 T1 Effective Clock [MHz]","Core 6 T0 Effective Clock [MHz]","Core 6 T1 Effective Clock [MHz]","Core 7 T0 Effective Clock [MHz]","Core 7 T1 Effective Clock [MHz]","Average Effective Clock [MHz]","Core 0 T0 Usage [%]","Core 0 T1 Usage [%]","Core 1 T0 Usage [%]","Core 1 T1 Usage [%]","Core 2 T0 Usage [%]","Core 2 T1 Usage [%]","Core 3 T0 Usage [%]","Core 3 T1 Usage [%]","Core 4 T0 Usage [%]","Core 4 T1 Usage [%]","Core 5 T0 Usage [%]","Core 5 T1 Usage [%]","Core 6 T0 Usage [%]","Core 6 T1 Usage [%]","Core 7 T0 Usage [%]","Core 7 T1 Usage [%]","Max CPU/Thread Usage [%]","Total CPU Usage [%]","Core 0 Ratio [x]","Core 1 Ratio [x]","Core 2 Ratio [x]","Core 3 Ratio [x]","Core 4 Ratio [x]","Core 5 Ratio [x]","Core 6 Ratio [x]","Core 7 Ratio [x]","Memory Clock [MHz]","Memory Clock Ratio [x]","Tcas [T]","Trcd [T]","Trp [T]","Tras [T]","Trc [T]","Trfc [T]","Command Rate [T]","CPU (Tctl/Tdie) [°C]","CPU CCD1 (Tdie) [°C]","CPU Core Voltage (SVI2 TFN) [V]","SoC Voltage (SVI2 TFN) [V]","CPU Core VID (Effective) [V]","CPU Core Current (SVI2 TFN) [A]","SoC Current (SVI2 TFN) [A]","Memory Controller Clock (UCLK) [MHz]","System [°C]","CPU [°C]","VR MOS [°C]","PCH [°C]","CPU (PECI) [°C]","Vcore [V]","+5V [V]","+3.3V (AVCC) [V]","+3.3V (3VCC) [V]","+12V [V]","VIN4 [V]","3VSB [V]","CPU +1.8V [V]","VIN6 [V]","CPU NB/SoC [V]","DIMM [V]","VIN7 [V]","CPU [RPM]","System 1 [RPM]","System 2 [RPM]","Chassis Intrusion [Yes/No]","VDD Voltage [V]","NB Voltage [V]","VDD Current [A]","NB Current [A]","Drive Temperature [°C]","Drive Failure [Yes/No]","Drive Warning [Yes/No]","Total Host Writes [GB]","Total Host Reads [GB]","Drive Temperature [°C]","Drive Remaining Life [%]","Drive Failure [Yes/No]","Drive Warning [Yes/No]","Total Host Writes [GB]","Total Host Reads [GB]","Read Activity [%]","Write Activity [%]","Total Activity [%]","Read Rate [MB/s]","Write Rate [MB/s]","Read Total [MB]","Write Total [MB]","Read Activity [%]","Write Activity [%]","Total Activity [%]","Read Rate [MB/s]","Write Rate [MB/s]","Read Total [MB]","Write Total [MB]","GPU Temperature [°C]","GPU Hot Spot Temperature [°C]","GPU Fan [RPM]","GPU Core Current [A]","GPU ASIC Power [W]","GPU Memory Clock [MHz]","GPU Utilization [%]","GPU D3D Usage [%]","GPU Memory Controller Utilization [%]","GPU Computing (High Priority Compute) Usage [%]","GPU Computing (Compute 3) Usage [%]","GPU Computing (Compute 0) Usage [%]","GPU Computing (Compute 1) Usage [%]","GPU Fan Speed [%]","GPU D3D Memory Dedicated [MB]","GPU D3D Memory Dynamic [MB]","PCIe Link Speed [GT/s]","GPU Memory Usage [MB]","Total DL [MB]","Total UP [MB]","Current DL rate [KB/s]","Current UP rate [KB/s]","Total Errors []", | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:21:12.448,6437,32912,16.3,4364,28328,13.3,0.0,1.369,1.381,1.369,0.988,0.988,0.988,0.981,0.981,3880.1,4850.1,3880.1,3775.1,3775.1,3775.1,3880.1,3775.1,100.0,246.2,29.0,29.2,40.8,18.4,401.0,29.9,12.7,12.1,32.9,298.5,211.8,113.5,49.8,77.4,66.8,104.4,11.6,0.6,0.6,0.6,0.0,3.6,1.2,0.0,0.0,1.2,0.0,3.0,1.2,0.6,0.0,0.0,11.6,1.5,38.8,48.5,38.8,37.8,37.8,37.8,38.8,37.8,1600.0,16.00,16,16,16,35,74,560,1,38.5,38.0,1.331,0.994,1.344,20.016,6.000,1600.0,31.0,37.9,32.0,38.0,40.0,1.112,5.040,3.328,3.376,12.192,0.888,3.328,1.832,0.776,1.008,1.360,1.536,701,703,1350,No,1.100,1.013,17.647,10.588,27,No,No,5951,176445,33,94.0,No,No,11883,16,0.0,0.0,0.0,0.000,0.000,149,2,0.1,0.1,0.2,0.044,0.145,16814,4340,49.0,50.0,0,5.000,27.000,1990.0,0.0,1.1,0.0,0.0,0.0,0.0,0.0,0.0,409,75,16.0,544,101,35,0.391,0.265,0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:21:15.006,6428,32920,16.3,4363,28329,13.3,0.0,1.337,1.337,1.337,0.981,0.981,0.981,0.981,0.981,3880.1,3775.1,3880.1,3880.1,3880.1,4850.1,3880.1,3880.1,100.0,227.9,38.6,106.3,15.8,7.1,445.0,37.7,7.7,1.9,14.1,308.5,355.1,90.8,23.6,59.2,42.2,111.3,11.5,1.2,0.0,0.6,0.0,1.2,0.6,0.0,0.0,0.0,0.0,3.0,0.0,0.0,0.0,0.6,11.5,1.2,38.8,37.8,38.8,38.8,38.8,48.5,38.8,38.8,1600.0,16.00,16,16,16,35,74,560,1,38.8,37.3,1.331,0.994,1.350,22.745,6.000,1600.0,31.0,38.8,32.0,38.0,40.0,1.200,5.040,3.344,3.376,12.192,0.880,3.328,1.832,0.776,1.008,1.360,1.536,701,703,692,No,1.100,1.013,13.412,10.588,27,No,No,5951,176445,33,94.0,No,No,11883,16,0.0,0.0,0.0,0.000,0.000,149,2,0.1,0.1,0.2,0.038,0.214,16814,4341,49.0,50.0,0,5.000,27.000,1988.0,0.0,0.4,0.0,0.0,0.0,0.0,0.0,0.0,409,75,16.0,544,101,35,0.096,0.042,0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:21:17.556,6412,32937,16.2,4346,28346,13.2,0.0,0.981,0.981,0.981,0.981,0.981,0.981,0.981,0.981,3775.1,3775.1,3775.1,3880.1,3775.1,3775.1,3775.1,3775.1,100.0,197.6,13.1,11.4,3.9,2.5,372.6,10.9,2.0,2.7,4.3,268.1,99.6,80.2,14.6,32.8,31.8,71.8,6.0,0.6,0.0,0.0,0.0,2.4,0.0,0.0,0.0,0.0,0.6,1.2,0.0,0.0,0.0,0.6,6.0,0.7,37.8,37.8,37.8,38.8,37.8,37.8,37.8,37.8,1600.0,16.00,16,16,16,35,74,560,1,38.4,36.3,1.325,0.994,1.344,22.745,5.600,1600.0,31.0,38.5,32.0,38.0,40.0,0.992,5.040,3.328,3.376,12.192,0.880,3.328,1.832,0.768,1.000,1.360,1.536,703,1436,691,No,1.100,1.013,14.118,9.882,27,No,No,5951,176445,33,94.0,No,No,11883,16,0.0,0.0,0.0,0.000,0.000,149,2,0.0,0.1,0.1,0.000,0.112,16814,4341,49.0,50.0,0,5.000,27.000,1988.0,0.0,0.2,0.0,0.0,0.0,0.0,0.0,0.0,409,75,16.0,544,101,35,1.451,0.755,0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:21:20.116,6412,32937,16.2,4350,28343,13.3,0.0,0.975,0.981,0.981,0.981,0.981,0.981,0.981,0.981,3775.1,3775.1,3775.1,3775.1,3775.1,3775.1,3775.1,3775.1,100.0,196.0,5.2,3.4,1.7,0.9,367.9,7.9,1.0,1.0,3.4,259.5,83.9,82.4,11.9,33.9,29.7,68.1,6.1,0.0,0.0,0.0,0.0,1.8,0.0,0.0,0.0,0.0,0.0,1.2,1.2,0.0,0.0,0.0,6.1,0.6,37.8,37.8,37.8,37.8,37.8,37.8,37.8,37.8,1600.0,16.00,16,16,16,35,74,560,1,38.0,35.8,1.331,0.994,1.344,20.925,5.600,1600.0,32.0,38.1,32.0,38.0,40.0,0.984,5.040,3.344,3.376,12.192,0.888,3.328,1.832,0.768,1.000,1.360,1.536,701,703,1351,No,1.100,1.013,12.706,9.882,27,No,No,5951,176445,33,94.0,No,No,11883,16,0.0,0.0,0.0,0.000,0.000,149,2,0.0,0.0,0.0,0.000,0.000,16814,4341,49.0,50.0,0,5.000,27.000,1986.0,0.0,0.2,0.0,0.0,0.0,0.0,0.0,0.0,409,75,16.0,544,101,35,0.180,0.042,0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:21:22.712,6434,32915,16.3,4349,28344,13.3,0.0,1.337,0.981,1.344,0.981,0.988,1.331,0.981,1.337,3880.1,3775.1,3775.1,3775.1,3775.1,4850.1,3775.1,3880.1,100.0,240.8,81.0,221.0,29.0,14.6,462.1,52.7,14.8,12.9,24.1,331.9,461.8,78.2,34.2,70.7,41.3,135.7,12.8,0.6,1.2,0.6,0.6,0.0,0.0,0.0,0.0,0.0,4.2,2.4,0.6,0.0,0.0,0.0,12.8,1.4,38.8,37.8,37.8,37.8,37.8,48.5,37.8,38.8,1600.0,16.00,16,16,16,35,74,560,1,39.4,38.3,1.325,0.994,1.356,22.745,6.000,1600.0,31.0,39.1,32.0,39.0,40.0,1.256,5.040,3.328,3.376,12.192,0.880,3.328,1.832,0.768,1.008,1.360,1.536,699,704,1351,No,1.100,1.013,14.118,10.588,27,No,No,5951,176445,33,94.0,No,No,11883,16,0.0,0.0,0.0,0.000,0.000,149,2,0.1,0.0,0.1,0.054,0.000,16814,4341,49.0,51.0,0,7.000,25.000,1990.0,0.0,3.4,0.0,0.0,0.0,0.0,0.0,0.0,440,78,16.0,575,101,35,0.426,0.347,0,0.893,0.894,0.250,6.251,0.223,6.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:21:25.228,6486,32863,16.4,4372,28320,13.3,0.0,1.344,1.331,1.337,1.344,1.344,1.344,1.331,1.344,3880.1,4850.1,3880.1,3880.1,3880.1,4850.1,3880.1,3880.1,100.0,403.4,183.2,414.8,111.3,61.5,470.4,108.9,56.2,54.7,94.6,513.6,463.8,115.4,58.9,126.8,68.3,206.6,17.7,6.1,6.7,2.4,1.8,4.2,2.4,0.0,0.6,1.8,10.4,9.8,1.8,0.6,1.2,0.0,17.7,4.2,38.8,48.5,38.8,38.8,38.8,48.5,38.8,38.8,1600.0,16.00,16,16,16,35,74,560,1,43.1,38.5,1.337,0.994,1.356,28.204,6.000,1600.0,32.0,43.4,32.0,39.0,40.0,1.056,5.040,3.344,3.376,12.192,0.880,3.328,1.832,0.768,1.000,1.360,1.536,703,704,692,No,1.106,1.013,15.529,10.588,27,No,No,5951,176445,33,94.0,No,No,11883,16,0.0,0.0,0.0,0.000,0.000,149,2,0.1,0.2,0.3,0.064,0.275,16814,4342,49.0,51.0,0,7.000,28.000,1994.0,11.0,5.5,0.0,0.0,0.0,0.0,0.0,0.0,427,76,16.0,562,101,35,25.330,12.157,0,0.868,0.869,0.000,6.076,0.000,67.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:21:27.792,5196,34153,13.2,3237,29455,9.9,0.0,1.356,0.981,1.344,0.981,0.988,0.981,0.988,1.337,3880.1,3880.1,3775.1,3775.1,3775.1,3880.1,3775.1,4850.1,100.0,595.7,188.5,152.4,107.8,27.7,507.4,99.3,58.8,41.4,56.3,739.9,398.7,132.0,69.6,143.0,66.2,211.5,23.7,3.6,1.8,2.4,0.6,6.0,1.8,0.6,1.2,0.0,4.2,3.6,1.8,0.6,2.4,1.2,23.7,3.5,38.8,38.8,37.8,37.8,37.8,38.8,37.8,48.5,1600.0,16.00,16,16,16,35,74,560,1,43.5,37.3,0.981,0.994,0.994,15.467,6.000,1600.0,32.0,43.5,33.0,39.0,40.0,1.248,5.040,3.344,3.376,12.192,0.880,3.328,1.832,0.768,1.008,1.360,1.536,708,704,1350,No,1.100,1.013,13.412,10.588,27,No,No,5951,176445,33,94.0,No,No,11883,16,0.0,0.0,0.0,0.000,0.000,149,2,0.2,1.1,1.3,0.134,1.148,16814,4344,50.0,51.0,0,4.000,27.000,1988.0,0.0,1.8,0.0,0.0,0.0,0.0,0.0,0.0,342,64,16.0,483,101,35,2.214,3.052,0,0.868,0.869,0.000,3.472,0.000,3.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:21:30.426,5218,34130,13.2,3269,29424,9.9,0.0,1.425,1.419,1.450,1.438,1.356,1.431,1.000,1.000,4850.1,3880.1,3880.1,3880.1,3775.1,3775.1,3775.1,3775.1,100.0,793.8,443.7,652.9,488.9,211.6,587.8,358.7,184.5,170.7,194.9,1140.5,563.8,268.8,210.8,540.3,289.6,443.8,21.3,10.9,13.9,10.3,4.2,12.8,9.7,2.4,3.6,5.4,16.4,10.9,3.6,4.8,9.7,6.0,21.3,9.1,48.5,38.8,38.8,38.8,37.8,37.8,37.8,37.8,1600.0,16.00,16,16,16,35,74,560,1,50.1,40.0,0.987,0.994,1.000,12.737,6.000,1600.0,31.0,49.9,33.0,39.0,40.0,1.344,5.000,3.344,3.376,12.192,0.872,3.328,1.832,0.768,1.008,1.360,1.536,720,703,692,No,1.113,1.013,14.824,10.588,27,No,No,5951,176445,36,94.0,No,No,11883,16,2.1,11.1,13.2,0.005,0.006,149,2,4.4,0.2,4.6,3.321,0.248,16823,4345,50.0,51.0,0,7.000,26.000,1990.0,0.0,3.7,0.0,0.0,0.0,0.0,0.0,0.0,338,65,16.0,479,101,35,8.396,60.469,0,0.893,0.894,0.000,6.251,0.000,3.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:21:33.135,5248,34101,13.3,3263,29429,9.9,0.0,0.981,1.344,0.988,1.350,0.981,1.350,1.344,1.350,3775.1,3775.1,3775.1,3880.1,3880.1,4850.1,3880.1,3775.1,100.0,466.1,218.7,241.8,166.8,79.6,473.6,167.4,281.3,91.6,68.3,583.4,824.2,172.8,99.9,263.3,132.1,270.7,17.1,10.0,2.9,2.9,1.1,7.6,4.1,1.7,1.7,1.1,7.6,12.4,0.5,1.7,2.9,2.3,17.1,4.9,37.8,37.8,37.8,38.8,38.8,48.5,38.8,37.8,1600.0,16.00,16,16,16,35,74,560,1,49.8,38.5,0.981,0.994,0.994,13.647,6.000,1600.0,32.0,49.9,33.0,39.0,40.0,1.312,5.040,3.328,3.376,12.192,0.872,3.328,1.832,0.768,1.000,1.360,1.536,734,706,692,No,1.106,1.013,14.118,11.294,27,No,No,5951,176445,34,94.0,No,No,11883,16,100.0,0.0,100.0,2.171,0.000,154,2,100.0,0.3,100.0,25.612,0.867,16889,4347,50.0,51.0,0,4.000,27.000,1988.0,0.0,2.4,0.0,0.0,0.0,0.0,0.0,0.0,334,63,16.0,476,101,35,15.687,4.316,0,0.868,0.869,0.000,3.472,0.000,3.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:21:35.708,5311,34038,13.4,3327,29366,10.1,0.0,1.350,1.344,1.363,1.350,1.344,1.337,1.350,1.344,3775.1,3880.1,3775.1,3880.1,3880.1,4850.1,3880.1,3880.1,100.0,719.0,342.0,788.6,248.8,43.9,457.6,131.8,41.4,30.9,23.9,1414.0,510.2,190.0,39.3,115.5,77.4,323.4,19.6,8.6,16.7,5.2,0.5,4.0,4.0,0.5,1.1,0.0,23.6,12.7,4.0,2.3,3.4,1.7,23.6,6.7,37.8,38.8,37.8,38.8,38.8,48.5,38.8,38.8,1600.0,16.00,16,16,16,35,74,560,1,53.5,41.0,1.350,0.994,1.363,20.016,6.000,1600.0,32.0,53.5,33.0,39.0,40.0,1.352,5.000,3.328,3.376,12.192,0.864,3.328,1.832,0.768,1.000,1.360,1.536,746,706,692,No,1.106,1.013,16.235,10.588,27,No,No,5951,176445,34,94.0,No,No,11883,16,19.9,0.0,19.9,1.100,0.000,157,2,0.3,0.1,0.4,0.127,0.329,16889,4348,50.0,51.0,0,4.000,25.000,1988.0,0.0,1.1,0.0,0.0,0.0,0.0,0.0,0.0,309,61,16.0,451,101,35,0.264,2.346,0,0.868,0.869,0.000,3.472,0.000,5.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:21:38.278,5371,33978,13.6,3381,29311,10.3,0.0,1.400,1.381,1.394,1.394,1.394,1.388,1.381,1.369,4850.1,4850.1,3880.1,4850.1,4850.1,4850.1,3880.1,4850.1,100.0,1082.9,225.2,768.9,210.1,92.2,263.3,306.5,29.1,349.1,260.5,842.6,298.8,221.0,54.5,225.6,97.9,333.0,27.2,4.8,12.1,4.8,1.8,3.0,2.4,0.6,4.2,3.0,10.9,6.0,2.4,1.2,4.2,1.2,27.2,5.6,48.5,48.5,38.8,48.5,48.5,48.5,38.8,48.5,1600.0,16.00,16,16,16,35,74,560,1,52.6,42.3,1.337,0.994,1.356,30.024,6.000,1600.0,32.0,52.9,33.0,39.0,40.0,1.368,5.000,3.328,3.376,12.192,0.864,3.328,1.832,0.768,1.008,1.360,1.536,742,1442,692,No,1.106,1.013,16.235,10.588,27,No,No,5951,176445,34,94.0,No,No,11883,16,4.8,0.1,4.9,0.129,0.105,157,2,0.6,0.3,0.9,0.429,0.652,16890,4350,50.0,51.0,0,4.000,24.000,1990.0,0.0,3.1,0.0,0.0,0.0,0.0,0.0,0.0,317,65,16.0,459,101,35,1.622,3.423,0,0.868,0.869,0.000,3.472,0.000,6.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:21:40.863,5439,33909,13.8,3469,29224,10.6,0.0,1.400,1.438,1.425,1.425,1.438,1.431,1.425,1.425,4850.1,4825.1,4825.1,4825.1,3880.1,4850.1,3880.1,3880.1,100.0,963.7,687.3,1509.6,362.0,484.0,536.6,593.9,252.6,434.2,225.9,1905.5,575.2,469.2,250.1,566.9,223.7,627.5,22.5,13.4,31.0,7.9,8.5,10.3,12.1,5.4,10.3,4.2,38.4,12.8,10.9,9.1,12.1,4.8,38.4,13.4,48.5,48.3,48.3,48.3,38.8,48.5,38.8,38.8,1600.0,16.00,16,16,16,35,74,560,1,59.0,69.5,1.425,1.000,1.450,45.490,6.000,1600.0,31.0,58.0,33.0,39.0,40.0,1.424,5.000,3.328,3.376,12.192,0.864,3.328,1.832,0.760,1.008,1.360,1.536,754,1442,1343,No,1.119,1.013,26.824,10.588,27,No,No,5951,176445,36,94.0,No,No,11883,16,0.0,3.8,3.8,0.000,0.025,157,2,100.0,8.8,100.0,91.385,0.929,17116,4352,50.0,51.0,0,6.000,27.000,1990.0,0.0,0.4,0.0,0.0,0.0,0.0,0.0,0.0,307,63,16.0,449,101,35,10.346,36.095,0,0.868,0.869,0.000,0.000,0.000,6.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:21:43.427,5490,33859,13.9,3554,29139,10.8,0.0,1.356,1.356,1.350,1.356,1.350,1.350,1.344,1.344,3880.1,3880.1,3880.1,3880.1,4850.1,3880.1,3880.1,3880.1,100.0,1521.2,690.7,1049.7,239.2,250.8,313.7,494.8,51.3,241.8,198.2,1333.2,365.7,184.5,214.2,381.4,142.6,479.6,32.5,13.3,19.3,6.7,4.2,6.0,5.4,0.6,3.0,3.6,29.5,4.8,3.6,5.4,8.4,3.6,32.5,9.4,38.8,38.8,38.8,38.8,48.5,38.8,38.8,38.8,1600.0,16.00,16,16,16,35,74,560,1,59.4,41.8,1.344,1.000,1.369,40.941,6.400,1600.0,32.0,59.5,34.0,39.0,40.0,1.368,5.000,3.328,3.376,12.192,0.856,3.328,1.832,0.760,1.008,1.360,1.536,777,1442,1351,No,1.106,1.013,22.588,10.588,27,No,No,5951,176445,36,94.0,No,No,11883,16,0.0,0.0,0.0,0.000,0.001,157,2,100.0,0.9,100.0,29.694,1.487,17188,4356,50.0,52.0,0,4.000,26.000,1990.0,0.0,1.8,0.0,0.0,0.0,0.0,0.0,0.0,323,63,16.0,465,101,35,33.336,10.898,0,0.868,0.869,0.000,3.472,0.000,4.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:21:45.986,5967,33381,15.1,3901,28791,11.9,0.0,1.438,1.419,1.313,1.313,1.344,1.344,1.337,1.319,4850.1,4825.1,4700.1,4725.1,4725.1,4750.1,4825.1,4750.1,100.0,2836.8,731.5,2264.5,774.7,941.8,542.2,833.8,749.6,659.9,321.5,1856.7,1114.9,449.7,615.8,583.1,307.9,974.0,59.1,12.7,44.8,20.4,21.9,9.0,20.1,10.9,13.3,4.2,38.4,26.6,8.5,10.9,12.8,7.8,59.1,20.1,48.5,48.3,47.0,47.3,47.3,47.5,48.3,47.5,1600.0,16.00,16,16,16,35,74,560,1,61.0,63.3,1.350,1.000,1.381,55.498,6.800,1600.0,31.0,60.5,34.0,39.0,40.0,1.368,5.000,3.328,3.376,12.192,0.848,3.328,1.832,0.760,1.008,1.360,1.536,778,707,692,No,1.100,1.013,39.529,12.000,27,No,No,5951,176445,38,94.0,No,No,11884,16,0.0,0.0,0.0,0.000,0.000,157,2,100.0,20.6,100.0,91.711,80.526,17412,4552,51.0,52.0,0,4.000,25.000,1990.0,8.0,9.2,0.0,0.0,0.0,0.0,0.0,0.0,180,63,16.0,322,151,35,19926.394,240.921,0,0.868,0.869,0.000,3.472,0.000,55.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:21:48.549,6270,33079,15.9,4320,28372,13.2,0.0,1.438,1.444,1.438,1.425,1.419,1.413,1.400,1.394,4850.1,3880.1,3880.1,3880.1,4850.1,4850.1,3880.1,3880.1,100.0,3387.2,610.4,2192.5,916.5,1279.4,476.4,1466.5,255.7,1625.3,245.1,2928.5,702.3,862.2,504.1,864.2,297.8,1163.4,70.5,11.6,46.6,17.7,24.5,9.2,31.9,4.9,35.5,2.4,62.5,14.1,12.2,9.8,14.1,5.5,70.5,23.3,48.5,38.8,38.8,38.8,48.5,48.5,38.8,38.8,1600.0,16.00,16,16,16,35,74,560,1,61.8,56.3,1.419,0.994,1.431,31.843,6.400,1600.0,32.0,61.0,35.0,39.0,40.0,1.440,5.000,3.328,3.376,12.192,0.840,3.328,1.832,0.760,1.008,1.360,1.536,795,708,1351,No,1.119,1.013,23.294,11.294,27,No,No,5951,176445,38,94.0,No,No,11884,17,0.0,0.0,0.0,0.000,0.001,157,2,100.0,4.6,100.0,95.408,20.474,17645,4602,51.0,52.0,0,7.000,25.000,1990.0,0.0,9.5,0.0,0.0,0.0,0.0,0.0,0.0,180,63,16.0,322,313,37,64821.833,697.021,0,0.868,0.894,0.500,6.076,0.447,9.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:21:51.125,6073,33275,15.4,4459,28234,13.6,0.0,1.388,1.375,1.344,1.344,1.356,1.344,1.356,1.344,4850.1,3880.1,3880.1,3880.1,3880.1,3880.1,4850.1,3880.1,100.0,3420.2,266.0,1274.4,762.0,589.0,253.5,603.2,45.8,627.6,47.5,2287.6,176.5,342.5,106.0,422.8,72.9,706.1,67.8,4.8,23.7,16.4,11.5,5.4,9.6,1.2,9.7,0.6,51.5,1.2,5.4,0.6,10.3,1.8,67.8,13.8,48.5,38.8,38.8,38.8,38.8,38.8,48.5,38.8,1600.0,16.00,16,16,16,35,74,560,1,61.3,52.0,1.375,0.994,1.400,39.122,6.000,1600.0,32.0,61.6,35.0,39.0,40.0,1.392,5.000,3.344,3.376,12.192,0.832,3.328,1.832,0.760,1.008,1.360,1.536,841,709,1344,No,1.113,1.013,28.235,11.294,27,No,No,5951,176445,38,94.0,No,No,11884,17,0.0,0.0,0.0,0.000,0.000,157,2,32.3,35.9,68.2,21.389,81.242,17698,4802,51.0,52.0,0,5.000,27.000,1990.0,0.0,8.1,0.0,0.0,0.0,0.0,0.0,0.0,181,63,16.0,323,313,37,1.998,4.160,0,0.868,0.894,0.000,0.000,0.000,9.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:21:53.688,6598,32751,16.7,4675,28018,14.3,0.0,1.375,1.369,1.381,1.369,1.363,1.413,1.369,1.450,3880.1,4850.1,4850.1,3880.1,3880.1,4850.1,3880.1,3880.1,100.0,1091.6,103.7,2152.7,126.3,94.6,298.4,399.2,22.0,121.6,295.5,1552.6,175.4,321.8,161.1,166.7,82.8,447.9,25.6,0.6,43.0,3.0,1.8,4.2,10.3,0.6,1.2,3.6,30.4,3.0,3.0,2.4,1.8,3.0,43.0,8.6,38.8,48.5,48.5,38.8,38.8,48.5,38.8,38.8,1600.0,16.00,16,16,16,35,74,560,1,64.5,69.8,1.437,1.000,1.463,41.851,6.000,1600.0,32.0,64.5,35.0,39.0,40.0,1.432,5.000,3.344,3.376,12.192,0.832,3.328,1.832,0.760,1.008,1.360,1.536,860,712,693,No,1.125,1.013,30.353,10.588,27,No,No,5951,176445,34,94.0,No,No,11884,17,0.0,0.0,0.0,0.000,0.007,157,2,100.0,45.9,100.0,59.977,95.856,17845,5036,50.0,52.0,0,5.000,27.000,1988.0,0.0,0.8,0.0,0.0,0.0,0.0,0.0,0.0,186,63,16.0,328,313,37,1.873,0.816,0,0.868,0.894,0.000,0.000,0.000,9.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:21:56.239,6126,33223,15.5,4134,28558,12.6,0.0,1.388,1.363,1.356,1.363,1.350,1.350,1.356,1.356,4850.1,4850.1,4850.1,3880.1,3880.1,3880.1,3880.1,3880.1,100.0,2981.5,135.5,3342.9,97.9,111.0,293.5,411.7,22.4,151.3,62.2,1865.0,184.7,813.6,94.9,112.8,73.0,672.1,59.7,1.8,70.1,1.8,3.0,4.8,7.3,0.0,3.0,0.0,40.8,1.8,15.8,3.6,3.0,1.8,70.1,13.6,48.5,48.5,48.5,38.8,38.8,38.8,38.8,38.8,1600.0,16.00,16,16,16,35,74,560,1,66.8,58.3,1.350,0.994,1.369,28.204,6.000,1600.0,32.0,66.8,35.0,39.0,40.0,1.400,5.000,3.328,3.376,12.192,0.832,3.328,1.832,0.760,1.008,1.360,1.536,881,713,693,No,1.106,1.013,20.471,10.588,27,No,No,5951,176445,34,94.0,No,No,11884,17,0.0,0.0,0.0,0.000,0.000,157,2,1.2,2.2,3.4,0.885,10.892,17847,5063,50.0,52.0,0,5.000,27.000,1990.0,0.0,0.3,0.0,0.0,0.0,0.0,0.0,0.0,186,63,16.0,328,313,37,1.189,2.818,0,0.868,0.894,0.000,0.000,0.000,9.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:21:59.164,6179,33169,15.7,4173,28519,12.7,0.0,1.400,1.394,1.388,1.400,1.400,1.381,1.375,1.419,4750.1,4750.1,3800.1,4775.1,3800.1,4850.1,4775.1,3820.1,100.0,1045.9,1216.8,3945.8,220.6,242.0,279.8,597.4,144.1,271.2,175.5,993.8,449.5,333.4,337.7,519.2,302.8,692.2,20.1,24.8,82.3,4.2,4.2,3.0,14.0,3.6,6.0,3.6,17.6,7.9,4.2,6.7,10.3,3.0,82.3,13.5,47.5,47.5,38.0,47.8,38.0,48.5,47.8,38.2,1600.0,16.00,16,16,16,35,74,560,1,66.1,74.3,1.419,0.994,1.444,34.573,6.400,1600.0,32.0,65.6,35.0,39.0,40.0,1.408,5.000,3.344,3.376,12.192,0.832,3.328,1.832,0.760,1.008,1.360,1.536,936,1451,1351,No,1.113,1.013,28.941,10.588,27,No,No,5951,176445,36,94.0,No,No,11884,17,50.9,0.0,50.9,8.997,0.001,182,2,16.8,1.7,18.5,17.504,7.604,17895,5084,51.0,52.0,0,5.000,27.000,1990.0,0.0,1.8,0.0,0.0,0.0,0.0,0.0,0.0,182,67,16.0,324,313,37,3.520,26.757,0,0.868,0.894,0.000,0.000,0.000,9.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:22:1.737,6813,32535,17.3,4680,28012,14.3,0.0,1.363,1.363,1.363,1.363,1.369,1.369,1.363,1.363,3880.1,4850.1,4850.1,3880.1,3880.1,4850.1,4850.1,3880.1,100.0,1124.0,477.7,4616.9,6.2,701.9,315.9,1141.7,50.2,489.3,155.2,1647.5,342.0,252.8,162.1,328.5,88.9,743.8,22.9,8.6,94.6,0.0,12.2,3.7,23.5,1.0,11.7,3.7,32.0,7.4,4.2,2.6,5.8,1.6,94.6,14.7,38.8,48.5,48.5,38.8,38.8,48.5,48.5,38.8,1600.0,16.00,16,16,16,35,74,560,1,67.4,53.8,1.356,0.994,1.375,30.024,6.400,1600.0,32.0,67.6,35.0,39.0,40.0,1.448,5.000,3.344,3.376,12.192,0.824,3.328,1.832,0.760,1.008,1.360,1.536,1005,720,1352,No,1.106,1.013,24.706,11.294,27,No,No,5951,176445,36,94.0,No,No,11884,17,30.3,0.0,30.3,11.624,0.000,211,2,7.3,1.4,8.7,8.136,6.581,17915,5100,51.0,52.0,0,5.000,27.000,1990.0,0.0,1.0,0.0,0.0,0.0,0.0,0.0,0.0,200,66,16.0,342,313,37,18.147,4.617,0,0.868,0.894,0.000,0.000,0.000,9.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:22:4.297,6714,32634,17.0,4418,28274,13.5,0.0,1.363,1.363,1.369,1.369,1.381,1.406,1.400,1.413,4850.1,4850.1,4850.1,3880.1,3880.1,4850.1,4850.1,3880.1,100.0,2348.2,643.5,2584.5,396.5,262.3,304.9,782.8,73.1,473.2,96.4,1363.2,271.6,173.8,153.7,341.5,65.3,645.9,54.8,12.1,50.6,7.8,6.0,2.4,10.9,1.2,9.7,0.6,20.7,6.0,1.8,2.4,3.6,1.2,54.8,12.0,48.5,48.5,48.5,38.8,38.8,48.5,48.5,38.8,1600.0,16.00,16,16,16,35,74,560,1,64.6,55.3,1.400,0.994,1.425,38.212,6.000,1600.0,32.0,64.8,35.0,39.0,40.0,1.424,5.000,3.344,3.376,12.192,0.824,3.328,1.832,0.752,1.008,1.360,1.536,1040,1465,1344,No,1.113,1.013,29.647,11.294,27,No,No,5951,176445,36,94.0,No,No,11884,17,0.0,0.0,0.0,0.000,0.006,211,2,6.4,1.1,7.5,15.238,5.389,17953,5113,51.0,53.0,0,8.000,26.000,1988.0,32.0,1.5,0.0,0.0,0.0,0.0,0.0,0.0,214,66,16.0,356,315,37,683.074,11.213,0,0.893,0.894,0.250,7.144,0.223,500.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:22:6.854,8870,30479,22.5,5750,26942,17.5,0.0,1.419,1.419,1.406,1.406,1.419,1.413,1.425,1.419,4850.1,4850.1,4850.1,4850.1,4850.1,4850.1,3880.1,3880.1,100.0,2796.6,1783.6,4346.5,303.7,737.0,400.9,1635.2,103.6,792.6,179.4,1660.6,231.2,737.3,239.5,443.8,146.4,1033.6,58.2,34.9,91.4,5.4,14.1,7.9,37.4,2.4,12.8,2.4,33.1,3.0,10.4,4.2,8.5,0.6,91.4,20.4,48.5,48.5,48.5,48.5,48.5,48.5,38.8,38.8,1600.0,16.00,16,16,16,35,74,560,1,67.8,69.3,1.412,0.994,1.444,39.122,6.000,1600.0,32.0,67.4,35.0,39.0,40.0,1.416,5.000,3.344,3.376,12.192,0.824,3.328,1.832,0.752,1.008,1.360,1.536,1120,1472,1351,No,1.119,1.013,35.294,10.588,27,No,No,5951,176445,36,94.0,No,No,11884,17,0.0,0.0,0.0,0.000,0.000,211,2,100.0,0.8,100.0,46.943,3.954,18067,5123,51.0,52.0,0,5.000,27.000,1990.0,0.0,1.2,0.0,0.0,0.0,0.0,0.0,0.0,955,1178,16.0,1105,315,37,0.137,0.147,0,0.893,0.894,0.000,0.000,0.000,500.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:22:9.431,9332,30016,23.7,6282,26411,19.2,0.0,1.219,1.406,1.400,1.438,1.431,1.419,1.400,1.281,4550.1,4775.1,3880.1,4825.1,4800.1,3880.1,4750.1,4650.1,100.0,4474.1,1250.4,3789.7,1479.5,1209.2,603.2,2333.9,710.2,1740.5,603.9,1486.3,684.3,1294.4,353.7,1029.0,271.3,1457.1,93.9,26.2,78.0,31.7,26.8,10.9,50.6,15.2,36.5,6.7,29.8,10.9,24.3,9.1,17.0,3.6,93.9,29.5,45.5,47.8,38.8,48.3,48.0,38.8,47.5,46.5,1600.0,16.00,16,16,16,35,74,560,1,67.3,57.8,1.244,1.000,1.275,57.318,7.600,1600.0,32.0,67.4,36.0,39.0,40.0,1.328,5.000,3.328,3.376,12.192,0.824,3.328,1.832,0.752,1.008,1.376,1.536,1173,1481,1344,No,1.081,1.013,40.235,12.000,27,No,No,5951,176445,38,94.0,No,No,11884,17,0.0,0.1,0.1,0.000,0.054,211,2,69.7,30.9,100.0,93.305,4.012,18295,5133,51.0,53.0,0,4.000,27.000,1990.0,0.0,1.9,0.0,0.0,0.0,0.0,0.0,0.0,1043,1195,16.0,1153,315,37,0.046,0.000,0,0.893,0.894,0.000,0.000,0.000,500.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:22:12.006,10108,29240,25.6,6779,25914,20.7,0.0,1.238,1.206,1.200,1.200,1.225,1.212,1.175,1.200,4575.1,4525.1,4525.1,4575.1,4575.1,4525.1,4450.1,4525.1,100.0,3257.9,3070.0,2871.5,3396.6,2127.5,1214.0,3790.6,1310.9,3061.8,1220.3,1693.9,2072.7,2025.3,1009.5,1891.0,920.9,2183.4,65.2,62.8,56.0,73.7,43.9,25.0,78.6,23.7,58.5,26.8,26.8,42.6,44.5,15.8,35.3,16.4,78.6,43.5,45.8,45.3,45.3,45.8,45.8,45.3,44.5,45.3,1600.0,16.00,16,16,16,35,74,560,1,66.5,60.5,1.212,1.000,1.244,57.318,6.400,1600.0,32.0,66.6,36.0,39.0,40.0,1.232,5.000,3.328,3.376,12.192,0.816,3.328,1.832,0.752,1.008,1.376,1.536,1231,1495,1344,No,1.063,1.013,43.059,12.000,27,No,No,5951,176445,38,94.0,No,No,11884,18,0.0,0.0,0.0,0.000,0.000,211,2,100.0,38.2,100.0,192.624,3.028,18767,5140,51.0,53.0,0,4.000,27.000,1980.0,1.0,24.3,0.0,0.0,0.0,0.0,0.0,0.0,1349,1207,16.0,1492,315,37,12.257,7.553,0,0.868,0.869,0.250,3.472,0.217,39.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:22:14.642,11769,27580,29.9,8070,24623,24.6,0.0,1.419,1.419,1.406,1.369,1.406,1.406,1.388,1.413,4800.1,4825.1,4750.1,4825.1,4775.1,4775.1,4800.1,4750.1,100.0,3807.6,3759.8,3606.8,4062.0,3405.5,2109.1,3935.3,2951.6,3886.7,2829.1,2385.2,2643.3,3256.4,1651.7,3124.7,1792.0,3075.4,82.4,80.6,78.1,85.4,72.7,50.3,86.0,65.4,81.2,64.8,46.0,55.1,63.0,35.7,73.3,38.1,86.0,66.1,48.0,48.3,47.5,48.3,47.8,47.8,48.0,47.5,1600.0,16.00,16,16,16,35,74,560,1,66.6,71.8,1.381,1.000,1.413,50.039,6.000,1600.0,32.0,66.8,36.0,40.0,40.0,1.392,5.000,3.344,3.376,12.192,0.808,3.328,1.832,0.752,1.008,1.360,1.536,1236,740,692,No,1.106,1.013,36.706,11.294,27,No,No,5951,176445,38,94.0,No,No,11884,18,0.0,0.0,0.0,0.000,0.006,211,2,32.6,2.5,35.1,44.169,2.899,18879,5147,52.0,53.0,0,8.000,26.000,1972.0,11.0,22.4,0.0,0.0,0.0,0.0,0.0,0.0,1713,1208,16.0,1852,315,37,13.761,4.925,0,0.893,0.894,0.250,7.144,0.223,181.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:22:17.206,11693,27656,29.7,7882,24811,24.1,0.0,1.406,1.388,1.406,1.381,1.394,1.413,1.400,1.400,4825.1,4800.1,4800.1,4800.1,4850.1,4850.1,4800.1,4800.1,100.0,3239.6,2332.0,1917.7,3515.5,1663.2,748.7,3514.1,730.2,2684.5,759.2,1040.5,1512.4,1594.5,406.7,1091.0,397.8,1696.7,71.5,49.7,40.8,75.1,37.2,10.6,72.7,14.2,57.9,13.0,17.7,30.7,30.1,4.7,21.3,6.5,75.1,34.6,48.3,48.0,48.0,48.0,48.5,48.5,48.0,48.0,1600.0,16.00,16,16,16,35,74,560,1,67.9,62.3,1.350,1.000,1.381,50.949,6.400,1600.0,32.0,67.9,37.0,40.0,40.0,1.392,5.000,3.344,3.376,12.192,0.808,3.328,1.832,0.752,1.008,1.360,1.536,1252,1503,1350,No,1.087,1.013,33.882,11.294,27,No,No,5951,176445,39,94.0,No,No,11884,18,0.0,0.0,0.0,0.000,0.000,211,2,80.1,0.5,80.6,150.439,1.844,19246,5152,52.0,53.0,0,7.000,25.000,1992.0,0.0,9.7,0.0,0.0,0.0,0.0,0.0,0.0,1852,1211,16.0,1984,315,37,41.745,8.248,0,0.868,0.869,0.000,6.076,0.000,9.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:22:19.776,12699,26650,32.2,8533,24160,26.1,0.0,1.413,1.331,1.369,1.325,1.337,1.394,1.394,1.400,4775.1,4700.1,4775.1,4750.1,4775.1,4850.1,4800.1,4800.1,100.0,2827.1,2734.8,2911.0,2871.0,2180.2,706.0,3938.6,674.4,3425.7,500.6,1202.4,1784.4,1836.4,547.5,1139.4,511.2,1861.9,55.4,53.6,55.4,62.1,40.2,10.9,83.5,11.5,71.9,6.7,17.6,32.3,32.3,12.1,23.1,4.8,83.5,35.8,47.8,47.0,47.8,47.5,47.8,48.5,48.0,48.0,1600.0,16.00,16,16,16,35,74,560,1,68.4,68.5,1.394,1.000,1.419,45.490,6.400,1600.0,32.0,68.4,37.0,40.0,40.0,1.376,5.000,3.344,3.376,12.192,0.800,3.328,1.832,0.752,1.008,1.376,1.536,1285,1506,1343,No,1.113,1.013,37.412,11.294,27,No,No,5951,176445,39,94.0,No,No,11884,19,0.0,0.0,0.0,0.000,0.001,211,2,60.6,8.3,68.9,247.200,4.832,19851,5164,52.0,54.0,0,4.000,27.000,1990.0,0.0,8.2,0.0,0.0,0.0,0.0,0.0,0.0,1858,1211,16.0,1990,315,37,133.817,28.387,0,0.868,0.869,0.000,3.472,0.000,3.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:22:22.341,13136,26212,33.3,9004,23688,27.5,0.0,1.319,1.406,1.406,1.331,1.319,1.350,1.313,1.331,4750.1,4775.1,4775.1,4675.1,4675.1,4700.1,4700.1,4725.1,100.0,2702.6,3052.2,2870.7,3154.8,2555.1,738.9,4052.7,821.5,3496.6,789.2,1434.0,1894.3,2148.5,657.6,1280.3,612.7,2016.4,56.3,59.3,60.0,70.3,57.5,10.3,83.6,15.7,69.0,13.9,23.6,37.5,41.2,13.3,25.4,15.1,83.6,40.7,47.5,47.8,47.8,46.8,46.8,47.0,47.0,47.3,1600.0,16.00,16,16,16,35,74,560,1,68.4,66.5,1.325,1.000,1.356,52.769,6.400,1600.0,32.0,68.4,37.0,40.0,40.0,1.360,5.000,3.328,3.376,12.192,0.792,3.328,1.832,0.752,1.008,1.360,1.536,1317,1521,1344,No,1.094,1.013,38.118,14.824,27,No,No,5951,176445,39,94.0,No,No,11884,19,0.0,0.0,0.0,0.000,0.000,211,2,100.0,0.1,100.0,153.309,0.282,20226,5164,52.0,53.0,0,4.000,27.000,1992.0,0.0,7.2,0.0,0.0,0.0,0.0,0.0,0.0,1855,1210,16.0,1987,315,38,23.830,11.965,0,0.868,0.869,0.000,3.472,0.000,4.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:22:24.919,13551,25798,34.4,9082,23611,27.7,0.0,1.394,1.394,1.406,1.413,1.394,1.413,1.406,1.400,4800.1,4775.1,4775.1,4800.1,4800.1,4825.1,4825.1,3860.1,100.0,3381.4,2019.1,1715.6,3449.4,1633.7,535.3,3644.7,403.4,2664.1,423.5,637.3,1759.4,1405.0,344.8,751.0,296.4,1566.5,68.9,42.0,33.5,70.7,34.1,10.9,75.0,4.8,54.8,9.7,12.1,31.0,25.0,10.3,15.8,2.4,75.0,31.3,48.0,47.8,47.8,48.0,48.0,48.3,48.3,38.6,1600.0,16.00,16,16,16,35,74,560,1,67.6,66.0,1.400,0.994,1.431,47.310,6.400,1600.0,32.0,67.6,37.0,40.0,40.0,1.416,5.000,3.344,3.376,12.192,0.792,3.328,1.832,0.752,1.008,1.360,1.536,1319,1528,1351,No,1.119,1.013,33.882,11.294,27,No,No,5951,176445,38,94.0,No,No,11884,19,0.0,0.0,0.0,0.000,0.012,211,2,9.5,0.1,9.6,25.477,0.331,20289,5165,52.0,53.0,0,7.000,27.000,1940.0,10.0,7.4,0.0,0.0,0.0,0.0,0.0,0.0,2501,1210,16.0,2627,315,38,4.206,6.754,0,0.868,0.869,0.000,6.076,0.000,55.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:22:27.509,13554,25795,34.4,9083,23610,27.7,0.0,1.400,1.406,1.419,1.413,1.356,1.406,1.394,1.400,4825.1,4825.1,3860.1,4850.1,4850.1,4850.1,4800.1,3840.1,100.0,3518.5,1491.2,2632.5,2506.2,1200.0,348.1,3712.9,294.5,2079.4,317.2,1100.8,371.3,820.0,208.8,544.5,177.0,1332.7,73.9,29.0,58.1,50.9,22.4,6.0,73.3,4.2,40.0,4.2,21.2,4.2,18.1,2.4,8.4,1.8,73.9,26.1,48.3,48.3,38.6,48.5,48.5,48.5,48.0,38.4,1600.0,16.00,16,16,16,35,74,560,1,68.5,65.0,1.412,1.000,1.438,51.859,6.400,1600.0,32.0,68.5,38.0,40.0,40.0,1.408,5.000,3.344,3.376,12.192,0.784,3.328,1.832,0.752,1.008,1.360,1.536,1317,1516,693,No,1.113,1.013,35.294,11.294,27,No,No,5951,176445,38,94.0,No,No,11884,19,0.0,0.0,0.0,0.000,0.000,211,2,0.2,0.1,0.3,0.189,0.235,20289,5166,52.0,53.0,0,7.000,27.000,1980.0,37.0,6.8,2.0,0.0,0.0,0.0,0.0,0.0,2501,1210,16.0,2627,315,38,86.496,3.015,0,0.868,0.869,0.000,6.076,0.000,500.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:22:30.079,13470,25879,34.2,9005,23688,27.5,0.0,1.406,1.400,1.406,1.394,1.406,1.413,1.400,1.406,4850.1,4800.1,4825.1,4825.1,4800.1,4825.1,4825.1,3880.1,100.0,2578.0,2531.2,2478.3,2423.4,1315.0,348.1,4005.1,175.5,1931.2,373.5,1294.9,273.2,823.2,225.4,446.1,187.8,1338.1,54.2,50.6,52.4,51.2,21.0,4.8,77.7,2.4,40.9,6.6,24.0,3.0,11.4,4.8,5.4,1.2,77.7,25.7,48.5,48.0,48.3,48.3,48.0,48.3,48.3,38.8,1600.0,16.00,16,16,16,35,74,560,1,68.9,64.5,1.400,1.000,1.425,45.490,6.000,1600.0,32.0,69.0,38.0,40.0,40.0,1.408,5.000,3.344,3.376,12.192,0.784,3.328,1.832,0.744,1.008,1.360,1.536,1326,1516,692,No,1.119,1.013,34.588,11.294,27,No,No,5951,176445,39,94.0,No,No,11884,19,0.0,0.0,0.0,0.000,0.004,211,2,2.2,0.5,2.7,8.224,0.231,20309,5166,52.0,54.0,0,4.000,27.000,1980.0,0.0,12.4,0.0,0.0,0.0,0.0,0.0,0.0,2508,1340,16.0,2633,315,38,57.017,6.210,0,0.868,0.869,0.000,3.472,0.000,5.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:22:32.651,12974,26375,32.9,8384,24309,25.6,0.0,1.413,1.413,1.394,1.388,1.419,1.438,1.356,1.375,4850.1,4850.1,4850.1,4850.1,4850.1,4850.1,4775.1,3840.1,100.0,2335.5,3783.2,1852.0,4072.4,2007.9,1101.5,3284.9,1324.5,2398.1,1283.6,1677.5,1094.5,1761.6,1017.2,1604.7,826.7,1964.1,50.0,76.8,38.4,85.9,45.1,19.5,65.8,27.4,45.7,26.8,31.0,22.5,38.4,18.9,29.2,16.4,85.9,39.9,48.5,48.5,48.5,48.5,48.5,48.5,47.8,38.4,1600.0,16.00,16,16,16,35,74,560,1,67.1,65.3,1.425,1.000,1.450,45.490,6.400,1600.0,32.0,67.3,38.0,40.0,40.0,1.400,5.000,3.328,3.376,12.192,0.784,3.328,1.832,0.744,1.008,1.360,1.536,1365,750,1345,No,1.119,1.013,33.176,10.588,27,No,No,5951,176445,38,94.0,No,No,11884,19,0.0,0.0,0.0,0.000,0.000,211,2,0.1,0.1,0.2,0.106,0.158,20310,5167,53.0,54.0,0,4.000,28.000,1986.0,94.0,27.3,0.0,0.0,0.0,0.0,0.0,0.0,2571,1340,16.0,2693,316,38,51.788,9.319,0,0.868,0.869,0.000,3.472,0.000,852.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:22:35.219,12845,26504,32.6,8257,24435,25.2,0.0,1.406,1.400,1.413,1.419,1.419,1.406,1.406,1.394,4850.1,4850.1,4850.1,4850.1,3880.1,4800.1,4850.1,3880.1,100.0,2467.5,2623.7,1393.8,3749.8,1332.1,358.9,3465.7,442.0,2061.6,370.6,1293.7,386.2,1018.7,306.2,548.7,321.3,1383.8,52.7,51.5,24.2,81.8,27.2,6.6,70.9,6.6,38.7,6.6,20.0,4.2,23.0,6.6,9.0,4.8,81.8,27.2,48.5,48.5,48.5,48.5,38.8,48.0,48.5,38.8,1600.0,16.00,16,16,16,35,74,560,1,66.4,63.0,1.387,0.994,1.413,49.129,7.600,1600.0,32.0,66.5,38.0,40.0,40.0,1.408,5.000,3.344,3.376,12.192,0.784,3.328,1.832,0.744,1.008,1.376,1.536,1378,1534,1344,No,1.119,1.013,30.353,12.706,27,No,No,5951,176445,38,94.0,No,No,11884,19,2.2,0.0,2.2,0.108,0.000,211,2,0.2,0.1,0.3,0.254,0.160,20310,5167,53.0,54.0,0,4.000,27.000,1994.0,0.0,15.3,0.0,0.0,0.0,0.0,0.0,0.0,2643,1340,16.0,2761,316,38,34.542,1.255,0,0.868,0.869,0.000,3.472,0.000,4.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:22:37.859,13891,25458,35.3,8805,23887,26.9,0.0,1.325,1.369,1.319,1.306,1.319,1.344,1.300,1.381,4725.1,4850.1,4725.1,4650.1,4725.1,4725.1,4700.1,3840.1,100.0,3950.2,1254.2,2953.8,2284.2,1510.2,447.1,3492.4,546.6,2391.7,379.4,1285.4,488.5,1052.9,365.0,562.8,418.1,1461.4,79.3,27.8,61.8,44.2,31.5,9.0,66.0,8.4,43.0,6.6,17.5,5.4,20.0,5.4,9.0,7.8,79.3,27.7,47.3,48.5,47.3,46.5,47.3,47.3,47.0,38.4,1600.0,16.00,16,16,16,35,74,560,1,65.9,64.5,1.406,1.000,1.431,41.851,6.400,1600.0,32.0,65.8,38.0,40.0,40.0,1.400,5.000,3.328,3.376,12.192,0.784,3.328,1.832,0.744,1.008,1.360,1.536,1356,751,693,No,1.113,1.013,29.647,12.000,27,No,No,5951,176445,38,94.0,No,No,11884,19,0.0,0.0,0.0,0.000,0.000,211,2,0.1,0.1,0.2,0.152,0.228,20311,5168,53.0,54.0,0,4.000,27.000,1994.0,0.0,10.6,0.0,0.0,0.0,0.0,0.0,0.0,2646,1340,16.0,2761,316,38,23.528,1.155,0,0.868,0.869,0.000,3.472,0.000,4.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:22:40.410,13841,25507,35.1,9163,23530,28.0,0.0,1.438,1.425,1.413,1.419,1.413,1.400,1.388,1.388,4825.1,4850.1,4850.1,4850.1,3880.1,4850.1,4850.1,4850.1,100.0,3411.6,1805.1,2906.4,2275.8,1459.3,548.6,3737.9,296.5,2497.4,425.4,1274.8,492.7,1104.3,470.1,547.1,399.8,1478.3,71.4,33.9,64.2,44.6,29.1,8.9,79.1,6.5,48.8,10.7,20.2,10.7,23.8,10.7,11.3,5.3,79.1,29.9,48.3,48.5,48.5,48.5,38.8,48.5,48.5,48.5,1600.0,16.00,16,16,16,35,74,560,1,65.9,57.5,1.369,0.994,1.394,36.392,6.800,1600.0,32.0,65.9,38.0,40.0,40.0,1.408,5.000,3.328,3.376,12.192,0.784,3.328,1.832,0.744,1.008,1.360,1.536,1315,751,1345,No,1.113,1.013,23.294,12.000,27,No,No,5951,176445,38,94.0,No,No,11884,19,0.0,0.0,0.0,0.000,0.000,211,2,6.8,1.6,8.4,26.726,0.584,20376,5169,53.0,54.0,0,4.000,27.000,1998.0,0.0,13.3,0.0,0.0,0.0,0.0,0.0,0.0,2646,1340,16.0,2761,316,38,53.869,12.390,0,0.868,0.869,0.000,3.472,0.000,4.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:22:42.973,14081,25267,35.7,9182,23511,28.0,0.0,1.381,1.375,1.375,1.388,1.381,1.388,1.369,1.400,4850.1,4850.1,4850.1,4850.1,3880.1,4850.1,4775.1,3880.1,100.0,1883.0,2122.6,2223.0,2438.0,854.9,370.9,1715.5,469.7,1161.3,364.0,1311.3,364.0,918.4,350.8,451.2,345.7,1084.0,33.5,40.8,42.3,49.3,12.1,4.2,32.3,8.5,18.2,5.4,26.2,5.4,9.7,4.8,4.2,7.3,49.3,19.0,48.5,48.5,48.5,48.5,38.8,48.5,47.8,38.8,1600.0,16.00,16,16,16,35,74,560,1,67.9,58.3,1.406,1.000,1.438,45.490,6.400,1600.0,32.0,68.1,38.0,40.0,40.0,1.392,5.000,3.328,3.376,12.192,0.776,3.328,1.832,0.744,1.008,1.360,1.536,1294,1525,1345,No,1.119,1.013,32.471,12.000,27,No,No,5951,176445,39,94.0,No,No,11884,19,0.0,0.0,0.0,0.000,0.000,211,2,24.7,2.9,27.5,63.123,0.122,20530,5170,54.0,56.0,0,9.000,30.000,1972.0,2.0,45.2,0.0,0.0,0.0,0.0,0.0,0.0,2913,1394,16.0,3026,316,38,0.229,0.156,0,0.893,0.894,1.000,8.037,0.894,44.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:22:45.527,14040,25308,35.6,9287,23406,28.4,0.0,1.375,1.363,1.381,1.375,1.400,1.388,1.375,1.375,4850.1,4850.1,4850.1,4850.1,3880.1,4850.1,4850.1,3880.1,100.0,2411.3,1942.8,1353.3,3461.6,1065.7,633.3,1942.3,713.0,1325.0,535.8,1062.4,995.0,1096.1,382.8,744.0,309.9,1248.4,37.4,31.9,26.2,68.0,15.9,12.2,29.4,6.7,16.5,5.5,14.1,15.9,15.9,4.2,9.8,3.0,68.0,19.5,48.5,48.5,48.5,48.5,38.8,48.5,48.5,38.8,1600.0,16.00,16,16,16,35,74,560,1,65.3,56.8,1.394,0.994,1.413,30.024,6.000,1600.0,32.0,65.5,38.0,40.0,40.0,1.384,5.000,3.328,3.376,12.192,0.784,3.328,1.832,0.744,1.008,1.360,1.536,1310,1513,1345,No,1.119,1.013,32.471,11.294,27,No,No,5951,176445,38,94.0,No,No,11884,20,0.0,0.0,0.0,0.000,0.000,211,2,12.6,0.1,12.8,29.696,0.305,20602,5170,54.0,56.0,0,11.000,28.000,1970.0,61.0,67.4,2.0,0.0,0.0,0.0,0.0,0.0,2914,1401,16.0,3026,316,38,1.059,3.794,0,0.893,0.887,2.750,9.823,2.441,706.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:22:48.092,14044,25304,35.6,9295,23398,28.4,0.0,1.350,1.381,1.375,1.369,1.369,1.381,1.388,1.381,4850.1,4850.1,3880.1,3880.1,4850.1,4850.1,3880.1,3880.1,100.0,2202.7,1932.2,1178.8,3553.1,1012.3,505.4,1796.9,515.2,1370.3,470.7,486.5,1563.6,831.3,249.7,579.1,286.2,1158.4,39.6,31.7,27.4,70.7,20.1,9.1,37.1,6.7,27.4,9.1,7.9,31.0,12.8,4.2,11.5,1.8,70.7,21.8,48.5,48.5,38.8,38.8,48.5,48.5,38.8,38.8,1600.0,16.00,16,16,16,35,74,560,1,63.1,56.0,1.369,1.000,1.394,50.039,6.800,1600.0,33.0,63.3,38.0,40.0,40.0,1.384,5.000,3.328,3.376,12.192,0.784,3.328,1.832,0.744,1.008,1.360,1.536,1299,747,693,No,1.113,1.013,25.412,12.706,27,No,No,5951,176445,38,94.0,No,No,11884,20,0.0,0.0,0.0,0.000,0.000,211,2,2.9,0.2,3.1,6.879,0.633,20619,5172,54.0,56.0,0,7.000,52.000,1990.0,99.0,65.8,3.0,0.0,0.0,0.0,0.0,0.0,2914,1404,16.0,3027,316,38,1.268,3.013,0,0.893,0.881,0.250,6.251,0.220,726.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:22:50.653,14619,24730,37.1,9775,22918,29.8,0.0,1.381,1.375,1.394,1.394,1.406,1.375,1.400,1.400,4850.1,4850.1,4850.1,4850.1,4850.1,4850.1,4850.1,4850.1,100.0,1665.9,3606.3,1493.0,3663.8,1773.4,677.3,3055.7,810.6,2263.2,752.0,611.6,1639.5,1398.1,438.8,863.3,489.8,1575.1,28.6,78.0,28.6,73.1,27.4,11.5,53.6,14.6,42.0,15.2,7.9,31.7,26.8,5.4,16.4,7.3,78.0,29.3,48.5,48.5,48.5,48.5,48.5,48.5,48.5,48.5,1600.0,16.00,16,16,16,35,74,560,1,63.1,55.0,1.400,1.000,1.419,43.671,6.400,1600.0,32.0,63.1,38.0,40.0,40.0,1.416,5.000,3.328,3.376,12.192,0.784,3.328,1.832,0.744,1.008,1.360,1.536,1273,1525,693,No,1.113,1.013,30.353,11.294,27,No,No,5951,176445,38,94.0,No,No,11884,20,0.0,0.0,0.0,0.000,0.000,211,2,1.9,0.2,2.1,4.663,0.491,20631,5173,55.0,57.0,0,4.000,37.000,1994.0,15.0,64.9,0.0,0.0,0.0,0.0,0.0,0.0,2916,1405,16.0,3027,316,38,0.457,0.255,0,0.868,0.869,0.000,3.472,0.000,145.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:22:53.212,14549,24799,36.9,9740,22953,29.7,0.0,1.363,1.388,1.394,1.400,1.394,1.369,1.400,1.394,4850.1,4850.1,4850.1,3880.1,4850.1,4850.1,4850.1,3880.1,100.0,2874.7,2304.5,2067.9,3272.2,1565.9,706.9,2839.8,781.0,2043.7,759.6,665.9,1652.2,1326.1,551.1,928.1,583.7,1557.7,54.2,37.1,36.5,63.4,26.2,11.5,53.6,11.5,29.2,9.1,8.5,23.1,24.3,8.5,10.3,9.7,63.4,26.0,48.5,48.5,48.5,38.8,48.5,48.5,48.5,38.8,1600.0,16.00,16,16,16,35,74,560,1,63.1,56.0,1.375,0.994,1.394,30.933,6.000,1600.0,33.0,63.0,38.0,40.0,40.0,1.400,5.000,3.328,3.376,12.192,0.784,3.328,1.832,0.744,1.008,1.360,1.536,1235,1508,693,No,1.113,1.013,28.235,13.412,27,No,No,5951,176445,39,94.0,No,No,11884,20,0.0,0.0,0.0,0.000,0.000,211,2,38.6,0.2,38.7,57.258,0.388,20771,5174,55.0,57.0,0,14.000,54.000,1988.0,98.0,65.9,1.0,0.0,0.0,0.0,0.0,0.0,2981,1406,16.0,3091,316,38,0.613,2.497,0,0.893,0.875,4.500,12.502,3.938,911.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:22:55.794,14916,24433,37.9,10161,22532,31.0,0.0,1.250,1.294,1.212,1.194,1.269,1.263,1.269,1.225,4600.1,4650.1,4550.1,4550.1,4625.1,4625.1,4650.1,4575.1,100.0,3212.6,1752.6,2114.0,2927.8,1421.7,679.4,2454.5,843.9,1830.2,722.0,713.8,1589.8,1313.8,587.3,1210.7,544.4,1494.9,64.6,32.3,38.4,57.3,25.6,16.4,45.1,12.8,29.2,10.3,13.4,31.7,21.3,10.3,16.4,10.3,64.6,27.2,46.0,46.5,45.5,45.5,46.3,46.3,46.5,45.8,1600.0,16.00,16,16,16,35,74,560,1,62.3,61.8,1.262,0.994,1.294,46.400,6.400,1600.0,33.0,62.3,38.0,40.0,40.0,1.392,5.000,3.328,3.376,12.192,0.776,3.328,1.832,0.744,1.008,1.376,1.536,1192,741,1345,No,1.094,1.013,40.941,11.294,27,No,No,5951,176445,39,94.0,No,No,11884,20,0.0,0.0,0.0,0.000,0.000,211,2,100.0,0.6,100.0,152.524,0.274,21144,5175,55.0,58.0,753,8.000,32.000,1984.0,6.0,68.3,0.0,0.0,0.0,0.0,0.0,22.0,2985,1406,16.0,3091,316,38,1.148,2.164,0,0.868,0.894,0.750,6.944,0.670,68.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:22:58.366,15919,23429,40.4,10921,21772,33.4,0.0,1.263,1.263,1.263,1.238,1.250,1.263,1.244,1.238,4625.1,4650.1,4650.1,4575.1,4625.1,4625.1,4650.1,4600.1,100.0,4103.4,3716.1,3912.3,3751.3,3595.9,2066.8,3866.6,2850.7,3798.7,2551.3,2261.2,2680.5,3613.1,1832.6,3421.3,1920.3,3121.4,85.4,78.7,80.0,78.1,73.3,45.4,83.0,66.6,80.6,47.8,46.6,49.6,73.9,38.1,71.5,43.6,85.4,65.1,46.3,46.5,46.5,45.8,46.3,46.3,46.5,46.0,1600.0,16.00,16,16,16,35,74,560,1,62.4,58.8,1.206,1.000,1.238,53.678,6.400,1600.0,33.0,62.4,38.0,40.0,40.0,1.304,5.000,3.328,3.360,12.192,0.776,3.328,1.832,0.736,1.008,1.376,1.536,1150,1495,1345,No,1.069,1.013,38.118,12.706,27,No,No,5951,176445,39,94.0,No,No,11884,20,0.0,0.0,0.0,0.000,0.000,211,2,22.8,1.3,24.1,96.997,3.949,21382,5184,55.0,57.0,523,13.000,43.000,1990.0,99.0,68.9,2.0,0.0,0.0,0.0,0.0,15.0,2985,1407,16.0,3091,316,38,0.593,0.614,0,0.893,0.881,3.000,11.609,2.644,501.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:23:0.934,16105,23244,40.9,11395,21298,34.8,0.0,1.381,1.369,1.394,1.363,1.300,1.388,1.388,1.281,4775.1,4775.1,4775.1,4750.1,4750.1,4800.1,4750.1,4675.1,100.0,3949.8,4004.9,4022.4,3952.0,3636.0,2168.3,3707.9,3080.3,3889.3,2809.7,2321.8,2765.3,3760.4,2011.0,3616.5,2079.3,3235.9,87.8,83.5,85.9,81.0,77.4,48.7,79.8,64.0,82.3,54.2,50.0,56.7,75.0,46.9,77.4,46.3,87.8,68.6,47.8,47.8,47.8,47.5,47.5,48.0,47.5,46.8,1600.0,16.00,16,16,16,35,74,560,1,63.3,62.3,1.387,1.000,1.413,44.580,6.000,1600.0,33.0,63.8,38.0,40.0,40.0,1.264,5.000,3.328,3.360,12.192,0.776,3.328,1.832,0.736,1.008,1.376,1.536,1108,1486,1344,No,1.106,1.013,35.294,10.588,27,No,No,5951,176445,39,94.0,No,No,11884,20,0.0,0.0,0.0,0.000,0.000,211,2,20.1,0.1,20.2,64.752,0.226,21540,5185,56.0,57.0,481,12.000,38.000,1984.0,83.0,70.4,4.0,0.0,0.0,0.0,0.0,14.0,3051,1409,16.0,3155,316,38,0.206,0.263,0,0.893,0.887,2.000,10.716,1.775,771.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:23:3.495,16579,22770,42.1,11797,20896,36.0,0.0,1.388,1.369,1.306,1.300,1.337,1.300,1.300,1.306,4800.1,4725.1,4625.1,4675.1,4800.1,4650.1,4700.1,4750.1,100.0,3580.0,3850.6,3691.0,4265.2,3409.4,2064.8,3867.4,2793.8,3792.9,2494.6,2586.6,2278.5,3469.3,1729.0,3166.6,1898.1,3058.6,69.5,75.0,73.7,89.0,70.7,40.8,74.3,51.2,71.9,45.7,45.1,42.0,73.1,32.3,65.2,38.4,89.0,59.9,48.0,47.3,46.3,46.8,48.0,46.5,47.0,47.5,1600.0,16.00,16,16,16,35,74,560,1,64.9,62.8,1.325,1.000,1.350,48.220,7.200,1600.0,33.0,64.9,39.0,40.0,40.0,1.392,5.000,3.344,3.376,12.192,0.768,3.328,1.832,0.736,1.008,1.360,1.536,1075,732,693,No,1.100,1.013,38.824,12.706,27,No,No,5951,176445,39,94.0,No,No,11884,21,0.0,0.0,0.0,0.000,0.000,211,2,37.7,7.7,45.3,102.734,11.349,21792,5213,55.0,58.0,476,9.000,50.000,1988.0,98.0,70.7,1.0,0.0,0.0,0.0,0.0,14.0,3115,1410,16.0,3219,316,38,0.187,0.154,0,0.893,0.881,3.500,8.037,3.084,738.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:23:6.033,16568,22781,42.1,11730,20962,35.8,0.0,1.400,1.394,1.394,1.381,1.381,1.381,1.406,1.394,4850.1,4850.1,4850.1,3880.1,4850.1,4850.1,4850.1,3880.1,100.0,3491.2,3014.7,3133.8,4027.8,2767.0,1282.1,3381.3,1952.6,2933.8,1647.6,1812.9,1555.8,2829.3,1250.2,2366.3,1107.5,2409.6,65.8,57.3,63.4,86.5,48.1,29.2,68.9,33.5,56.0,31.0,28.6,30.4,51.8,23.1,43.9,18.9,86.5,46.0,48.5,48.5,48.5,38.8,48.5,48.5,48.5,38.8,1600.0,16.00,16,16,16,35,74,560,1,65.4,56.8,1.400,1.000,1.425,42.761,6.400,1600.0,33.0,65.5,39.0,40.0,40.0,1.400,5.000,3.328,3.376,12.192,0.768,3.328,1.832,0.736,1.008,1.360,1.536,1066,730,1345,No,1.119,1.013,31.765,12.000,27,No,No,5951,176445,39,94.0,No,No,11884,21,0.0,0.0,0.0,0.000,0.000,211,2,0.7,0.7,1.3,0.515,2.121,21793,5218,55.0,57.0,476,15.000,47.000,1990.0,99.0,56.0,1.0,0.0,0.0,0.0,0.0,14.0,3115,1412,16.0,3219,316,38,19.962,3.683,0,0.893,0.881,3.000,13.395,2.644,661.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:23:8.587,16560,22789,42.0,11728,20965,35.8,0.0,1.400,1.400,1.388,1.394,1.381,1.400,1.381,1.331,4850.1,4850.1,4850.1,4800.1,4825.1,4825.1,4850.1,3880.1,100.0,2626.9,2230.4,1251.8,3604.9,1323.7,667.2,2520.5,742.9,1606.2,854.5,1325.8,702.5,1329.2,624.3,841.0,543.6,1424.7,55.2,42.3,35.5,73.6,29.4,11.6,56.4,17.7,34.9,20.8,23.9,12.2,23.9,10.4,20.2,14.1,73.6,30.1,48.5,48.5,48.5,48.0,48.3,48.3,48.5,38.8,1600.0,16.00,16,16,16,35,74,560,1,66.4,62.5,1.387,1.000,1.419,59.137,6.400,1600.0,33.0,66.0,39.0,40.0,40.0,1.408,5.000,3.344,3.376,12.192,0.768,3.328,1.832,0.736,1.008,1.360,1.536,1102,1481,694,No,1.113,1.013,26.118,11.294,27,No,No,5951,176445,39,94.0,No,No,11884,21,0.0,0.0,0.0,0.000,0.000,211,2,1.7,0.1,1.8,4.777,0.196,21805,5218,56.0,58.0,476,11.000,28.000,1940.0,3.0,72.4,0.0,0.0,0.0,0.0,0.0,14.0,3115,1412,16.0,3219,316,38,9.566,0.677,0,0.893,0.894,1.000,9.823,0.894,37.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:23:11.143,16599,22749,42.1,11773,20919,36.0,0.0,1.406,1.388,1.381,1.394,1.406,1.394,1.406,1.406,4825.1,4850.1,4800.1,4775.1,4800.1,4800.1,4825.1,3820.1,100.0,1756.2,3561.7,1253.6,3794.8,1451.0,955.4,2922.7,790.9,1993.4,910.3,1396.1,708.9,1369.4,658.5,956.5,677.4,1572.3,37.8,72.5,28.2,76.2,29.8,14.6,62.8,16.5,43.2,20.1,23.1,12.1,27.4,13.4,21.3,12.8,76.2,32.0,48.3,48.5,48.0,47.8,48.0,48.0,48.3,38.2,1600.0,16.00,16,16,16,35,74,560,1,66.6,66.8,1.387,1.000,1.413,41.851,6.400,1600.0,33.0,66.8,39.0,41.0,40.0,1.416,5.000,3.344,3.376,12.192,0.760,3.328,1.832,0.736,1.008,1.360,1.536,1138,1483,1354,No,1.119,1.013,41.647,11.294,27,No,No,5951,176445,39,94.0,No,No,11884,21,0.0,0.0,0.0,0.000,0.000,211,2,53.0,0.1,53.0,50.609,0.180,21928,5219,56.0,58.0,477,10.000,37.000,1988.0,78.0,72.4,4.0,0.0,0.0,0.0,0.0,14.0,3115,1412,16.0,3219,316,38,5.612,5.147,0,0.893,0.887,2.000,8.930,1.775,703.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:23:13.702,16551,22798,42.0,11731,20962,35.8,0.0,1.406,1.400,1.388,1.400,1.394,1.419,1.388,1.363,4850.1,4850.1,3880.1,4850.1,4850.1,4850.1,4825.1,3880.1,100.0,2836.6,2492.5,2192.2,2995.6,1806.3,737.4,3224.9,881.9,2307.1,803.0,1425.3,696.6,1604.7,604.0,920.1,667.6,1637.2,60.1,47.8,40.8,64.4,30.6,14.1,59.5,16.4,36.8,15.9,24.5,11.6,30.0,14.1,14.7,12.2,64.4,30.8,48.5,48.5,38.8,48.5,48.5,48.5,48.3,38.8,1600.0,16.00,16,16,16,35,74,560,1,69.1,60.3,1.412,1.000,1.438,45.490,6.400,1600.0,33.0,69.3,39.0,41.0,40.0,1.408,5.000,3.344,3.376,12.192,0.760,3.328,1.832,0.736,1.008,1.360,1.536,1178,736,694,No,1.113,1.013,38.824,10.588,28,No,No,5951,176445,39,94.0,No,No,11884,21,0.0,0.0,0.0,0.000,0.000,211,2,14.0,1.0,15.1,30.094,0.227,22001,5219,55.0,58.0,477,11.000,50.000,1988.0,99.0,74.6,2.0,0.0,0.0,0.0,0.0,14.0,3115,1412,16.0,3219,316,38,4.240,52.378,0,0.893,0.881,3.500,9.823,3.084,681.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:23:16.270,16547,22801,42.0,11720,20972,35.8,0.0,1.388,1.394,1.406,1.375,1.381,1.419,1.375,1.400,4850.1,4850.1,3880.1,4850.1,4850.1,4850.1,3880.1,4850.1,100.0,2844.3,1507.3,1537.0,3428.6,1060.6,609.8,2120.5,680.2,1359.5,702.9,1324.2,592.9,1127.1,440.6,711.2,390.2,1277.3,54.2,25.6,34.1,61.5,21.3,6.7,41.4,12.1,25.0,9.1,22.5,9.1,23.7,9.1,12.8,6.7,61.5,23.4,48.5,48.5,38.8,48.5,48.5,48.5,38.8,48.5,1600.0,16.00,16,16,16,35,74,560,1,67.3,58.3,1.394,1.000,1.425,50.949,6.400,1600.0,33.0,67.5,39.0,41.0,40.0,1.392,5.000,3.344,3.376,12.192,0.760,3.328,1.832,0.736,1.008,1.360,1.536,1225,740,694,No,1.119,1.013,22.588,10.588,28,No,No,5951,176445,39,94.0,No,No,11884,21,0.0,0.0,0.0,0.000,0.000,211,2,0.1,0.1,0.2,0.153,0.169,22002,5220,56.0,59.0,478,4.000,48.000,1968.0,27.0,74.5,1.0,0.0,0.0,0.0,0.0,14.0,3115,1412,16.0,3219,316,38,12.748,30.697,0,0.868,0.869,0.000,3.472,0.000,658.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:23:18.842,16576,22772,42.1,11735,20958,35.8,0.0,1.375,1.369,1.363,1.381,1.413,1.288,1.400,1.369,4725.1,4775.1,4775.1,4825.1,4800.1,4775.1,4825.1,3840.1,100.0,1515.9,2543.6,1178.0,3477.1,993.5,501.9,1705.2,648.6,1167.9,600.5,1320.0,569.6,959.2,456.4,676.5,429.6,1171.5,21.9,47.5,19.5,67.6,15.8,9.0,30.9,11.5,21.8,9.6,23.7,9.0,20.0,5.4,11.5,9.7,67.6,20.9,47.3,47.8,47.8,48.3,48.0,47.8,48.3,38.4,1600.0,16.00,16,16,16,35,74,560,1,65.1,66.3,1.344,1.000,1.363,41.851,6.800,1600.0,33.0,65.3,39.0,41.0,40.0,1.392,5.000,3.328,3.376,12.192,0.760,3.328,1.832,0.736,1.008,1.360,1.536,1278,1521,1354,No,1.106,1.013,38.118,12.706,28,No,No,5951,176445,39,94.0,No,No,11884,21,0.0,0.0,0.0,0.000,0.000,211,2,6.3,0.1,6.3,26.426,0.126,22066,5220,55.0,58.0,478,13.000,54.000,1988.0,99.0,74.4,2.0,0.0,0.0,0.0,0.0,14.0,3115,1415,16.0,3219,316,38,1.272,1.473,0,0.893,0.875,3.750,11.609,3.281,815.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:23:21.401,16798,22551,42.6,12015,20678,36.7,0.0,1.394,1.400,1.400,1.388,1.406,1.388,1.394,1.406,4825.1,4825.1,4825.1,4850.1,3880.1,4800.1,3880.1,4825.1,100.0,3354.6,2007.5,1423.5,3867.0,1555.4,456.5,3044.5,702.8,2155.1,562.8,927.2,1085.7,1178.9,447.1,880.4,360.7,1500.6,66.6,38.1,29.0,78.7,33.3,7.9,53.6,13.4,43.2,6.7,12.1,18.9,22.5,6.0,18.9,3.0,78.7,28.2,48.3,48.3,48.3,48.5,38.8,48.0,38.8,48.3,1600.0,16.00,16,16,16,35,74,560,1,69.1,70.3,1.412,0.994,1.431,38.212,6.800,1600.0,33.0,69.0,39.0,41.0,40.0,1.416,5.000,3.328,3.376,12.192,0.760,3.328,1.832,0.736,1.008,1.360,1.536,1282,1515,1354,No,1.119,1.013,31.059,12.000,28,No,No,5951,176445,39,94.0,No,No,11884,21,0.0,0.0,0.0,0.000,0.000,211,2,8.4,0.0,8.5,33.198,0.114,22148,5220,56.0,58.0,478,11.000,29.000,1940.0,3.0,73.4,0.0,0.0,0.0,0.0,0.0,14.0,3115,1415,16.0,3219,316,38,1.230,1.370,0,0.893,0.894,1.250,9.823,1.117,42.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:23:23.961,16795,22554,42.6,12013,20679,36.7,0.0,1.413,1.413,1.406,1.406,1.356,1.406,1.406,1.406,4825.1,4825.1,3860.1,4825.1,4800.1,4850.1,3860.1,4825.1,100.0,4070.5,1110.0,1223.1,3931.4,1170.1,441.9,2456.6,656.2,1524.0,576.1,454.6,1415.5,1099.0,383.6,809.6,459.3,1361.3,79.3,22.4,18.1,76.9,16.9,5.4,50.9,7.2,27.2,6.0,4.8,22.4,14.5,4.2,9.0,7.2,79.3,23.3,48.3,48.3,38.6,48.3,48.0,48.5,38.6,48.3,1600.0,16.00,16,16,16,35,74,560,1,69.9,59.5,1.394,1.000,1.419,49.129,6.400,1600.0,33.0,69.9,39.0,41.0,40.0,1.416,5.000,3.328,3.376,12.192,0.760,3.328,1.832,0.728,1.008,1.360,1.536,1332,1532,1354,No,1.100,1.013,36.706,12.000,28,No,No,5951,176445,39,94.0,No,No,11884,21,0.0,0.0,0.0,0.000,0.000,211,2,0.1,0.1,0.2,0.179,0.134,22148,5221,56.0,58.0,478,12.000,53.000,1990.0,99.0,72.8,2.0,0.0,0.0,0.0,0.0,14.0,3115,1415,16.0,3219,316,38,5.153,1.205,0,0.893,0.875,3.500,10.716,3.063,779.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:23:26.524,16794,22554,42.6,12015,20677,36.7,0.0,1.400,1.400,1.394,1.406,1.375,1.406,1.406,1.400,4800.1,4825.1,4825.1,4825.1,4850.1,4825.1,4825.1,3840.1,100.0,3538.0,1720.3,1868.4,3253.4,1228.1,460.2,2475.3,674.4,1527.0,593.7,453.5,1424.8,1081.5,426.9,746.2,394.4,1366.6,69.9,36.8,38.6,63.1,25.1,7.3,58.8,13.4,29.4,10.4,6.7,31.2,23.3,6.1,15.9,8.5,69.9,27.8,48.0,48.3,48.3,48.3,48.5,48.3,48.3,38.4,1600.0,16.00,16,16,16,35,74,560,1,70.3,61.5,1.394,0.994,1.419,36.392,6.400,1600.0,33.0,70.3,39.0,41.0,40.0,1.408,5.000,3.328,3.376,12.192,0.760,3.328,1.832,0.728,1.008,1.360,1.536,1373,1525,694,No,1.113,1.013,33.882,13.412,28,No,No,5951,176445,39,94.0,No,No,11884,21,0.0,0.0,0.0,0.000,0.000,211,2,0.5,0.1,0.5,1.847,0.107,22153,5221,55.0,57.0,478,4.000,27.000,1990.0,0.0,67.0,0.0,0.0,0.0,0.0,0.0,14.0,2852,1415,16.0,2957,316,38,2.809,3.472,0,0.868,0.869,0.000,3.472,0.000,3.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:23:29.113,16161,23188,41.0,11401,21292,34.8,0.0,1.331,1.344,1.369,1.363,1.344,1.325,1.331,1.350,4750.1,4825.1,4800.1,4825.1,4800.1,4775.1,4750.1,4775.1,100.0,2731.1,1580.9,1435.6,2881.6,978.2,471.5,1886.3,499.4,1144.0,677.0,580.8,1409.6,882.5,383.2,640.6,433.2,1163.5,58.5,31.7,31.0,59.7,15.2,6.7,32.9,9.1,21.9,8.5,10.3,27.4,15.8,7.9,11.5,7.3,59.7,22.2,47.5,48.3,48.0,48.3,48.0,47.8,47.5,47.8,1600.0,16.00,16,16,16,35,74,560,1,68.0,68.3,1.406,0.994,1.431,60.047,6.400,1600.0,33.0,68.0,39.0,41.0,40.0,1.376,5.000,3.344,3.360,12.192,0.760,3.328,1.832,0.728,1.008,1.360,1.536,1422,1530,1354,No,1.100,1.013,35.294,11.294,28,No,No,5951,176445,39,94.0,No,No,11884,21,0.0,0.0,0.0,0.000,0.000,211,2,4.0,0.2,4.2,12.160,0.324,22182,5222,59.0,65.0,478,18.000,86.000,1990.0,70.0,50.2,9.0,0.0,0.0,0.0,0.0,14.0,2991,1424,16.0,3085,316,38,4.268,14.019,0,0.981,0.950,1.750,17.658,1.662,2237.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:23:31.663,16041,23308,40.7,11402,21291,34.8,0.0,1.388,1.375,1.369,1.394,1.381,1.394,1.375,1.394,4850.1,4850.1,4850.1,4850.1,4850.1,4850.1,4850.1,3880.1,100.0,2968.3,2522.1,1734.7,3393.9,1597.6,938.1,2554.3,1089.1,1901.9,1055.0,1064.9,1657.0,1522.8,744.5,1301.6,679.2,1670.3,65.8,46.3,34.1,70.7,28.6,24.3,49.3,24.3,37.8,23.1,20.7,27.4,28.0,18.9,20.7,17.6,70.7,33.6,48.5,48.5,48.5,48.5,48.5,48.5,48.5,38.8,1600.0,16.00,16,16,16,35,74,560,1,66.9,53.0,1.381,1.000,1.400,34.573,6.400,1600.0,33.0,66.1,39.0,41.0,40.0,1.400,5.000,3.328,3.376,12.192,0.760,3.328,1.832,0.728,1.008,1.360,1.536,1437,756,694,No,1.119,1.013,32.471,12.000,28,No,No,5951,176445,41,94.0,No,No,11884,22,0.0,0.0,0.0,0.000,0.000,211,2,64.1,0.1,64.2,165.286,0.240,22587,5222,55.0,57.0,479,4.000,25.000,1990.0,2.0,39.7,0.0,0.0,0.0,0.0,0.0,14.0,2999,1433,16.0,3085,316,38,23.253,7.249,0,0.868,0.869,0.000,3.472,0.000,17.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:23:34.272,16361,22988,41.5,11643,21050,35.6,0.0,1.356,1.419,1.300,1.388,1.325,1.394,1.337,1.406,4725.1,4850.1,4800.1,4700.1,4825.1,4725.1,4800.1,4700.1,100.0,2115.6,1798.5,1711.8,2477.4,1208.8,768.8,1911.6,876.6,1484.2,782.7,762.9,1591.3,1224.3,566.2,1072.7,560.8,1307.1,40.0,35.1,23.6,46.6,21.2,17.5,40.0,13.3,29.0,17.5,13.3,26.0,24.2,10.3,19.3,10.3,46.6,24.2,47.3,48.5,48.0,47.0,48.3,47.3,48.0,47.0,1600.0,16.00,16,16,16,35,74,560,1,64.4,59.5,1.300,1.000,1.325,40.941,6.800,1600.0,33.0,64.4,39.0,41.0,40.0,1.392,5.000,3.344,3.360,12.192,0.760,3.328,1.832,0.728,1.008,1.360,1.536,1424,757,694,No,1.113,1.019,42.353,11.294,28,No,No,5951,176445,39,94.0,No,No,11884,22,0.0,0.0,0.0,0.000,0.000,211,2,64.8,0.5,65.3,154.898,0.162,22972,5223,58.0,62.0,478,27.000,78.000,1988.0,95.0,45.2,7.0,0.0,0.0,0.0,0.0,14.0,3611,1447,16.0,3688,316,38,25.267,7.021,0,0.981,0.950,10.000,26.487,9.500,2125.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:23:36.831,16858,22491,42.8,11805,20887,36.1,0.0,1.388,1.406,1.394,1.394,1.413,1.400,1.394,1.400,4850.1,4850.1,3880.1,4850.1,4850.1,4850.1,4850.1,4850.1,100.0,3087.2,2298.4,1979.6,3740.8,1664.9,950.4,2607.3,1474.7,2120.2,1216.1,989.4,1776.2,1754.2,840.1,1529.0,565.3,1787.1,56.0,45.7,36.7,76.5,36.7,19.8,50.0,29.5,37.3,21.6,15.0,37.3,31.9,15.6,27.7,7.2,76.5,34.0,48.5,48.5,38.8,48.5,48.5,48.5,48.5,48.5,1600.0,16.00,16,16,16,35,74,560,1,64.0,58.5,1.381,1.000,1.419,60.957,8.000,1600.0,33.0,64.3,39.0,41.0,40.0,1.400,5.000,3.344,3.360,12.192,0.760,3.328,1.832,0.728,1.008,1.360,1.536,1400,1528,693,No,1.094,1.013,38.118,12.706,28,No,No,5951,176445,39,94.0,No,No,11884,22,0.0,0.0,0.0,0.000,0.000,211,2,7.8,0.0,7.8,30.742,0.153,23047,5223,59.0,64.0,478,8.000,90.000,1950.0,33.0,71.7,3.0,0.0,0.0,0.0,0.0,14.0,3680,1448,16.0,3752,316,38,22.959,7.360,0,1.131,0.856,0.000,9.048,0.000,1274.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:23:39.387,16921,22427,43.0,11885,20808,36.3,0.0,1.337,1.394,1.406,1.319,1.406,1.394,1.406,1.394,4850.1,4850.1,4850.1,4775.1,3880.1,4850.1,3880.1,4825.1,100.0,2476.8,2614.0,1955.6,3554.6,1619.1,915.4,2284.2,1440.8,1884.3,1137.2,1033.3,1608.2,1546.3,616.9,1502.4,644.6,1677.1,45.7,49.3,37.8,75.6,34.7,22.5,50.0,30.4,39.0,17.0,24.3,26.2,31.0,14.0,31.0,10.9,75.6,33.7,48.5,48.5,48.5,47.8,38.8,48.5,38.8,48.3,1600.0,16.00,16,16,16,35,74,560,1,63.1,59.3,1.406,0.994,1.425,32.753,6.400,1600.0,33.0,63.3,39.0,41.0,40.0,1.408,5.000,3.344,3.360,12.192,0.760,3.328,1.832,0.728,1.008,1.360,1.536,1355,1527,1347,No,1.113,1.013,40.941,12.706,28,No,No,5951,176445,39,94.0,No,No,11884,22,0.0,0.0,0.0,0.000,0.000,211,2,7.0,0.1,7.0,25.453,0.206,23109,5224,58.0,62.0,479,28.000,70.000,1988.0,95.0,67.7,6.0,0.0,0.0,0.0,0.0,14.0,3612,1450,16.0,3688,316,38,16.361,8.225,0,0.918,0.887,7.250,25.704,6.434,1949.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:23:41.954,17115,22234,43.4,12090,20603,36.9,0.0,1.388,1.306,1.419,1.300,1.306,1.281,1.425,1.388,4850.1,4800.1,3880.1,4750.1,4850.1,4775.1,3880.1,4700.1,100.0,2594.9,2918.9,2220.9,3477.0,1909.2,1004.7,2836.5,1451.5,2378.8,1186.2,1706.8,1075.8,1812.6,656.6,1572.6,583.2,1836.6,51.2,56.7,47.5,70.1,40.2,18.9,60.9,31.0,43.2,25.0,32.9,17.6,37.1,14.6,35.9,12.8,70.1,37.2,48.5,48.0,38.8,47.5,48.5,47.8,38.8,47.0,1600.0,16.00,16,16,16,35,74,560,1,63.3,60.8,1.369,1.000,1.406,57.318,8.000,1600.0,33.0,63.0,39.0,41.0,40.0,1.384,5.000,3.328,3.360,12.192,0.752,3.328,1.832,0.728,1.008,1.376,1.536,1313,753,1347,No,1.106,1.019,30.353,12.706,28,No,No,5951,176445,39,94.0,No,No,11884,22,0.0,0.0,0.0,0.000,0.000,211,2,14.7,0.1,14.8,54.468,0.290,23243,5224,60.0,66.0,482,6.000,40.000,1936.0,6.0,73.4,0.0,0.0,0.0,0.0,0.0,14.0,3876,1452,16.0,3944,316,38,10.125,9.110,0,0.868,1.044,0.500,5.208,0.522,183.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:23:44.506,17558,21790,44.6,12296,20396,37.6,0.0,1.419,1.375,1.406,1.394,1.406,1.294,1.400,1.319,4850.1,4850.1,4825.1,4825.1,3860.1,4850.1,3860.1,4825.1,100.0,3525.4,2390.1,2654.8,3300.7,2154.8,996.3,3200.2,1560.1,2775.7,1282.0,1807.1,1141.0,2098.8,701.9,1717.1,705.0,2000.7,70.7,45.7,53.6,64.0,46.3,17.0,67.0,29.2,49.3,21.3,26.8,21.3,40.8,15.2,36.5,14.0,70.7,38.7,48.5,48.5,48.3,48.3,38.6,48.5,38.6,48.3,1600.0,16.00,16,16,16,35,74,560,1,63.3,60.5,1.406,1.000,1.431,50.949,8.400,1600.0,33.0,63.3,39.0,41.0,40.0,1.400,5.000,3.344,3.360,12.192,0.752,3.328,1.832,0.728,1.008,1.360,1.536,1286,1520,1354,No,1.100,1.013,24.706,14.118,28,No,No,5951,176445,39,94.0,No,No,11884,22,0.0,0.0,0.0,0.000,0.000,211,2,15.7,0.1,15.8,46.874,0.236,23357,5225,61.0,68.0,515,21.000,97.000,1986.0,93.0,71.2,9.0,0.0,0.0,0.0,0.0,15.0,3877,1457,16.0,3944,316,38,14.011,8.892,0,1.081,0.919,4.750,22.701,4.364,2330.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:23:47.072,17574,21774,44.6,12343,20350,37.7,0.0,1.350,1.406,1.344,1.425,1.319,1.419,1.325,1.388,4725.1,4825.1,4800.1,4850.1,4750.1,4825.1,4725.1,4825.1,100.0,3162.2,2781.2,2680.3,3343.0,2264.2,1104.2,3138.5,1845.8,2658.2,1520.7,1772.0,1237.6,2175.6,837.7,1950.8,626.9,2068.7,67.4,62.5,56.4,71.7,47.2,22.6,61.9,41.1,61.3,34.3,37.4,23.9,49.0,19.6,44.7,14.7,71.7,44.7,47.3,48.3,48.0,48.5,47.5,48.3,47.3,48.3,1600.0,16.00,16,16,16,35,74,560,1,62.9,59.8,1.350,0.994,1.375,41.851,8.000,1600.0,33.0,62.9,40.0,41.0,40.0,1.392,5.000,3.328,3.360,12.096,0.752,3.328,1.832,0.728,1.008,1.360,1.536,1232,748,693,No,1.081,1.013,24.706,12.706,28,No,No,5951,176445,39,94.0,No,No,11884,22,0.0,0.0,0.0,0.000,0.000,211,2,14.1,0.0,14.1,34.541,0.128,23441,5225,61.0,70.0,549,24.000,105.000,1984.0,94.0,72.7,9.0,0.0,0.0,0.0,0.0,16.0,3878,1465,16.0,3945,316,38,18.904,9.201,0,1.200,1.150,16.000,28.800,18.400,2413.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:23:49.627,17567,21781,44.6,12343,20349,37.7,0.0,1.394,1.388,1.281,1.406,1.381,1.406,1.344,1.419,4825.1,4825.1,4775.1,4825.1,4825.1,4825.1,4675.1,3860.1,100.0,2910.9,3251.3,2694.4,3701.0,2445.2,1285.8,3265.0,2093.9,2719.5,1703.6,1764.1,1268.7,2387.1,952.9,2074.5,604.0,2195.1,57.9,69.5,56.7,73.1,45.7,37.8,62.8,48.7,53.6,39.0,29.2,26.8,50.0,18.2,39.0,12.1,73.1,45.0,48.3,48.3,47.8,48.3,48.3,48.3,46.8,38.6,1600.0,16.00,16,16,16,35,74,560,1,62.6,62.3,1.350,1.000,1.381,60.047,8.000,1600.0,34.0,62.6,40.0,41.0,40.0,1.368,5.000,3.344,3.360,12.192,0.744,3.328,1.832,0.728,1.008,1.360,1.536,1198,743,1354,No,1.113,1.013,50.824,12.706,28,No,No,5951,176445,39,94.0,No,No,11884,22,0.0,0.0,0.0,0.000,0.000,211,2,2.5,0.1,2.6,5.908,0.155,23456,5226,61.0,66.0,596,10.000,43.000,1990.0,97.0,74.6,5.0,0.0,0.0,0.0,0.0,17.0,3878,1465,16.0,3945,316,38,19.508,8.178,0,0.893,0.881,4.000,8.930,3.525,954.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:23:52.186,17853,21496,45.3,12353,20340,37.7,0.0,1.419,1.337,1.419,1.331,1.419,1.388,1.425,1.300,4850.1,4700.1,3880.1,4825.1,4850.1,4850.1,3880.1,4825.1,100.0,2793.7,2487.5,2153.5,3307.1,1936.6,894.5,2908.0,1329.2,2332.1,1062.4,1587.0,990.4,1827.4,612.4,1460.3,459.1,1758.8,50.6,42.6,35.9,59.1,29.8,8.5,51.8,15.8,38.4,12.8,31.7,9.7,25.0,7.3,22.5,5.4,59.1,27.9,48.5,47.0,38.8,48.3,48.5,48.5,38.8,48.3,1600.0,16.00,16,16,16,35,74,560,1,62.5,59.8,1.412,0.994,1.438,40.031,6.400,1600.0,34.0,62.5,40.0,41.0,40.0,1.400,5.000,3.344,3.360,12.192,0.744,3.328,1.832,0.720,1.008,1.360,1.536,1156,739,1348,No,1.100,1.013,36.000,14.824,28,No,No,5951,176445,39,94.0,No,No,11884,22,0.0,0.0,0.0,0.000,0.000,211,2,3.8,0.1,3.8,10.681,0.177,23482,5226,60.0,63.0,612,8.000,59.000,1998.0,41.0,71.1,2.0,0.0,0.0,0.0,0.0,18.0,4199,1466,16.0,4265,317,38,19.370,9.172,0,0.893,0.863,0.250,7.144,0.216,926.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:23:54.752,17850,21498,45.3,12356,20336,37.7,0.0,1.413,1.394,1.363,1.413,1.406,1.381,1.413,1.388,4850.1,4800.1,4850.1,4850.1,4850.1,4775.1,4850.1,4775.1,100.0,2936.0,2122.2,1951.7,3356.6,1624.7,850.4,2686.2,1242.5,2222.4,948.8,1586.8,969.4,1586.2,538.9,1265.0,584.5,1654.5,56.7,39.0,40.8,62.8,33.5,12.8,45.1,17.6,40.2,15.8,32.9,14.0,31.0,8.5,25.6,9.7,62.8,30.4,48.5,48.0,48.5,48.5,48.5,47.8,48.5,47.8,1600.0,16.00,16,16,16,35,74,560,1,62.1,60.0,1.412,0.994,1.431,32.753,6.400,1600.0,34.0,62.1,40.0,41.0,40.0,1.408,5.000,3.344,3.376,12.192,0.744,3.328,1.832,0.720,1.008,1.360,1.536,1119,737,1356,No,1.125,1.013,49.412,14.118,28,No,No,5951,176445,39,94.0,No,No,11884,22,0.0,0.0,0.0,0.000,0.000,211,2,2.2,0.1,2.3,6.387,0.183,23497,5226,60.0,62.0,608,6.000,65.000,1986.0,95.0,70.1,5.0,0.0,0.0,0.0,0.0,17.0,4199,1467,16.0,4265,317,38,19.444,8.883,0,0.893,0.850,0.250,5.358,0.212,1500.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:23:57.321,17851,21498,45.3,12372,20321,37.8,0.0,1.400,1.406,1.406,1.294,1.363,1.281,1.356,1.319,4850.1,4850.1,4850.1,4725.1,4850.1,4675.1,3880.1,4725.1,100.0,2689.6,2629.7,2183.4,3277.9,1638.9,899.0,2726.3,1324.2,2140.8,1079.1,1357.5,1280.4,1720.3,619.5,1393.3,565.5,1720.3,52.4,48.1,46.9,65.2,36.5,19.5,52.4,28.0,38.4,22.5,28.6,20.1,34.1,10.9,28.6,8.5,65.2,33.8,48.5,48.5,48.5,47.3,48.5,46.8,38.8,47.3,1600.0,16.00,16,16,16,35,74,560,1,61.6,58.0,1.406,0.994,1.425,34.573,6.400,1600.0,34.0,61.8,40.0,41.0,40.0,1.392,5.000,3.328,3.376,12.192,0.744,3.328,1.832,0.720,1.008,1.360,1.536,1078,734,1348,No,1.113,1.019,48.000,13.412,28,No,No,5951,176445,39,94.0,No,No,11884,22,0.0,0.0,0.0,0.000,0.000,211,2,7.7,0.0,7.7,17.693,0.153,23541,5227,60.0,64.0,607,19.000,44.000,1986.0,65.0,70.6,2.0,0.0,0.0,0.0,0.0,17.0,4200,1468,16.0,4265,317,38,19.516,9.082,0,0.937,0.925,9.250,17.803,8.556,1546.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:23:59.890,17864,21485,45.3,12386,20307,37.8,0.0,1.400,1.438,1.388,1.406,1.288,1.381,1.406,1.406,4750.1,4850.1,4700.1,4825.1,4625.1,4850.1,4650.1,4850.1,100.0,2940.0,3321.2,2726.8,3486.0,2373.8,1296.1,3224.8,2114.9,2815.2,1699.7,1303.3,1945.2,2304.4,990.9,2019.1,823.4,2211.5,58.5,62.1,53.6,67.6,46.3,25.6,62.1,35.9,54.2,34.7,22.5,31.0,42.6,17.0,39.0,17.0,67.6,41.9,47.5,48.5,47.0,48.3,46.3,48.5,46.5,48.5,1600.0,16.00,16,16,16,35,74,560,1,61.9,64.5,1.300,0.994,1.325,46.400,8.400,1600.0,34.0,61.9,40.0,41.0,40.0,1.352,5.000,3.328,3.360,12.192,0.744,3.328,1.832,0.720,1.008,1.360,1.528,1025,1491,694,No,1.081,1.013,25.412,13.412,28,No,No,5951,176445,39,94.0,No,No,11884,22,0.0,0.0,0.0,0.000,0.000,211,2,3.7,0.2,3.9,9.360,0.360,23563,5228,63.0,72.0,625,38.000,150.000,1988.0,99.0,77.5,8.0,0.0,0.0,0.0,0.0,18.0,4200,1471,16.0,4265,317,38,20.972,10.776,0,1.200,1.150,11.750,45.600,13.512,2579.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:24:2.445,17865,21484,45.4,12378,20314,37.8,0.0,1.325,1.419,1.306,1.400,1.306,1.413,1.350,1.406,4850.1,4850.1,4825.1,4850.1,4850.1,4850.1,4850.1,4850.1,100.0,3389.7,2851.2,2607.0,3701.6,2368.3,1270.9,3236.7,2067.6,2754.0,1675.1,1278.3,1892.5,2310.3,963.0,2007.8,866.1,2202.5,69.0,50.3,54.5,80.0,50.3,25.4,64.2,42.4,55.1,29.0,24.2,36.3,46.0,21.8,40.0,14.5,80.0,43.9,48.5,48.5,48.3,48.5,48.5,48.5,48.5,48.5,1600.0,16.00,16,16,16,35,74,560,1,62.9,58.5,1.356,0.994,1.438,34.573,7.200,1600.0,34.0,62.8,40.0,41.0,40.0,1.384,5.000,3.328,3.360,12.192,0.736,3.328,1.832,0.720,1.008,1.360,1.536,978,1486,1350,No,1.119,1.013,24.706,12.706,28,No,No,5951,176445,39,94.0,No,No,11884,22,0.0,0.0,0.0,0.000,0.000,211,2,0.9,0.0,0.9,2.059,0.129,23568,5228,61.0,65.0,664,15.000,69.000,1988.0,97.0,75.3,7.0,0.0,0.0,0.0,0.0,19.0,4200,1471,16.0,4265,317,38,22.714,10.375,0,0.893,0.869,2.750,13.395,2.389,1783.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:24:5.016,17909,21439,45.5,12417,20276,37.9,0.0,1.406,1.337,1.381,1.419,1.388,1.337,1.413,1.281,4850.1,4700.1,4725.1,4850.1,4800.1,4825.1,3880.1,4600.1,100.0,3402.4,2162.2,2348.4,3411.8,1952.1,1053.2,2708.1,1647.1,2214.4,1322.3,1170.1,1792.1,1869.7,826.1,1735.1,603.3,1888.6,60.7,47.8,55.8,69.9,38.0,23.9,52.1,31.2,49.6,22.6,20.2,33.7,39.2,19.6,39.2,11.6,69.9,38.4,48.5,47.0,47.3,48.5,48.0,48.3,38.8,46.0,1600.0,16.00,16,16,16,35,74,560,1,62.9,61.0,1.256,1.000,1.281,49.129,7.600,1600.0,34.0,62.8,40.0,42.0,40.0,1.376,5.000,3.344,3.360,12.192,0.736,3.328,1.832,0.720,1.008,1.360,1.536,958,726,1350,No,1.087,1.013,32.471,12.706,28,No,No,5951,176445,39,94.0,No,No,11884,23,0.0,0.0,0.0,0.000,0.000,211,2,6.5,0.1,6.6,17.650,0.311,23612,5229,62.0,66.0,687,27.000,53.000,1990.0,85.0,72.1,5.0,0.0,0.0,0.0,0.0,20.0,4201,1484,16.0,4265,317,38,25.507,12.668,0,1.012,0.988,7.250,27.324,7.159,1973.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:24:7.577,17918,21430,45.5,12438,20255,38.0,0.0,1.400,1.400,1.275,1.313,1.425,1.431,1.406,1.419,4850.1,4850.1,4800.1,4700.1,3880.1,4750.1,3880.1,4850.1,100.0,3067.9,2655.0,2478.8,3393.6,1965.8,1237.7,2767.7,1731.4,2332.2,1466.7,1225.0,1868.1,1885.1,851.2,1794.1,768.6,1968.0,53.3,49.6,48.4,66.6,38.7,26.6,53.9,31.5,43.6,32.7,22.4,35.7,38.7,20.6,36.3,18.7,66.6,38.6,48.5,48.5,48.0,47.0,38.8,47.5,38.8,48.5,1600.0,16.00,16,16,16,35,74,560,1,63.0,61.8,1.381,0.994,1.413,59.137,8.400,1600.0,34.0,62.9,41.0,42.0,40.0,1.376,5.000,3.328,3.360,12.192,0.736,3.328,1.832,0.720,1.008,1.360,1.536,957,1481,694,No,1.100,1.013,35.294,12.706,28,No,No,5951,176445,39,94.0,No,No,11884,23,0.0,0.0,0.0,0.000,0.000,211,2,6.4,0.1,6.5,16.274,0.319,23652,5230,61.0,66.0,721,8.000,87.000,2050.0,48.0,70.7,4.0,0.0,0.0,0.0,0.0,21.0,4202,1487,16.0,4265,317,38,28.973,14.189,0,0.925,0.919,0.500,7.400,0.459,1832.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:24:10.137,17896,21452,45.4,12434,20259,38.0,0.0,1.400,1.269,1.394,1.306,1.388,1.363,1.419,1.275,4850.1,4775.1,4625.1,4650.1,3880.1,4825.1,3880.1,4675.1,100.0,3061.1,2562.0,2434.4,3374.7,1974.2,1141.9,2934.2,1633.0,2451.0,1336.7,1139.5,1877.9,1920.1,790.6,1746.7,789.7,1948.0,59.1,55.4,52.4,70.1,40.8,24.3,58.5,37.8,45.1,28.0,20.7,35.9,40.8,12.1,42.0,14.0,70.1,39.8,48.5,47.8,46.3,46.5,38.8,48.3,38.8,46.8,1600.0,16.00,16,16,16,35,74,560,1,63.3,61.8,1.244,1.000,1.275,54.588,8.000,1600.0,34.0,63.3,41.0,42.0,40.0,1.376,5.000,3.328,3.376,12.192,0.736,3.328,1.832,0.720,1.008,1.360,1.536,950,1468,695,No,1.081,1.013,31.059,12.706,28,No,No,5951,176445,39,94.0,No,No,11884,23,0.0,0.0,0.0,0.000,0.000,211,2,8.3,0.1,8.4,23.466,0.331,23709,5230,61.0,68.0,723,13.000,42.000,1974.0,58.0,72.4,1.0,0.0,0.0,0.0,0.0,21.0,4204,1492,16.0,4265,317,38,26.602,13.933,0,1.087,1.063,7.500,14.131,7.969,1571.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:24:12.710,17985,21364,45.7,12519,20173,38.2,0.0,1.400,1.244,1.369,1.263,1.400,1.244,1.306,1.225,4675.1,4700.1,4800.1,4675.1,3880.1,4675.1,4625.1,4525.1,100.0,3359.0,2416.1,2406.7,3607.8,2024.9,1146.9,2959.8,1696.1,2435.4,1415.1,1144.4,1943.1,2058.9,863.7,1777.0,760.3,2000.9,65.2,47.5,51.8,71.9,41.4,21.9,58.5,35.3,46.3,26.8,18.2,39.6,42.0,17.6,37.8,20.1,71.9,40.1,46.8,47.0,48.0,46.8,38.8,46.8,46.3,45.3,1600.0,16.00,16,16,16,35,74,560,1,63.8,61.3,1.325,1.000,1.344,49.129,8.000,1600.0,34.0,63.9,41.0,42.0,40.0,1.368,5.000,3.328,3.360,12.192,0.728,3.328,1.832,0.712,1.008,1.360,1.536,952,1481,695,No,1.087,1.019,33.176,12.706,28,No,No,5951,176445,39,94.0,No,No,11884,23,0.0,0.0,0.0,0.000,0.000,211,2,14.4,0.1,14.5,36.648,0.255,23799,5231,63.0,72.0,728,24.000,117.000,1988.0,96.0,73.9,7.0,0.0,0.0,0.0,0.0,21.0,4205,1494,16.0,4265,317,38,28.201,13.508,0,1.200,1.144,12.250,28.800,14.011,2472.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:24:15.274,18013,21335,45.7,12563,20129,38.4,0.0,1.250,1.419,1.313,1.400,1.306,1.394,1.381,1.325,4650.1,4675.1,4725.1,4675.1,4725.1,4650.1,4725.1,4625.1,100.0,3081.5,3147.3,2621.6,3873.5,2367.0,1453.6,3063.9,2181.1,2622.2,1819.6,1900.2,1462.6,2379.1,991.2,2208.0,740.2,2244.6,60.9,59.1,52.4,78.6,48.7,31.7,64.6,40.8,45.1,36.5,34.1,29.2,43.2,18.9,40.2,13.4,78.6,43.6,46.5,46.8,47.3,46.8,47.3,46.5,47.3,46.3,1600.0,16.00,16,16,16,35,74,560,1,63.9,60.0,1.306,0.994,1.325,37.302,6.400,1600.0,35.0,63.9,41.0,42.0,40.0,1.360,5.000,3.328,3.360,12.096,0.728,3.328,1.832,0.712,1.008,1.360,1.536,953,725,695,No,1.106,1.013,45.882,14.118,28,No,No,5951,176445,39,94.0,No,No,11884,23,0.0,0.0,0.0,0.000,0.000,211,2,8.5,0.1,8.6,20.092,0.346,23848,5232,62.0,69.0,753,22.000,70.000,1984.0,87.0,72.0,7.0,0.0,0.0,0.0,0.0,22.0,4206,1496,16.0,4265,317,38,26.250,13.203,0,1.006,1.038,9.750,22.132,10.116,2093.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:24:17.835,17977,21371,45.6,12536,20157,38.3,0.0,1.413,1.419,1.369,1.400,1.394,1.413,1.275,1.406,4825.1,4850.1,4650.1,4825.1,4625.1,4850.1,4625.1,3880.1,100.0,2769.0,3187.5,2503.3,3861.4,2143.7,1385.5,2740.4,2067.4,2351.2,1762.9,1860.6,1396.9,2269.4,1069.5,2134.4,690.5,2137.1,57.9,64.6,52.4,78.6,45.7,23.7,55.4,46.3,48.7,36.5,33.5,26.8,42.0,23.7,43.2,14.6,78.6,43.4,48.3,48.5,46.5,48.3,46.3,48.5,46.3,38.8,1600.0,16.00,16,16,16,35,74,560,1,63.8,61.3,1.300,0.994,1.325,41.851,8.400,1600.0,35.0,63.8,41.0,42.0,40.0,1.392,5.000,3.328,3.360,12.192,0.728,3.328,1.832,0.712,1.008,1.360,1.536,949,1470,1350,No,1.094,1.013,38.824,13.412,28,No,No,5951,176445,39,94.0,No,No,11884,23,0.0,0.0,0.0,0.000,0.000,211,2,2.0,0.2,2.3,4.936,0.538,23860,5233,62.0,66.0,760,24.000,39.000,1988.0,73.0,71.1,4.0,0.0,0.0,0.0,0.0,22.0,4206,1496,16.0,4265,317,38,25.275,16.318,0,0.893,0.875,4.250,21.432,3.719,1551.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:24:20.395,17962,21387,45.6,12510,20182,38.2,0.0,1.406,1.275,1.425,1.369,1.431,1.369,1.419,1.294,4850.1,4625.1,3860.1,4725.1,3880.1,4850.1,3880.1,4725.1,100.0,2837.1,2985.1,2453.1,3799.8,2115.6,1383.7,2668.7,2063.1,2312.1,1684.1,1841.9,1355.5,2161.1,996.3,2051.2,664.7,2085.8,52.4,64.0,46.3,81.7,39.6,26.8,48.1,40.8,40.2,35.9,30.4,25.0,43.9,18.2,37.8,11.5,81.7,40.2,48.5,46.3,38.6,47.3,38.8,48.5,38.8,47.3,1600.0,16.00,16,16,16,35,74,560,1,63.6,62.0,1.394,1.000,1.425,60.047,8.000,1600.0,35.0,63.6,41.0,42.0,40.0,1.392,5.000,3.328,3.360,12.192,0.728,3.328,1.832,0.712,1.008,1.360,1.536,946,725,1350,No,1.094,1.013,43.059,14.118,28,No,No,5951,176445,39,94.0,No,No,11884,23,0.0,0.0,0.0,0.000,0.000,211,2,0.1,0.1,0.2,0.153,0.302,23860,5234,62.0,66.0,765,10.000,58.000,1970.0,16.0,71.2,1.0,0.0,0.0,0.0,0.0,22.0,4206,1496,16.0,4265,317,38,25.891,15.997,0,0.868,0.994,2.000,8.680,1.988,1157.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:24:22.963,17947,21401,45.6,12510,20182,38.2,0.0,1.325,1.406,1.300,1.406,1.337,1.406,1.331,1.331,4825.1,4675.1,4775.1,4675.1,4800.1,4650.1,4825.1,4625.1,100.0,3203.1,2811.7,2555.2,3807.3,2238.2,1425.3,2741.2,2144.1,2410.9,1770.7,2029.7,1271.1,2282.0,1017.7,2138.4,709.5,2159.8,62.1,57.3,50.6,78.6,48.7,30.4,48.7,45.7,39.6,38.4,39.6,27.4,43.9,19.5,43.9,16.4,78.6,43.2,48.3,46.8,47.8,46.8,48.0,46.5,48.3,46.3,1600.0,16.00,16,16,16,35,74,560,1,63.8,60.8,1.431,1.000,1.450,34.573,6.800,1600.0,35.0,63.8,41.0,42.0,40.0,1.368,5.000,3.328,3.360,12.192,0.720,3.328,1.832,0.712,1.008,1.360,1.528,952,726,1350,No,1.119,1.013,40.941,13.412,28,No,No,5951,176445,39,94.0,No,No,11884,23,0.0,0.0,0.0,0.000,0.000,211,2,0.2,0.2,0.4,0.588,0.376,23862,5235,63.0,73.0,768,26.000,87.000,1986.0,88.0,72.7,8.0,0.0,0.0,0.0,0.0,22.0,4206,1496,16.0,4265,317,38,23.053,15.351,0,1.200,1.163,10.000,31.200,11.625,2237.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:24:25.515,17925,21424,45.5,12485,20208,38.1,0.0,1.331,1.381,1.388,1.350,1.406,1.356,1.363,1.381,4825.1,4725.1,4825.1,4825.1,4825.1,4825.1,4775.1,4800.1,100.0,3038.8,3055.5,2644.1,3819.0,2319.8,1453.9,2848.7,2239.2,2470.7,1894.5,2014.6,1307.3,2308.9,1014.7,2178.8,719.0,2208.0,56.7,57.9,51.2,78.0,41.4,31.7,52.4,45.1,46.3,33.5,40.2,25.0,49.3,17.0,45.7,14.6,78.0,42.9,48.3,47.3,48.3,48.3,48.3,48.3,47.8,48.0,1600.0,16.00,16,16,16,35,74,560,1,63.9,63.5,1.412,0.994,1.431,38.212,6.400,1600.0,35.0,63.9,41.0,42.0,40.0,1.392,5.000,3.328,3.360,12.192,0.720,3.328,1.832,0.712,1.008,1.360,1.536,958,725,1350,No,1.113,1.013,35.294,12.706,28,No,No,5951,176445,39,94.0,No,No,11884,23,0.0,0.0,0.0,0.000,0.000,211,2,0.4,0.1,0.5,0.795,0.342,23864,5236,63.0,70.0,795,4.000,138.000,2048.0,48.0,74.9,4.0,0.0,0.0,0.0,0.0,23.0,4206,1496,16.0,4265,317,39,27.046,15.765,0,0.868,0.856,0.250,3.472,0.214,1497.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:24:28.079,17919,21429,45.5,12487,20206,38.1,0.0,1.313,1.394,1.300,1.356,1.400,1.381,1.275,1.369,4825.1,4725.1,4825.1,4700.1,4825.1,4700.1,4825.1,4675.1,100.0,3143.3,2908.3,2645.6,3715.4,2192.0,1544.3,2810.6,2206.0,2465.0,1827.4,2057.8,1287.2,2223.3,996.1,2149.7,899.2,2192.0,59.7,57.9,50.6,76.2,46.9,32.9,51.8,48.1,51.8,37.8,37.8,31.7,42.6,20.7,42.6,17.6,76.2,44.2,48.3,47.3,48.3,47.0,48.3,47.0,48.3,46.8,1600.0,16.00,16,16,16,35,74,560,1,64.0,61.0,1.394,0.994,1.419,36.392,6.400,1600.0,35.0,64.0,42.0,42.0,40.0,1.392,5.000,3.344,3.376,12.192,0.720,3.328,1.832,0.712,1.008,1.360,1.536,993,1475,695,No,1.113,1.013,42.353,13.412,28,No,No,5951,176445,39,94.0,No,No,11884,23,0.0,0.0,0.0,0.000,0.000,211,2,4.0,0.1,4.1,10.131,0.376,23888,5237,62.0,65.0,801,9.000,55.000,1986.0,89.0,73.6,5.0,0.0,0.0,0.0,0.0,23.0,4206,1496,16.0,4265,317,39,20.607,14.686,0,0.893,0.869,3.500,8.037,3.041,1766.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:24:30.632,17912,21437,45.5,12477,20216,38.1,0.0,1.400,1.400,1.369,1.356,1.400,1.319,1.394,1.294,4825.1,4650.1,4750.1,4650.1,4825.1,4675.1,4825.1,4700.1,100.0,3261.9,2416.8,2466.8,3456.1,1962.4,1396.0,2658.3,2034.1,2285.0,1642.8,1391.7,1801.5,1978.2,976.3,1917.5,781.3,2026.7,61.5,48.1,48.7,68.9,38.4,25.6,47.5,43.9,43.2,27.4,22.5,39.0,39.0,21.3,37.8,15.2,68.9,39.3,48.3,46.5,47.5,46.5,48.3,46.8,48.3,47.0,1600.0,16.00,16,16,16,35,74,560,1,63.8,62.3,1.381,1.000,1.413,63.686,8.000,1600.0,36.0,63.8,42.0,42.0,40.0,1.384,5.000,3.328,3.360,12.192,0.720,3.328,1.832,0.712,1.008,1.360,1.536,1026,730,1358,No,1.087,1.013,33.882,13.412,28,No,No,5951,176445,39,94.0,No,No,11884,23,0.0,0.0,0.0,0.000,0.000,211,2,2.7,0.1,2.8,6.122,0.306,23903,5237,62.0,67.0,806,8.000,112.000,2016.0,47.0,73.3,3.0,0.0,0.0,0.0,0.0,23.0,4206,1497,16.0,4265,317,39,21.517,15.328,0,1.200,0.856,0.000,9.600,0.000,2105.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:24:33.189,17913,21436,45.5,12479,20214,38.1,0.0,1.400,1.388,1.294,1.381,1.413,1.300,1.306,1.356,4800.1,4825.1,4825.1,4750.1,4750.1,4775.1,4850.1,4850.1,100.0,3528.4,2739.9,2808.4,3763.5,2414.8,1632.0,2995.5,2439.8,2608.2,2071.9,1340.5,2147.1,2408.6,1139.6,2268.0,950.2,2328.5,70.5,54.6,53.9,74.2,48.4,33.7,55.8,48.4,49.0,39.2,30.0,38.6,47.8,25.7,46.0,17.7,74.2,45.8,48.0,48.3,48.3,47.5,47.5,47.8,48.5,48.5,1600.0,16.00,16,16,16,35,74,560,1,64.1,64.3,1.406,1.000,1.444,62.776,8.400,1600.0,36.0,64.0,42.0,42.0,40.0,1.344,5.000,3.328,3.360,12.192,0.720,3.328,1.832,0.712,1.008,1.360,1.528,1036,731,1351,No,1.100,1.013,28.941,12.000,28,No,No,5951,176445,39,94.0,No,No,11884,23,0.0,0.0,0.0,0.000,0.000,211,2,0.7,0.1,0.9,1.829,0.344,23908,5238,63.0,67.0,800,21.000,43.000,1986.0,76.0,74.5,4.0,0.0,0.0,0.0,0.0,23.0,4206,1497,16.0,4265,317,39,20.420,14.252,0,0.950,0.931,5.750,19.950,5.355,1688.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:24:35.755,17907,21441,45.5,12470,20222,38.1,0.0,1.306,1.337,1.388,1.381,1.294,1.394,1.388,1.263,4700.1,4725.1,4700.1,4700.1,4750.1,4775.1,4800.1,4650.1,100.0,3281.8,3019.4,2769.5,3871.5,2355.8,1601.5,2959.3,2407.5,2641.5,1976.7,1292.8,2178.8,2346.5,1120.7,2196.3,1104.7,2320.3,57.3,51.8,53.6,79.8,46.9,29.8,51.2,45.1,48.7,37.8,20.7,35.9,40.8,20.7,37.1,20.7,79.8,42.4,47.0,47.3,47.0,47.0,47.5,47.8,48.0,46.5,1600.0,16.00,16,16,16,35,74,560,1,64.6,62.0,1.369,0.994,1.388,31.843,6.400,1600.0,36.0,64.5,42.0,42.0,40.0,1.384,5.000,3.328,3.360,12.192,0.712,3.328,1.832,0.704,1.008,1.360,1.536,1037,731,695,No,1.106,1.013,33.882,13.412,28,No,No,5951,176445,39,94.0,No,No,11884,23,0.0,0.0,0.0,0.000,0.000,211,2,1.9,0.1,1.9,4.425,0.282,23918,5239,63.0,69.0,803,22.000,72.000,1986.0,88.0,74.8,8.0,0.0,0.0,0.0,0.0,23.0,4206,1498,16.0,4265,318,39,22.381,16.884,0,1.037,0.969,11.750,22.814,11.383,2086.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:24:38.321,17901,21447,45.4,12476,20217,38.1,0.0,1.356,1.388,1.381,1.394,1.400,1.381,1.400,1.375,4675.1,4750.1,4775.1,4800.1,3840.1,4800.1,4800.1,4750.1,100.0,3188.4,3108.9,2832.8,3728.3,2450.6,1614.5,3093.6,2428.1,2728.6,2039.6,1317.1,2172.0,2494.7,1108.8,2322.7,827.4,2341.0,59.7,69.5,56.0,79.8,47.5,34.7,58.5,50.6,54.2,39.0,24.3,40.8,51.8,20.7,50.6,18.9,79.8,47.3,46.8,47.5,47.8,48.0,38.4,48.0,48.0,47.5,1600.0,16.00,16,16,16,35,74,560,1,64.6,62.5,1.400,0.994,1.419,35.482,6.800,1600.0,36.0,64.6,42.0,42.0,40.0,1.384,5.000,3.328,3.360,12.192,0.712,3.328,1.832,0.704,1.008,1.360,1.536,1034,1481,1358,No,1.113,1.013,43.765,14.118,28,No,No,5951,176445,39,94.0,No,No,11884,23,0.0,0.0,0.0,0.000,0.000,211,2,0.7,0.1,0.8,2.258,0.255,23924,5239,63.0,70.0,845,8.000,111.000,2010.0,40.0,75.6,5.0,0.0,0.0,0.0,0.0,24.0,4206,1498,16.0,4265,318,39,21.088,14.223,0,1.193,1.181,2.250,9.544,2.658,1363.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:24:40.880,17904,21445,45.4,12481,20212,38.1,0.0,1.344,1.431,1.363,1.300,1.288,1.406,1.300,1.406,4650.1,4825.1,4675.1,4625.1,4600.1,4675.1,4750.1,4650.1,100.0,3226.0,2969.8,2766.7,3816.1,2400.6,1580.2,3005.7,2413.6,2626.3,2043.3,1385.3,2032.5,2373.8,1092.3,2224.7,965.8,2307.7,62.8,53.0,51.8,74.3,44.5,31.0,52.4,46.3,46.3,37.8,28.0,35.9,41.4,21.3,41.4,17.0,74.3,42.8,46.5,48.3,46.8,46.3,46.0,46.8,47.5,46.5,1600.0,16.00,16,16,16,35,74,560,1,64.9,65.5,1.356,1.000,1.394,70.055,8.000,1600.0,36.0,64.9,42.0,42.0,40.0,1.360,5.000,3.328,3.360,12.192,0.712,3.328,1.832,0.704,1.008,1.360,1.528,1039,732,1356,No,1.113,1.013,33.882,14.118,28,No,No,5951,176445,39,94.0,No,No,11884,23,0.0,0.0,0.0,0.000,0.000,211,2,0.4,0.3,0.7,1.712,0.395,23928,5240,64.0,72.0,870,21.000,46.000,1984.0,65.0,77.4,3.0,0.0,0.0,0.0,0.0,25.0,4206,1498,16.0,4265,318,39,21.715,10.574,0,1.200,1.163,5.750,25.200,6.684,1619.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:24:43.432,17821,21528,45.2,12441,20252,38.0,0.0,1.406,1.281,1.363,1.375,1.388,1.369,1.406,1.369,4825.1,4825.1,3860.1,4775.1,4825.1,4775.1,4800.1,4750.1,100.0,3310.3,3000.2,2854.3,3540.0,2379.6,1580.6,3098.4,2246.4,2784.4,1923.3,1512.3,1957.3,2379.1,1217.6,2263.5,1011.4,2316.2,67.6,60.3,57.3,69.5,47.5,32.3,58.5,45.1,59.7,37.8,32.9,39.0,47.5,25.0,43.2,21.9,69.5,46.6,48.3,48.3,38.6,47.8,48.3,47.8,48.0,47.5,1600.0,16.00,16,16,16,35,74,560,1,65.4,64.0,1.394,1.000,1.419,43.671,6.800,1600.0,36.0,65.3,42.0,42.0,40.0,1.360,5.000,3.328,3.360,12.192,0.712,3.328,1.832,0.704,1.008,1.360,1.528,1040,1481,696,No,1.113,1.013,42.353,14.824,28,No,No,5951,176445,39,94.0,No,No,11884,23,0.0,0.0,0.0,0.000,0.000,211,2,30.9,0.1,31.0,87.216,0.182,24141,5241,66.0,79.0,897,28.000,142.000,1990.0,97.0,88.2,4.0,0.0,0.0,0.0,0.0,26.0,4207,1503,16.0,4266,318,39,20.948,7.381,0,1.200,1.150,7.750,33.600,8.912,2478.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:24:45.988,17891,21457,45.4,12525,20168,38.3,0.0,1.406,1.400,1.400,1.406,1.388,1.406,1.406,1.406,4825.1,4850.1,4825.1,4825.1,4775.1,4825.1,3860.1,4825.1,100.0,3121.2,2633.2,2108.0,3512.1,1628.3,1037.6,2795.4,1502.0,2007.8,1207.1,1582.8,1007.2,1588.7,681.0,1398.8,512.9,1770.3,56.7,60.9,46.9,70.1,32.3,21.3,54.2,32.3,45.1,25.0,31.7,19.5,34.7,13.4,32.3,8.5,70.1,36.6,48.3,48.5,48.3,48.3,47.8,48.3,38.6,48.3,1600.0,16.00,16,16,16,35,74,560,1,65.8,64.0,1.387,1.000,1.419,60.957,8.000,1600.0,36.0,65.8,42.0,43.0,40.0,1.392,5.000,3.328,3.360,12.096,0.704,3.328,1.832,0.704,1.008,1.360,1.528,1086,1485,1350,No,1.119,1.013,28.941,13.412,28,No,No,5951,176445,39,94.0,No,No,11884,23,0.0,0.0,0.0,0.000,0.000,211,2,2.2,0.0,2.2,8.798,0.128,24162,5241,68.0,80.0,953,13.000,132.000,1990.0,97.0,99.5,4.0,0.0,0.0,0.0,0.0,28.0,4207,1504,16.0,4266,318,39,12.380,7.386,0,1.200,1.138,15.250,15.600,17.347,2600.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:24:48.539,18015,21334,45.7,12586,20107,38.4,0.0,1.381,1.413,1.394,1.425,1.369,1.419,1.344,1.419,4850.1,4825.1,4800.1,3880.1,4850.1,4850.1,4800.1,3880.1,100.0,2735.5,2553.2,1813.2,3569.9,1590.9,932.9,2547.2,1362.8,2103.3,1139.6,1739.8,834.2,1513.8,733.1,1361.2,513.7,1690.3,59.5,49.6,39.2,74.2,31.9,17.7,47.8,27.6,41.1,26.3,26.9,17.7,31.9,15.9,31.2,12.8,74.2,34.5,48.5,48.3,48.0,38.8,48.5,48.5,48.0,38.8,1600.0,16.00,16,16,16,35,74,560,1,65.5,62.3,1.400,0.994,1.419,32.753,6.800,1600.0,36.0,65.6,42.0,43.0,40.0,1.400,5.000,3.328,3.360,12.192,0.704,3.328,1.832,0.704,1.008,1.360,1.528,1126,736,695,No,1.119,1.013,27.529,12.000,28,No,No,5951,176445,39,94.0,No,No,11884,23,0.0,0.0,0.0,0.000,0.000,211,2,3.6,0.1,3.7,12.564,0.266,24193,5242,67.0,80.0,1048,9.000,123.000,1986.0,95.0,98.2,2.0,0.0,0.0,0.0,0.0,30.0,4271,1568,16.0,4330,318,39,25.749,8.085,0,1.200,1.131,16.500,10.800,18.666,2518.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:24:51.090,18030,21318,45.8,12608,20085,38.5,0.0,1.413,1.400,1.419,1.394,1.406,1.419,1.400,1.400,4850.1,4825.1,3880.1,4850.1,4775.1,4850.1,4750.1,4800.1,100.0,2497.0,2333.2,1770.2,3695.1,1544.7,960.4,2152.7,1354.7,2008.7,1104.8,1733.0,815.5,1458.3,675.0,1337.8,437.6,1617.4,51.5,49.6,31.2,80.3,28.8,22.6,41.7,27.6,36.1,26.9,32.5,16.5,31.9,16.5,24.5,8.5,80.3,32.9,48.5,48.3,38.8,48.5,47.8,48.5,47.5,48.0,1600.0,16.00,16,16,16,35,74,560,1,65.1,62.0,1.387,1.000,1.419,52.769,8.400,1600.0,36.0,65.3,42.0,43.0,40.0,1.400,5.000,3.328,3.360,12.192,0.704,3.328,1.832,0.704,1.008,1.360,1.528,1163,740,696,No,1.113,1.013,33.176,12.706,28,No,No,5951,176445,39,94.0,No,No,11884,23,0.0,0.0,0.0,0.000,0.000,211,2,2.2,0.1,2.2,6.031,0.259,24208,5242,68.0,80.0,1165,9.000,135.000,1990.0,98.0,98.9,2.0,0.0,0.0,0.0,0.0,34.0,4271,1571,16.0,4330,318,39,26.523,8.363,0,1.200,1.138,13.000,10.800,14.788,2569.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:24:53.643,18042,21307,45.8,12624,20069,38.6,0.0,1.400,1.394,1.313,1.400,1.381,1.400,1.400,1.388,4800.1,4775.1,4800.1,4800.1,4775.1,4825.1,4850.1,4850.1,100.0,3201.7,2099.9,1903.6,3472.8,1368.1,958.0,2716.4,1120.0,1811.0,1020.9,1669.7,730.1,1311.9,669.9,1204.5,600.7,1616.2,65.8,37.1,31.2,75.0,26.8,18.2,53.6,20.2,36.5,15.8,28.6,15.2,23.1,14.0,25.6,14.0,75.0,31.3,48.0,47.8,48.0,48.0,47.8,48.3,48.5,48.5,1600.0,16.00,16,16,16,35,74,560,1,67.8,64.8,1.400,1.000,1.425,38.212,6.400,1600.0,36.0,67.9,42.0,43.0,40.0,1.400,5.000,3.328,3.360,12.096,0.704,3.328,1.832,0.696,1.008,1.360,1.528,1186,742,696,No,1.113,1.013,28.235,12.000,28,No,No,5951,176445,39,94.0,No,No,11884,23,0.0,0.0,0.0,0.000,0.000,211,2,1.3,0.1,1.4,3.687,0.190,24217,5243,68.0,83.0,1276,24.000,106.000,1988.0,96.0,99.4,5.0,0.0,0.0,0.0,0.0,37.0,4271,1572,16.0,4330,318,39,23.969,8.143,0,1.200,1.156,7.250,28.800,8.383,2552.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:24:56.201,18044,21305,45.8,12610,20082,38.5,0.0,1.388,1.400,1.331,1.413,1.394,1.413,1.388,1.406,4825.1,4825.1,4825.1,4825.1,4825.1,4800.1,4800.1,4825.1,100.0,3212.8,2134.0,1770.7,3482.0,1167.5,682.7,2438.0,1070.9,1474.3,874.7,1488.4,719.3,1128.2,567.3,1059.6,379.9,1478.1,69.3,42.3,40.2,70.5,26.9,12.2,50.3,25.6,31.2,16.5,28.2,15.3,25.1,11.0,22.0,6.7,70.5,30.8,48.3,48.3,48.3,48.3,48.3,48.0,48.0,48.3,1600.0,16.00,16,16,16,35,74,560,1,66.9,62.8,1.394,0.994,1.419,46.400,8.400,1600.0,36.0,66.0,42.0,43.0,40.0,1.400,5.000,3.328,3.360,12.192,0.704,3.328,1.832,0.696,1.008,1.360,1.528,1235,1518,696,No,1.113,1.013,32.471,11.294,28,No,No,5951,176445,39,94.0,No,No,11884,23,0.0,0.0,0.0,0.000,0.000,211,2,0.4,0.1,0.5,1.130,0.204,24219,5243,69.0,85.0,1324,10.000,168.000,1990.0,99.0,99.5,2.0,0.0,0.0,0.0,0.0,38.0,4271,1556,16.0,4330,318,39,24.640,10.977,0,1.200,1.119,17.500,12.000,19.578,2556.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:24:58.762,18041,21308,45.8,12610,20083,38.5,0.0,1.388,1.406,1.406,1.406,1.388,1.394,1.413,1.394,4850.1,4825.1,4825.1,4825.1,4850.1,4825.1,4825.1,4800.1,100.0,3641.4,1567.9,1422.4,3863.4,1261.6,733.9,2435.2,1074.0,1560.7,911.9,1491.0,758.7,1149.3,493.1,1087.1,430.5,1492.6,72.5,27.4,27.4,79.8,23.1,12.8,39.0,18.9,27.4,12.8,32.9,11.5,18.9,8.5,17.0,8.5,79.8,27.4,48.5,48.3,48.3,48.3,48.5,48.3,48.3,48.0,1600.0,16.00,16,16,16,35,74,560,1,66.3,61.5,1.306,1.000,1.413,50.039,8.000,1600.0,36.0,66.4,42.0,43.0,40.0,1.400,5.000,3.328,3.360,12.096,0.704,3.328,1.832,0.696,1.008,1.360,1.528,1277,748,696,No,1.100,1.013,36.000,12.000,28,No,No,5951,176445,39,94.0,No,No,11884,23,0.0,0.0,0.0,0.000,0.000,211,2,0.3,0.0,0.3,0.573,0.155,24221,5244,69.0,84.0,1300,15.000,172.000,1988.0,99.0,100.0,1.0,0.0,0.0,0.0,0.0,38.0,4271,1556,16.0,4330,318,39,17.227,9.146,0,1.200,1.125,8.250,18.000,9.281,2567.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:25:1.318,17741,21608,45.0,12319,20373,37.6,0.0,1.400,1.381,1.400,1.419,1.400,1.413,1.394,1.406,4800.1,4700.1,4800.1,4825.1,4825.1,4800.1,4800.1,4825.1,100.0,3128.1,1704.3,1514.5,3770.9,1310.1,820.5,2226.5,1150.8,1530.9,974.6,1569.0,845.2,1263.2,576.7,1164.2,467.3,1501.1,62.8,31.0,31.7,75.6,25.0,16.4,40.2,22.5,27.4,19.5,23.1,15.2,25.0,7.3,25.0,7.9,75.6,28.5,48.0,47.0,48.0,48.3,48.3,48.0,48.0,48.3,1600.0,16.00,16,16,16,35,74,560,1,65.8,61.3,1.400,0.994,1.425,40.031,6.800,1600.0,37.0,65.9,42.0,43.0,40.0,1.408,5.000,3.328,3.360,12.192,0.704,3.328,1.832,0.696,1.008,1.360,1.528,1314,1534,696,No,1.119,1.013,31.765,11.294,28,No,No,5951,176445,39,94.0,No,No,11884,23,0.0,0.0,0.0,0.000,0.000,211,2,1.3,0.1,1.4,2.921,0.153,24228,5244,69.0,85.0,1301,28.000,181.000,1988.0,99.0,95.8,1.0,0.0,0.0,0.0,0.0,38.0,4272,1556,16.0,4330,318,39,8.468,8.608,0,1.200,1.131,14.500,33.600,16.403,2570.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:25:3.877,17736,21612,45.0,12311,20382,37.6,0.0,1.413,1.406,1.381,1.394,1.400,1.406,1.406,1.356,4825.1,4825.1,4725.1,4800.1,4775.1,4825.1,3860.1,4825.1,100.0,3105.1,2310.1,1962.7,3325.4,1277.5,864.3,2546.1,1239.4,1676.3,953.6,1074.5,1274.5,1255.9,542.2,1147.6,474.1,1564.3,67.6,48.1,39.0,67.0,22.5,13.4,50.6,26.2,27.4,19.5,19.5,20.7,29.2,9.1,19.5,9.1,67.6,30.5,48.3,48.3,47.3,48.0,47.8,48.3,38.6,48.3,1600.0,16.00,16,16,16,35,74,560,1,65.6,63.5,1.394,1.000,1.419,38.212,6.800,1600.0,37.0,65.6,42.0,43.0,40.0,1.400,5.000,3.328,3.360,12.192,0.704,3.328,1.832,0.696,1.008,1.360,1.528,1300,1521,696,No,1.100,1.019,24.706,14.118,28,No,No,5951,176445,39,94.0,No,No,11884,23,0.0,0.0,0.0,0.000,0.000,211,2,0.3,0.0,0.4,0.587,0.129,24229,5244,69.0,86.0,1302,13.000,171.000,1988.0,99.0,99.5,1.0,0.0,0.0,0.0,0.0,38.0,4272,1556,16.0,4330,318,39,5.957,7.002,0,1.200,1.131,7.750,15.600,8.767,2568.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:25:6.439,17812,21536,45.2,12376,20317,37.8,0.0,1.394,1.331,1.400,1.281,1.400,1.313,1.400,1.388,4825.1,4700.1,3860.1,4725.1,3840.1,4650.1,4800.1,4825.1,100.0,2962.5,2370.8,2004.2,3375.7,1445.9,928.4,2539.5,1260.2,1987.8,963.0,792.0,1649.7,1428.2,586.4,1136.1,449.4,1617.5,57.6,45.3,32.5,72.3,33.1,14.7,46.0,25.7,35.5,19.6,16.5,28.8,24.5,9.8,20.8,9.2,72.3,30.7,48.3,47.0,38.6,47.3,38.4,46.5,48.0,48.3,1600.0,16.00,16,16,16,35,74,560,1,66.0,64.5,1.412,0.994,1.431,32.753,6.400,1600.0,37.0,66.6,42.0,43.0,40.0,1.384,5.000,3.328,3.360,12.192,0.704,3.328,1.832,0.688,1.008,1.360,1.536,1279,1534,697,No,1.113,1.013,51.529,12.706,28,No,No,5951,176445,39,94.0,No,No,11884,23,0.0,0.0,0.0,0.000,0.000,211,2,9.8,0.2,10.0,37.412,0.356,24321,5245,67.0,70.0,1299,24.000,41.000,1982.0,88.0,81.8,5.0,0.0,0.0,0.0,0.0,38.0,4274,1556,16.0,4330,318,39,7.726,8.256,0,0.912,0.887,8.500,21.888,7.544,1928.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:25:9.004,18018,21330,45.7,12583,20110,38.4,0.0,1.394,1.394,1.381,1.394,1.406,1.394,1.394,1.381,4825.1,4800.1,4825.1,4800.1,4825.1,4825.1,4825.1,4800.1,100.0,2883.9,2548.2,1886.2,3595.6,1704.5,1090.5,2578.4,1369.5,2015.0,1196.1,948.9,1748.0,1724.0,645.7,1385.6,535.1,1740.9,53.6,48.7,37.1,73.7,28.6,22.5,55.4,24.3,38.4,22.5,18.9,37.1,31.7,11.5,32.9,9.7,73.7,34.2,48.3,48.0,48.3,48.0,48.3,48.3,48.3,48.0,1600.0,16.00,16,16,16,35,74,560,1,66.8,63.8,1.381,1.000,1.413,56.408,8.000,1600.0,37.0,66.9,43.0,43.0,40.0,1.408,5.000,3.328,3.360,12.192,0.704,3.328,1.832,0.688,1.008,1.360,1.536,1250,1520,697,No,1.113,1.013,33.882,12.000,28,No,No,5951,176445,39,94.0,No,No,11884,23,0.0,0.0,0.0,0.000,0.000,211,2,8.1,0.0,8.2,33.390,0.175,24402,5246,65.0,68.0,1291,9.000,63.000,1900.0,41.0,68.7,2.0,0.0,0.0,0.0,0.0,37.0,4274,1556,16.0,4330,318,39,8.038,9.357,0,0.893,0.887,1.500,8.037,1.331,1211.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:25:11.554,18076,21273,45.9,12643,20049,38.6,0.0,1.400,1.375,1.413,1.388,1.313,1.363,1.406,1.394,4825.1,4825.1,4825.1,4800.1,4825.1,4700.1,3860.1,4825.1,100.0,2714.0,2345.6,2342.1,3094.2,1595.1,927.4,2377.0,1363.4,1833.3,1169.9,855.8,1750.6,1467.3,640.6,1493.8,560.5,1658.2,47.5,48.7,48.7,53.6,29.8,16.4,39.6,26.2,33.5,24.3,13.4,28.6,27.4,12.1,34.1,9.1,53.6,30.8,48.3,48.3,48.3,48.0,48.3,47.0,38.6,48.3,1600.0,16.00,16,16,16,35,74,560,1,66.3,61.5,1.400,0.994,1.425,37.302,6.800,1600.0,37.0,66.4,43.0,43.0,40.0,1.400,5.000,3.328,3.360,12.192,0.704,3.328,1.832,0.688,1.008,1.360,1.536,1256,750,698,No,1.100,1.013,28.235,12.706,28,No,No,5951,176445,39,94.0,No,No,11884,23,0.0,0.0,0.0,0.000,0.000,211,2,3.9,0.0,4.0,11.716,0.179,24431,5246,65.0,69.0,1285,8.000,81.000,1956.0,41.0,68.1,3.0,0.0,0.0,0.0,0.0,37.0,4274,1556,16.0,4330,318,39,8.570,9.241,0,0.868,0.950,2.000,6.944,1.900,1300.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:25:14.148,18094,21254,45.9,12660,20033,38.7,0.0,1.419,1.425,1.381,1.381,1.400,1.406,1.400,1.406,4850.1,4825.1,3860.1,4775.1,3880.1,4825.1,4725.1,3880.1,100.0,2281.6,2838.0,2186.9,3247.8,1420.7,900.1,2489.1,1319.4,1876.8,1148.7,856.1,1717.1,1433.6,786.0,1254.0,569.9,1645.4,43.9,53.0,42.9,63.4,25.6,18.2,42.6,26.9,35.3,19.5,14.0,26.8,25.0,18.2,21.9,10.9,63.4,30.5,48.5,48.3,38.6,47.8,38.8,48.3,47.3,38.8,1600.0,16.00,16,16,16,35,74,560,1,66.4,62.5,1.400,0.994,1.425,39.122,7.200,1600.0,37.0,66.4,43.0,44.0,40.0,1.392,5.000,3.328,3.360,12.192,0.704,3.328,1.832,0.688,1.008,1.360,1.536,1243,751,698,No,1.119,1.013,26.824,14.118,28,No,No,5951,176445,39,94.0,No,No,11884,23,0.0,0.0,0.0,0.000,0.000,211,2,2.2,0.1,2.2,6.959,0.229,24448,5247,63.0,66.0,1284,10.000,53.000,1956.0,24.0,68.2,1.0,0.0,0.0,0.0,0.0,37.0,4275,1556,16.0,4330,318,39,8.048,10.717,0,0.893,0.887,1.750,8.930,1.553,889.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:25:16.716,18095,21254,45.9,12661,20031,38.7,0.0,1.350,1.381,1.363,1.375,1.294,1.394,1.325,1.406,4825.1,4700.1,4825.1,4800.1,4825.1,4750.1,4800.1,3840.1,100.0,2833.5,2231.9,1779.3,3537.4,1340.1,939.2,2320.6,1197.1,1720.9,1052.8,920.1,1614.7,1342.1,720.0,1265.6,510.9,1582.9,51.5,36.3,28.3,74.5,20.0,12.7,44.8,13.2,27.2,13.9,9.6,24.2,19.3,10.3,17.5,7.2,74.5,25.7,48.3,47.0,48.3,48.0,48.3,47.5,48.0,38.4,1600.0,16.00,16,16,16,35,74,560,1,66.3,62.3,1.400,1.000,1.344,61.867,7.600,1600.0,37.0,66.3,43.0,44.0,40.0,1.384,5.000,3.328,3.360,12.192,0.704,3.328,1.832,0.688,1.008,1.360,1.536,1253,751,698,No,1.119,1.013,30.353,12.706,28,No,No,5951,176445,39,94.0,No,No,11884,23,0.0,0.0,0.0,0.000,0.000,211,2,6.4,0.1,6.5,20.138,0.229,24497,5247,62.0,66.0,1284,28.000,61.000,1984.0,94.0,68.9,5.0,0.0,0.0,0.0,0.0,37.0,4276,1556,16.0,4330,318,39,10.530,11.143,0,0.893,0.869,5.500,25.004,4.778,1757.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:25:19.282,18007,21342,45.7,12605,20088,38.5,0.0,1.394,1.400,1.394,1.394,1.388,1.388,1.419,1.350,4775.1,4800.1,3840.1,4800.1,4850.1,4775.1,3860.1,4750.1,100.0,3154.9,2148.5,2180.2,3158.0,1572.4,1065.9,2559.7,1375.9,1912.3,1239.7,1004.3,1721.9,1563.0,766.1,1405.8,609.5,1714.9,58.7,40.0,44.2,61.2,31.5,16.3,50.3,22.4,35.7,20.6,17.5,32.1,24.8,15.7,29.6,9.0,61.2,31.9,47.8,48.0,38.4,48.0,48.5,47.8,38.6,47.5,1600.0,16.00,16,16,16,35,74,560,1,66.9,62.8,1.419,1.000,1.444,45.490,7.200,1600.0,37.0,66.8,43.0,44.0,40.0,1.400,5.000,3.328,3.360,12.192,0.696,3.328,1.832,0.688,1.008,1.360,1.536,1244,747,697,No,1.106,1.013,31.765,14.118,28,No,No,5951,176445,39,94.0,No,No,11884,23,0.0,0.0,0.0,0.000,0.000,211,2,10.0,0.1,10.1,32.294,0.250,24576,5248,62.0,64.0,1283,11.000,44.000,1950.0,20.0,70.1,1.0,0.0,0.0,0.0,0.0,37.0,4276,1557,16.0,4330,318,39,16.142,12.349,0,0.893,0.894,1.250,9.823,1.117,734.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:25:21.847,18211,21138,46.2,12808,19884,39.1,0.0,1.394,1.388,1.406,1.406,1.400,1.400,1.381,1.400,4800.1,4800.1,3860.1,4825.1,3860.1,4825.1,4800.1,4825.1,100.0,2324.1,3018.5,1868.5,3472.7,1553.7,903.9,2700.5,1204.7,2008.7,1067.9,1481.4,1092.7,1478.8,598.9,1293.4,683.8,1672.0,39.0,54.8,32.3,71.3,28.6,18.2,51.2,20.7,35.3,23.7,29.2,18.9,23.7,14.0,25.0,12.8,71.3,31.2,48.0,48.0,38.6,48.3,38.6,48.3,48.0,48.3,1600.0,16.00,16,16,16,35,74,560,1,67.3,60.5,1.400,0.994,1.406,41.851,8.000,1600.0,37.0,67.4,43.0,44.0,40.0,1.400,5.000,3.328,3.360,12.192,0.696,3.328,1.832,0.680,1.008,1.360,1.536,1247,1523,698,No,1.113,1.013,36.000,14.118,28,No,No,5951,176445,39,94.0,No,No,11884,24,0.0,0.0,0.0,0.000,0.000,211,2,10.3,1.0,11.3,38.656,0.242,24671,5249,61.0,62.0,1284,10.000,36.000,1988.0,99.0,69.9,0.0,0.0,0.0,0.0,0.0,37.0,4276,1557,16.0,4330,318,39,17.114,11.857,0,0.893,0.887,1.500,8.930,1.331,1762.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:25:24.406,18838,20511,47.8,12859,19834,39.3,0.0,1.381,1.306,1.319,1.350,1.381,1.288,1.337,1.263,4800.1,4600.1,4800.1,4775.1,4800.1,4675.1,4800.1,4625.1,100.0,2442.5,2809.8,2023.4,3282.0,1507.8,866.1,2530.4,1290.4,1863.5,1091.9,1703.3,901.5,1502.1,710.2,1273.4,523.2,1645.1,42.6,52.4,42.6,64.6,31.0,14.0,48.7,21.3,35.3,17.0,35.3,10.3,28.6,14.0,23.1,7.3,64.6,30.5,48.0,46.0,48.0,47.8,48.0,46.8,48.0,46.3,1600.0,16.00,16,16,16,35,74,560,1,67.0,61.8,1.406,0.994,1.431,42.761,6.800,1600.0,38.0,66.9,43.0,44.0,40.0,1.384,5.000,3.328,3.376,12.192,0.696,3.328,1.832,0.680,1.008,1.360,1.536,1253,752,698,No,1.087,1.013,33.176,14.118,28,No,No,5951,176445,39,94.0,No,No,11884,24,0.0,0.0,0.0,0.000,0.000,211,2,7.8,0.1,7.9,24.130,0.203,24730,5249,60.0,62.0,1266,11.000,40.000,1986.0,68.0,70.2,1.0,0.0,0.0,0.0,0.0,37.0,4857,1559,16.0,4906,318,39,19.775,15.126,0,0.893,0.881,5.000,9.823,4.406,1231.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:25:26.975,18888,20461,48.0,12913,19780,39.4,0.0,1.413,1.300,1.438,1.406,1.425,1.406,1.281,1.300,4825.1,4650.1,3860.1,4650.1,4775.1,4700.1,4750.1,4650.1,100.0,3264.6,2080.5,2107.7,3373.4,1675.6,1048.2,2549.5,1426.0,1945.2,1265.3,1778.3,1017.6,1667.9,771.0,1429.8,662.8,1754.0,64.6,41.4,38.4,68.2,29.2,18.9,51.2,28.0,37.1,21.3,32.3,12.8,28.6,14.0,32.3,10.9,68.2,33.1,48.3,46.5,38.6,46.5,47.8,47.0,47.5,46.5,1600.0,16.00,16,16,16,35,74,560,1,66.8,63.0,1.419,0.994,1.438,39.122,6.800,1600.0,38.0,66.9,43.0,44.0,40.0,1.384,5.000,3.328,3.360,12.192,0.696,3.328,1.832,0.680,1.008,1.360,1.536,1245,745,698,No,1.119,1.013,48.000,12.706,28,No,No,5951,176445,39,94.0,No,No,11884,24,0.0,0.0,0.0,0.000,0.000,211,2,7.5,0.1,7.6,19.804,0.217,24778,5250,60.0,62.0,1208,8.000,58.000,1924.0,33.0,69.8,2.0,0.0,0.0,0.0,0.0,35.0,4859,1553,16.0,4906,318,39,26.869,19.105,0,0.868,0.863,0.000,6.944,0.000,1087.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:25:29.522,18906,20443,48.0,12917,19776,39.5,0.0,1.381,1.400,1.350,1.375,1.363,1.394,1.369,1.413,4775.1,4800.1,4775.1,4825.1,4800.1,4825.1,4750.1,4825.1,100.0,3400.8,2059.4,2334.4,3323.6,1795.8,1165.3,2643.2,1649.9,2142.9,1494.1,1850.1,1073.9,1856.9,843.8,1607.4,731.7,1873.3,63.4,40.2,47.5,64.6,37.8,19.5,53.0,32.3,43.9,32.3,37.8,23.1,34.7,21.3,29.2,16.4,64.6,37.3,47.8,48.0,47.8,48.3,48.0,48.3,47.5,48.3,1600.0,16.00,16,16,16,35,74,560,1,66.4,62.8,1.325,0.994,1.350,40.941,7.600,1600.0,38.0,66.4,43.0,44.0,40.0,1.384,5.000,3.328,3.360,12.192,0.696,3.328,1.832,0.680,1.008,1.360,1.536,1251,1521,1354,No,1.113,1.013,31.059,12.706,28,No,No,5951,176445,41,94.0,No,No,11884,24,0.0,0.0,0.0,0.000,0.000,211,2,11.1,0.1,11.2,26.741,0.207,24843,5250,59.0,62.0,1124,25.000,67.000,1986.0,96.0,69.6,5.0,0.0,0.0,0.0,0.0,33.0,4860,1554,16.0,4906,318,39,30.987,14.992,0,0.900,0.875,9.250,22.500,8.094,1931.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:25:32.088,18938,20411,48.1,12952,19741,39.6,0.0,1.319,1.381,1.394,1.319,1.319,1.263,1.400,1.319,4700.1,4800.1,3820.1,4725.1,4675.1,4725.1,4775.1,4775.1,100.0,3134.4,2668.8,2484.2,3457.3,1988.4,1210.1,2810.9,1861.0,2283.9,1619.1,1821.6,1238.6,1969.0,966.2,1785.0,778.3,2004.8,65.6,55.2,57.6,73.0,42.3,24.5,55.8,40.4,44.1,34.9,34.9,22.6,43.5,21.4,39.2,18.4,73.0,42.1,47.0,48.0,38.2,47.3,46.8,47.3,47.8,47.8,1600.0,16.00,16,16,16,35,74,560,1,66.4,69.0,1.275,0.994,1.306,57.318,8.400,1600.0,38.0,66.4,43.0,44.0,40.0,1.384,5.000,3.328,3.360,12.192,0.696,3.328,1.832,0.680,1.008,1.360,1.536,1253,743,697,No,1.100,1.013,26.824,11.294,28,No,No,5951,176445,39,94.0,No,No,11884,24,0.0,0.0,0.0,0.000,0.000,211,2,5.6,0.0,5.6,15.779,0.178,24882,5251,60.0,61.0,1023,11.000,42.000,1996.0,63.0,71.0,1.0,0.0,0.0,0.0,0.0,30.0,4861,1554,16.0,4906,319,39,34.541,13.073,0,0.893,0.881,3.500,9.823,3.084,1271.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:25:34.650,18946,20403,48.1,12962,19730,39.6,0.0,1.300,1.394,1.300,1.369,1.300,1.406,1.313,1.413,4650.1,4825.1,4575.1,4800.1,4750.1,4850.1,4750.1,3860.1,100.0,3136.0,2555.8,2523.3,3289.0,1951.9,1220.8,2718.6,1855.9,2269.8,1574.2,1831.9,1205.2,1940.8,953.5,1767.9,754.6,1971.8,66.6,47.2,53.3,67.8,38.1,23.6,53.9,35.1,49.0,29.0,38.1,23.6,35.1,19.3,35.7,12.7,67.8,39.3,46.5,48.3,45.8,48.0,47.5,48.5,47.5,38.6,1600.0,16.00,16,16,16,35,74,560,1,66.3,67.0,1.337,1.000,1.375,68.235,7.600,1600.0,38.0,66.1,43.0,44.0,40.0,1.368,5.000,3.344,3.360,12.192,0.688,3.328,1.832,0.680,1.008,1.360,1.528,1248,1456,698,No,1.094,1.013,36.706,12.706,28,No,No,5951,176445,39,94.0,No,No,11884,24,0.0,0.0,0.0,0.000,0.000,211,2,5.5,0.1,5.5,12.300,0.260,24912,5251,59.0,62.0,912,22.000,55.000,1988.0,92.0,70.5,4.0,0.0,0.0,0.0,0.0,26.0,4863,1554,16.0,4906,319,39,36.323,13.136,0,0.893,0.869,6.000,19.646,5.213,1819.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:25:37.205,18914,20435,48.0,12956,19736,39.6,0.0,1.406,1.394,1.306,1.394,1.394,1.394,1.350,1.400,4775.1,4825.1,4750.1,3860.1,4800.1,4800.1,4800.1,3840.1,100.0,3132.1,2423.7,2565.9,3251.0,1984.1,1223.1,2687.1,1797.0,2304.8,1637.3,1734.2,1304.5,1899.5,880.0,1710.8,771.8,1956.7,61.9,47.2,55.2,64.4,38.0,19.0,47.8,40.4,44.7,36.1,36.8,25.7,38.6,10.4,36.1,11.6,64.4,38.4,47.8,48.3,47.5,38.6,48.0,48.0,48.0,38.4,1600.0,16.00,16,16,16,35,74,560,1,65.9,63.0,1.375,1.000,1.413,68.235,7.600,1600.0,38.0,65.9,43.0,44.0,40.0,1.376,5.000,3.328,3.376,12.192,0.688,3.328,1.832,0.680,1.008,1.360,1.536,1246,751,1359,No,1.094,1.013,31.765,14.824,28,No,No,5951,176445,39,94.0,No,No,11884,24,0.0,0.0,0.0,0.000,0.000,211,2,1.7,0.1,1.8,4.329,0.283,24923,5252,59.0,62.0,782,3.000,87.000,1992.0,98.0,70.2,7.0,0.0,0.0,0.0,0.0,23.0,4863,1554,16.0,4906,319,39,37.482,16.140,0,0.868,0.850,0.000,2.604,0.000,2125.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:25:39.775,18888,20460,48.0,12929,19764,39.5,0.0,1.325,1.350,1.288,1.413,1.394,1.425,1.331,1.413,4775.1,4850.1,4725.1,4800.1,4825.1,4825.1,4775.1,4825.1,100.0,2879.4,2684.5,2519.0,3211.8,1996.6,1171.8,2589.7,1819.3,2148.1,1501.7,1097.1,1904.2,1940.3,800.5,1828.5,863.3,1934.7,60.3,57.3,57.3,66.4,42.0,28.0,47.5,41.4,43.9,35.3,28.6,43.2,41.4,15.8,40.8,14.0,66.4,41.4,47.8,48.5,47.3,48.0,48.3,48.3,47.8,48.3,1600.0,16.00,16,16,16,35,74,560,1,65.8,66.0,1.412,1.000,1.438,40.941,7.200,1600.0,38.0,65.6,44.0,44.0,40.0,1.368,5.000,3.328,3.360,12.192,0.688,3.328,1.832,0.680,1.008,1.360,1.536,1250,3928,696,No,1.119,1.013,24.706,12.000,28,No,No,5951,176445,39,94.0,No,No,11884,24,0.0,0.0,0.0,0.000,0.000,211,2,0.6,0.2,0.8,1.762,0.510,24927,5253,60.0,64.0,639,12.000,37.000,1960.0,37.0,68.6,0.0,0.0,0.0,0.0,0.0,18.0,4863,1554,16.0,4906,319,39,38.124,17.887,0,0.968,0.956,5.750,11.616,5.498,969.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:25:42.344,18938,20411,48.1,12963,19729,39.6,0.0,1.400,1.288,1.406,1.363,1.400,1.319,1.400,1.225,4825.1,4775.1,3840.1,4675.1,4675.1,4825.1,4825.1,4625.1,100.0,2765.2,3083.3,2563.7,3325.8,2163.4,1215.1,2919.5,1902.5,2484.4,1524.8,1138.9,1995.0,2104.5,903.0,1858.3,706.6,2040.9,53.6,63.4,54.2,67.6,46.3,21.9,53.6,37.1,49.3,31.7,17.6,39.6,38.4,20.1,40.2,13.4,67.6,40.5,48.3,47.8,38.4,46.8,46.8,48.3,48.3,46.3,1600.0,16.00,16,16,16,35,74,560,1,66.0,66.0,1.287,1.000,1.313,46.400,7.200,1600.0,38.0,66.0,44.0,44.0,40.0,1.368,5.000,3.328,3.360,12.192,0.688,3.328,1.832,0.680,1.008,1.360,1.536,1247,751,696,No,1.081,1.013,33.882,14.118,28,No,No,5951,176445,39,94.0,No,No,11884,24,0.0,0.0,0.0,0.000,0.000,211,2,1.8,0.6,2.4,4.610,0.335,24938,5254,60.0,63.0,561,6.000,59.000,1958.0,24.0,70.0,2.0,0.0,0.0,0.0,0.0,16.0,4863,1554,16.0,4906,319,39,40.482,18.361,0,0.868,0.863,0.000,5.208,0.000,1138.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:25:44.900,18975,20374,48.2,13005,19688,39.7,0.0,1.413,1.331,1.419,1.319,1.406,1.331,1.425,1.388,4700.1,4725.1,4625.1,4725.1,4650.1,4800.1,4750.1,3860.1,100.0,3035.0,3028.0,2482.5,3473.3,2249.5,1282.0,3054.6,1934.8,2530.1,1590.9,1283.2,1881.4,2084.5,902.1,1939.8,853.6,2100.3,58.7,66.0,44.2,70.3,49.6,29.0,60.0,37.5,53.3,27.8,22.4,37.5,38.1,18.1,46.6,18.1,70.3,42.3,47.0,47.3,46.3,47.3,46.5,48.0,47.5,38.6,1600.0,16.00,16,16,16,35,74,560,1,66.6,66.3,1.362,1.000,1.394,63.686,8.000,1600.0,38.0,66.5,44.0,44.0,40.0,1.360,5.000,3.328,3.360,12.192,0.680,3.328,1.832,0.680,1.008,1.360,1.536,1255,746,1358,No,1.106,1.013,49.412,14.118,28,No,No,5951,176445,39,94.0,No,No,11884,24,0.0,0.0,0.0,0.000,0.000,211,2,1.5,0.1,1.6,3.911,0.257,24948,5255,60.0,67.0,514,8.000,121.000,2016.0,48.0,70.0,5.0,0.0,0.0,0.0,0.0,15.0,4863,1555,16.0,4906,319,39,40.332,18.427,0,0.868,0.856,0.250,6.944,0.214,2162.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:25:47.466,18958,20391,48.1,12986,19706,39.7,0.0,1.344,1.394,1.281,1.281,1.325,1.369,1.337,1.337,4650.1,4850.1,4650.1,4700.1,4800.1,4800.1,4800.1,4800.1,100.0,3266.5,2756.0,2647.1,3363.6,2272.6,1335.3,2990.1,2029.4,2611.3,1619.9,1266.4,1952.4,2167.3,946.7,1966.0,715.5,2119.1,57.0,50.9,56.4,68.7,40.4,29.4,58.2,41.1,52.1,32.5,20.2,36.8,44.7,18.4,40.4,10.4,68.7,41.1,46.5,48.5,46.5,47.0,48.0,48.0,48.0,48.0,1600.0,16.00,16,16,16,35,74,560,1,66.5,64.8,1.281,0.994,1.306,39.122,7.600,1600.0,38.0,66.6,44.0,44.0,40.0,1.336,5.000,3.328,3.360,12.192,0.680,3.328,1.832,0.680,1.008,1.360,1.536,1245,748,696,No,1.100,1.013,37.412,12.706,28,No,No,5951,176445,39,94.0,No,No,11884,24,0.0,0.0,0.0,0.000,0.000,211,2,1.0,0.1,1.1,2.634,0.257,24954,5255,62.0,70.0,547,26.000,46.000,1976.0,57.0,70.9,2.0,0.0,0.0,0.0,0.0,16.0,4863,1556,16.0,4906,319,40,40.336,18.660,0,1.200,1.169,10.250,31.200,11.980,1631.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:25:50.014,18974,20374,48.2,13004,19688,39.7,0.0,1.388,1.381,1.388,1.313,1.325,1.375,1.350,1.394,4675.1,4825.1,4650.1,4725.1,4650.1,4575.1,4725.1,4725.1,100.0,3143.8,2943.0,2813.8,3298.5,2351.8,1353.8,3003.1,1984.7,2672.1,1654.9,1292.8,1867.7,2173.1,924.8,2040.4,614.3,2133.3,61.8,58.1,61.2,64.8,47.2,29.6,61.2,37.5,55.1,35.7,23.6,35.1,41.2,23.1,43.6,12.7,64.8,43.2,46.8,48.3,46.5,47.3,46.5,45.8,47.3,47.3,1600.0,16.00,16,16,16,35,74,560,1,66.8,65.5,1.300,1.000,1.337,61.867,8.000,1600.0,38.0,66.8,44.0,44.0,40.0,1.368,5.000,3.328,3.360,12.192,0.680,3.328,1.832,0.680,1.008,1.360,1.536,1247,1473,695,No,1.081,1.013,42.353,12.706,28,No,No,5951,176445,41,94.0,No,No,11884,24,0.0,0.0,0.0,0.000,0.000,211,2,3.6,0.1,3.7,12.988,0.237,24986,5256,61.0,68.0,592,9.000,54.000,1946.0,12.0,70.7,1.0,0.0,0.0,0.0,0.0,17.0,4864,1556,16.0,4906,319,40,37.862,18.093,0,0.968,0.963,2.000,8.712,1.925,445.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:25:52.580,19006,20342,48.3,13037,19656,39.8,0.0,1.400,1.281,1.381,1.319,1.350,1.263,1.325,1.263,4825.1,4775.1,3840.1,4800.1,4800.1,4650.1,3840.1,4700.1,100.0,3093.2,2692.5,2693.4,3227.8,2094.1,1161.1,2777.0,1776.8,2428.7,1466.3,1194.6,1797.5,1998.1,800.3,1895.6,628.7,1982.9,58.8,50.9,53.3,69.9,43.5,29.4,57.6,37.4,49.6,32.5,19.0,33.1,39.8,17.6,38.6,12.8,69.9,40.2,48.3,47.8,38.4,48.0,48.0,46.5,38.4,47.0,1600.0,16.00,16,16,16,35,74,560,1,66.6,63.0,1.394,1.000,1.425,57.318,8.400,1600.0,38.0,66.6,44.0,44.0,40.0,1.376,5.000,3.328,3.360,12.192,0.680,3.328,1.832,0.680,1.008,1.360,1.536,1254,752,695,No,1.100,1.013,29.647,14.824,28,No,No,5951,176445,39,94.0,No,No,11884,24,0.0,0.0,0.0,0.000,0.000,211,2,4.1,0.1,4.2,14.210,0.252,25020,5256,62.0,68.0,618,9.000,45.000,1966.0,17.0,71.1,1.0,0.0,0.0,0.0,0.0,18.0,4864,1557,16.0,4906,319,40,36.502,18.807,0,0.968,0.988,2.000,8.712,1.975,1001.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:25:55.147,18993,20355,48.2,13028,19665,39.8,0.0,1.344,1.281,1.413,1.344,1.406,1.269,1.406,1.325,4825.1,4675.1,3880.1,4825.1,3880.1,4750.1,3860.1,4775.1,100.0,3588.5,2120.9,2592.4,3149.6,1915.8,1158.5,2792.7,1707.5,2363.7,1394.3,1738.5,1253.6,1920.3,846.3,1744.1,712.4,1937.4,74.3,41.4,59.1,63.4,43.9,19.5,54.8,39.0,48.7,31.0,33.5,23.1,33.5,21.3,40.2,11.5,74.3,39.9,48.3,46.8,38.8,48.3,38.8,47.5,38.6,47.8,1600.0,16.00,16,16,16,35,74,560,1,66.5,65.0,1.406,0.994,1.438,61.867,8.000,1600.0,38.0,66.5,44.0,44.0,40.0,1.376,5.000,3.328,3.360,12.192,0.680,3.328,1.832,0.680,1.008,1.360,1.536,1250,752,696,No,1.087,1.013,28.941,15.529,28,No,No,5951,176445,39,94.0,No,No,11884,24,0.0,0.0,0.0,0.000,0.000,211,2,2.1,0.3,2.3,5.248,0.502,25033,5258,62.0,71.0,628,5.000,65.000,1974.0,21.0,70.8,1.0,0.0,0.0,0.0,0.0,18.0,4864,1557,16.0,4906,319,40,37.398,19.795,0,0.868,0.863,0.250,4.340,0.216,1052.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:25:57.706,19001,20347,48.2,13040,19653,39.8,0.0,1.363,1.375,1.388,1.388,1.381,1.394,1.394,1.388,4650.1,4800.1,4675.1,4750.1,4650.1,4800.1,4625.1,4800.1,100.0,3573.0,2366.9,2711.4,3421.2,2224.8,1248.1,3063.3,1954.2,2624.7,1634.5,1894.0,1307.1,2148.9,944.7,1988.8,763.1,2116.8,70.1,43.9,51.8,73.7,43.2,28.0,54.2,38.4,51.2,31.0,39.0,28.6,44.5,20.1,39.0,12.1,73.7,41.8,46.5,48.0,46.8,47.5,46.5,48.0,46.3,48.0,1600.0,16.00,16,16,16,35,74,560,1,66.6,66.5,1.362,1.000,1.400,64.596,8.000,1600.0,38.0,66.6,44.0,44.0,40.0,1.376,5.000,3.328,3.360,12.192,0.672,3.328,1.832,0.680,1.008,1.360,1.528,1246,1525,1350,No,1.106,1.013,45.882,12.706,28,No,No,5951,176445,39,94.0,No,No,11884,24,0.0,0.0,0.0,0.000,0.000,211,2,5.0,0.1,5.0,16.456,0.240,25073,5258,63.0,71.0,656,12.000,55.000,1976.0,24.0,72.6,1.0,0.0,0.0,0.0,0.0,19.0,4866,1558,16.0,4906,319,40,34.942,18.344,0,1.081,1.131,5.500,12.972,6.222,1182.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:26:0.270,19023,20326,48.3,13073,19620,39.9,0.0,1.375,1.381,1.394,1.388,1.294,1.406,1.281,1.400,4800.1,4750.1,3840.1,4800.1,4750.1,4800.1,4650.1,3840.1,100.0,3025.3,3113.5,2651.0,3472.6,2204.1,1356.9,2977.2,1999.9,2599.3,1642.9,1851.3,1401.8,2197.4,934.4,2086.6,736.6,2140.7,57.9,67.0,53.0,73.7,45.1,29.2,60.3,43.9,47.5,30.4,31.0,29.2,45.7,17.6,43.2,12.8,73.7,43.0,48.0,47.5,38.4,48.0,47.5,48.0,46.5,38.4,1600.0,16.00,16,16,16,35,74,560,1,67.0,66.0,1.319,0.994,1.350,61.867,7.600,1600.0,38.0,67.0,44.0,44.0,40.0,1.376,5.000,3.328,3.360,12.192,0.672,3.328,1.832,0.680,1.008,1.360,1.536,1254,751,695,No,1.100,1.013,36.000,16.235,28,No,No,5951,176445,39,94.0,No,No,11884,24,0.0,0.0,0.0,0.000,0.000,211,2,3.2,0.1,3.3,10.801,0.239,25100,5259,64.0,73.0,696,7.000,149.000,1988.0,98.0,72.8,8.0,0.0,0.0,0.0,0.0,20.0,4867,1558,16.0,4906,320,40,35.178,18.996,0,0.868,0.825,0.000,6.076,0.000,2531.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:26:2.840,19046,20302,48.4,13084,19608,40.0,0.0,1.375,1.344,1.413,1.400,1.394,1.394,1.406,1.313,4700.1,4650.1,3840.1,3840.1,4700.1,4800.1,4800.1,4800.1,100.0,2918.4,3151.4,2669.6,3297.0,2166.4,1245.2,2959.2,1947.6,2555.1,1573.9,1869.9,1327.3,2148.5,924.4,1973.6,782.3,2094.4,60.9,65.2,57.3,67.6,50.6,23.1,54.2,45.7,47.5,34.1,37.1,30.4,46.9,23.1,44.5,18.9,67.6,44.2,47.0,46.5,38.4,38.4,47.0,48.0,48.0,48.0,1600.0,16.00,16,16,16,35,74,560,1,67.0,63.8,1.281,0.994,1.306,46.400,7.200,1600.0,38.0,67.0,44.0,44.0,40.0,1.360,5.000,3.328,3.360,12.192,0.672,3.328,1.832,0.672,1.008,1.360,1.528,1250,753,696,No,1.081,1.013,35.294,14.824,28,No,No,5951,176445,39,94.0,No,No,11884,24,0.0,0.0,0.0,0.000,0.000,211,2,3.4,0.1,3.5,10.395,0.281,25125,5259,64.0,69.0,741,10.000,59.000,1958.0,47.0,73.4,2.0,0.0,0.0,0.0,0.0,21.0,4868,1558,16.0,4906,320,40,34.870,18.201,0,0.968,0.956,2.000,9.680,1.913,1468.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:26:5.398,19055,20294,48.4,13096,19596,40.0,0.0,1.275,1.275,1.281,1.425,1.281,1.369,1.388,1.425,4600.1,4600.1,4700.1,4800.1,4800.1,4700.1,4675.1,4700.1,100.0,3256.2,2783.7,2693.0,3373.4,2225.2,1266.8,2990.8,1917.3,2607.8,1590.5,1944.9,1330.4,2144.3,880.0,2070.4,739.8,2113.4,68.4,55.1,57.5,68.4,49.0,28.4,61.2,38.7,52.7,31.5,43.6,29.0,46.6,12.1,47.8,9.6,68.4,43.7,46.0,46.0,47.0,48.0,48.0,47.0,46.8,47.0,1600.0,16.00,16,16,16,35,74,560,1,67.3,66.5,1.400,1.000,1.425,40.941,7.200,1600.0,38.0,67.1,45.0,44.0,40.0,1.376,5.000,3.328,3.360,12.096,0.672,3.328,1.832,0.672,1.008,1.360,1.536,1244,3928,696,No,1.113,1.013,35.294,14.824,28,No,No,5951,176445,39,94.0,No,No,11884,24,0.0,0.0,0.0,0.000,0.000,211,2,5.8,0.1,5.9,19.969,0.318,25174,5260,64.0,68.0,773,23.000,57.000,1988.0,86.0,75.0,7.0,0.0,0.0,0.0,0.0,22.0,4869,1558,16.0,4906,320,40,34.615,18.915,0,0.956,0.925,9.000,21.988,8.325,2004.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:26:7.954,19057,20292,48.4,13102,19590,40.0,0.0,1.406,1.388,1.388,1.388,1.375,1.375,1.300,1.375,4800.1,4725.1,4775.1,4725.1,4775.1,4650.1,4725.1,4625.1,100.0,3243.6,2804.5,2805.2,3349.8,2267.5,1263.6,3094.8,1973.2,2592.0,1632.0,1980.1,1293.6,2190.6,875.0,2042.5,807.3,2138.5,59.5,52.7,53.3,64.4,42.9,21.4,53.3,35.5,48.4,30.6,33.1,22.6,40.4,14.7,39.2,13.4,64.4,39.1,48.0,47.3,47.8,47.3,47.8,46.5,47.3,46.3,1600.0,16.00,16,16,16,35,74,560,1,67.5,67.3,1.369,1.000,1.388,36.392,6.800,1600.0,39.0,67.4,45.0,44.0,40.0,1.360,5.000,3.344,3.360,12.192,0.672,3.328,1.832,0.672,1.008,1.360,1.536,1248,748,696,No,1.119,1.013,50.824,14.118,28,No,No,5951,176445,39,94.0,No,No,11884,24,0.0,0.0,0.0,0.000,0.000,211,2,2.5,0.1,2.6,8.388,0.230,25195,5261,64.0,70.0,784,14.000,44.000,1964.0,19.0,76.4,0.0,0.0,0.0,0.0,0.0,23.0,4871,1558,16.0,4906,320,40,34.585,17.934,0,1.037,1.025,5.250,14.518,5.381,992.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:26:10.525,19066,20283,48.4,13110,19583,40.1,0.0,1.331,1.388,1.319,1.381,1.388,1.388,1.381,1.400,4750.1,4800.1,4775.1,4775.1,4775.1,4750.1,3820.1,3840.1,100.0,2876.6,3230.5,2703.5,3270.0,2158.9,1401.8,2896.6,1916.1,2453.9,1696.9,1415.1,1718.3,2220.0,911.2,1890.1,667.3,2089.2,55.4,62.8,56.0,61.5,45.7,27.4,55.4,33.5,46.9,34.1,28.6,31.7,41.4,20.1,35.3,12.8,62.8,40.5,47.5,48.0,47.8,47.8,47.8,47.5,38.2,38.4,1600.0,16.00,16,16,16,35,74,560,1,67.1,69.5,1.337,0.994,1.356,41.851,8.400,1600.0,39.0,67.3,45.0,44.0,40.0,1.384,5.000,3.328,3.360,12.096,0.664,3.328,1.832,0.672,1.008,1.360,1.536,1243,1535,697,No,1.106,1.013,50.824,13.412,28,No,No,5951,176445,39,94.0,No,No,11884,24,0.0,0.0,0.0,0.000,0.000,211,2,2.4,0.1,2.5,7.401,0.257,25213,5261,64.0,70.0,765,5.000,108.000,2016.0,99.0,73.4,8.0,0.0,0.0,0.0,0.0,22.0,4871,1560,16.0,4907,320,40,33.510,18.345,0,0.868,0.844,0.250,4.340,0.211,2314.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:26:13.088,19058,20291,48.4,13127,19566,40.1,0.0,1.363,1.394,1.337,1.369,1.369,1.406,1.275,1.388,4800.1,4775.1,4800.1,4675.1,4650.1,4800.1,4775.1,4800.1,100.0,3144.8,3071.2,2856.7,3412.7,2387.9,1424.8,3076.5,2151.2,2749.1,1857.9,1380.7,1939.2,2381.6,1051.2,2062.3,866.2,2238.4,63.6,54.5,56.9,64.8,46.0,21.2,62.4,43.0,48.4,29.6,23.0,39.3,47.2,21.2,40.6,13.3,64.8,42.2,48.0,47.8,48.0,46.8,46.5,48.0,47.8,48.0,1600.0,16.00,16,16,16,35,74,560,1,67.3,67.5,1.369,0.994,1.400,53.678,8.000,1600.0,38.0,67.3,45.0,44.0,40.0,1.352,5.000,3.328,3.360,12.192,0.664,3.328,1.832,0.672,1.008,1.360,1.536,1253,1472,696,No,1.106,1.013,40.235,12.706,28,No,No,5951,176445,39,94.0,No,No,11884,24,0.0,0.0,0.0,0.000,0.000,211,2,3.5,0.1,3.6,10.478,0.230,25238,5262,65.0,70.0,716,24.000,37.000,1972.0,61.0,75.0,1.0,0.0,0.0,0.0,0.0,21.0,4871,1562,16.0,4907,320,40,30.023,18.532,0,1.087,1.063,9.750,26.088,10.359,1362.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:26:15.646,19044,20305,48.3,13110,19582,40.1,0.0,1.281,1.406,1.263,1.400,1.275,1.413,1.337,1.406,4625.1,4850.1,4700.1,4675.1,4600.1,4800.1,4675.1,3880.1,100.0,3526.0,2991.8,3055.2,3558.5,2507.7,1599.6,3141.6,2410.1,2815.9,1998.3,1466.2,2067.5,2613.7,1189.1,2311.7,895.0,2384.2,73.0,61.9,63.1,74.8,51.5,34.3,63.1,50.3,60.7,36.8,30.0,46.6,57.6,25.1,48.4,17.7,74.8,49.7,46.3,48.5,47.0,46.8,46.0,48.0,46.8,38.8,1600.0,16.00,16,16,16,35,74,560,1,67.1,67.3,1.331,0.994,1.356,41.851,8.000,1600.0,38.0,67.1,45.0,44.0,40.0,1.360,5.000,3.328,3.360,12.192,0.664,3.328,1.832,0.672,1.008,1.360,1.528,1244,753,696,No,1.106,1.013,30.353,12.706,29,No,No,5951,176445,39,94.0,No,No,11884,24,0.0,0.0,0.0,0.000,0.000,211,2,2.4,0.1,2.4,6.890,0.227,25255,5263,66.0,74.0,694,25.000,56.000,1978.0,53.0,77.3,1.0,0.0,0.0,0.0,0.0,20.0,4871,1564,16.0,4907,320,40,30.454,17.808,0,1.200,1.175,10.250,30.000,12.044,1331.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:26:18.213,19095,20254,48.5,13135,19557,40.1,0.0,1.263,1.381,1.369,1.400,1.363,1.431,1.300,1.363,4750.1,4675.1,4800.1,4725.1,4650.1,4850.1,4800.1,4725.1,100.0,3226.6,3246.3,2949.0,3545.0,2468.3,1482.8,3191.6,2298.8,2777.2,1870.0,1341.5,2044.6,2461.3,1013.0,2227.6,843.8,2311.7,70.7,68.9,64.6,73.1,54.2,36.5,67.0,51.8,59.7,42.6,28.0,45.7,53.0,21.3,49.3,18.2,73.1,50.3,47.5,46.8,48.0,47.3,46.5,48.5,48.0,47.3,1600.0,16.00,16,16,16,35,74,560,1,67.4,64.5,1.300,1.000,1.381,45.490,7.600,1600.0,38.0,67.4,45.0,44.0,40.0,1.360,5.000,3.328,3.360,12.192,0.664,3.328,1.832,0.672,1.008,1.360,1.528,1246,1457,696,No,1.119,1.013,55.059,14.118,29,No,No,5951,176445,39,94.0,No,No,11884,24,0.0,0.0,0.0,0.000,0.000,211,2,4.4,0.1,4.4,17.772,0.153,25299,5263,66.0,74.0,730,9.000,82.000,1986.0,96.0,77.5,2.0,0.0,0.0,0.0,0.0,21.0,4871,1569,16.0,4907,320,40,31.498,17.114,0,0.968,0.950,2.000,8.712,1.900,2632.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:26:20.774,19051,20297,48.4,13108,19585,40.0,0.0,1.388,1.356,1.363,1.356,1.331,1.369,1.381,1.375,4750.1,4750.1,4775.1,4750.1,4725.1,4775.1,4750.1,4750.1,100.0,3298.7,3378.6,2974.8,3679.8,2502.8,1685.4,3206.5,2444.9,2847.6,2047.5,1414.3,2192.8,2594.1,1245.4,2374.1,991.5,2429.9,68.2,75.6,66.4,76.8,51.8,37.1,67.0,58.5,59.7,47.5,28.6,50.6,57.3,32.3,56.7,23.1,76.8,53.6,47.5,47.5,47.8,47.5,47.3,47.8,47.5,47.5,1600.0,16.00,16,16,16,35,74,560,1,67.5,67.0,1.369,0.994,1.394,44.580,7.200,1600.0,39.0,67.4,45.0,45.0,40.0,1.352,5.000,3.328,3.360,12.096,0.664,3.328,1.832,0.672,1.008,1.360,1.528,1251,753,1350,No,1.106,1.019,43.765,14.118,29,No,No,5951,176445,39,94.0,No,No,11884,24,0.0,0.0,0.0,0.000,0.000,211,2,4.5,0.1,4.5,15.385,0.233,25336,5263,67.0,74.0,781,14.000,56.000,1944.0,26.0,79.4,1.0,0.0,0.0,0.0,0.0,22.0,4872,1569,16.0,4907,320,40,30.946,18.605,0,0.968,1.100,6.000,13.552,6.600,1171.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:26:23.335,19094,20255,48.5,13155,19538,40.2,0.0,1.344,1.381,1.388,1.381,1.369,1.256,1.369,1.319,4750.1,4775.1,4775.1,4775.1,4700.1,4650.1,4775.1,4725.1,100.0,3615.8,2916.0,2840.8,3605.8,2461.7,1545.6,3126.2,2355.1,2728.7,1948.2,1381.6,2117.7,2458.4,1222.7,2266.4,957.8,2346.8,72.5,59.7,61.5,72.5,52.4,27.4,61.5,53.0,53.6,45.7,34.1,43.2,50.0,25.6,47.5,23.1,72.5,49.0,47.5,47.8,47.8,47.8,47.0,46.5,47.8,47.3,1600.0,16.00,16,16,16,35,74,560,1,67.3,65.8,1.381,0.994,1.406,36.392,6.800,1600.0,39.0,67.3,45.0,45.0,40.0,1.344,5.000,3.328,3.360,12.192,0.664,3.328,1.832,0.672,1.008,1.360,1.528,1247,3928,696,No,1.106,1.013,38.118,12.706,29,No,No,5951,176445,39,94.0,No,No,11884,24,0.0,0.0,0.0,0.000,0.000,211,2,5.2,0.0,5.3,15.111,0.204,25373,5264,67.0,76.0,847,35.000,69.000,1986.0,54.0,78.0,3.0,0.0,0.0,0.0,0.0,24.0,4873,1572,16.0,4907,320,40,31.535,17.806,0,1.200,1.125,10.750,42.000,12.094,1508.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:26:25.896,19095,20253,48.5,13180,19513,40.3,0.0,1.413,1.363,1.275,1.325,1.288,1.394,1.350,1.400,4850.1,4700.1,4650.1,4625.1,4775.1,4675.1,4750.1,4800.1,100.0,3563.7,2649.8,2834.3,3451.3,2358.0,1436.6,3036.2,2162.7,2740.8,1804.0,1778.7,1569.5,2330.7,1070.1,2174.5,805.5,2235.4,67.6,52.4,62.1,65.2,43.2,28.0,58.5,42.6,53.6,38.4,36.5,31.7,46.3,26.8,39.6,15.8,67.6,44.3,48.5,47.0,46.5,46.3,47.8,46.8,47.5,48.0,1600.0,16.00,16,16,16,35,74,560,1,67.4,64.8,1.394,1.000,1.425,43.671,7.200,1600.0,39.0,67.4,45.0,45.0,40.0,1.360,5.000,3.328,3.360,12.096,0.656,3.328,1.832,0.672,1.008,1.360,1.528,1254,752,1358,No,1.119,1.013,50.824,14.118,29,No,No,5951,176445,39,94.0,No,No,11884,24,0.0,0.0,0.0,0.000,0.000,211,2,5.1,0.1,5.1,14.536,0.305,25409,5265,67.0,75.0,901,4.000,124.000,2000.0,41.0,76.7,4.0,0.0,0.0,0.0,0.0,26.0,4873,1572,16.0,4907,320,40,31.547,19.035,0,0.868,0.856,0.250,3.472,0.214,1420.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:26:28.462,19100,20248,48.5,13165,19527,40.2,0.0,1.331,1.381,1.425,1.325,1.356,1.256,1.419,1.319,4750.1,4825.1,4825.1,4675.1,4625.1,4700.1,4750.1,4775.1,100.0,3223.8,3113.7,3092.5,3195.0,2449.1,1591.3,3121.7,2200.2,2796.4,1930.3,2033.1,1344.6,2428.7,1246.3,2233.9,935.5,2308.5,68.2,60.9,64.6,64.6,45.1,30.4,59.7,46.9,53.6,45.7,45.1,26.8,46.9,25.6,45.7,17.0,68.2,46.7,47.5,48.3,48.3,46.8,46.3,47.0,47.5,47.8,1600.0,16.00,16,16,16,35,74,560,1,68.9,68.0,1.375,0.994,1.400,48.220,7.600,1600.0,39.0,69.0,45.0,45.0,40.0,1.360,5.000,3.328,3.360,12.096,0.656,3.328,1.832,0.672,1.008,1.360,1.528,1243,1521,1351,No,1.106,1.013,26.824,14.824,29,No,No,5951,176445,39,94.0,No,No,11884,24,0.0,0.0,0.0,0.000,0.000,211,2,5.0,0.1,5.1,17.251,0.400,25451,5266,67.0,75.0,909,8.000,127.000,2010.0,53.0,77.1,5.0,0.0,0.0,0.0,0.0,26.0,4873,1572,16.0,4907,320,40,33.738,17.952,0,0.868,0.850,0.250,6.944,0.212,1751.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:26:31.026,19135,20213,48.6,13210,19483,40.4,0.0,1.375,1.381,1.419,1.325,1.344,1.400,1.300,1.413,4800.1,4700.1,4800.1,4600.1,4775.1,4825.1,4800.1,3860.1,100.0,2934.2,3048.5,2855.9,3199.1,2178.7,1333.9,2895.1,1961.6,2470.2,1692.1,1982.1,1270.9,2216.2,1017.2,2001.8,746.5,2112.7,57.9,60.9,57.9,64.6,39.0,30.4,56.0,37.8,45.7,32.3,37.1,24.3,44.5,20.7,44.5,11.5,64.6,41.6,48.0,47.0,48.0,46.0,47.8,48.3,48.0,38.6,1600.0,16.00,16,16,16,35,74,560,1,68.3,66.0,1.275,1.000,1.294,40.941,7.200,1600.0,39.0,68.3,45.0,45.0,40.0,1.376,5.000,3.328,3.360,12.192,0.656,3.328,1.832,0.664,1.008,1.360,1.528,1285,746,696,No,1.100,1.013,45.176,14.118,29,No,No,5951,176445,41,94.0,No,No,11884,24,0.0,0.0,0.0,0.000,0.000,211,2,4.4,0.1,4.5,14.696,0.357,25487,5267,67.0,76.0,910,8.000,142.000,2030.0,82.0,72.4,8.0,0.0,0.0,0.0,0.0,26.0,4874,1574,16.0,4907,321,40,34.193,19.168,0,1.200,0.950,1.750,9.600,1.662,2366.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:26:33.586,19148,20201,48.6,13220,19473,40.4,0.0,1.369,1.325,1.406,1.325,1.400,1.300,1.394,1.313,4700.1,4775.1,4775.1,4575.1,4825.1,4775.1,3860.1,4675.1,100.0,3445.1,2982.7,2803.3,3600.9,2429.9,1505.8,3197.7,2239.4,2752.6,1928.8,2033.5,1434.6,2481.1,1242.5,2315.9,855.8,2328.1,69.0,60.0,56.3,70.3,48.4,31.5,63.6,47.2,57.5,43.0,44.8,27.2,49.0,27.2,47.8,14.5,70.3,47.3,47.0,47.8,47.8,45.8,48.3,47.8,38.6,46.8,1600.0,16.00,16,16,16,35,74,560,1,68.1,70.5,1.412,0.994,1.438,40.941,7.200,1600.0,39.0,68.1,46.0,45.0,40.0,1.336,5.000,3.328,3.360,12.096,0.656,3.328,1.832,0.664,1.008,1.360,1.528,1343,752,696,No,1.119,1.013,28.235,12.000,29,No,No,5951,176445,39,94.0,No,No,11884,24,0.0,0.0,0.0,0.000,0.000,211,2,2.1,0.1,2.2,5.816,0.360,25501,5267,67.0,75.0,912,8.000,97.000,2010.0,42.0,73.1,3.0,0.0,0.0,0.0,0.0,26.0,4874,1577,16.0,4907,321,40,33.093,18.248,0,0.868,0.856,0.250,6.944,0.214,1548.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:26:36.155,19146,20203,48.6,13232,19460,40.4,0.0,1.369,1.406,1.306,1.413,1.300,1.413,1.381,1.356,4675.1,4800.1,4575.1,4700.1,4575.1,4825.1,4675.1,3860.1,100.0,3362.8,3327.2,2953.1,3707.8,2526.8,1726.4,3210.1,2469.2,2875.6,2109.2,1951.3,1688.4,2586.5,1334.3,2450.3,965.0,2452.8,73.6,71.7,65.6,79.1,56.4,38.0,63.1,56.4,58.2,42.3,47.2,38.6,52.1,30.6,55.8,20.2,79.1,53.1,46.8,48.0,45.8,47.0,45.8,48.3,46.8,38.6,1600.0,16.00,16,16,16,35,74,560,1,67.9,64.5,1.275,1.000,1.319,60.047,8.400,1600.0,39.0,67.9,46.0,45.0,40.0,1.376,5.000,3.328,3.360,12.192,0.656,3.328,1.832,0.664,1.008,1.360,1.536,1376,1537,1352,No,1.094,1.013,39.529,13.412,29,No,No,5951,176445,39,94.0,No,No,11884,24,0.0,0.0,0.0,0.000,0.000,211,2,3.1,0.1,3.2,8.362,0.390,25521,5268,67.0,75.0,912,10.000,65.000,1944.0,48.0,73.3,1.0,0.0,0.0,0.0,0.0,26.0,4875,1577,16.0,4907,321,40,30.917,18.332,0,0.968,0.956,2.000,9.680,1.913,1361.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:26:38.720,19155,20194,48.6,13242,19451,40.5,0.0,1.400,1.394,1.419,1.256,1.356,1.375,1.413,1.256,4650.1,4825.1,3840.1,4725.1,4650.1,4850.1,3860.1,4725.1,100.0,2931.7,3582.8,2869.7,3596.2,2465.2,1538.1,3141.4,2305.1,2833.3,1939.7,1905.0,1546.6,2436.6,1167.4,2335.3,829.6,2339.0,63.0,76.9,60.6,74.5,52.7,29.0,71.5,51.5,59.3,36.3,36.3,36.3,47.2,23.0,53.3,15.1,76.9,49.2,46.5,48.3,38.4,47.3,46.5,48.5,38.6,47.3,1600.0,16.00,16,16,16,35,74,560,1,68.0,64.8,1.375,0.994,1.394,36.392,6.800,1600.0,39.0,68.0,46.0,45.0,40.0,1.352,5.000,3.328,3.360,12.192,0.656,3.328,1.832,0.664,1.008,1.360,1.536,1384,761,1360,No,1.119,1.013,56.471,13.412,29,No,No,5951,176445,39,94.0,No,No,11884,24,0.0,0.0,0.0,0.000,0.000,211,2,3.5,0.6,4.1,11.189,0.381,25549,5269,67.0,74.0,912,11.000,59.000,1944.0,23.0,69.4,1.0,0.0,0.0,0.0,0.0,26.0,4875,1577,16.0,4907,321,40,29.508,18.090,0,0.968,1.188,3.250,10.648,3.859,1110.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:26:41.287,19171,20177,48.7,13253,19440,40.5,0.0,1.331,1.369,1.438,1.331,1.431,1.294,1.431,1.344,4850.1,4700.1,3880.1,4700.1,3880.1,4650.1,3880.1,4650.1,100.0,3338.8,3097.9,2894.2,3543.9,2412.9,1427.2,3057.9,2256.6,2703.8,1960.3,1628.8,1794.1,2399.6,1181.8,2247.3,922.9,2304.3,66.4,64.0,62.8,72.5,50.0,26.2,65.2,45.7,54.8,43.2,30.4,35.9,50.6,24.3,53.0,19.5,72.5,47.8,48.5,47.0,38.8,47.0,38.8,46.5,38.8,46.5,1600.0,16.00,16,16,16,35,74,560,1,67.9,65.3,1.444,1.000,1.469,40.941,6.800,1600.0,39.0,67.9,46.0,45.0,40.0,1.336,5.000,3.328,3.360,12.192,0.648,3.328,1.832,0.664,1.008,1.360,1.536,1390,762,1351,No,1.106,1.013,39.529,14.118,29,No,No,5951,176445,39,94.0,No,No,11884,24,0.0,0.0,0.0,0.000,0.000,211,2,3.0,0.1,3.1,8.342,0.256,25569,5270,68.0,76.0,912,10.000,82.000,1972.0,29.0,70.2,3.0,0.0,0.0,0.0,0.0,26.0,4940,1577,16.0,4971,321,41,29.621,17.989,0,0.968,0.956,2.000,9.680,1.913,1295.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:26:43.845,19266,20082,48.9,13293,19399,40.6,0.0,1.331,1.400,1.350,1.394,1.294,1.400,1.406,1.400,4700.1,4650.1,4825.1,4725.1,4750.1,4625.1,4725.1,4800.1,100.0,3647.5,2731.2,3031.1,3426.6,2502.8,1579.0,3141.2,2349.1,2848.8,1979.1,1468.4,2013.7,2454.3,1234.7,2354.0,934.5,2356.0,75.6,54.8,65.2,70.1,50.0,35.3,56.7,48.7,56.7,40.2,29.8,43.2,53.6,30.4,51.8,15.2,75.6,48.6,47.0,46.5,48.3,47.3,47.5,46.3,47.3,48.0,1600.0,16.00,16,16,16,35,74,560,1,67.8,64.0,1.281,1.000,1.319,61.867,8.000,1600.0,39.0,67.8,46.0,45.0,40.0,1.360,5.000,3.328,3.360,12.192,0.648,3.328,1.832,0.664,1.008,1.360,1.528,1393,761,696,No,1.081,1.013,48.000,14.824,29,No,No,5951,176445,41,94.0,No,No,11884,24,0.0,0.0,0.0,0.000,0.000,211,2,3.6,0.1,3.7,10.098,0.287,25594,5271,67.0,76.0,932,18.000,142.000,1988.0,99.0,72.2,6.0,0.0,0.0,0.0,0.0,27.0,4941,1577,16.0,4971,321,41,28.953,17.934,0,1.200,1.150,2.250,21.600,2.587,2584.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:26:46.393,19246,20102,48.9,13275,19418,40.6,0.0,1.256,1.394,1.225,1.375,1.231,1.356,1.269,1.363,4650.1,4800.1,4600.1,4825.1,4650.1,4800.1,4550.1,4800.1,100.0,3252.6,2983.5,2860.7,3393.1,2347.8,1506.1,2988.0,2270.6,2649.8,1849.9,1415.5,1941.8,2368.9,1109.1,2155.6,879.1,2248.3,67.6,65.2,62.8,70.1,51.8,32.3,58.5,50.6,59.7,43.9,34.1,42.0,47.5,23.1,42.0,17.6,70.1,48.1,46.5,48.0,46.0,48.3,46.5,48.0,45.5,48.0,1600.0,16.00,16,16,16,35,74,560,1,67.5,65.5,1.306,1.000,1.344,65.506,8.000,1600.0,39.0,67.5,46.0,45.0,40.0,1.360,5.000,3.328,3.360,12.192,0.648,3.328,1.832,0.664,1.008,1.360,1.536,1397,761,696,No,1.094,1.013,36.706,14.824,29,No,No,5951,176445,39,94.0,No,No,11884,24,0.0,0.0,0.0,0.000,0.000,211,2,2.5,0.1,2.5,7.394,0.256,25612,5271,67.0,75.0,936,8.000,114.000,1988.0,94.0,71.9,6.0,0.0,0.0,0.0,0.0,27.0,4941,1577,16.0,4971,321,41,30.107,18.020,0,1.200,1.150,6.250,9.600,7.187,2440.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:26:48.943,19253,20096,48.9,13295,19398,40.6,0.0,1.325,1.281,1.419,1.337,1.356,1.300,1.425,1.288,4800.1,4750.1,3840.1,4675.1,4825.1,4700.1,4775.1,4775.1,100.0,3155.5,3169.2,2810.9,3479.5,2385.8,1479.9,3007.3,2217.4,2774.3,1851.1,1328.3,1990.4,2224.2,1098.6,2115.7,782.1,2241.9,59.5,66.2,58.8,68.0,48.4,31.9,59.5,46.0,53.3,40.4,23.3,39.2,43.5,23.3,43.5,10.4,68.0,44.7,48.0,47.5,38.4,46.8,48.3,47.0,47.8,47.8,1600.0,16.00,16,16,16,35,74,560,1,67.4,62.8,1.381,1.000,1.413,50.039,7.200,1600.0,39.0,67.4,46.0,45.0,40.0,1.352,5.000,3.328,3.360,12.096,0.648,3.328,1.832,0.664,1.008,1.360,1.536,1388,762,697,No,1.081,1.013,26.824,14.824,29,No,No,5951,176445,39,94.0,No,No,11884,24,0.0,0.0,0.0,0.000,0.000,211,2,5.1,0.1,5.1,13.471,0.266,25645,5272,68.0,75.0,917,10.000,62.000,1944.0,23.0,68.9,1.0,0.0,0.0,0.0,0.0,26.0,4943,1577,16.0,4971,321,41,29.739,18.866,0,0.968,0.956,2.250,9.680,2.152,1166.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:26:51.509,19292,20056,49.0,13329,19364,40.7,0.0,1.350,1.288,1.425,1.319,1.388,1.300,1.400,1.281,4800.1,4575.1,4800.1,4750.1,4700.1,4725.1,4825.1,4675.1,100.0,3349.7,2978.8,2747.6,3594.2,2438.5,1533.0,3114.5,2227.3,2866.2,1884.0,1342.4,2016.1,2289.9,1150.5,2140.5,829.8,2281.4,63.1,61.3,52.7,73.6,50.3,29.4,61.9,42.9,57.6,36.1,23.9,38.0,41.7,24.5,38.0,20.2,73.6,44.7,48.0,45.8,48.0,47.5,47.0,47.3,48.3,46.8,1600.0,16.00,16,16,16,35,74,560,1,67.6,64.8,1.375,0.994,1.306,61.867,8.000,1600.0,39.0,67.4,46.0,45.0,40.0,1.336,5.000,3.328,3.360,12.192,0.648,3.328,1.832,0.664,1.008,1.376,1.536,1388,762,1359,No,1.094,1.013,44.471,13.412,29,No,No,5951,176445,39,94.0,No,No,11884,25,0.0,0.0,0.0,0.000,0.000,211,2,2.2,0.1,2.3,5.903,0.256,25659,5273,68.0,75.0,856,10.000,53.000,2000.0,19.0,72.0,1.0,0.0,0.0,0.0,0.0,25.0,4945,1577,16.0,4971,321,41,33.067,18.717,0,0.968,0.963,2.250,9.680,2.166,1049.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:26:54.070,19299,20050,49.0,13344,19349,40.8,0.0,1.406,1.388,1.419,1.313,1.400,1.319,1.375,1.350,4800.1,4800.1,3840.1,4800.1,4800.1,4775.1,4700.1,4800.1,100.0,3432.4,2742.4,2709.9,3531.6,2243.2,1492.7,3003.7,2176.4,2519.6,1807.2,1288.0,2026.9,2187.7,1100.5,2044.9,850.5,2197.4,67.0,56.0,53.6,71.3,45.1,27.4,58.5,45.7,52.4,37.1,20.7,39.6,51.2,21.9,45.7,13.4,71.3,44.2,48.0,48.0,38.4,48.0,48.0,47.8,47.0,48.0,1600.0,16.00,16,16,16,35,74,560,1,67.5,66.5,1.381,1.000,1.425,70.965,8.400,1600.0,39.0,67.5,46.0,45.0,40.0,1.360,5.000,3.328,3.360,12.192,0.648,3.328,1.832,0.664,1.008,1.360,1.536,1390,763,1352,No,1.106,1.013,31.765,12.000,29,No,No,5951,176445,39,94.0,No,No,11884,25,0.0,0.0,0.0,0.000,0.000,211,2,3.4,0.1,3.5,10.754,0.302,25685,5273,68.0,76.0,838,12.000,55.000,1980.0,55.0,72.7,1.0,0.0,0.0,0.0,0.0,24.0,4946,1577,16.0,4971,321,41,33.507,19.114,0,1.200,1.181,6.750,14.400,7.973,1463.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:26:56.636,19336,20012,49.1,13355,19337,40.8,0.0,1.406,1.300,1.331,1.381,1.381,1.388,1.275,1.288,4800.1,4675.1,4800.1,4750.1,4725.1,4650.1,4550.1,4600.1,100.0,2943.8,3369.0,2790.6,3472.7,2312.4,1444.7,3092.9,2138.1,2619.2,1802.6,1498.9,1812.0,2225.2,1036.8,2062.5,906.3,2220.5,57.3,65.8,57.9,70.1,47.5,32.3,58.5,37.1,50.6,35.9,26.8,32.9,50.0,18.9,39.6,19.5,70.1,43.8,48.0,46.8,48.0,47.5,47.3,46.5,45.5,46.0,1600.0,16.00,16,16,16,35,74,560,1,67.9,66.5,1.337,1.000,1.356,43.671,7.200,1600.0,39.0,67.9,46.0,45.0,40.0,1.376,5.000,3.328,3.360,12.096,0.648,3.328,1.832,0.664,1.008,1.360,1.528,1394,764,1351,No,1.087,1.013,41.647,12.706,29,No,No,5951,176445,39,94.0,No,No,11884,25,0.0,0.0,0.0,0.000,0.000,211,2,2.3,0.1,2.3,6.503,0.205,25701,5274,68.0,76.0,887,24.000,117.000,1988.0,95.0,71.5,7.0,0.0,0.0,0.0,0.0,26.0,4946,1577,16.0,4971,321,41,34.859,19.304,0,1.200,1.144,10.750,28.800,12.295,2480.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:26:59.194,19311,20037,49.0,13357,19336,40.8,0.0,1.381,1.406,1.388,1.288,1.388,1.288,1.306,1.400,4675.1,4800.1,4800.1,4750.1,4725.1,4700.1,4800.1,4700.1,100.0,3048.0,3052.2,2825.0,3331.5,2228.4,1407.2,2985.0,2017.2,2585.4,1685.0,1865.7,1363.8,2181.4,990.5,2007.3,810.0,2149.0,57.9,65.8,64.0,68.2,45.1,28.0,61.5,46.9,53.0,34.1,38.4,24.3,46.3,20.7,43.2,13.4,68.2,44.4,46.8,48.0,48.0,47.5,47.3,47.0,48.0,47.0,1600.0,16.00,16,16,16,35,74,560,1,68.1,63.8,1.250,1.000,1.275,43.671,8.000,1600.0,39.0,68.1,46.0,45.0,40.0,1.384,5.000,3.328,3.360,12.096,0.640,3.328,1.832,0.664,1.008,1.360,1.536,1398,1546,1352,No,1.100,1.013,51.529,14.118,29,No,No,5951,176445,41,94.0,No,No,11884,25,0.0,0.0,0.0,0.000,0.000,211,2,1.4,0.1,1.5,3.138,0.316,25709,5275,68.0,75.0,951,13.000,47.000,1974.0,64.0,70.4,1.0,0.0,0.0,0.0,0.0,27.0,4946,1577,16.0,4971,321,41,32.718,18.485,0,0.968,0.988,2.500,12.584,2.469,1673.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:27:1.758,19337,20011,49.1,13383,19309,40.9,0.0,1.381,1.400,1.319,1.375,1.288,1.394,1.300,1.394,4800.1,4800.1,4700.1,4800.1,4725.1,4800.1,4725.1,4800.1,100.0,3297.8,2583.2,2673.7,3351.0,2128.4,1419.4,2887.5,2024.0,2344.6,1672.8,1869.9,1331.7,2095.3,1021.4,1962.0,832.4,2093.4,71.9,48.7,53.6,73.1,42.6,26.8,63.4,45.7,52.4,39.6,35.9,30.4,47.5,18.9,46.9,15.8,73.1,44.6,48.0,48.0,47.0,48.0,47.3,48.0,47.3,48.0,1600.0,16.00,16,16,16,35,74,560,1,68.1,66.3,1.406,1.000,1.431,40.941,6.800,1600.0,39.0,68.0,46.0,45.0,40.0,1.376,5.000,3.328,3.360,12.192,0.640,3.328,1.832,0.664,1.008,1.360,1.536,1391,762,696,No,1.113,1.013,49.412,12.706,29,No,No,5951,176445,41,94.0,No,No,11884,25,0.0,0.0,0.0,0.000,0.000,211,2,3.5,0.1,3.6,8.251,0.320,25729,5275,67.0,72.0,972,20.000,45.000,1984.0,82.0,71.2,6.0,0.0,0.0,0.0,0.0,28.0,4946,1577,16.0,4971,321,41,29.619,19.326,0,0.931,0.906,9.250,18.620,8.383,1888.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:27:4.328,19334,20015,49.1,13383,19310,40.9,0.0,1.375,1.337,1.363,1.375,1.394,1.363,1.381,1.388,4775.1,4775.1,4725.1,4775.1,4800.1,4775.1,4800.1,4800.1,100.0,3127.6,2823.3,2629.2,3297.7,2046.4,1326.6,2849.4,1910.2,2297.5,1540.8,1885.3,1224.1,1989.8,909.1,1892.6,725.2,2029.7,60.9,57.3,54.2,62.1,39.6,25.0,55.4,40.2,42.6,34.7,37.8,21.9,37.8,18.9,37.8,18.2,62.1,40.3,47.8,47.8,47.3,47.8,48.0,47.8,48.0,48.0,1600.0,16.00,16,16,16,35,74,560,1,68.0,65.8,1.369,0.994,1.400,57.318,8.400,1600.0,39.0,68.1,46.0,45.0,40.0,1.368,5.000,3.328,3.360,12.192,0.640,3.328,1.832,0.664,1.008,1.360,1.536,1390,1546,1354,No,1.106,1.013,48.706,12.706,29,No,No,5951,176445,39,94.0,No,No,11884,25,0.0,0.0,0.0,0.000,0.000,211,2,1.6,0.1,1.7,3.675,0.230,25738,5276,67.0,72.0,972,27.000,46.000,1980.0,80.0,69.6,4.0,0.0,0.0,0.0,0.0,28.0,4946,1577,16.0,4971,322,41,31.592,18.385,0,1.018,0.994,10.000,27.486,9.938,1968.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:27:6.908,19328,20021,49.1,13396,19297,40.9,0.0,1.394,1.375,1.381,1.388,1.394,1.325,1.375,1.288,4775.1,4775.1,3840.1,4750.1,4800.1,4775.1,4800.1,4775.1,100.0,2563.4,3353.2,2521.8,3417.9,2016.4,1298.7,2734.5,1953.7,2363.4,1616.1,1877.0,1217.6,2070.3,918.4,1969.0,678.8,2035.6,49.6,71.5,52.1,67.2,38.1,22.4,56.3,38.1,44.8,33.3,42.4,21.2,37.5,20.0,44.8,16.3,71.5,41.0,47.8,47.8,38.4,47.5,48.0,47.8,48.0,47.8,1600.0,16.00,16,16,16,35,74,560,1,67.9,65.5,1.381,1.000,1.406,45.490,7.200,1600.0,39.0,67.0,46.0,45.0,40.0,1.368,5.000,3.328,3.360,12.192,0.640,3.328,1.832,0.656,1.008,1.360,1.536,1397,1491,698,No,1.094,1.013,27.529,14.118,29,No,No,5951,176445,41,94.0,No,No,11884,25,0.0,0.0,0.0,0.000,0.000,211,2,1.7,0.1,1.8,4.017,0.255,25748,5277,68.0,77.0,970,8.000,144.000,1988.0,99.0,71.8,8.0,0.0,0.0,0.0,0.0,28.0,4947,1577,16.0,4971,322,41,32.465,18.187,0,1.200,0.825,0.000,9.600,0.000,2575.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:27:9.473,19330,20019,49.1,13383,19309,40.9,0.0,1.381,1.400,1.369,1.381,1.388,1.381,1.381,1.406,4700.1,4800.1,4725.1,3840.1,4800.1,4775.1,4800.1,4800.1,100.0,3116.9,2970.7,2552.9,3551.8,2102.9,1250.4,2879.9,2017.6,2370.9,1656.2,1934.7,1266.7,2020.2,1059.2,1928.6,755.0,2089.7,60.0,60.0,61.2,71.5,44.8,23.6,59.3,47.8,47.8,35.7,40.0,26.6,50.3,23.0,46.6,11.5,71.5,44.4,47.0,48.0,47.3,38.4,48.0,47.8,48.0,48.0,1600.0,16.00,16,16,16,35,74,560,1,68.0,65.0,1.319,0.994,1.337,52.769,8.000,1600.0,39.0,68.0,47.0,45.0,40.0,1.376,5.000,3.328,3.360,12.192,0.640,3.328,1.832,0.656,1.008,1.360,1.536,1394,1560,1362,No,1.106,1.013,27.529,12.706,29,No,No,5951,176445,41,94.0,No,No,11884,25,0.0,0.0,0.0,0.000,0.000,211,2,1.3,0.1,1.3,3.112,0.229,25756,5277,67.0,75.0,973,22.000,46.000,1980.0,76.0,70.8,2.0,0.0,0.0,0.0,0.0,28.0,4947,1578,16.0,4971,322,41,31.078,17.899,0,1.125,1.169,8.750,24.750,10.227,1851.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:27:12.034,19330,20019,49.1,13391,19301,40.9,0.0,1.269,1.256,1.238,1.419,1.250,1.356,1.250,1.356,4675.1,4625.1,4500.1,4625.1,4525.1,4575.1,4550.1,4600.1,100.0,3474.4,2568.2,2545.2,3606.9,2202.3,1381.2,2932.7,2100.6,2441.2,1758.4,1838.9,1408.0,2125.6,977.1,1992.2,802.9,2134.7,68.9,49.3,49.3,73.7,41.4,29.8,50.0,36.5,43.2,35.9,35.3,23.7,39.0,22.5,37.1,12.1,73.7,40.5,46.8,46.3,45.0,46.3,45.3,45.8,45.5,46.0,1600.0,16.00,16,16,16,35,74,560,1,67.9,63.5,1.281,0.994,1.306,34.573,6.800,1600.0,39.0,67.9,47.0,45.0,40.0,1.352,5.000,3.328,3.360,12.192,0.640,3.328,1.832,0.656,1.008,1.360,1.528,1394,1495,697,No,1.106,1.013,45.882,14.118,29,No,No,5951,176445,39,94.0,No,No,11884,25,0.0,0.0,0.0,0.000,0.000,211,2,1.5,0.1,1.6,2.805,0.252,25762,5278,68.0,77.0,978,8.000,142.000,2030.0,97.0,74.9,8.0,0.0,0.0,0.0,0.0,28.0,4947,1581,16.0,4971,322,41,32.810,18.330,0,0.868,0.844,0.250,6.944,0.211,2546.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:27:14.594,19346,20003,49.1,13405,19288,41.0,0.0,1.263,1.394,1.269,1.325,1.281,1.369,1.300,1.406,4575.1,4750.1,4650.1,4775.1,4625.1,4650.1,4700.1,4800.1,100.0,3408.2,3073.3,2847.6,3583.7,2438.8,1511.8,3117.1,2301.5,2644.8,1911.2,1372.9,2023.1,2311.5,1117.7,2119.0,919.4,2293.9,70.7,63.4,59.1,75.0,50.6,31.0,64.6,47.5,57.3,41.4,29.8,40.8,46.9,22.5,47.5,23.1,75.0,48.2,45.8,47.5,46.5,47.8,46.3,46.5,47.0,48.0,1600.0,16.00,16,16,16,35,74,560,1,68.6,65.5,1.394,1.000,1.431,69.145,7.600,1600.0,39.0,68.6,47.0,45.0,40.0,1.344,5.000,3.328,3.360,12.192,0.640,3.328,1.832,0.656,1.008,1.360,1.528,1396,1546,1352,No,1.113,1.013,29.647,12.706,29,No,No,5951,176445,39,94.0,No,No,11884,25,0.0,0.0,0.0,0.000,0.000,211,2,1.6,0.1,1.7,4.009,0.230,25772,5278,68.0,78.0,1001,27.000,71.000,1988.0,85.0,74.5,5.0,0.0,0.0,0.0,0.0,29.0,4948,1581,16.0,4971,322,41,30.416,17.822,0,1.200,1.163,11.000,32.400,12.788,2148.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:27:17.148,19337,20012,49.1,13400,19292,40.9,0.0,1.394,1.319,1.400,1.381,1.388,1.325,1.313,1.300,4700.1,4800.1,4800.1,4775.1,4800.1,4600.1,4725.1,4775.1,100.0,3129.3,3112.3,2793.7,3532.5,2263.8,1447.8,2928.7,2228.7,2518.0,1870.9,1301.8,2068.7,2216.1,1163.3,2044.7,848.3,2216.8,60.9,68.2,62.1,71.9,44.5,29.8,67.0,48.7,49.3,40.2,25.6,44.5,46.9,25.6,48.7,14.6,71.9,46.8,47.0,48.0,48.0,47.8,48.0,46.0,47.3,47.8,1600.0,16.00,16,16,16,35,74,560,1,68.4,65.3,1.237,0.994,1.263,40.941,8.000,1600.0,39.0,68.4,47.0,46.0,40.0,1.344,5.000,3.328,3.360,12.192,0.640,3.328,1.832,0.656,1.008,1.360,1.528,1390,1546,1352,No,1.087,1.013,31.765,12.706,29,No,No,5951,176445,39,94.0,No,No,11884,25,0.0,0.0,0.0,0.000,0.000,211,2,1.4,0.2,1.7,4.198,0.356,25782,5279,69.0,78.0,1072,26.000,54.000,1984.0,83.0,76.3,5.0,0.0,0.0,0.0,0.0,31.0,4948,1582,16.0,4971,322,41,31.139,17.924,0,1.200,1.163,7.750,31.200,9.009,2095.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:27:19.706,19340,20008,49.1,13393,19300,40.9,0.0,1.256,1.388,1.269,1.337,1.238,1.425,1.331,1.375,4575.1,4825.1,4575.1,4850.1,4650.1,4850.1,4625.1,3860.1,100.0,3687.4,2645.4,2749.4,3562.2,2247.2,1431.9,2920.4,2243.9,2422.5,1869.8,1354.7,2003.1,2183.2,1136.9,2066.9,838.8,2210.2,74.2,57.0,61.3,73.6,41.1,31.2,58.2,45.3,52.7,39.8,27.6,43.5,44.7,26.3,44.7,17.7,74.2,46.2,45.8,48.3,45.8,48.5,46.5,48.5,46.3,38.6,1600.0,16.00,16,16,16,35,74,560,1,68.1,63.0,1.281,1.000,1.306,45.490,7.200,1600.0,39.0,68.1,47.0,46.0,40.0,1.352,5.000,3.328,3.360,12.096,0.632,3.328,1.832,0.656,1.008,1.360,1.528,1386,753,698,No,1.100,1.013,22.588,12.000,29,No,No,5951,176445,39,94.0,No,No,11884,25,0.0,0.0,0.0,0.000,0.000,211,2,0.3,0.2,0.5,0.449,0.228,25784,5280,69.0,77.0,1159,22.000,120.000,1986.0,95.0,79.2,8.0,0.0,0.0,0.0,0.0,34.0,4948,1582,16.0,4971,322,41,33.153,18.101,0,1.200,1.144,5.000,26.400,5.719,2464.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:27:22.266,19359,19990,49.1,13401,19292,40.9,0.0,1.344,1.388,1.300,1.337,1.375,1.413,1.331,1.381,4625.1,4750.1,4750.1,4800.1,4725.1,4825.1,4700.1,4750.1,100.0,3438.9,2730.0,2842.4,3348.4,2242.9,1378.5,3037.4,2125.7,2576.4,1753.2,1274.6,1988.3,2190.9,1058.9,2018.2,824.8,2176.8,68.2,57.3,63.4,62.8,40.2,25.0,60.9,45.1,51.2,35.9,25.6,38.4,40.8,19.5,42.0,14.0,68.2,43.1,46.3,47.5,47.5,48.0,47.3,48.3,47.0,47.5,1600.0,16.00,16,16,16,35,74,560,1,68.9,65.3,1.387,1.000,1.425,63.686,7.200,1600.0,40.0,68.0,47.0,46.0,40.0,1.336,5.000,3.328,3.360,12.192,0.632,3.328,1.832,0.656,1.008,1.360,1.528,1386,1542,1354,No,1.087,1.013,38.118,14.824,29,No,No,5951,176445,38,94.0,No,No,11884,25,0.0,0.0,0.0,0.000,0.000,211,2,0.2,0.2,0.4,0.573,0.179,25785,5280,69.0,77.0,1239,8.000,149.000,2026.0,87.0,73.2,6.0,0.0,0.0,0.0,0.0,36.0,4948,1582,16.0,4971,322,41,30.802,17.627,0,1.200,1.175,2.250,9.600,2.644,2560.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:27:24.821,19334,20015,49.1,13386,19307,40.9,0.0,1.288,1.388,1.319,1.394,1.281,1.381,1.394,1.350,4800.1,4800.1,4800.1,4800.1,4625.1,4775.1,4675.1,4800.1,100.0,2539.8,3400.2,2469.7,3388.3,1979.1,1220.4,2805.9,1760.3,2303.0,1488.7,1103.1,1892.1,1947.4,860.7,1724.6,757.1,1977.5,47.5,73.1,54.8,67.0,42.6,20.1,55.4,39.0,52.4,34.1,25.0,37.1,45.7,25.0,41.4,18.2,73.1,42.4,48.0,48.0,48.0,48.0,46.3,47.8,46.8,48.0,1600.0,16.00,16,16,16,35,74,560,1,68.8,69.0,1.306,0.994,1.331,34.573,8.400,1600.0,40.0,68.8,47.0,46.0,40.0,1.376,5.000,3.328,3.360,12.192,0.632,3.328,1.832,0.648,1.008,1.360,1.528,1393,752,698,No,1.094,1.013,30.353,12.000,29,No,No,5951,176445,39,94.0,No,No,11884,25,0.0,0.0,0.0,0.000,0.000,211,2,1.5,0.1,1.6,3.569,0.209,25794,5281,68.0,74.0,1266,9.000,118.000,1988.0,96.0,71.3,8.0,0.0,0.0,0.0,0.0,37.0,4949,1582,16.0,4971,322,41,32.000,18.060,0,0.868,0.838,0.250,7.812,0.209,2318.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:27:27.389,19364,19984,49.2,13404,19289,40.9,0.0,1.344,1.375,1.381,1.381,1.263,1.350,1.256,1.263,4800.1,4750.1,4775.1,4650.1,4700.1,4825.1,4675.1,4625.1,100.0,2708.3,3406.1,2280.4,3562.0,1949.2,1190.3,2999.5,1725.9,2382.2,1421.8,1155.9,1810.4,1893.9,905.8,1710.7,824.7,1995.4,54.8,70.5,48.1,77.3,39.0,29.2,57.3,38.4,44.5,32.9,28.0,34.7,42.0,19.5,35.3,18.9,77.3,41.9,48.0,47.5,47.8,46.5,47.0,48.3,46.8,46.3,1600.0,16.00,16,16,16,35,74,560,1,69.3,65.0,1.412,1.000,1.444,53.678,8.000,1600.0,40.0,69.3,47.0,46.0,40.0,1.376,5.000,3.328,3.360,12.192,0.632,3.328,1.832,0.648,1.008,1.360,1.536,1388,760,698,No,1.081,1.013,40.235,14.824,29,No,No,5951,176445,39,94.0,No,No,11884,25,0.0,0.0,0.0,0.000,0.000,211,2,1.5,0.1,1.7,5.065,0.204,25806,5281,67.0,75.0,1267,7.000,120.000,1988.0,97.0,74.0,8.0,0.0,0.0,0.0,0.0,37.0,4949,1585,16.0,4971,322,41,32.514,17.762,0,1.100,0.831,0.250,7.700,0.208,2350.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:27:29.947,19336,20013,49.1,13399,19294,40.9,0.0,1.244,1.381,1.356,1.306,1.388,1.413,1.306,1.400,4625.1,4725.1,4700.1,4600.1,4700.1,4800.1,4750.1,4775.1,100.0,3216.8,2639.9,2449.8,3396.8,2003.1,1216.3,2926.1,1736.6,2337.2,1505.0,1797.9,1258.5,1929.0,935.2,1778.7,811.0,1996.1,65.2,53.3,56.0,72.1,39.6,24.3,59.1,40.2,43.2,33.5,32.3,28.6,39.6,23.1,42.0,18.9,72.1,41.9,46.3,47.3,47.0,46.0,47.0,48.0,47.5,47.8,1600.0,16.00,16,16,16,35,74,560,1,69.1,66.0,1.287,0.994,1.306,31.843,6.800,1600.0,40.0,69.0,47.0,46.0,40.0,1.368,5.000,3.328,3.360,12.096,0.632,3.328,1.832,0.648,1.008,1.360,1.528,1393,762,699,No,1.119,1.013,28.941,13.412,29,No,No,5951,176445,39,94.0,No,No,11884,25,0.0,0.0,0.0,0.000,0.000,211,2,1.8,0.1,1.9,4.935,0.252,25818,5282,66.0,71.0,1233,23.000,78.000,1986.0,92.0,70.4,7.0,0.0,0.0,0.0,0.0,36.0,4949,1585,16.0,4971,322,41,32.498,18.644,0,0.987,0.950,9.000,22.701,8.550,2119.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:27:32.518,19655,19693,49.9,13397,19295,40.9,0.0,1.406,1.400,1.381,1.369,1.381,1.394,1.381,1.337,4800.1,4800.1,4725.1,4800.1,4675.1,4700.1,4600.1,4800.1,100.0,3136.2,2746.3,2482.0,3353.3,1981.0,1162.3,2960.7,1670.3,2328.8,1420.4,1896.4,1132.6,1882.9,867.9,1767.8,739.5,1970.5,61.8,54.5,52.7,69.6,38.7,30.3,61.2,37.5,45.4,31.5,32.1,21.8,33.3,23.0,43.0,16.3,69.6,40.8,48.0,48.0,47.3,48.0,46.8,47.0,46.0,48.0,1600.0,16.00,16,16,16,35,74,560,1,69.3,67.5,1.262,0.994,1.281,39.122,7.600,1600.0,40.0,69.3,47.0,46.0,40.0,1.368,5.000,3.328,3.360,12.192,0.632,3.328,1.832,0.648,1.008,1.360,1.536,1391,762,699,No,1.081,1.013,23.294,12.000,29,No,No,5951,176445,39,94.0,No,No,11884,25,0.0,0.0,0.0,0.000,0.000,211,2,4.2,0.2,4.4,16.005,0.287,25857,5283,66.0,70.0,1168,29.000,48.000,1980.0,77.0,71.6,3.0,0.0,0.0,0.0,0.0,34.0,5271,1586,16.0,5291,322,41,31.385,17.833,0,0.975,0.950,3.500,28.275,3.325,1857.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:27:35.082,19656,19692,49.9,13414,19279,41.0,0.0,1.375,1.369,1.381,1.381,1.381,1.381,1.388,1.375,4700.1,4700.1,4700.1,4775.1,4725.1,4675.1,3840.1,4800.1,100.0,2843.7,3084.0,2883.5,3091.6,2015.0,1204.1,2926.0,1772.6,2414.9,1470.5,1946.5,1140.4,1966.1,856.7,1770.1,860.6,2015.4,58.2,62.5,57.6,64.4,39.2,26.3,59.5,36.8,49.0,32.5,38.6,22.6,43.5,14.1,32.5,20.2,64.4,41.1,47.0,47.0,47.0,47.8,47.3,46.8,38.4,48.0,1600.0,16.00,16,16,16,35,74,560,1,69.1,64.3,1.312,1.000,1.344,60.047,8.000,1600.0,40.0,69.1,47.0,46.0,40.0,1.368,5.000,3.328,3.360,12.096,0.632,3.328,1.832,0.648,1.008,1.360,1.528,1391,762,1355,No,1.094,1.013,50.824,12.706,29,No,No,5951,176445,39,94.0,No,No,11884,25,0.0,0.0,0.0,0.000,0.000,211,2,1.5,0.1,1.6,3.312,0.259,25865,5283,66.0,71.0,1075,7.000,91.000,1992.0,97.0,72.1,7.0,0.0,0.0,0.0,0.0,31.0,5271,1586,16.0,5291,323,41,33.481,17.925,0,0.868,0.850,0.250,6.076,0.212,2109.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:27:37.648,19657,19692,49.9,13393,19299,40.9,0.0,1.381,1.369,1.375,1.394,1.313,1.400,1.294,1.394,4775.1,4725.1,4700.1,3840.1,4775.1,4800.1,4775.1,3840.1,100.0,3294.2,2756.2,2731.5,3253.7,2037.1,1253.6,2999.9,1794.8,2386.3,1539.8,1900.2,1155.0,1874.9,960.0,1828.9,808.8,2035.9,64.6,57.3,61.5,66.4,49.3,24.3,56.0,39.6,43.2,29.8,38.4,24.3,41.4,18.2,37.8,18.2,66.4,41.9,47.8,47.3,47.0,38.4,47.8,48.0,47.8,38.4,1600.0,16.00,16,16,16,35,74,560,1,71.3,65.3,1.387,1.000,1.419,50.949,7.200,1600.0,40.0,71.4,47.0,46.0,40.0,1.376,5.000,3.328,3.360,12.192,0.632,3.328,1.832,0.648,1.008,1.360,1.536,1396,762,698,No,1.113,1.013,23.294,12.000,29,No,No,5951,176445,39,94.0,No,No,11884,25,0.0,0.0,0.0,0.000,0.000,211,2,1.1,0.1,1.2,3.083,0.178,25873,5284,65.0,70.0,977,5.000,33.000,1986.0,3.0,70.9,0.0,0.0,0.0,0.0,0.0,28.0,5271,1586,16.0,5291,323,42,32.341,17.953,0,0.868,0.869,0.250,4.340,0.217,126.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:27:40.209,19665,19684,49.9,13402,19291,40.9,0.0,1.381,1.375,1.381,1.375,1.369,1.375,1.388,1.250,4775.1,4750.1,4775.1,4775.1,4750.1,4800.1,4675.1,4700.1,100.0,3424.1,2412.7,2338.0,3620.0,2039.2,1207.8,2905.0,1775.6,2416.6,1490.4,1824.0,1210.2,1973.1,876.9,1764.1,711.5,1999.3,68.2,49.3,45.1,78.0,43.9,26.2,59.7,39.0,53.6,32.9,36.5,25.0,45.1,20.1,39.0,14.6,78.0,42.3,47.8,47.5,47.8,47.8,47.5,48.0,46.8,47.0,1600.0,16.00,16,16,16,35,74,560,1,70.4,67.3,1.356,1.000,1.300,47.310,7.600,1600.0,40.0,70.5,48.0,46.0,40.0,1.384,5.000,3.328,3.360,12.192,0.624,3.328,1.832,0.648,1.008,1.360,1.536,1415,1549,1362,No,1.094,1.013,25.412,12.706,29,No,No,5951,176445,39,94.0,No,No,11884,25,0.0,0.0,0.0,0.000,0.000,211,2,1.0,0.2,1.1,2.181,0.257,25878,5284,65.0,68.0,866,28.000,39.000,1982.0,75.0,71.9,5.0,0.0,0.0,0.0,0.0,25.0,5272,1586,16.0,5291,323,42,32.185,18.024,0,0.950,0.931,3.250,26.600,3.027,1694.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:27:42.763,19653,19696,49.9,13386,19307,40.9,0.0,1.337,1.394,1.369,1.375,1.356,1.388,1.388,1.394,4800.1,4725.1,4725.1,4725.1,4775.1,4750.1,4675.1,4800.1,100.0,3015.1,2922.8,2404.9,3620.7,2149.4,1246.7,2894.4,1839.9,2442.0,1509.6,1831.0,1257.3,2029.9,897.4,1776.9,769.8,2038.0,60.3,56.7,54.2,68.2,31.7,26.2,54.8,39.0,46.9,28.6,31.0,28.0,40.2,17.6,40.2,15.8,68.2,40.0,48.0,47.3,47.3,47.3,47.8,47.5,46.8,48.0,1600.0,16.00,16,16,16,35,74,560,1,69.6,66.5,1.394,0.994,1.425,35.482,6.800,1600.0,40.0,69.8,48.0,46.0,40.0,1.376,5.000,3.328,3.360,12.192,0.624,3.328,1.832,0.648,1.008,1.360,1.536,1475,1557,698,No,1.113,1.013,51.529,14.824,29,No,No,5951,176445,39,94.0,No,No,11884,25,0.0,0.0,0.0,0.000,0.000,211,2,2.8,0.1,2.9,10.432,0.256,25904,5285,66.0,71.0,732,23.000,50.000,1982.0,80.0,73.8,6.0,0.0,0.0,0.0,0.0,21.0,5272,1586,16.0,5291,323,42,30.514,18.148,0,0.912,0.887,8.500,20.976,7.544,1867.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:27:45.336,19563,19786,49.7,13298,19395,40.6,0.0,1.250,1.275,1.288,1.244,1.388,1.281,1.288,1.263,4550.1,4675.1,4575.1,4575.1,4675.1,4650.1,4625.1,4750.1,100.0,2943.4,2871.1,2528.4,3297.8,2073.6,1305.2,2713.1,1930.1,2327.3,1575.7,1400.8,1702.3,1999.7,947.4,1785.4,723.0,2007.8,55.4,57.9,57.3,68.2,42.6,24.3,53.6,43.2,50.6,29.8,26.8,32.3,42.0,16.4,41.4,17.0,68.2,41.2,45.5,46.8,45.8,45.8,46.8,46.5,46.3,47.5,1600.0,16.00,16,16,16,35,74,560,1,69.3,71.3,1.356,0.994,1.381,46.400,7.600,1600.0,40.0,69.0,48.0,46.0,40.0,1.360,5.000,3.328,3.360,12.192,0.624,3.328,1.832,0.648,1.008,1.360,1.536,1516,1564,1360,No,1.100,1.013,36.000,12.706,29,No,No,5951,176445,39,94.0,No,No,11884,25,0.0,0.0,0.0,0.000,0.000,211,2,5.3,0.1,5.4,20.709,0.229,25954,5285,65.0,68.0,575,12.000,47.000,1988.0,88.0,75.4,7.0,0.0,0.0,0.0,0.0,16.0,5272,1586,16.0,5291,323,42,28.925,18.163,0,0.893,0.875,4.750,10.716,4.156,1742.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| 3.7.2021,10:27:47.892,19776,19573,50.2,13432,19260,41.0,0.0,1.381,1.406,1.388,1.388,1.388,1.400,1.388,1.394,4800.1,4800.1,4800.1,3860.1,4800.1,4800.1,4800.1,3840.1,100.0,3485.2,2145.3,2445.6,3296.2,1869.3,1192.5,2707.2,1539.8,2233.6,1298.4,1523.0,1727.7,1823.4,882.4,1560.9,676.7,1900.5,79.2,39.6,50.6,68.9,41.4,26.8,51.8,27.4,43.2,25.6,21.3,29.8,37.1,18.2,37.8,10.3,79.2,38.1,48.0,48.0,48.0,38.6,48.0,48.0,48.0,38.4,1600.0,16.00,16,16,16,35,74,560,1,69.3,69.5,1.375,1.000,1.406,59.137,8.000,1600.0,40.0,69.4,48.0,46.0,40.0,1.376,5.000,3.328,3.360,12.192,0.624,3.328,1.832,0.648,1.008,1.360,1.536,1525,772,697,No,1.106,1.013,25.412,12.706,29,No,No,5951,176445,39,94.0,No,No,11884,25,0.0,0.0,0.0,0.000,0.000,211,2,3.2,0.0,3.2,13.394,0.076,25987,5286,64.0,67.0,499,4.000,74.000,1976.0,35.0,71.2,2.0,0.0,0.0,0.0,0.0,14.0,5272,1592,16.0,5291,323,42,28.069,17.193,0,0.868,0.863,0.000,3.472,0.000,1803.0, | | | | | | | | | | | | | | | | | | | | | | | | | |
| Date,Time,"Virtual Memory Commited [MB]","Virtual Memory Available [MB]","Virtual Memory Load [%]","Physical Memory Used [MB]","Physical Memory Available [MB]","Physical Memory Load [%]","Page File Usage [%]","Core 0 VID [V]","Core 1 VID [V]","Core 2 VID [V]","Core 3 VID [V]","Core 4 VID [V]","Core 5 VID [V]","Core 6 VID [V]","Core 7 VID [V]","Core 0 Clock (perf #1/) [MHz]","Core 1 Clock (perf #1/) [MHz]","Core 2 Clock (perf #4/) [MHz]","Core 3 Clock (perf #2/) [MHz]","Core 4 Clock (perf #3/) [MHz]","Core 5 Clock (perf #7/) [MHz]","Core 6 Clock (perf #5/) [MHz]","Core 7 Clock (perf #6/) [MHz]","Bus Clock [MHz]","Core 0 T0 Effective Clock [MHz]","Core 0 T1 Effective Clock [MHz]","Core 1 T0 Effective Clock [MHz]","Core 1 T1 Effective Clock [MHz]","Core 2 T0 Effective Clock [MHz]","Core 2 T1 Effective Clock [MHz]","Core 3 T0 Effective Clock [MHz]","Core 3 T1 Effective Clock [MHz]","Core 4 T0 Effective Clock [MHz]","Core 4 T1 Effective Clock [MHz]","Core 5 T0 Effective Clock [MHz]","Core 5 T1 Effective Clock [MHz]","Core 6 T0 Effective Clock [MHz]","Core 6 T1 Effective Clock [MHz]","Core 7 T0 Effective Clock [MHz]","Core 7 T1 Effective Clock [MHz]","Average Effective Clock [MHz]","Core 0 T0 Usage [%]","Core 0 T1 Usage [%]","Core 1 T0 Usage [%]","Core 1 T1 Usage [%]","Core 2 T0 Usage [%]","Core 2 T1 Usage [%]","Core 3 T0 Usage [%]","Core 3 T1 Usage [%]","Core 4 T0 Usage [%]","Core 4 T1 Usage [%]","Core 5 T0 Usage [%]","Core 5 T1 Usage [%]","Core 6 T0 Usage [%]","Core 6 T1 Usage [%]","Core 7 T0 Usage [%]","Core 7 T1 Usage [%]","Max CPU/Thread Usage [%]","Total CPU Usage [%]","Core 0 Ratio [x]","Core 1 Ratio [x]","Core 2 Ratio [x]","Core 3 Ratio [x]","Core 4 Ratio [x]","Core 5 Ratio [x]","Core 6 Ratio [x]","Core 7 Ratio [x]","Memory Clock [MHz]","Memory Clock Ratio [x]","Tcas [T]","Trcd [T]","Trp [T]","Tras [T]","Trc [T]","Trfc [T]","Command Rate [T]","CPU (Tctl/Tdie) [°C]","CPU CCD1 (Tdie) [°C]","CPU Core Voltage (SVI2 TFN) [V]","SoC Voltage (SVI2 TFN) [V]","CPU Core VID (Effective) [V]","CPU Core Current (SVI2 TFN) [A]","SoC Current (SVI2 TFN) [A]","Memory Controller Clock (UCLK) [MHz]","System [°C]","CPU [°C]","VR MOS [°C]","PCH [°C]","CPU (PECI) [°C]","Vcore [V]","+5V [V]","+3.3V (AVCC) [V]","+3.3V (3VCC) [V]","+12V [V]","VIN4 [V]","3VSB [V]","CPU +1.8V [V]","VIN6 [V]","CPU NB/SoC [V]","DIMM [V]","VIN7 [V]","CPU [RPM]","System 1 [RPM]","System 2 [RPM]","Chassis Intrusion [Yes/No]","VDD Voltage [V]","NB Voltage [V]","VDD Current [A]","NB Current [A]","Drive Temperature [°C]","Drive Failure [Yes/No]","Drive Warning [Yes/No]","Total Host Writes [GB]","Total Host Reads [GB]","Drive Temperature [°C]","Drive Remaining Life [%]","Drive Failure [Yes/No]","Drive Warning [Yes/No]","Total Host Writes [GB]","Total Host Reads [GB]","Read Activity [%]","Write Activity [%]","Total Activity [%]","Read Rate [MB/s]","Write Rate [MB/s]","Read Total [MB]","Write Total [MB]","Read Activity [%]","Write Activity [%]","Total Activity [%]","Read Rate [MB/s]","Write Rate [MB/s]","Read Total [MB]","Write Total [MB]","GPU Temperature [°C]","GPU Hot Spot Temperature [°C]","GPU Fan [RPM]","GPU Core Current [A]","GPU ASIC Power [W]","GPU Memory Clock [MHz]","GPU Utilization [%]","GPU D3D Usage [%]","GPU Memory Controller Utilization [%]","GPU Computing (High Priority Compute) Usage [%]","GPU Computing (Compute 3) Usage [%]","GPU Computing (Compute 0) Usage [%]","GPU Computing (Compute 1) Usage [%]","GPU Fan Speed [%]","GPU D3D Memory Dedicated [MB]","GPU D3D Memory Dynamic [MB]","PCIe Link Speed [GT/s]","GPU Memory Usage [MB]","Total DL [MB]","Total UP [MB]","Current DL rate [KB/s]","Current UP rate [KB/s]","Total Errors []","GPU Core Voltage (VDDC) [V]","GPU Memory Voltage (MVDDC) [V]","GPU Memory Current [A]","GPU Core Power [W]","GPU Memory Power [W]","GPU Clock [MHz]", | | | | | | | | | | | | | | | | | | | | | | | | | |
| ,,System: MSI MS-7B86,System: MSI MS-7B86,System: MSI MS-7B86,System: MSI MS-7B86,System: MSI MS-7B86,System: MSI MS-7B86,System: MSI MS-7B86,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,CPU [#0]: AMD Ryzen 7 5800X,Memory Timings,Memory Timings,Memory Timings,Memory Timings,Memory Timings,Memory Timings,Memory Timings,Memory Timings,Memory Timings,CPU [#0]: AMD Ryzen 7 5800X: Enhanced,CPU [#0]: AMD Ryzen 7 5800X: Enhanced,CPU [#0]: AMD Ryzen 7 5800X: Enhanced,CPU [#0]: AMD Ryzen 7 5800X: Enhanced,CPU [#0]: AMD Ryzen 7 5800X: Enhanced,CPU [#0]: AMD Ryzen 7 5800X: Enhanced,CPU [#0]: AMD Ryzen 7 5800X: Enhanced,CPU [#0]: AMD Ryzen 7 5800X: Enhanced,MSI B450 GAMING PLUS MAX (MS-7B86) (Nuvoton NCT6797D),MSI B450 GAMING PLUS MAX (MS-7B86) (Nuvoton NCT6797D),MSI B450 GAMING PLUS MAX (MS-7B86) (Nuvoton NCT6797D),MSI B450 GAMING PLUS MAX (MS-7B86) (Nuvoton NCT6797D),MSI B450 GAMING PLUS MAX (MS-7B86) (Nuvoton NCT6797D),MSI B450 GAMING PLUS MAX (MS-7B86) (Nuvoton NCT6797D),MSI B450 GAMING PLUS MAX (MS-7B86) (Nuvoton NCT6797D),MSI B450 GAMING PLUS MAX (MS-7B86) (Nuvoton NCT6797D),MSI B450 GAMING PLUS MAX (MS-7B86) (Nuvoton NCT6797D),MSI B450 GAMING PLUS MAX (MS-7B86) (Nuvoton NCT6797D),MSI B450 GAMING PLUS MAX (MS-7B86) (Nuvoton NCT6797D),MSI B450 GAMING PLUS MAX (MS-7B86) (Nuvoton NCT6797D),MSI B450 GAMING PLUS MAX (MS-7B86) (Nuvoton NCT6797D),MSI B450 GAMING PLUS MAX (MS-7B86) (Nuvoton NCT6797D),MSI B450 GAMING PLUS MAX (MS-7B86) (Nuvoton NCT6797D),MSI B450 GAMING PLUS MAX (MS-7B86) (Nuvoton NCT6797D),MSI B450 GAMING PLUS MAX (MS-7B86) (Nuvoton NCT6797D),MSI B450 GAMING PLUS MAX (MS-7B86) (Nuvoton NCT6797D),MSI B450 GAMING PLUS MAX (MS-7B86) (Nuvoton NCT6797D),MSI B450 GAMING PLUS MAX (MS-7B86) (Nuvoton NCT6797D),MSI B450 GAMING PLUS MAX (MS-7B86) (Nuvoton NCT6797D),MSI B450 GAMING PLUS MAX (MS-7B86) (Richtek RT8894A/ASP1106),MSI B450 GAMING PLUS MAX (MS-7B86) (Richtek RT8894A/ASP1106),MSI B450 GAMING PLUS MAX (MS-7B86) (Richtek RT8894A/ASP1106),MSI B450 GAMING PLUS MAX (MS-7B86) (Richtek RT8894A/ASP1106),S.M.A.R.T.: TOSHIBA HDWD110 (87SB150FS),S.M.A.R.T.: TOSHIBA HDWD110 (87SB150FS),S.M.A.R.T.: TOSHIBA HDWD110 (87SB150FS),S.M.A.R.T.: TOSHIBA HDWD110 (87SB150FS),S.M.A.R.T.: TOSHIBA HDWD110 (87SB150FS),S.M.A.R.T.: CT500MX500SSD1 (2003E2810E02),S.M.A.R.T.: CT500MX500SSD1 (2003E2810E02),S.M.A.R.T.: CT500MX500SSD1 (2003E2810E02),S.M.A.R.T.: CT500MX500SSD1 (2003E2810E02),S.M.A.R.T.: CT500MX500SSD1 (2003E2810E02),S.M.A.R.T.: CT500MX500SSD1 (2003E2810E02),Drive: TOSHIBA HDWD110 (87SB150FS),Drive: TOSHIBA HDWD110 (87SB150FS),Drive: TOSHIBA HDWD110 (87SB150FS),Drive: TOSHIBA HDWD110 (87SB150FS),Drive: TOSHIBA HDWD110 (87SB150FS),Drive: TOSHIBA HDWD110 (87SB150FS),Drive: TOSHIBA HDWD110 (87SB150FS),Drive: CT500MX500SSD1 (2003E2810E02),Drive: CT500MX500SSD1 (2003E2810E02),Drive: CT500MX500SSD1 (2003E2810E02),Drive: CT500MX500SSD1 (2003E2810E02),Drive: CT500MX500SSD1 (2003E2810E02),Drive: CT500MX500SSD1 (2003E2810E02),Drive: CT500MX500SSD1 (2003E2810E02),GPU [#0]: AMD: ,GPU [#0]: AMD: ,GPU [#0]: AMD: ,GPU [#0]: AMD: ,GPU [#0]: AMD: ,GPU [#0]: AMD: ,GPU [#0]: AMD: ,GPU [#0]: AMD: ,GPU [#0]: AMD: ,GPU [#0]: AMD: ,GPU [#0]: AMD: ,GPU [#0]: AMD: ,GPU [#0]: AMD: ,GPU [#0]: AMD: ,GPU [#0]: AMD: ,GPU [#0]: AMD: ,GPU [#0]: AMD: ,GPU [#0]: AMD: ,Network: RealTek Semiconductor RTL8168/8111 PCI-E Gigabit Ethernet NIC,Network: RealTek Semiconductor RTL8168/8111 PCI-E Gigabit Ethernet NIC,Network: RealTek Semiconductor RTL8168/8111 PCI-E Gigabit Ethernet NIC,Network: RealTek Semiconductor RTL8168/8111 PCI-E Gigabit Ethernet NIC,Windows Hardware Errors (WHEA),GPU [#0]: AMD: ,GPU [#0]: AMD: ,GPU [#0]: AMD: ,GPU [#0]: AMD: ,GPU [#0]: AMD: ,GPU [#0]: AMD: , | | | | | | | | | | | | | | | | | | | | | | | | | |
