[Sammelthread] MSI MEG X570(S) Unify (X MAX) / ACE (MAX) (AM4)
product_10_20191002132606_5d9434ee62129.pngproduct_9_20190723092258_5d3661724d540.pngproduct_1629079667f4b88b2d70e858818adcfd4767cd52a2.pngproduct_1629094385a72f0a5d4a37c30deff6b3dcba91659c.png
Sammelthread für das MSI MEG x570 Unify/ACE
Herstellerseite:
MEG X570 UNIFY
Herstellerseite: MEG X570 ACE
Herstellerseite: MEG X570S ACE MAX
Herstellerseite: MEG X570S UNIFY-X MAX
Reviews:
MSI MEG X570 UNIFY Review - Introduction
MSI MEG X570 Unify motherboard (updated)
MSI MEG X570 Unify: An All-Black Motherboard
MSI MEG X570 Unify kommt ohne RGB aus
MSI MEG X570 Unify | Tom's Hardware
MSI MEG X570 ACE Infinity | Hardwareluxx
MSI MEG X570 Ace Motherboard Review
MSI MEG X570 Ace - Review 2019 - PCMag UK
MSI MEG X570 ACE - Hardware Journal
MSI MEG X570 ACE - Review
MSI MEG X570S ACE MAX - digideutsche
MSI MEG X570S ACE MAX - wccftech
MSI MEG X570S ACE MAX - IT Info
MSI MEG X570S UNIFY-X MAX - geeknetic
Besonderheiten:
  • Supports 2nd and 3rd Gen AMD Ryzen™ / Ryzen™ with Radeon™ Vega Graphics and 2nd Gen AMD Ryzen™ with Radeon™ Graphics Desktop Processors for AM4 socket
  • Supports DDR4 Memory, up to 5000+(OC) MHz
  • Aluminum Cover with Extended Heatsink: All-metal extended heatsink cover enlarge the surface of heat dissipation, ensures even high-end processors to run in full speed.
  • Lightning Fast Game Experience: PCIe 4.0, Triple Lightning Gen4 x4 M.2 with M.2 Shield Frozr, StoreMI, AMD Turbo USB 3.2 Gen2.
  • 2.5G Gaming LAN with Latest Wi-Fi 6 Solution: Onboard 2.5G LAN with gaming LAN manager, combining latest Wi-Fi 6 solution which supports MU-MIMO and BSS color technology, delivering the best online gaming experience.
  • Frozr Heatsink Design: Designed with the patented fan and double ball bearings to provide the best performance for enthusiast gamers and prosumers.
  • Audio Boost HD: Isolated audio with dedicated processor combining ESS audio DAC with amplifier, deliver the breathtaking, game-changing sound to create the most exciting gameplay.
  • Pre-installed I/O Shielding: Better EMI protection and more convenience for installation
  • ACE: Mystic Light Infinity, Dual LAN, Extended Heat-pipe Design
Spezifikationen Unify/ACE/ACE MAX/Unify X:
SOCKET:
AM4
CPU (MAX SUPPORT): Ryzen 9
CHIPSET:
AMD® X570 Chipset
DDR4 MEMORY: 1866/ 2133/ 2400/ 2667/ 2800/2933 /3000 /3066 /3200 /3466 /3600 /3733 /3866 /4000 /4133 /4266 /4400 /4533 /4600 /4733 /4800 /5000+ Mhz by JEDEC and A-XMP OC MODE
MEMORY CHANNEL: Dual
DIMM SLOTS: 2/4
MAX MEMORY (GB): 128GB
PCI-E X16: 3
PCI-E X1: 2
SATAIII: 4
M.2 SLOT: 3/4/6
RAID: 0/1/10
TPM (HEADER): 1
LAN UNIFY/UNIFY X: 1x Realtek® RTL8125 2.5 Gbps
LAN ACE/ACE MAX: 1x Intel® WGI211AT Gigabit / Intel® Wi-Fi 6E AX210, 1x Realtek® RTL8125 2.5 Gbps
USB 3.2 PORTS (FRONT): 1(Gen2, Type C), 4(Gen1, Type A)
USB 3.2 PORTS (REAR): 1(Gen2, Type C), 3(Gen2, Type A), 2(Gen1, Type A)
USB 2.0 PORTS (FRONT): 4
USB 2.0 PORTS (REAR): 2
AUDIO PORTS (REAR): 5+ Optical S/PDIF (Realtek® ALC1220 Codec)
DIRECTX: 12
FORM FACTOR: ATX
SLI: Y
CROSSFIRE: Y
OPERATING SYSTEM: Support for Windows® 10 64-bit
MSI Support bei hwluxx.
Hier ein paar Bilder zu denn Boards:
Würde ich dennoch mal an MSI weiterleiten. :wink:
Also das neue Beta Bios hat einen Bug bei der CPU Lüfter Anzeige. Springt immer auf über 800 ob wohl andere Werte eingestellt sind die niedriger sind. War beim A9 und davor nicht so. Unter Windows bei hwinfo werden die Werte aber richtig angezeigt.
Und Improve system performance Hat sich denn da was verändert..?
lg
leider halten sich die Hersteller beim BIOS immer sehr zurück was ein Changelog angeht. Falls es überhaupt möglich ist, die Whea Problematik bei hohem IF mit einem BIOS update in den Griff zu bekommen, hoffe ich ja immer noch, dass es jetzt vielleicht so weit ist.
Allerdings habe ich jetzt gerade erst drei Tage das A90 auf RAM OC und CO getuned, dass ich gerade keine Lust habe ein neues Beta zu flashen. Bin also gespannt auf Berichte, ob sich was bei den WHEAs getan hat.
War jetzt wieder im Bios weil der MSI Support ein Bild wollte, da waren die Werte aber wieder normal. Ka warum die ersten beide male als ich ins Bios ging die Anzeige stieg auf über 800rpm. Auf jeden fall ist der MSI Support schnell.
Mit AGESA 1.2.0.2 sollte man auch zunächst mehr als solide unterwegs sein. Fraglich ist, ob und inwiefern überhaupt eine Leistungssteigerung mit AGESA 1.2.0.3A feststellbar ist.
Also in Spielen verhält sich meine 6800 XT jetzt komisch. Lüfter heulen auf ob wohl sich an der Last nichts verändert hat. Werde wieder zurück zu A9 gehen.
Ich habs auch mal getestet CB20 bei selben einstellungen im Bios bei fast gleichen Temperaturen ~50 Punkte mehr.
Der Rest läuft auch unauffällig wie beim Release.
Also in Spielen verhält sich meine 6800 XT jetzt komisch seit dem Beta Bios. Lüfter heulen kurz auf ob wohl sich an der Last nichts verändert hat. Werde wieder zurück zu A9 gehen da dies dort nicht so war. Hat das noch jemand bemerkt?
:unsure:Steuerst du deine Lüfter der Grafikkarte über das Mainboard? Normal hat ein Bios fürs Mainboard nichts mit der Lüftersteuerung der Grafikkarte zu tun.
Nein und das geht auch gar nicht. Warum die Lüfter immer kurz aufheulen kenne ich nur von Ryzen CPUs wo das normal ist aber bei der GPU habe ich das zum ersten mal mit dem neuen Beta Bios. Kann es mir auch nicht erklären wo der zusammenhang ist darum wäre es interessant ob das andere RX 6000 User mit dem neuen Beta Bios auch haben. Vielleicht wird zu viel Spannung auf denn PCIe immer kurz angelegt so das die Karte dann meint es wird heißer und der Lüfter muss schneller drehen oder so???
Das Phänomen hatte ich zuletzt auf einer ATI 4870, Lüfter springt von 0-100% für 10Sekunden, dann 5Sekunden 50%, dann eine halbe Minute 0% im Idle wohlgemerkt und hart nervig gewesen. Gut, ich erzähle wieder von vorm Krieg aber ich konnte es mit "PowerStrip" umgehen aber einen Workaround willste denke ich eher nicht.
Da es sich um ein Beta-BIOS handelt (A.AA1), macht es wenig Sinn, sich nun über diesen Fehler aufzuregen. Einfach bei MSI melden und gut ist und so lange die letzte finale Version nutzen (A.90).
Und wenn man nachfragt, bekommt man keine Antwort.
Ich habe mal von A91 Beta auf die finale A9 geupdated heute und jetzt auf beiden CCDs ähnlich hohe Temperaturen. Obwohl wie in der A91 Beta CPPC und CPPC Prefered Cores auf Auto steht.
Kann sich das einer erklären? Ich bevorzuge eigentlich, wenn nur ein CCD heiß wird mittlerweile, da er ja die besseren Kerne anspricht mit CPPC. Anfangs fand ich das noch verwirrend und dachte die CPU ist kaputt.
Aber weder Auto noch Enabled geben mir diesen Effekt.
Maximaltemperaturen waren mit der A91 81°C. Jetzt sind es schon 83-84°C.
Sicher, dass es nicht einfach daran liegt, dass es jetzt wärmer ist?
Das ist tatsächlich ein Argument :d. Irgendwie nich drüber nachgedacht, aber das wirds sein
Sorry, musste schnaufen ^^
Hmm, in HWinfo64 ist die Anzeige für den Chipsatz Fan verschwunden. Könnte schwören, der war da mal. Chipsatz Temp ist da. Kann das jemand bestätigen? BIOS A9 vom 17.5.21
Wenn der Fan aus ist, ist die Anzeige auch nicht aktiv ... jedenfalls ist das bei mir so
So siehts aus!
das wirds dann wohl sein. lol
Hat schon jemand bemerkt das MSI eine neue Software hat. Statt dem Dragon Center gibt es jetzt das MSI Center. Gefällt mir deutlich besser und es wird vor allem nur noch das nötigste installiert. Man kann nun zusätzliche Extras separat installieren die beim alten Dragon Center immer automatisch mit installiert wurden. Auch Optisch viel klarer nun.
Zwischenablage-Bild (10 Juni 2021).pngZwischenablage-Bild (10 Juni 2021) (2).pngZwischenablage-Bild (10 Juni 2021) (3).png
@Scoty ,danke habe ich noch nicht mitbekommen. Gleich mal installiert und ausprobiert.
Besser aufgeräumt als das Dragon Center aber, schaue ich über Support und klicke auf suche, friert der Rechner ein.:bigok:
Sonst läuft das Programm.
Also bei mir ist nix eingefroren bei der Suche.
Bin auch schon auf der suche nach dem Fehler.
Edit: Habe es nochmal neu installiert, bisher kann ich den Fehler nicht mehr reproduzieren.
Ich suche für das Unify ein tpm 2.0 modul. Bei ebay gibt es zwar einige aber entweder 1.0 oder aber für Asus bzw andere pin belegung.
Es werden zwar Webshops verlinkt aber leider asiatisch, zumindest sollteste damit die richtige Typbezeichnung haben (TPM 2.0 MS-4136) und fündig werden.
Eine Frage. Hab immer wieder mal beim Starten ein Problem bei meinem Unify.
Es piept 1x lang und 2x kurz, dann bootet es aber normal. Laut Tabelle müsste es ein GPU Problem sein, die Karte funktioniert aber ganz normal (6900xt)
Steckt auch bomben fest im Slot, Stromversorgung passt ebenfalls.
Hat jemand eine Idee was das sein könnte??
Edit, habs rausgefunden. Er piept nur wenn der Monitor ausgeschaltet ist. Hab ich bei einem ASRock Board auch, nur dort 5x lang.
Eigenartiges Verhalten, aber kein Problem am Ende.
Ähnliche Themen
