[Sammelthread] MSI MEG X570(S) Unify (X MAX) / ACE (MAX) (AM4)
product_10_20191002132606_5d9434ee62129.pngproduct_9_20190723092258_5d3661724d540.pngproduct_1629079667f4b88b2d70e858818adcfd4767cd52a2.pngproduct_1629094385a72f0a5d4a37c30deff6b3dcba91659c.png
Sammelthread für das MSI MEG x570 Unify/ACE
Herstellerseite:
MEG X570 UNIFY
Herstellerseite: MEG X570 ACE
Herstellerseite: MEG X570S ACE MAX
Herstellerseite: MEG X570S UNIFY-X MAX
Reviews:
MSI MEG X570 UNIFY Review - Introduction
MSI MEG X570 Unify motherboard (updated)
MSI MEG X570 Unify: An All-Black Motherboard
MSI MEG X570 Unify kommt ohne RGB aus
MSI MEG X570 Unify | Tom's Hardware
MSI MEG X570 ACE Infinity | Hardwareluxx
MSI MEG X570 Ace Motherboard Review
MSI MEG X570 Ace - Review 2019 - PCMag UK
MSI MEG X570 ACE - Hardware Journal
MSI MEG X570 ACE - Review
MSI MEG X570S ACE MAX - digideutsche
MSI MEG X570S ACE MAX - wccftech
MSI MEG X570S ACE MAX - IT Info
MSI MEG X570S UNIFY-X MAX - geeknetic
Besonderheiten:
  • Supports 2nd and 3rd Gen AMD Ryzen™ / Ryzen™ with Radeon™ Vega Graphics and 2nd Gen AMD Ryzen™ with Radeon™ Graphics Desktop Processors for AM4 socket
  • Supports DDR4 Memory, up to 5000+(OC) MHz
  • Aluminum Cover with Extended Heatsink: All-metal extended heatsink cover enlarge the surface of heat dissipation, ensures even high-end processors to run in full speed.
  • Lightning Fast Game Experience: PCIe 4.0, Triple Lightning Gen4 x4 M.2 with M.2 Shield Frozr, StoreMI, AMD Turbo USB 3.2 Gen2.
  • 2.5G Gaming LAN with Latest Wi-Fi 6 Solution: Onboard 2.5G LAN with gaming LAN manager, combining latest Wi-Fi 6 solution which supports MU-MIMO and BSS color technology, delivering the best online gaming experience.
  • Frozr Heatsink Design: Designed with the patented fan and double ball bearings to provide the best performance for enthusiast gamers and prosumers.
  • Audio Boost HD: Isolated audio with dedicated processor combining ESS audio DAC with amplifier, deliver the breathtaking, game-changing sound to create the most exciting gameplay.
  • Pre-installed I/O Shielding: Better EMI protection and more convenience for installation
  • ACE: Mystic Light Infinity, Dual LAN, Extended Heat-pipe Design
Spezifikationen Unify/ACE/ACE MAX/Unify X:
SOCKET:
AM4
CPU (MAX SUPPORT): Ryzen 9
CHIPSET:
AMD® X570 Chipset
DDR4 MEMORY: 1866/ 2133/ 2400/ 2667/ 2800/2933 /3000 /3066 /3200 /3466 /3600 /3733 /3866 /4000 /4133 /4266 /4400 /4533 /4600 /4733 /4800 /5000+ Mhz by JEDEC and A-XMP OC MODE
MEMORY CHANNEL: Dual
DIMM SLOTS: 2/4
MAX MEMORY (GB): 128GB
PCI-E X16: 3
PCI-E X1: 2
SATAIII: 4
M.2 SLOT: 3/4/6
RAID: 0/1/10
TPM (HEADER): 1
LAN UNIFY/UNIFY X: 1x Realtek® RTL8125 2.5 Gbps
LAN ACE/ACE MAX: 1x Intel® WGI211AT Gigabit / Intel® Wi-Fi 6E AX210, 1x Realtek® RTL8125 2.5 Gbps
USB 3.2 PORTS (FRONT): 1(Gen2, Type C), 4(Gen1, Type A)
USB 3.2 PORTS (REAR): 1(Gen2, Type C), 3(Gen2, Type A), 2(Gen1, Type A)
USB 2.0 PORTS (FRONT): 4
USB 2.0 PORTS (REAR): 2
AUDIO PORTS (REAR): 5+ Optical S/PDIF (Realtek® ALC1220 Codec)
DIRECTX: 12
FORM FACTOR: ATX
SLI: Y
CROSSFIRE: Y
OPERATING SYSTEM: Support for Windows® 10 64-bit
MSI Support bei hwluxx.
Hier ein paar Bilder zu denn Boards:
Er fragt aber nach 7C35vA93 mit Agesa 1.2.0.2 und den integrierten USB Patch.
Ich hab nicht geupdated, weil mein System absolut stabil läuft und nie wieder das USB Problem auftauchte. Freue mich aber auf Rückmeldungen zum Bios hier.
Ja. Mir ging's um das aktuellste, dass die Woche raus kam. Ich habe auch nicht viel Lust zu testen, da alles gut läuft. Aber eigentlich hatte ich nie größere Probleme bisher.
Wann darf man den wieder auf eine reguläre BIOS Version fürs ACE hoffen?
moin.
Mal ne Frage:
Wenn ich beim RAM OC" Memory TRY" benutze und ich mit den Einstellungen zufrieden bin, muss ich dann " Memory TRY " wieder deaktivieren und die Daten danach manuell eingeben oder kann ich das so lassen??
Beim BIOS warte ich auch erstmal ab- auch bei mir läuft mit dem letzten 1.2.0.0 alles bestens.
gruß
ich denke, dass kannst du so lassen. Kannst ja mal mit Zen Timings überprüfen, ob das board Spannungen etc. von reboot zu reboot verändert.
Bei mir war heute auf einmal im a86 der nvme2_2 tot. Dachte erst die ssd hätte sich verabschiedet, update auf das letzte beta bios gemacht und die ssd war wieder da. Sehr sehr kurios.
Ich bekomme seit kurzem diese Treiberupdates über Windows Update vorgeschlagen. Von der Versionsnummer her kann das fast nur der Ethernet-Treiber sein. Aber was sind dann die anderen beiden?
Ich habe den Ethernet-Treiber von Realtek direkt installiert. Windows scheint da auf jeden Fall flotter zu sein als MSI.
Installiert ihr die Treiber von Windows Update?
Ich habe die Treiber-Installation über Windows-Update komplett deaktiviert und mache dies in Eigenregie.
hmm- ich bekomme diese treiber updates nicht angezeigt.
Die Sachen findest du im Gerätemanager unter Softwarekomponenten , sind Realtek Audio Effects Component , Realtek Audio Universal Service und Realtek Hardware Support Application . Kannst bei den jeweiligen mal schauen was für Treiberversionen installiert sind . Bei mir waren Ältere drauf und ich habe mal auf die angebotenen geupdatet . Hat ohne Probleme geklappt und System läuft normal . Weiß aber auch nicht genau für was diese Sachen da sind oder wofür sie gebraucht werden.
Danke mal für die Info. Manche Treiberupdates würde ich schon gerne Windows übernehmen lassen. Sachen wie NVIDIA oder AMD Chipsatztreiber will ich immernoch selber machen. Aber das Update über Windows ist ganz angenehm. Muss ich mich nicht drum kümmern und brauch nur ein Button klicken. Ich brauche nicht unbedingt den aktuellsten Ethernet- oder Soundkartentreiber, will aber auch nicht das veraltete Zeug von MSI. Obwohl es hier gar nicht so alt ist. Aber auf jeden Fall nicht aktuell.
Ich probier es mal aus.
Da mein aktueller RAM seit einiger Zeit komischerweise nicht mehr stabil auf 3800Mhz laufen will, wollte ich mich mal nach Alternativen umsehen. Hat hier jemand Empfehlungen für ein 32GB RAM Kit (2x16) das die 3800Mhz locker schafft und gegebenfalls OC Potential für 4000Mhz hat? Wenn ich mich so durch Geizhals klicke sind sauviele von den RAMs nicht auf der QVL von MSI. Allerdings ist das Board auf der QVL von einigen RAM Kits. Die 4000er Kits von G.Skill beispielsweise.
Crucial Ballistix Max 4000Mhz oder "besseren" 3600mhz ram besorgen und schauen, ob der 3800mhz mitmacht mit ein bisschen mehr spannung ohne die timings groß hochschrauben zu müssen.
Wie Temperaturanfällig sind die dort verbauten Chips? Bei mir leiden die B-Dies sehr unter den Temperaturen in meinem Gehäuse. Hab schon viel probiert, aber auf 3800 krieg ich sie dank der Abwärme meiner 3080 nicht mehr dauerhaft stabil zum laufen.
Outriders gespielt, CPU 4,7Ghz Allcore bei ~63C°, Speicherspeccs siehe Sig, der Dark Rock Pro saugt sich auch ordentlich die warme Luft von der 3080 rein, erster Speicherriegel knapp 40C° und der, der mehr im Luftzug steht 36C°, dabei 3 Frontlüfter reinpustend, oben 2 raus, hinten 1 raus, alles auf balanced und eben die beiden vom Dark Rock, die die Abwärme bündeln/aufsaugen.
Welche CPU? Das spielt auch eine wichtige Rolle. Zen2 schaffen nur die guten CPUs 3800Mhz, Zen3 fast alle.
https://geizhals.de/crucial-ballistix-schwarz-dimm-kit-32gb-bl2k16g36c16u4b-a2222375.html
der schafft mit Leichtigkeit auch 3800Mhz. Wenn du noch besseren RAM willst nimmst du Samsung B-Die. Der entfaltet sein Potenzial aber erst, wenn du vor allem die Subtimings optimierst. Da läuft dann ein 3200 C14 Kit mit 3800 16-16-16-32.
Ah gerade gelesen du hast B-Die. Wie warm werden sie denn? Meine laufen bei 1.41v und werden max 47C beim Stresstest und auch nicht mehr, wenn die 3080 schwer arbeitet. Nicht aktiv gekühlt aber ein luftiges Gehäuse (BQ! 500DX).
Stell doch mal einen ZenTimings screenshot hier rein, dann kann man mehr sagen.
Auf die QVL Listen würde ich nicht allzuviel geben. Die sind nie aktuell und auch nicht vollständig.
Meine Daten hab ich hinterlegt, kannst im Profil nachschauen. Handelt sich um einen 5800x. Wird aber auch demnächst ausgetauscht.
Dies ist mein aktueller Ram. Läuft mit 3800 16-16-17-16-32 @1,44v. Insgesamt sind es die Einstellungen aus dem RAM-OC Discord - kann bei Bedarf aber gerne einen Screen machen. Die letzen Monate lief das einwandfrei. Sämtliche Stresstests inkl. Karhu hab ich durchlaufen lassen. Hab vor kurzem Kingdom Come Deliverance angefangen und dort Reboots bekommen. Hab dann mal die Temperaturen beobachtet und die Riegel liegen beim zocken bei max 60°C. Unter AIDA Cache/Memory sogar mehr. Als Vergleich: Als ich damals die Tests durchlaufen lies waren es max 55°C. Die einzige Änderung seitdem war der Wechsel von der 3070 auf die 3080. Und selbst nach der Anschaffung waren die Temperaturen nicht so hoch.
Wenn ich die Lüfter weiter hochdrehe kann ich ein paar Grad einsparen und das System läuft wieder stabil, allerdings gefällt mir die Geräuschkulisse dann nicht mehr. Also such ich mir entweder anderen RAM der vielleicht nicht ganz so warm wird bzw. unter den Temperaturen nicht so zickig wird.
Alternativ kann ich natürlich mal versuchen einen Lüfter auf die RAMs zu richten. Insgesamt ist aber eigentlich ein guter Airflow vorhanden. 3*140 vorne von der AiO. 1*140 hinten sowie 2*140 oben. Der Rest der Systems hat auch zufriedenstellende Temperaturen.
B-Die wird ja nachgesagt ab ~50C empfindlich zu reagieren. Könnte also wirklich daran liegen. Allerdings wundert mich, dass du bei 1.44v auf so hohe Temperaturen kommst.
oder könnte es sein, dass da warme Luft draufgepustet wird?
ein zentimings screenshot würde mich trotzdem mal interessieren. meine 3200C14 B-Die laufen auf 3800 16-16-16-32 mit 1.41v stabil
Warm nicht direkt, allerdings natürlich nicht so "kalt" als wenn dort kein Radi wäre. Wenn ich den Radi nach oben lege hab ich leider das Problem, dass die CPU dann die Hitze der Graka abbekommt. Darum hab ich die Lösung mit dem Radi vorne gewählt.
Ja ich geh auch fest davon aus, dass es die Temperaturen sind. Ich frag mich nur warum so hoch. Der Rest des Systems wird auch nicht überdurchschnittlich warm. Die Graka sowie die CPU laufen undervolted.
Ich muss dazu sagen, der RAM ist mittlerweile schon ~4 Jahre alt. Lief vorher 3,5 Jahre auf einem Zen1 System. Keine Ahnung ob die Wärmeentwicklung unter dem Heatspreader mit der Zeit schlechter wird.
Die Idle Temps der beiden Riegel liegen aktuell bei 43°C und 44°C.
hmm, fällt mir jetzt auch nix schlaues mehr zu ein. ZenTimings sieht auch alles gut aus. Eventuell vielleicht mal Vsoc bisschen niedriger probieren und oder die Nebenspannungen. Aber ob das hilft?
Ich musste nach dem letzen Bios Update VSoc höher stellen. Vorher lief es mit 1,125v. Ansonsten kann ich nochmal Probieren mit Vdimm weiter runter zu gehen. Aber ich meine ich hab vor ein paar Monaten alles probiert.
Also das letzte Bios (A93) auf dem Unify hab ich jetzt schon einige zeit am laufen und es läuft alles wie es soll man kann es echt empfehlen.
Sämtliche Limits (PPT, TDC, EDC sowie TJMax) werden eingehalten wie mit den bisherigen Versionen auch?
Ich kann die Limits nur anhand von Hwinfo und den werten im Bios beurteilen und da ist kein unterschied zum A92 festzustellen.
Muss man für die Stromversorgung beide 8-Pin anschließen? Es soll ein 5900x ohne OC und eine Corsair MP600 betrieben werden.
Moin....
Habe meinen 3300x gegen einen 5800x getauscht.
Bios ist 7C35vA93(Beta version).
Wo finde ich die CPPC_Einstellungen und die Global C_States?!?!?!
Habe mir gesucht bis zur Verzweiflung aber nichts gefunden (Ansicht ist überall auf Erweiter bzw. Expert)
RON
Laut Handbuch, deutsch, Seite 50:
▶▶CPU Features
Drücken Sie die Eingabetaste <Enter>, um das Untermenü aufzurufen.
▶▶Global C-state Control [Enabled] (optional)
Aktiviert oder deaktiviert die IO-basierten C-States und DF C-States.
