[Sammelthread] MSI MEG X570(S) Unify (X MAX) / ACE (MAX) (AM4)
product_10_20191002132606_5d9434ee62129.pngproduct_9_20190723092258_5d3661724d540.pngproduct_1629079667f4b88b2d70e858818adcfd4767cd52a2.pngproduct_1629094385a72f0a5d4a37c30deff6b3dcba91659c.png
Sammelthread für das MSI MEG x570 Unify/ACE
Herstellerseite:
MEG X570 UNIFY
Herstellerseite: MEG X570 ACE
Herstellerseite: MEG X570S ACE MAX
Herstellerseite: MEG X570S UNIFY-X MAX
Reviews:
MSI MEG X570 UNIFY Review - Introduction
MSI MEG X570 Unify motherboard (updated)
MSI MEG X570 Unify: An All-Black Motherboard
MSI MEG X570 Unify kommt ohne RGB aus
MSI MEG X570 Unify | Tom's Hardware
MSI MEG X570 ACE Infinity | Hardwareluxx
MSI MEG X570 Ace Motherboard Review
MSI MEG X570 Ace - Review 2019 - PCMag UK
MSI MEG X570 ACE - Hardware Journal
MSI MEG X570 ACE - Review
MSI MEG X570S ACE MAX - digideutsche
MSI MEG X570S ACE MAX - wccftech
MSI MEG X570S ACE MAX - IT Info
MSI MEG X570S UNIFY-X MAX - geeknetic
Besonderheiten:
  • Supports 2nd and 3rd Gen AMD Ryzen™ / Ryzen™ with Radeon™ Vega Graphics and 2nd Gen AMD Ryzen™ with Radeon™ Graphics Desktop Processors for AM4 socket
  • Supports DDR4 Memory, up to 5000+(OC) MHz
  • Aluminum Cover with Extended Heatsink: All-metal extended heatsink cover enlarge the surface of heat dissipation, ensures even high-end processors to run in full speed.
  • Lightning Fast Game Experience: PCIe 4.0, Triple Lightning Gen4 x4 M.2 with M.2 Shield Frozr, StoreMI, AMD Turbo USB 3.2 Gen2.
  • 2.5G Gaming LAN with Latest Wi-Fi 6 Solution: Onboard 2.5G LAN with gaming LAN manager, combining latest Wi-Fi 6 solution which supports MU-MIMO and BSS color technology, delivering the best online gaming experience.
  • Frozr Heatsink Design: Designed with the patented fan and double ball bearings to provide the best performance for enthusiast gamers and prosumers.
  • Audio Boost HD: Isolated audio with dedicated processor combining ESS audio DAC with amplifier, deliver the breathtaking, game-changing sound to create the most exciting gameplay.
  • Pre-installed I/O Shielding: Better EMI protection and more convenience for installation
  • ACE: Mystic Light Infinity, Dual LAN, Extended Heat-pipe Design
Spezifikationen Unify/ACE/ACE MAX/Unify X:
SOCKET:
AM4
CPU (MAX SUPPORT): Ryzen 9
CHIPSET:
AMD® X570 Chipset
DDR4 MEMORY: 1866/ 2133/ 2400/ 2667/ 2800/2933 /3000 /3066 /3200 /3466 /3600 /3733 /3866 /4000 /4133 /4266 /4400 /4533 /4600 /4733 /4800 /5000+ Mhz by JEDEC and A-XMP OC MODE
MEMORY CHANNEL: Dual
DIMM SLOTS: 2/4
MAX MEMORY (GB): 128GB
PCI-E X16: 3
PCI-E X1: 2
SATAIII: 4
M.2 SLOT: 3/4/6
RAID: 0/1/10
TPM (HEADER): 1
LAN UNIFY/UNIFY X: 1x Realtek® RTL8125 2.5 Gbps
LAN ACE/ACE MAX: 1x Intel® WGI211AT Gigabit / Intel® Wi-Fi 6E AX210, 1x Realtek® RTL8125 2.5 Gbps
USB 3.2 PORTS (FRONT): 1(Gen2, Type C), 4(Gen1, Type A)
USB 3.2 PORTS (REAR): 1(Gen2, Type C), 3(Gen2, Type A), 2(Gen1, Type A)
USB 2.0 PORTS (FRONT): 4
USB 2.0 PORTS (REAR): 2
AUDIO PORTS (REAR): 5+ Optical S/PDIF (Realtek® ALC1220 Codec)
DIRECTX: 12
FORM FACTOR: ATX
SLI: Y
CROSSFIRE: Y
OPERATING SYSTEM: Support for Windows® 10 64-bit
MSI Support bei hwluxx.
Hier ein paar Bilder zu denn Boards:
Dieses Verhalten habe ich schon länger als einen Monat. Auch andere hier. Das Ganze wurde hier im Thread thematisiert.
Schon, aber da ging es um den Power-Management-Zusatz vom Chipsatztreiber.
Die Core Voltage (SVI2 TFN) unter HWInfo64 ging auch bei meinen kurz im Einsatz gehabten 5800x und B550 Strix Gaming-E nicht runter und war bei 1.4
Laut CPU-Z/Ryzen Master wird aber sauber die VCore runter gesetzt. Temperaturen sind im Idle auch bei angenehmen 35°C.
Ich ignorier das einfach.
Ich habe das Problem bereits identifiziert. Ich hatte vergessen, dass ich den Windows-Indizierungsdienst aktiviert hatte und dieser hat ständig eine Last erzeugt...
Okay, nun verstehe ich gar nichts mehr! Eine Zeit lang ging er wieder brav runter und nun bleibt er wieder bei 3,6 GHz hängen.
Spannungen von Kernen, die in den Schlafmodus versetzt wurden, können nicht wirklich ausgelesen werden. Monitoring Tools zeigen nur den letzten Stand bezüglich Takt und Spannung an. Wenn ein Kern bei 1,2V und 4GHz war und unmittelbar danach in den C6 State versetzt wurde, wird HWinfo nur das letzte Abbild anzeigen. Dann kommt noch hinzu, dass aufgrund der Monitoring Software auch ständig die Kerne geweckt werden, man nennt das "observer effect"
Wenn man die tatsächlichen Spannungen und Zustand der Cores auslesen möchte, sollte man Ryzen Master benutzen.
Haste die Einstellungen in den Energieoptionen mal probiert? @FM4E
Danke, aber ich habe schon alles mögliche probiert. Nun habe ich testweise mal einen Mod-Energiesparplan (Pizza Mod V4) genommen und damit läuft alles reibungslos. Scheinbar hat Microsoft (wieder mal) etwas mit den Updates verkorkst.
Ich habe seit gut ner Woche ein neues System: 5900x@ Msi Unify 570 + 2x 16GB G.Skill DDR4000 cl16 (Samsung B)
Das ganze lief mit dem Bios 7C35vA8 ziemlich gut bis auf USB Problemen. Bei jedem Neustart Tastertur und Maus Empfänger einmal raus und wieder rein.
Das System lief (ansonnsten) ohne jegliche Fehler mit 3800/IF1900 Cl14-16-16-16-36. (1,5v)
Bei IF2000/4000 bootete das System auch ganz normal, jedoch gab ein Rauschen im Sound bei Video Wiedergabe. Darum beließ ich es bei IF1900/3800. Bisher auch nicht ein WHEA Fehler im Protokoll.
(Das USB Problem gab es auch mit Stock Einstellung.)
Dann versuchte ich das beta Bios 7C35vA92. Die Bios Einstellung vorher resettet.
Mit den Stock Werten ist es dann auch ganz normal hochgefahren aber mit höherem (IF&) Speichertakt ist der Rechner nicht einmal bis ins Windows gekommen.
Es ging auch nicht bei 1800/3600 CL16. Bei dieser Einstellung gab wenigstens eine irgendeine Angabe "Memory Error" irgendwas...
Weiter runter testete ich dann nicht weil es so aussah als hätte es die Win10 Installation geschrottet. Hab dann das alte Bios zurück geflasht und dann war alles beim alten.
Ich habe viele Stunden bei 3800cl14 gezockt und mit dem neuen war mit 3600cl16 nicht einmal booten drin.
Ich kann mich über das A92 nicht beklagen. Ich hab 3600/IF1800 eingestellt mit guten Timigs.CPU läuft absolut stabil und bringt top Leistung.Bist jetzt konnte ich nichts negatives feststellen.
Wie laut sind denn bei euch im Betrieb die Lüfter der MSI X570er Boards?
Desktop/Idle? Ist ein Silent Betrieb möglich?
Beim Spielen?
Ich würd vermuten, dass sich die Lüfter der verschiedenen MSI X570 Boards kaum oder nicht unterscheiden, oder?
Beim Spielen?
Ich habe den Chipsatz FAN bis heute nicht einmal gehört. :ROFLMAO:
trotz 2 NVME dreht mein Chipsatzlüfter nur einmal auf, beim Post wenn das System gestartet wird, ansonsten dreht er sich nie.
Beim Spielen?
Die Lüfter? Redest du überhaupt vom Chipsatzlüfter?
Ja genau, von DEM einen Chipsatzlüfter auf einem entsprechen MB oder DEN Chipsatzlüftern, wenn ich an alle MSI Boards mit demselben Lüftertyp denke - sorry wenns missverständlich war.
Wie Mastereye auch schon sagte. Ich habe bisher noch nicht erlebt, dass der Lüfter Mal an ging weil der Chipsatz zu warm würde.
Für das MEG X570 ACE ist heute ebenfalls ein neues Beta BIOS mit AGESA 1.2.0.2 veröffentlicht worden:
Btw...ich habe heute zum ersten mal das USB Problem gehabt. Komischerweise tritt es nur auf wenn sich zwei Geräte am Front-Panel befinden.
Dann hat die Maus völlige Aussetzer und ist nicht mehr zu bedienen. Zieh ich ein Device ab und verwende einen Port am MB, alles wieder takko.
Ich habe die Probleme mit der Logitech G502 Hero Maus erst seit AGESA 1.2.0.1 Patch A. Kann nicht in Ruhe mit der Maus selektieren (z.B. mehrere Dateien auf dem Desktop oder mehrere Krieger in Spielen etc.). Trotz niedergedrückter linker Maustaste, hält diese nicht bis zum Schluss fest und spielt nahezu verrückt.
Das ist echt extremer Mist. Gerade in Spielen! Ich werde um meine Vorteile gebracht und die Herden sind schon über mir. :-)
Hoffe mit dem seit heute erschienenen AGESA 1.2.0.2 ist das Problem gefixt!
Viele Grüße
Ist die Maus zufällig an USB 3 angeschlossen und wurde schon versucht, sie an USB 2 anzuschließen?
Angehen tut er auf jeden Fall, bei mir so bei ~60°C+/- zumindest auf dem ACE.
Allerdings nicht wirklich hörbar, klar wenn du ihn manuell hochknallst dann hört man was aber prinzipiell bekommt man im normalen Gamingalltag (+Supersilent beim Surfen) nichts davon mit
Hallo Zusammen
Weiss Jemand ob man die XMP Led, Power- & Reset Button LED deaktivieren kann?
Habe im Bios nur die Option gefunden um die LED vom "Mosfet" heisst das glaube ich (das Teil links vom CPU) zu deaktivieren.
Die sehen einfach nicht gut aus 🤢
(MSI MEG X570 Ace // Bios 7C35v1D)
Hallo Zusammen
Deaktivieren kann man mW nicht direkt. Du könntest die Werte aber manuell eingeben vom XMP-Profil, dann läuft es unter den Spezifikationen und die LED bleibt aus.
Aaaah... danke ;) markier ich nochmal gleich den @Navi , damit er es definitiv sieht aber danke auch von mir ;)
@gsus83
Mein Held !!! :d
Ich hatte das irgendwie übersehen... und nur den "RGB Light Control" deaktiviert.... :rolleyes2:
DANKE!
RGB Light Control = Schaltet die LED aus vom Mosfet Teil
Indication LED Control = Schaltet die LED aus vom RAM XMP Profil, Power- & Resetbutton
Hat jemand schon das aktuellste BIOS getestet?
Ähnliche Themen
