[Sammelthread] MSI MEG X570(S) Unify (X MAX) / ACE (MAX) (AM4)
product_10_20191002132606_5d9434ee62129.pngproduct_9_20190723092258_5d3661724d540.pngproduct_1629079667f4b88b2d70e858818adcfd4767cd52a2.pngproduct_1629094385a72f0a5d4a37c30deff6b3dcba91659c.png
Sammelthread für das MSI MEG x570 Unify/ACE
Herstellerseite:
MEG X570 UNIFY
Herstellerseite: MEG X570 ACE
Herstellerseite: MEG X570S ACE MAX
Herstellerseite: MEG X570S UNIFY-X MAX
Reviews:
MSI MEG X570 UNIFY Review - Introduction
MSI MEG X570 Unify motherboard (updated)
MSI MEG X570 Unify: An All-Black Motherboard
MSI MEG X570 Unify kommt ohne RGB aus
MSI MEG X570 Unify | Tom's Hardware
MSI MEG X570 ACE Infinity | Hardwareluxx
MSI MEG X570 Ace Motherboard Review
MSI MEG X570 Ace - Review 2019 - PCMag UK
MSI MEG X570 ACE - Hardware Journal
MSI MEG X570 ACE - Review
MSI MEG X570S ACE MAX - digideutsche
MSI MEG X570S ACE MAX - wccftech
MSI MEG X570S ACE MAX - IT Info
MSI MEG X570S UNIFY-X MAX - geeknetic
Besonderheiten:
  • Supports 2nd and 3rd Gen AMD Ryzen™ / Ryzen™ with Radeon™ Vega Graphics and 2nd Gen AMD Ryzen™ with Radeon™ Graphics Desktop Processors for AM4 socket
  • Supports DDR4 Memory, up to 5000+(OC) MHz
  • Aluminum Cover with Extended Heatsink: All-metal extended heatsink cover enlarge the surface of heat dissipation, ensures even high-end processors to run in full speed.
  • Lightning Fast Game Experience: PCIe 4.0, Triple Lightning Gen4 x4 M.2 with M.2 Shield Frozr, StoreMI, AMD Turbo USB 3.2 Gen2.
  • 2.5G Gaming LAN with Latest Wi-Fi 6 Solution: Onboard 2.5G LAN with gaming LAN manager, combining latest Wi-Fi 6 solution which supports MU-MIMO and BSS color technology, delivering the best online gaming experience.
  • Frozr Heatsink Design: Designed with the patented fan and double ball bearings to provide the best performance for enthusiast gamers and prosumers.
  • Audio Boost HD: Isolated audio with dedicated processor combining ESS audio DAC with amplifier, deliver the breathtaking, game-changing sound to create the most exciting gameplay.
  • Pre-installed I/O Shielding: Better EMI protection and more convenience for installation
  • ACE: Mystic Light Infinity, Dual LAN, Extended Heat-pipe Design
Spezifikationen Unify/ACE/ACE MAX/Unify X:
SOCKET:
AM4
CPU (MAX SUPPORT): Ryzen 9
CHIPSET:
AMD® X570 Chipset
DDR4 MEMORY: 1866/ 2133/ 2400/ 2667/ 2800/2933 /3000 /3066 /3200 /3466 /3600 /3733 /3866 /4000 /4133 /4266 /4400 /4533 /4600 /4733 /4800 /5000+ Mhz by JEDEC and A-XMP OC MODE
MEMORY CHANNEL: Dual
DIMM SLOTS: 2/4
MAX MEMORY (GB): 128GB
PCI-E X16: 3
PCI-E X1: 2
SATAIII: 4
M.2 SLOT: 3/4/6
RAID: 0/1/10
TPM (HEADER): 1
LAN UNIFY/UNIFY X: 1x Realtek® RTL8125 2.5 Gbps
LAN ACE/ACE MAX: 1x Intel® WGI211AT Gigabit / Intel® Wi-Fi 6E AX210, 1x Realtek® RTL8125 2.5 Gbps
USB 3.2 PORTS (FRONT): 1(Gen2, Type C), 4(Gen1, Type A)
USB 3.2 PORTS (REAR): 1(Gen2, Type C), 3(Gen2, Type A), 2(Gen1, Type A)
USB 2.0 PORTS (FRONT): 4
USB 2.0 PORTS (REAR): 2
AUDIO PORTS (REAR): 5+ Optical S/PDIF (Realtek® ALC1220 Codec)
DIRECTX: 12
FORM FACTOR: ATX
SLI: Y
CROSSFIRE: Y
OPERATING SYSTEM: Support for Windows® 10 64-bit
MSI Support bei hwluxx.
Hier ein paar Bilder zu denn Boards:
Also die Lüftersteuerung ist stark verbesserungswürdig da muss MSI noch nachlegen.Als ich den Ram gestern testete sind die lüfter beider kühler nach 3 stunden ausgegangen ich musste sie im Bios wieder aktivieren.Diese steuerung muss man erst mal verstehen.Aber der rest des boards ist sehr gut gelungen ohne das ganze blinkende zeug😁😁
Wahrscheinlich darfst du dir einmal das MSI Dragon Center installieren und die LED-Firmware aktualisieren.
Ich habe gestern mal mit HWINFO64 meine CPU getrackt über fast 3 Std und die niedrigste Voltage die ich gesehen habe war ca. 1.35V. Ich weiß nicht, ob HWINFO64 nicht richtig trackt, das Board zuviel Spannung in die CPU pumpt oder die CPU defekt ist und zuviel Spannung anfordert. Ist das eine Möglichkeit? Beim Rendern habe ich jedoch deutlich niedrigere Spannungen unter 0.9 V sogar zum Teil in Prime95. Aber ich kann mir nicht vorstellen, dass diese Voltages auf Dauer gut sind für die CPU im Alltagsbetrieb für Single Core Anwendungen oder beim browsen.
Was mir auch erst jetzt auffällt ist der Unterschied zwischen Effective Clock und Core Clock. Teilweise komplett andere Werte. Ich habs Gefühl HWINFO64 ist nicht wirklich zuverlässig als Auslesemethode, da ich in Ryzen Master auch andere Voltages sehe.
EDIT:
Core 0 Clock (perf #5/6) [MHz]Core 1 Clock (perf #7/8) [MHz]Core 2 Clock (perf #4/5) [MHz]Core 3 Clock (perf #2/3) [MHz]Core 4 Clock (perf #6/7) [MHz]Core 5 Clock (perf #1/1) [MHz]Core 6 Clock (perf #3/4) [MHz]Core 7 Clock (perf #1/2) [MHz]Core 8 Clock (perf #14/15) [MHz]Core 9 Clock (perf #11/12) [MHz]Core 10 Clock (perf #13/14) [MHz]Core 11 Clock (perf #12/13) [MHz]Core 12 Clock (perf #8/9) [MHz]Core 13 Clock (perf #9/11) [MHz]Core 14 Clock (perf #10/10) [MHz]Core 15 Clock (perf #15/16) [MHz]Bus Clock [MHz]Core 0 T0 Effective Clock [MHz]Core 0 T1 Effective Clock [MHz]
3600.23600.23600.23600.22400.23166.93166.93166.93166.93166.93166.93166.93166.93166.93166.94750.3100.0110.322.1
Hier sieht man dass die Core 0 Clock und Core 0 T0/T1 Effective Clock komplett abweichen. Hat einer dazu mehr Ahnung? Wieso hat Core 0 zwei Werte mit T0 und T1 (ich nehme an für Threads).
Dragon Center ist installiert und Liveupdate sagt keine updates unter der Bios sektion.Vermutlich war alles nen zufall oder falsch eingestellt von mir ich werde das beobachten.
EDIT:
Das ist bei meinem 5950 auch so da kann ich dich beruhigen.
Über die LED Firmware kommt bei MSI auch ein Update für die Lüftersteuerung. Das taucht nicht unter der normalen BIOS Sektion auf. Da ich Dragon Center nach dem Update gleich wieder deinstalliert habe, kann ich nicht genau sagen unter welchem Punkt das Update für die LED/Lüftersteuerung war.
Kann mir mal einer erklären, warum bei manueller Voltage Eingabe das Unify trotzdem immer noch mehr draufgibt?
Ich habe gerade mal die Safe Timings aus dem DRAM Calculator versucht und bekomme nen Bluescreen beim Start "Memory_Management" und "Critical Process has died"
Bin derzeit bei A82 Bios und habe nur 3200mhz Ram mit Samsung B-Die. Sollten die Safe Timings nicht laufen?
Also ich habe jetzt das Beta Bios A86 für das Unify am laufen mit Curve Optimizer -7 und IF 1800 Festgenagelt sowie meine B-Die auf 3600@14/15/15/15/30.
Mit dem Stable hatte ich nur Whea erros im idle.Momentam lasse ich den Ramtest laufen und beobachte mit hwinfo die Whea fehler die noch auf 0 sind.Ich hoffe mal das es stabil bleibt.
Mit dem xmp auf 3200 war alles stabil ohne fehler.
@monitorhero
Du befindest dich im Bios. Die anderen sichtbaren Einstellungen machen für meine Begriffe teils auch nicht viel Sinn.
Bei meinem alten Gigabyte war es genauso 1,35v eingestellt und 1,376 wurden angezeigt.Ich gehe bei meinen B-Die bis auf 1,4v egal was da angezeigt wird und das ohne bedenken.
Aber sollte meine SOC Spannung nicht die sein, die ich auch eingebe? Und hast du eine Ahnung, warum die Safe Timings des Ryzen DRAM Calculators nicht funktionieren?
Soc Spannung ist so das letzte Stellrädchen, was ich anpacken würde, wenn überhaupt. CPU Corespannung auf AMD-Overclocking, Soc Auto. Dram zunächst händisch auf 1.35V, zumindest ist das die Spannung, die mein OC-Ram braucht und die nicht automatisch gesetzt wird. Soc bringt zu schnell Instabilitäten, weshalb ich für gewöhnlich zunächst meinen gewünschten Takt einstelle, den der Dram/IF mitmacht (3800/1900), dann langsam an die Timings mit mehr Spannung und gucken, ob es stabil läuft.
Ich habe SOC und DRAM manuell eingestellt, da ich davor Instabilität hatte und meine Spiele eingefroren sind. Mit diesen Voltages hatte ich dann keine Probleme mehr. Als die SOC auf Auto war lief es nicht wirklich. Hier ein separater Thread zu den Problemen.
Über die RMA Threads zu jedem PC-Bauteil von dir bin ich schon gestolpert. Und AMD-Overclocking bei der CPU Voltage würde ich immernoch einstellen, gepaart mit Testläufen.
Zu jedem Bauteil? Außer dem GPU Thread hab ich doch nichts sonst eröffnet? Ich hatte nur die GPU im Verdacht, da ich mit der 1080ti davor keine Probleme hatte mit Freezes etc.
Und was macht AMD-Overclocking? Ich hoffe es nimmt Voltage weg, da laut HWINFO64 ständig über 1.4V anliegen.
Edit: Nachdem ich AMD Overclocking aktiviert habe und die SoC Spannung wieder auf Auto gestellt habe, laggt der PC schon beim Login Menü. Sehr strange
Also das Beta bios ist schonmal echt nicht schlecht da ist einiges verbessert worden.
AMD Overclocking bewirkt, dass die einzelnen Cores in den Ruhezustand wechseln können. Gepaart mit den Energieoptionen Minimalzustand der CPU 85% sollten sich ungenutzte Cores abschalten und ungenutzte Cores brauchen weder Spannung, noch produzieren sie Abwärme...
@raev war so freundlich meinen RAM bei sich zu prüfen und hatte auch Probleme beim XMP laden.
Ging wohl nur mit manuellen Anpassungen u.A. der Voltage auf 1.45+
So weit bin ich garnicht gegangen. Andersrum lief sein RAM bei mir problemlos.
Falls Du mit den Patriots weiter ein Problem hast, empfehle ich als 32GB Module die Crucial Ballistix DDR4-3600 2x32GB (BL2K32G36C16U4B). Die laufen auf dem ACE auch mit 3800-CL16-18-18-38 ohne Probleme.
Danke dir, habe ich soeben bestellt und hoffe das meine Probleme nun endlich aus der Welt sind.
Dies erstmal abschließend, das Ace ist also nicht Schuld :d
@monitorhero macht das Ace auch, voltage auf 1.35 gesetzt und er legt zwischen 1.36 und 1.37 an.
Sowohl latest stable als auch Beta bios.
Freut mich zu hören, dass es nicht das ACE war. Ich bin noch immer auf der Suche nach den Ursachen für meine Probleme. Aber verursacht fehlerhafter RAM Ausschläge in Frametimes bei Benchmarks? Dachte sowas ist eher auf die CPU oder GPU zurückzuführen. Ich hoffe MSI kommt mal in die Pötte und released ein finales Bios.
Ich hab mal ne Frage: Ich benutze bisher Allcore OC bzw. Undervolten mit meinem 5800x. Ich würde aber lieber mit PBO/Curve etc. arbeiten. Was mich davon abhält ist das mit meinen Allcore Einstellungen die Temperaturen schön gleichmäßig bleiben. Also im Idle kaum Temperatur und beim öffnen von jeglichen Programmen keine Temperatur Spikes.
Effizienter ist Leistungsmäßig aber die Variante PBO und mit Curve rumspielen. Was mich da stört, ist das bei jeglicher Aktion im Windows schießen 1-2 Kerne auf 5Ghz und die Temperatur geht für 1-2Sek auf 70°C+. Ist vom Prinzip her ja auch völlig in Ordnung. Allerdings nervt mich dieses kurze Lüfter aufheulen im Windows Betrieb. Gibt es eine Möglichkeit, dass man eine Verzögerung einbauen kann, sodass die Lüfter die Temperatur erst "akzeptieren" wenn sie länger als X Sekunden anliegt? Im Afterburner gibts dazu ja eine Option für die Graka. Gibts da eine BIOS Funktion die ich übersehe oder eventuell eine Software für? Am besten kein Dragon Center Mist :d.
Ich finde es schon bedenklich, dass deine Spike-Temps bis auf 70°C reichen. Bei mir gehts da so auf max. 55°C rauf, was noch in Ordnung geht. Aber du kannst per Curve Optimizer mal probieren, wie es aussieht, wenn du für alle Kerne -10 hinterlegst.
@FM4E @CyR4DiS ich habe genauso Spikes. Beim spielen wenn die CPU hochtaktet auf bis zu 5 Ghz habe ich sogar 87°C auf einem CCD. Genau das gleiche Problem gehabt mit dem Aufheulen der Lüfter durch diese nervigen Spikes. Bin deshalb auf ne Wasserkühlung umgestiegen und habe die Lüfterverzögerung auf 0.7 Sekunden gesetzt. Die Heatspreader von Ryzen 3000/5000 sind sehr uneben und der Kühler hat manchmal keinen guten Kontakt an den äußeren Kanten, wo die CCDs sitzen. Dazu hat Igors Lab eine gute Analyse durchgeführt. Außerdem sind die Ryzen 5000 noch heißer als Ryzen 3000 zumindest nach meiner Erfahrung. Die Streuung in den Bins ist wohl sehr groß. Auf Reddit findest du unzählige Beiträge mit dem gleichen Problem. AllCore ist wohl die beste Wahl und eine Lüfterverzögerung.
@CyR4DiS
Alternativ kannst du auch deine Lüftersteuerung ein wenig entschärfend einstellen, dass diese nicht gleich sofort aufdreht. Bei mir habe ich es so eingestellt, dass ab 70°C CPU-Temp der CPU-FAN auf max. Umdrehungen geht. Den höre ich dann kaum. Die drei Gehäuselüfter bleiben dann aber zunächst bei etwa 1.000 Umdrehungen (von max. 1.600). Erst ab 80°C geben auch die alles, um die Hitze hinauszubefördern.
Du hast einen 5950x oder?
Schau mal in's MSi Support Forum. Oberhalb von 3200 MHz geht bei mir auch nix, egal was ich für Timings mache...
Somit gehen die RAMs sowie die Alternate CPU zurück, ich bestelle dann ein Kit aus 2x32 gb Patriot Viper Blackout -> PVB464G360C8K
Problem somit gelöst, der RAM war es. Das Ace verhält sich mit dem XMP auslesen sowie CMOS clear nicht immer ganz einwandfrei aber da gehe ich mal von einem Fix bei zukünftigen BOIS versionen aus.
Ich habe das PVB464G360C8K im X570 Tomahawk und es läuft nicht mit mehr als 3200 MHz.
Soweit ich herausfinden konnte sind hier Samsung M-Die RAMs verbaut - keine Ahnung was dies genau bedeutet.
Da wissen die Experten sicher mehr.
Manuell 3200 MHz und Default läuft, XMP geht leider gar kein Profil.
Ich warte hier immer noch auf ein finales AGESA Update bevor die Dinger bei Patriot wegen RMA landen.
Alternate hat mir die verkauft und beruft sich auf Ryzen 5950x kann nur bis 3200MHz.
MSI schreibt im Supportforum dass es Overclocking wäre (XMP Profil...) und auch kein Mangel vorliegen würde... jooo... werd an die Sprüche vor der nächsten Bestellung denken und andere Hersteller wählen...
Ok interessant. Ich habe jedoch nicht mehr als 3200mhz eingestellt und trotzdem Bluescreens mit dem 5950x. Das raubt mir etwas die Hoffnung, dass es noch Verbesserungen gibt in Zukunft. Habe auch immer wieder Ruckler in Spielen und auch im Desktopbetrieb stottern Videos wenn ich parallel zB Photoshop öffne. Vielleicht muss ich dann doch wieder auf Asus umsteigen, wenn sich MSI bei XMP nicht bemüht
BIOS A.82, XMP mit DDR4-3600 läuft bei mir absolut rund (ohne WHEA-Fehler). Daher würde ich es zunächst nicht auf das Board selbst schieben. Es kommt eben auf die jeweilige Kombination an.
Welche Timings und welchen Board nutzt du?
Welches Board?
Steht unter System: MEG X570 UNIFY
Oder meinst du die Board-Revision?
Ähnliche Themen
