[Sammelthread] MSI MEG X570(S) Unify (X MAX) / ACE (MAX) (AM4)
product_10_20191002132606_5d9434ee62129.pngproduct_9_20190723092258_5d3661724d540.pngproduct_1629079667f4b88b2d70e858818adcfd4767cd52a2.pngproduct_1629094385a72f0a5d4a37c30deff6b3dcba91659c.png
Sammelthread für das MSI MEG x570 Unify/ACE
Herstellerseite:
MEG X570 UNIFY
Herstellerseite: MEG X570 ACE
Herstellerseite: MEG X570S ACE MAX
Herstellerseite: MEG X570S UNIFY-X MAX
Reviews:
MSI MEG X570 UNIFY Review - Introduction
MSI MEG X570 Unify motherboard (updated)
MSI MEG X570 Unify: An All-Black Motherboard
MSI MEG X570 Unify kommt ohne RGB aus
MSI MEG X570 Unify | Tom's Hardware
MSI MEG X570 ACE Infinity | Hardwareluxx
MSI MEG X570 Ace Motherboard Review
MSI MEG X570 Ace - Review 2019 - PCMag UK
MSI MEG X570 ACE - Hardware Journal
MSI MEG X570 ACE - Review
MSI MEG X570S ACE MAX - digideutsche
MSI MEG X570S ACE MAX - wccftech
MSI MEG X570S ACE MAX - IT Info
MSI MEG X570S UNIFY-X MAX - geeknetic
Besonderheiten:
  • Supports 2nd and 3rd Gen AMD Ryzen™ / Ryzen™ with Radeon™ Vega Graphics and 2nd Gen AMD Ryzen™ with Radeon™ Graphics Desktop Processors for AM4 socket
  • Supports DDR4 Memory, up to 5000+(OC) MHz
  • Aluminum Cover with Extended Heatsink: All-metal extended heatsink cover enlarge the surface of heat dissipation, ensures even high-end processors to run in full speed.
  • Lightning Fast Game Experience: PCIe 4.0, Triple Lightning Gen4 x4 M.2 with M.2 Shield Frozr, StoreMI, AMD Turbo USB 3.2 Gen2.
  • 2.5G Gaming LAN with Latest Wi-Fi 6 Solution: Onboard 2.5G LAN with gaming LAN manager, combining latest Wi-Fi 6 solution which supports MU-MIMO and BSS color technology, delivering the best online gaming experience.
  • Frozr Heatsink Design: Designed with the patented fan and double ball bearings to provide the best performance for enthusiast gamers and prosumers.
  • Audio Boost HD: Isolated audio with dedicated processor combining ESS audio DAC with amplifier, deliver the breathtaking, game-changing sound to create the most exciting gameplay.
  • Pre-installed I/O Shielding: Better EMI protection and more convenience for installation
  • ACE: Mystic Light Infinity, Dual LAN, Extended Heat-pipe Design
Spezifikationen Unify/ACE/ACE MAX/Unify X:
SOCKET:
AM4
CPU (MAX SUPPORT): Ryzen 9
CHIPSET:
AMD® X570 Chipset
DDR4 MEMORY: 1866/ 2133/ 2400/ 2667/ 2800/2933 /3000 /3066 /3200 /3466 /3600 /3733 /3866 /4000 /4133 /4266 /4400 /4533 /4600 /4733 /4800 /5000+ Mhz by JEDEC and A-XMP OC MODE
MEMORY CHANNEL: Dual
DIMM SLOTS: 2/4
MAX MEMORY (GB): 128GB
PCI-E X16: 3
PCI-E X1: 2
SATAIII: 4
M.2 SLOT: 3/4/6
RAID: 0/1/10
TPM (HEADER): 1
LAN UNIFY/UNIFY X: 1x Realtek® RTL8125 2.5 Gbps
LAN ACE/ACE MAX: 1x Intel® WGI211AT Gigabit / Intel® Wi-Fi 6E AX210, 1x Realtek® RTL8125 2.5 Gbps
USB 3.2 PORTS (FRONT): 1(Gen2, Type C), 4(Gen1, Type A)
USB 3.2 PORTS (REAR): 1(Gen2, Type C), 3(Gen2, Type A), 2(Gen1, Type A)
USB 2.0 PORTS (FRONT): 4
USB 2.0 PORTS (REAR): 2
AUDIO PORTS (REAR): 5+ Optical S/PDIF (Realtek® ALC1220 Codec)
DIRECTX: 12
FORM FACTOR: ATX
SLI: Y
CROSSFIRE: Y
OPERATING SYSTEM: Support for Windows® 10 64-bit
MSI Support bei hwluxx.
Hier ein paar Bilder zu denn Boards:
Ich bin mir ziemlich sicher, dass es nicht an der CPU liegt und dass der RAM auch keine Probleme hat. Versuch es mal so wie ich, mit manueller Eingabe der Timings und ohne XMP. Vielleicht auch die Timings entschärfen.
Probiere ich mal aus. Single oder Dual DIMM? Der eine Dimm war ja nicht ganz so geil, aber mittlerweile denke ich nicht dass der dafür verantwortlich ist.
Welche Timings sollte ich alle ANpassen?
Dual DIMM bei mir. Ich hab erstmal nur die primären Timings angepasst. Von Subtimings fehlt mir auch das Verständnis. Wenn du DIMM sagst, meinst du einzelne Sticks? Du hast also zu einem Riegel nen anderen dazugekauft und es war kein Kit?
EDIT: Übrigens sind 550W nicht ein bisschen mager für dein System?
Genau so ist es bei mir auch. Hm komisch, ich habe mir bei einem 5600x ein ähnliches Ergebniss erwartet. Aber gut, bei mit ist die Temperaturdifferenz auch "nur" 5 °C.
Du hast wenigstens 5 Grad weniger.
Korrekt. Wenn ich von DIMMs spreche meine ich Arbeitsspeicherriegel bzw. Sticks.
Der eine Stick kommt aus dem Outlet, der andere aus dem regulären Shop, allerdings sind die baugleich.
Mit primären Timings meinst du die Settings bei Advanced DRAM Configuration -> tCL, TRCD, tRP und tRAS?
Genau die 4 habe ich geändert. Ich habe auch mit zwei baugleichen Kits Probleme gehabt, wenn sie zusammen laufen. Da gab es bereits nach 10% ein Fehler im Memtest. Aber auch ein einzelnes Kit aus 2x16 Gb Modulen macht noch Probleme mit XMP.
Auch wenn ich das XMP Profil manuel setze bleibt das Fehlerbild gleich.
Ich habe mittlerweile alles mögliche durchgetestet, VDDG& VDDP manuel angepasst, Vcore angepasst, xmp an, xmp aus.
2 CPUs, 2 DIMMS, alles was über 3200/1600 geht ist entweder nicht stabil oder wirft im memtest fehler im dual.
Wenn der Test mit den beiden andren DIMMs morgen keine Besserung gibt (die in einem anderen Build einwandfrei laufen) dann ist es das ACE.
Sollte ich die RMA über MSI oder den Händler anstoßen?
Edit: Kann man das BIOS vollständig neu draufspielen um mögliche Altlasten loszuwerden?
Hast du die DIMMs schon separat getestet? Vielleicht ist dann doch einer der beiden defekt
Ja ich habe alles Testszenarien sowohl im Dual als auch jeweils Single durchgeführt. Das ganze auch an beiden CPUs. Viel mehr kann man nicht machen.
Aber du hast noch einen zweiten Rechner wenn ich das richtig gesehen habe? Damit du den RAM ausschließen kannst als Fehlerquelle. Aber wenn er da funktioniert ist es das Board. Die Frage ist nur, obs am Bios liegt oder das Board einen Schlag abbekommen hat.
Habe das gar nicht mehr gesehen. sorry. Naja das Focus Plus Gold ist ja generell ein recht gutes NT, habe damit bereits problemlos einen 1600X sowie eine Vega 64 im OC betrieben, die ziehen sich in Lastspitzen ja auch ordentlich.
Weiterhin hatte ich ja mit dem ACE, 5950X sowie dem GSKILL mit XMP Profil keine Probleme.
Die Probleme gingen ja los als ich versucht habe das XMP der Patriots zu laden die über der "magischen" 3200 Grenze liegen.
Einen 2. Rechner habe ich nicht, lediglich das alte Brett mit 1600X und Asus Prime X370-A liegen hier noch.
Ich bekomme morgen von einem Kumpel die gleichen Patriot 2x 32 GB 3600 CL18 die ich auch habe, die laufen bei ihm auf einem MSI X570 Creation mit 5900X Problemlos mit XMP sowie darüber.
Das Creation ist dem Unify ja auch sehr ähnlich, wobei es nur eine Phase für RAM hat, wenn ich das richtige verstehe. Bin kein Experte für VRM, also bitte korrigiert mich. Der Ram müsste dann ja auch bei dir laufen.
Aber vielleicht ist das Bios ausgereifter oder bekommt mehr Aufmerksamkeit von MSI (dürfte man erwarten bei dem Preis). Also bei meinem Rechner hat das XMP wohl Probleme verursacht. Trau der ganzen Sache aber noch nicht. Ich bin gespannt, was bei dir rauskommt. Ich hoffe ja für dich es ist de RAM. Mit RMA immer zuerst zum Händler, das geht garantiert schneller als über MSI
Gerade released. Von wegen Infinity Clocks gepushed :d
@taeddyyy
Hast Du denn bei den Riegeln im einzeln verbautem Zustand jeweils die Subtimings mal verglichen....
Sind zwar die gleichen Riegel, aber eben nicht als DUAL_Pack gekauft u.U. könnten sich auch abweichende Subtimings darauf befinden, und deshalb wollen die beiden nicht zusammen...
Nur so eine Idee.
Bei mir liegt das Maximum beim RAM mit dem neuen BIOS immer noch bei 3800/1900, 5900x. Mehr geht nicht. Mein 3900x schafft mehr.
Aber egal, gibt schlimmeres.
Beim balancing gehen auch nur maximal - 15, bringt auch in Sachen Leistung fast nichts.
Allerdings taktet meine CPU so schon recht hoch rauf, und recht kühl für einen 5900x bleibt sie auch.
Kommt wohl stark auf die CPU an, wie hoch die Stock vcore ist usw.
Mir ist gerade ein stranges Problem aufgefallen. Ich habe in Firefox ein Video laufen von Youtube. Starte ein Rendering und plötzlich wird der Sound dumpfer wie ein switch von Stereo auf Mono. Habe eine Soundblaster Z im System. Hat irgendwer änhliche Erfahrungen?
Kann mal jemand mit einen 5600x seinen L3 Cache mit Aida64 testen. Mit A82 komme ch nur auf 250 GB/s und mit A7 Bios auf 330 GB/s. Beides wäre aber viel zu wenig. Sollte doch über 500 GB/s sein eigentlich?
@taeddyyy
Nur so eine Idee.
Die einzelnen nicht verglichen, nein. Aber es ist mir ja nichtmal im Single möglich irgendwo in die nähe des XMP zu kommen, da brauche ich über Dual nicht nachdenken.
Mit Dual 3200 CL16-18-18-18-40 / 1600FCLK sowie Curve Optimizer -10 erreiche ich im CB MC 10151 sowie SC 639
Ab 3400 nimmt die Leistung ab, den FCLK brauche ich nicht anzupacken.
XMP ist in keiner Konstellation möglich.
Ich lasse mir wie gesagt heute baugleichen RAM zum testen geben, wenn es dabei dann bleibt geht das ACE zurück und ich bestelle mir entweder das Unify oder wechsel auf einen anderen Hersteller.
Diese Bios Problematik ist ja mal mega ätzend.
So es gibt Neuigkeiten.
Der Testram lief mit XMP einwandfrei, auch FCLK von 1800 problemlos. Alles getestet mit der MF CPU.
Weiterhin haben wir rausgefunden dass trotz gleicher modellnummer der Patriots einer SK Hynix und einer Samsung bestückt war und die XMP Profile nicht gleich waren.
Somit gehen die RAMs sowie die Alternate CPU zurück, ich bestelle dann ein Kit aus 2x32 gb Patriot Viper Blackout -> PVB464G360C8K
Problem somit gelöst, der RAM war es. Das Ace verhält sich mit dem XMP auslesen sowie CMOS clear nicht immer ganz einwandfrei aber da gehe ich mal von einem Fix bei zukünftigen BOIS versionen aus.
Also so, wie ich es schon vermutet hatte. Unterschiedliche Chips auf den DIMMs.
Jup, das war ein Griff ins Klo. Das war das erste und letzte mal das ich kein Kit bestelle :d Danke euch allen für die Tipps, nächstes mal achte ich direkt drauf :)
Die Patriots sind wohl auch nicht erste Sahne, für 3600cl18/1800 sollte das aber wohl reichen.
Das man besser immer Kits kaufen sollte ist aber nichts neues statt Module einzeln zu kaufen.
@Scoty schon klar. Das Problem was ja so für Verwirrung gesorgt hatte war ja aber , dass ich unglücklicherweise 2 defekte Dimms sowie ein zickiges Bios hatte. Da kamen verschiedene Dinge zusammen die das ganze sehr undurchsichtig gemacht haben.
Viel Spaß mit dem Brett :bigok:
Ich muss man sagen, dass ich eine Zeit lang immer wieder einfach komische Restarts hatte ohne wirklich erkennbaren Grund mit ACE & 5950X - allerdings scheint das neue BIOS mit AGESA 1.2.0.0 wirklich zu helfen. Da bin ich auf jeden Fall erleichtert, weil 1.1.9.0 lief echt bescheiden in meinen Augen. Gerade mit Curve Optimizer konnte mein PC sich nicht wirklich anfreunden.
Stand jetzt läuft aber alles super, 5950X mit all core negativ 12 und 3600er CL16 RAM mit 1800 FLCK
@Bobby53 das wird auch exakt meine Config sein, was macht dein Sys im CB MC & SC?
Ach verdammt sry :d Die letzten Tage waren ziemlich holprig, entschuldige :fresse:
Ähnliche Themen
