[Sammelthread] MSI MEG X570(S) Unify (X MAX) / ACE (MAX) (AM4)
product_10_20191002132606_5d9434ee62129.pngproduct_9_20190723092258_5d3661724d540.pngproduct_1629079667f4b88b2d70e858818adcfd4767cd52a2.pngproduct_1629094385a72f0a5d4a37c30deff6b3dcba91659c.png
Sammelthread für das MSI MEG x570 Unify/ACE
Herstellerseite:
MEG X570 UNIFY
Herstellerseite: MEG X570 ACE
Herstellerseite: MEG X570S ACE MAX
Herstellerseite: MEG X570S UNIFY-X MAX
Reviews:
MSI MEG X570 UNIFY Review - Introduction
MSI MEG X570 Unify motherboard (updated)
MSI MEG X570 Unify: An All-Black Motherboard
MSI MEG X570 Unify kommt ohne RGB aus
MSI MEG X570 Unify | Tom's Hardware
MSI MEG X570 ACE Infinity | Hardwareluxx
MSI MEG X570 Ace Motherboard Review
MSI MEG X570 Ace - Review 2019 - PCMag UK
MSI MEG X570 ACE - Hardware Journal
MSI MEG X570 ACE - Review
MSI MEG X570S ACE MAX - digideutsche
MSI MEG X570S ACE MAX - wccftech
MSI MEG X570S ACE MAX - IT Info
MSI MEG X570S UNIFY-X MAX - geeknetic
Besonderheiten:
  • Supports 2nd and 3rd Gen AMD Ryzen™ / Ryzen™ with Radeon™ Vega Graphics and 2nd Gen AMD Ryzen™ with Radeon™ Graphics Desktop Processors for AM4 socket
  • Supports DDR4 Memory, up to 5000+(OC) MHz
  • Aluminum Cover with Extended Heatsink: All-metal extended heatsink cover enlarge the surface of heat dissipation, ensures even high-end processors to run in full speed.
  • Lightning Fast Game Experience: PCIe 4.0, Triple Lightning Gen4 x4 M.2 with M.2 Shield Frozr, StoreMI, AMD Turbo USB 3.2 Gen2.
  • 2.5G Gaming LAN with Latest Wi-Fi 6 Solution: Onboard 2.5G LAN with gaming LAN manager, combining latest Wi-Fi 6 solution which supports MU-MIMO and BSS color technology, delivering the best online gaming experience.
  • Frozr Heatsink Design: Designed with the patented fan and double ball bearings to provide the best performance for enthusiast gamers and prosumers.
  • Audio Boost HD: Isolated audio with dedicated processor combining ESS audio DAC with amplifier, deliver the breathtaking, game-changing sound to create the most exciting gameplay.
  • Pre-installed I/O Shielding: Better EMI protection and more convenience for installation
  • ACE: Mystic Light Infinity, Dual LAN, Extended Heat-pipe Design
Spezifikationen Unify/ACE/ACE MAX/Unify X:
SOCKET:
AM4
CPU (MAX SUPPORT): Ryzen 9
CHIPSET:
AMD® X570 Chipset
DDR4 MEMORY: 1866/ 2133/ 2400/ 2667/ 2800/2933 /3000 /3066 /3200 /3466 /3600 /3733 /3866 /4000 /4133 /4266 /4400 /4533 /4600 /4733 /4800 /5000+ Mhz by JEDEC and A-XMP OC MODE
MEMORY CHANNEL: Dual
DIMM SLOTS: 2/4
MAX MEMORY (GB): 128GB
PCI-E X16: 3
PCI-E X1: 2
SATAIII: 4
M.2 SLOT: 3/4/6
RAID: 0/1/10
TPM (HEADER): 1
LAN UNIFY/UNIFY X: 1x Realtek® RTL8125 2.5 Gbps
LAN ACE/ACE MAX: 1x Intel® WGI211AT Gigabit / Intel® Wi-Fi 6E AX210, 1x Realtek® RTL8125 2.5 Gbps
USB 3.2 PORTS (FRONT): 1(Gen2, Type C), 4(Gen1, Type A)
USB 3.2 PORTS (REAR): 1(Gen2, Type C), 3(Gen2, Type A), 2(Gen1, Type A)
USB 2.0 PORTS (FRONT): 4
USB 2.0 PORTS (REAR): 2
AUDIO PORTS (REAR): 5+ Optical S/PDIF (Realtek® ALC1220 Codec)
DIRECTX: 12
FORM FACTOR: ATX
SLI: Y
CROSSFIRE: Y
OPERATING SYSTEM: Support for Windows® 10 64-bit
MSI Support bei hwluxx.
Hier ein paar Bilder zu denn Boards:
@Darkne$$ also bei den settings crashed mein System, wenn ich CB23 laufen lasse. Beim ersten Boot wurde ich auch mit einem bluescreen begrüßt.
Auch wenn die Frage eher allgemein ist: Ist es möglich einen DIMM statt 2 zu nutzen und damit mal das System zu testen auf höheren FCLK und XMP Profil?
Mich beschleicht die Vermutung das ein DIMM defekt ist.
Würde ein funktiuonierendes XMP mit 3600 sowie 1800FCLK mit single DIMM darauf hinweisen dass entweder ein DIMM defekt ist oder der Memory Controller einen weg hat?
Beim Memtest im Dual gabs 4 Fehler, der Single mit dem ersten DIMM läuft ohne Probleme durch.
Dass der Memory-Controller einen weg hat, kann man zwar nicht ausschließen, ist aber eher unwahrscheinlich. Wahrscheinlicher ist dafür mehr, dass die eben unterschiedlich hohen Speichertakt vertragen. Daher würde ich es in deinem Fall einfach mal ausprobieren und nur ein DIMM drinlassen und schauen, wie sich das System dann verhält.
@FM4E ich vermute (hoffe) aktuell, dass der RAM einen weg hat. Habe den einen DIMM aus dem Alternate Outlet, den anderen aus dem Shop. Ich bin bisher so weit:
XMP mit Dual DIMMs ist nicht nutzbar, egal ob FCLK 1600 oder 1800.
Folgende Settings: RAM 3400, CL 16-19-19-19-43 FCLK 1600 DRAM V 1.35
Dual DIMMs: Windows Stable, Cinebench läuft durch,Cinebench MC 9934 SC 636
Memtest Schmeißt ab Run 2 Fehler.
Single DIMM mit dem Shop RAM ist Windows stable, Cinebench MC 9961, SC 637
Memtest ist grade bei Run 3/4 ohne Fehler.
Sobald der durch ist werde ich anfangen den outlet RAM zu testen.
5900x. Bin mittlerweile bei 25. Alles zwischen 25 und 30 stürzt ab. 25 lief durch.
Das AllCore -30 die 5600x und 5900x schaffen wie der Typ im Video meint betweife ich. Ich werde meinen 5600x später testen.
@Scoty ich denke auch, dass das auf die CPU ankommt und er eben Glück gehabt hat mit seinem 5600x und 5900x.
So, meiner läuft mit Negative 25 durch. All Core und Single Core. 25 - 30 crashed.
Bin mir unschlüssig, was nun wirklich besser ist.
Mein manuelles OC mit fester Vcore:
All Core: 4,5 GHz bei 1.16 V, Package Power im Durchschnitt 145 W, Temperatur im Durchschnitt 71,5 und 22820 Punkte (CB R23)
Single Core: 4,5 GHz bei 1.16 V, Package Power im Durchschnitt 44,7 W, Temperatur im Durchschnitt 51,2 und 1484 Punkte (CB 23)
Mit Curve Optimizer (-20):
All Core: ~4,34 Ghz, ~1.1 V, PP 131 W, Temperatur 66,7 und 21990 Punkte
Single Core: bis zu 4,9 GHz, ~1,413 V, PP 57 W, Temp im Durchschnitt 63 und 1627 Punkte
Ich bezweifle, dass dein RAM einen weg hat. Ich habe auch Probleme auf dem Unify mit meinen Kits, was mit nem 9900k problemlos lief out of the box. Ich hatte gehofft mit Ryzen 5000 hätte sich diese XMP Problematik endlich erledigt, zumal mein RAM in der QVL drin ist. Ich hatte mit nem 1800x angefangen mit dem selben Kit und schon damals Probleme. Trotz tollem Samsung B-Die, was immer gepriesen wird.
Ich habe jetzt XMP deaktiviert und gestern und heute jeweils 2 Std gezockt und keine Freezes mehr (jedoch mit 3000mhz und CL18 statt CL14). Also entweder ist der Memory Controller mies oder es liegt am aktuellen Bios.
Der 5950x hat wohl weniger Spielraum. Was ich auch glaube, wenn ich so auf Reddit die Erfahrung lese.
@Murazor Ich würde fast den Curve Optimizer nehmen. Die paar Punkte sind doch letztlich egal, dafür hast du jetzt weniger Spannung und bessere Temps bei AllCore Loads und bessere Single Core Leistung.
@monitorhero Ich lasse jetzt noch die Memtests laufen, das wird wohl bis heute Abend andauern. Die BIOS Updates vom Ace haben ja keine Änderung gebracht, daher wirds wohl nicht am Brett liegen sondern CPU oder RAM.
Danach wird die CPU gewechselt und das gleiche Spiel beginnt von vorne.
Dann kann man definitiv ne Aussage treffen. Sollte es bei der Problematik bleiben werde ich das Set so wie es ist behalten und den Ram mit 3400 16-19-19-19 laufen lassen.
Der Preis vom 700€ für die CPU ist mir das kleine übel von 1-2 % Leistungseinbußen wert.
Vor allem ist das ja alles schon OC, mit 3200/1600 gibt es ja keine Probleme und das sind die beworbenen Angaben von AMD. Von einer defekten CPU kann man dann ja nicht sprechen, nur ein schlechtes sample.
Edit: Die Spannungsversorgung vom Ace/Unify sind doch identisch und auf einem hohen Niveau oder?
Das stimmt schon. Aber dafür habe ich im idle bzw. beim einfachen Surfen wieder höhrere Temperaturen. Muss ich aber erst nochmal beobachten. Und ich hoffe, dass mit dem Curve Optimizer die Temperatur nicht wie früher gerne mal auf über 60 °C springt für 2 - 3 Sekunden.
Ich habe heute mal ein paar Stunden gezockt. Weiß einer, warum ich so krasse Deltas in den CCDs habe? Werden beim Gaming immer nur die Cores auf CCD1 angesprochen, weil die schneller sind?
Diese Temperaturspikes finde ich auch störend.
Was mir da abseits der generellen Stabilitätsprobleme derzeit einfällt: Haben denn beide DIMMs die gleichen ICs und Timing-Angaben? Eventuell vertragen die sich auch nicht.
Temperaturspikes sind völlig normal seit Ryzen. Ist also nicht wirklich was neues.
Ja, aber mit manuellem OC konnte man dem wenigstens entgegen wirken. Aber mit dem Curve Optimizer habe ich in der kurzen Zeit noch keine feststellen können. Mal sehen.
Ja, mit Undervolting kann man das schon ein wenig begrenzen. Aber kleinere Spikes bei kleinsten Anstrengungen sind eben immer mal da und halt normal für die Ryzen-Prozessoren.
Einfach mal testen, vor dem A85 Beta Bios ging bei mir auch keine -30.
Habe heute eine neue Grafikkarte eingebaut, dann nochmal die Cpupaste gewechselt von MX4 auf Kryonaut und den Anpressdruck erhöht. Vielleicht saß der Kühler vorher auch nicht richtig und siehe da nochmal ca 5-6 Grad bessere Temperaturen.
Der Wechsel von der MX4 auf die Kryonaut macht garantiert keine 5-6 Grad aus. Das schafft leine Paste am Markt. Was die Pasten betrifft so gibt es da maximal 1-2 Grad unterschied, mehr aber sicher nicht von daher ist es auch völlig egal ob man eine kauft um 2 Euro oder 20 Euro. Alles nur Marketing blabla.
Okay, dann war der Kühler nicht richtig drauf :wall:
So habe jetzt denn Curve getestet und es gab keinen Unterschied was die Temps betrifft, egal ob mit -20 oder -30.. Habe 2x CB15 und 2x CB20 laufen lassen und die Temps waren immer um die 64 bis 65 Grad. Punkte gab es zwischen 59 und 100 mehr. Whea oder bootfehler gab es nicht mit -30.
Habe aber nicht alle Settings 1:1 Übernommen, nur rein die Curve Settings alles andere weicht leicht ab.
Ich zitiere mich mal selbst für die Übersichtlichkeit.
Ergänzend dazu neue Ergebnisse:
Der Shop RAM läuft mit o.g. Settings ohne Probleme durch.
Sobald ich XMP lade schmeißt mir der RAM haufenweise Fehler.
Habe daraufhin die CPU gegen den anderen 5950X getauscht welcher von Alternate kommt.
Memtest schmeißt mit XMP Single Ram weiterhin Fehler, selbes Spiel wie mit der MF CPU.
Auch verhält sich Windows exakt gleich mit Alternate sowie MF CPU. Also entweder habe ich mit beiden CPUs ins Klo gegriffen oder das Problem sitzt woanders.
Also RAM oder das ACE.
Ich habe die Möglichkeit den gleichen RAM von einem Kumpel zu bekommen und zu testen, das stoße ich gerade an.
Wenn es bei den Problemen bleibt ist doch ziemlich sicher das ACE defekt oder?
Habt ihr noch Vorschläge was man noch testen kann?
@Darkne$$ bei dir laut Screenshot sind LND2 Mode beide Disabled. Warum bzw wozu? Habe jetzt mal 1:1 eingestellt wie auf deinen Screenshot auch, macht aber auch keinen Unterschied bei mir was die Temps oder Punkte betrifft.
Das hier manche doch weniger Temps haben verstehe ich daher nicht warum es bei mir überhaupt nichts bringt. Oder habt ihr an der Voltage auch was verändert?
Hast du das mit dem A86-BIOS ausprobiert? Falls ja, finde ich es schon schade, wenn sich an den Temps nichts ändert. Ich fahre aktuell noch das A82-BIOS und habe für alle Kerne beim CO -10 hinterlegt und das macht sich bei der VCore und auch bei den Temps entsprechend bemerkbar. Mich interessiert generell nur Undervolting, da @ Stock zuviel Hitze entsteht. Alternativ kann man das natürlich mittels normalem Offset realisieren, aber ob dann die Turbo-Modi noch funktionieren ist dann die Frage.
Ich würde nun zunächst einmal anderen RAM ausprobieren. Wenn das dann auch nichts ändert, dann würde ich das Board verdächtigen.
@FM4E habe es mit dem A86 getestet gehabt. Ihr habe alle einen 5900x bzw die meisten, ich ja nur einen 5600x. Allerdings laut dem YT Video sollte gerade der 5600x eigentlich am meisten Profitieren was ich nicht bestätigen kann bei mir. Ka warum, irgendwas passt dann wohl nicht aber mehr als die Settings 1:1 zu übernehmen kann ich ja nicht.
Mit der anderen CPU sowie Single XMP habe ich das gleich verhalten.
Habe mittlerweile alles getestet. 2 CPUs, 2 DIMMs in allen möglichen Zusammensetzungen, die einzige Konstante ist das Mainboard.
Morgen bekomme ich den anderen RAM der auf einem MSI Creation mit einem 5900X ohne Probleme mit XMP und darüber läuft, sollte das auch nicht klappen ist es zu 99% das Brett.
@Scoty auf was hast du PBO Limits gestellt?
Also ich habe auch das A82 und keine tollen Temps. Ich glaube da ändert auch ein Bios Update nichts.
@taeddyyy Ich bin mir ziemlich sicher, dass es nicht an der CPU liegt und dass der RAM auch keine Probleme hat. Versuch es mal so wie ich, mit manueller Eingabe der Timings und ohne XMP. Vielleicht auch die Timings entschärfen. Das wurde mir hier in einem anderen Thread empfohlen. Ich bin ziemlich sicher, dass die Mem Fehler eher am XMP Profil liegen und der Ram keinen weg hat. Ich habe alle Komponenten neu gekauft in letzter Zeit und auch Probleme mit dem Ram. 4 Kits gingen gar nicht, weil sie zu heiß wurden und dann Fehler ausspucken. Jetzt mit 2 Riegeln hatte ich im Memtest keine Fehler mehr, aber mit XMP Profil in Spielen Abstürze. Jetzt mit manuellen entschärften Timings läuft es. Aber hab noch nicht genug Langzeitests durchgeführt um wirklich sicher zu gehen, dass es das Problem gelöst hat.
@Darkne$$ Ist deine Kryonaut auch so verdammt zäh beim auftragen? In Tests schneidet die Paste auch nicht wirklich besser ab, teilweise sogar hinter ner MX-4 (1-2 Grad)
Wie im Video und auf denn Screenshot auf Disabled. Wenn ich das auf Auto lasse geht meine Temp schnell auf 82 Grad hoch.
Genau so ist es bei mir auch. Hm komisch, ich habe mir bei einem 5600x ein ähnliches Ergebniss erwartet. Aber gut, bei mit ist die Temperaturdifferenz auch "nur" 5 °C.
Ähnliche Themen
