[Sammelthread] MSI MEG X570(S) Unify (X MAX) / ACE (MAX) (AM4)
product_10_20191002132606_5d9434ee62129.pngproduct_9_20190723092258_5d3661724d540.pngproduct_1629079667f4b88b2d70e858818adcfd4767cd52a2.pngproduct_1629094385a72f0a5d4a37c30deff6b3dcba91659c.png
Sammelthread für das MSI MEG x570 Unify/ACE
Herstellerseite:
MEG X570 UNIFY
Herstellerseite: MEG X570 ACE
Herstellerseite: MEG X570S ACE MAX
Herstellerseite: MEG X570S UNIFY-X MAX
Reviews:
MSI MEG X570 UNIFY Review - Introduction
MSI MEG X570 Unify motherboard (updated)
MSI MEG X570 Unify: An All-Black Motherboard
MSI MEG X570 Unify kommt ohne RGB aus
MSI MEG X570 Unify | Tom's Hardware
MSI MEG X570 ACE Infinity | Hardwareluxx
MSI MEG X570 Ace Motherboard Review
MSI MEG X570 Ace - Review 2019 - PCMag UK
MSI MEG X570 ACE - Hardware Journal
MSI MEG X570 ACE - Review
MSI MEG X570S ACE MAX - digideutsche
MSI MEG X570S ACE MAX - wccftech
MSI MEG X570S ACE MAX - IT Info
MSI MEG X570S UNIFY-X MAX - geeknetic
Besonderheiten:
  • Supports 2nd and 3rd Gen AMD Ryzen™ / Ryzen™ with Radeon™ Vega Graphics and 2nd Gen AMD Ryzen™ with Radeon™ Graphics Desktop Processors for AM4 socket
  • Supports DDR4 Memory, up to 5000+(OC) MHz
  • Aluminum Cover with Extended Heatsink: All-metal extended heatsink cover enlarge the surface of heat dissipation, ensures even high-end processors to run in full speed.
  • Lightning Fast Game Experience: PCIe 4.0, Triple Lightning Gen4 x4 M.2 with M.2 Shield Frozr, StoreMI, AMD Turbo USB 3.2 Gen2.
  • 2.5G Gaming LAN with Latest Wi-Fi 6 Solution: Onboard 2.5G LAN with gaming LAN manager, combining latest Wi-Fi 6 solution which supports MU-MIMO and BSS color technology, delivering the best online gaming experience.
  • Frozr Heatsink Design: Designed with the patented fan and double ball bearings to provide the best performance for enthusiast gamers and prosumers.
  • Audio Boost HD: Isolated audio with dedicated processor combining ESS audio DAC with amplifier, deliver the breathtaking, game-changing sound to create the most exciting gameplay.
  • Pre-installed I/O Shielding: Better EMI protection and more convenience for installation
  • ACE: Mystic Light Infinity, Dual LAN, Extended Heat-pipe Design
Spezifikationen Unify/ACE/ACE MAX/Unify X:
SOCKET:
AM4
CPU (MAX SUPPORT): Ryzen 9
CHIPSET:
AMD® X570 Chipset
DDR4 MEMORY: 1866/ 2133/ 2400/ 2667/ 2800/2933 /3000 /3066 /3200 /3466 /3600 /3733 /3866 /4000 /4133 /4266 /4400 /4533 /4600 /4733 /4800 /5000+ Mhz by JEDEC and A-XMP OC MODE
MEMORY CHANNEL: Dual
DIMM SLOTS: 2/4
MAX MEMORY (GB): 128GB
PCI-E X16: 3
PCI-E X1: 2
SATAIII: 4
M.2 SLOT: 3/4/6
RAID: 0/1/10
TPM (HEADER): 1
LAN UNIFY/UNIFY X: 1x Realtek® RTL8125 2.5 Gbps
LAN ACE/ACE MAX: 1x Intel® WGI211AT Gigabit / Intel® Wi-Fi 6E AX210, 1x Realtek® RTL8125 2.5 Gbps
USB 3.2 PORTS (FRONT): 1(Gen2, Type C), 4(Gen1, Type A)
USB 3.2 PORTS (REAR): 1(Gen2, Type C), 3(Gen2, Type A), 2(Gen1, Type A)
USB 2.0 PORTS (FRONT): 4
USB 2.0 PORTS (REAR): 2
AUDIO PORTS (REAR): 5+ Optical S/PDIF (Realtek® ALC1220 Codec)
DIRECTX: 12
FORM FACTOR: ATX
SLI: Y
CROSSFIRE: Y
OPERATING SYSTEM: Support for Windows® 10 64-bit
MSI Support bei hwluxx.
Hier ein paar Bilder zu denn Boards:
Wenn ihr bereits alles durchprobiert habt (CMOS-Clear usw.), könnte sich derselbe Fehler eingeschlichen haben, wie beim letzten ASUS-Beta-BIOS, dass die Boards mit dem AGESA-1.1.9.0-BIOS zusammen mit dem 3300X nicht mehr booten können. Demnach bliebe das Warten auf eine neue BIOS-Version übrig. Alternativ müsst ihr auf die vorherige BIOS-Version zurückflashen, wobei SAM dann nicht möglich sein dürfte. Dies ist mit der RX 5700XT aber afaik sowieso nicht möglich.
Habe diverse Aussagen im CB gehört, dass die 5700XT und sogar ältere Radeons mit Sam funktionieren - sprich der "erweiterte Speicherbereich" dann im Gerätemanager angezeigt wird.
Hey, habe gerade bei meinem Bro auf dem X570 Gaming Edge das neue Beta BIOS installiert. Leider bootet damit das System nicht mehr; CPU Led geht an.
3300X, 5700XT und 2x8gb RAM. Wollte es installieren wegen Sam.
Gaming Edge? Dann bist du hier falsch...
@FM4E
Doch. Zb. mein zweites 570er Unify mit dem 85er Beta BIOS.
Ryzen 3900x mit Vega 64, SAM lässt sich nun aktivieren, mit dem 82er ging das noch nicht.
In Cyberpunk hab ich einen deutlichen fps Anstieg, von 33 auf 41fps. AC Valhalla bringt es nichts.
Ebenso beim MSI x470 pro Carbon, aktuelles BIOS, 2700x und Vega 64. SAM aktiviert. Cyberpunk von 32 auf 40fps, immer selbe Scene auf allen Rechnern.
AC Valhalla 2fps plus.
Es funktioniert definitiv 😉
@el3c Oh, danke für den Hinweis, das hab ich ja total übersehen. War mir nicht Bewusst, dass der Unterschied zwischen Unify und Gaming Edge so groß ist.
Wenn du drauf bestehst, dann lösch ich gleich meine Posts und mache einen eigenen Sammler für das Gaming Edge auf. Nicht dass hier noch irgendwie
Verwirrung aufkommt mit dieser doch recht spezifischen frage.
Alternativ kannst du auch im Mainboard-Unterforum einen Thread für dein Problem eröffnen, aber für mich sieht das schon nach einem BIOS-Fehler aus, wenn du die neueste Beta-BIOS-Version genommen hast und andere Fehler ausschließen kannst. Ich kann mich aber natürlich auch irren, denn das ist menschlich. ;)
Also denn Curve Optimicer verstehe ich nicht. Ich habe bei mir allcore -10 aber die Temperatur ging extrem hoch was eigentlich mit negative nicht sein dürfte. Mit Stock im CB20 um die 67 Grad, mit -10 dann aber 81 Grad. Verstehe es nicht. Sonst läuft die A85 sehr gut. Was sind die Default PPT, TDC, EDC Werte bei einen 5600x?
Auf denn Takt habe ich nicht wirklich geschaut. Ich hatte etwas höhere CB20 Werte. Mit Stock um die 4430, mit Curve -10 bzw -15 hatte ich dann knapp 4670. Stock erreiche ich im CB20 einen Takt zwischen 4.41 und 4.43 je nach Temp. Glaube mit dem Curve waren es dann um die 100Mhz bis 200Mhz mehr.
Moin, läuft auf dem Unify ein 1600X? Laut MSI Supportseite nicht, aber man kann ja mal fragen.
Also 1st Gen Ryzen sollen nicht laufen, wenn es ein AF ist könnte es sein, aber das könnte wäre mir es nicht wert-
@FM4E
Bei mir macht der 3900x die -10 auf allen Kernen nicht mit. Das Problem ist denk ich dann der hohe Takt. Stock ohne PBO bekomm ich auf core 1 und 3 schon immer wieder 4975mhz. Schalte ich PBO an und -10 auf allen Kernen dann geht's rauf bis 5050mhz, und dann meistens ein crash im Cinebench sc.
Habs mittlerweile aufgegeben, CPU ist auch stock ein Traum, und maximal 73 Grad passt auch.
Ich frag mich gerade, wie ein 3900x 4975mhz schafft? Sind die neuen Ryzen 5000 nicht wirklich schneller und es sind letztlich nur Bios Optimierungen? Mein 3900x hat jedenfalls niemals solche Taktraten gesehen und seit dem neuen AGESA haben selbst die alten Ryzen in den Single Core Taktraten massiv zugelegt.
@FM4E Mir sind die Temps auch deutlich zu hoch. Erreiche noch immer 86°C zwischenzeitlich beim Gaming. Bin extra auf den Arctic Liquid Freezer II umgestiegen. Muss man sich wohl dran gewöhnen. Ich versuche auch mal diesen Curve Optimizer. Was bedeutet denn dieses -10? mV?
@monitorhero
Sorry, natürlich mein 5900x. Verschrieben.
Hab beide, komm bei den ganzen Nummer immer wieder durcheinander.
Mein 3900x kommt leider nicht ganz auf den angegebenen Boost.
Ich hatte beim 3900x aber nach dem Update auf das neue Bios auch höhere Boosts festgestellt.
Hat sich bei mir von 82 auf 85 nicht merklich verändert.
Single Core Boost 4550, selten mal 4575mhz.
Multicore Boost 4075 bis 4100mhz.
Das ganze mit einer recht starken Wakü.
Der 5900x liegt generell deutlich über dem versprochenen Boost Takt, single wie Multicore last.
Schnell sind sie aber beide, bin super zufrieden damit. Nur eine zweite 6800xt fehlt noch, das wird noch dauern.
Edit, Temps liegen beim 3900x maximal bei 72 Grad, PBO aus. Also fast gleich wie beim 5900x. Würde mich von den Temps generell nicht verrückt machen lassen. PBO bringt etwas höhere Temps aber kaum höhere Leistung @monitorhero
Und der Curve Optimizer funktioniert beim 3000er nicht, ist 5000er only. Wird sich auch nicht ändern.
Installiert und weiterhin kein fclk von 1900mhz möglich. Mit dem 3950X gingen 2000mhz
kann auch am IMC des 5900X liegen
IF 1600 wären normal, wenn er IF 1800 macht ist das schon mal recht ordentlich, allerdings hatte ich mit dem Unify auch so meine Probleme mit meinen 4 FlareX Riegeln.
Auf dem Crosshair VI liefen die 3800 15-15-15-38 auf dem Unify nur noch mit 3600 16-16-16-42 und zuletzt gar nicht mehr. ...
Ebenso meine Vengeance LPX jetzt, mit dem A70 war bei 3200 Schluß, erst mit dem A83 liefen die 3600 wieder. NAja, jetzt mal Crucial bestellt und hofe das Beste.
Komme auch mit dem aktuellen Bios mit dem 5900x nicht über 1900IF, ist wie festgetackert dort. SoC OC oder auch UC probiert, 1933 nada... Denke das Gesamtpaket mit dem Speicher/Timings ist brauchbar. Ist aber ok, hab ich diesmal mal nicht soviel Glück wie mit meinem 3700x, der hatte auch die 1900IF gepackt.
Kann man als ACE User auch hier mitmachen? Gibt ja keinen Sammler fürs Ace :d
Gleichen sich die Biosverionen vom Unify und Ace? Ich mein große Unterschiede am Layout un der Ausstattung gibt es ja nicht.
Für das ACE was eigenes machen. Diese Diskussion gab es schon und muss nicht nochmal sein.
Ist doch fast das gleiche Brett ...
Ich habe mich damals dazu entschlossen es nur für das Unify zu machen und dabei bleibe ich auch. Was andere machen ist deren Sache.
Da der TE die Zusammenlegung konsequent ablehnt wurde ein neuer Sammler eröffnet.
Link in meiner Sig :)
Ähnliche Themen
