[Sammelthread] MSI MEG X570(S) Unify (X MAX) / ACE (MAX) (AM4)
product_10_20191002132606_5d9434ee62129.pngproduct_9_20190723092258_5d3661724d540.pngproduct_1629079667f4b88b2d70e858818adcfd4767cd52a2.pngproduct_1629094385a72f0a5d4a37c30deff6b3dcba91659c.png
Sammelthread für das MSI MEG x570 Unify/ACE
Herstellerseite:
MEG X570 UNIFY
Herstellerseite: MEG X570 ACE
Herstellerseite: MEG X570S ACE MAX
Herstellerseite: MEG X570S UNIFY-X MAX
Reviews:
MSI MEG X570 UNIFY Review - Introduction
MSI MEG X570 Unify motherboard (updated)
MSI MEG X570 Unify: An All-Black Motherboard
MSI MEG X570 Unify kommt ohne RGB aus
MSI MEG X570 Unify | Tom's Hardware
MSI MEG X570 ACE Infinity | Hardwareluxx
MSI MEG X570 Ace Motherboard Review
MSI MEG X570 Ace - Review 2019 - PCMag UK
MSI MEG X570 ACE - Hardware Journal
MSI MEG X570 ACE - Review
MSI MEG X570S ACE MAX - digideutsche
MSI MEG X570S ACE MAX - wccftech
MSI MEG X570S ACE MAX - IT Info
MSI MEG X570S UNIFY-X MAX - geeknetic
Besonderheiten:
  • Supports 2nd and 3rd Gen AMD Ryzen™ / Ryzen™ with Radeon™ Vega Graphics and 2nd Gen AMD Ryzen™ with Radeon™ Graphics Desktop Processors for AM4 socket
  • Supports DDR4 Memory, up to 5000+(OC) MHz
  • Aluminum Cover with Extended Heatsink: All-metal extended heatsink cover enlarge the surface of heat dissipation, ensures even high-end processors to run in full speed.
  • Lightning Fast Game Experience: PCIe 4.0, Triple Lightning Gen4 x4 M.2 with M.2 Shield Frozr, StoreMI, AMD Turbo USB 3.2 Gen2.
  • 2.5G Gaming LAN with Latest Wi-Fi 6 Solution: Onboard 2.5G LAN with gaming LAN manager, combining latest Wi-Fi 6 solution which supports MU-MIMO and BSS color technology, delivering the best online gaming experience.
  • Frozr Heatsink Design: Designed with the patented fan and double ball bearings to provide the best performance for enthusiast gamers and prosumers.
  • Audio Boost HD: Isolated audio with dedicated processor combining ESS audio DAC with amplifier, deliver the breathtaking, game-changing sound to create the most exciting gameplay.
  • Pre-installed I/O Shielding: Better EMI protection and more convenience for installation
  • ACE: Mystic Light Infinity, Dual LAN, Extended Heat-pipe Design
Spezifikationen Unify/ACE/ACE MAX/Unify X:
SOCKET:
AM4
CPU (MAX SUPPORT): Ryzen 9
CHIPSET:
AMD® X570 Chipset
DDR4 MEMORY: 1866/ 2133/ 2400/ 2667/ 2800/2933 /3000 /3066 /3200 /3466 /3600 /3733 /3866 /4000 /4133 /4266 /4400 /4533 /4600 /4733 /4800 /5000+ Mhz by JEDEC and A-XMP OC MODE
MEMORY CHANNEL: Dual
DIMM SLOTS: 2/4
MAX MEMORY (GB): 128GB
PCI-E X16: 3
PCI-E X1: 2
SATAIII: 4
M.2 SLOT: 3/4/6
RAID: 0/1/10
TPM (HEADER): 1
LAN UNIFY/UNIFY X: 1x Realtek® RTL8125 2.5 Gbps
LAN ACE/ACE MAX: 1x Intel® WGI211AT Gigabit / Intel® Wi-Fi 6E AX210, 1x Realtek® RTL8125 2.5 Gbps
USB 3.2 PORTS (FRONT): 1(Gen2, Type C), 4(Gen1, Type A)
USB 3.2 PORTS (REAR): 1(Gen2, Type C), 3(Gen2, Type A), 2(Gen1, Type A)
USB 2.0 PORTS (FRONT): 4
USB 2.0 PORTS (REAR): 2
AUDIO PORTS (REAR): 5+ Optical S/PDIF (Realtek® ALC1220 Codec)
DIRECTX: 12
FORM FACTOR: ATX
SLI: Y
CROSSFIRE: Y
OPERATING SYSTEM: Support for Windows® 10 64-bit
MSI Support bei hwluxx.
Hier ein paar Bilder zu denn Boards:
Der Idle-Verbrauch kommt eben drauf an, was alles am System angeschlossen ist und ob die Stromspar-Modi aktiv sind und auch greifen. In deinem Fall würde ich zunächst einmal schauen, ob dein System korrekt idled, sprich ob die VCore im Leerlauf auch runtergeht, was bisher nicht der Fall war, wenn ich das richtig verstanden habe. Sofern du also noch keinen richtigen CMOS Clear gemacht hast, würde ich das dringend empfehlen.
Wie gesagt, Ryzen Master sagt mir, die Idle ist unter 1V und die Cores im Ruhezustand. HWinfo sagt eigentlich permanent 1,48Volt und nur bei Allcore Anwendungen geht es dann auch runter. Wie kann ich die tatsächliche Voltage rausfinden ohne ein Multimeter? :d
Das ist ein guter Tipp!
Da fallen mir gleich mehrere Sachen ein:
Cmos clear hat beim a82 nichts mehr bei mir gebracht (teils über 20 Sekunden gedrückt). Xmp wurde nicht aktiviert und auch nach einem clear standen noch meine ram sub timings aus dem calculator im Profil.
Hier half nur erneutes flashen.
Wenn bei mir cppc und cppc2 aktiv und global c states an waren, taktet die die CPU nicht unter 3.6ghz im idle. Erst wenn ich cppc deaktiviere (nicht cppc2), takten die kerne ordentlich runter.
Das wäre auch mein Tipp bios nochmal flashen, cppc2 und global c states an.
Mein Verbrauch liegt im idle bei 32W. Das ist okay.
Du hast dann die gleiche Bios Version nochmal geflashed? Besteht da ein Risiko? Ich versuche mal den Clear CMOS Button zuerst. Ich hatte ja davor noch eine andere Bios Version und die gleichen hohen Idle Voltages mit dem 3900X (siehe Seite 27). In Ryzen Master und Hwinfo64 sehe ich Taktraten unter 3,6 Ghz, aber keine Spannungen unter 1.47V im Idle bei Hwinfo64. 30W klingt jedenfalls top im Idle.
CPPC ist glaube ich beides aktiviert bei mir, da ich niemals was umgestellt habe.
Edit: Im Bios finde ich nur CPPC auf Auto, C-State Control Auto und CPPC Preferred Cores Auto. Aber CPPC 1 und 2 sehe ich nicht. Wo genau ist das versteckt?
ersteinmal danke an den Moderator der meinen Thread in diesen verschoben hat, ich hatte ihn extra nicht ins unify Forum gestellt weil ich denke das es nichts speziel mit diesem Board zu tun hat!
@FM4E
Bios Version: 7C35vA7
hatte zuerst die 7C35vA82(Beta version) drauf aber bin dann wieder zur Final 7C35vA7 gewechselt weil mit der beta die Lüftersteurung nicht funktioniert hat.
Ryzen 5900X
Noctua NH D15 Kühler
Team Group 2x15 GB DDR4 3600
Gigabyte 3070Super
WD Black SN850 2TB
Samsung SSD 850Evo 1TB
WD 3TB Platte
BeQueit Dark Power 850w
Windows 10Pro
Logitech G Hub
sämtliche Treiber aktuell
und eben besagter PCTV 461e DVBS USB Stick und Logitech g910 und g502 auf einem Logitech Powerplay Pad
CPPC Preferred Cores ist cppc2
Das andere dann mal deaktivieren und schauen ob es was bringt. Und die anderen beiden nicht auf Auto stehen lassen sondern aktivieren.
Hab ich gerade versucht. Hat nichts verändert. Noch immer 85 Watt Verbrauch
Und du hast auch den ryzen Energie Plan im Windows aktiv?
Ansonsten Bügel das Bios nochmal drüber.
Den Energiesparplan gibts unter Ryzen 5000 nicht mehr, nur noch Ausbalanciert. Bios überbügel ich morgen mal.
Ich habe vor, demnächst das Unify zu holen. Nun ist mir aufgefallen, dass der von mir anvisierte RAM auf der MSI-Seite nicht in der Kompatibilitätsliste auftaucht..
Wie hoch ist die Wahrscheinlichkeit, dass es zu Problemen kommen kann?
Oder lieber andere Riegel nehmen?
und wie gehen die Riegel ?
Bringt das irgendwelche Vorteile? Ich möchte eine finale Version.
Noch eine Frage. Ich habe mir ein paar Profile fürs Bios gespeichert mit unterschiedlichen Lüfterkurven. Kann ich das auf nem Stick speichern und später wieder laden, da ich nen Clear-CMOS machen möchte?
Es hat mein Problem gelöst, dass bei manuellem OC der Sound anfängt zu kratzen. Ich musste auch keine SOC Spannung ändern oder Ähnliches.
Ich habe jetzt mal Clear-CMOS gemacht. Wenn ich das Bios offen habe liegt da auch immer ne Spannung von 1.48 V an. Wie ist das bei euch?
Das sagt mir der Clear-CMOS war erfolgreich oder? Weil die OC Profile sind noch da zur Auswahl.
Also an den Voltages hat sich nichts verändert. Es stehen noch immer 1.47-1.48V in HWINFO64. Meint ihr das Bios ist für den 5950x nicht richtig optimiert?
Gibt es jetzt eigentlich eine Lösung das man zwischen Lautsprecher am Backpanel und Headset am Frontpanel umschalten kann?
Ist wohl durch die ganzen OC, UV und UEFI Beiträge untergegangen :)
Das ist doch sicher nur eine Frage der Software oder? Wüsste nicht, wie das anders geregelt wird. Hat der Realtek Chip ne eigene Software, die Anschlüsse am Frontpanel erkennt? Dann müsste das theoretisch gehen. Mit meiner Soundblaster Z passiert das automatisch.
Klar "sollte" es gehen, aber es geht nicht. Habe jetzt das B550 wieder aus- und das Unify eingebaut und da war es wieder, das Problem, das mich beim Unify mal so richtig ankotzt. :)
BB50 war auch ein MSI Board?
Nur grob angetestet bisher: Mit dem neuen Bios komme ich ebenfalls nicht über 1900IF
Bin Direkt wieder zu a82 zurück
Ich schaffe noch nicht einmal die 1900, max sind 1866.
Hab dir Werte aus dem Curve Optimizer von a82 genommen und statt 4.6 GHz all core sind es jetzt 4.25 ghz. Was ein Witz...
Ich lass das jetzt auch und warte auf ein richtiges Release und die ersten Feedbacks dazu.
Ich werde wohl auch erst mal beim A82-BIOS bleiben, da mein Rechner so jetzt bisher fehlerfrei läuft. Frei nach dem Motto "Never touch a running system". Wenn das BIOS dann mit AGESA 1.1.9.0 final draussen ist, werde ich wohl flashen.
So geht es mir auch ;-)
Zieh doch mal alle Laufwerke außer der Systemplatte ab, das dürfte bestimmt 20-25W bringen (allein die beiden WD-Platten brauchen je ~6W, solange sie nicht komplett schlafen). Dazu kommt noch das extrem "große" Netzteil, bei nicht mal 10% Auslastung sinkt die Effizienz deutlich ab, da dürften dann auch noch mal gut 10W stecken...
Das NT ist etwas überdimensioniert, da ich davor 2x1080ti im SLI hatte und jetzt auf ne 3080 TUF umstelle. Aber ein neues NT kaufen macht auch wenig Sinn gerade. Ich habe jetzt das Board resetted aber keine Änderungen im Idle Verbrauch erhalten. Hat jemand einen 5950x und HWINFO64 und kann mir sagen, ob da auch immer 1.48V stehen? Die Voltage sinkt nur, wenn ich z.B. CB laufen lasse.
Diese Spannungen sind unbedenklich und normal, da der Prozessor keine Last fährt. Mein 3700x sieht auch die 1,48 V auf allen Cores wenn nix los ist.
Habe jetzt die älteren Beiträge nicht gelesen, aber generell empfehle ich folgende Einstellungen, sofern man nichts mit OC zu tun hat und die CPU @ Stock läuft (empfehle ich grundsätzlich jedem wenn es um einen Ryzen geht, die sind schon ab Werk exzellent):
Unter Advanced\ Power Management
- ErP Ready -> Aktiviert (schaltet im ausgeschalteten Zustand Funktionen ab und Verbrauch sinkt auf <1W.. z.B. kein Stand-By USB 5V usw.)
- System Power Fault Protection -> Aktiviert (wenn aktiviert, wird bei bedenklichen Spannungen, die vom Netzteil kommen, der PC nicht eingeschaltet. Ist also ein guter Schutz)
Unter Advanced\ AMD Overclocking
- LN2 Mode -> Deaktiviert ( nur für Stickstoffnutzer interessant)
- SoC Voltage -> Auto bzw. Standartwert
- SoC Uncore OC -> Deaktiviert (bei Enabled wird der Idle Modus gehemmt)
- VDDP/VDDG Voltage Control -> Deaktiviert
Unter Advanced\ USB Configuration
- XHCI Hand-Off -> Deaktiviert (bei Enabled übernimmt das OS die USB 3 -Kontrolle. Kein Performanceverlust, allerdings leicht höherer Aufwand für die CPU. Bei Deaktiviert übernimmt das BIOS die Kontrolle)
Danke für die Tipps @talha777. Das meiste habe ich schon so aktiviert, wie von dir beschrieben. Was macht die VDDP/VDDG Voltage Control?
Mit VDDG kann man die Spannung des Infinity Fabric verändern bzw. jene Spannung, die der SoC dem IF anlegt, erhöhen.
Mit VDDP verstellt man die Spannung der Kommunikationsbrücke zwischen IF und Speichercontroller (Physikalische Ebene des RAM).
Beides sind nur OC-Spielereien.
Ok bei mir im Bios steht da nur Auto oder Manual zur Auswahl
Ähnliche Themen
