[Sammelthread] MSI MEG X570(S) Unify (X MAX) / ACE (MAX) (AM4)
product_10_20191002132606_5d9434ee62129.pngproduct_9_20190723092258_5d3661724d540.pngproduct_1629079667f4b88b2d70e858818adcfd4767cd52a2.pngproduct_1629094385a72f0a5d4a37c30deff6b3dcba91659c.png
Sammelthread für das MSI MEG x570 Unify/ACE
Herstellerseite:
MEG X570 UNIFY
Herstellerseite: MEG X570 ACE
Herstellerseite: MEG X570S ACE MAX
Herstellerseite: MEG X570S UNIFY-X MAX
Reviews:
MSI MEG X570 UNIFY Review - Introduction
MSI MEG X570 Unify motherboard (updated)
MSI MEG X570 Unify: An All-Black Motherboard
MSI MEG X570 Unify kommt ohne RGB aus
MSI MEG X570 Unify | Tom's Hardware
MSI MEG X570 ACE Infinity | Hardwareluxx
MSI MEG X570 Ace Motherboard Review
MSI MEG X570 Ace - Review 2019 - PCMag UK
MSI MEG X570 ACE - Hardware Journal
MSI MEG X570 ACE - Review
MSI MEG X570S ACE MAX - digideutsche
MSI MEG X570S ACE MAX - wccftech
MSI MEG X570S ACE MAX - IT Info
MSI MEG X570S UNIFY-X MAX - geeknetic
Besonderheiten:
  • Supports 2nd and 3rd Gen AMD Ryzen™ / Ryzen™ with Radeon™ Vega Graphics and 2nd Gen AMD Ryzen™ with Radeon™ Graphics Desktop Processors for AM4 socket
  • Supports DDR4 Memory, up to 5000+(OC) MHz
  • Aluminum Cover with Extended Heatsink: All-metal extended heatsink cover enlarge the surface of heat dissipation, ensures even high-end processors to run in full speed.
  • Lightning Fast Game Experience: PCIe 4.0, Triple Lightning Gen4 x4 M.2 with M.2 Shield Frozr, StoreMI, AMD Turbo USB 3.2 Gen2.
  • 2.5G Gaming LAN with Latest Wi-Fi 6 Solution: Onboard 2.5G LAN with gaming LAN manager, combining latest Wi-Fi 6 solution which supports MU-MIMO and BSS color technology, delivering the best online gaming experience.
  • Frozr Heatsink Design: Designed with the patented fan and double ball bearings to provide the best performance for enthusiast gamers and prosumers.
  • Audio Boost HD: Isolated audio with dedicated processor combining ESS audio DAC with amplifier, deliver the breathtaking, game-changing sound to create the most exciting gameplay.
  • Pre-installed I/O Shielding: Better EMI protection and more convenience for installation
  • ACE: Mystic Light Infinity, Dual LAN, Extended Heat-pipe Design
Spezifikationen Unify/ACE/ACE MAX/Unify X:
SOCKET:
AM4
CPU (MAX SUPPORT): Ryzen 9
CHIPSET:
AMD® X570 Chipset
DDR4 MEMORY: 1866/ 2133/ 2400/ 2667/ 2800/2933 /3000 /3066 /3200 /3466 /3600 /3733 /3866 /4000 /4133 /4266 /4400 /4533 /4600 /4733 /4800 /5000+ Mhz by JEDEC and A-XMP OC MODE
MEMORY CHANNEL: Dual
DIMM SLOTS: 2/4
MAX MEMORY (GB): 128GB
PCI-E X16: 3
PCI-E X1: 2
SATAIII: 4
M.2 SLOT: 3/4/6
RAID: 0/1/10
TPM (HEADER): 1
LAN UNIFY/UNIFY X: 1x Realtek® RTL8125 2.5 Gbps
LAN ACE/ACE MAX: 1x Intel® WGI211AT Gigabit / Intel® Wi-Fi 6E AX210, 1x Realtek® RTL8125 2.5 Gbps
USB 3.2 PORTS (FRONT): 1(Gen2, Type C), 4(Gen1, Type A)
USB 3.2 PORTS (REAR): 1(Gen2, Type C), 3(Gen2, Type A), 2(Gen1, Type A)
USB 2.0 PORTS (FRONT): 4
USB 2.0 PORTS (REAR): 2
AUDIO PORTS (REAR): 5+ Optical S/PDIF (Realtek® ALC1220 Codec)
DIRECTX: 12
FORM FACTOR: ATX
SLI: Y
CROSSFIRE: Y
OPERATING SYSTEM: Support for Windows® 10 64-bit
MSI Support bei hwluxx.
Hier ein paar Bilder zu denn Boards:
BIOS A50
CMOS Reset durchgeführt
Soundkarte ausgebaut
alle PCIe Steckplätze gehen nicht mit der RX 5700 XT
Lief ja vorher auch ab November und hat vorletztes Wochenende seinen Geist aufgegeben ... Was kotzt mich das Board an, hatte noch nie solch ein schrottiges Mainboard mit so vielen Problemen und schwachsinnigen "Features"
schon mal probiert den PCIe Bus von Hand auf 3.0 zu setzen? Bzw. den CSM Modus an oder ausgeschalten?
(so schlimm ist das board jetzt nicht; war early adopter für Ryzen 1, das war grausam)
Ich kriege kein Bild mit einer 5700, mit den alten läuft es
Bei mir laufen die AMD Karten ganz normal. Am Board liegt es dann wohl nicht. Wenn du es so schrottig findest kauf ein neues und fertig.
Kennt von euch jemand das Problem, wenn ich eine AIO am Pumpen-Header angeschlossen habe, dass dieser keine RPM der Pumpe anzeigt? Regeln lässt sich die Pumpe aber.
Bei mir läuft das A6 ebenfalls unauffällig und ich finde die Lüftersteuerung ist nun weniger zickig wie zuvor.
Bei mir ist Secureboot nicht mehr nutzbar.
Läuft zickiger. Stabile Timings laufen nicht mehr.
Der letzte Slot ist sharingfrei. Die Aussetzer können an der PCI-E Anbindung liegen, wenn nicht alle Teilnehmer mit dem selben Protokoll kommunizieren. Wenn kein PCI-E 4.0 Peripherie angeschlossen/genutzt ist/wird, sollte ein manuelles forcieren auf 3.0 das Problem lösen.
Das RX5700XT Problem liegt höchstwahrscheinlich auch an PCI-E 4.0. Im UEFI auf 3.0 umstellen und dann probieren. Es gibt auch viele Leute, die Probleme mit X570 und einer 4.0 Karte haben. Soundaussetzer, microruckler, USB Probleme.. Das Problem lässt sich zu 99% beheben, wenn man auf 3.0 runterschaltet. Aktuell ist noch unklar, ob es am X570, am Boarddesign oder doch an den AMD Karten liegt. Wenn NVIDIA seine 4.0er bringt, wird man das Problem ein Stück weiter eingrenzen können. Betroffen sind meisten Gigabyte Boards, doch auch bei allen anderen Herstellern tauchen ähnliche Probleme auf.
PS.: Ich fahre immer noch mit dem A3 BIOS. Absolut stabil, keine Probleme bisher.
Secureboot funktioniert bei meinem MSI B550 Gaming Carbon auch nicht mehr seit dem neuesten Agesa !
Habe mich bei MSI gemeldet aber bis jetzt noch keine Antwort bekommen.
Bin nun auf die V50 zurück, nicht weil es Instabilitäten ec. gab, sondern weil die RAM Latenzen schlechter geworden waren.
Die Latency geht von 68.2 auf 81,7 ns hoch und die Werte werden auch etwas schlechter. Kann das mal jemand mit einem Crucial 3200/16 32 MB Kit (oder anderen) gegenprüfen. Die Einstellugen im BIOS sind exakt gleich geblieben. Der RAM läuft auch nach wie vor stabil bei 3800/1900 MHz, nur die Latenzen sind schlechter.
Bei mir ist die Latenc gleich geblieben, liegt also nicht am neuen Bios direkt.
Merkwürdig habe seit gestern Abend alle möglichen Einstellungen getestet mit der V60, die Werte blieben immer im Bereich von 81.X. V50 aufgespielt, Werte eingestellt, sofort wieder 68.X.
Mal sehen ob noch jemand mit einem Crucial Kit kommt.
update
Manchmal... Ich muss wohl die FCLK auf 1800 Mhz eingestellt haben bei der V60 (war spät gestern), zurück auf die V50 heute habe ich es dann natürlich richtig eingestellt. Und nun auch wieder richtig, alles gut mit dem neuen BIOS.
Die Latenzen stimmen, kein Problem.
Ich habe heute ein Betabios von MSI bekommen, wo Secure Boot wieder funktionieren soll !
Ich habe das B550 Gaming Carbon.
Was zeigt Euer Board nach dem Booten (im Windowsbetrieb) auf der LED Postcode Anzeige an? Meiner steht auf 67, manchmal auch 68, aber nie weiter. Müsste da nach dem Booten nicht 00 stehen?
Bei mir zeigt das gleiche in Windows. Manchmal noch andere Codes. Aber es ist nie auf nur 00.
Ich hab das an, das der die CPU Temperatur da anzeigt.
(Ich find das gut, durch meine Dunkel getönte Scheibe kann ich so direkt und ohne extra Software die CPU Temp sehen.)
Würde mich auch interessieren. Wusste gar nicht, dass das geht.
wie geht das denn?
Das geht wie folgt:
im BIOS (Advanced Mode)
>>> OC
>>> Advanced CPU Configuration
>>> CPU Temperature Display >>> Enable
und schon zeigt er während des Bootens die Codes und unter Windows die CPU Temperatur.
Hatte es die ganze Zeit schon an. Habe aber nie realisiert, dass das die CPU Temperatur ist. Wieder was gelernt. Trotzdem danke.
Leute, ich bin von Intel auf den 3900x umgestiegen, kenne mich mit den Ryzen nicht aus.
Könnt Ihr mir bitte sagen, was ich im UEFI des Unify Boards auf jeden Fall ein/aus schalten sollte? Standard Dinge sind klar, aber so CPU oder Chipsatz spezifische Dinge. Habe lediglich von CMS auf UEFI geschaltet und XMP des RAMs aktiviert, der Rest steht fast alles noch auf AUTO bzw. default
Eigentlich nix. Außer xmp und meinen oc Einstellungen gibt es da meiner Meinung nach nicht viel einzustellen oder nicht viel, worauf man achten muss. PBO würde ich persönlich immer aus lassen. Aber das ist per Default aus.
Meine OC Einstellungen werden dir ja nicht viel bringen. Aber ich fahre 4,2 GHz Allcore mit dem Vcore bei 1,19. Mein Ziel war es damit die Temperatur runter und Effizienz hoch zu bringen. Deswegen bin auch kein Freund von PBO. Auch ohne PBO liegt ziemlich viel Spannung an im Stock, wenn auch nur kurz. Aber bei mit ist der CB Score um 200 Punkte hoch und die Temperatur um 10° Grad runter.
Es gibt ein paar Settings die man machen kann im Bios außer XMP. Ich betreibe zB UV mit meinen 3900x. PBO würde ich immer aus machen bei einer 3000 CPU. Das Ryzen Master Tool würde ich auch nicht installieren. Macht mehr Probleme als es bringt, besser Hwinfo verwenden.
Ich habe heute mal das Wlan getestet über das Unify und dabei habe ich bemerkt das es langsamer ist als am Handy. Beim Handy erreiche ich über 5Ghz um die 440Mbit, beim Unify komme ich gerade mal auf 320Mbit und das ob wohl der PC direkt neben dem Router steht. Treiber ist der neueste installiert. Habe eine 500Mbit Leitung. Ist das bei euch so? Die Wlan Antenne ist angeschlossen wobei das keinen Unterschied macht denn auch ohne diese Antenne erreiche ich die selbe Geschwindigkeit.
Mein Rechner ist auch direkt neben dem Router und deshalb auch per LANKABEL angeschlossen.
WLAN ist im BIOS deaktiviert und hab ich auch nie ausprobiert, die Antennen liegen Originalverpackt im Karton...
Ähnliche Themen
