SANY
Urgestein
- Desktop System
- Gaming PC
- Intel Core i9-10900K @5,2 GHz allcore, HT off, SP87
- Asus Z490 ROG Maximus XII Hero (WI-FI)
- Wakü, Heatkiller IV Pro, Phanteks Glacier, HeatkillerTube, D5, 2x 420er Radi extern, 240er intern
- 2x16Gb G.Skill Trident Z (F4-3200C14D-32GTZSK), @DDR4-4000 16-17-17-32, Samsung B-Die
- ASUS ROG Strix GeForce RTX 2070 OC
- ASUS ROG Swift PG279Q, IPS 165 Hz; Zweitmonitor: AOC G2590VXQ, TN 75 Hz
- NVMe: Samsung SSD 970 EVO 250GB, Corsair Force Series MP510 960GB; SSD: Samsung SSD 860 EVO 500GB
- Phanteks Eclipse P600S Anthracite Gray
- ASUS ROG-THOR-850P, Platinum 850W
- Keyboard
- Logitech G610 Orion, Cherry MX Brown
- Mouse
- Logitech G Pro Wireless
- Windows 10 Pro
Wechselst du dann wieder auf Heatkiller IV?Es gibt ihn jetzt:
Direct Die Kit - Intel 9th & 10th Gen
Direct Die kit - fits Intel 9th & 10th Gen CPUs When you're hunting maximum overclocks and lowest temps, the Direct to Die is the answer. CNC machined to tight tolerances. Waterblock sits directly on the CPU DIE for maximum cooling. Tough Cerakote coated. Easy to install, no modifications...rockitcool.myshopify.com
Hab mir mal zwei bestellt, da so der Versand günstiger wird. Wer den anderen durchgeschliffen haben will -> PN.
