[Sammelthread] MSI MEG X570(S) Unify (X MAX) / ACE (MAX) (AM4)
product_10_20191002132606_5d9434ee62129.pngproduct_9_20190723092258_5d3661724d540.pngproduct_1629079667f4b88b2d70e858818adcfd4767cd52a2.pngproduct_1629094385a72f0a5d4a37c30deff6b3dcba91659c.png
Sammelthread für das MSI MEG x570 Unify/ACE
Herstellerseite:
MEG X570 UNIFY
Herstellerseite: MEG X570 ACE
Herstellerseite: MEG X570S ACE MAX
Herstellerseite: MEG X570S UNIFY-X MAX
Reviews:
MSI MEG X570 UNIFY Review - Introduction
MSI MEG X570 Unify motherboard (updated)
MSI MEG X570 Unify: An All-Black Motherboard
MSI MEG X570 Unify kommt ohne RGB aus
MSI MEG X570 Unify | Tom's Hardware
MSI MEG X570 ACE Infinity | Hardwareluxx
MSI MEG X570 Ace Motherboard Review
MSI MEG X570 Ace - Review 2019 - PCMag UK
MSI MEG X570 ACE - Hardware Journal
MSI MEG X570 ACE - Review
MSI MEG X570S ACE MAX - digideutsche
MSI MEG X570S ACE MAX - wccftech
MSI MEG X570S ACE MAX - IT Info
MSI MEG X570S UNIFY-X MAX - geeknetic
Besonderheiten:
  • Supports 2nd and 3rd Gen AMD Ryzen™ / Ryzen™ with Radeon™ Vega Graphics and 2nd Gen AMD Ryzen™ with Radeon™ Graphics Desktop Processors for AM4 socket
  • Supports DDR4 Memory, up to 5000+(OC) MHz
  • Aluminum Cover with Extended Heatsink: All-metal extended heatsink cover enlarge the surface of heat dissipation, ensures even high-end processors to run in full speed.
  • Lightning Fast Game Experience: PCIe 4.0, Triple Lightning Gen4 x4 M.2 with M.2 Shield Frozr, StoreMI, AMD Turbo USB 3.2 Gen2.
  • 2.5G Gaming LAN with Latest Wi-Fi 6 Solution: Onboard 2.5G LAN with gaming LAN manager, combining latest Wi-Fi 6 solution which supports MU-MIMO and BSS color technology, delivering the best online gaming experience.
  • Frozr Heatsink Design: Designed with the patented fan and double ball bearings to provide the best performance for enthusiast gamers and prosumers.
  • Audio Boost HD: Isolated audio with dedicated processor combining ESS audio DAC with amplifier, deliver the breathtaking, game-changing sound to create the most exciting gameplay.
  • Pre-installed I/O Shielding: Better EMI protection and more convenience for installation
  • ACE: Mystic Light Infinity, Dual LAN, Extended Heat-pipe Design
Spezifikationen Unify/ACE/ACE MAX/Unify X:
SOCKET:
AM4
CPU (MAX SUPPORT): Ryzen 9
CHIPSET:
AMD® X570 Chipset
DDR4 MEMORY: 1866/ 2133/ 2400/ 2667/ 2800/2933 /3000 /3066 /3200 /3466 /3600 /3733 /3866 /4000 /4133 /4266 /4400 /4533 /4600 /4733 /4800 /5000+ Mhz by JEDEC and A-XMP OC MODE
MEMORY CHANNEL: Dual
DIMM SLOTS: 2/4
MAX MEMORY (GB): 128GB
PCI-E X16: 3
PCI-E X1: 2
SATAIII: 4
M.2 SLOT: 3/4/6
RAID: 0/1/10
TPM (HEADER): 1
LAN UNIFY/UNIFY X: 1x Realtek® RTL8125 2.5 Gbps
LAN ACE/ACE MAX: 1x Intel® WGI211AT Gigabit / Intel® Wi-Fi 6E AX210, 1x Realtek® RTL8125 2.5 Gbps
USB 3.2 PORTS (FRONT): 1(Gen2, Type C), 4(Gen1, Type A)
USB 3.2 PORTS (REAR): 1(Gen2, Type C), 3(Gen2, Type A), 2(Gen1, Type A)
USB 2.0 PORTS (FRONT): 4
USB 2.0 PORTS (REAR): 2
AUDIO PORTS (REAR): 5+ Optical S/PDIF (Realtek® ALC1220 Codec)
DIRECTX: 12
FORM FACTOR: ATX
SLI: Y
CROSSFIRE: Y
OPERATING SYSTEM: Support for Windows® 10 64-bit
MSI Support bei hwluxx.
Hier ein paar Bilder zu denn Boards:
Mh.. weil man sich das leisten kann? 3090 wird wohl PCIe 4.0 mitbringen. Gibts ein gute Anleitung für Undervolting?
Ob ne 3090 selbst die Bandbreite von PCIe 3.0 voll ausreizen kann ist die andere Frage.
@deadlink das ist schwierig zu sagen, wenn du dir nicht Sicher bist und auch keine Probleme hast und alles gut läuft, dann MUSS man nicht Updaten (Never change a running System)
Sollte es aber Probleme geben die auf die Aufgelisteten Verbesserungen zutreffen dann wäre es schon einen Versuch wert.
Ich persönlich Update nur Finalversionen, bin mir aber auch bewußt das man dabei was Kaputt machen kann, wenns ganz dumm läuft -
wie z.B. ein Stromausfall während des Updatevorgangs, defekter USB-Stick...
Von BETA-BIOS halte ich: Abstand
Grüße
Hat jemand beim neusten Bios auch das Problem das GDM als deaktiviert angezigt wird, aber die NP Frequenz mit der Hälfte des Taktes läuft?
So, habe jetzt 32GiB Corsair LPX 3600er drin, eine Soundkarte (endlich kein Realtek/Nahimic mehr) und einen 3900X, langsam macht das Board Spaß.
Einzige Spaß, dass das kein LED blinkt. Leistung in 4K (oder in m.2) NULL in vergleich mit meine "10 Jahre" alte Board / CPU.
Neues Final Bios ist da.
Jemand schon erste Erfahrungen gesammelt?
Hab das Bios heute mittag aufgespielt. Die Lüftersteuerung ist verbugged. Bei mir laufen CPU Lüfter pwm gesteuert und drei Gehäuselüfter mit drei Pins nicht dynamisch. Hab die Werte vom Vorgänger Bios händisch eingestellt . Dann andere ausprobiert. Die Lüfter bleiben beim niedrigsten eingestellten Wert, egal wie warm es wird.
Und dann noch die Speichertimings: CL, tRCD, tRP und den vierten primären Wert musste ich eins zurück nehmen, von 15 auf 16. Mit dem Vorgänger lief alles Problemlos.
Bisher ist das alles.
Hab den ganzen Nachmittag ausprobiert.
Keine Probleme hier. Lüftersteuerung läuft wie immer. Einstellen speichern und fertig. Problem ist nicht immer das Bios. Meine Ram Settings ebenfalls 1:1 übernommen.
Kann ich so bestätigen. Habe es auch mal installiert. OC werte sind die gleichen wie vorher und funktionieren. Lüfter Regeln ganz normal. @clouseau vielleicht mal mit CMOS Clear versuchen?
Edit: sollte Bluetooth nicht auch aus sein, wenn ich im BIOS Wi-Fi deaktivere? Das habe ich gemacht, weil ich es nicht nutze aber unter Windows scheint Bluetooth dennoch aktiv zu sein.
Bei mir funktionieren auch alle alten Settings. Beim RAM ist ja einiges dazu gekommen, weiß jemand was davon brauchbar ist?
Bluetooth blieb auch in den vorherigen BIOS Versionen an.
Danke für den Tip. Hab ich gestern schon ausprobiert. Softwareprobleme kann ich auch ausschliessen. Ryzenmaster oder die MSI Software (egal welcher Hersteller) benutze ich eh nicht. Wenn was verändert wird dann nur im Bios.
Das A4 Bios hab ich nochmal aufgespielt, leider ohne Erfolg. Bin jetzt auf A3 zurück und die Probleme treten jetzt auch hier auf.
Naja, jedes Problem lässt sich lösen, nur die Zeit die man benötigt hat man leider nicht immer wenn man sie braucht.
Hm, das ist echt komisch, dass das auch mit dem alten Auftritt. Und du bist sicher, dass es auf Smart Fan steht und du ggfs. Von DC auf PWM umgestellt hast, falls du damit regelst?
So, bin jetzt zurück. Nachdem ich die Brücke/ JBAT1 mal ca 20 Sekunden mit dem Schrauber kurzgeschlossen habe funktioniert das Meiste wieder. Bisher immer so 5 bis 10 Sekunden und das wars. Aber diesmal nicht, es brauchte etwas länger.
Keine Probleme mehr mit der Lüftersteuerung. Den RAM hatte ich mit A30 auf 3600/15/15/15/15/34. Jetzt mit A40 auf 3200/14/14/14/14/34. Aber ich probier weiter.
Es würde auch die A4 gehen. Das man mindestens 15 bis 20 Sekunden denn CMOS drücken soll ist bekannt eigentlich.
Mir nicht. In Handbuch steht 5 bis 10 Sekunden. 10 Sekunden habe ich auch gemacht gestern und es hat funktioniert.
15 Sekunden werden dennoch allgemein empfohlen. Hatte es schon oft das 10 Sekunden nicht reichen.
DANKE!!! Jeder macht andere Erfahrungen. Meine sind die das ich meist mit dem Knopf am Mainboard auskomme. Die Brücke musste ich ganz selten kurzschließen und da reichte bisher eine kurze Zeit.
Das MSI Unify hat ein neues Final A5 Bios bekommen.
Beschreibung
- Improved boot time.
- Improved PS/2 KB/Mouse compatibility.
- Improved memory compatibility.
Man kann bei MSI Unify wie bei Asrock ebenfalls die LED Firmware und Flash Button Firmware updaten was ich bis jetzt nicht wusste. Im Overclock Forum teilte das jemand mit und geht mit dem Dragon Center. Die Option ist aber recht gut versteckt. Ich ging davon das bei MSI das ganze im Bios dabei ist, ist es aber nicht. Das ganze findet man im Dragon Center wenn man auf Support klickt und dann auf Fortschritt, dann werden beide Firmware angeboten.
Bei mir sieht es so aus:
Nach dem Update:
Hast du eine Idee oder Erfahrung was das bringt?
Nein ka was dieses Firmware Update genau macht. Ich weiß nur bei ASRock wird bei den LED Firmware Update mehr gefixt als nur LED zeugs. Ob das bei MSI auch so ist kann ich nicht sagen.
Edit: Dass das Update mehr als nur LED fixt hat ein User im Overclock Forum selbst gemerkt und ein anderer ebenfalls.
Werde das Mal vor dem nächsten Formatieren machen. Davor kommt mir das Dragon Center nicht auf den PC.
Kann man jederzeit wieder deinstallieren wie ich es auch gemacht habe.
Nicht gründlich genug für dieses Monster. :fresse:
Edit: war zu neugierig. Habe es dennoch mal installiert. LED ist bei A4 und FW BIOS bei 6. Bekomme aber keine Aufforderung zum Updaten.
Registrieren muss ich mich dafür aber nicht, oder?
Edit²: ah ok, habs. Habe an der falschen Stelle geschaut. Dieser Post hat mir weitergeholfen.
Go to the System Info page in Dragon Center to see which LED firmware you have. To update it go to the Live Update page and click the button that says "Advance" in the top right, then click the checkbox next to the LED Firmware and click "install."
Anfangs hatte ich das MSI Dragon Center installiert und wegen der Probleme damit wieder deinstalliert.
Nach diesem Hinweis von @Scoty wieder installiert und brav die beiden Bios Updates installiert und gleich auch die veralteten Treiber auf den aktuellen Stand gebracht.
Nach dem Update auf die Bios Version A50 spielte bei mir der Chip Lüfter verrückt. Er ging nach dem Start in Windows bis auf 14.835 RPM hoch. Auch die anderen Lüfter reagierten kaum und die CPU Temperatur war auch im Idle über 55 °C. Ich bezog es auf die überhöhten Raumtemperaturen der letzten Tage. Heute war es aber nur 24 °C im Raum und das Lüfterverhalten änderte sich nicht und die CPU Temperaturen waren immer noch so hoch.
Nach den Updates mit dem MSI Dragon Center herrscht nun wieder Ruhe im PC. Die Gehäuselüfter kann ich nun wieder in der mittleren Stufe betreiben und die CPU Temperatur ist wieder bei 46 °C und der Chipsetlüfter bei 0 RPM.
Jetzt dürfte es auch wieder wärmer werden, ohne das der PC gleich brüllt. (y)
P.S.: Verstehe nur nicht die Update Politik von MSI nicht. Kein Hinweis über diese Prozedur auf der Service Seite. Weshalb diese beiden Bios Updates nicht gleich mit erledigt werden ist mir auch schleierhaft. Ansonsten bin ich immer noch sehr zufrieden mit dem Board.
Ähm ich habe doch geschrieben wo es diese Option gibt. Das diese beiden Firmwares nicht im Bios drin sieht ist kein MSI ding, macht Asrock auch so und wie schon erwähnt bei Asrock so wird auch bei MSI mehr als nur LED gefixt wie man nachlesen kann im Overclock Forum. Das unify hat kein LED Kirmes wie die anderen, das LED Firmware ist aber auch nicht dafür da sondern zB auch die LED Debug Anzeige, das ansteuern von anderen LED die man anstecken kann und eben auch anderes was nichts mit LED zu tun hat. Einzig warum der Flash Button auch eine Firmware hat verstehe ich nicht gant. Eventuell werden hier diverse USB Sticks dann besser erkannt?
