[Sammelthread] MSI MEG X570(S) Unify (X MAX) / ACE (MAX) (AM4)
product_10_20191002132606_5d9434ee62129.pngproduct_9_20190723092258_5d3661724d540.pngproduct_1629079667f4b88b2d70e858818adcfd4767cd52a2.pngproduct_1629094385a72f0a5d4a37c30deff6b3dcba91659c.png
Sammelthread für das MSI MEG x570 Unify/ACE
Herstellerseite:
MEG X570 UNIFY
Herstellerseite: MEG X570 ACE
Herstellerseite: MEG X570S ACE MAX
Herstellerseite: MEG X570S UNIFY-X MAX
Reviews:
MSI MEG X570 UNIFY Review - Introduction
MSI MEG X570 Unify motherboard (updated)
MSI MEG X570 Unify: An All-Black Motherboard
MSI MEG X570 Unify kommt ohne RGB aus
MSI MEG X570 Unify | Tom's Hardware
MSI MEG X570 ACE Infinity | Hardwareluxx
MSI MEG X570 Ace Motherboard Review
MSI MEG X570 Ace - Review 2019 - PCMag UK
MSI MEG X570 ACE - Hardware Journal
MSI MEG X570 ACE - Review
MSI MEG X570S ACE MAX - digideutsche
MSI MEG X570S ACE MAX - wccftech
MSI MEG X570S ACE MAX - IT Info
MSI MEG X570S UNIFY-X MAX - geeknetic
Besonderheiten:
  • Supports 2nd and 3rd Gen AMD Ryzen™ / Ryzen™ with Radeon™ Vega Graphics and 2nd Gen AMD Ryzen™ with Radeon™ Graphics Desktop Processors for AM4 socket
  • Supports DDR4 Memory, up to 5000+(OC) MHz
  • Aluminum Cover with Extended Heatsink: All-metal extended heatsink cover enlarge the surface of heat dissipation, ensures even high-end processors to run in full speed.
  • Lightning Fast Game Experience: PCIe 4.0, Triple Lightning Gen4 x4 M.2 with M.2 Shield Frozr, StoreMI, AMD Turbo USB 3.2 Gen2.
  • 2.5G Gaming LAN with Latest Wi-Fi 6 Solution: Onboard 2.5G LAN with gaming LAN manager, combining latest Wi-Fi 6 solution which supports MU-MIMO and BSS color technology, delivering the best online gaming experience.
  • Frozr Heatsink Design: Designed with the patented fan and double ball bearings to provide the best performance for enthusiast gamers and prosumers.
  • Audio Boost HD: Isolated audio with dedicated processor combining ESS audio DAC with amplifier, deliver the breathtaking, game-changing sound to create the most exciting gameplay.
  • Pre-installed I/O Shielding: Better EMI protection and more convenience for installation
  • ACE: Mystic Light Infinity, Dual LAN, Extended Heat-pipe Design
Spezifikationen Unify/ACE/ACE MAX/Unify X:
SOCKET:
AM4
CPU (MAX SUPPORT): Ryzen 9
CHIPSET:
AMD® X570 Chipset
DDR4 MEMORY: 1866/ 2133/ 2400/ 2667/ 2800/2933 /3000 /3066 /3200 /3466 /3600 /3733 /3866 /4000 /4133 /4266 /4400 /4533 /4600 /4733 /4800 /5000+ Mhz by JEDEC and A-XMP OC MODE
MEMORY CHANNEL: Dual
DIMM SLOTS: 2/4
MAX MEMORY (GB): 128GB
PCI-E X16: 3
PCI-E X1: 2
SATAIII: 4
M.2 SLOT: 3/4/6
RAID: 0/1/10
TPM (HEADER): 1
LAN UNIFY/UNIFY X: 1x Realtek® RTL8125 2.5 Gbps
LAN ACE/ACE MAX: 1x Intel® WGI211AT Gigabit / Intel® Wi-Fi 6E AX210, 1x Realtek® RTL8125 2.5 Gbps
USB 3.2 PORTS (FRONT): 1(Gen2, Type C), 4(Gen1, Type A)
USB 3.2 PORTS (REAR): 1(Gen2, Type C), 3(Gen2, Type A), 2(Gen1, Type A)
USB 2.0 PORTS (FRONT): 4
USB 2.0 PORTS (REAR): 2
AUDIO PORTS (REAR): 5+ Optical S/PDIF (Realtek® ALC1220 Codec)
DIRECTX: 12
FORM FACTOR: ATX
SLI: Y
CROSSFIRE: Y
OPERATING SYSTEM: Support for Windows® 10 64-bit
MSI Support bei hwluxx.
Hier ein paar Bilder zu denn Boards:
Ach das ist ohne Blende, das muss gehen, einfach das Brett von der gegenüber liegenden Seite feste rein drücken ...
Mit viel Drücken gings dann...Das IO Shield ist aber gebaut wie ein Panzer..lässt sich null rein drücken.
Bei meinem Gehäuse (Fractal Design Define R6) hat das sauber gepasst, komisch...
bei meinem U5 auch.
Man kann außerdem den Chipsatzlüfter bedenkenlos mit 2k rpm laufen lassen. Das hört man nicht und der Chipsatz erfreut sich einer niedrigeren Temperatur.
Ja ich hab die Halterungspins quasi auch stark drücken müssen. Hat bei meinem bequiet Base 500 nicht gepasst.
Ich wär jetzt bereit für AGESA 1.0.0.2 V2
dann lad es doch runter. :d
Einzige Grund diese MB zu kaufen war das er total schwarz ist. Ich frage lieber, zweite 8 pin anschluß an MB mit Strom zu versorgen nicht von Nöten ? CPU 3900X
Hat jemand Erfahrung mit schon laufende Windows System (auf Intel) auf diese MB umzusteigen? KB auf Neuinstallation.
Speicher 32GB HyperX Fury DDR4-3200 DIMM CL16 (2x16GB) Dual Kit ich bin gespannt ob läuft. DR wegen.
Hat jemand mit Ventirad Raijintek Pallas 120 Ventilator Erfahrung? Der gefällt mir... weil total schwarz ist (ausser blöde Aufkleber, aber der kriege ich bestimmt ab)
Ja, kannst den 2ten 8pin ruhig weglassen.
Dein RAM wird locker auf XMP laufen, auch mehr
Beim Raijintek würde ich mit ziemlicher Sicherheit sagen, dass ein Low Profile Cooler zu wenig für den 3900X ist. Ich habe nen NH-D15 und der ist bereits am schwitzen.
kannst es ohne Neuinstallation probieren, aber ich würde generell neu installieren. Hab ich bei meinem Wechsel auch gemacht. Sicher ist sicher^^
Es reicht ein 8 Pin locker aus. Läuft bei mir ebenfalls so. Ram einfach XMP laden und gut ist, wenn du nix weiter dran machen willst.
Schwarze Lüfter gibt es doch zu hauf. Arctic P12/14 PWM zum Bleistift, wenn es um Preis Leistung geht.
Etwas teurer, aber ihren Preis absolut wert, die S12A PWM chromax. Die sind auch komplett schwarz und ohne Aufkleber. Nur um mal Beispiele zu nennen.
Ich wollte sogar vorerst mit Box Cooler das CPU zu betreiben, und der ist winzig aber für 105 Watt doch spezifiziert. Wieso soll so ein Monster mit 800 Gramm (leidet TDP habe ich nicht gefunden) das 3900X nicht kühlen zu können? Dazu Übertaktung jetzt hat null Sinn.
uh, mit dem Boxed... im Sommer. Kannst es ja mal versuchen.
Ich lass meinen 3900X mit 3.9 allcore und 1.0V laufen. Das ist sehr förderlich für die Temperaturen. :d
Raijintek Pallas 120 wurde bestellt. Test folgt.
Ich hatte den 3600x mit dem Big Shuriken 3 versucht zu betreiben und auch der kam bereits an seine Grenzen mit 6 Cores und der 3900x wird mindestens genauso heiss. Spreche hier aus eigener Erfahrung. Hoffe mal der Raijintek ist besser.
für 50€ hätte ich eher den Fuma 2 empfohlen.
Ich hätte mal zwei Fragen.
1. Habe hier leider keine genaue Info im Handbuch gefunden. Bei der Einstellung der Lüfterkurven kann ich als Quelle PCIE1 und PCIE3 wählen. Ist PCIE1 tatsächlich die Grafikkarte? Und bei PCIE3 zeigt es mir eine Temperatur an aber in PCIE3 habe ich nichts eingesteckt... wird hier die M.2 Platte angezeigt?
2. Im Gerätemanager habe ich ein ubekanntes Gerät "PCI-Gerät" - eine Idee worum es sich hier handeln könnte? Ich habe, wie schon gesagt eigentlich nur zwei Dinge angeschlossen. Grafikkarte und M.2 SSD. Es wäre zu erwähnen, dass ich weder WLAN noch Bluetooth Treiber installiert habe. Statdessen habe ich WLAN im BIOS deaktiviert.
Edit: Punkt 2. habe ich rausgefunden. Ist der Type-C Port der Grafikkarte.
Hab das ganze mal noch selbst getestet. PCIE1 als Source ist wohl definitiv nicht die Temperatur, die aus der Grafikkarte gelesen wird. Bei der Suche, was das nun ist habe ich irgendwo einen Beitrag auf Reddit gefunden, wo beiläufig erwähnt wird, dass PCIE1 und PCIE3 Sensoren auf dem Board sind in der nähe der jeweiligen Slots.
Bringt leider nur nicht so viel. Gestern bem Spielen wurde die 2060 Super bis zu 73 - 74 °C warm, während PCIE1 bei 57°C stand. Das macht die Lüfterkurve, der Lüfter die auf die GPU pusten, sehr steil. Idle ist PCIE1 37 - 40 °C bei mir.
Es gehen seltsame Dinge vor... nachdem erst vor wenigen Tagen auf der MSI-Seite das aktualisierte BETA BIOS 7C35vA44 Auftauchte, ist jetzt jegliches BETA BIOS verschwunden und die stabile 7C35vA3 vom 16.01.2020 ist plötzlich die aktuellste verfügbare Version... ist da vielleicht was schief gelaufen das man die vA44 zurückgezogen hat?
Na ich bleibe dabei - von BETA BIOSen halte ich vor allem eines und das ist Abstand!
Im übrigen hat MSI angekündigt mitte Juli eine neue Finalversion A4 herauszubringen, dann auch mit Agesa 1.0.0.2 und Support für die Ryzen XT Prozessoren.
Grüße aus Berlin
easycrossy
Bei der neusten Agesa Version ist mir aufgefallen, dass die Lüftersteuerung nicht mehr so sauber lief. Das Auslesen der CPU Temp funzt wohl nicht mehr so sauber. Unter Aida64 hat der CPU Sensor auch nicht mehr das richtige Ergebnis ausgegeben, ich musste den 2. CPU Sensorkrempel wählen.
Die Lüfter muss ich jetzt im Bios bei deutlich niedrigeren Temperaturen hochdrehen lassen, was nicht stimmen kann. Aber funktioniert jetzt dennoch irgendwie.
Neue Beta Verfügbar:
7C35vA46(Beta version) vom 03.07.2020
Beschreibung
- Updated AMD AGESA ComboAm4v2PI 1.0.0.2
wer es mag, ich persönlich warte ja lieber noch die ca. 2 Wochen bis zu Final.
Crossy
Mainboard ist angekommen und wurde verbaut. Lief sofort. In BIOS GAME on Modus eingeschaltet. Natürlich für 4K gaming es völlig egal welche CPU man hat (ausser Core Duo natürlich). Das Board wurde nur gekauft für zukünftige RTX 3090.
Jetzt müsst ihr mit kurz helfen. Irgendwie habe ich da wohl was verpasst.
HWiNFO64 zeigt mir BIOS Version A.20 mit dem Release Date: 11/06/2019 an. Ist das jetzt noch das aktuellste?
Oder ist Version 7C35vA3 / Release Date 2020-01-16 die aktuellste?
Dann werde ich wohl mal aktualisieren müssen.
bin von einem Gigabyte X570 zum Unify gewechselt.
Hab 2 Fragen zu dem Board:
- Lohnt sich den Game Modus zu aktivieren, bzw. ich habe gesehn, dass dort manche Sachen im Bios ausgeschaltet werden
- Hat jemand gute Einstellungen für die FAN´s (sind doch etwas laut in der Standardeinstellung)
Generell muss ich sagen, ist das Boad zickiger als das Gigabyte. XMP aktivieren und gut ist nicht. Auch sind die vorher stabilen timings (karhu 8000%) nicht bootfähig. Bios ist A46
@deadlink die A3 ist die letzte Stable BIOS Version genau die von dir besagte " Version 7C35vA3 / Release Date 2020-01-16 "
@HSW du installierst dir ein BETA-BIOS und jammerst das das Board zickt?! Ernsthaft jetzt? Bei meinem mit der oben erwähnten Stable-Version A3 läuft "aktivieren und gut", nämlich absolut Problemlos.
Grüße
@easycrossy wenn ich nicht das Beta BIOS draufmachen, habe ich wieder Probleme mit der Grafikkarte, da AMD Bugs am pcie4 gefixed hat. Mit der letzten offiziellen hatte ich gleich Mal wieder black Screens. Und Beta muss nicht bedeuten, dass Basic Funktionen wie xmp/AMP nicht funktionieren (gibt's ja nicht erst seit gestern)
Die Frage mit dem zweiten Stecker für die CPU-Stromversorgung kann ich vielleicht beantworten. Ich habe mir nämlich gestern ein paar Review-Videos angesehen, die auf der MSI Homepage verlinkt waren. In einem (englisch) wurde erklärt, dass der zweite Anschluss der PCIe Stromversorgung dient, so dass man sich an den PCIe-Karten extra Stecker sparen kann. Allerdings hat der Rezensent auch beklagt, dass sich MSI im Handbuch darüber nicht weiter auslässt. Ansonsten ist für ihn das Unify das beste X570 Package.
Ich selber habe übrigens immer noch nicht zugeschlagen. Ein wenig liebäugle ich noch mit dem Creation, was vom Preis her auch langsam interessant wird. Wichtig ist für mich v. a. die Audioqualität über Kopfhörer, da ich den Rechner zum Komponieren nutze. (Der Hauptgrund, weswegen ich meinen alten Rechner in Rente schicken möchte. Bei Ochesterbesetzung reagiert das Notensatzprogramm Finale alles andere als flüssig und das nervt zunehmend.) Meint Ihr, dass von de Tonqualität ein wesentlicher Unterschied zwischen dem Unify und dem Creation besteht. Die anderen Mehr-Features des Creation (2 Phasen mehr für die VRM, USB-Overkill am Anschluss-Panel, M.2 Karte, 2 SATA mehr) sind mir eigentlich egal. Manche Dinge sind nach meiner Einschätzung beim Creation sogar schlechter gelöst. Das gilt v. a. für den fehlenden Bios Flashback Button. (Wenn da mal ein BIOS Update in die Hose geht, hat man keine Chance mehr, das zu heilen. Da hätte MSI beim Creation mal lieber zwei USB-Ports gestrichen.)
Ansonsten frage ich mich natürlich, ob ich den Herbst abwarten soll, bis ggf. neue Boards (X670) rauskommen, Allerdings sind die Gerüchte darüber sind bereits ein halbes Jahr alt. Vielleicht konzentriert sich AMD inzwischen ja schon auf den neuen Sockel. Die X570 Boards sind ja auf jeden Fall Ryzen 4000 fähig, wozu dann nochmal einen neuen Chipsatz rausbringen.
Ähnliche Themen
