[Sammelthread] MSI MEG X570(S) Unify (X MAX) / ACE (MAX) (AM4)
product_10_20191002132606_5d9434ee62129.pngproduct_9_20190723092258_5d3661724d540.pngproduct_1629079667f4b88b2d70e858818adcfd4767cd52a2.pngproduct_1629094385a72f0a5d4a37c30deff6b3dcba91659c.png
Sammelthread für das MSI MEG x570 Unify/ACE
Herstellerseite:
MEG X570 UNIFY
Herstellerseite: MEG X570 ACE
Herstellerseite: MEG X570S ACE MAX
Herstellerseite: MEG X570S UNIFY-X MAX
Reviews:
MSI MEG X570 UNIFY Review - Introduction
MSI MEG X570 Unify motherboard (updated)
MSI MEG X570 Unify: An All-Black Motherboard
MSI MEG X570 Unify kommt ohne RGB aus
MSI MEG X570 Unify | Tom's Hardware
MSI MEG X570 ACE Infinity | Hardwareluxx
MSI MEG X570 Ace Motherboard Review
MSI MEG X570 Ace - Review 2019 - PCMag UK
MSI MEG X570 ACE - Hardware Journal
MSI MEG X570 ACE - Review
MSI MEG X570S ACE MAX - digideutsche
MSI MEG X570S ACE MAX - wccftech
MSI MEG X570S ACE MAX - IT Info
MSI MEG X570S UNIFY-X MAX - geeknetic
Besonderheiten:
  • Supports 2nd and 3rd Gen AMD Ryzen™ / Ryzen™ with Radeon™ Vega Graphics and 2nd Gen AMD Ryzen™ with Radeon™ Graphics Desktop Processors for AM4 socket
  • Supports DDR4 Memory, up to 5000+(OC) MHz
  • Aluminum Cover with Extended Heatsink: All-metal extended heatsink cover enlarge the surface of heat dissipation, ensures even high-end processors to run in full speed.
  • Lightning Fast Game Experience: PCIe 4.0, Triple Lightning Gen4 x4 M.2 with M.2 Shield Frozr, StoreMI, AMD Turbo USB 3.2 Gen2.
  • 2.5G Gaming LAN with Latest Wi-Fi 6 Solution: Onboard 2.5G LAN with gaming LAN manager, combining latest Wi-Fi 6 solution which supports MU-MIMO and BSS color technology, delivering the best online gaming experience.
  • Frozr Heatsink Design: Designed with the patented fan and double ball bearings to provide the best performance for enthusiast gamers and prosumers.
  • Audio Boost HD: Isolated audio with dedicated processor combining ESS audio DAC with amplifier, deliver the breathtaking, game-changing sound to create the most exciting gameplay.
  • Pre-installed I/O Shielding: Better EMI protection and more convenience for installation
  • ACE: Mystic Light Infinity, Dual LAN, Extended Heat-pipe Design
Spezifikationen Unify/ACE/ACE MAX/Unify X:
SOCKET:
AM4
CPU (MAX SUPPORT): Ryzen 9
CHIPSET:
AMD® X570 Chipset
DDR4 MEMORY: 1866/ 2133/ 2400/ 2667/ 2800/2933 /3000 /3066 /3200 /3466 /3600 /3733 /3866 /4000 /4133 /4266 /4400 /4533 /4600 /4733 /4800 /5000+ Mhz by JEDEC and A-XMP OC MODE
MEMORY CHANNEL: Dual
DIMM SLOTS: 2/4
MAX MEMORY (GB): 128GB
PCI-E X16: 3
PCI-E X1: 2
SATAIII: 4
M.2 SLOT: 3/4/6
RAID: 0/1/10
TPM (HEADER): 1
LAN UNIFY/UNIFY X: 1x Realtek® RTL8125 2.5 Gbps
LAN ACE/ACE MAX: 1x Intel® WGI211AT Gigabit / Intel® Wi-Fi 6E AX210, 1x Realtek® RTL8125 2.5 Gbps
USB 3.2 PORTS (FRONT): 1(Gen2, Type C), 4(Gen1, Type A)
USB 3.2 PORTS (REAR): 1(Gen2, Type C), 3(Gen2, Type A), 2(Gen1, Type A)
USB 2.0 PORTS (FRONT): 4
USB 2.0 PORTS (REAR): 2
AUDIO PORTS (REAR): 5+ Optical S/PDIF (Realtek® ALC1220 Codec)
DIRECTX: 12
FORM FACTOR: ATX
SLI: Y
CROSSFIRE: Y
OPERATING SYSTEM: Support for Windows® 10 64-bit
MSI Support bei hwluxx.
Hier ein paar Bilder zu denn Boards:
Hallo zusammen,
mit dem neuen BETA BIOS funktionieren endlich meine G.Skill Trident Z Neo F4-3600C16D-32GTZNC CL16-19-19-39.
Mit dem vorherigen BIOS konnte ich mit dem XMP Profil nicht posten und alles über 3200 lief nicht. Jetzt ohne Probleme mit den Specs der DIMMs.
schräg, hab 64GB davon. Haben immer einwandfrei funktioniert.
Verdammte Axt, jetzt wollte ich das Beta Bios mit M-Flash updaten (weiß der Geier was für ein Narr mich da geritten hat) und das Board bootet nicht mehr. Zuerst hing es mit Postcode d0, CMOS Reset brachte auch keine Besserung. Also das alte Bios (A30) runtergeladen, entpackt und in MSI.ROM umbenannt und die Bios Flashback Funktion angeworfen. Jetzt hängt es bei 00 schon und es leuchtet nur die CPU LED Rot. Jemand eine Idee?
FFS, nur noch 500 Punkte im WOT Frontline Modus hätten gefehlt, der Rechner muss wieder laufen ... :rolleyes2::ROFLMAO:
Welche CPU ist aktuell installiert ?
Ich würde nochmal versuchen das Beta Bios mittels Flashback zu flashen und vorher alle anderen USB Geräte abklemmen.
Rechner aus, Netzstecker ziehen, paar mal auf PowerTaste drücken (Reststrom entladen), alle Geräte abklemmen, CMOS Clear mit jumper, dann bios flash
@citsejam, keine Ahnung, ich hatte seit Sockel 939 nur ASUS Boards, mein erstes (und letztes) MSI ist jetzt das Unify und M-Flash ist im UEFI die Flashfunktion, also sollte es normalerweise gehen.
@talha777, mein R7 3700X ist installiert, dazu 32 GiB FlareX, 2 NVME PCIe SSD und meine RX 5700XT.
Flashe grade das 5 mal über Bios Flashback, aber bringt allem Anschein nach nichts. Jetzt den CPU Kühler abzubauen um an den Ram zu kommen ist mir für heute zu viel Stress, werde jetzt meinen Grillplatz im Garten weiterbauen.
also ich habe das Unify seit Anfang Januar 2020 mit einem 3800X und 32GB G.Skill Trident Z Neo F4-3600C16D-32GTZNC CL16-19-19-39 in Verbindung mit einer 2070S zu laufen (von A1 auf A2 und A3 geupdated) und frage mich gerade ernsthaft warum sich jemand OHNE NOT ein Beta-Bios installiert?
(und dann hinterher beschwert das was nicht Fehlerfrei klappt)
PS: ach ja, XMP läuft völlig problemlos bei mir mit dem RAM-Kit und ich Undervolte die CPU sehr stabil per VCore Offset um -0.1375V ansonsten alles default. :sneaky:
grüße Easy :coffee3:
Habt ihr schon mal versucht die Timings noch weiter zu drücken?
Ich habe ein 2x16GB G.Skill RipJaws V 3600 16-19-19-39 Kit.
Mit XMP läuft es stabil aber alles weitere (natürlich nicht garantierte) läuft direkt auf Fehler.
16-18-18-38 laufen auch bei 1,4V im Ram Test gleich auf Fehler. (Viel höhere Spannung würde ich pers. vermeiden)
Wozu? Um irgendwo 0,5% mehr Leistung rauszuholen die man eh nicht merkt? Wofür ist denn ein solcher Rechner denn default zu langsam?
Ich seh das so: anstatt Stunden damit zu verbraten, irgendwelche nahezu sinnlosen Übertaktungen aus der Hardware zu quetschen, was bei den 3000er Ryzens nur mit extremer ineffizienz erkauft wird, finde ich es VIEL INTERESSANTER zu sehen wie viel effizienter (und damit auch Kühler) das ganze ohne Leistungsverlust zu Betreiben ist, per Untervolten z.B.
Aber wer meint zu Viel Zeit und Geld für die Stromrechnung zu haben, der soll halt rumprobieren, aus nem 6 Kerner wird davon aber auch kein 8er...
Die Chips werden heute überall so aussortiert (auch beim RAM), das man so gut wie keine Chance mehr auf einen 6er in der Silicon-Lottery hat, also kauft man das was man Leistungsmäßig BRAUCHT/Bezahlen kann und versucht am Zweckmäßigsten noch was an der Effizienz zu schrauben
meine Meinung...
Ich find bis zu 30% mehr Leistung je nach Anwendung nicht unbedingt unnötig.
30% ab 3600er Ram?? Von 3600 auf zB 3800 sind keine 5% nur mal so als Vergleich. Daher bleibe ich bei der Aussage das es unnötig ist außer man macht 10x am Tag einen Benchmark.
Schau dir einfach hier den Vergleich an.
Selbst 3600er mit exakt den getesteten CL14 Settings ist grad mal 4% langsamer als das 3800er CL14 Setting dort.
Straffere Timings machen also eine Menge unterschied aus. Allerdings braucht ma da natürlich auch entsprechenden RAM zu.
Wenn man Ram mit sehr guten B dies hat lass ich mir einreden das man da viel raus holen kann nur wie viele User kaufen Ram welcher um die 300 Euro kostet (je nach Speichergröße)? Das machen User die zu viel Geld haben oder einfach Spaß am Übertakten haben. Mit denn Micron-E kann man auch einiges anstellen wenn man denn ein gutes Kit erwischt, ich hatte nur Probleme mit denn Micron-E. Jetzt mit denn Gskill Neo erreiche ich mehr als mit denn Micron-E ohne 2 Wochen testen zu müssen. Die Sub Timings etwas angepasst weil XMP zu hohe Werte machte aber sonst mega zufrieden.
Aber nun genug OT hier, hat mit dem Board nichts mehr zu tun. Inzwischen läuft das Beta Bios ganz gut hier und vor allem sehr stabil. Keine Abstürze oder dergleichen auch wenn die Änderungen nur sehr maginal sind. Ist ja mein erstes MSI Board und was denn Bios Support betrifft hat mich MSI sehr positiv überrascht.
Mein einziger Wirklicher Kritikpunkt an dem Board ist bisher das BIOS, genauer gesagt das einstellen der Lüfterkurven, wäre sehr schön wenn man auch einfach die Zahlen eintippen könnte anstatt im Graphen rumzufummeln (idealerweise beides ermöglichen), auch wäre es schön gewesen wenn man die Werte dort Abspeichern (z.b. als Profil auf einen USB-Stick?) und wieder laden könnte nach einem BIOS-Update... mir ist das bisher jedenfalls nicht gelungen...
Das ist auch mein größter Grund nicht mit Beta-Biosen herumfummeln zu wollen, ich hab zwar Screenshots von den Lüfterkurven aber es ist halt lästig...
Grüße :coffee3:
So, habe mein Problem gefunden, Das Board mag seit dem UEFI Update keine Vollbestückung des Ram mehr. Jeweils 2 Riegel meines 32GiB Kit laufen ohne Probleme, egal wie ich sie durchmische, aber alle 4 wie zuvor laufen nicht mehr. Sehr frustrierend, auf dem Crosshair VI läuft alles noch ohne Probleme, leider hat das Board nur einen M.2 Port.
Hast du das irgendwie an MSI gemeldet? Dann bestünde ja wenigstens die vage Hoffnung das es in der Final A4 wieder gefixt wird.
Ja, habe es im Forum gepostet und den Support angeschrieben. Das blöde, egal welche UEFI Version ich jetzt flashe, es gehen nur noch Kanal A2 und B2, sobald in A1 oder B1 ein Riegel eingesetzt ist zeigt die Debug LED 0d beim Versuch das Board zu starten. Mit A20 lief es vorher seit November ohne Probleme, nur meine 2TB 2.5" S-ATA SSD machte ab und an mit bescheidener Performance auf sich Aufmerksam. Zuerst hatte ich sie mit einer 2TB M.2 ersetzt, aber hätte schon gerne wieder meine beiden BX 500 2TB S-ATA SSD eingebaut zwecks Speicherplatz.
So mein Board ist am WE gekommen und ich hätte nach dem Einbau mal ein paar Frage an euch:
1) ist es normal, das nach dem einschalten erstmal für ein paar sekunden ein weißer underscore im linken oberen drittel des Bildschirms erscheint? Das sieht ein wenig seltsam aus :)
2) Sobald der PC läuft zeigt das onboard display einen sich ständig verändernden Zahlenwert an. Ich vermute das ist ne Temperatur. Aber welche und kann man das ändern?
3) Das Bios zeigt mir 7C35vA30 an. Auf MSI ist die neuste Version 7C35vA3. Ist das das gleiche oder ist mein Board der Zeit voraus?
1) Ja ist normal
2) Das ist die Debug LED - die Hexadezimale Anzeige zeigt im Falle eines Problemes wo es hakt, Handbuch ab Seite 49
3) Dein Board hat die aktuelle Version A30, abgekürzt A3, weiß der Geier was MSI sich dabei denkt
also zu.
1) ja ist bei mir auch so
2) Das ist die CPU Temperatur und ja kann man im BIOS Ein- und Auschalten (aber nicht ändern auf Tctl/Tdie oder Chipset oder sowas)
3) 7C35vA3 = A30 also die aktuelle stable Version - Aktueller ist lediglich das angebotene BETA-BIOS (wovon ich persönlich eines halte - und zwar Abstand ;))
Da scheint sich etwas während dem BIOS Update verhaspelt zu haben, wenn das Board nun auch nach flashen des vorigen BIOS nicht mehr mit Vollbestückung bootet. Ich vermute, dass die Register, die mit dem Beta BIOS überschrieben bzw. beschrieben wurden, durch das flashen eines älteren BIOS nicht mehr überschrieben werden, weil ein älteres BIOS weniger Daten zu flashen hat. Das könnte MSI mit einer überarbeiteten A3 ohne Probleme fixen.
Allerdings kann man einen Schaden in der Elektronik auch nicht gänzlich ausschließen. Wäre interessant, ob das Board mit einem anderen 4x Ram Kit bootet.
Jedenfalls richtig mies, würde mich auch sehr darüber aufregen.
In eigener Sache: Ich hatte vor ein paar Wochen über spontane Systemneustarts berichtet und möchte nur eine kurze Rückmeldung darüber geben.
Gestern ging mir nämlich jetzt zum zweiten mal plötzlich der Rechner im Desktopbetrieb aus, ohne bluescreen oder sonstigen Meldungen. In beiden Fällen war es während einem YouTube Video in Chrome. Unter Last ist das System stabil, sei es furmark oder Prime Last und memtest lief bereits erwähnt 2,5 Std. ohne Fehler.
Leider ging das System vorhin nach ca. 4Min. CPU-Z Stresstest wieder aus. Also nehme ich die Aussage, dass die Abstürze nur im idle Betrieb kommen zurück. Ich habe den selben Test sofort nach dem Ausgehen wieder gestartet und er lief 10Min. ohne Fehler.
Ich vermute, dass der Fehler an den mangelhaften Steckverbindungen meiner Kabelverlängerung für 24Pin ATX und EPS 8Pin lagen. Mir war vor ein paar Wochen aufgefallen, dass man die Steckverbindungen trotz eingerasteter Haltenase noch leicht um ein paar mm rausziehen konnte. Ich habe sie mit der Hand festgedrückt und mit Iso-Band umwickelt, seitdem trat das Problem nicht mehr auf. Allerdings sind in der Zeit und seitdem auch mehrere Updates erschienen, sei es Windows Updates oder neue Chipset Treiber, könnte also vermutlich auch daran liegen, denn lt. Netz hatten einige andere ähnliche Probleme,
@citsejam, falls du mich meinst, klar. Sowohl per CMOS Button am I/O Panel, als auch an der JBAT1 Jumperbrücke bei ausgebauter Grafikkarte, da diese über dieser liegt. (Wer macht so einen Bullshit im Layout)
Hey Leute, ich besitze zur Zeit ein X570-I Gaming von Asus und überlege auf das Unify umzusteigen. Gibt es irgendwelche Dinge die euch negativ aufgefallen sind oder die man beachten muss? Bin zwar mit dem Asus Board zufrieden, aber möchte wieder auf ATX umsteigen. Funktionieren zb alle SATA Anschlüsse, wenn man alle drei M.2 belegt?
Ähnliche Themen
