[Sammelthread] MSI MEG X570(S) Unify (X MAX) / ACE (MAX) (AM4)
product_10_20191002132606_5d9434ee62129.pngproduct_9_20190723092258_5d3661724d540.pngproduct_1629079667f4b88b2d70e858818adcfd4767cd52a2.pngproduct_1629094385a72f0a5d4a37c30deff6b3dcba91659c.png
Sammelthread für das MSI MEG x570 Unify/ACE
Herstellerseite:
MEG X570 UNIFY
Herstellerseite: MEG X570 ACE
Herstellerseite: MEG X570S ACE MAX
Herstellerseite: MEG X570S UNIFY-X MAX
Reviews:
MSI MEG X570 UNIFY Review - Introduction
MSI MEG X570 Unify motherboard (updated)
MSI MEG X570 Unify: An All-Black Motherboard
MSI MEG X570 Unify kommt ohne RGB aus
MSI MEG X570 Unify | Tom's Hardware
MSI MEG X570 ACE Infinity | Hardwareluxx
MSI MEG X570 Ace Motherboard Review
MSI MEG X570 Ace - Review 2019 - PCMag UK
MSI MEG X570 ACE - Hardware Journal
MSI MEG X570 ACE - Review
MSI MEG X570S ACE MAX - digideutsche
MSI MEG X570S ACE MAX - wccftech
MSI MEG X570S ACE MAX - IT Info
MSI MEG X570S UNIFY-X MAX - geeknetic
Besonderheiten:
  • Supports 2nd and 3rd Gen AMD Ryzen™ / Ryzen™ with Radeon™ Vega Graphics and 2nd Gen AMD Ryzen™ with Radeon™ Graphics Desktop Processors for AM4 socket
  • Supports DDR4 Memory, up to 5000+(OC) MHz
  • Aluminum Cover with Extended Heatsink: All-metal extended heatsink cover enlarge the surface of heat dissipation, ensures even high-end processors to run in full speed.
  • Lightning Fast Game Experience: PCIe 4.0, Triple Lightning Gen4 x4 M.2 with M.2 Shield Frozr, StoreMI, AMD Turbo USB 3.2 Gen2.
  • 2.5G Gaming LAN with Latest Wi-Fi 6 Solution: Onboard 2.5G LAN with gaming LAN manager, combining latest Wi-Fi 6 solution which supports MU-MIMO and BSS color technology, delivering the best online gaming experience.
  • Frozr Heatsink Design: Designed with the patented fan and double ball bearings to provide the best performance for enthusiast gamers and prosumers.
  • Audio Boost HD: Isolated audio with dedicated processor combining ESS audio DAC with amplifier, deliver the breathtaking, game-changing sound to create the most exciting gameplay.
  • Pre-installed I/O Shielding: Better EMI protection and more convenience for installation
  • ACE: Mystic Light Infinity, Dual LAN, Extended Heat-pipe Design
Spezifikationen Unify/ACE/ACE MAX/Unify X:
SOCKET:
AM4
CPU (MAX SUPPORT): Ryzen 9
CHIPSET:
AMD® X570 Chipset
DDR4 MEMORY: 1866/ 2133/ 2400/ 2667/ 2800/2933 /3000 /3066 /3200 /3466 /3600 /3733 /3866 /4000 /4133 /4266 /4400 /4533 /4600 /4733 /4800 /5000+ Mhz by JEDEC and A-XMP OC MODE
MEMORY CHANNEL: Dual
DIMM SLOTS: 2/4
MAX MEMORY (GB): 128GB
PCI-E X16: 3
PCI-E X1: 2
SATAIII: 4
M.2 SLOT: 3/4/6
RAID: 0/1/10
TPM (HEADER): 1
LAN UNIFY/UNIFY X: 1x Realtek® RTL8125 2.5 Gbps
LAN ACE/ACE MAX: 1x Intel® WGI211AT Gigabit / Intel® Wi-Fi 6E AX210, 1x Realtek® RTL8125 2.5 Gbps
USB 3.2 PORTS (FRONT): 1(Gen2, Type C), 4(Gen1, Type A)
USB 3.2 PORTS (REAR): 1(Gen2, Type C), 3(Gen2, Type A), 2(Gen1, Type A)
USB 2.0 PORTS (FRONT): 4
USB 2.0 PORTS (REAR): 2
AUDIO PORTS (REAR): 5+ Optical S/PDIF (Realtek® ALC1220 Codec)
DIRECTX: 12
FORM FACTOR: ATX
SLI: Y
CROSSFIRE: Y
OPERATING SYSTEM: Support for Windows® 10 64-bit
MSI Support bei hwluxx.
Hier ein paar Bilder zu denn Boards:
Zum Asus wirst du hier keine Auskunft bekommen. Wenn du nicht warten willst oder kannst kauf ein anderes und fertig.
Es hätte ja auch niciht zum Asus sein müssen. Eher ob ihr bei dem MSI exklusive Vortiele seht, die man andernorts vermissen würde.
By the way, wenn man nicht antworten möchte oder der Post nicht ganz das Thema trifft, kann man sich die Energie auch sparen und nicht antworten ;)
Wie dem auch sei, heute haben wohl alle möglichen Händler nachschub bekommen!
Das MSI ist bestellt und auf dem Weg.
Den Chipsatzlüfter habe ich bei mir nach dem starten noch nie aktiv gesehen. ...
Chipsatzlüfter weder gehört nocht gesehen das er sich dreht. :bigok:
Angeblich hat das MSI ne besser Lüftersteuerung für den Chipsatz-Lüfter
das ist in dem Fall aber auch keine Kunst :haha: - weil das von Mauser3 genannte Crosshair 7 (x470) noch kein PCIE 4.0 und somit auch keinen Chipsatzlüfter hat :d
in unsere neue Kartierungs-Workstation kommt jedenfalls weil wir sie dringend brauchen ein Unify mit einem 3900X - also ich hoffe das die Lobeshymnen hier auf das Board auch gerechtfertigt sind :d (und das obwohl ich selber einen 3700X am CH7 laufen habe und sehr zufrieden damit bin, aber fast 300 Flocken für ne doch "alte" x470 Plattform wären mir zu teuer, dann doch lieber X570 und hoffen das man den Lüfter wie viele hier schreiben - nie hört ^^) Wenn ich mehr Zeit hätte, hätte ich wohl auf das neue MAg Tomahawk WIFI gewartet, das dürfte um so 200-220 Euro mit einer 300+ Euro VRM Lösung der neue P/L King bei X570 werden...
wo bitte ist das unify VRM mässig eine andere Liga ?
das Unify hat :
12(6)+2 Phases Infineon IR35201 (8/6+2)
14x Infineon IR3555 (60A)
Infineon IR3599 (Doppler)
und das neue Tomahawk hat :
12(6)+2 Phases Intersil ISL69247 (6+2)
14x Intersil ISL99360 PowerStage (60A)
Intersil ISL6617 (Doppler)
beide haben (mittels Doppler) 12 Phasen für die Vcore und 2 für den Soc und beide haben 14 Powersages á 60 Watt und die neusten Smart Powerstages von Intersil, die Msi für das Tomahwak verwendet, stehen in ihren Monitoring Fähigkeiten (Temperatur, Genauigkeit usw.) den Infineon Powerstages am Unify in nichts nach - ich sehe also nicht wo die Vrm Lösung am Unify eine andere Liga wäre als die am neuen Tomahawk.
und wenn du mir nicht glaubst - hier wird eigentlich alles gesagt:
das Unify hat halt noch Dinge wie die Debug LED Anzeige, einige Taster fürs Übertakten und einige Messpunkte - aber rein vom VRM kann das neuen Tomahawk locker mithalten...
Die Unify hat 3 vollwertige m2 Slot die voll angebunden sind. Die Kühlung bei der VRM dürfte besser sein allerdings wird der Chipsatz beim Tomahawk wieder besser gekühlt. Ob die Intersil gleichwertig sind müssen tests erst zeigen. Da traue ich Infinion schon mehr. Aber der Preis ist schon gut beim Tomahawk keine Frage. Aber genug OT. Hier im Thread soll es nur um das Unify gehen.
Intersil hat nicht weniger Erfahrung im Bau von VRM Controllern und Powerstages als Infineon und rein von den Spezifikationen der verbauten Komponenten kann Intersil am Tomahawk da locker mit den Infineons am Unfiy mithalten und um nichts anderes ging es mir mit der Aussage das das Tomahawk um ~220 Euro ne Vrm Lösung bietet, welche bis jetzt nur Boards in der 300€+ Klasse haben, wie eben das Unify
das das Unify noch andere Dinge hat wie eben nen dritten M2 Slot, ne bessere Onboard Soundlösung ? und ein paar weitere Spielereien steht ja ausser Frage, aber wer das eben nicht braucht der bekommt mit dem neuen Tomahawk einen P/L Kracher mit in der Preisklasse überragender VRM Ausführung- soferne der Preis von 200-220 Euro wirklich stimmt - ich glaub das nämlich nicht so recht :unsure:
ich hab mich für das Unify entschieden weil ich nicht die Zeit habe auf das Tomahawk zu warten und weil ich hoffe, das wie viele vom Unify berichten der Chipsatzlüfter wirklich nur unter absoluter Vollast über die PCIE 4.0 Schnittstellen anläuft und das sollte in unserem Fall mit "nur" 2 Stück 970 EVO Plus ja hoffentlich nicht eintreten, ansonsten wirds wie bei dir ein 3900X und ich bin schon gespannt wie hoch ich die neuen 2x32GB Ballistics mit den Micron E-Dies am Unify bekomme :d
Ich habe 3 nvme verbaut und der Lüfter dreht nie außer kurz beim einschalten.
Das Board war auch schon Wochen vor der Corona Zeit sehr oft ~100-130€ über dem Normalpreis.
Ich habe den größten Teil meines Setups bei Mindfactory bestellt und das Board stand mehrere Tage mit erhöhtem Preis in meinem Warenkorb. Dann habe ich einfach auf "dumm" getan und MF angeschrieben, warum das Board so stark vom Normalpreis abweicht, ich bei denen eine hohe Summe hinterlassen werde und ganz gerne alles auf einmal bestellen würde, aber eben nur unter der Bedingung, dass das Board um die ~300€ kostet.
Antwort war "ja das ist üblich, da müssen sie immer mal wieder reinschauen" und zack, nach 10Min. lag der Preis bei 295€. Natürlich sofort bestellt ;)
Nach der Bestellung lag das Board wieder bei 430€
Vielleicht hilft dieser Trick dem einen oder anderen weiter ;)
toll... wer möchte mein unify haben ? ;)
Da bist du hier falsch und es gibt keinen Grund zu wechseln. Außerdem falscher Thread.
Sooo gestern war endlich mal Basteltag.
Noctua Kühler und Netzteil fehlen noch, auch da gibt es momentan große Lieferschwierigkeiten.
Betreibe es jetzt mal vorläufig mit dem kleinen Box Kühler und altem 400W Netzteil :/
Ich bin so weit super zufrieden, Chipsatz Lüfter bleibt in Stock Einstellungen auch nach einer Weile Crystal Mark (mit einer PCI E 3 Nvme) komplett ruhig.
Der Kühler erwärmt sich aber doch spürbar. Ich denke für Extreme Auslastung ist der kleine Lüfter schon sinnvoll.
XMP wurde anstandsfrei geladen (3600 16 19 19 39).
Mit weiterem Übertakten bin ich mal noch vorsichtig bis Netzteil und Kühler ankommen.
Übertakten ist nicht wirklich nötig und macht bei Ryzen 3000 auch nicht wirklich Sinn. Ram mit 3600 ist auch schon gut und mehr merkt man nicht mehr.
Wenn man ne CPU-Krücke erwischt hat evtl. nicht, aber ansonsten kann man sich zwischen ca. 10% Leistungsplus oder ner Menge Effizienz entscheiden. Ich hab mich für 50% weniger Stromverbrauch bei Stockleistung entschieden und dazu noch RAM OC betrieben.
Naja für weniger Stromverbrauch ist es vor allem entscheidend die CPU zu untervolten.
Das kann natürlich auf Kosten der Stabilität des Systems gehen und ist von Chip zu Chip auszutesten, aber da ist schon einiges möglich.
Wenn man dann kein festes All-Core OC betreibt, profitiert man bei Ryzen noch vom guten dynamischen heruntertakten /weiterer Spannungsabsenkung im Idle.
Sowie guter Single Core Performance. (Der8auer hat hier man ein gutes Video gemacht im Zuge des schon angesprochenen Asus 7 Hero)
Was hierzu die besten Stellschrauben beim Unify sind habe ich leider noch nicht raus gefunden...
Eben geflasht. Mal testen.
Edit: Was ich bis jetzt bemerkt habe wenn man Win startet das es etwas länger dauert bis das Bild da ist und zB meine App Dock leiste nicht sofort reagiert sondern erst wenige Sekunden später. Der Bios flash hat im übrigen auch etwas länger gedauert als sonst.
Es gibt auf Reddit ein offizielles changelog zum AGESA 1005:
Change log for AGESA 1005
  • Rollup of 1004a, ab, abb, abba patches into a single release
  • Fixed a PCIe® lane configuration issue on the AMD Ryzen™ 3 PRO 2100GE
  • Resolved an intermittent virtual memory error with Realtek onboard LAN
  • Improved POST with select Micron DDR4-3200 memory ICs
  • Optimized PCIe® firmware to improve stability and interoperability
Interessant wäre in der Hinsicht, ob das Problem mit externen Audio Interfaces in Verbindung mit einer PCI-E 4.0 Grafikkarte behoben wurden. Es gibt nämlich querbet durch verschiedene X570 Platinen das Problem, dass es zu extremen Soundstörungen kommt, wenn man eine 4.0 GPU und eine externe Soundkarte verwendet. Einige berichten auch über Probleme mit internen Lösungen. Abhilfe verschaffte bis jetzt nur das Deaktivieren von 4.0 bzw. das runterstufen auf PCI-E 3.0.
Gibt es hier welche, die mit dem UNIFY eine 4.0 Karte UND ein externes Audio Interface betreiben ?
Was genau wäre denn ein externes audio interface? eine usb soundkarte?
Genau, wobei es primär um Studio Lösungen geht, wie z.B. ein Steinberg UR22, Scarlett Focusrite etc. pp.
Aber auch mit einfacheren USB Soundkarten gibt es diese Probleme. Es scheint irgendwo ein Konflikt mit den PCI-E 4.0 Lanes und dem USB Controller zu geben und dieser macht sich dann am stärksten bemerkbar, wenn über USB ein Soundinterface betrieben wird. Es ist bisher unklar, ob das Problem an den RX5000er Karten liegt (weil diese aktuell die einzigen 4.0er GPUs sind) oder ob das generell ein Designfehler der Mainboards oder ein Firmwareproblem ist.
Jedenfalls verschwinden ALLE Probleme, wenn man entweder direkt ne 3.0 GPU einsteckt oder im Bios auf 3.0 forciert.
Hallo zusammen,
mit dem neuen BETA BIOS funktionieren endlich meine G.Skill Trident Z Neo F4-3600C16D-32GTZNC CL16-19-19-39.
Mit dem vorherigen BIOS konnte ich mit dem XMP Profil nicht posten und alles über 3200 lief nicht. Jetzt ohne Probleme mit den Specs der DIMMs.
Hallo zusammen,
Interessant. Ich habe das gleiche Ram-Kit und bei mir lief es schon mit dem vorigen BIOS auf Anhieb. Hast du die RAM Spannung zusätzlich zum aktivierten XMP manuell noch verändert ? Wenn nein, kannst du im BIOS nachschauen, was für eine Ram Spannung anliegt ?
Hattest du "vor" dem neuen BIOS nachgeschaut wie die Spannung war bzw. hattest du versucht, diese manuell zu setzen ?
Bei mir liefen die Gskill Neo auch schon vorher ohne Problem.
Ähnliche Themen
