[Sammelthread] MSI MEG X570(S) Unify (X MAX) / ACE (MAX) (AM4)
product_10_20191002132606_5d9434ee62129.pngproduct_9_20190723092258_5d3661724d540.pngproduct_1629079667f4b88b2d70e858818adcfd4767cd52a2.pngproduct_1629094385a72f0a5d4a37c30deff6b3dcba91659c.png
Sammelthread für das MSI MEG x570 Unify/ACE
Herstellerseite:
MEG X570 UNIFY
Herstellerseite: MEG X570 ACE
Herstellerseite: MEG X570S ACE MAX
Herstellerseite: MEG X570S UNIFY-X MAX
Reviews:
MSI MEG X570 UNIFY Review - Introduction
MSI MEG X570 Unify motherboard (updated)
MSI MEG X570 Unify: An All-Black Motherboard
MSI MEG X570 Unify kommt ohne RGB aus
MSI MEG X570 Unify | Tom's Hardware
MSI MEG X570 ACE Infinity | Hardwareluxx
MSI MEG X570 Ace Motherboard Review
MSI MEG X570 Ace - Review 2019 - PCMag UK
MSI MEG X570 ACE - Hardware Journal
MSI MEG X570 ACE - Review
MSI MEG X570S ACE MAX - digideutsche
MSI MEG X570S ACE MAX - wccftech
MSI MEG X570S ACE MAX - IT Info
MSI MEG X570S UNIFY-X MAX - geeknetic
Besonderheiten:
  • Supports 2nd and 3rd Gen AMD Ryzen™ / Ryzen™ with Radeon™ Vega Graphics and 2nd Gen AMD Ryzen™ with Radeon™ Graphics Desktop Processors for AM4 socket
  • Supports DDR4 Memory, up to 5000+(OC) MHz
  • Aluminum Cover with Extended Heatsink: All-metal extended heatsink cover enlarge the surface of heat dissipation, ensures even high-end processors to run in full speed.
  • Lightning Fast Game Experience: PCIe 4.0, Triple Lightning Gen4 x4 M.2 with M.2 Shield Frozr, StoreMI, AMD Turbo USB 3.2 Gen2.
  • 2.5G Gaming LAN with Latest Wi-Fi 6 Solution: Onboard 2.5G LAN with gaming LAN manager, combining latest Wi-Fi 6 solution which supports MU-MIMO and BSS color technology, delivering the best online gaming experience.
  • Frozr Heatsink Design: Designed with the patented fan and double ball bearings to provide the best performance for enthusiast gamers and prosumers.
  • Audio Boost HD: Isolated audio with dedicated processor combining ESS audio DAC with amplifier, deliver the breathtaking, game-changing sound to create the most exciting gameplay.
  • Pre-installed I/O Shielding: Better EMI protection and more convenience for installation
  • ACE: Mystic Light Infinity, Dual LAN, Extended Heat-pipe Design
Spezifikationen Unify/ACE/ACE MAX/Unify X:
SOCKET:
AM4
CPU (MAX SUPPORT): Ryzen 9
CHIPSET:
AMD® X570 Chipset
DDR4 MEMORY: 1866/ 2133/ 2400/ 2667/ 2800/2933 /3000 /3066 /3200 /3466 /3600 /3733 /3866 /4000 /4133 /4266 /4400 /4533 /4600 /4733 /4800 /5000+ Mhz by JEDEC and A-XMP OC MODE
MEMORY CHANNEL: Dual
DIMM SLOTS: 2/4
MAX MEMORY (GB): 128GB
PCI-E X16: 3
PCI-E X1: 2
SATAIII: 4
M.2 SLOT: 3/4/6
RAID: 0/1/10
TPM (HEADER): 1
LAN UNIFY/UNIFY X: 1x Realtek® RTL8125 2.5 Gbps
LAN ACE/ACE MAX: 1x Intel® WGI211AT Gigabit / Intel® Wi-Fi 6E AX210, 1x Realtek® RTL8125 2.5 Gbps
USB 3.2 PORTS (FRONT): 1(Gen2, Type C), 4(Gen1, Type A)
USB 3.2 PORTS (REAR): 1(Gen2, Type C), 3(Gen2, Type A), 2(Gen1, Type A)
USB 2.0 PORTS (FRONT): 4
USB 2.0 PORTS (REAR): 2
AUDIO PORTS (REAR): 5+ Optical S/PDIF (Realtek® ALC1220 Codec)
DIRECTX: 12
FORM FACTOR: ATX
SLI: Y
CROSSFIRE: Y
OPERATING SYSTEM: Support for Windows® 10 64-bit
MSI Support bei hwluxx.
Hier ein paar Bilder zu denn Boards:
Mal was anderes, ist es normal, dass das Dragon Center so um die 3-5 Minuten zum starten braucht und dann noch ab und an der monitoring Tab inkl. Settings fehlt?
Um mal was drauf zu Antworten. DC am besten gar nicht installieren, und wenn man es unbedingt braucht dann zumindest so einstellen das es nicht beim Systemstart startet. Und dann nur bei bedarf öffnen.
Ich hab's installiert aber nur einmal angemacht um die RGB Ausgänge auf dem Board einszustellen.
Ansonsten ist das DC meiner Meinung völlig überladen und überflüssig.
Bin gespannt. Bald ist es so weit, dann darf das Unify bei mir einziehen
Hier ist es so still? Wirklich so wenig bis gar keine Probleme mit dem Unify? Dann darf ich mich ja freuen, denn das Brett ist unterwegs zu mir 8-)
Meines funktioniert prächtig. Nachdem nun ein Kumpel von mir den RAM richtig eingestellt hat, ist es noch ein ticken schneller geworden.
Ich frage mich nur, wann wird das nächste Update für das UEFI kommen?
Und wie wird man drüber benachrichtigt? Über die Presse?
Am ehesten wirst du hier im Thread informiert werden, sonst kannst du aber auch auf der herstellerseite im Support gucken ....
Auch Null Probleme. Hab jetzt den Chipsatzkühler noch gegen einen Wasserkühler getauscht. Nun ist absolute Ruhe. Gut war vorher auch schon außer beim hochfahren.
Danke @sc07ch, wollte nur die Lüfter einstellen und wunderte mich, dass der Start so ewig braucht. Von der Software bin ich noch ASUS verwöhnt, denn Aura, der SupremeFX Soundtreiber und dessen Oberfläche und Gamefirst waren Sahnestücke die ich seit dem Crosshair III liebte. Daher wird das nächste wohl wieder ein ASUS werden. Die Hardware ist Top beim Unify, das außenrum ist enttäuschend. :)
rd
Ich bin überhaupt kein Freund von Zusatzsoftware für Mainboards. Lüfter würde ich immer im BIOS/UEFI einstellen und nicht mit einer Software. Bei den RGB Anschlüssen ist das leider nicht möglich. Trotzdem wären solche Programme für mich nie ein Argument für den Kauf eines Boards weil sie schlicht und einfach überflüssig sind.
Würde die Lüfter auch im BIOS regeln und gut ist. Diese ganze Mainboard Software Tools vom Hersteller sind alle mist.
hallo zusammen, also ich bekomme die FCLK 1900 ums verecken nicht zum laufen, egal welche ob 3200, 3600 oder 3800 auch alles an Timings probiert.. weder mit 4x8Gb noch mit 2x8GB. Sind Tidenzt Z 3600C16q-32GTZKK alles mit Samsung Chips.
Kann das nur am Speicher liegen oder auch ein Problem von CPU sein?
Das ist kein Problem der CPU, FCLK von 1900 wird nicht von AMD garantiert.
Heißt ich könnte wenn ich unbedingt einen FCLK von 1900 haben will müsste ich den Speicher tauschen und weiter testen?
Vielleicht teste ich mal den Ballistix..
Hab noch etwas getestet, 2 Riegel 1h Prime stabil, 4 Riegel kacken nach 5 min ab bei gleichen Einstellungen.
Warum willst Du bei 3600er RAM einen FCLK von 1900 haben? Lass den RAM auf 3600 laufen und den FCLK auf 1800, also 1:1 und alles ist gut.
Hallo Luxxer,
nach langem hin und her habe ich mich jetzt auch hinreissen lassen und ein neues System bestellt und kann das Brett die Tage in Betrieb nehmen :banana:
Bestellte Config: MSI Unify X570 + 3700X + 32GB DDR4 3600 CL16
so wollte mal feedback geben. also ich hatte mit dem Brett enorme Schwierigkeiten. Das erste Brett war einfach hin daher, Schwamm drüber denn sowas kann immer passieren.
Bei zweiten Brett hab ich meinen Corsair Speicher nicht zu laufen bekommen also auf Gskill gegangen. Habe 4x8GB Tidenzt Z 3600C16q-32GTZKK bestellt. Das System war nun 4 Wochen instabil (abstürze beim Zocken, Bluescreens..). Alles Ausprobiert war nicht hin zubekommen. Als am Wochenende Ballistix Sport 3200 bestellt, diesmal 2x16GB. Seit dem Einbau läuft das Ding einfach ohen Probleme. Die gleichen Speichersettings (3600-1t-18-18-18-36) macht der 3200er von Ballistix ohne Probleme. Prime läuft nach einer Stunde immer noch wobei das mit den Einstellungen mit dem Gskill Speicher nicht 1 Sekunde ging denn dann haben einige Worker sofort wegen Fatal Error gestreikt...
Wenn mir mal langweilig ist teste ich mal noch die 380mhz an und flck von 1900 und das wars..
Jetzt final einfach glücklich mit dem Board.
Lg
schitz
Nachdem ich nun alle Komponenten beieinander hatte, habe ich die letzten Tage damit verbracht, meine Verkabelung neu zu machen, den Rechner zusammenzubauen und Windows 10 nebst Treibern und Software aufzusetzen. Dabei bin ich auf massive Probleme gestossen, die aber nicht vom Board kamen, sondern von der Sch*** Grafikkarte, bzw. deren Treiber. Die habe ich heute schon zurückgeschickt. Das Board läuft nun mit einem Ryzen 3700X und Crucial Ballistix schwarz DDR4-3600(32GB) absolut perfekt(mit alter Graka GTX1050Ti). Und eine meiner NVMes wurde auch nicht erkannt, das aber in keinem Slot, also kann ich von einem Defekt ausgehen und die ist auch schon unterwegs zurück.
Das Board kann ich aber bedenkenlos empfehlen. Das ist wirklich "Out of the Box" lauffähig, auch wenn ich gleich das aktuellste Bios draufgespielt habe. Und der Arbeitspeicher läuft nach laden des XMP Profiles auch einwandfrei. Auch wenns nicht ganz billig ist, dieses Brett ist es wert.
doch kein 3900x? gab es die tage für 429,-
aber schön dass das brett dir taugt.
@xYeti
Nein, doch nicht. Ich habe vor, wenn die Preise der Ryzen 4000er aufgrund des Erscheinens der übernächsten AMD-Prozessor-Generation gefallen sind, auf nen Ryzen 4000 aufzurüsten. Und mir gefallen die 65W TDP bei der Leistung.:sneaky:
Moin,
ich wollte folgendes Bauen:
Msi Meg Unify,
Ryzen 3700x oder 3900x
welchen würdet ihr nehmen?
Wie "groß" da Netzteil?
Ganz lieben Dank! :)
Kommt drauf an, was mit dem PC gemacht werden soll?
Bischen Spielen und was man so macht ;)
Hatte gesehen das bei den "normalen Ryzen" die Ram Werte schlechter waren als z.B beim 3900x.
Bemerkt man das im Alltag?
Ja, bei den Zen CPUs mit nur einem chiplet, betrifft aber nur die Write-Werte, also messen kann man das, aber für Gaming ist das nicht relevant,
da kann man getrost zum 3700x greifen
Moin,
Msi Meg Unify,
denk ni groß nach - wenn das geld für den 3900x da wäre nimm den. der kostet nur noch 429,- was pro kern billiger wäre als der 3700x
NT 600W würde ich schon nehmen. bzw. 650w
Corsair High Modular full attack II 860i iCUE support. :d
So, heute war Bastel-Tag.....mein altes Intel System flog raus und AMD rein. Momentane Konfig siehe Systeminfo.
Einbau sowie in Inbetriebnahme lief ohne Fehler. Das Brett hat nicht einmal gezuckt oder gemeckert. Auch die RAM Timing per XMP hat es sofort umgesetzt.
Bis jetzt bin ich wunschlos glücklich. Qualität des Boards ist 1A. Man merkt die Qualität sobald man es in der Hand hält.
Ähnliche Themen
