[Sammelthread] MSI MEG X570(S) Unify (X MAX) / ACE (MAX) (AM4)
product_10_20191002132606_5d9434ee62129.pngproduct_9_20190723092258_5d3661724d540.pngproduct_1629079667f4b88b2d70e858818adcfd4767cd52a2.pngproduct_1629094385a72f0a5d4a37c30deff6b3dcba91659c.png
Sammelthread für das MSI MEG x570 Unify/ACE
Herstellerseite:
MEG X570 UNIFY
Herstellerseite: MEG X570 ACE
Herstellerseite: MEG X570S ACE MAX
Herstellerseite: MEG X570S UNIFY-X MAX
Reviews:
MSI MEG X570 UNIFY Review - Introduction
MSI MEG X570 Unify motherboard (updated)
MSI MEG X570 Unify: An All-Black Motherboard
MSI MEG X570 Unify kommt ohne RGB aus
MSI MEG X570 Unify | Tom's Hardware
MSI MEG X570 ACE Infinity | Hardwareluxx
MSI MEG X570 Ace Motherboard Review
MSI MEG X570 Ace - Review 2019 - PCMag UK
MSI MEG X570 ACE - Hardware Journal
MSI MEG X570 ACE - Review
MSI MEG X570S ACE MAX - digideutsche
MSI MEG X570S ACE MAX - wccftech
MSI MEG X570S ACE MAX - IT Info
MSI MEG X570S UNIFY-X MAX - geeknetic
Besonderheiten:
  • Supports 2nd and 3rd Gen AMD Ryzen™ / Ryzen™ with Radeon™ Vega Graphics and 2nd Gen AMD Ryzen™ with Radeon™ Graphics Desktop Processors for AM4 socket
  • Supports DDR4 Memory, up to 5000+(OC) MHz
  • Aluminum Cover with Extended Heatsink: All-metal extended heatsink cover enlarge the surface of heat dissipation, ensures even high-end processors to run in full speed.
  • Lightning Fast Game Experience: PCIe 4.0, Triple Lightning Gen4 x4 M.2 with M.2 Shield Frozr, StoreMI, AMD Turbo USB 3.2 Gen2.
  • 2.5G Gaming LAN with Latest Wi-Fi 6 Solution: Onboard 2.5G LAN with gaming LAN manager, combining latest Wi-Fi 6 solution which supports MU-MIMO and BSS color technology, delivering the best online gaming experience.
  • Frozr Heatsink Design: Designed with the patented fan and double ball bearings to provide the best performance for enthusiast gamers and prosumers.
  • Audio Boost HD: Isolated audio with dedicated processor combining ESS audio DAC with amplifier, deliver the breathtaking, game-changing sound to create the most exciting gameplay.
  • Pre-installed I/O Shielding: Better EMI protection and more convenience for installation
  • ACE: Mystic Light Infinity, Dual LAN, Extended Heat-pipe Design
Spezifikationen Unify/ACE/ACE MAX/Unify X:
SOCKET:
AM4
CPU (MAX SUPPORT): Ryzen 9
CHIPSET:
AMD® X570 Chipset
DDR4 MEMORY: 1866/ 2133/ 2400/ 2667/ 2800/2933 /3000 /3066 /3200 /3466 /3600 /3733 /3866 /4000 /4133 /4266 /4400 /4533 /4600 /4733 /4800 /5000+ Mhz by JEDEC and A-XMP OC MODE
MEMORY CHANNEL: Dual
DIMM SLOTS: 2/4
MAX MEMORY (GB): 128GB
PCI-E X16: 3
PCI-E X1: 2
SATAIII: 4
M.2 SLOT: 3/4/6
RAID: 0/1/10
TPM (HEADER): 1
LAN UNIFY/UNIFY X: 1x Realtek® RTL8125 2.5 Gbps
LAN ACE/ACE MAX: 1x Intel® WGI211AT Gigabit / Intel® Wi-Fi 6E AX210, 1x Realtek® RTL8125 2.5 Gbps
USB 3.2 PORTS (FRONT): 1(Gen2, Type C), 4(Gen1, Type A)
USB 3.2 PORTS (REAR): 1(Gen2, Type C), 3(Gen2, Type A), 2(Gen1, Type A)
USB 2.0 PORTS (FRONT): 4
USB 2.0 PORTS (REAR): 2
AUDIO PORTS (REAR): 5+ Optical S/PDIF (Realtek® ALC1220 Codec)
DIRECTX: 12
FORM FACTOR: ATX
SLI: Y
CROSSFIRE: Y
OPERATING SYSTEM: Support for Windows® 10 64-bit
MSI Support bei hwluxx.
Hier ein paar Bilder zu denn Boards:
Du hast sicher Windows ganz neu aufgesetzt?
Den ram auch in die richtigen slots?
Nutzt du ne M.2.? Wenn ja, raus.
In der Liste bei msi stehen sehr viele RAM.. Steht deiner drin?
Ne Windows nicht neu aufgesetzt, läuft prima wenn er startet
Ram ist in den richtigen Slots
M.2 ist meine einzige platte im Rechner funktioniert auch bestens
Speicher hab ich Version 5,32 nicht 4.31 ....
Bin mir jetzt echt nicht sicher welchen Speicher ich mir holen soll, die paar auf der MSI Hp machen es mir nicht wirklich leichter.
Ich denk du hast Probleme?
Moin moin
Eine Frage an die Unify Besitzer :
Hat irgendjemand mit diesem Board schon diesen Coldboot Bug gehabt oder bleibt dieses Board davon verschont?
Bin noch in der frühen Planungsphase meines neuen Rechners und wollte ursprünglich das X570 Aorus Elite kaufen.
Jedoch wird im Sammelthread zur Aorus Serie ( klick! ) von einer gewissen Lotterie bei den Boards berichtet.
Viele haben diesen Coldboot Bug, bei anderen funktioniert das Board problemlos.
Ich möchte einfach nur den Rechner zusammenbauen und Spass haben. Keine Frickelei mit Austausch, neu bestellen und zurücksenden etc.
Und als alter grumpy goat gefällt mir das Board ohne Geblinke ausgesprochen gut.
Danke.
Moin moin
Danke.
Moin moin.
Ich habe diesen sogenannten Coldboot Bug definitiv nicht mit dem Unify. Ich kenne den Bug und hatte ihn schon früher bei einigen Asus Boards.
Das Unifiy ist aber nicht betroffen. Ich trenne den Rechner immer nachts vom Strom und er startet ohne Probleme , schnell und ohne Änderungen der Einstellungen.
Moin moin
Danke.
du hast sicher den thread hier komplett gelesen :) oder den bei CB...
es ist bisher nichts bekannt das es mit dem MB probleme dieser art gibt. eigentlich gibt es auch sonst keine wirklichen probleme.
ganz ohne einstellen geht es aber nicht - RAM, Lüfter, und am besten auch die Volt festsetzen.
Hi hab ich auch, denke aber nicht das sie M.2 oder das aufgesetzte Windows damit zu tun hat da ich jetzt gerade im Windows bin, damit super arbeiten kann und der start, wenn das Bios nicht nicht mit D6 stehenbleibt problemlos funktioniert.
Aus diesem Grund nehme ich erst einmal Abstand davon Windows platt zu machen oder die SSD anzuzweifeln.
Was ich anzweifle ist der Speicher, vor allem da hier jemand den selben Debug mit Corsair Speicher beschrieben hat.
Ich werde erstmal anderen Speicher testen bevor ich alles platt mache. Dennoch danke für deinen Input kann auch wirklich an allem möglichen liegen.
du willst hilfe - aber nimmst se ne an. also hast auch keine probleme.
sehr schlaue Argumentation, aber wenn du wirklich denkst Windows zu plätten wäre die Lösung dann lasse ich in dem Glauben.
Ein Blick in die Signaturen sollte dir verraten, kauf dir Crucial Ballistix oder G.Skill Trident Z. Mit beiden wirst du ganz gute Chancen haben, dass sie funktionieren.
Hiermit melde ich mich auch als ein Nutzer von dem Mainboard.
Wenn man weitere Details wissen möchte, ich habe mein Sysprofil überarbeitet.
Mich hatte das Board nur zu anfang qausi "angequackt" der RAM säße in den nicht dafür konfigurierten Slots. Habe diesen dann umgesteckt und am UEFI selbst kaum etwas eingestellt.
Das einzige was mir so auffällt, in Verbindung mit meinem CPU-Kühler, die Regelung ist recht nervös. Habe diese nun anders eingestellt und schon ist im normalem Windows Betrieb die Drehzahl bei 350rpm schön ruhig.
Da ich ich noch keine Lasten fahre, werde ich noch feststellen, wie laut die wirklich werden können.
Mir scheint allerdings beim start des PCs die Lüftereinstellungen werden erst nach dem Einstellungsautomatiken eingestellt.
Ich werde diesen Thread hier weiter beobachten und dank Euch Erfahrungen sammeln.
Wie es scheint, ist meine Lüftersteuerung defekt! Habe alle Einstellungen mehrfach kontrolliert und konnte bisher keinen Fehler finden.
Egal was ich einstelle, die Lüfter drehen immer bei konstanter Drehzahl. Wobei sich diese Drehzahl durch Anpassung der Lüfterkurve verändern lässt.
Einzig die temperaturabhängige Änderung der Lüfterdrehzahl bleibt aus. Egal ob die CPU nun 30 °C oder 80 °C warm ist, die Drehzahl bleibt konstant bei z.B. 500 U/min.
Irgendjemand eine Idee woran das liegen könnte oder was man da noch testen kann? Oder muss ich davon ausgehen, dass das Mainboard defekt ist?
Ist als Regelgröße auch die CPU Temperatur eingestellt oder evt. aus versehen die CHipsatztemp. ?
Ja hab mich mal für den GSkiller entschieden den gab es in ganz schwarz ohne bling :) Danke
Bitte mal berichten ob es geholfen hat. Und vielleicht auch erstmal nur einen Riegel einbauen und testen.
du meinst sicher den kleinen auf dem MB, ja der dreht beim start kurz ganz auf und dann läuft der wie er eingestellt wurde. sind ja nur ~2 sekunden.
ja, tausch weiter ram, usw. belaste die händler und die umwelt. verärgere die kunden die dein gebrauchten mist, der ganz ist, bekommen. nur weil du resistent bist!
oh, stimmt - bin der neue ohne ahnung! :hail: :hmm:
Ein BIOS-Fehlercode hat nun aber wirklich nichts mit Windows zu tun. Da ist das OS noch gar nicht im Spiel.
An der M2 liegt es eher auch nicht. Statt xmp die Werte Manuel eintragen mal.
So hier die Rückmeldung, also hab erst den Ram getauscht ... selber Fehler. Dann Prozessor getauscht den es kam endlich der 3900x an .... selber Fehler.
Gott sei dank habe ich mir direkt ein Ersatzboard schicken lassen (hatte halt ein komisches Gefühl, hat mal vielleicht auch nach den gefühlt 375sten Board im Leben)..
Nun läuft alles normal und tut was es soll. Tja was soll man sagen Montagsborad erwisch?!
Und eines noch ja Ram Werte muss man zwingend manuell eingeben die haben nie gestimmt.
Die Einstellungen haben alle gepasst - das hab ich sicher über 10x komplett neu eingestellt.
Heute Abend hab ich dann erstmal die Batterie raus genommen und dabei auch gleich den CPU-Kühler neu montiert.
Nachdem ich alles wieder zusammengebaut und eingestellt hatte, funktionierte die Lüftersteuerung wieder ohne Probleme.
Ich habe heute ein neues Beta Bios A35 bekommen. Wer Interesse hat kann sich bei mir melden. Changelog gab es wie immer keinen dazu. Das Datum ist vom 15.01.2020 und so mit 2 Wochen neuer als das A34 welches vom Anfang Jänner war. Bei mir läuft es inzwischen und bis jetzt nichts negatives festgestellt.
Gerne, bin für solche Späße immer zu haben ;)
Wundert mich wirklich ein wenig, dass da offiziell gar nichts neues kommt.
Könnte aber auch bedeuten, dass die viel vom ACE abgeguckt haben und sich die Bugs wirklich sehr in Grenzen halten.
Wurde eigentlich mit dem Beta Bios die DRAM Spannung gefixt? Bezogen auf, dass ich 1.330 V einstellen muss, um 1,350 V zu bekommen.
K.A, aber das Problem habe ich so auch nicht. Ich stelle 1,4V ein und 1,404 kommen dabei raus (Ballistix Sport LT 3200 @3600).
Guten Abend zusammen,
ich interessiere mich für das MEG UNIFY und eventuell für das ACE. Soweit ich weiss liegen die Unterschiede ja nur im Design (RGB, Abdeckungen) und der fehlenden Heatpipe zum IO-Hub.
Ist das korrekt, dass das UNIFY etwas kühlere VRMs hat, weil die Abwärme aufgrund der fehlenden Heatpipe nicht zu den VRMs geführt wird ? Gibt es sonst noch technische Unterschiede, die für/gegen das UNIFY sprechen ? Wie ist das STRIX-E von ASUS im Vergleich ?
Ich bin bereit bis max. 350€ (+/- paar € machen dann auch keinen Unterschied) auszugeben.
Setup sähe wie folgt aus:
X570 Unify
3700X
2x16Gig 3000 oder 3200er von Crucial
Dark Rock Pro4 oder vergleichbarer Kühler, evtl. Noctua
1TB HDD + 500GB Samsung NVMe
FractalDesign Meshify C (da bin ich mir noch nicht sicher.. finde das Case gut aber brauche das Glaspanel nicht)
Grafikkarte kommt später, zur Überbrückung kommt da erstmal ne alte R9 380 rein.
Netzteil habe ich hier ein Straight Power E11 500W von BQ rumliegen.
Edit:
Ich habe vergessen zu erwähnen, warum das ACE überhaupt in Frage kommt: Meine jungen Neffen, die häufig bei mir übernachten, versuchen mich seit Wochen zu überreden ein Bling Bling Setup zu basteln. Hatte ich bisher noch nie, bin aber auch nicht davon abgeneigt. Wenn es der RGB'sche Weg sein soll, käme eben das MEG ACE auch in Frage. RAM würde ich dann auch was mit RGB kaufen und evtl. den LuKü mit Compact WaKü ersetzen. (aus kühlungstechnischer Sicht eigl.ungern, aber meinen Neffen zur Liebe evtl. doch)
Die primaeren Unterschiede hast schon genannt, die Temp. Differenz (Chipset/VRMs) ist allerdings zu vernachlässigen.
Vorteil beim Ace ist die Intel NIC + 2.5G Realtek.
Der RGB Mirror ist naja, RGB halt. Ich hab das Ace damals wegen gutem Preis (Amazon + Gutscheine) genommen und bin absolut zufrieden damit, 0 Probleme. Ich nutzt allerdings nur die Intel NIC, sofern du vor hast die Realtek NIC (Unify/Ace) zu nutzen, unbedingt die aktuellen Realtek Treiber installieren (ohne geht kein Standby).
Beim Gehäuse isses die Wahl zwischen Silent (Define C) oder Airflow (Meshify).
Das NT sollte passen je nach verwendeter GPU.
Das mit dem NIC habe ich glatt übersehen. Der Intel NIC wäre mir zwar lieber, aber jahrelang Realtek hat mir auch keine Probleme gemacht.
Ich sehe grad auch, dass beim ACE der Drache im IO Hub gar nicht leuchtet. Ich denke das lässt mich dann, egal ob RGB Build oder nicht, mehr zum Unify tendieren, rein aus preislichen Gründen.
Ich warte aber noch ein bisschen, werde aber meine Entscheidung natürlich hier mitteilen.
Bis zum 17. März gibt es ne cashback Aktion von msi. Da würde ich mit unify/3700x oder ace/3700x 70€ bekommen.
Ob Intel oder Realtek LAN ist irrelevant inzwischen. Die nehmen sich beide nichts und das man immer denn aktuellsten Treiber/Bios verwenden sollte versteht sich eh von selbst.
@talha777
Ob nun das Ace, Unify oder Asus, da wärst du im Kaufthread besser aufgehoben denke ich.
Mal was anderes, ist es normal, dass das Dragon Center so um die 3-5 Minuten zum starten braucht und dann noch ab und an der monitoring Tab inkl. Settings fehlt?
Ähnliche Themen
