[Sammelthread] MSI MEG X570(S) Unify (X MAX) / ACE (MAX) (AM4)
product_10_20191002132606_5d9434ee62129.pngproduct_9_20190723092258_5d3661724d540.pngproduct_1629079667f4b88b2d70e858818adcfd4767cd52a2.pngproduct_1629094385a72f0a5d4a37c30deff6b3dcba91659c.png
Sammelthread für das MSI MEG x570 Unify/ACE
Herstellerseite:
MEG X570 UNIFY
Herstellerseite: MEG X570 ACE
Herstellerseite: MEG X570S ACE MAX
Herstellerseite: MEG X570S UNIFY-X MAX
Reviews:
MSI MEG X570 UNIFY Review - Introduction
MSI MEG X570 Unify motherboard (updated)
MSI MEG X570 Unify: An All-Black Motherboard
MSI MEG X570 Unify kommt ohne RGB aus
MSI MEG X570 Unify | Tom's Hardware
MSI MEG X570 ACE Infinity | Hardwareluxx
MSI MEG X570 Ace Motherboard Review
MSI MEG X570 Ace - Review 2019 - PCMag UK
MSI MEG X570 ACE - Hardware Journal
MSI MEG X570 ACE - Review
MSI MEG X570S ACE MAX - digideutsche
MSI MEG X570S ACE MAX - wccftech
MSI MEG X570S ACE MAX - IT Info
MSI MEG X570S UNIFY-X MAX - geeknetic
Besonderheiten:
  • Supports 2nd and 3rd Gen AMD Ryzen™ / Ryzen™ with Radeon™ Vega Graphics and 2nd Gen AMD Ryzen™ with Radeon™ Graphics Desktop Processors for AM4 socket
  • Supports DDR4 Memory, up to 5000+(OC) MHz
  • Aluminum Cover with Extended Heatsink: All-metal extended heatsink cover enlarge the surface of heat dissipation, ensures even high-end processors to run in full speed.
  • Lightning Fast Game Experience: PCIe 4.0, Triple Lightning Gen4 x4 M.2 with M.2 Shield Frozr, StoreMI, AMD Turbo USB 3.2 Gen2.
  • 2.5G Gaming LAN with Latest Wi-Fi 6 Solution: Onboard 2.5G LAN with gaming LAN manager, combining latest Wi-Fi 6 solution which supports MU-MIMO and BSS color technology, delivering the best online gaming experience.
  • Frozr Heatsink Design: Designed with the patented fan and double ball bearings to provide the best performance for enthusiast gamers and prosumers.
  • Audio Boost HD: Isolated audio with dedicated processor combining ESS audio DAC with amplifier, deliver the breathtaking, game-changing sound to create the most exciting gameplay.
  • Pre-installed I/O Shielding: Better EMI protection and more convenience for installation
  • ACE: Mystic Light Infinity, Dual LAN, Extended Heat-pipe Design
Spezifikationen Unify/ACE/ACE MAX/Unify X:
SOCKET:
AM4
CPU (MAX SUPPORT): Ryzen 9
CHIPSET:
AMD® X570 Chipset
DDR4 MEMORY: 1866/ 2133/ 2400/ 2667/ 2800/2933 /3000 /3066 /3200 /3466 /3600 /3733 /3866 /4000 /4133 /4266 /4400 /4533 /4600 /4733 /4800 /5000+ Mhz by JEDEC and A-XMP OC MODE
MEMORY CHANNEL: Dual
DIMM SLOTS: 2/4
MAX MEMORY (GB): 128GB
PCI-E X16: 3
PCI-E X1: 2
SATAIII: 4
M.2 SLOT: 3/4/6
RAID: 0/1/10
TPM (HEADER): 1
LAN UNIFY/UNIFY X: 1x Realtek® RTL8125 2.5 Gbps
LAN ACE/ACE MAX: 1x Intel® WGI211AT Gigabit / Intel® Wi-Fi 6E AX210, 1x Realtek® RTL8125 2.5 Gbps
USB 3.2 PORTS (FRONT): 1(Gen2, Type C), 4(Gen1, Type A)
USB 3.2 PORTS (REAR): 1(Gen2, Type C), 3(Gen2, Type A), 2(Gen1, Type A)
USB 2.0 PORTS (FRONT): 4
USB 2.0 PORTS (REAR): 2
AUDIO PORTS (REAR): 5+ Optical S/PDIF (Realtek® ALC1220 Codec)
DIRECTX: 12
FORM FACTOR: ATX
SLI: Y
CROSSFIRE: Y
OPERATING SYSTEM: Support for Windows® 10 64-bit
MSI Support bei hwluxx.
Hier ein paar Bilder zu denn Boards:
Noch eine kurze Frage. Das Board hat doch diesen 2,5T Netzwerkanschluß. Ich kann aber diese Geschwindigkeit gar nicht nutzen, denn ich habe ausschließlich Komponenten mit 1000Gb verbaut. Da ich in diesem Bereich nicht (mehr) so firm bin, muss ich mal ganz blöd fragen, ob der Lananschluß vom Board dann auch mit meinem 1000er Netzwerk kompatibel ist. Sorry für meine für euch vielleicht dumm erscheinende Fragen, aber ich bin halt nunmal seit 6 Jahren ziemlich raus aus der Materie.
is genauso Abwärtskompatibil wie usb 3.0 zu usb 2.0
du machst dir zu viele gedankn
@xYeti
Ich will nur in keine Falle tappen. Kaufen, Zusammenbauen, Bios Flashen und einstellen, Windows installieren und einrichten und gut ist, jua so wünsche ich mir das. Das wäre dann für mich sozusagen "out of the Box" :sneaky:
was denn für "fallen"?
Einfach machen.
Na, das irgendetwas nicht so funktioniert bzw. ich noch auf die Schnelle etwas nachkaufen muss, weil ich etwas nicht beachtet habe.
cpu, ram, kühler, mb - was willst du da noch kaufen? kabel liegen bei - steht dazu alles extra beim hersteller auf der seite was bei liegt.
is ni anders wie vor 6 jahren.
Ist eigentlich bekannt, ob die zukünftigen 4000er Ryzen auch auf dem Board laufen werden oder braucht man dann wieder ein neues Board?
4000er werden nicht mehr laufen das ist bekannt. Die kommende CPU dieses Jahr wird noch laufen, jene ab 2021 aber nicht mehr.
Guter Preis, würde aber immer zum Unify raten. Der Aufpreis zum ACE finde ich nicht gerechtfertigt.
Hatte mir das Ace wegen der nicht Verfügbarkeit und unschlagbarem Preis (+Gutschein) bei Ama geschossen. Sonst waers vmtl au das Unifi geworden.
Bin aber absolut zufrieden damit.
Das ACE ist ja ein gutes Board auch.
Nach allem was ich im Netz finde ist der 4000er Ryzen die letzte Generation die noch auf AM4 läuft. Also auch auf dem X570
So habe ich das auch im Kopf, aber sicher ist da ja nichts
Beim ACE zahlt mal halt die Beleuchtung mit und das es eine Heatpipe mehr hat allerdings die VRM sind beim Unify besser. Wegen denn 4000 so muss man das abwarten. Hellsehen kann keiner, sind alles derzeit nur Gerüchte. Sicher ist die kommende CPU welche wohl Q3 bzw Q4 kommt wird auf AM4 laufen, danach ist aber wohl Schluss. Wenn man bedenkt wie viele Jahre es AM4 gegeben hat ist das sehr löblich von AMD. Hoffe die nächste Generation wird auch wieder ein paar Jahre halten dann.
Meine Erfahrung mit dem Unify sind bisher relativ bescheiden.
Bekomme mein G.Skill F4-3600C16D-32GTZR leider nichtmal mit XMP zum Laufen :cautious:
Hat jemand ähnliche Probleme und einen Rat für mich?
Ich habe die F4-3600C16D-32GTZNC und die laufen nach Anpassen super.
Magst du mir verraten was du angepasst hast? :-)
Du hast ja die besseren 32GTZR, ich nur die 32GTZNC von daher hast du andere Chips auch drauf. Im Grunde was dem Speed betrifft ist da aber kein Unterschied, sieht man nur bei Benchmarks.
Naja, aber bei mir läuft nichtmal XMP. Meinst du damit, dass ich die Timings noch manuell langsamer stellen soll?
Ich hatte mir die bei MSI vorgeschlagenen G.Skill RipJaws V schwarz, (F4-3200C14D-32GVK) gekauft. Wurden mit der XMP Einstellung gleich richtig erkannt und habe mist auf die Probleme mit dem fehlenden Chip Satz Treiber und dem MSI DragonCenter keine Probleme.
Nachdem ich das MSI DragonCenter und die Chip Satz Treiber von dem Mainboard installierte, läuft er mit dem Ryzen Balance Energieplan perfekt.
Bis Windows komm ich nicht. Sobald ich XMP lade, piept der Speaker wie bescheuert
Bios ist aktuell?
Stell die Timings manuell ein. Wenn ich XMP nutze sind die Second Timings schlechter. Jetzt manuell alles super.
Ich würde die Timings einfach mal selber eintragen und testen.
Ähnliche Themen
