[Sammelthread] MSI MEG X570(S) Unify (X MAX) / ACE (MAX) (AM4)
product_10_20191002132606_5d9434ee62129.pngproduct_9_20190723092258_5d3661724d540.pngproduct_1629079667f4b88b2d70e858818adcfd4767cd52a2.pngproduct_1629094385a72f0a5d4a37c30deff6b3dcba91659c.png
Sammelthread für das MSI MEG x570 Unify/ACE
Herstellerseite:
MEG X570 UNIFY
Herstellerseite: MEG X570 ACE
Herstellerseite: MEG X570S ACE MAX
Herstellerseite: MEG X570S UNIFY-X MAX
Reviews:
MSI MEG X570 UNIFY Review - Introduction
MSI MEG X570 Unify motherboard (updated)
MSI MEG X570 Unify: An All-Black Motherboard
MSI MEG X570 Unify kommt ohne RGB aus
MSI MEG X570 Unify | Tom's Hardware
MSI MEG X570 ACE Infinity | Hardwareluxx
MSI MEG X570 Ace Motherboard Review
MSI MEG X570 Ace - Review 2019 - PCMag UK
MSI MEG X570 ACE - Hardware Journal
MSI MEG X570 ACE - Review
MSI MEG X570S ACE MAX - digideutsche
MSI MEG X570S ACE MAX - wccftech
MSI MEG X570S ACE MAX - IT Info
MSI MEG X570S UNIFY-X MAX - geeknetic
Besonderheiten:
  • Supports 2nd and 3rd Gen AMD Ryzen™ / Ryzen™ with Radeon™ Vega Graphics and 2nd Gen AMD Ryzen™ with Radeon™ Graphics Desktop Processors for AM4 socket
  • Supports DDR4 Memory, up to 5000+(OC) MHz
  • Aluminum Cover with Extended Heatsink: All-metal extended heatsink cover enlarge the surface of heat dissipation, ensures even high-end processors to run in full speed.
  • Lightning Fast Game Experience: PCIe 4.0, Triple Lightning Gen4 x4 M.2 with M.2 Shield Frozr, StoreMI, AMD Turbo USB 3.2 Gen2.
  • 2.5G Gaming LAN with Latest Wi-Fi 6 Solution: Onboard 2.5G LAN with gaming LAN manager, combining latest Wi-Fi 6 solution which supports MU-MIMO and BSS color technology, delivering the best online gaming experience.
  • Frozr Heatsink Design: Designed with the patented fan and double ball bearings to provide the best performance for enthusiast gamers and prosumers.
  • Audio Boost HD: Isolated audio with dedicated processor combining ESS audio DAC with amplifier, deliver the breathtaking, game-changing sound to create the most exciting gameplay.
  • Pre-installed I/O Shielding: Better EMI protection and more convenience for installation
  • ACE: Mystic Light Infinity, Dual LAN, Extended Heat-pipe Design
Spezifikationen Unify/ACE/ACE MAX/Unify X:
SOCKET:
AM4
CPU (MAX SUPPORT): Ryzen 9
CHIPSET:
AMD® X570 Chipset
DDR4 MEMORY: 1866/ 2133/ 2400/ 2667/ 2800/2933 /3000 /3066 /3200 /3466 /3600 /3733 /3866 /4000 /4133 /4266 /4400 /4533 /4600 /4733 /4800 /5000+ Mhz by JEDEC and A-XMP OC MODE
MEMORY CHANNEL: Dual
DIMM SLOTS: 2/4
MAX MEMORY (GB): 128GB
PCI-E X16: 3
PCI-E X1: 2
SATAIII: 4
M.2 SLOT: 3/4/6
RAID: 0/1/10
TPM (HEADER): 1
LAN UNIFY/UNIFY X: 1x Realtek® RTL8125 2.5 Gbps
LAN ACE/ACE MAX: 1x Intel® WGI211AT Gigabit / Intel® Wi-Fi 6E AX210, 1x Realtek® RTL8125 2.5 Gbps
USB 3.2 PORTS (FRONT): 1(Gen2, Type C), 4(Gen1, Type A)
USB 3.2 PORTS (REAR): 1(Gen2, Type C), 3(Gen2, Type A), 2(Gen1, Type A)
USB 2.0 PORTS (FRONT): 4
USB 2.0 PORTS (REAR): 2
AUDIO PORTS (REAR): 5+ Optical S/PDIF (Realtek® ALC1220 Codec)
DIRECTX: 12
FORM FACTOR: ATX
SLI: Y
CROSSFIRE: Y
OPERATING SYSTEM: Support for Windows® 10 64-bit
MSI Support bei hwluxx.
Hier ein paar Bilder zu denn Boards:
Nutze deine Tastatur und Mouse wie immer. Einfach hinten anstecken. Verstehe denn Sinn der Frage nicht wirklich. Wegen Bios lade das neuste runter und so fern nicht drauf kannst du es flashen.
Na, der eine USB 2.0 Port ist doch laut Beschreibung auf der Herstellerseite zum Flashen gedacht. Wenn die beiden Ports mit Maus und Tastatur belegt sind, kann ich dort doch keinen Stick einstecken. Oder flasht ihr das Bios unter Windows oder an einem anderen Port? Ich hab noch ein recht altes Board und deshalb ist mir das nicht ganz klar, denn dort unter Windows zu Flashen ist Selbstmord.
hab ich dir schon beantwortet. das bios muss gar ni geflasht werden , es läuft auch so alles. hab hinten 3 usb teile stecken - läuft - auch im bios.
Ernsthaft? Das Teil läuft ohne das Bios zu flashen? Das wäre ja mal mehr als nur positiv.
Bios würde ich schon Updaten alleine schon wegen Agesa 1004B.
@Scoty
Machst du das an dem Port oder unter Windows?
Ich hab es eingebaut und erstmal probiert.. Und mich dann ums BIOS kümmert..
Zum USB... Es ist genug Platz... Und 3.0 kann auch 2.0
@xYeti
Das heißt also, ich kann jeden Port zum Flashen benutzen?
Das wäre USB Flashback aber, das kann man verwenden, muss man aber nicht. Und beantwortet auch nicht seine Frage nebenbei. Man kann jeden USB Port verwenden wenn man im BIOS selbst flasht.
er wollte wissen für was der bios usb ist.
und das brett kann out of the box genutzt werden - selbst getestet - auch mit ram - null probleme.
Klar läuft es sofort, Update empfehle ich dennoch sofern es nicht schon drauf ist.
Im Bios gibt es die Option M-Flash.
Da wird das Board rebootet und dann ruft sich diese Option selbst auf.
Wenn der Stick erkannt wird, kann man den Datensatz sehen.
Drauf klicken und los gehts aber FAT32 ist Plicht.
Der Bios USB sollte den so genannten EZ Flash darstellen, das kann man nutzen, wenn das Board vermeintlich *Tod* ist: https://forum-de.msi.com/index.php/topic,113838.0.html
Dann müsste das ja über den angeschlossenen Front-Header auch funktionieren. Ist heute also einfacher als wie früher:-)
Ja geht auch über Front USB. USB Flashback ist eher dafür gedacht sollte ein Update mal schief gehen kann man darüber ein Bios nochmals flashen.
Früher sind viele an der *DOS Zeile* gescheitert.
War aber halb so schlimm, die meisten waren ja gesockelt... :bigok:
Warum ich das gefragt habe? Es ist so, dass der Rechner unter einem Schreibtisch steht, der 90cm tief ist. Das heißt also beim Umstecken jedesmal Kriechtier spielen und das will ich vermeiden, denn darüber freut sich mein Kreuz und mein Nacken so gar nicht :sneaky:
Es funktioniert wie Scoty gesagt hat.... . Wenn das Board den Stick *findet* ist alles gut.
Sehr schön. Jetzt muss nur noch mein Geld bis Mitte März(oder früher) reinkommen, und dann gehts los
deswegen kannst es vorn dran machen oder hinten wenn es lang genug ist. gibt ja genug anschlüsse. und "häng" dich ni so am bios auf. :) is nie wie bei gigabyte aktuell
Na dann viel Spaß mit dem neuen System.
Danke, das werde ich haben.
Das ist dann mein erstes MSI Board in meiner PC-Selbstbau-Laufbahn, die schon seit 2001 andauert. Bisher habe ich hauptsächlich Asus und Gigabyte verbaut. Aschrott zweimal und zweimal reingefallen. Mein Stiefsohn schwört auf MSI und vielleicht hat er da ja recht. Wir werden sehen ...
hab schon, asrock, gigabyte, asus, jetzt msi - und noch nie probleme gehabt.
Nachdem ich mir nun auch das Board gegönnt und am Wochenende meinen neuen PC zusammengebaut habe, gleich mal zwei Fragen zu den Treibern und Programmen.
1) Macht es Sinn das MSI Dragon Center zu installieren bzw. welche Voteile habe ich davon?
2) Wie seid ihr mit den Audio-Treibern verfahren?
Ich habe den Audio-Treiber automatisch durch Windows installieren lassen. Den Nahimic- und Realtek-Treiber habe ich nicht angerührt, da ich keine Lust auf eine verbuggte Realtek-Software habe.
Und falls jemand einen 3700X betreibt. Sind Idle-Temperaturen zwischen 35-45 °C (teilweise stark schwankend) normal?
Unter Last sind es gerne mal 75-85 °C @ 4 GHz auf allen Kernen (kein OC). Gekühlt wird mit einem Broken 3 mit einem Lüfter der bei ca. 800 U/min läuft.
Ich gehe zwar davon aus, dass alles normal ist. Eine zweite Meinung wäre dennoch ganz gut.
Temperatur Schwankungen sind normal, das sollte aber jetzt wirklich allgemeinen bekannt sein und findet man leicht per Suche. Ob du die Treiber über Win oder selbst installieren tust macht keinen Unterschied.
1. Kannst du dir sparen
2. Ich hab mir den passenden Treiber, ganz aktuell, aus dem Netz gezogen. Dieses nahimic hab ich weg gelassen.
Zu deinen Temperaturen.. Wie immer hier, befass dich mit vcore senken und deine temp wird besser.
@xYeti
Hast du dir den von der Realtek-Seite direkt gezogen?
Bei mir war es nach 10 Jahren Intel und Nvidia Mitte Dezember nach meiner positiven Erfahrung mit einem Athlon vor dem Intel System auch wieder ein AMD System geworden.
MSI Meg X570 Unify, Ryzen 7 3700X, Powercolor Red Devil RX5700XT
Noch unwissend bei der benötigten Software installierte ich auch das MSI Dragon Center und hatte ebenfalls stark schwankende IDLE Temperaturen und CPU Frequenzen. Erst hier im Thema merkte ich, das ich die Chip Treiber nicht installiert hatte und mir die Ryzen Energiesparpläne in Windows fehlten.
Nach der Deinstallation von den Windows Treibern und Installation der AMD Treiber hatte ich danach auch die Ryzen Energiesparpläne. Seit der Deinstallation vom MSI Dragon Center herrscht nun Ruhe im PC.
Bei meinem BeQuiet! Silent Base 600 Gehäuse mit geringster Lüfterdrehzahl in Stellung 1, hat sich die Temperatur bei Internetnutzung nun bei 39°C eingependelt. Die CPU Lüfterkurve habe ich so angepasst, das der Lüfter bis 50°C mit 50% dreht und erst danach langsam die Drehzahl steigert.
Im Spiel bei Need For Speed Head habe ich dann max. 75-80°C bei einer CPU Frequenz von 4200.
Nach nun 6 Wochen experimentieren bin ich nun zufrieden mit der Systemleistung. Ohne OC hat der PC genug Leistung und anscheinend auch noch Reserven für die nächste Zeit.
Noch eine kurze Frage. Das Board hat doch diesen 2,5T Netzwerkanschluß. Ich kann aber diese Geschwindigkeit gar nicht nutzen, denn ich habe ausschließlich Komponenten mit 1000Gb verbaut. Da ich in diesem Bereich nicht (mehr) so firm bin, muss ich mal ganz blöd fragen, ob der Lananschluß vom Board dann auch mit meinem 1000er Netzwerk kompatibel ist. Sorry für meine für euch vielleicht dumm erscheinende Fragen, aber ich bin halt nunmal seit 6 Jahren ziemlich raus aus der Materie.
Ähnliche Themen
