[Sammelthread] MSI MEG X570(S) Unify (X MAX) / ACE (MAX) (AM4)
product_10_20191002132606_5d9434ee62129.pngproduct_9_20190723092258_5d3661724d540.pngproduct_1629079667f4b88b2d70e858818adcfd4767cd52a2.pngproduct_1629094385a72f0a5d4a37c30deff6b3dcba91659c.png
Sammelthread für das MSI MEG x570 Unify/ACE
Herstellerseite:
MEG X570 UNIFY
Herstellerseite: MEG X570 ACE
Herstellerseite: MEG X570S ACE MAX
Herstellerseite: MEG X570S UNIFY-X MAX
Reviews:
MSI MEG X570 UNIFY Review - Introduction
MSI MEG X570 Unify motherboard (updated)
MSI MEG X570 Unify: An All-Black Motherboard
MSI MEG X570 Unify kommt ohne RGB aus
MSI MEG X570 Unify | Tom's Hardware
MSI MEG X570 ACE Infinity | Hardwareluxx
MSI MEG X570 Ace Motherboard Review
MSI MEG X570 Ace - Review 2019 - PCMag UK
MSI MEG X570 ACE - Hardware Journal
MSI MEG X570 ACE - Review
MSI MEG X570S ACE MAX - digideutsche
MSI MEG X570S ACE MAX - wccftech
MSI MEG X570S ACE MAX - IT Info
MSI MEG X570S UNIFY-X MAX - geeknetic
Besonderheiten:
  • Supports 2nd and 3rd Gen AMD Ryzen™ / Ryzen™ with Radeon™ Vega Graphics and 2nd Gen AMD Ryzen™ with Radeon™ Graphics Desktop Processors for AM4 socket
  • Supports DDR4 Memory, up to 5000+(OC) MHz
  • Aluminum Cover with Extended Heatsink: All-metal extended heatsink cover enlarge the surface of heat dissipation, ensures even high-end processors to run in full speed.
  • Lightning Fast Game Experience: PCIe 4.0, Triple Lightning Gen4 x4 M.2 with M.2 Shield Frozr, StoreMI, AMD Turbo USB 3.2 Gen2.
  • 2.5G Gaming LAN with Latest Wi-Fi 6 Solution: Onboard 2.5G LAN with gaming LAN manager, combining latest Wi-Fi 6 solution which supports MU-MIMO and BSS color technology, delivering the best online gaming experience.
  • Frozr Heatsink Design: Designed with the patented fan and double ball bearings to provide the best performance for enthusiast gamers and prosumers.
  • Audio Boost HD: Isolated audio with dedicated processor combining ESS audio DAC with amplifier, deliver the breathtaking, game-changing sound to create the most exciting gameplay.
  • Pre-installed I/O Shielding: Better EMI protection and more convenience for installation
  • ACE: Mystic Light Infinity, Dual LAN, Extended Heat-pipe Design
Spezifikationen Unify/ACE/ACE MAX/Unify X:
SOCKET:
AM4
CPU (MAX SUPPORT): Ryzen 9
CHIPSET:
AMD® X570 Chipset
DDR4 MEMORY: 1866/ 2133/ 2400/ 2667/ 2800/2933 /3000 /3066 /3200 /3466 /3600 /3733 /3866 /4000 /4133 /4266 /4400 /4533 /4600 /4733 /4800 /5000+ Mhz by JEDEC and A-XMP OC MODE
MEMORY CHANNEL: Dual
DIMM SLOTS: 2/4
MAX MEMORY (GB): 128GB
PCI-E X16: 3
PCI-E X1: 2
SATAIII: 4
M.2 SLOT: 3/4/6
RAID: 0/1/10
TPM (HEADER): 1
LAN UNIFY/UNIFY X: 1x Realtek® RTL8125 2.5 Gbps
LAN ACE/ACE MAX: 1x Intel® WGI211AT Gigabit / Intel® Wi-Fi 6E AX210, 1x Realtek® RTL8125 2.5 Gbps
USB 3.2 PORTS (FRONT): 1(Gen2, Type C), 4(Gen1, Type A)
USB 3.2 PORTS (REAR): 1(Gen2, Type C), 3(Gen2, Type A), 2(Gen1, Type A)
USB 2.0 PORTS (FRONT): 4
USB 2.0 PORTS (REAR): 2
AUDIO PORTS (REAR): 5+ Optical S/PDIF (Realtek® ALC1220 Codec)
DIRECTX: 12
FORM FACTOR: ATX
SLI: Y
CROSSFIRE: Y
OPERATING SYSTEM: Support for Windows® 10 64-bit
MSI Support bei hwluxx.
Hier ein paar Bilder zu denn Boards:
Die Kühlung vom Ultra is genauso effizient, Finstack vs Aluklotz(der irgendwann mal maximal warm ist und dann deutlich weniger Oberflaeche zum abgeben hat...)
Trc hat fast 3ns ausgemacht (default XMP waehlt 85), hast du Trfc auf 631 gesetzt?
Ich hatte auf dem Ultra 69,4ns, jetzt mit dem Ace 70,1ns Messtoleranz...
TRFC hatte ich auch Auto gelassen was 631 entspricht.
Kann eigentlich jemand was zur Verfügbarkeit des Boards sagen? Es ist momentan nirgends verfügbar und etwas vergleichbares zum MSI Unify gibt es aktuell auch nicht.
sofort lieferbar:
bei MF in 4 tagen....
usw
Danke. Wie ich sehe, hat sich die Liefersituation inzwischen wieder etwas entspannt. Dann kann ich demnächst bestellen und muss nicht mit nem Gigabyte Aorus Ultra auf die 2. Wahl zurückgreifen.
Um die 69ns habe ich auch ob wohl der tRC so hoch ist bei mir. Sonst läuft der Ram aber gut. 2x Karhu mit 10.000% und auch sonst verhält sich das System unauffällig. Für mich hat sich der Ram Wechsel somit ausgezahlt.
Ja für denn Preis ist das Board ok, vor allem besser als das teuere ACE was die vrm angeht. Bios Update mäßig ist ja seit November nix mehr gekommen. Dabei gibt es doch paar Sachen die einen FIX tringend notwendig machen würden wie die lahme SSD Schreibgeschwindigkeit die bei MSI bekannt ist schon länger aber es kommt halt kein nix.
Hallo zusammen, hätte interesse an dem Unify Brett, meine frage ist kann man ein bios update ohne CPU/RAM machen ?
kann man. aber wozu willst du das tun?
Wollte nur wissen ob es das Feature hat, man kann ja nie wissen ob man das mal brauchen kann.
Ja es hat USB Flashback.
Was willst du explizit wissen?
Ich merke bei mir nichts von wegen langsamen Zugriffszeiten. (wenn ist das meßbar)
Nach anfänglicher Umgewöhnungsphase weg vom Crosshair will ich das MSI nicht mehr missen.
Aber zu Gigabyte kann ich dir nichts sagen, ist ein Hersteller den ich nie kaufen würde.
@Holzmann,die Marke spricht mich persönlich nicht an. Da springt kein Funke über, ist wie mit SEAT würde ich auch nie kaufen, obwohl die tolle Autos bauen.
In der Sammelthread Übersicht verlinkt und ins Unterforum verschoben :wink:
Danke für die Infos -ich werde mich wohl zwischen dem Unify und dem Gigabyte Elite entscheiden.
Das MSI ist vom Gefühl und das Gigabyte von der Vernunft die Wahl... -schwierig.
Zum Glück ist gerade das Auto in der Werkstatt und knabbert am Budget -habe jetzt noch ein paar Wochen länger Zeit zum Aussuchen...
Ich hatte vorher das Elite und muss sagen Preis/Leistungstechnisch ist das Board im X570 Bereich meiner Meinung nach ungeschlagen.
Sowohl was die Ausstattung, als auch das Design und Leistung angeht. Gigabyte hat auch sehr schnell neue Biosversionen nachgeschoben, wenn entsprechende Probleme bekannt wurden.
Schau am besten mal hier.
Und warum hast du gewechselt?
ich bin grad auf der suche nach ner M.2 - meine erste.
in welchem slot wäre die am besten untergebracht?
oder ist das vollkommen egal da in allen drei slot die gleiche anbindung?
@xYeti Danke für die Frage. Ich schließe mich derer an, nur möchte ich alle drei Slots belegen und völlig auf Sata verzichten. So weit ich weiß(man korrigiere mich), läuft Slot 1 über die CPU und die anderen Beiden über den Chipsatz. Laut Beschreibung von MSI sind alle drei mit vollen Lanes angebunden.
Ist egal wo man die Einsteckt da es keinen Auswirkung hat auf andere Anschlüsse.
@Scoty
Sind auf dem Unify schon Wärmeleitpads vorgesehen, um den Boardeigenen M.2 Kühler nutzen zu können oder muss man die zukaufen?
Sind natürlich dabei.
@xYeti
Vor lauter "lass mich auch rein" überlesen☺
Und wie löst ihr das mit dem PS/2 Anschluß, der laut MSI für die Tastatur vorgesehen ist? Ich möchte eine USB Tastatur anschließen, muss aber vermutlich Anfangs das Bios flashen, da das nicht auf Stand sein wird. Wo schließt ihr dann eure Peripherie an. Bei mir kommt eine Maus, eine Tastatur und ein Hub ran. Der Hub ist USB 3.0, die Maus und die Tastatur 2.0. Die Maus bräuchte ich ja im UEFI Bios, auch wenn es dort auch nur mit Tastatur geht, aber halt etwas umständlicher.
Nutze deine Tastatur und Mouse wie immer. Einfach hinten anstecken. Verstehe denn Sinn der Frage nicht wirklich. Wegen Bios lade das neuste runter und so fern nicht drauf kannst du es flashen.
hab ich dir schon beantwortet. das bios muss gar ni geflasht werden , es läuft auch so alles. hab hinten 3 usb teile stecken - läuft - auch im bios.
Ähnliche Themen
