[Sammelthread] MSI MEG X570(S) Unify (X MAX) / ACE (MAX) (AM4)
product_10_20191002132606_5d9434ee62129.pngproduct_9_20190723092258_5d3661724d540.pngproduct_1629079667f4b88b2d70e858818adcfd4767cd52a2.pngproduct_1629094385a72f0a5d4a37c30deff6b3dcba91659c.png
Sammelthread für das MSI MEG x570 Unify/ACE
Herstellerseite:
MEG X570 UNIFY
Herstellerseite: MEG X570 ACE
Herstellerseite: MEG X570S ACE MAX
Herstellerseite: MEG X570S UNIFY-X MAX
Reviews:
MSI MEG X570 UNIFY Review - Introduction
MSI MEG X570 Unify motherboard (updated)
MSI MEG X570 Unify: An All-Black Motherboard
MSI MEG X570 Unify kommt ohne RGB aus
MSI MEG X570 Unify | Tom's Hardware
MSI MEG X570 ACE Infinity | Hardwareluxx
MSI MEG X570 Ace Motherboard Review
MSI MEG X570 Ace - Review 2019 - PCMag UK
MSI MEG X570 ACE - Hardware Journal
MSI MEG X570 ACE - Review
MSI MEG X570S ACE MAX - digideutsche
MSI MEG X570S ACE MAX - wccftech
MSI MEG X570S ACE MAX - IT Info
MSI MEG X570S UNIFY-X MAX - geeknetic
Besonderheiten:
  • Supports 2nd and 3rd Gen AMD Ryzen™ / Ryzen™ with Radeon™ Vega Graphics and 2nd Gen AMD Ryzen™ with Radeon™ Graphics Desktop Processors for AM4 socket
  • Supports DDR4 Memory, up to 5000+(OC) MHz
  • Aluminum Cover with Extended Heatsink: All-metal extended heatsink cover enlarge the surface of heat dissipation, ensures even high-end processors to run in full speed.
  • Lightning Fast Game Experience: PCIe 4.0, Triple Lightning Gen4 x4 M.2 with M.2 Shield Frozr, StoreMI, AMD Turbo USB 3.2 Gen2.
  • 2.5G Gaming LAN with Latest Wi-Fi 6 Solution: Onboard 2.5G LAN with gaming LAN manager, combining latest Wi-Fi 6 solution which supports MU-MIMO and BSS color technology, delivering the best online gaming experience.
  • Frozr Heatsink Design: Designed with the patented fan and double ball bearings to provide the best performance for enthusiast gamers and prosumers.
  • Audio Boost HD: Isolated audio with dedicated processor combining ESS audio DAC with amplifier, deliver the breathtaking, game-changing sound to create the most exciting gameplay.
  • Pre-installed I/O Shielding: Better EMI protection and more convenience for installation
  • ACE: Mystic Light Infinity, Dual LAN, Extended Heat-pipe Design
Spezifikationen Unify/ACE/ACE MAX/Unify X:
SOCKET:
AM4
CPU (MAX SUPPORT): Ryzen 9
CHIPSET:
AMD® X570 Chipset
DDR4 MEMORY: 1866/ 2133/ 2400/ 2667/ 2800/2933 /3000 /3066 /3200 /3466 /3600 /3733 /3866 /4000 /4133 /4266 /4400 /4533 /4600 /4733 /4800 /5000+ Mhz by JEDEC and A-XMP OC MODE
MEMORY CHANNEL: Dual
DIMM SLOTS: 2/4
MAX MEMORY (GB): 128GB
PCI-E X16: 3
PCI-E X1: 2
SATAIII: 4
M.2 SLOT: 3/4/6
RAID: 0/1/10
TPM (HEADER): 1
LAN UNIFY/UNIFY X: 1x Realtek® RTL8125 2.5 Gbps
LAN ACE/ACE MAX: 1x Intel® WGI211AT Gigabit / Intel® Wi-Fi 6E AX210, 1x Realtek® RTL8125 2.5 Gbps
USB 3.2 PORTS (FRONT): 1(Gen2, Type C), 4(Gen1, Type A)
USB 3.2 PORTS (REAR): 1(Gen2, Type C), 3(Gen2, Type A), 2(Gen1, Type A)
USB 2.0 PORTS (FRONT): 4
USB 2.0 PORTS (REAR): 2
AUDIO PORTS (REAR): 5+ Optical S/PDIF (Realtek® ALC1220 Codec)
DIRECTX: 12
FORM FACTOR: ATX
SLI: Y
CROSSFIRE: Y
OPERATING SYSTEM: Support for Windows® 10 64-bit
MSI Support bei hwluxx.
Hier ein paar Bilder zu denn Boards:
Eigentlich habe ich so eingestellt wie du von daher sollte die Vcore gleich sein. Kannst du mal bitte Screenshots machen von denn Settings aus dem Bios. Vielleicht habe ich was übersehen.
Habe denn Fehler wahrscheinlich gefunden. Habe denn SOC nicht angepasst gehabt wobei der eigentlich nur für denn Ram Relevant ist oder? Hast du sonst keine Gehäuselüfter weil alle anderen auf 0 sind? Nutzt du beide Lüfter auf deinen Noctua oder nur einen wie ich es habe weil denn 2. müsste ich wegen dem Ram höher machen was dann nicht mehr so toll ist. Habe mir dafür einen 120mm Noctua bestellt der heute kommt. Deine Lüfterkurve war ähnlich wie meine. Ich habe aber bis 60 Grad die 40% gehabt weil die CPU doch immer wieder selbst im Chrome schon mal bis 58 hoch geht, mit deiner Kurve würde er da schon lauter werden. Denn. 3 Punkt habe ich ab 75 Grad mit 55% angegeben.
nicht ans mainboard angeschlossen - externe Lüftersteuerung. Ja beide Lüfter beim Noctua installiert - haben ja den gleichen Ram Speicher - bei mir geht sich das gut aus, die sind ja nicht so hoch.
bzgl. SOC - bin auch kein Experte, habe das aber überall in Zusammenhang mit dem Ram OC gelesen, wobei bei mir zwischen auto und fix auf 1.1 V kein nennenswerter Unterschied ist - wollte es nur fix gesetzt haben.
Habe oben nochmals editiert wegen der Lüfterkurve. Ja beim RAM OC macht der soc sinn. Dann kann es daran nicht liegen das ich einen höheren verbrauch habe und nicht alle 24 Kerne auf 100% sind. Vielleicht habe ich bei der CPU Lotterie einen schlechteren erwischt.
Kommt ihr mit dem BIOS klar?
Es sieht halt aus wie ne Website aus den 90ern, aber ja man kommt damit klar :d
Ich wünschte mir MSI würden ihr GSE-Lite Bios als entweder oder Option anbieten.
Da kommt so viel neues im Vergleich zum alten Brett von Intel.
Wo finde ich die Einstellungen für den kleinen Lüfter vom MB.
Ich finde das MSI Bios nicht gut. Das die das nicht mal endlich ändern verstehe ich nicht.Selbst Gigabyte hat es inzwischen geschafft ein komplett neues Bios zu bringen und die neue Oberfläche ist echt mega geworden. So was bei MSI und ich wäre mir dem Board viel glücklicher. Vor allem die Lüftersteuerung bringt einen zum verzweifeln, das ist die schlechteste von allen Herstellern und das mit großen Abstand.
Ja die Oberfläche des UEFI ist zum davonlaufen, ansonsten ist das Board ziemlich gut, bin positiv überrascht.
Ja für denn Preis ist das Board ok, vor allem besser als das teuere ACE was die vrm angeht. Bios Update mäßig ist ja seit November nix mehr gekommen. Dabei gibt es doch paar Sachen die einen FIX tringend notwendig machen würden wie die lahme SSD Schreibgeschwindigkeit die bei MSI bekannt ist schon länger aber es kommt halt kein neues.
Auf die Kuehlung bezogen, VRMs sind identisch. Beim Ace ist nen viel kleinerer Heatsink verbaut+Plastikspoiler drueber.
Das ist mir bewusst, aber er schrieb "was die vrm angeht". Darum auch meine kritische Nachfrage. ;)
Dem Kühler würde ich bei den dicken VRMs übrigens nicht zu viel Bedeutung zuweisen, auch nicht trotz der minimal schlechteren Werte beim GN Test. Selbst da waren die Unterschiede gering und ich hab mit 3900X und Wasserkühlung auch noch nie mehr als gute 60 (63?) °C auf den VRMs gesehen. Zudem wegen dem "kleineren Heatsink": Nicht die Heatpipe vergessen, die wiederum dem Unify unter anderem fehlt.
Und ein C7H ist direkt mal 10°C besser, das schlägt also beide Boards. Wir sind hier aber in Bereichen wo es sowas von egal ist, weil sowieso bei allen überdimensioniert.
Ja, aber lieber so als 100C VRMs, war bei mir zb au einer der Gruende das Ultra dem Pro vorzuziehen(Gigabyte), weil richtiger Finstack anstatt Aluklotz :d
Das C7H soll besser sein? Mutige Aussage.
Kein Mut nötig sondern eigene Erfahrung. Ich plapper schließlich nicht wenn ich mich nicht auskenne...
für alle die mehr vom bios sehen wollen.
das ist mit abstand das umfangreichste was ich bisher gesehen habe.
es gibt sogar zwei wegen zum OC - :unsure:😅
Ich habe heute ein neues Beta Bios von MSI bekommen. Die hat die Version 7C35_a34. Changelog habe ich keinen mit bekommen. Ich stelle das neue Bios hier mal bereit. Jeder des es testet macht das auf eigene Verantwortung und MUSS wissen was er tut sollte was nicht gehen. Dank USB Flashback ist die Gefahr aber bei gleich null. Will es dennoch erwähnt haben.
Hier der Link:
https://www.file-upload.net/download-13857809/7C35_a34.zip.html
Hast du schon Erkenntnisse zu den Beta EFI Builds gewinnen können?
Läuft bisher gut und ich meine der Sata Speed wurde etwas besser.
weil ja viele darüber reden das der soundchip so schlecht sein soll.
ich hab grad mal meine musikplatte am rechner hänger - bin positiv überrascht- mein z97 brett hatte schon nen echt guten chip drauf aber der hier ist nochmal ne nummer besser.
lauter, klarer, mehr bums dahinter.
Es gibt neue Treiber auf der MSI Unify Seite.
Kann eigentlich jemand was zur Verfügbarkeit des Boards sagen? Es ist momentan nirgends verfügbar und etwas vergleichbares zum MSI Unify gibt es aktuell auch nicht.
bei MF wars bis zu letzt so das es am 20.1. wieder lieferbar sein soll. das die das aktuell nicht auf der HP haben heißt nix. musst du einfach mal die tage beobachten....
alternative wäre: Gigabyte X570-AORUS-ULTRA
@Scoty ich hab das RAM(F4-3600C16D-32GTZNC) heute Nacht aufm Ace (aktuellste stable Bios)verbaut, XMP, Trc58, Trfc631 Rest auto. Passmark Memtest/Aida64 stable.
Das Gigabyte X570-AORUS-ULTRA hat nicht so eine gute VRM Kühlung wie das Unify.
@oNyX` also bei mir will tRC58 nicht, nutze aber ein sehr neues Beta Bios. Werde mal die letzte Stabel damit nochmals testen wenn ich Zeit habe. Sonst ob tRC 58 oder 85 ist eigentlich eh egal da keine Auswirkung auf denn Speed.
Ähnliche Themen
