[Sammelthread] MrH OpenCL Benchmark 2.0d (64BIT/ARM64)
misterh
Berlin
Hi alle
möchte Euch mein/unser neuer OpenCL-Benchmark vorstellen.
Ihr habt viel Auswahl, das auf Eure CPU/GPU/ACC mit verschiedene Einstellungen, durchlaufen lassen könnt.
Hab die ältere Versionen davor bisher nur in 3Dcenter gepostet daher hab ich nur das neueste Version Changelog.
DOWNLOAD
MrH OPENCL Benchmark 2.0d 64BIT
- MrH OPENCL Benchmark 2.0d ARM64
AMD/NVIDIA/INTEL : MrH OpenCL Benchmark Rangliste
Changelog
1.0.030
- Added Modus - Benchmark/Statistic (Only unlocks when CPU and GPU devices are available.)
- Added Minimum and Ultra in Benchmark
- Added Accelerator Support
- some fixed
1.0.032
- some fixed in Statistic
1.0.034/035
- again some fixed in Statistic (now run better on some System with Intel CPU/Nvidia GPU and some AMDs)
1.0.040
- added "Total as %" in Benchmark (only visible if both devices have a result and Time is 10sec)
1.0.041
- changed CPU-THREADS CONTROL
1.1
- result calculations changed.
- the measurements should be more precise / more fluid.
- min and max TPS added.
- "Total as %" in Benchmark changed from 10s to 15s.
1.1.034
- Time changed to only 15s
- added unlimited test in Benchmark
- The highest approved details are selected.
- some fixed
1.1.035/061
- Statistic removed
- some fixed
1.1.065
- max TPS removed
- Priority Select removed (now always "Normal")
- added GPU Details
- Each test adjusted individual score. (Total Score and % are unchanged)
1.1.085/086
- Texture Test resolution reduced. Data type UINT8 changed to UINT16.
- Realtime CPU LOAD added.
1.1.132
- Texture Test changed back to before. Data type UINT8
- Realtime CPU LOAD removed
- added Extreme Test
- some fixed
1.1.133
- Added Downloadlink-Button for missing CPU OpenCL Support
1.1.145 Beta
- Memory Read/Write/Copy changed to 3 in 1
- Unlimited Test with Chart now and added Warmup + 6x2Min Score.
1.1.146 Beta
- Low/Medium Details removed.
- added control for Extreme
- some fixed
1.1.147 Beta
- some fixed in Unlimited Test
1.1.152 Beta
- added Skala in Unlimited Test
1.1.2/1.1.21
- added Time Modus (Time : X SEC)
- changed Design in Benchmark Modus (Time : 15 SEC)
- some fixed in Unlimited Test (Time : ∞ SEC)
1.1.3/1.1.31
- some fixed
- some optimized
1.20/1.21
- some fixed
- added new Test (Async Compute)
- added 3 Language (English, German, Turkish) -> if want more, you can write PN.
1.22
- some fixed in Score
1.23
- some fixed in Control
1.25
- added reset in Benchmark Modus (after 1/3 and 2/3 time)
- added restart in Time Modus (after 2s)
- some fixed/optimized
- small correction in Turkish
1.26/1.27
- Time Mode: added time correction.
- some fixed.
1.30
- "Total as %" removed
- Points doubled
- AVG -> Score fixed
- some fixed for Ranking (Benchmark Modus)
1.31
- "GPU Async Compute" bug fixed. Now more performance.
1.35
- Async Compute fixed and run now better on Nvidia.
- Added new Modus "All in One Test".
1.38
- Added Control/Option to "All in One Test" Modus.
1.40
- new design
- unlimited/all-in-one modus removed
- language removed. now only english.
- Benchmark Modus 15s to 30s changed
- now only Single Test
- added Status
- result/Time now saved until you did device list, modus changed or exe closed.
1.41
- some fixed
- warmup changed (Time Modus)
1.42
- 30s Modus : single results are comparable to 1.38 Version.
1.50
- Changed 30s to 15s and added more Time Options.
- Time Modus now run with Time and will show you how long your devices need for this.
- Digit after comma 1 changed to 2 (TPS/TIME).
- Loadtime display added.
- "Warmup" removed
- Added "How to" in Info
- Added Hardware Check + On/Off
- Numbers 1 to 8 added to see the order in which to be followed.
- HDR 8192/4096/2048 changed to 4096/2048/1024 with more Performance.
- High Setting removed
- Added Start Time in Info.
- GPU : Extreme will only be activated by Hardware Check On if has 3 GB or more.
- CPU : Extreme will only be activated by Hardware Check On if has 8 Threads or more.
- Some fixed/optimized
1.51
- Added control question for BICUBIC Test.
1.52
- "MEMORY" renamed to "MEMORY R-W-C".
- Added more Memory Test (R-W, R-C, W-C, READ, WRITE, COPY).
- Added "Save as TXT"-Button.
- Added more Time Options for Score (30min + 60min) and Time (1min to 60min).
- Added Memory Info.
- some fixed/optimized.
1.53
- Score Modus removed.
- Completely changed CPU benchmark.
- CPU : Min requirement for Extreme: 8 threads reduced to 4.
- Added control for CPU OpenCL version.
- Added date/time to display in image.
- Added maximum tasks for Ultra (20K) and Extreme (10K) separately.
- PI crashed on Nvidia after Run -> fixed
- Fixed some small bugs.
1.54
- Added best time
- Added Reset button for every Test
- (CPU) Memory Test had Error. Changed and fixed. -> new Ranklist
1.55/1.56
- Optimized code -> performance on device maybe better.
- Added more screenshot save format
- Added more info if device are not found -> Download Links (CPU: OpenCL Runtime 16.1.2 and GPU: NVIDIA/AMD/INTEL Driver Websites)
- HW-Check removed
- Added color info after start device control under settings
- Added OS/Hardware Info to TXT File
1.60
- After clicking STOP, the previous result is displayed again.
- for 1.60 version Intel OpenCL Runtime 2021.2.0.616 must be installed. (16.1.2 and other versions must be uninstalled first)
for CPU
- TEXTURE
- ULTRA : 1024, 1024 -> 2048,1024
- EXTREME : 2048, 2048 -> 4096, 4096
- ASYNC COMPUTE
- ULTRA : 256, 128 -> 128, 128
- EXTREME : 256, 256 -> 256, 128
- MEMORY
- ULTRA : 1024, 1024 -> 2048, 1024
- EXTREME : 2048, 2048 -> 4096, 2048
1.70
- Added “KILL PROCESS?”
- Result changed to “Time per task”.
- Some in "Texture" have been corrected
- Time selection changed. And benchmark mode only with 30s.
for CPU
- MEMORY
- ULTRA : 2048, 1024 -> 2048, 2048
- EXTREME : 4096, 2048 -> 4096, 4096
1.80
- Start Time 10-50x faster
- Color for Setting removed
- Added Warning for Texture like Bicubic
- Added more Info VAR + MAD. Explanation under info.
- Added min + max. No more only avg.
- Admin rights removed
- Some Code optimized
- Best Time removed
- Task times has been changed from three to two decimal places.
- Added 19 Language
- Indonesian
- German
- Spanish
- Spanish LATAM
- French
- Italian
- Latin
- Dutch
- Polish
- Portuguese
- Russian
- Turkish
- Arabic
- Hindi
- Chinese simplified
- Chinese traditional
- Japanese
- Thai
- Korean
Note: I am sorry, if something is write wrong in any Language. Let me know it pls for correct.
1.81
- VAR/MAD measurement bug fixed.
- Changed back to 3 decimal places. Also for VAR/MAD.
CPU-Anforderungen: Für CPU ( ab SSE 4.2 ) muss Intel OpenCL Runtime 2021.2.0.616 (2021.11.3.0.17 160000) installiert sein. Andere Versionen werden nicht eingetragen. Wenn doppelt gelistet wird, könnt ihr CPU List Fix runterladen.
Intel dGPU (Only A-Series) : Um eingetragen zu werden, müsst ihr erst 1x HDR laufen lassen, dann X klicken und erneut laufen lassen. Danach erst die anderen 5 Tests laufen lassen.
Warnung vor BICUBIC/TEXTURE TEST: Mit euren "MPT/Powerlimit/Spannung usw."-Einstellungen bitte langsam nach oben gehen. Nicht übertreiben.
Ich übernehme keine Verantwortung, wenn durch die Verwendung des MPT usw. etwas schief geht.
Falls das Programm nicht startet, überprüfe, ob Visual C++ 2015-2022 ( x86 + x64 ) installiert ist, und installiere sie gegebenenfalls.
Falls es trotzdem nicht öffnet, liegt es sehr wahrscheinlich an der Intel‑iGPU. In dem Fall im BIOS oder im Geräte‑Manager deaktivieren (betrifft Systeme mit iGPU + GPU).
Würde mich auf Eure Feedback freuen. :)
Scheint mit AMD CPUs noch nicht immer ohne Fehler zu gehen?:
Zudem ist mein GPU Score insane höher kann ja auch nicht sein, oder?
@ Holzmann
Thx für mitmachen :)
1. Hast auf Low stehen. Daher sind die Werte auch höher. Einfach höhere Einstellung ausprobieren wie zb Ultra
2. Hab Startposting extra geschrieben, Intel OpenCL Runtime 16.1.2_x64 installieren. Dann ist dein CPU auch gelistet.
cpu hab ich auf max 4ghz laufen.
gpu default
@ Holzmann
lass mal nochmal durchlaufen in BenchmarkModus
@ King Bill
Sieht gut aus, checkt bitte mit eben freigegebene 035er, ob nun CPU Score angezeigt wird. Passiert irgendwie wenn während Benchmark ab und an laggen tut.
OK jetzt ging es :)
Edit:
Finde den benchmark ganz schön, würde mir aber noch einen Gesamtscore zum kompetitiven Vergleich wünschen. :)
App Entwickler misterh hat in der neusten Version, ist oben im Startpost verlinkt einen Gesamtscore eingeführt mit einer Gewichtung 65% CPU und 35% GPU.
Ich komme hier auf 147,1%
Hier mit höchster Einstellung, sprich Ultra Details:
Vielen Dank für die Erweiterung, hoffe es machen noch einige mehr mit. :)
Hier mein Score
Hier von mir auch noch mal einen run mit neuster Version:
kostenlos handy bilder hochladen
Läuft bei mir fehlerfrei und brennt richtig gut bzw. treibt die Hardware an die Grenzen! :)
Hier mit 4.3GHZ all core, mehr ist mit meinem 3900x nicht drin, wird sonst zu heiß:
3900X@Stock
X570 Taichi @ Bios 2.10
4x8GB DDR3200@3800CL14-15-14-28-1T+Angepasste Subtimings
RTX2080Ti@2025/8200
So läuft mein System immer und ist nicht irgendwie gepusht für den Benchmark
@Power
Vernichtend :eek:
Zu meinem Leitungsproblem gesellt sich jetzt auch noch ein Hitzeproblem :fire:
Warum vernichtend?
achso naja hier hat doch kaum jemand mitgemacht.
Update
Jetzt mit Ranking im Startpost :teufel:
Die meisten Punkte macht er aber mit der Grafikkarte und diese wird nicht Stock laufen! ;)
Die derzeitige Gewichtung 65% CPU und 35% GPU, halte ich für in Ordnung, oder bist du anderer Meinung?
@misterH
Fürs Protokoll, meine VII lief mit 2100 GPU und 1200 Speicher, für die CPU gilt CL15 ;)
ich finde der test muss überarbeitet werden weil aktuell reagiert er nur auch RAM übertaktung und quasi null auf CPU takt.
Sieht man gut das Holzman @4,3ghz eigentlich überall schneller ist nur im Write und Copy liegt er zurück und hat dadurch gleich weniger Leistung?? das passt nicht!
Für einen Test der auf openCL aufsetzt finde ich auch dass die Grafikkarte eine höhere Wichtung haben sollte.
Ich sprach hier von der CPU wo ich 325Punkte habe und Holzmann 308Punkte wobei er eigentlich überall mehr punkte in den einzelnen tests hat und ich nur bei Write und Copy höhere werte habe
Man sollte Read, Wirte und Copy wohl eher aus der Wertung nehmen .
Ich weiß was du meintest, ich wollte nur sagen das zusätzlich zu deinem Einwand der CPU eine zu große Wichtung gegeben wird. OpenCL wird sehr oft, wenn nicht meistens, für GPU Beschleunigung genutzt. Sicher geht OpenCL auch super mit der CPU, aber diese bräuchte OpenCL nicht. Die GPU ist da weit effizienter und skaliert auch besser weshalb man sich auch meisten für OpenCL zum Ansprechen der GPU entscheidet.
Ich hätte das eh so gemacht das ich die Gewichtung anhand der Leistung machen würde.
erreicht die GPU 5000Punkte und die CPU 200Punkte dann sind das 5200Punkte und schon passt das
Ja, es gibt dann aber Probleme mit der Vergleichbarkeit. Wie gesagt, der GPU muss mehr an Wichtung zugesprochen kommen. So wie du das vorschlägst verliert man an Vergleichbarkeit an Gesamtleistung des System. Dann hast du mit 2x RTX2080ti und einem DualCore Prozessor weit größere Werte als ein System mit RTX2080 und 3950x. Das das System ansonsten mit DualCore quasi kaum performant nutzbar ist wird so verschleiert.
ja das mag ja sein aber muss man das so auf die art vergleichbar machen oder würde es reichen wenn man sieht was die CPU erreicht und was die GPU erreicht.
Ich brauche da keine zusammenfassung sondern einfach CPU Punkte und GPU punkte reicht doch völlig. Es geht doch hier um OpenCL und man sieht dann was da die GPU und was die CPU leisten.
Bin da eh nicht so mit dem Benchen, weil sowas mir eh nicht so wichtig ist.
Ein video Rendern, dann packen und wieder entpacken wäre für mich z.b. ein guter test.
Benchmarks sind ja eh nur eher um zu vergleichen ob das System so läuft wie es soll.
Wäre eine Gewichtung von 50:50 vielleicht besser?
zur nächsten Version nehm ich Gewichtung raus und tue jede einzel Werte von CPU/GPU/ACC zusammen und rechne so in % als Gesamtswerte um.
hier schon mal Vorschau wie aussehen könnte. Es kann sich noch das eine und andere ändern, bis ich das freigebe. Spätesten nach Neujahr.
Die Einzelnwerte und jeweils Score von CPU/GPU/ACC bleiben unverändert und vergleichbar mit ältere Versionen.
Naja aber ich verstehe nicht warum ich mit weniger mhz und weniger Punkte in den Einzelwerten dann im gesammten Ergebnis besser sein soll als Holzmann. Nur weil memory write und copy besser sind? Das macht doch überhaupt keinen Sinn.
