[Sammelthread] Asrock AB350 Gaming-ITX/ac | X370 Gaming-ITX/ac
  • Ersteller Gelöschtes Mitglied 189576
  • Erstellt am
Sammelthread Asrock AB350 Gaming-ITX/ac | X370 Gaming-ITX/ac​
die beiden Mini-ITX AM4 von Asrock
Inhaltsverzeichnis:
  • Technische Daten
  • Preisvergleich
  • Fragen / Antworten
  • RAM Kompatibilität
  • Berichte & Reviews
  • aktuelle BIOS Versionen
Technische Daten
AB350 Gaming-ITX:
Code:
[table="width: 500"]
[tr]
	[td]Gaming Armor[/td]
	[td]Power
- Hi-Density Power Connector (8 pin)
Memory
- 15μ Gold Contact in DIMM Slots
VGA Card
- 15μ Gold Contact in VGA PCIe Slot (PCIE1)
Internet
- Intel® LAN
Cooling
- 2oz Copper PCB
Audio
- Creative Sound Blaster™ Cinema 3[/td]
[/tr]
[tr]
	[td]Unique Feature[/td]
	[td]ASRock Super Alloy
- Premium Power Choke
- Dual-N MOSFET
- Nichicon 12K Black Caps (100% Japan made high quality conductive polymer capacitors)
- Matte Black PCB
- High Density Glass Fabric PCB
- 2oz Copper PCB
Intel® 802.11ac WiFi
ASRock Steel Slots
ASRock Ultra M.2 (PCIe Gen3 x4 & SATA3)
ASRock Full Spike Protection (for all USB, Audio, LAN Ports)
ASRock Live Update & APP Shop[/td]
[/tr]
[tr]
	[td]CPU[/td]
	[td]- Supports AMD Socket AM4 A-Series APUs (Bristol Ridge) and Ryzen Series CPUs (Summit Ridge)
- Digi Power design
- 8 Power Phase design
- Supports 95W Water Cooling[/td]
[/tr]
[tr]
	[td]Chipset[/td]
	[td]- AMD Promontory B350[/td]
[/tr]
[tr]
	[td]Memory[/td]
	[td]- Dual Channel DDR4 Memory Technology
- 2 x DDR4 DIMM Slots
- AMD Ryzen series CPUs support DDR4 3466+(OC) / 3200(OC) / 2933(OC) / 2667 / 2400 / 2133 ECC & non-ECC, un-buffered memory*
- AMD 7th Gen A-Series APUs support DDR4 2400/2133 ECC & non-ECC, un-buffered memory*
- Max. capacity of system memory: 32GB**
- 15μ Gold Contact in DIMM Slots[/td]
[/tr]
[tr]
	[td]BIOS[/td]
	[td]- 128Mb AMI UEFI Legal BIOS with GUI support
- Supports "Plug and Play"
- ACPI 5.1 compliance wake up events
- Supports jumperfree
- SMBIOS 2.3 support
- CPU, DRAM, PCH 1.05V, PROM 2.5V, Voltage Multi-adjustment[/td]
[/tr]
[tr]
	[td]Graphics[/td]
	[td]- Integrated AMD Radeon™ R-Series Graphics in A-series APU*
- DirectX 12, Pixel Shader 5.0
- Max. shared memory 2GB
- Supports 2 x HDMI with max. resolution up to 4K x 2K (4096x2160) @ 24Hz / (3840x2160) @ 30Hz
- Supports Auto Lip Sync, Deep Color (12bpc), xvYCC and HBR (High Bit Rate Audio) with HDMI Ports (Compliant HDMI monitor is required)
- Supports HDCP with HDMI Ports
- Supports Full HD 1080p Blu-ray (BD) playback with HDMI Ports[/td]
[/tr]
[tr]
	[td]Audio[/td]
	[td]- 7.1 CH HD Audio with Content Protection (Realtek ALC1220 Audio Codec)
- Premium Blu-ray Audio support
- Supports Surge Protection
- Nichicon Fine Gold Series Audio Caps
- 120dB SNR DAC with Differential Amplifier
- Pure Power-In
- Direct Drive Technology
- PCB Isolate Shielding
- Impedance Sensing on Line Out port
- Individual PCB Layers for R/L Audio Channel
- Gold Audio Jacks
- Supports Creative Sound Blaster™ Cinema 3[/td]
[/tr]
[tr]
	[td]LAN[/td]
	[td]- Gigabit LAN 10/100/1000 Mb/s
- GigaLAN Intel® I211AT
- Supports Wake-On-LAN
- Supports Lightning/ESD Protection
- Supports Energy Efficient Ethernet 802.3az
- Supports PXE[/td]
[/tr]
[tr]
	[td]Wireless LAN[/td]
	[td]- Intel® 802.11ac WiFi Module (Free Bundle)
- Supports IEEE 802.11a/b/g/n/ac
- Supports Dual-Band (2.4/5 GHz)
- Supports high speed wireless connections up to 433Mbps
- Supports Bluetooth 4.2 / 3.0 + High speed class II[/td]
[/tr]
[tr]
	[td]Slots[/td]
	[td]AMD Ryzen series CPUs
- 1 x PCI Express 3.0 x16 Slot (PCIE1: x16 mode)*
AMD 7th A-Series APUs
- 1 x PCI Express 3.0 x16 Slot (PCIE1: x8 mode)*
- 1 x Vertical M.2 Socket (Key E) with the bundled WiFi-802.11ac module (on the rear I/O)
*Supports NVMe SSD as boot disks[/td]
[/tr]
[tr]
	[td]Storage[/td]
	[td]- 4 x SATA3 6.0 Gb/s Connectors, support RAID (RAID 0, RAID 1 and RAID 10), NCQ, AHCI and Hot Plug
- 1 x Ultra M.2 Socket, supports M Key type 2280 M.2 SATA3 6.0 Gb/s module and M.2 PCI Express module up to Gen3 x4 (32 Gb/s) (with Ryzen Series CPU) or Gen3 x2 (16 Gb/s) (with A-Series APU)*
[/tr]
[tr]
	[td]Connector[/td]
	[td]- 1 x LPC Header
- 1 x AMD Fan LED Header
- 1 x CPU Fan Connector (4-pin)*
- 1 x Chassis Fan Connector (4-pin)
- 1 x Chassis Optional/Water Pump Fan Connector (4-pin) (Smart Fan Speed Control)*
- 1 x 24 pin ATX Power Connector
- 1 x 8 pin 12V Power Connector (Hi-Density Power Connector)
- 1 x Front Panel Audio Connector
- 1 x AMD LED Fan USB Header
- 1 x USB 2.0 Header (Supports 2 USB 2.0 ports) (Supports ESD Protection)
- 1 x USB 3.0 Header (Supports 2 USB 3.0 ports) (Supports ESD Protection)
*The CPU Fan Connector supports the CPU fan of maximum 1A (12W) fan power.
**The Chassis Optional/Water Pump Fan supports the water cooler fan of maximum 1.5A (18W) fan power.
CHA_FAN1/W_PUMP can auto detect if 3-pin or 4-pin fan is in use.[/td]
[/tr]
[tr]
	[td]Rear Panel I/O[/td]
	[td]- 2 x Antenna Ports
- 1 x PS/2 Mouse/Keyboard Port
- 2 x HDMI Ports
- 1 x Optical SPDIF Out Port
- 2 x USB 2.0 Ports (Supports ESD Protection)*
- 1 x USB 3.0 Type-A Port (Supports ESD Protection)
- 1 x USB 3.0 Type-C Port (Supports ESD Protection)
- 2 x USB 3.0 Ports (Supports ESD Protection)
- 1 x RJ-45 LAN Port with LED (ACT/LINK LED and SPEED LED)
- HD Audio Jacks: Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone (Gold Audio Jacks)[/td]
[/tr]
[tr]
	[td]Software and UEFI[/td]
	[td]Software
- ASRock F-Stream
- ASRock RGB LED
- ASRock Key Master
- ASRock APP Charger
- ASRock XFast LAN*
UEFI
- ASRock Full HD UEFI
- ASRock Instant Flash
- ASRock Internet Flash
- ASRock Crashless BIOS
- ASRock Easy RAID Installer[/td]
[/tr]
[tr]
	[td]Support CD[/td]
	[td]- Drivers, Utilities, AntiVirus Software (Trial Version), Google Chrome Browser and Toolbar[/td]
[/tr]
[tr]
	[td]Accessories[/td]
	[td]- Quick Installation Guide, Support CD, I/O Shield
- 2 x SATA Data Cables
- 2 x ASRock WiFi 2.4/5 GHz Antennas
- 1 x Screw for M.2 Socket[/td]
[/tr]
[tr]
	[td]Hardware Monitor[/td]
	[td]- Temperature Sensing: CPU, Chassis, Chassis Optional/Water Pump Fans
- Fan Tachometer: CPU, Chassis, Chassis Optional/Water Pump Fans
- Quiet Fan (Auto adjust chassis fan speed by CPU temperature): CPU, Chassis, Chassis Optional/Water Pump Fans
- Fan Multi-Speed Control: CPU, Chassis, Chassis Optional/Water Pump Fans
- Voltage monitoring: +12V, +5V, +3.3V, CPU Vcore[/td]
[/tr]
[tr]
	[td]Form Factor[/td]
	[td]- Mini-ITX Form Factor: 6.7-in x 6.7-in, 17.0 cm x 17.0 cm
- 2oz Copper PCB[/td]
[/tr]
[tr]
	[td]OS[/td]
	[td]- Microsoft® Windows® 10 64-bit
* For the updated Windows® 10 driver, please visit ASRock's website for details: http://www.asrock.com
[/td]
[/tr]
[tr]
	[td]Certifications[/td]
	[td]- FCC, CE
- ErP/EuP ready (ErP/EuP ready power supply is required)[/td]
[/tr]
[/table]
X370 Gaming-ITX
Code:
[tr]
	[td]Power
Memory
VGA Card
Internet
- Intel® LAN
Cooling
- 2oz Copper PCB
Audio
[/tr]
[tr]
- Dual-N MOSFET
- Matte Black PCB
- 2oz Copper PCB
ASRock Steel Slots
[/tr]
[tr]
	[td]CPU[/td]
- Digi Power design
[/tr]
[tr]
	[td]Chipset[/td]
	[td]- AMD Promontory X370[/td]
[/tr]
[tr]
	[td]Memory[/td]
- AMD 7th Gen A-Series APUs support DDR4 2400/2133 ECC & non-ECC, un-buffered memory**
[/tr]
[tr]
	[td]BIOS[/td]
[/tr]
[tr]
	[td]Graphics[/td]
[/tr]
[tr]
	[td]Audio[/td]
- Pure Power-In
- Gold Audio Jacks
[/tr]
[tr]
	[td]LAN[/td]
- Supports PXE[/td]
[/tr]
[tr]
- Supports high speed wireless connections up to 867Mbps
- 2 antennas to support 2 (Transmit) x 2 (Receive) diversity technology
[/tr]
[tr]
	[td]Slots[/td]
[/tr]
[tr]
	[td]Storage[/td]
[/tr]
[tr]
	[td]Connector[/td]
- 1 x Chassis Optional/Water Pump Fan Connector (4-pin) (Smart Fan Speed Control)**
[/tr]
[tr]
- 2 x HDMI Ports
[/tr]
[tr]
	[td]Software
- ASRock F-Stream
- ASRock RGB LED
- ASRock Key Master
- ASRock XFast LAN*
UEFI
[/tr]
[tr]
	[td]Support CD[/td]
[/tr]
[tr]
- 1 x ASRock WiFi 2.4/5 GHz Antenna
[/tr]
[tr]
[/tr]
[tr]
[/tr]
[tr]
	[td]OS[/td]
[/td]
[/tr]
[tr]
	[td]- FCC, CE
[/tr]
[/table]
Preisvergleich
AB350 Gaming-ITX/ac: ASRock Fatal1ty AB350 Gaming-ITX/ac Preisvergleich geizhals.eu EU
X370 Gaming-ITX/ac: ASRock Fatal1ty X370 Gaming-ITX/ac Preisvergleich geizhals.eu EU
Fragen und Antworten:
  • Was ist der Unterschied zwischen dem AB350 und X370?
    Da ein ITX Board nicht die kompletten Vorteile von X370 nützen kann, unterscheiden sich die beiden nur gering. Das X370 hat schnelleres WLAN und erlaubt PCIe Bifurcation
    edit 17.8.2017: Die beiden haben nun doch andere VRM Komponenten, wie br0da herausgefunden hat:
    FDPC5030 = AB350; SM7341EH = X370
    ASRocks X370 und B350 mini-ITX unterscheidet doch mehr, als der Kühlkörper (anfangs): VRM on the new AM4 motherboards - Page 251
    Die FETs im Vergleich:
    RDS(on) max​
    Rise + Fall Time
    FDPC5030Q1:
    5.0 mOhm @ VGS = 10 V @ ID = 17A
    6.5 mOhm @ VGS = 4.5V @ ID = 14 A
    Q2:
    2.4 mOhm @ VGS = 10V @ ID = 25 A
    3.0 mOhm @ VGS = 4.5V @ ID = 22 A
    Q1: 20ns
    Q2: 20ns
    SM7341EHQ1:
    3.9mOhm @ VGS = 10V @ ID = 24A
    6.5mOhm @ VGS = 4.5V @ ID = 24A
    Q2:
    1.2mOhm @ VGS =10V @ ID = 24A
    2mOhm @ VGS =4.5V @ ID = 24A
    Q1: 18.6ns
    Q2: 39ns
  • Wie unterschieden sich die VRM Kühler?
    alt: https://abload.de/img/img_15572ssdc.jpg
    neu: https://abload.de/img/fullsizerenderfaujg.jpg
  • Ich habe noch den alten VRM-Kühler, was kann ich tun?
    Schreibt den Asrock Support an! Der Support will danach noch eine Rechnung und die Seriennummer vom Board.
    ASRock > Support Request Form
  • Welchen RAM habt ihr getestet?
    Dazu habe ich ein 16GB Trident Z 3200MHz CL14 Kit. F4-3200C14D-16GTZ
    Mit den XMP Profil konnte ich den Ram nicht starten. Wenn ich jedoch die Spannung auf 1.4V erhöhe, die command rate auf 1T setze, Geardown Mode und BankGroupSwap deaktiviere, dann läuft er und es gab nach 2 Stunden Memtest64 keine Fehler.
    Als RAM habe ich Kingston KVR21E15D8K2/16I
    Corsair CMK16GX4M2A2400C14 funktioniert ebenfalls einwandfrei, ist direkt mit 2400Mhz gestartet.
    Aber ne kleine Info, ich habe diesen RAM hier beim Kollegen auf einen AB350 am Laufen:
    GWW416GB3000C15DC
    Dieser hat Samsung D-Die und ist Dualranked. Er läuft auf 3000Mhz mit 15-17-17-35 bei 1,35v, das läuft tadellos. Haben gestern was probiert und sind am Ende bei 1,35v auf 3200mhz bei 17-19-19-38 gekommen. Dualranked sollte er so schnell sein wie 3400-3500er Singlerank.
RAM Kompatibilität
Asrock gibt folgenden Arbeitsspeicher auf der Homepage an (Update 7.10.2017; 27 neue Einträge):
Code:
DDR4	3000	4GB	ADATA	KM4B4GX2A-3000-15-16-16-36-0			SS		2pcs	v
DDR4	2800	16GB	ADATA	AX4U2800316G16			SS		2pcs
DDR4	2400	8GB	ADATA	AX4U2400W8G16-SRD			DS		2pcs
DDR4	2400	8GB	ADATA	AX4U2400W8G16-QRD			DS		2pcs
DDR4	2400	8GB	ADATA	AX4U2400316G16-BBF			DS		2pcs
DDR4	2400	8GB	ADATA	AX4U2400W8G16-BRD			DS		2pcs
DDR4	2400	8GB	ADATA	AX4U2400W8G16-QWZ			DS		2pcs
DDR4	2400	8GB	ADATA	AX4U2400W8G16-QRZ			DS		2pcs
DDR4	2400	8GB	ADATA	AX4U2400W8G16-DWZ			DS		2pcs
DDR4	2400	8GB	ADATA	AX4U2400W8G16-BRZ			DS		2pcs
DDR4	2400	8GB	ADATA	AX4U2400W8G16-BBZ			DS		2pcs
DDR4	2400	8GB	ADATA	AX4U2400W8G16-BWZ			DS		2pcs
DDR4	2400	8GB	ADATA	AX4U2400W8G16-DRD			SS		2pcs
DDR4	2400	8GB	ADATA	AX4U2400W8G16-DRZ			DS		2pcs
DDR4	2400	4GB	ADATA	AX4U2400W4G16-DRZ			SS		2pcs
DDR4	2400	4GB	ADATA	AX4U2400W4G16-SBF			SS		2pcs
DDR4	2400	4GB	ADATA	AX4U2400W4G16-BBF			SS		2pcs
DDR4	2400	4GB	ADATA	AX4U2400W4G16-BWZ			SS		2pcs
DDR4	2400	4GB	ADATA	AX4U2400W4G16-QWZ			SS		2pcs
DDR4	2400	4GB	ADATA	AX4U2400W4G16-BBZ			SS		2pcs
DDR4	2400	4GB	ADATA	AX4U2400W4G16-BRZ			SS		2pcs
DDR4	2400	4GB	ADATA	AX4U2400W4G16-DWZ			SS		2pcs
DDR4	2400	4GB	ADATA	AX4U2400W4G16-SWZ			SS		2pcs
DDR4	2400	4GB	ADATA	AX4U2400W4G16-QRZ			SS		2pcs
DDR4	2400	4GB	ADATA	AX4U2400W4G16-SRZ			SS		2pcs
DDR4	2400	16GB	ADATA	AX4U2400316G16-QRZ			DS		2pcs
DDR4	2400	16GB	ADATA	AX4U2400316G16-QWZ			DS		2pcs
DDR4	2400	16GB	ADATA	AX4U2400316G16-SRZ			DS		2pcs
DDR4	2400	16GB	ADATA	AX4U2400316G16-BRZ	ADATA		DS		2pcs
DDR4	2400	16GB	ADATA	AX4U2400316G16-DWZ			DS		2pcs
DDR4	2400	16GB	ADATA	AX4U2400316G16-SBF			DS		2pcs
DDR4	2400	16GB	ADATA	AX4U2400316G16-SWZ			DS		2pcs
DDR4	2400	16GB	ADATA	AX4U2400316G16-QRD			DS		2pcs
DDR4	2400	16GB	ADATA	AX4U2400316G16-DRD			DS		2pcs
DDR4	2400	16GB	ADATA	AX4U2400316G16-SRD			DS		2pcs
DDR4	2400	16GB	ADATA	AX4U2400316G16-BWZ			SS		2pcs
DDR4	2400	16GB	ADATA	AX4U2400316G16-BRD			SS		2pcs
DDR4	2400	16GB	ADATA	AX4U2400316G16-DRZ			DS		2pcs
DDR4	2133	8GB	ADATA	AD4E2133W8G15-BHYA (ECC)			SS		2pcs
DDR4	2400	8GB	Apacer	AU08GGB24CEYBGC			SS		2pcs
DDR4	2133	8GB	Apacer	78.C1GM3.AF10B	Hynix		DS		2pcs
DDR4	3000	8GB	Avexir	AVD4UZ130001608G-4BZ1RR			SS		2pcs	v
DDR4	2400	8GB	Avexir	AVD4UZ124001608G-1COR			SS		2pcs
DDR4	2400	4GB	Avexir	AVD4UZ124001604G-1COB			SS		2pcs
DDR4	3000	8GB	Corsair	CMD32GX4M4B3000C15 (Hynix-M)			SS		2pcs	v
DDR4	2800	8GB	Corsair	CMK32GX4M4A2800C16			DS		2pcs
DDR4	2800	8GB	Corsair	CMD32GX4M4A2800C16			DS		2pcs
DDR4	2800	4GB	Corsair	CMD16GX4M4A2800C16			SS		2pcs
DDR4	2666	8GB	Corsair	CMD32GX4M4A2666C15 ver4.23			DS		2pcs
DDR4	2666	8GB	Corsair	CMD32GX4M4A2666C16			DS		2pcs
DDR4	2666	8GB	Corsair	CMK32GX4M4A2666C16			DS		2pcs
DDR4	2666	8GB	Corsair	CMK32GX4M4A2666C16 ver 5.30			SS		2pcs
DDR4	2666	4GB	Corsair	CMD16GX4M4A2666C15			SS		2pcs
DDR4	2666	4GB	Corsair	CMK16GX4M4A2666C16			SS		2pcs
DDR4	2666	4GB	Corsair	CMD16GX4M4A2666C16			SS		2pcs
DDR4	2400	8GB	Corsair	CMK32GX4M2A2400C14			SS		2pcs
DDR4	2133	4GB	Corsair	CMV4GX4M1A2133C15			SS		2pcs
DDR4	2666	8GB	Crucial	BLT8G4D26AFTA.16FAD			SS		2pcs
DDR4	2666	4GB	Crucial	BLE4G4D26AFEA.8FAD			SS		2pcs
DDR4	2400	8GB	Crucial	CT8G4WFD824A.18FB1 (ECC)			SS		2pcs
DDR4	2133	8GB	Crucial	CT8G4DFS8213.8FB1			SS		2pcs
DDR4	2133	8GB	Crucial	CT8G4DFD8213.16FA2			SS		2pcs
DDR4	2133	8GB	Crucial	CT8G4DFD8213.C16FAD11			SS		2pcs
DDR4	2133	4GB	Crucial	CT4G4DFS8213.8FA1			SS		2pcs
DDR4	2133	16GB	Crucial	CT16G4DFD8213.16FB1			SS		2pcs
DDR4	3066	8GB	G.Skill	F4-4133C19D-16GTZKWC			SS		2pcs	v
DDR4	3066	8GB	G.Skill	F4-4000C18D-16GTZR			SS		2pcs	v
DDR4	3000	4GB	G.Skill	F4-3000C15Q-16GRR			SS		2pcs	v
DDR4	2933	8GB	G.Skill	F4-3200C16D-16GTZB			SS		2pcs	v
DDR4	2933	8GB	G.Skill	F4-4266C19D-16GTZR			SS		2pcs	v
DDR4	2933	8GB	G.Skill	F4-3466C16D-16GTZSK			SS		2pcs	v
DDR4	2933	16GB	G.Skill	F4-3333C16D-32GTZSK			DS		2pcs	v
DDR4	2933	16GB	G.Skill	F4-3200C14D-32GTZR			DS		2pcs	v
DDR4	2933	16GB	G.Skill	F4-3866C18D-32GTZR			DS		2pcs	v
DDR4	2933	16GB	G.Skill	F4-3200C15D-32GTZR			DS		2pcs	v
DDR4	2400	8GB	G.Skill	F4-2400C16D-16GFXR			SS		2pcs
DDR4	2400	8GB	G.Skill	F4-2400C15D-16GFX			SS		2pcs
DDR4	2400	8GB	G.Skill	F4-2400C15D-16GFXR			SS		2pcs
DDR4	2400	8GB	G.Skill	F4-2400C15D-16GFT			SS		2pcs
DDR4	2400	8GB	G.Skill	F4-2400C16D-16GFX			SS		2pcs
DDR4	2400	8GB	G.Skill	F4-2400C15D-16GBTZR			SS		2pcs
DDR4	2400	8GB	G.Skill	F4-2400C16D-16GFT			SS		2pcs
DDR4	2400	4GB	G.Skill	F4-2400C15D-8GFT			SS		2pcs
DDR4	2400	4GB	G.Skill	F4-2400C16D-8GFT			SS		2pcs
DDR4	2400	4GB	G.Skill	F4-2400C16D-8GFXR			SS		2pcs
DDR4	2400	4GB	G.Skill	F4-2400C16D-8GFX			SS		2pcs
DDR4	2400	4GB	G.Skill	F4-2400C15D-8GFXR			SS		2pcs
DDR4	2400	4GB	G.Skill	F4-2400C15D-8GFX			SS		2pcs
DDR4	2400	16GB	G.Skill	F4-2400C16D-32GFXR			DS		2pcs
DDR4	2400	16GB	G.Skill	F4-2400C16D-32GFT			DS		2pcs
DDR4	2400	16GB	G.Skill	F4-2400C15D-32GFX			DS		2pcs
DDR4	2400	16GB	G.Skill	F4-2400C15D-32GFXR			DS		2pcs
DDR4	2400	16GB	G.Skill	F4-2400C16D-32GFX			DS		2pcs
DDR4	2400	16GB	G.Skill	F4-2400C15D-32GFT			DS		2pcs
DDR4	2133	8GB	G.Skill	F4-2133C15D-16GFT			SS		2pcs
DDR4	2133	8GB	G.Skill	F4-2133C15D-16GFXR			SS		2pcs
DDR4	2133	8GB	G.Skill	F4-2133C15D-16GFX			SS		2pcs
DDR4	2133	4GB	G.Skill	F4-2133C15D-8GFX			SS		2pcs
DDR4	2133	4GB	G.Skill	F4-2133C15D-8GFXR			SS		2pcs
DDR4	2133	4GB	G.Skill	F4-2133C15D-8GFT			SS		2pcs
DDR4	2133	16GB	G.Skill	F4-2133C15D-32GFX			DS		2pcs
DDR4	2133	16GB	G.Skill	F4-2133C15D-32GFT			DS		2pcs
DDR4	2133	16GB	G.Skill	F4-2133C15D-32GFXR			DS		2pcs
DDR4	2400	4GB	Geil	GWB48GB2400C14DC			SS		2pcs
DDR4	2133	8GB	Geil	GP48GB2133C15SC			SS		2pcs
DDR4	2666	8GB	HyperX	HX426C15FB/8			DS		2pcs
DDR4	2666	8GB	HyperX	HX426C13SB2K4/32			DS		2pcs
DDR4	2666	8GB	HyperX	HX426C13PB3/8	Hynix M-die		SS		2pcs
DDR4	2666	8GB	HyperX	HX426C13PB3K4/32	Hynix M-die		SS		2pcs
DDR4	2666	8GB	HyperX	HX426C13PB3K2/16	Hynix M-die		SS		2pcs
DDR4	2666	16GB	HyperX	HX426C13PB3/16	Hynix M-die		DS		2pcs
DDR4	2666	16GB	HyperX	HX426C13PB3K2/32	Hynix M-die		DS		2pcs
DDR4	2666	16GB	HyperX	HX426C13PB3K4/64	Hynix M-die		DS		2pcs
DDR4	2400	8GB	HyperX	HX424C15FB2K4/32			SS		2pcs
DDR4	2400	8GB	HyperX	HX424C12PB3K4/32	Hynix M-die		SS		2pcs
DDR4	2400	8GB	HyperX	HX424C12PB3K2/16	Hynix M-die		SS		2pcs
DDR4	2400	8GB	HyperX	HX424C12PB3/8	Hynix M-die		SS		2pcs
DDR4	2400	4GB	HyperX	HX424C15FBK4/16			SS		2pcs
DDR4	2400	16GB	HyperX	HX424C15FBK4/64			DS		2pcs
DDR4	2400	16GB	HyperX	HX424C12PB3K2/32	Hynix M-die		DS		2pcs
DDR4	2400	16GB	HyperX	HX424C12PB3/16	Hynix M-die		DS		2pcs
DDR4	2133	8GB	HyperX	HX421C14FB2K4/32			SS		2pcs
DDR4	2133	8GB	HyperX	HX421C14FB/8			DS		2pcs
DDR4	2400	8GB	J&A	JAD4U24001608-8M			SS		2pcs
DDR4	2400	4GB	J&A	JAD4U24001608-4M			SS		2pcs
DDR4	2133	4GB	J&A	JAD4U21331508-4M			SS		2pcs
DDR4	2666	8GB	Kingston	KVR26N19S8/8	Micron D-die		SS		2pcs
DDR4	2666	8GB	Kingston	KVR26N19S8/8	Micron H-die		SS		2pcs
DDR4	2666	16GB	Kingston	KVR26N19D8/16	Micron D-die		DS		2pcs
DDR4	2666	16GB	Kingston	KVR26N19D8/16	Micron H-die		DS		2pcs
DDR4	2400	8GB	Kingston	KVR24N17S8/8			SS		2pcs
DDR4	2400	8GB	Kingston	HX424C15FBK4/32			SS		2pcs
DDR4	2400	8GB	Kingston	HX424C15FB2/8			SS		2pcs
DDR4	2400	4GB	Kingston	KVR24N17S8/4	Micron		SS		2pcs
DDR4	2133	8GB	Kingston	KVR21N15S8/8			SS		2pcs
DDR4	2133	8GB	Kingston	KVR21N15D8/8			DS		2pcs
DDR4	2133	4GB	Kingston	KVR21N15S8/4			SS		2pcs
DDR4	2133	16GB	Kingston	KVR21N15D8/16			DS		2pcs
DDR4	3000	8GB	KLEVV	IM44GU88A30-FGGHMZ			SS		2pcs	v
DDR4	3000	8GB	KLEVV	IM44GU88A30-FGGHMB			SS		2pcs	v
DDR4	3000	4GB	KLEVV	IM44GU48A30-GIIHMC			SS		2pcs	v
DDR4	3000	4GB	KLEVV	KM4Z4GX1A-3000-15-16-16-36-1			SS		2pcs	v
DDR4	3000	4GB	KLEVV	KM4B4GX1A-3000-15-16-16-36-0			SS		2pcs	v
DDR4	3000	4GB	KLEVV	KM4Z4GX2A-3000-15-16-16-36-1			SS		2pcs	v
DDR4	2666	8GB	KLEVV	KM4Z8GX1N-2666-15-15-15-35-1			SS		2pcs
DDR4	2666	8GB	KLEVV	KM4Z8GX2N-2666-15-15-15-35-1			SS		2pcs
DDR4	2666	4GB	KLEVV	KM4Z4GX2N-2666-15-15-15-35-1			SS		2pcs
DDR4	2666	4GB	KLEVV	KM4Z4GX1N-2666-15-15-15-35-1			SS		2pcs
DDR4	2666	16GB	KLEVV	KM4Z16X1N-2666-15-15-15-35-0			DS		2pcs
DDR4	2666	16GB	KLEVV	KM4Z16X2N-2666-15-15-15-35-0			DS		2pcs
DDR4	2400	8GB	KLEVV	KM4Z8GX2N-2400-15-15-15-35-1			SS		2pcs
DDR4	2400	8GB	KLEVV	KM4Z8GX1N-2400-15-15-15-35-1			SS		2pcs
DDR4	2400	4GB	KLEVV	KM4Z4GX2N-2400-15-15-15-35-1			SS		2pcs
DDR4	2400	4GB	KLEVV	KM4Z4GX1N-2400-15-15-15-35-1			SS		2pcs
DDR4	2400	16GB	KLEVV	KM4Z16X2N-2400-15-15-15-35-0			DS		2pcs
DDR4	2400	16GB	KLEVV	KM4Z16X1N-2400-15-15-15-35-0			DS		2pcs
DDR4	2133	8GB	KLEVV	IMA41GU6MFR8N-TF1			SS		2pcs
DDR4	3000	8GB	Neo Forza	NFMUD480E8-3000DH2A			SS		2pcs
DDR4	2800	4GB	Panram	PUD42800C164G4NJW			SS		2pcs
DDR4	2666	8GB	Panram	W4U2666PS-8G			SS		2pcs
DDR4	2666	16GB	Panram	W4U2666PS-16G			DS		2pcs
DDR4	2400	8GB	Panram	PUD42400C158G4NJW			DS		2pcs
DDR4	2400	8GB	Panram	W4U2400PS-8G			SS		2pcs
DDR4	2133	8GB	Panram	W4U2133PS-8G			SS		2pcs
DDR4	3333	8GB	Patriot	PV416G340C6K (11BF2)			SS		2pcs	v
DDR4	3333	4GB	Patriot	PV48G340C6K (11E2)			SS		2pcs	v
DDR4	3333	4GB	Patriot	PV48G360C7K (11E1)			SS		2pcs	v
DDR4	3200	8GB	Patriot	PV416G360C7K (11BF1)			SS		2pcs	v
DDR4	3200	8GB	Patriot	PV416G320C6K (11BF2)			SS		2pcs	v
DDR4	3200	4GB	Patriot	PV48G320C6K (11EC2)			SS		2pcs	v
DDR4	3200	4GB	Patriot	PV48G320C6K (11D1)	Samsung 11D1		SS		2pcs	v
DDR4	3000	4GB	Patriot	PV48G300C6K (14M1)			SS		2pcs	v
DDR4	2933	8GB	Patriot	PV416G300C6K (11BF2)			SS		2pcs	v
DDR4	2933	4GB	Patriot	PV48G300C6K (11EC2)			SS		2pcs	v
DDR4	2400	8GB	Patriot	PSD48G240081			SS		2pcs
DDR4	2400	8GB	Patriot	PVE416G240C5KRD (11BF2)			SS		2pcs
DDR4	2400	4GB	Patriot	PSD44G240081			SS		2pcs
DDR4	2400	4GB	Patriot	PVE48G240C5KRD (11EC2)			SS		2pcs
DDR4	2400	16GB	Patriot	PSD416G24002			DS		2pcs
DDR4	2133	8GB	Patriot	PSD48G21332			SS		2pcs
DDR4	2133	4GB	Patriot	PSD44G213381			SS		2pcs
DDR4	2400	4GB	Samsung	M378A5244CB0-CRC			SS		2pcs
DDR4	2133	8GB	Samsung	M378A5143DB0-CPB			SS		2pcs
DDR4	2133	8GB	Samsung	M391A1G43EB1-CPBQ (ECC)			SS		2pcs
DDR4	2133	4GB	Samsung	M378A5143EB1-CPB			SS		2pcs
DDR4	2133	4GB	Samsung	M378A1G43DB0-CPB			SS		2pcs
DDR4	2133	8GB	Silicon Power	SP008GBLFU213N01			SS		2pcs
DDR4	2666	8GB	Team	TFWD48G2666C15BBK			SS		2pcs
DDR4	2400	8GB	Team	TED48G2400C16BK			SS		2pcs
DDR4	2400	4GB	Team	TED44G2400C16BK			SS		2pcs
DDR4	2133	8GB	Transcend	TS1GLH64V1H			DS		2pcs
DDR4	2400	8GB	UMAX	84G48GA3SP-24MSPGNGFY7B			SS		2pcs
DDR4	2400	8GB	UMAX	84G48GA3CP-241MCALGFY7J1			SS		2pcs
DDR4	2400	16GB	UMAX	84G416A3CP-241MCGNGFY7B			DS		2pcs
DDR4	2400	16GB	UMAX	84G416A3CP-241MCGNGFY7J1			DS		2pcs
DDR4	2133	8GB	UMAX	RMUM8GD42131024			SS		2pcs
DDR4	2133	8GB	UMAX	RMUM8GD42133512			SS		2pcs
DDR4	2133	4GB	UMAX	RMUM4GD421333512			SS		2pcs
DDR4	2133	4GB	UMAX	RMUM4GD42133512			SS		2pcs
DDR4	2400	8GB	V-Color	TD8G16C17-UH			DS		2pcs
DDR4	2400	8GB	V-Color	TC48G24S817			SS		2pcs
DDR4	2133	8GB	V-Color	TC48G21S815-iMS			SS		2pcs
DDR4	2133	8GB	V-Color	TD8G8C15-093E			SS		2pcs
Berichte & Reviews
https://smallformfactor.net/reviews/motherboards/fatal1ty-asrocks-x370-ab350-gaming-itxac-motherboards-reviewed
deutsches Video-Review: ASRock Fatal1ty AB350 Gaming-ITX/ac - Quick Review - YouTube
16.03.2018 - Aktuell gibt es einen Bug mit den Raven Ridge CPUs die bei WLAN Nutzung zur Instabilität führen. Dazu solltet ihr mal einen Blick in die Beta BIOS werfen. (4.51A)
Links zu den neusten BIOS Versionen findet ihr hier:
AB350: ASRock > Fatal1ty AB350 Gaming-ITX/ac
X370: ASRock > Fatal1ty X370 Gaming-ITX/ac
Wer noch eine ältere Version nutzt und auf 4.0 oder höher möchte, bitte das Bridge BIOS nicht vergessen.
Habe den 2200g, anstatt 3,5Ghz mit 3,7Ghz Boost kann man direkt 3,8Ghz allcore einstellen. Bei mir war die Stockspannung bei 1.4V.
Das ist Chiplotterie, dann musst wohl etwas mehr Spannung geben. Probier mal 1.35 und taste dich ran.
Ich empfehle dir das mit Offset zu lassen, im Endeffekt bringt es nix wenn du OC hast. (Volt ist fix)
Denn 1,3V mit deinem Offset ergibt dann logischerweise 1,2V. Was durchaus etwas knapp sein kann bei 3,7 Ghz.
Probier mal das Offset komplett rauszunehmen und gib direkt 1,2125V ein. Dann immer langsam erhöhen, falls instabil. Mein 2400G läuft mit 1,20625V stabil auf 3,7. Ist alles wie bereits von promontory gesagt ein Lottospiel^^
Ich versuche gerade noch mal bei meinem 1600 die krittische Spannung für 3.8GHz auszuloten.
Bei 1.2V ist er mir noch abgeschmiert nach ner Minute Prime.
Jetzt bin ich gerade bei 1.21V und Prime läuft schon 10 Minuten. Die Temperaturen sind auch alle im Gleichgewucht angekommen.
Nach 10 Min. Prime Maximum Heat Test habe ich:
CPU Tctl/Tdie: 61°C
CPU: 54°C
MB: 49°C
Das wäre immer noch kühler als mein altes Setting mit 3.6GHz.
Während ich dies gerade schreibe, ist er abgeschmiert^^. Wenn ich mich hier ganz inkrementell an die Spannung annähere, sollte man dann die so gefundene nehmen, oder noch ein bisschen drauf packen?
Prime Blend Test und da mal 1-2h laufen lassen... spätestens ab 8k gibts richtig Feuer drauf. ;)
Btw laufen die Tests alleine 15min... 10min mit dem ersten FFT ...
Was ist der Vorteil von dem Blend Test ggü dem large FFT?
Jetzt bin ich gerade bei 1.225V.
Nach 15 Min. Prime Maximum Heat Test habe ich:
CPU Tctl/Tdie: 62°C
CPU: 54°C
MB: 50°C
Habe gerade mal gewechselt auf den Blend Test. Damit ist die Kerntemperatur gleich mal um 4K gesunken.
Edit: wieder abgeschmiert. Jetzt versuche ich 1.231V. Macht das überhaupt Sinn mit den minimalen Schritten?
Was mich wundert ist, laut HWinfo kommen bei den Kernen die 1.231V an und stehen da bei dem maximalen Wert. Aber während des Prime Tests steht bei dem aktuellem Wert was kleineres. Aktuell zum Beispiel 1.181-1.2V
Blend ist allgemein ein etwas "softerer" Test, der alle Komponenten mit einbezieht.
Ich würde an deiner Stelle nicht Blend nehmen, sondern In-place large FFT. Klick zuerst auf In-large, dann auf "Custom" und dort erhöhst du die RAM Menge, z.B. auf 12000 MB wenn du 16GB hast. Das ganze starten und währenddessen rumsurfen (Video etc.) um noch mehr Last zu generieren. (Nimm hier keinen Firefox, der kann nach einem Absturz mit den Profilen rumbuggen).
Wenn das dann nach ca. 2-3 Stunden noch gut rennt, bist du safe :)
Falls es bei 1.225V jetzt läuft, kannst du nochmal 1 oder 2 Stufen weiter unten probieren. Man muss halt Geduld mitbringen und wirklich einige Stunden laufen lassen. Bei meiner APU hab ich zusätzlich noch die Vega Grafik auslasten müssen, das entfällt bei deinem 1600 zum Glück.
Nur 10-15 Minuten Prime laufen lassen reicht nicht immer aus. Musste ich vor kurzem selbst erleben. Handbrake Encoding auf 4 Threads und die anderen 4 Threads für ein Spiel... Also die CPU hatte mächtig zutun. Hatte dann so ca. 2 Stunden gezockt und es kam zum Freeze. Ganzes Enconding umsonst. Hab die Volt dann nochmal eine Stufe rauf, Prime 3-4 Stunden volldampf zum verifizieren und jetzt ist alles stabil.
Hmm, aber das mit dem Ram geht doch nur, wenn ich nicht in place mache.
Ich habe jetzt mal In Place und FFT zwischen 8 und 4096 eingestellt mit 15 Min Wechsel.
Spannung ist jetzt bei 1.238V. Ich komme ja gerade von unten. Das macht also keinen Sinn wieder runter zu gehen.
Ich denke ich würde das schon gerne so 12 Stunden laufen lassen, bevor ich das nutze. Aber langsam komme ich wieder auf die 1,25V und die Temps steigen mit. Jetzt im Winter ist das ja kein Problem, aber wenn dann im Sommer die Luft wärmer wird...
Muss man eigentlich idealerweise die CPU gleichzeitig mit dem Ram mit memtest laufen lassen?
Ja, den Haken bei "Run FFTs in place" weg machen und man kann die MB anpassen.
Also gleichzeitig RAM laufen lassen muss man nicht unbedingt, schadet aber nicht. Vor allem wenn man 3200er RAM nutzt.
Die Werte die HWiNFO ausliest schwanken immer etwas, ist ganz normal.
Die Platine ist nun bestellt.
Vorhaben:
Mainboard: Asrock Fatal1ty AB350 ITX/ac
CPU: Ryzen 5 2400G
CPU Kühler: Noctua NH-L9a M4
RAM: 200 €
G.Skill Flare X schwarz DIMM Kit 16GB, DDR4-3200, CL14-14-14-34 (F4-3200C14D-16GFX) oder eine Alternative?
Ich habe gestern bei 1.238V 2 Stunden Prime laufen lassen und noch ne dreiviertel Stunde Aida64 mit CPU, FPU Cache und Ram. Ich hatte gelesen, dass AIDA64 bei Ryzen mehr Stress machen soll und aussagekräftiger ist.
Weil das aber so gerade an der Grenze ist, habe ich heute noch etwas drauf gegeben und bin jetzt bei 1.244V. AIDA64 läuft jetzt seit bald drei Stunden. Die Temperatur ist hier nicht so vergleichbar mit Prime, aber liegt bei 60°C. Ich denke mal bei Prime sind das dann so 63°C. Vlt. mache ich dann in ner Stunde den Prime komplett Test. Aber vlt. bleibt es dann bei dem Setting. Ist glaube ich für nen 1600 ohne X gar nicht so schlecht.
Zwei Fragen habe ich noch, aber vlt. sind die auch im OC Forum besser aufgehoben.
1. Wenn es im Sommer wärmer wird, steigt natürlich auch die CPU Temp unter Last. Wirkt sich das auf die benötigte Spannung aus? Ich habe jetzt 21°C Lufttemperatur und taste mich an ein stabiles System ran. Kann das dann bei 27°C instabil werden oder ändert sich rein die Wärmeabfuhr?
2. Dieser Spannungsdrop unter Last ist ziemlich konstant 50-40mV. Soll das so sein oder liegt das an den Spawas? Bedeutet das, dass ich dann eigentlich 3.8GHz @ 1.2V habe?
Ja diesen
, der läuft garantiert auf 3466Mhz 14-14-14-32 plus scharfe subtimings, bei mir laufen gerade 3600Mhz unter vorbehalt, ich hatte ein bluescreen, gucke da noch woran es liegt
Ansonsten kann ich den nur empfehlen, da Samsung B-Die und absolut unproblematisch bis 3466Mhz
gruß
- - - Updated - - -
Spannungsdropp ist normal, dafür gibt es nromalerweise LLC, aber dann werden dir im idle zu viel mV auf die Core´s gelegt.
Und ja, mehr temperatur "kann" zu instabilitäten führen. Das kannste aber doch jetzt schon testen, heitzung an, auf 28°C aufheitzen und dann testen. Alles was du da stabil bekommst, ist dann auch 365 Tage im Jahr stabil
Auf 28°C möchte ich die Wohnung eher nicht aufheizen.
Ich habe auf jeden Fall bereits gelernt, dass es nicht reicht Prime einfach mal 2 Stunden laufen zu lassen und wenn der Rechner nicht abschmiert ist es stabil. Habe gestern zum Beispiel bei 1.275V Prime laufen lassen und es war ewig nichts. Morgens habe ich dann unter HWinfo 5 WHEA Fehler gesehen.
Weil ich die ganz winzigen Schritte mittlerweile leit bin, habe ich mal 1.3V genommen. Da ist jetzt nach 12 Stunden nichts aufgetreten. Aber die Temperaturen sind natürlich deutlich schlechter geworden. Ich lasse das jetzt aber erst mal noch weiter laufen bis morgen. Dann weiß ich, 1.3V bei 3.8GHz ist stabil. Vlt. probiere ich auch noch mal 3.7 oder 3.75GHz aus. Evtl. wird das etwas angenehmer.
Hallo zusammen.
Mein Ryzen System ist nun auch fertig, jetzt geht es dann mal ans feintuning, testen und tweaken aber dazu hab ich noch ein paar Fragen.
Vorerst mal mein aktuelles Setup:
Case: SilverStone Raven RVZ03
CPU: Ryzen 5 2400G
Mobo: ASRock AB350 Gaming-iTX/ac (eh klar)
RAM: Trident Z PC4000 C19 - 16 GB Kit
Kühler: Noctua NH L9-65
NT: Coolink 600 W (ATX)
SSD: Samsung SATA SSD (noch)
OS: Win 10 pro
Kurze Story dazu:
Das Board habe ich von Amazon bekommen, trotz Nachfrage und Zusage von Amazon hab ich eine Version OHNE Ryzen Desktop 2000 ready Bios bekommen was mich ziemlich geärgert hat weil ich damit erstmal nix machen konnte. Habe danach direkt ASRock kontaktiert und die haben mir super schnell geantwortet und innerhalb von 4 Tagen hatte ich einen BIOS Chip mit dem neuesten BIOS (4.50). Der Einbau war super einfach, am besten geht es mit ner Lupenlampe und ner GUTEN Pinzette ;-)
Der Aufbau war relativ problemlos. Das Gehäuse ist zwar nicht das kleinste der Welt aber mit dem ATX Netzteil und dem bockigen Kabelstrang war es dann doch sehr eng. Ansonsten gab es keine großen Probleme und ohne extra Grafikkarte bleibt auch noch genügend Freiraum im Gehäuse.
Nun zu meinen Fragen/Beobachtungen:
1.) Als ich fertig war und den Rechner gestartet habe passierte erst mal nichts, ok Schalter am NT versehentlich beim nachträglichen Kabel verlegen wieder ausgeschaltet. Als die Mühle dann ansprang drehten mal alle Lüfter korrekt und die RGB LED pulsierte Rot. Ich dachte erst mal die will mir damit was sagen, stellte sich aber raus, dass das zufällig so eingestellt war. Jedenfalls kam kein Bild, ich hab 5-6 mal ein und wider ausgeschalten aber nichts passierte. Dann hab ich beide RAM raus und abwechselnd gesteckt, nix. SSD an und abgesteckt auch nix. Dann einen PC Speaker rangehängt aber auch hier kein Piep (der ist im BIOS default OFF, lustig). Hab weiter mit Power gedrückt halten und Reset hämmern probiert und dann auch CMOS Clear gemacht, alles ohne Erfolg und als ich aufgeben wollte und ihn ein letztes mal eingeschalten hab, höre ich plötzlich den CPU Lüfter hochdrehen!? OK das war neu, also warte ich ... und ein paar Sekunden später plötzlich ein POST und Hurra wir sind im uefi! WTF?! Warum jetzt auf einmal!?
Ich hatte das dann während der initalen Einstellerei der Basisfunktionen im uefi noch 2-3 mal, warum auch immer bleibt er da manchmal hängen und ich muss 2-3 mal neu starten.
Kann mir jemand erklären ob das in irgend einer Art und weise ein gewünschtes Verhalten ist und ob es dazu eine Dokumentation gibt oder ob das vielleicht ein Fehler bei meinem Board ist?!
2.) Kann mich jemand ein wenig mit den umfangreichen Einstellungen vertraut machen ;-) Ich bin etwas erschlagen von den gefühlten 500 Optionen im uefi. Bei meinem alten Boarf (ein anständiges OCer ASUS P5K Deluxe) gab es ne Seite für RAM (Freq. und Timings) und eine für CPU und BUS Takte und Voltage, fertig. Hier gibt es allein für den Ram schon 3 Menüpunkte mit ich weiß nicht wie vielen Settings dahinter. Bei der CPU hab ich noch garnicht gewagt zu schauen.
Also was mir helfen würde ist eine kurze Zusammenfassung der relevanten Settings für OC und welche Zusammenhänge zu beachten sind. Also welche Spannungsregler für welche Komponenten verantwortlich sind, was die "maximalen" Werte in etwa sind und welche Ausganswerte man mal probieren könnte!?
Auch diese XMP Sache ist mir leider komplett neu. Ich hab das gesehen ok, XMP 2.0 Profile, ok!? Dann hab ich aus der Liste 3200 genommen und fertig gesagt. Wars das? nö oder? Dann hab ich in die Timings geguckt und dort manuell auf CL14 gesetzt (gleiche Timings wie die FlareX) und vorsichtshalber mal RAM Voltage auf 1,4 V geschraubt. Scheint zu laufen aber ist das alles? Ganz hab ich es nicht kapiert was dieses XMP macht.
3.) Wie ist da mti dem Framebuffer Speicher? Erst mal hab ich ne weile gebraucht bis ich diese Einstellungen gefunden habe, sind ja gut versteckt für etwas was man bei dieser APU doch unbedingt einstellen sollte!? Egal jedenfalls hab ich es dann gefunden und dort kann man ja auch mal 8 GB oder mehr zuweisen, hab ich probiert ging natürlich nicht. Ich hab dann gelesen, dass max. 4 GB gehen. OK nur warum kann man dann so viel mehr auswählen? Oder geht das schon irgendwie?
4.) Wie genau ist das nun mit einer Ryzen APU und PCIe M.2 Karten...? Bekomme ich da nun die vollen 4 PCIe Lanes oder nicht? In der Anleitung vom Board steht: Ryzen CPU 4 Lanes, A-Series (also Bristol?!) APUs 2 Lanes... aber was ist mit Raven Ridge Ryzen APUs?! Die sollten ja mehr PCIe Lanes haben oder doch nicht?! Ich frag so doof weil ich mir eine größere SSD holen will und eigentlich natürlich gern eine NVMe möchte wegen der höheren Speeds aber wenn die dann nur mit 2 Lanes auf Halbgas rennt steht sich der Preis nicht dafür und ich nehm mir lieber eine größere SATA SSD fürs gleiche Geld.
So das war es erstmal, hoffe ihr könnt mir ein paar Antworten geben.
Danke schon mal an alle die das hier jetzt gelesen haben ;-)
Falls jemand das Board mit einer Summit Ridge CPU und Win7 betreibt: Funktioniert das Ganze noch mit der neuen AGESA 1.0.0.1a? Oder wurde die Win7-Kompatibilität nachräglich rausgepatcht?
AGESA 1.0.0.1a müsste mit Bios 4.60 kommen, wenn ich mich nicht vertue.
Kaltstart Bug, manchmal gibt es das, insbesondere dann, wenn alles @OC ist und die Spannungen noch nicht 100% da sind beim start, dann kann es ein Bootloop7Bug geben. Das passiert manchmal aber auch mit sachen komplett @ stock. Mach dir da mal kein kopf drum, wenn jetzt alles läuft.
Firmware einer HDD, Uefi mag den Ram nciht oder oder oder, da gibt es viele Gründe. Auch hier, COOL bleiben und erstmal alles einstellen =)
Sieht alles viel aus, am ende brauchst du aber nur 3-4 sachen, den rest musst du nicht anfassen, solange du OC im Rahmen betreiben willst!
XMP sind auf dem Speicher abgelegte Profile, wenn das ausgewählt wird, dann läuft der Speicher wie vom Hersteller vorgegeben.
Habe keine APU, weis da leider nicht zu helfen.
4.)
Lg
max 2GB. Mehr einstellen kannst du zwar, aber Windows erkennt es nicht.
Mehr wirst du auch nicht brauchen, bevor die VRAM ein Bottleneck darstellen, ist es eher die Leistung der APU.
Vielleicht lassen Windows Versionen in der Zukunft mehr zu.
Danke für deine Antworten!
Kannst du mir ev. sagen welche Optionen ich für OC beachten muss?
Beim RAM hab ich zumindest mal das gemacht was ich wusste, einfach die Timings und Spannung entsprechend eingestellt, der läuft mal wie er soll ohne es jetzt getestet zu haben. Aber den hab ich ja eigentlich untertaktet sogesehen ;-)
CPU und APU möchte ich noch ein wenig testen, auch um zu sehen wie es mit den Temperaturen dann aussieht und wie ich das Gehäuse optimal belüften kann.
OK alles klar, lustigerweise wollte er aber mit mehr als 2 GB garnicht erst booten, hat sich ja einfach direkt nach dem Einschalten wieder abgeschaltet und wieder ein usw. Aber ok, wenn nicht mehr als 2 GB gehen dann soll es mir recht sein.
Kann mir nun noch jemand was zu den PCIe Lanes am M.2 Port sagen???
----------------------- Update 1 -----------------------
M.2 PCIc Lanes
ASRock Support hat, wie immer, super schnell reagiert und mir geantwortet.
Konkret geht geht es um folgende Aussage in den Spezifikationen des Boards:
Storage:
Laut Support bezieht sich der blaue Teil auf ALLE Ryzen Chips (Summit und Raven Ridge) und somit auch auf Ryzen APUs.
Daher: Ryzen CPUs und APUs (Summit- und Raven Ridge) haben alle 4 PCIe Lanes > Gen3 x4 (32 Gb/s) über den M.2 Steckplatz.
----------------------- Update 2 -----------------------
Freezes / BSOD
Gestern habe ich begonnen mein System ein wenig zu testen da ich nun langsam mit dem ausloten der Settings beginnen will. Zuerst also einfache Spiele testen und sehen wie es läuft. Habe mir Assassins Creed Black Flag genommen weil es gerade da war. Spiel lief nach DX Installation einwandfrei, Temperaturen auch unbedenklich. Dann irgendwann bei einer Mission nach der letzten "Aktion" bleibt der Screen schwarz, Audio läuft weiter, dann Stille und plötzlich komische Artefakte am Screen und Neustart. Ich hab es noch 1-2 mal probiert, immer an der selben Stelle. Habe die RAM Timings runter gefahren (das einzige was ich bisher verändert hatte), keine Erfolg. Nach 5-6 Versuchen habe ich für mich entschieden es als Fehler im Spiel bzw. Treiberproblem abzuhaken. Ich denke nicht, dass es ein Systemproblem per se ist da alle Werte stets normal waren und der Crash immer exakt an der selben Stelle kommt.
Danach wollte ich 3D Mark testen um zu sehen was die GPU und CPU unter Load so machen und wie die Werte ausfallen. Also erst mal downloaden. Da der PC noch im Keller steht ist das WLAN dort sehr schlecht und der Download sollte rund 20 Minuten dauern > was für ein Glück wie sich herusstellen sollte. Zuerst hatte ich beim Surfen schon mal einen BSOD, keine Ahung, ich hab es ignoriert weil das bei neuen Systemen gerne mal passiert wenn noch nicht alle Treiber 100% passen oder eine Einstellung noch nicht OK ist.
Zurück zum Download, ich sitze also davor und beobachte wie er langsam dahinlädt so mit 5-7 mb/s. Auf einmal bleibt die Anzeige stehen als würde die Verbindung abgebrochen sein. WLAN Status aber OK, sehr komisch. Als ich zur Maus greife merke ich, das system ist eingefroren. Hilft nur Reset. OK ich denk mir wieder das kann ja mal sein, war aber etwas verunsichert weil ich kurz zuvor viele Berichte über plötzliche Freezes mit dem ASRock Board gelesen habe. Also neu gestartet, download setzt normal fort alles OK aber dann, ein paar Minuten später bleibt die Anzeige wieder stehen, ich greif sofort zur Maus aber das System läuft noch ... komisch, Download steht, Empfang lt. Statusanzeige OK und ein paar Sekunden später > Freeze. Das kann ja nicht sein denk ich mir und schau ins UEFI, RAM Settings komplett stock und runtergetatktet, damit kann eigentlich nix sein, der lief zuvor ja auch und ich mach nen blöden DOWNLOAD und keinen Stresstest. In Summe hatte ich dann 4 Freezes bis der Download fertig war und ich 3D Mark installieren konnte.
3D Mark hab ich dann laufen lassen, beim 1. mal gab es einen Abbruch mit einem Fehler (der aber nicht näher beschrieben wurde). OK noch mal, ich hab vermutlich durch mein herumschalten zwischen 3D Mark und AMS Master tool was durcheinandergebracht. Beim 2. mal lief der Test komplett und Fehlerfrei durch. Die GPU Performance war aber sehr mager das hat mich irritiert. Am Ende zeigt er mir an, dass meine Grafikkarte nicht erkann und der Treiber nicht akzeptiert worden sei!? WTF?! Es ist alles korrekt installiert und am Startscreen von 3D Mark wird auch alles korrekt angezeigt!? Ich hab dann nicht weiter getestet weil es schon 2 Uhr morgens war aber ich hatte keine weiteren Freezes mehr!
Heute hab ich mich auf die Suche nach Antworten gemacht und siehe da ich bin fündig geworden. Das Freezen schein ein WLAN Problem zu sein. Durch einen Fehler in der Kommunikation zwischen dem WLAN Adapter und dem Prozessor am Board kommt es wohl zu einer Überlastung der Datenschnittstelle mit dem Effekt, dass zuerst keine Daten mehr übertragen werden und, in den meisten Fällen das System einfriert oder es einen BSOD gibt. Das ganze Fällt aber nicht sofort auf, es dauert immer ein paar Minuten, scheinbar unabhängig von der Datenmenge. Ich habe auf reddit einen Thread gefunden, dort haben die Leute es beim Video streaming beobachtet und reproduzieren könne weil dort über längere Zeit konstant Daten über die WLAN Schnittstelle laufen. Von ASRock gibt es bereits ein Beta BIOS (4.51) welches dieses Problem beheben soll, ich werde das heute testen. Wenn es das war, hatte ich jedenfalls Glück, dass ich im Keller war denn sonst wäre der Download wohl so schnell fertig gewesen, dass ich es nicht bemerkt hätte.
Damit versteh ich dann auch die Rezensionen die von den unmotivierten Freezes berichten, wenn das System mal läuft und man dann surft oder im Hintergrund Updates geladen werden passiert das und man bekommt nicht wirklich mit warum. In meinem Fall war die Downloadanzeige der entscheidende Hinweis.
Also, für alle die Probleme mit BSODs oder Freezes mit diesm Board haben > Es könnte am WLAN liegen > Beta BIOS 4.51 laden und testen!!!!
LG
Ist doch bekannt und hättest du ne Seite zuvor gelesen, hättest du dir den langen Text sparen können ;)
Hey danke für den Hinweis. Ich hab natürlich schon das eine oder andere mal von "DEM WLAN PROBLEM" gelesen aber mir war bisher nicht klar was das Problem ist denn mein WLAN hat immer funktioniert, jedenfalls insofern, als ich ne Verbindung hatte und auch Daten übertragen wurden.
Mir war aber NICHT bekannt/bewusst, dass dieses Problem zu Abstürzen/Freezes führt! Daher hatte ich das auch zuerst überhaupt nicht im Verdacht. Und anscheinend geht es da manchen anderen auch so denn es beklagen sich aktuell extrem viele Leute über Freezes mit dem Board und ich vermute die meisten haben genau diesen Bug als Ursache! Es trat nämlich erst nach der Aktualisierung der WLAN Treiber auf wenn ich so zurückdenke denn vorher hab ich noch sämtliche Windows Updates über WLAN gemacht ohne einen Freeze o. BS.
Ich wollte mit meinem Text einfach darauf eingehen was das WLAN Problem ist, wie man es ev. auch als das erkennen kann und natürlich, dass es bereits gefixt wurde > Support wie immer großartig. Auch wenn manche meinen, dass soetwas garnicht erst passieren darf. Ich seh das lockerer nach so vielen Jahren und Systemen die ich schon gebaut habe.
LG
Hat jemand schon das neue BIOS ausprobiert?
Ist das nur für Ryzen+ oder bringt das auch so bessere OC Möglichkeiten hinsichtlich RAM usw.?
Gibt es was neueres als [Beta] 4.51A?
Mich nervt irgendwie total, dass das hier zwar ein Sammler sein soll aber im ersten Post nicht mal ein gescheiter Link zu Asrock drin ist.
Nix zu den Treibern, nix zum Bios oder den Downloads allgemein, nicht mal zur Produktseite vom board.
Sowas fehlt hier echt.
Direkt vorne weg, ich bin totaler Computer Laie und versteh nicht mal die Hälfte von dem was hier beschrieben wird, nehmt mir unnötige Fragen also bitte nicht übel.
Wie scheinbar viele auf den letzten Seiten habe ich Probleme mit dem WLAN, nur aber beginnt das Problem bei mir viel früher. Ich empfange seit ein paar Wochen kein WLAN Signal mehr, welches >als 1m von meinem Rechner entfernt gesendet wird. Mit meinem Handy empfange ich den Hotspot wenn es neben dem Rechner liegt. Die zwei Antennen sind hinten angeschraubt und funktionierten (falls dass das Problem ist) zu Beginn auch. Meine Vermutung ist, dass die Antennen defekt sind oder das MB einen Defekt hat. Das BETA BIOS habe ich installiert, hat aber keine Abhilfe gebracht. Freezes hatte ich nie, da ich aber auch bisher über LAN gesurft habe.
Ist dieses Problem jemandem bekannt und wie wurde es gefixt? Alle Teile meine Systems (auch das MB) habe ich über Mindfactory vergangenes Jahr im August bestellt, wende ich mich da am besten an die um mein MB zu ersetzten oder an den Asrock Support?
Beste Grüße und Danke CorbuGD
Hast du einen Treiber für die W-Lan-Karte installiert?
Vielleicht war windows der meinung bei einem der Updates den Treiber aktuallisiseren zu müssen und hat dabei einen nicht richt arbeitenden oder nicht wirklich passenden Treiber installiert.
Such dir mal hier das passende Betriebssystem raus
Und dann den Treiber hier runter laden: Intel Wireless Lan driver ver:18.40.4
Hatte das in letzter Zeit nicht mehr aber beim Erscheinen von Windows 10 hatte ich mehrmals das Problem, dass Windows einen nicht passenden Treiber installiert hat und damit das System langsamer / instabil gemacht hat.
Muss nicht die Lösung sein, könnte aber vielleicht helfen.
Guten Abend zusammen,
Lässt sich bei ASRock über die S/N herausfinden, ob die Platine bereits mit einer 2200g / 2400g APU kompatibel ist?
Ähnliche Themen
