Sammelthread Asrock AB350 Gaming-ITX/ac | X370 Gaming-ITX/ac
die beiden Mini-ITX AM4 von Asrock
Inhaltsverzeichnis:
- Technische Daten
- Preisvergleich
- Fragen / Antworten
- RAM Kompatibilität
- Berichte & Reviews
- aktuelle BIOS Versionen
Technische Daten
AB350 Gaming-ITX:
Code:
[table="width: 500"]
[tr]
[td]Gaming Armor[/td]
[td]Power
- Hi-Density Power Connector (8 pin)
Memory
- 15μ Gold Contact in DIMM Slots
VGA Card
- 15μ Gold Contact in VGA PCIe Slot (PCIE1)
Internet
- Intel® LAN
Cooling
- 2oz Copper PCB
Audio
- Creative Sound Blaster™ Cinema 3[/td]
[/tr]
[tr]
[td]Unique Feature[/td]
[td]ASRock Super Alloy
- Premium Power Choke
- Dual-N MOSFET
- Nichicon 12K Black Caps (100% Japan made high quality conductive polymer capacitors)
- Matte Black PCB
- High Density Glass Fabric PCB
- 2oz Copper PCB
Intel® 802.11ac WiFi
ASRock Steel Slots
ASRock Ultra M.2 (PCIe Gen3 x4 & SATA3)
ASRock Full Spike Protection (for all USB, Audio, LAN Ports)
ASRock Live Update & APP Shop[/td]
[/tr]
[tr]
[td]CPU[/td]
[td]- Supports AMD Socket AM4 A-Series APUs (Bristol Ridge) and Ryzen Series CPUs (Summit Ridge)
- Digi Power design
- 8 Power Phase design
- Supports 95W Water Cooling[/td]
[/tr]
[tr]
[td]Chipset[/td]
[td]- AMD Promontory B350[/td]
[/tr]
[tr]
[td]Memory[/td]
[td]- Dual Channel DDR4 Memory Technology
- 2 x DDR4 DIMM Slots
- AMD Ryzen series CPUs support DDR4 3466+(OC) / 3200(OC) / 2933(OC) / 2667 / 2400 / 2133 ECC & non-ECC, un-buffered memory*
- AMD 7th Gen A-Series APUs support DDR4 2400/2133 ECC & non-ECC, un-buffered memory*
- Max. capacity of system memory: 32GB**
- 15μ Gold Contact in DIMM Slots[/td]
[/tr]
[tr]
[td]BIOS[/td]
[td]- 128Mb AMI UEFI Legal BIOS with GUI support
- Supports "Plug and Play"
- ACPI 5.1 compliance wake up events
- Supports jumperfree
- SMBIOS 2.3 support
- CPU, DRAM, PCH 1.05V, PROM 2.5V, Voltage Multi-adjustment[/td]
[/tr]
[tr]
[td]Graphics[/td]
[td]- Integrated AMD Radeon™ R-Series Graphics in A-series APU*
- DirectX 12, Pixel Shader 5.0
- Max. shared memory 2GB
- Supports 2 x HDMI with max. resolution up to 4K x 2K (4096x2160) @ 24Hz / (3840x2160) @ 30Hz
- Supports Auto Lip Sync, Deep Color (12bpc), xvYCC and HBR (High Bit Rate Audio) with HDMI Ports (Compliant HDMI monitor is required)
- Supports HDCP with HDMI Ports
- Supports Full HD 1080p Blu-ray (BD) playback with HDMI Ports[/td]
[/tr]
[tr]
[td]Audio[/td]
[td]- 7.1 CH HD Audio with Content Protection (Realtek ALC1220 Audio Codec)
- Premium Blu-ray Audio support
- Supports Surge Protection
- Nichicon Fine Gold Series Audio Caps
- 120dB SNR DAC with Differential Amplifier
- Pure Power-In
- Direct Drive Technology
- PCB Isolate Shielding
- Impedance Sensing on Line Out port
- Individual PCB Layers for R/L Audio Channel
- Gold Audio Jacks
- Supports Creative Sound Blaster™ Cinema 3[/td]
[/tr]
[tr]
[td]LAN[/td]
[td]- Gigabit LAN 10/100/1000 Mb/s
- GigaLAN Intel® I211AT
- Supports Wake-On-LAN
- Supports Lightning/ESD Protection
- Supports Energy Efficient Ethernet 802.3az
- Supports PXE[/td]
[/tr]
[tr]
[td]Wireless LAN[/td]
[td]- Intel® 802.11ac WiFi Module (Free Bundle)
- Supports IEEE 802.11a/b/g/n/ac
- Supports Dual-Band (2.4/5 GHz)
- Supports high speed wireless connections up to 433Mbps
- Supports Bluetooth 4.2 / 3.0 + High speed class II[/td]
[/tr]
[tr]
[td]Slots[/td]
[td]AMD Ryzen series CPUs
- 1 x PCI Express 3.0 x16 Slot (PCIE1: x16 mode)*
AMD 7th A-Series APUs
- 1 x PCI Express 3.0 x16 Slot (PCIE1: x8 mode)*
- 1 x Vertical M.2 Socket (Key E) with the bundled WiFi-802.11ac module (on the rear I/O)
*Supports NVMe SSD as boot disks[/td]
[/tr]
[tr]
[td]Storage[/td]
[td]- 4 x SATA3 6.0 Gb/s Connectors, support RAID (RAID 0, RAID 1 and RAID 10), NCQ, AHCI and Hot Plug
- 1 x Ultra M.2 Socket, supports M Key type 2280 M.2 SATA3 6.0 Gb/s module and M.2 PCI Express module up to Gen3 x4 (32 Gb/s) (with Ryzen Series CPU) or Gen3 x2 (16 Gb/s) (with A-Series APU)*
[/tr]
[tr]
[td]Connector[/td]
[td]- 1 x LPC Header
- 1 x AMD Fan LED Header
- 1 x CPU Fan Connector (4-pin)*
- 1 x Chassis Fan Connector (4-pin)
- 1 x Chassis Optional/Water Pump Fan Connector (4-pin) (Smart Fan Speed Control)*
- 1 x 24 pin ATX Power Connector
- 1 x 8 pin 12V Power Connector (Hi-Density Power Connector)
- 1 x Front Panel Audio Connector
- 1 x AMD LED Fan USB Header
- 1 x USB 2.0 Header (Supports 2 USB 2.0 ports) (Supports ESD Protection)
- 1 x USB 3.0 Header (Supports 2 USB 3.0 ports) (Supports ESD Protection)
*The CPU Fan Connector supports the CPU fan of maximum 1A (12W) fan power.
**The Chassis Optional/Water Pump Fan supports the water cooler fan of maximum 1.5A (18W) fan power.
CHA_FAN1/W_PUMP can auto detect if 3-pin or 4-pin fan is in use.[/td]
[/tr]
[tr]
[td]Rear Panel I/O[/td]
[td]- 2 x Antenna Ports
- 1 x PS/2 Mouse/Keyboard Port
- 2 x HDMI Ports
- 1 x Optical SPDIF Out Port
- 2 x USB 2.0 Ports (Supports ESD Protection)*
- 1 x USB 3.0 Type-A Port (Supports ESD Protection)
- 1 x USB 3.0 Type-C Port (Supports ESD Protection)
- 2 x USB 3.0 Ports (Supports ESD Protection)
- 1 x RJ-45 LAN Port with LED (ACT/LINK LED and SPEED LED)
- HD Audio Jacks: Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone (Gold Audio Jacks)[/td]
[/tr]
[tr]
[td]Software and UEFI[/td]
[td]Software
- ASRock F-Stream
- ASRock RGB LED
- ASRock Key Master
- ASRock APP Charger
- ASRock XFast LAN*
UEFI
- ASRock Full HD UEFI
- ASRock Instant Flash
- ASRock Internet Flash
- ASRock Crashless BIOS
- ASRock Easy RAID Installer[/td]
[/tr]
[tr]
[td]Support CD[/td]
[td]- Drivers, Utilities, AntiVirus Software (Trial Version), Google Chrome Browser and Toolbar[/td]
[/tr]
[tr]
[td]Accessories[/td]
[td]- Quick Installation Guide, Support CD, I/O Shield
- 2 x SATA Data Cables
- 2 x ASRock WiFi 2.4/5 GHz Antennas
- 1 x Screw for M.2 Socket[/td]
[/tr]
[tr]
[td]Hardware Monitor[/td]
[td]- Temperature Sensing: CPU, Chassis, Chassis Optional/Water Pump Fans
- Fan Tachometer: CPU, Chassis, Chassis Optional/Water Pump Fans
- Quiet Fan (Auto adjust chassis fan speed by CPU temperature): CPU, Chassis, Chassis Optional/Water Pump Fans
- Fan Multi-Speed Control: CPU, Chassis, Chassis Optional/Water Pump Fans
- Voltage monitoring: +12V, +5V, +3.3V, CPU Vcore[/td]
[/tr]
[tr]
[td]Form Factor[/td]
[td]- Mini-ITX Form Factor: 6.7-in x 6.7-in, 17.0 cm x 17.0 cm
- 2oz Copper PCB[/td]
[/tr]
[tr]
[td]OS[/td]
[td]- Microsoft® Windows® 10 64-bit
* For the updated Windows® 10 driver, please visit ASRock's website for details: http://www.asrock.com
[/td]
[/tr]
[tr]
[td]Certifications[/td]
[td]- FCC, CE
- ErP/EuP ready (ErP/EuP ready power supply is required)[/td]
[/tr]
[/table]
X370 Gaming-ITX
Code:
[tr]
[td]Power
Memory
VGA Card
Internet
- Intel® LAN
Cooling
- 2oz Copper PCB
Audio
[/tr]
[tr]
- Dual-N MOSFET
- Matte Black PCB
- 2oz Copper PCB
ASRock Steel Slots
[/tr]
[tr]
[td]CPU[/td]
- Digi Power design
[/tr]
[tr]
[td]Chipset[/td]
[td]- AMD Promontory X370[/td]
[/tr]
[tr]
[td]Memory[/td]
- AMD 7th Gen A-Series APUs support DDR4 2400/2133 ECC & non-ECC, un-buffered memory**
[/tr]
[tr]
[td]BIOS[/td]
[/tr]
[tr]
[td]Graphics[/td]
[/tr]
[tr]
[td]Audio[/td]
- Pure Power-In
- Gold Audio Jacks
[/tr]
[tr]
[td]LAN[/td]
- Supports PXE[/td]
[/tr]
[tr]
- Supports high speed wireless connections up to 867Mbps
- 2 antennas to support 2 (Transmit) x 2 (Receive) diversity technology
[/tr]
[tr]
[td]Slots[/td]
[/tr]
[tr]
[td]Storage[/td]
[/tr]
[tr]
[td]Connector[/td]
- 1 x Chassis Optional/Water Pump Fan Connector (4-pin) (Smart Fan Speed Control)**
[/tr]
[tr]
- 2 x HDMI Ports
[/tr]
[tr]
[td]Software
- ASRock F-Stream
- ASRock RGB LED
- ASRock Key Master
- ASRock XFast LAN*
UEFI
[/tr]
[tr]
[td]Support CD[/td]
[/tr]
[tr]
- 1 x ASRock WiFi 2.4/5 GHz Antenna
[/tr]
[tr]
[/tr]
[tr]
[/tr]
[tr]
[td]OS[/td]
[/td]
[/tr]
[tr]
[td]- FCC, CE
[/tr]
[/table]
Preisvergleich
AB350 Gaming-ITX/ac: ASRock Fatal1ty AB350 Gaming-ITX/ac Preisvergleich geizhals.eu EU
X370 Gaming-ITX/ac: ASRock Fatal1ty X370 Gaming-ITX/ac Preisvergleich geizhals.eu EU
Fragen und Antworten:
- Was ist der Unterschied zwischen dem AB350 und X370?
Da ein ITX Board nicht die kompletten Vorteile von X370 nützen kann, unterscheiden sich die beiden nur gering. Das X370 hat schnelleres WLAN und erlaubt PCIe Bifurcation
edit 17.8.2017: Die beiden haben nun doch andere VRM Komponenten, wie br0da herausgefunden hat:
FDPC5030 = AB350; SM7341EH = X370
ASRocks X370 und B350 mini-ITX unterscheidet doch mehr, als der Kühlkörper (anfangs): VRM on the new AM4 motherboards - Page 251
Die FETs im Vergleich:
RDS(on) maxRise + Fall Time FDPC5030 Q1:
5.0 mOhm @ VGS = 10 V @ ID = 17A
6.5 mOhm @ VGS = 4.5V @ ID = 14 A
Q2:
2.4 mOhm @ VGS = 10V @ ID = 25 A
3.0 mOhm @ VGS = 4.5V @ ID = 22 AQ1: 20ns
Q2: 20nsSM7341EH Q1:
3.9mOhm @ VGS = 10V @ ID = 24A
6.5mOhm @ VGS = 4.5V @ ID = 24A
Q2:
1.2mOhm @ VGS =10V @ ID = 24A
2mOhm @ VGS =4.5V @ ID = 24AQ1: 18.6ns
Q2: 39ns
- Wie unterschieden sich die VRM Kühler?
alt: https://abload.de/img/img_15572ssdc.jpg
neu: https://abload.de/img/fullsizerenderfaujg.jpg
- Ich habe noch den alten VRM-Kühler, was kann ich tun?
Schreibt den Asrock Support an! Der Support will danach noch eine Rechnung und die Seriennummer vom Board.
ASRock > Support Request Form
- Welchen RAM habt ihr getestet?
Dazu habe ich ein 16GB Trident Z 3200MHz CL14 Kit. F4-3200C14D-16GTZ
Mit den XMP Profil konnte ich den Ram nicht starten. Wenn ich jedoch die Spannung auf 1.4V erhöhe, die command rate auf 1T setze, Geardown Mode und BankGroupSwap deaktiviere, dann läuft er und es gab nach 2 Stunden Memtest64 keine Fehler.
Als RAM habe ich Kingston KVR21E15D8K2/16I
Corsair CMK16GX4M2A2400C14 funktioniert ebenfalls einwandfrei, ist direkt mit 2400Mhz gestartet.
Aber ne kleine Info, ich habe diesen RAM hier beim Kollegen auf einen AB350 am Laufen:
GWW416GB3000C15DC
Dieser hat Samsung D-Die und ist Dualranked. Er läuft auf 3000Mhz mit 15-17-17-35 bei 1,35v, das läuft tadellos. Haben gestern was probiert und sind am Ende bei 1,35v auf 3200mhz bei 17-19-19-38 gekommen. Dualranked sollte er so schnell sein wie 3400-3500er Singlerank.
RAM Kompatibilität
Asrock gibt folgenden Arbeitsspeicher auf der Homepage an (Update 7.10.2017; 27 neue Einträge):
Code:
DDR4 3000 4GB ADATA KM4B4GX2A-3000-15-16-16-36-0 SS 2pcs v
DDR4 2800 16GB ADATA AX4U2800316G16 SS 2pcs
DDR4 2400 8GB ADATA AX4U2400W8G16-SRD DS 2pcs
DDR4 2400 8GB ADATA AX4U2400W8G16-QRD DS 2pcs
DDR4 2400 8GB ADATA AX4U2400316G16-BBF DS 2pcs
DDR4 2400 8GB ADATA AX4U2400W8G16-BRD DS 2pcs
DDR4 2400 8GB ADATA AX4U2400W8G16-QWZ DS 2pcs
DDR4 2400 8GB ADATA AX4U2400W8G16-QRZ DS 2pcs
DDR4 2400 8GB ADATA AX4U2400W8G16-DWZ DS 2pcs
DDR4 2400 8GB ADATA AX4U2400W8G16-BRZ DS 2pcs
DDR4 2400 8GB ADATA AX4U2400W8G16-BBZ DS 2pcs
DDR4 2400 8GB ADATA AX4U2400W8G16-BWZ DS 2pcs
DDR4 2400 8GB ADATA AX4U2400W8G16-DRD SS 2pcs
DDR4 2400 8GB ADATA AX4U2400W8G16-DRZ DS 2pcs
DDR4 2400 4GB ADATA AX4U2400W4G16-DRZ SS 2pcs
DDR4 2400 4GB ADATA AX4U2400W4G16-SBF SS 2pcs
DDR4 2400 4GB ADATA AX4U2400W4G16-BBF SS 2pcs
DDR4 2400 4GB ADATA AX4U2400W4G16-BWZ SS 2pcs
DDR4 2400 4GB ADATA AX4U2400W4G16-QWZ SS 2pcs
DDR4 2400 4GB ADATA AX4U2400W4G16-BBZ SS 2pcs
DDR4 2400 4GB ADATA AX4U2400W4G16-BRZ SS 2pcs
DDR4 2400 4GB ADATA AX4U2400W4G16-DWZ SS 2pcs
DDR4 2400 4GB ADATA AX4U2400W4G16-SWZ SS 2pcs
DDR4 2400 4GB ADATA AX4U2400W4G16-QRZ SS 2pcs
DDR4 2400 4GB ADATA AX4U2400W4G16-SRZ SS 2pcs
DDR4 2400 16GB ADATA AX4U2400316G16-QRZ DS 2pcs
DDR4 2400 16GB ADATA AX4U2400316G16-QWZ DS 2pcs
DDR4 2400 16GB ADATA AX4U2400316G16-SRZ DS 2pcs
DDR4 2400 16GB ADATA AX4U2400316G16-BRZ ADATA DS 2pcs
DDR4 2400 16GB ADATA AX4U2400316G16-DWZ DS 2pcs
DDR4 2400 16GB ADATA AX4U2400316G16-SBF DS 2pcs
DDR4 2400 16GB ADATA AX4U2400316G16-SWZ DS 2pcs
DDR4 2400 16GB ADATA AX4U2400316G16-QRD DS 2pcs
DDR4 2400 16GB ADATA AX4U2400316G16-DRD DS 2pcs
DDR4 2400 16GB ADATA AX4U2400316G16-SRD DS 2pcs
DDR4 2400 16GB ADATA AX4U2400316G16-BWZ SS 2pcs
DDR4 2400 16GB ADATA AX4U2400316G16-BRD SS 2pcs
DDR4 2400 16GB ADATA AX4U2400316G16-DRZ DS 2pcs
DDR4 2133 8GB ADATA AD4E2133W8G15-BHYA (ECC) SS 2pcs
DDR4 2400 8GB Apacer AU08GGB24CEYBGC SS 2pcs
DDR4 2133 8GB Apacer 78.C1GM3.AF10B Hynix DS 2pcs
DDR4 3000 8GB Avexir AVD4UZ130001608G-4BZ1RR SS 2pcs v
DDR4 2400 8GB Avexir AVD4UZ124001608G-1COR SS 2pcs
DDR4 2400 4GB Avexir AVD4UZ124001604G-1COB SS 2pcs
DDR4 3000 8GB Corsair CMD32GX4M4B3000C15 (Hynix-M) SS 2pcs v
DDR4 2800 8GB Corsair CMK32GX4M4A2800C16 DS 2pcs
DDR4 2800 8GB Corsair CMD32GX4M4A2800C16 DS 2pcs
DDR4 2800 4GB Corsair CMD16GX4M4A2800C16 SS 2pcs
DDR4 2666 8GB Corsair CMD32GX4M4A2666C15 ver4.23 DS 2pcs
DDR4 2666 8GB Corsair CMD32GX4M4A2666C16 DS 2pcs
DDR4 2666 8GB Corsair CMK32GX4M4A2666C16 DS 2pcs
DDR4 2666 8GB Corsair CMK32GX4M4A2666C16 ver 5.30 SS 2pcs
DDR4 2666 4GB Corsair CMD16GX4M4A2666C15 SS 2pcs
DDR4 2666 4GB Corsair CMK16GX4M4A2666C16 SS 2pcs
DDR4 2666 4GB Corsair CMD16GX4M4A2666C16 SS 2pcs
DDR4 2400 8GB Corsair CMK32GX4M2A2400C14 SS 2pcs
DDR4 2133 4GB Corsair CMV4GX4M1A2133C15 SS 2pcs
DDR4 2666 8GB Crucial BLT8G4D26AFTA.16FAD SS 2pcs
DDR4 2666 4GB Crucial BLE4G4D26AFEA.8FAD SS 2pcs
DDR4 2400 8GB Crucial CT8G4WFD824A.18FB1 (ECC) SS 2pcs
DDR4 2133 8GB Crucial CT8G4DFS8213.8FB1 SS 2pcs
DDR4 2133 8GB Crucial CT8G4DFD8213.16FA2 SS 2pcs
DDR4 2133 8GB Crucial CT8G4DFD8213.C16FAD11 SS 2pcs
DDR4 2133 4GB Crucial CT4G4DFS8213.8FA1 SS 2pcs
DDR4 2133 16GB Crucial CT16G4DFD8213.16FB1 SS 2pcs
DDR4 3066 8GB G.Skill F4-4133C19D-16GTZKWC SS 2pcs v
DDR4 3066 8GB G.Skill F4-4000C18D-16GTZR SS 2pcs v
DDR4 3000 4GB G.Skill F4-3000C15Q-16GRR SS 2pcs v
DDR4 2933 8GB G.Skill F4-3200C16D-16GTZB SS 2pcs v
DDR4 2933 8GB G.Skill F4-4266C19D-16GTZR SS 2pcs v
DDR4 2933 8GB G.Skill F4-3466C16D-16GTZSK SS 2pcs v
DDR4 2933 16GB G.Skill F4-3333C16D-32GTZSK DS 2pcs v
DDR4 2933 16GB G.Skill F4-3200C14D-32GTZR DS 2pcs v
DDR4 2933 16GB G.Skill F4-3866C18D-32GTZR DS 2pcs v
DDR4 2933 16GB G.Skill F4-3200C15D-32GTZR DS 2pcs v
DDR4 2400 8GB G.Skill F4-2400C16D-16GFXR SS 2pcs
DDR4 2400 8GB G.Skill F4-2400C15D-16GFX SS 2pcs
DDR4 2400 8GB G.Skill F4-2400C15D-16GFXR SS 2pcs
DDR4 2400 8GB G.Skill F4-2400C15D-16GFT SS 2pcs
DDR4 2400 8GB G.Skill F4-2400C16D-16GFX SS 2pcs
DDR4 2400 8GB G.Skill F4-2400C15D-16GBTZR SS 2pcs
DDR4 2400 8GB G.Skill F4-2400C16D-16GFT SS 2pcs
DDR4 2400 4GB G.Skill F4-2400C15D-8GFT SS 2pcs
DDR4 2400 4GB G.Skill F4-2400C16D-8GFT SS 2pcs
DDR4 2400 4GB G.Skill F4-2400C16D-8GFXR SS 2pcs
DDR4 2400 4GB G.Skill F4-2400C16D-8GFX SS 2pcs
DDR4 2400 4GB G.Skill F4-2400C15D-8GFXR SS 2pcs
DDR4 2400 4GB G.Skill F4-2400C15D-8GFX SS 2pcs
DDR4 2400 16GB G.Skill F4-2400C16D-32GFXR DS 2pcs
DDR4 2400 16GB G.Skill F4-2400C16D-32GFT DS 2pcs
DDR4 2400 16GB G.Skill F4-2400C15D-32GFX DS 2pcs
DDR4 2400 16GB G.Skill F4-2400C15D-32GFXR DS 2pcs
DDR4 2400 16GB G.Skill F4-2400C16D-32GFX DS 2pcs
DDR4 2400 16GB G.Skill F4-2400C15D-32GFT DS 2pcs
DDR4 2133 8GB G.Skill F4-2133C15D-16GFT SS 2pcs
DDR4 2133 8GB G.Skill F4-2133C15D-16GFXR SS 2pcs
DDR4 2133 8GB G.Skill F4-2133C15D-16GFX SS 2pcs
DDR4 2133 4GB G.Skill F4-2133C15D-8GFX SS 2pcs
DDR4 2133 4GB G.Skill F4-2133C15D-8GFXR SS 2pcs
DDR4 2133 4GB G.Skill F4-2133C15D-8GFT SS 2pcs
DDR4 2133 16GB G.Skill F4-2133C15D-32GFX DS 2pcs
DDR4 2133 16GB G.Skill F4-2133C15D-32GFT DS 2pcs
DDR4 2133 16GB G.Skill F4-2133C15D-32GFXR DS 2pcs
DDR4 2400 4GB Geil GWB48GB2400C14DC SS 2pcs
DDR4 2133 8GB Geil GP48GB2133C15SC SS 2pcs
DDR4 2666 8GB HyperX HX426C15FB/8 DS 2pcs
DDR4 2666 8GB HyperX HX426C13SB2K4/32 DS 2pcs
DDR4 2666 8GB HyperX HX426C13PB3/8 Hynix M-die SS 2pcs
DDR4 2666 8GB HyperX HX426C13PB3K4/32 Hynix M-die SS 2pcs
DDR4 2666 8GB HyperX HX426C13PB3K2/16 Hynix M-die SS 2pcs
DDR4 2666 16GB HyperX HX426C13PB3/16 Hynix M-die DS 2pcs
DDR4 2666 16GB HyperX HX426C13PB3K2/32 Hynix M-die DS 2pcs
DDR4 2666 16GB HyperX HX426C13PB3K4/64 Hynix M-die DS 2pcs
DDR4 2400 8GB HyperX HX424C15FB2K4/32 SS 2pcs
DDR4 2400 8GB HyperX HX424C12PB3K4/32 Hynix M-die SS 2pcs
DDR4 2400 8GB HyperX HX424C12PB3K2/16 Hynix M-die SS 2pcs
DDR4 2400 8GB HyperX HX424C12PB3/8 Hynix M-die SS 2pcs
DDR4 2400 4GB HyperX HX424C15FBK4/16 SS 2pcs
DDR4 2400 16GB HyperX HX424C15FBK4/64 DS 2pcs
DDR4 2400 16GB HyperX HX424C12PB3K2/32 Hynix M-die DS 2pcs
DDR4 2400 16GB HyperX HX424C12PB3/16 Hynix M-die DS 2pcs
DDR4 2133 8GB HyperX HX421C14FB2K4/32 SS 2pcs
DDR4 2133 8GB HyperX HX421C14FB/8 DS 2pcs
DDR4 2400 8GB J&A JAD4U24001608-8M SS 2pcs
DDR4 2400 4GB J&A JAD4U24001608-4M SS 2pcs
DDR4 2133 4GB J&A JAD4U21331508-4M SS 2pcs
DDR4 2666 8GB Kingston KVR26N19S8/8 Micron D-die SS 2pcs
DDR4 2666 8GB Kingston KVR26N19S8/8 Micron H-die SS 2pcs
DDR4 2666 16GB Kingston KVR26N19D8/16 Micron D-die DS 2pcs
DDR4 2666 16GB Kingston KVR26N19D8/16 Micron H-die DS 2pcs
DDR4 2400 8GB Kingston KVR24N17S8/8 SS 2pcs
DDR4 2400 8GB Kingston HX424C15FBK4/32 SS 2pcs
DDR4 2400 8GB Kingston HX424C15FB2/8 SS 2pcs
DDR4 2400 4GB Kingston KVR24N17S8/4 Micron SS 2pcs
DDR4 2133 8GB Kingston KVR21N15S8/8 SS 2pcs
DDR4 2133 8GB Kingston KVR21N15D8/8 DS 2pcs
DDR4 2133 4GB Kingston KVR21N15S8/4 SS 2pcs
DDR4 2133 16GB Kingston KVR21N15D8/16 DS 2pcs
DDR4 3000 8GB KLEVV IM44GU88A30-FGGHMZ SS 2pcs v
DDR4 3000 8GB KLEVV IM44GU88A30-FGGHMB SS 2pcs v
DDR4 3000 4GB KLEVV IM44GU48A30-GIIHMC SS 2pcs v
DDR4 3000 4GB KLEVV KM4Z4GX1A-3000-15-16-16-36-1 SS 2pcs v
DDR4 3000 4GB KLEVV KM4B4GX1A-3000-15-16-16-36-0 SS 2pcs v
DDR4 3000 4GB KLEVV KM4Z4GX2A-3000-15-16-16-36-1 SS 2pcs v
DDR4 2666 8GB KLEVV KM4Z8GX1N-2666-15-15-15-35-1 SS 2pcs
DDR4 2666 8GB KLEVV KM4Z8GX2N-2666-15-15-15-35-1 SS 2pcs
DDR4 2666 4GB KLEVV KM4Z4GX2N-2666-15-15-15-35-1 SS 2pcs
DDR4 2666 4GB KLEVV KM4Z4GX1N-2666-15-15-15-35-1 SS 2pcs
DDR4 2666 16GB KLEVV KM4Z16X1N-2666-15-15-15-35-0 DS 2pcs
DDR4 2666 16GB KLEVV KM4Z16X2N-2666-15-15-15-35-0 DS 2pcs
DDR4 2400 8GB KLEVV KM4Z8GX2N-2400-15-15-15-35-1 SS 2pcs
DDR4 2400 8GB KLEVV KM4Z8GX1N-2400-15-15-15-35-1 SS 2pcs
DDR4 2400 4GB KLEVV KM4Z4GX2N-2400-15-15-15-35-1 SS 2pcs
DDR4 2400 4GB KLEVV KM4Z4GX1N-2400-15-15-15-35-1 SS 2pcs
DDR4 2400 16GB KLEVV KM4Z16X2N-2400-15-15-15-35-0 DS 2pcs
DDR4 2400 16GB KLEVV KM4Z16X1N-2400-15-15-15-35-0 DS 2pcs
DDR4 2133 8GB KLEVV IMA41GU6MFR8N-TF1 SS 2pcs
DDR4 3000 8GB Neo Forza NFMUD480E8-3000DH2A SS 2pcs
DDR4 2800 4GB Panram PUD42800C164G4NJW SS 2pcs
DDR4 2666 8GB Panram W4U2666PS-8G SS 2pcs
DDR4 2666 16GB Panram W4U2666PS-16G DS 2pcs
DDR4 2400 8GB Panram PUD42400C158G4NJW DS 2pcs
DDR4 2400 8GB Panram W4U2400PS-8G SS 2pcs
DDR4 2133 8GB Panram W4U2133PS-8G SS 2pcs
DDR4 3333 8GB Patriot PV416G340C6K (11BF2) SS 2pcs v
DDR4 3333 4GB Patriot PV48G340C6K (11E2) SS 2pcs v
DDR4 3333 4GB Patriot PV48G360C7K (11E1) SS 2pcs v
DDR4 3200 8GB Patriot PV416G360C7K (11BF1) SS 2pcs v
DDR4 3200 8GB Patriot PV416G320C6K (11BF2) SS 2pcs v
DDR4 3200 4GB Patriot PV48G320C6K (11EC2) SS 2pcs v
DDR4 3200 4GB Patriot PV48G320C6K (11D1) Samsung 11D1 SS 2pcs v
DDR4 3000 4GB Patriot PV48G300C6K (14M1) SS 2pcs v
DDR4 2933 8GB Patriot PV416G300C6K (11BF2) SS 2pcs v
DDR4 2933 4GB Patriot PV48G300C6K (11EC2) SS 2pcs v
DDR4 2400 8GB Patriot PSD48G240081 SS 2pcs
DDR4 2400 8GB Patriot PVE416G240C5KRD (11BF2) SS 2pcs
DDR4 2400 4GB Patriot PSD44G240081 SS 2pcs
DDR4 2400 4GB Patriot PVE48G240C5KRD (11EC2) SS 2pcs
DDR4 2400 16GB Patriot PSD416G24002 DS 2pcs
DDR4 2133 8GB Patriot PSD48G21332 SS 2pcs
DDR4 2133 4GB Patriot PSD44G213381 SS 2pcs
DDR4 2400 4GB Samsung M378A5244CB0-CRC SS 2pcs
DDR4 2133 8GB Samsung M378A5143DB0-CPB SS 2pcs
DDR4 2133 8GB Samsung M391A1G43EB1-CPBQ (ECC) SS 2pcs
DDR4 2133 4GB Samsung M378A5143EB1-CPB SS 2pcs
DDR4 2133 4GB Samsung M378A1G43DB0-CPB SS 2pcs
DDR4 2133 8GB Silicon Power SP008GBLFU213N01 SS 2pcs
DDR4 2666 8GB Team TFWD48G2666C15BBK SS 2pcs
DDR4 2400 8GB Team TED48G2400C16BK SS 2pcs
DDR4 2400 4GB Team TED44G2400C16BK SS 2pcs
DDR4 2133 8GB Transcend TS1GLH64V1H DS 2pcs
DDR4 2400 8GB UMAX 84G48GA3SP-24MSPGNGFY7B SS 2pcs
DDR4 2400 8GB UMAX 84G48GA3CP-241MCALGFY7J1 SS 2pcs
DDR4 2400 16GB UMAX 84G416A3CP-241MCGNGFY7B DS 2pcs
DDR4 2400 16GB UMAX 84G416A3CP-241MCGNGFY7J1 DS 2pcs
DDR4 2133 8GB UMAX RMUM8GD42131024 SS 2pcs
DDR4 2133 8GB UMAX RMUM8GD42133512 SS 2pcs
DDR4 2133 4GB UMAX RMUM4GD421333512 SS 2pcs
DDR4 2133 4GB UMAX RMUM4GD42133512 SS 2pcs
DDR4 2400 8GB V-Color TD8G16C17-UH DS 2pcs
DDR4 2400 8GB V-Color TC48G24S817 SS 2pcs
DDR4 2133 8GB V-Color TC48G21S815-iMS SS 2pcs
DDR4 2133 8GB V-Color TD8G8C15-093E SS 2pcs
Berichte & Reviews
https://smallformfactor.net/reviews/motherboards/fatal1ty-asrocks-x370-ab350-gaming-itxac-motherboards-reviewed
deutsches Video-Review: ASRock Fatal1ty AB350 Gaming-ITX/ac - Quick Review - YouTube
16.03.2018 - Aktuell gibt es einen Bug mit den Raven Ridge CPUs die bei WLAN Nutzung zur Instabilität führen. Dazu solltet ihr mal einen Blick in die Beta BIOS werfen. (4.51A)
Links zu den neusten BIOS Versionen findet ihr hier:
AB350: ASRock > Fatal1ty AB350 Gaming-ITX/ac
X370: ASRock > Fatal1ty X370 Gaming-ITX/ac
Wer noch eine ältere Version nutzt und auf 4.0 oder höher möchte, bitte das Bridge BIOS nicht vergessen.
Eine Windows-Neuinstallation ist wahrscheinlich nun am Besten, weil der PC ja immer einfriert oder was meint ihr? Würde eventuell auch diese Reparatur-Option im Setup ausreichen?
