[Sammelthread] ASUS ROG Maximus IX Apex - The New Hardcore (Z270)
--- Produktseite | PDF-Handbuch | Preisvergleich ---
388055d1484583484-intel-union-point-mainboards-ft-200-series-chipset-news-reviews-specs-bilder-1561949-1.jpg
Spezifikationen
CPUIntel® for 7th/6th Generation Core i7 / i5 / i3 / Pentium / Celeron Processors
Supports Intel 14 nm CPU
* The Intel Turbo Boost Technology 2.0 support depends on the CPU types.
ChipsetIntel Z270
Memory2x DDR4, Non-ECC, Un-buffered DIMM, max. 32GB**
DDR4 4266/4133/4000/3866/3800/3733/3600/3500/3466/3400/3333/3300/3200/3000/2800/2666/2400(O.C.)/2133 MHz
* Hyper DIMM support is subject to the physical characteristics of individual CPUs.
** Anm. d. Verf.: bzw 64GB, sobald 16Gbit DDR4 ICs verfügbar sind
GraphicIntegrated Graphics Processor HD Graphics support
Multi-Monitor support : HDMI/DisplayPort ports
- HDMI 1.4b (up to 4096 x 2160 @ 24 Hz)
- DisplayPort 1.2 (up to 4096 x 2304 @ 60 Hz)
Maximum shared memory of 1024 MB
Multi-GPU Support (2-Way SLI, Quad-GPU SLI, 2-Way & 4-Way CrossfireX)
Expansion Slots2 x PCIe 3.0/2.0 x16 (x16 or dual x8)
1 x PCIe 3.0/2.0 x16 (max at x4 mode)
2 x PCIe 3.0/2.0 x1
StorageIntel® Z270 Chipset :
Supports Intel Smart Response, Rapid Start , Smart Connect
Support Raid 0, 1, 5, 10
Intel Optane Memory Ready
LANIntel® I219V, 1 x Gigabit LAN Controller(s)
ASUS LAN Guard
Dual interconnect between the integrated Media Access Controller (MAC) and physical layer (PHY)
AudioROG SupremeFX 8-Channel High Definition Audio CODEC S1220A
- Impedance sense for front and rear headphone outputs
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
- ESS ES9023P
- SupremeFX Shielding Technology
- Optical S/PDIF out port(s) at back panel
USB PortsIntel Z270 Chipset :
8 x USB 3.0 port(s)
6 x USB 2.0 port(s)
ASMedia USB 3.1 controller :
2 x USB 3.1 port(s) (2 at back panel, Type-A + Type-C)
ROG Exclusive FeaturesROG RAMCache II
ROG CPU-Z
ROG CloneDrive
MemOK! Button
Slow Mode
CMOS button
Overwolf
ReTry Button
Safe Boot Button
Start Button
Reset Button
LN2 Mode
ROG Aura
- Aura Lighting Control
- Aura RGB Strip Headers
Extreme Engine Digi+ :
- MicroFine Alloy Chokes
- NexFET Power Block MOSFET
- 10K Black Metallic Capacitors
Mem TweakIt
UEFI BIOS features :
Special Features
5-Way Optimization by Dual Intelligent Processors 5
SafeDIMM slot
AURA :
- Aura Lighting Effects Synchronization with compatible ASUS ROG devices
ASUS Exclusive Features- MemOK!
- AI Suite 3
- Anti-Surge
ASUS EZ DIY :
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 3
- ASUS USB BIOS Flashback
- ASUS UEFI BIOS EZ Mode
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Code
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-Connector
Gaming Aesthetics :
- 3D printing friendly
- AURA-RGB Lighting
Performance Optimization :
- Fan Xpert 4 featuring Fan Auto Tuning function and multiple thermistors selection for optimized system cooling control
Back I/O Ports1 x PS/2 keyboard (purple)
1x PS/2 mouse (green)
1x DisplayPort
1x HDMI
1x LAN (RJ45) port(s)
2x USB 3.1 (Type-A + Type-C)
6x USB 3.0
1x Optical S/PDIF out
1x Clear CMOS button(s)
1x USB BIOS Flashback Button(s)
5x Gold-plated audio jacks
Internal I/O Ports1x AAFP
2x RGB Header(s)
1x USB 3.0
3x USB 2.0
4x SATA 6Gb/s
1x CPU Fan
1x CPU OPT Fan
3x Chassis Fan
1x W_PUMP+
1x AIO_PUMP
1x W_Pump+ Header
1x AIO PUMP Header
1x W_IN header
1x W_OUT header
1x W_FLOW header
2x Thermal sensor connector
1x 24-pin EATX Power
2x 8-pin ATX 12V Power
1x EZ Plug connector(s) (4-pin Molex)
1x LN2 Mode switch(es)
1x LN2 Mode jumper(s)
1x Slow Mode switch(es)
1x Slow Mode jumper(s)
1x Reset button(s)
1x BIOS Switch button(s)
1x Safe Boot button
1x ReTry button
1x Start button
1x 14-1 pin TPM
1x 3D Mount screw port(s)
AccessoriesUser's manual
I/O Shield
2 x SATA 6Gb/s cable(s)
1 x SLI HB BRIDGE(2-WAY-L)
1 x Q-Connector
1 x DIMM.2 extension card with 2 x M key (2242/2260/2280/22110, SATA & PCIE 3.0 x 4 mode)
1 x ROG coasters
Operating SystemWindows 10 64-bit
Windows 8.1 64-bit
Windows 7 32-bit
Windows 7 64-bit
Form FactorExtended ATX Form Factor
12 inch x 10.7 inch ( 30.5 cm x 27.2 cm )
Special Features
ASUS Dimm.2 - Dual M.2 Mount Add-On Card
The DIMM.2 module has an exclusive design that accepts two M.2 drives vertically-mounted on a DDR4 interface. This allows a DRAM fan cooler to direct air towards the M.2 drives to prevent throttling.
BIOS
Bilder
Inoffizielle BIOS Versionen u.a. für Extrem-OC (Achtung: Nutzung auf eigene Gefahr!)
  • 0009 (for IGPU benching, higher voltage limits without LN2 Mode)
  • 0023 (0801 with USB over-current detection disabled)
  • 0026 (very early release)
  • 0088 (might fix CBB issues with CPU RSVD switch, BIOS behaves differently during POST with B-die + high voltage)
  • 0091 (0088 + updated Microcode for Core i3-7350K)
  • 0701 (recommended for general use)
News & Reviews
Hardwareluxx CPU-Kühler & RAM-Kompatibilitätsliste
1) CPU-Kühler
2) RAM
ASUS Memory QVL (PDF).​
Wer mir die Arbeit abnehmen möchte, kann seinen Eintrag gern direkt in diesem Format posten. Danke.​
Nützliche Links & Tipps (im Forum & im WWW)
1) Hardwareluxx
2) WWW (international)
3) Tips & Tricks
4) FAQ - Frequently Asked Questions
  • --> Deine Frage hier!
  • Q: Wie sind die Lüfter und Pumpenanschlüsse konfiguriert? Was ist die maximale Belastbarkeit pro Anschluss?
  • A: Die regulären Lüfteranschlüsse lassen manuell als PWM oder per Spannung geregelt konfigurieren. Die Belastbarkeiten im Überblick:
  • Q: Wie sind die PCI Express Slots angebunden?
  • A:
  • Q: Wo finde ich auf dem Board XYZ?
  • A: (zum vergrößern auf die Grafik klicken)
  • Q: Aus welchen Komponenten besteht und wie leistungsfähig ist das VRM des Apex?
  • A: Es handelt sich um eine 8+2 [2*4(CPU) + 2(iGFX)] & [+ 1(SA) + 1(IO)] Implementierung, mit einem digitalen IR IR35201/3 PWM Controller und zehn TI NexFET PowerBlocks vom Typ 87350D mit einem Rating von bis zu 40A pro Phase für CPU und iGFX.
    (Mosfets für SA/IO sind OnSemi NTMFS4C06B)
  • Q: Wie kann ich den Startvorgang des System beschleunigen?
  • A: Ich habe den Startvorgang bis zum Desktop mit dem M8G mit folgenden Einstellungen auf unter 10s reduzieren können. Diese scheinen analog auch für das Apex wirksam zu sein.
    Code:
    MRC Fast Boost [Enabled] [color=red]Vorher unbedingt die Speichereinstellungen auf Stabilität testen, da das Speicherretraining damit deaktiviert wird![/Color]
    MCH Full Check [Disabled]
    PCH Storage configuration Smart self test [Disabled]
    CSM [Disabled] [color=red]Nur wenn ihr euer OS im UEFI Modus installiert habt.[/Color]
    Option ROM Messages [Disabled]
    Fast Boot [Enabled]
    POST delay time [0]
    Boot Logo [AUTO] oder [Full Screen]
  • Q: Kann man auf dem Maximus IX Apex Coffee Lake Prozessoren verwenden?
  • A: Offiziell ist dies von Intel nicht vorgesehen, es gibt aber einen relativ simplen Hardware+BIOS Mod, der dies ermöglicht. Dies wurde so auch schon von einigen Seiten wie hier Intel Core I9-9900K & Z270! @ overclockers.ru getestet. The_patchelor hat dazu eine Anleitung erstellt:
    APEX IX Coffeelake Mod
    Ohne zusätzliche Modifikationen an der CPU (weder SKT_OCC noch 2 Punkte isolieren) ;) nur Mainboard Mod notwendig.
    So hab ich es gemacht, Bilder sind von mir:
    die 2 Mods
    1x CPU Paqd Mod (SKT_OCC brücken)
    1x Bios brücken (löten, Silberleitlack, Bleistift oder einfach nur kurzschließen) damit wohl das "fremde" Bios drauf kann
    hier der Link zur Quelle
    jAlex@ro hat ein IX Bios aufgebohrt (XP geht damit)
    0084v2 (wohl ohne HT)
    jjxaker hat das Board quasi in ein X verwandelt (XP geht nicht)
    1602 mit HT
    Bios UPDATE
    Base: Asus Maximus X Apex for Maximus IX Apex@BIOS MOD 1602
    Support CPU: Skylake/Kaby Lake/Coffee Lake
    Latest Bios Microcode:
    Intel CPU SKL 0xC6, KBL 0x8E, CFL 8 Core 0x96 / 6 Core 0x96 / 4 Core 0x8E.
    Intel EFI RST 16.5.0.3492
    Intel VBIOS 1059/GOP 9.0.1080
    Intel Lan UNDI 0.0.19/Lan OROM 0.1.13/Lan GBE 0.5
    Intel ME Firmware 11.7.0.1129
    All Region DESC/ME/BIOS Unlock.
    All components of the board are working. including RGB Light, on-board graphics card, HT, PCI-e.
    To MOD flash through the ISP programmer or HW MOD USB Bios Flashback.
    Habe das 1602 einfach per USB Bios Flashback drauf gepackt. Beim ersten Start dreht das Bios 2 Runden und aktualisiert sich, dann habe ich noch den nicht vorhandenen 5G LAN Anschluss deaktiviert. Um das gemoddete 1602 downloaden zu können, müsst ihr im HWBOT Forum eingelogged sein.
    Hinweis zum Bios Flashback: Das Bios überschreibt euch die MAC, UUID und MB Serial.
    Lösung:
    -mit altem Bios zuvor oder mit Bios2 booten (SL oder KL CPU erforderlich...)
    -Universal Bios Backup Toolkit 2.0 suchen und downloaden (als Admin ausführen, Viruswarnung ignorieren... am besten mit einem temp. Windows arbeiten..)
    -Bios auslesen und abspeichern
    -FD44Editor verwenden um die MAC, UUID und Motherboard S/N auszulesen (vom backupBios)
    -1602 creative.rom auch mit FD44Editor öffnen und die Werte eintragen und abspeichern
    hier werden die Werte aus dem alten ins neue eingetragen...
    wieder als creative.rom speichern und auf einen USB Stick packen. BIOS wieder auf 1 umstellen und das korrigierte "persönliche" BIOS per USB Flashback laden
5) ASUS ROG Wallpaper
6) Wasserkühler (Mainboard)
WORK IN PROGRESS :angel:
So, nachdem ich jetzt noch mal ein paar Stunden investiert habe, ist dass Apex echt on Fire: DDR4-4333 bootet.
Die Trident Z RGB DDR4-4266 sind in Kombination mit dem Apex einfach unfassbar zickig. Auf anderen ASRock Z270 Boards ist es kein Problem...
Die RGB brauchen vielleicht etwas relaxtere Timings als die Non-RGB Trident Z B-Die, sollten aber nicht schlechter als deine E-Die laufen (hab keine hier für einen direkten Vergleich).
So, hab heute mal die neuen Corsair Vengeance LPX DDR4-4400 CL19 (CMK16GX4M2F4400C19) auf das Apex geworfen.
Mehr als DDR4-4360 CL19-19-19-39 packe ich aktuell nicht, scheinbar macht hier die CPU dicht.
Dennoch bin ich damit echt zufrieden. Mit dem richtigen Speicher kann das Apex auch was. :fresse2:
Kann man das auch fühlen Oder nur messen in benchmarks?
Sent from my XT1562 using Tapatalk
Für Benchmarks fährt man am besten 12-12-12 oder 12-11-11 Timings bei 2000-2100MHz Ramtakt.
CL19 ist was für Max Ramtakt, aber dafür sollte man nur einen Riegel im System haben.
Hi Leute!
Ich habe seit einigen Tagen das Board und habe leider ein Problem mit dem RAM OC.
Mein Ram ist ein G.Skill 2x8GB 4.266mhz 19-19-19-39 bei 1,4V
Leider schaffe ich es nicht den RAM merklich über 2.133mhz zu takten, wenn ich es versuche leuchtet die weiße led am board auf. Passiert beim XMP Profil als auch bei manuellem hochtakten. VCCIO und SA hab ich auch schon angehoben, hat nichts gebracht. In den DRAM Tminings Mode 2 aktiviert, hat auch nichts gebracht. Bei meinem alten Board, ein Z170A Gaming Pro Carbon lief der Speicher immerhin auf 3.600mhz. Hab auch schon die Riegel einzeln getestet, macht aber keinen Unterschied.
Ich weiß echt nicht mehr weiter und kann mir nicht erklären warum der RAM sich nicht übertakten lässt.
Vielen vielen Dank für jede Hilfe :)
LG matze19999
Liegt an der Kombination des Speicher & Mainboards. Exakt das gleiche Problem gab es hier diverse Seiten vorher schön öfters. Ich selber hab die Kombi und es läuft einfach nicht.
Selbst mit manuellen Settings sind die beiden Komponenten unheimlich zickig untereinander. Mit vergleichbarem Corsair-Speicher rennt das Apex wie entfesselt.
G.SKill Speicher hatte schon immer die etwas schärferen Sub-Timings, offensichtlich macht dass dann bei entsprechenden Taktraten nicht jeder IMC mit.
Nach dem Motto ich habe 4xxx MHz Ram gekauft und der muss also so laufen geht das nun mal nicht. :rolleyes:
Selbst wenn ist fast immer eine manuelle Anpassung der Ram Timinings und der betreffenden Spannungen nötig.
Und wie schon gesagt, der IMC der CPU spielt dabei auch eine wichtige Rolle und bedenkt, was Intel als Ram Takt spezifiziert hat.
Alles darüber ist schön, aber ist nicht garantiert.
Btw., von der Ram Peformance her ist bei ca. 4133 MHz Ram Takt vom Mainboard her der Knackpunkt, alle darüber ist eher ein Verlustgeschäft. ;)
Je nach Software sind auch eher scharfe Ram Timinings wichtiger als Takt bis zum geht nicht mehr.
Heinrich
also ich finde das apex auch recht zickig, wenn ich es mit dem mocf vergleiche. irgendwie renn ich immer wieder in einen blackscreen beim start und postcodes von 30, 40 sind oft zu sehen. aktuell bin ich wieder auf start mit factory default unterwegs und selbst da verrennt es sich oft.
das neue bios flog wieder runter da bin ich jetzt bei 0401 zurueck. ds werde ich jetzt mal weiter testen.
es kann schnell sein. kann aber auch gqrnicht laufen.
haette ich bloß das ocf behalten. von der stabiltaet nahezu unerreicht.
Gesendet von meinem XT1562 mit Tapatalk
Klar, aber das Apex hat auch seine stärken. ;)
Ist zwar meiner Meinung nach wie du weißt nicht ganz das Mainboard für 24/7, aber zum benchen genau so gut zu gebrauchen wie das Mini OCF.
Man muss halt für ein paar Kleinigkeiten beachten dann klappt das auch mit dem schnellen booten und stabilem Ram Oc zum Beispiel.
Für den Alltagsgebrauch läuft mein Ram auf dem Apex "nur" mit 3600 MHz CL.16 und angepassten Sub Latenzzeiten, reicht mehr wie aus. :d
Heinrich
ram oc kann dir irreparabel windows zerschiessen. das zeigt sich dann in hoher cpu auslastung und lags.
zu 99% sehe ich das dann in gsmes das die gpu auslastung unter 50% faellt und cpu bei 100% steht.
problembehebung nur durch neues os.
deshlab hab ich mir eigentlich immer eine saubere spiegelplatte beiseitegelegt.
qcode 26 sehe ich hier auch oft.
Mein Windows habe ich mir letztens auch zerschossen. Die Spannungen für DDR4-4300 waren wohl etwas zu "konservativ" gesetzt und schwups war eine Neuinstallation fällig. Aber aus dem Grund haben die meisten von uns wohl auch ein Alltags- und ein Bastelsystem :d
hi.
jmd eine idee warum ich bei belegung von PCIE Slot 3 zu 90% in einen Postcode 30 laufe.
ich habe jetzt den Adaptec Kontroller in den PCI Slot 2 gesteckt und auf dem ersten Blick ist das verhalten besser.
Ich werde hier noch wahnsinnig mit dem APex
Vg
Mahlzeit, wollte mal ne kleine Rückmeldung des unten genannten Problems dalassen :)
Mahlzeit. Seit gestern spiele ich ein bisl mit dem Apex rum.
Allerdings hab ich n kleines Prob.
Bei einem neustart, ist er erst in einer bootschleife (3x) und bootet dann wieder ins OS. Ich habe ein paar Seiten weiter vorne gesehen, dass dies mehrere hatten. Gab es dafür ne lösung? *hoffe habe das nicht überlesen!
Welches Codes durchläuft er in der Schleife? Eventuell hauen die Subtimings nicht hin und das Speichertraining braucht drei Anläufe (das Retraining lässt sich im UEFI deaktivieren).
Also es scheint nicht am Speicher gelegen zu haben :confused:
Ich habe seit heute 2x ne 960 Evo eingebaut Win10 auf einer davon installiert. Seit dem gibt es kein Problem mehr mit der Bootschleife nach einem Neustart. Habe grad mal 20x neugestartet und jedes mal ging es direkt ins Windows.
Vorher: PNY SSD Raid0 (Auch ohne RAID getestet) - Neustart = 3x Boot (schleife) -> Win10
Jetzt: Samsung 960 Evo - Neustart = direkter Boot in Win10
Systemstart ist auch noch mal n tacken schneller geworden. 8.4/8.7sec auf 8/8.2sec "verbessert"^^
Damit sollte dann der verbaute Speicher kein Problem darstellen auf dem Apex! Handelte sich übrigens um den hier GeIL White Dragon 3000MHz Cl15. Läuft nun stabil bei 3600MHz Cl16.
Wo es nun gehakt hat, kann ich leider nicht ausmachen. Festplatte kann dafür also verantwortlich sein ?!
LG
Edit: Wat ein teuflischer Beitrag :asthanos:
DDR4-3600 CL16 mit den Dingern?
Ziemlich ordentlich für Dual Rank 4Gbit D-Dies.
Jips, genau mit denen.
3600MHz 16-18-18-35-350 2t 1.4v restlichen Timings auch angepasst.
auf 1T kam ich nicht über die 3000MHz hinaus. Dafür konnte man sehr scharfe Timings einstellen.
Mal sehen was die Trident Z Kits können. Bis zum Wochenende sollten die 3600 CL17 & die RGB DDR4-3466 CL16 ankommen. (rgb's nur mal zum testen^^)
Das klingt doch gut, dann wird es auch mal wieder Zeit für ein Update der Speicherliste.
Ich hab auch ein paar neue Kits da :d
Hier läuft ja nicht mehr viel ....jetzt alle auf Z370 unterwegs ?
Dann schreib ich noch mal was .....hab meinem 7700K mal ne WLP Kur verpasst mit LM .
Hat noch mal gute 6-10°c bessere Temps gebracht .
Jetzt laufen die 5000 Mhz @ 1,264v. auf dem Apex einwandfrei .:bigok:
Nah, Z370 werde ich wohl auslassen. Auch weil das X Apex sich irgendwie in die falsche Richtung entwickelt hat, u.a. mit 5GBE und den anderen tollen Key Upgardes :rolleyes:
ps: Zeig mal einen Screen mit AidaMEM und Timings für deine 4133 CL17!
Ebenfalls.
Bei Z390 weiß ich es noch nicht so genau, aber wahrscheinlich werde ich die Plattform auch auslassen.
Bin zur Zeit gut bedient mit doppel Apex und eine MSI für 24/7. :d
Oder Langfassung. Benchen Z270 Apex und X299 Apex (ist zur Zeit noch im Hauptsystem), und einem MSI X299 GpC was demnächst ins Hauptsystem wandert.
Auf dem X299 laufen ja jede Menge CPU's (6,8,10 Kerner, alles darüber ist zu teuer finde ich), reicht zum benchen vollkommen aus. Dieser Coffeelake Kram bringt ja nicht wirklich mehr Performance im direkten Vergleich, also warum auch noch kaufen? Geld kann man auch besser anlegen, falls man zu viel davon hat. :asthanos:
Heinrich
Ich bin noch am schrauben:
Sieht schon mal gut aus laut ASRock TC. ;)
Die Werte bei AIDA übrigens auch. Ein wenig Feintuning geht noch würde ich sagen, aber echt gut gemacht bisher.
Schau mal ob du bei Tcwl 12 stabil kommst.
Heinrich
Ja, die Latenz in Aida64 sieht aber schon recht gut aus für 45x42. Wenn ich mit tWCL tiefer gehe bekomme ich direkt Postcode 49.
Keine Ahnung ob ich dafür noch an was anderem herumschrauben muss, oder das am PCB der Trident Z RGB liegt...
#49-DRAM Training Fehler
Mit wie viel VDIMM/VCCIO/VCCSA bist du den Unterwegs?
Versuche mal tFAW 24 in Kombination mit tCWL 13 (zum testen).
tREFI 32767 (nicht 32768) ist eher was für X99 und X299, bei Z270 nimm man eher 65534. Meiner Meinung nach und ist auch nicht sooooo wichtig. ;)
Heinrich
Die Tridentz sind heute angekommen und hab bei lauter probiere rei erst einmal win10 zerschossen :lol:
win10 is wieder frisch und das is jetz der erste boot mit 2000mhz, cl15, Vdimm 1.600v, SA/IO 1.300v (Dimm Ram 1.300v)
muss mich leider noch ma ne runde hin haun, aber morgen nach der letzten Nachtschicht kann dann ausgelassen gefummelt werden :d
edit
das lief dann auch schon mal 20min 800k
