emissary42
Kapitän zur See
- Ort
- Nehr'esham
- Desktop System
- Endlos-Baustelle
- AMD & Intel
- alle Hersteller
- Luft
- G.SKILL, Corsair & Co
- 8K, 5K, 4K
- 80plus Platinum
Software Releases
- G.SKILL Trident Z Lighting Control V1.00.37 (10.12.24) (Z890 Patch)
- G.SKILL Trident Z Lighting Control V1.00.35 (12.04.23)
- G.SKILL Trident Z Lighting Control V1.00.31 (13.05.22)
- G.SKILL Trident Z Lighting Control V1.00.30 (05.05.22)
- G.SKILL Trident Z Lighting Control V1.00.29 (01.12.21)
- G.SKILL Trident Z Lighting Control V1.00.27 (04.08.21) (+ DDR5 Patch)
- G.SKILL Trident Z Lighting Control V1.00.26 (27.04.21)
- G.SKILL Trident Z Lighting Control V1.00.24 BETA (17.03.21)
- G.SKILL Trident Z Lighting Control V1.00.22 (04.12.20)
- G.SKILL Trident Z Lighting Control V1.00.18 (05.06.20)
- G.SKILL Trident Z Lighting Control V1.00.17 (27.04.20)
- G.SKILL Trident Z Lighting Control V1.00.08 (14.08.19)
- G.SKILL Trident Z Lighting Control V1.00.07 (25.07.19)
Ältere Downloads entfernt, da diese Versionen nicht mehr zur Verfügung stehen.
IMPORTANT
- Before installing, please make sure the motherboard BIOS is updated to the latest version.
- Before installing the software, please extract the ZIP file contents to a known location. If you are using Windows built-in zip utility or having trouble with the installation process, please right click on the ZIP file, click "Properties", and then check "Unblock" (example screenshot).
- When installing, if the installer isn't working properly for you, please right click on the installer EXE file and choose to "Run as Administrator".
- On some Z370 and ASUS X99 motherboards, enabling "SPD Write" in BIOS is required: PDF Guide.
- This software may conflict with other LED lighting control software (such as ASUS Aura, Gigabyte RGB Fusion, MSI Command Center/Mystic Light, NZXT CAM, etc.). Please do not install multiple software at the same time, or the software may not work as intended. We are working to improve compatibility between the different software programs.
Meldet eure Probleme mit der G.SKILL RGB Control Software hier: Post your issues with the Trident RGB Control software here - G.SKILL TECH FORUM
G.SKILL schrieb:Would you mind listing your motherboard model, BIOS version, memory model number, and Windows version (e.g. Windows 10 Pro 64-bit, English US) for us? We'll see if there's anything we missed that'll cause the sticks to get stuck.
Troubleshooting
Trident Z Lighting Control Software Guides - G.SKILL International Enterprise Co., Ltd.
Basic troubleshooting and clean uninstall guides for the Trident Z Lighting Control software.
