Karte R9 270X Tri-X OC, es ist der Lüfter nahe dem IO-Panel. Beim letzten Benchmark hats ihn erwischt, Ironie an der Sache: Grade alle Gehäuselüfter auf bequiet! umgerüstet, und jetzt macht die GraKa Krach x( Gekauft 27. Oktober '14, sollte ich es erst beim Verkäufer (Cyberport) versuchen, oder dir gleich eine PM schicken?"Dear All,
We have a very low rate of faults with our graphics boards. That an issue showed up and someone was able to fix it and subsequently did a video shows a real enthusiasm for our products. However this issue only occurred on a very small number of early production boards and has been addressed. The rattle is caused by a resonance in the shroud, only at certain fan speeds, and it vibrating against the fins of the cooler. The clearance has been adjusted and this no longer happens.
We would normally recommend users with any issue to take advantage of our warranty return and repair service. However, the fix in the youtube video will not invalidate the warranty because it only involves removing the fan from the cooler - not the cooler from the board, therefore not breaking the critical thermal bond between the cooler and the gpu or other components.
Best Regards,
SAPPHIRE Technology"
Bitte immer einfach eine PM schicken, danke![]()
ich bräuchte auch ein lüfter für mein r9 290 von gigabyte
ein lüfter macht komische geräuche
