[Sammelthread] Gigabyte GA-Z170X-Gaming 7 (Intel Z170) Sockel 1151
Specifications
Intel® Thunderbolt™ 3 Certified Motherboard
•Supports 6th Generation Intel® Core™ Processor
•Dual Channel DDR4, 4 DIMMs
•Intel® USB 3.1 with USB Type-C™ - The World's Next Universal Connector
•3-Way Graphics Support with Exclusive Ultra Durable Metal Shielding over the PCIe Slots
•Dual PCIe Gen3 x4 M.2 Connectors with up to 32Gb/s Data Transfer (PCIe NVMe & SATA SSD support)
•3 SATA Express Connectors for up to 16Gb/s Data Transfer
•Integrated HDMI 2.0 support
•Creative SoundCore™ 3D Gaming Audio
•Killer™ E2400 and Intel® Gaming Networks
•LED Trace Path with Multi-Color Choice
•APP Center Including EasyTune™ and Cloud Station™ Utilities
•GIGABYTE UEFI DualBIOS™ Technology
CPU
1.Support for Intel® Core™ i7 processors/Intel® Core™ i5 processors/ Intel® Core™ i3 processors/Intel® Pentium® processors/ Intel® Celeron® processors in the LGA1151 package
2.L3 cache varies with CPU
Chipset
1.Intel® Z170 Express Chipset
Memory
1.4 x DDR4 DIMM sockets supporting up to 64 GB of system memory
* Due to a Windows 32-bit operating system limitation, when more than 4 GB of physical memory is installed, the actual memory size displayed will be less than the size of the physical memory installed.
2.Dual channel memory architecture
3.Support for DDR4 3866(O.C)/3733(O.C)/3666(O.C) /3600(O.C.) /3466(O.C.) /3400(O.C.) /3333(O.C.) /3300(O.C.) /3200(O.C.) /3000(O.C.) /2800(O.C.) /2666(O.C.) /2400(O.C.) /2133 MHz memory modules
4.Support for ECC UDIMM 1Rx8/2Rx8 memory modules (operate in non-ECC mode)
5.Support for non-ECC UDIMM 1Rx8/2Rx8/1Rx16 memory modules
6.Support for Extreme Memory Profile (XMP) memory modules
Onboard Graphics
Integrated Graphics Processor-Intel® HD Graphics support: 1.1 x DisplayPort, supporting a maximum resolution of 4096x2304@60 Hz
* Support for DisplayPort 1.2 version.
ŠŠ Integrated Graphics Processor+MegaChips MCDP2800 chip: 1.1 x HDMI 2.0 port
Requires the latest Intel® Graphic Driver from GIGABYTE website.
Maximum shared memory of 512 MB
Audio
1.Creative® Sound Core 3D chip
2.Support for Sound Blaster Recon3Di
3.TI Burr Brown® OPA2134 operational amplifier
4.High Definition Audio
5.2/5.1-channel
6.Support for S/PDIF Out
LAN
1.1 x Intel® GbE LAN chip (10/100/1000 Mbit)(LAN1)
2.1 x Killer E2400 chip (10/100/1000 Mbit) (LAN2)
* Teaming is not supported.
Expansion Slots
1.1 x PCI Express x16 slot, running at x16 (PCIEX16)
* For optimum performance, if only one PCI Express graphics card is to be installed, be sure to install it in the PCIEX16 slot.
2.1 x PCI Express x16 slot, running at x8 (PCIEX8)
* The PCIEX8 slot shares bandwidth with the PCIEX16 slot. When the PCIEX8 slot is populated, the PCIEX16 slot will operate at up to x8 mode.
3.1 x PCI Express x16 slot, running at x4 (PCIEX4)
* The PCIEX4 slot shares bandwidth with the M2H_32G connector. The PCIEX4 slot will become unavailable when an SSD is installed in the M2H_32G connector.
4.3 x PCI Express x1 slots
(All of the PCI Express slots conform to PCI Express 3.0 standard.)
Mlti-Graphics Technology
1.Support for 3-Way/2-Way AMD CrossFire™ and 2-Way NVIDIA® SLI™ Technology
Storage Interface
Chipset: 1.2 x M.2 Socket 3 connectors (Socket 3, M key, type 2242/2260/2280 SATA & PCIe x4/x2/x1 SSD support)
2.3 x SATA Express connectors
3.6 x SATA 6Gb/s connectors (SATA3 0~5)
4.Support for RAID 0, RAID 1, RAID 5, and RAID 10
* Refer to "1-10 Internal Connectors," for the supported configurations with the M.2, SATA Express, and SATA connectors.
ASMedia® ASM1061 chip: 1.2 x SATA 6Gb/s connectors (SATA3 6~7), supporting AHCI mode only
USB
Chipset: 1.5 x USB 3.0/2.0 ports on the back panel
2.4 x USB 2.0/1.1 ports (available through the internal USB headers)
Chipset+Renesas® USB 3.0 Hub: 1.4 x USB 3.0/2.0 ports (available through the internal USB headers)
Chipset+Intel® Thunderbolt™ 3 Controller: 1.1 x USB Type-C™ port on the back panel, with USB 3.1 support
2.1 x USB 3.1 Type-A port (red) on the back panel
Internal I/O Connectors
1.1 x 24-pin ATX main power connector
2.1 x 8-pin ATX 12V power connector
3.2 x M.2 Socket 3 connectors
4.3 x SATA Express connectors
5.8 x SATA 6Gb/s connectors
6.1 x I/O shield audio LED power connector
7.1 x CPU fan header
8.1 x water cooling fan header (CPU_OPT)
9.3 x system fan headers
10.1 x front panel header
11.1 x front panel audio header
12.2 x USB 3.0/2.0 headers
13.2 x USB 2.0/1.1 headers
14.1 x Trusted Platform Module (TPM) header
15.1 x serial port header
16.1 x Clear CMOS jumper
17.1 x power button
18.1 x reset button
19.1 x Clear CMOS button
20.1 x ECO button
21.1 x OC button
22.1 x audio gain control switch
23.Voltage Measurement Points
24.1 x BIOS switch
Back Panel Connectors
1.1 x PS/2 keyboard/mouse port
2.1 x DisplayPort
3.1 x HDMI port
4.1 x USB Type-C™ port, with USB 3.1 support
5.1 x USB 3.1 Type-A port (red)
6.5 x USB 3.0/2.0 ports
7.2 x RJ-45 ports
8.1 x optical S/PDIF Out connector
9.5 x audio jacks (Center/Subwoofer Speaker Out, Rear Speaker Out, Line In/Mic In, Line Out, Headphone)
I/O Controller
1.iTE® I/O Controller Chip
H/W Monitoring
1.System voltage detection
2.CPU/System/Chipset temperature detection
3.CPU/CPU OPT/System fan speed detection
4.CPU/System/Chipset overheating warning
5.CPU/CPU OPT/System fan fail warning
6.CPU/CPU OPT/System fan speed control
* Whether the fan speed control function is supported will depend on the cooler you install.
Bios
1.2 x 128 Mbit flash
2.Use of licensed AMI UEFI BIOS
3.Support for DualBIOS™
4.PnP 1.0a, DMI 2.7, WfM 2.0, SM BIOS 2.7, ACPI 5.0
Unique Features
1.Support for APP Center
* Available applications in APP Center may vary by motherboard model. Supported functions of each application may also vary depending on motherboard specifications.
3D OSD
@BIOS
Ambient LED
AutoGreen
Cloud Station
EasyTune
Easy RAID
Fast Boot
Smart TimeLock
Smart Keyboard
Smart Backup
System Information Viewer
USB Blocker
2.Support for Q-Flash
3.Support for Smart Switch
4.Support for Xpress Install
Bundle Software
1.Norton® Internet Security (OEM version)
2.Intel® Smart Response Technology
Operating System
1.Support for Windows 10/8.1/7*
* Please download “Windows® USB Installation Tool” to install Windows® 7.
Form Factor
1.ATX Form Factor; 30.5cm x 24.4cm
Box Contents
1.GA-Z170X-Gaming 7 motherboard
2.Motherboard driver disk
3.User's Manual
4.Quick Installation Guide
5.Four SATA cables
6.I/O Shield
7.One 2-Way SLI bridge connector
8.One G Connector
9.One pack of back I/O dust covers
Remark
1.Due to different Linux support condition provided by chipset vendors, please download Linux driver from chipset vendors' website or 3rd party website.
2.Most hardware/software vendors may no longer offer drivers to support Win9X/ME/2000/XP. If drivers are available from the vendors, we will update them on the GIGABYTE website
Reviews
GIGABYTE Z170X Gaming 7 Motherboard Review
Gigabyte Z170X-Gaming 7 | TrustedReviews
GIGABYTE GA-Z170X-Gaming 7 - Bjorn3D.com
Gigabyte GA-Z170X-Gaming-7
Gigabyte GA-Z170X-Gaming 7 Motherboard Review
OVP/Zubehör/Layout/Features
Geizhals Link
https://geizhals.de/gigabyte-ga-z170x-gaming-7-a1306472.html
Treiber&Tools
GIGABYTE - Motherboard - Socket 1151 - GA-Z170X-Gaming 7 (rev. 1.0)
Bios Downloadlink
Bios History
F5
1.Update CPU Microcode
F5p
1.Beta BIOS
2.Improve DDR XMP compatibility
F4
1.Fix Intel processor issue which may cause some video games to exhibit launch issues with video game error code 8016.
F3
F2
1.First Release
Beta Bios
Aktuelle Beta Biose findet ihr wie immer bei JZ auf seiner Homepage im Drop Down Menü
Das Flashen geschieht wie immer auf eigene Gefahr.
http://www.jzelectronic.de/jz2/index.php
CPU Support Liste
GIGABYTE TECHNOLOGY Socket 1151 - Intel Z170 - GA-Z170X-Gaming 7 (rev. 1.0)
Dem kann ich mich nur anschließen.
Mein 6600K bekommt 1.280 im Bios fix eingestellt, in Windows sind es dann 1.272, unter Last 1.260V.
Meine Hynix 2400er rennen 3000 mühelos mit straffen Timings.
Was will ich/man mehr.
XMP mit Auto Spannung (Vcore/IO/SA) derbe zu hoch / Auto/Normal Vcore weiterhin noFunktion / LLC auch noch so wie zuvor, läßt sich nicht nach Intel Spef. schalten.
Minus Offset geht jetzt !
@JZ
Ich konnte den Speicher nochmal gegen den 3000er Corsair tauschen und der rennt soweit problemlos ...
Der 2800er lief im Bios mit 1.212V und der 3000er mit 1.344V, dabei ist die CPU Package von 60 auf 66 Grad gestiegen ( unter Prime / 1344k )
Derzeit versuche ich noch ein paar Werte zu senken :-)
CPU VCCIO = 1,05V
CPU VCCSA = 1,10V
Macht es Sinn noch weiter runter zu gehen ?
Kenne das Problem bei vielen Herstellern, würde mal den Speicher prüfen und ein aktuelles BetaBIOS ausprobieren.
Die Rams habe ich gewechselt, BetaBIOS aber noch nicht draufgespielt... alle anderen getestet... Problem bleibt bestehen... wechsel Morgen das MB und hoffe auf ein Hardware-Problem.
Hi zusammen
Bin zufällig durch JZ auf diesen Bereich gestoßen und werde auch ein wenig berichten.
Habe die gleichen Probleme wie bereits mehrfach angesprochen mit diesem Board (viel zu hohe >1.4 VCore mit meinem 6700K, sporadische Bootfehler mit aktiviertem XMP) und stehe seit Kurzem mit Gigabyte bezüglich einer Lösung in Kontakt.Total nervtötend ist, dass sobald das Bios mit einem Error den Start nach Aktivierung des XMP Profils abbricht meine Maus und Tastatur (USB) nicht mehr erkannt werden und ich ein CMOS Reset machen muss. :kotz:
Folgendes habe ich noch beobachtet:
Die CPU läuft unter Last auf allen Kernen mit 4.2GhZ. Hier wurde anscheinend der Turbo Modus überschrieben, da ja 4.2GhZ eigentlich nur bei Auslastung eines einzelnen Kerns anstehen sollte. Schalte ich den Turbo Modus auf „Enabled“ (nicht Auto), sollten eigentlich (wie angegeben) die normalen Intel Einstellungen greifen,aber auch hier läuft die CPU unter Last mit 4.2GhZ auf allen Kernen. Wird der Turbo Modus komplett deaktiviert, laufen die Kerne korrekt mit 4.0Ghz und die Spannung sinkt auf etwa 1.37V unter Last. Eine manuelle Einrichtung des Turbo Modus' funktioniert übrigens auch nicht, hier läuft der aktive Kern trotzdem immer nur mit der Minimal-Einstellung.
Mal schauen was sich tut... So viel zum "Luxus-" Produkt.
Und ich wollte vom Asus Hero VIII zum Z170X-Gaming 7 wechseln, da die Bootzeit beim Hero ein Graus ist und es nirgends ne wirkliche Lösung gibt. Alles andere aber ist sonst ok und auch 4,6GHz plus Corsair 3000 per XMP läuft top. Aber wenn ich das hier so lese......mhhh.
Wie schnell bootet das Gaming 7. Meine vom Startknopf betätigen bis Windows einsatzbereit ist? Beim Hero mit default Werte ca. 1:45! Minute, nach "Optimierung" (abschalten vieler Funktionen, was es ja eigentlich nicht sein kann) dann noch ca. 40 Sekunden....
Mit i7 6700K und ner 950Pro. Der Windowsstart an sich geht sehr schnell, eben aber bis dahin ist es schwach.
Bei ASRock habe ich die Bootzeit mit der Samsung 950 Pro verkürzen lassen und die liegt jetzt ab PowerOn bis Win10 Desktop bei 16 Sek. :)
Das Gigabyte mit aktuellem BIOS bei 18 Sek. :d
Ja, so stellt man sich das auch vor. Dachte es liegt an der 950Pro.
Aber was ist mit den hier beschriebenen Problemen beim Gaming 7? Wie läuft das Gaming 7 sonst so? Der Sound besser als Asus?
Mit aktivierten Schnellstart in Windows (Energieoptionen) oder ohne? Wie sehen die Bootzeiten mit und ohne aus?
Ist denn das Gaming 7 wirklich so viel schlechter als das Hero VIII in Bezug auf Übertaktbarkeit, Speicherkompatibilität, UEFI und Lüftersteuerung, wie es dargestellt wird???
Das Gigabyte punktet vor allem durch die Ausstattung.
Dafür muss man in Sachen UEFI, OC Verhalten und vor allem Speicher-Unterstützung zurück stecken.
Ich habe beide Boards hier gehabt und das Gigabyte hat wieder her gegeben.
Was es allerdings ganz gut gemacht hat war das non-K OC ... also das Übertakten via BCLK.
Hiho,
ich hätt da mal ne Frage..
kann ich beim Gaming 7 auch einen "einfachen" 4pin P4-ATX Stecker nutzen? Habe noch ein 120w Netzteil aus nem flachen SST Case, das halt nur 1x 4pin bietet, nicht 2x 4pin (ATX_12V_2X4/ATX); Adapter von 4 auf 8 sind meines Wissens nutzlos, da es sowieso bei einer 12V Leitung bliebe.
Meines Wissens gab's die Erweiterung auf 2x4pin wegen der erhöhten Leistungsaufnahme.
Da ich allerdings nur nen i7-6700T mit 2x M.2 und 32gb RAM darauf laufen lasse, sollte das doch eigentlich passen, oder? Wird kein OC betrieben.
Besten Dank vorab *wink*
Ist das jetzt generell ein Problem der verbauten Hardware (Wandler, Kondensatoren, Spannungsphasen usw.) oder sind das rein softwareseitige Probleme, bei denen Hoffnung auf Besserung durch zukünftige Updates (UEFI) besteht? Ich finde die Ausstattung und die 5 Jahre Garantie auch sehr interessant. Zur Not tauscht man Ende diesen / Anfang nächstes Jahr gegen den Nachfolger. Gibt ja auch da 70€ noch obendrauf....
- - - Updated - - -
Was ist eigentlich der Unterschied vom Gaming 7-EU zum nicht EU ausser dem Bild auf der Verpackung? Hab das EU hier liegen. Übrigens original Gigabyte versiegelt, bei Asus gibt es das nicht mehr. Weiß man nie wirklich, ob es schon benutzt wurde...:confused:
Was willst du mit so einem teuren schweren Kühler ?
Total unnötig, wenn man kein OC > 4.50 GHz betreiben möchte.
Der be quiet! Dark Rock Advanced C1 ist Klasse und viel günstiger ;-)
Klingt lustig, teuer und schwer....
Teuer finde ich ihn auch, aber da muss ja jeder sein Budget kennen. Aber zum Thema Schwer.....
be quiet! Dark Rock TF 810g und der Dark Rock Advanced C1 1100g...?
Ich nutze einen Thermalright HR-02 Macho Rev. B, wiegt 880g und kostet die Hälfte. Hat eine super Kühlleistung und ist dabei auch noch superleise.
Liegt es am platz oder warum der be quiet! Dark Rock TF?
GONZ0
PS: Antworten haben sich überschnitten.
