No difference between Z87 and Z97![]()
I have a good cpu, I can stable 5.1 with vcore 1.34 , But now I cpu in stock and want to test the memory
My problem is that I never did overclock memory so I'm a little
lost :/
I try to rise slightly voltages below?
VCCSA
VCCIO d
VCCIO a
It is probably not a timing issue, but might be a case of VCCSA and VCCIO(a/d) needing a slight voltage bump. This varies from CPU to CPU. Maybe try increasing both individually in small steps of 10mV, until you find stability. You probably don't need more than +30/50mV total each.
My CMD16GX3M4A2666C10 @ DDR3-2400 CL9 on MSI Z97M GAMING:
Edit: please remove the picture from your quote above
you have enabled xmp profile or put all manual,
Timmins primary, secondary and tertiary all manual?
