	[Sammelthread] MSI Z97 GAMING Series
ehemals [Sammelthread] MSI Z97M GAMING
--- MSI GAMING Microsite ---
| MSI Z97A Gaming 9 ACK (+ USB 3.1) |
| MSI Z97 Gaming 9 ACK (+ Killer Double Shot) |
| MSI Z97 Gaming 9 AC |
| MSI Z97A Gaming 7 (+ USB 3.1) |
| MSI Z97 Gaming 7 |
| MSI Z97A Gaming 6 (+ USB 3.1) |
| MSI Z97 Gaming 5 |
| MSI Z97 Gaming 3 |
| MSI Z97M Gaming (der Ursprung dieses Threads) |
| MSI Z97I Gaming ACK (+ Killer Double Shot, M.2) |
| MSI Z97I Gaming AC |
	MSI Z97M GAMING
( Preisvergleich | Produktseite | PDF-Manual | Memory-QVL )
--- MSI Z97M GAMING @ hwbot ---
Spezifikationen
	| Model number | Z97M GAMING (M7919, 7919-001R) |
| EAN | 4719072343187 |
| Form factor | µATX (244x244mm) |
| CPU | LGA1150 |
| Chipset | Intel Z97 |
| Memory | Number of slots: 4 Channels: Dual Corresponding standard: DDR3 3200 (OC) / 3100 (OC) / 3000 (OC) / 2933 (OC) / 2800 (OC) / 2666 (OC) / 2600 (OC) / 2500 (OC) 2400 (OC) / 2200 (OC) / 2133 (OC) / 2000 (OC) / 1866 (OC) / 1800 (OC) / 1600 / 1333 |
| Built-in graphics | HDMI 1.4a (4096x2160 @ 24Hz, 2560x1600 @ 60Hz) DisplayPort 1.2 (4096x2304 @ 24Hz, 3840x2160 @ 60Hz) |
| Expansion slot | 2x PCI Express 3.0 x16 (16+0 / 8+8 Lanes) 2x PCI Express 2.0 x1 |
| Multi-GPU | 2-Way AMD CrossFire, 2-Way NVIDIA SLI |
| Storage | 6x SATA 6Gb/s (RAID 0/1/5/10 support) 1x M.2 (10Gb/s, SATA, 2242/2260/2280, shared with SATA5/6) 2x eSATA 6Gb/s (ASMedia ASM1061, PCIe 2.0 x1) |
| Audio | 7.1 Channel Realtek HD Audio (ALC1150) 2x OPA1652 headphone amplifiers (1x front, 1x rear) |
| LAN | 1x Qualcomm Atheros Killer E2205 (Gigabit Ethernet) |
| Interface | 6x Intel USB3.0 (4x Backpanel, 2x Internal) 2x ASMedia ASM1042 USB 3.0 (Backpanel) 8x USB2.0 (4x Backpanel, 4x Internal) |
| Internal connector | 1x 24-pin ATX main power 1x 8-pin ATX 12V power 6x SATA 6Gb/s 2x CPU fan header 2x system fan headers 1x front panel header 1x front panel audio header 1x S/PDIF Out header 1x USB 3.0 / 2.0 header 2x USB 2.0 / 1.1 header 1x TPM header 1x Clear CMOS jumper 1x power button 1x reset button 1x OC Genie 1x audio power switch |
| Back panel | 2 x USB 2.0 / 1.1 ports 6x USB 3.0 / 2.0 ports 2x eSATA 6Gb/s 1x clear CMOS button 1x optical S/PDIF Out connector 1x HDMI port 1x DisplayPort 1x PS/2 keyboard & mouse port 1x RJ-45 port 6x audio jacks (Center / Subwoofer Speaker Out, Rear Speaker Out, Side Speaker Out, Line In, Line Out, Mic In) |
| Super IO | NUVOTON NCT6792 |
| BIOS | 64Mb flash (Winbond W25Q64FVSIQ) UEFI AMI BIOS ACPI 5.0, PnP 1.0a, SM BIOS 2.7, DMI 2.0 Multi-language |
| Supported OS | Windows 7 / 8 / 8.1 |
| Accessories | Drivers & Utilities Disc Motherboard User Guide I/O Shield 4x SATA Cable Warranty brochure Software & Application User Guide M-Connectors SLI bridge case badge audio power adapter Door Hanger |
BIOS
1) Bilder
siehe User Review
2) Spannungen
siehe User Review
3) BIOS Downloads - Achtung: Beim BIOS Update gehen die gespeicherten OC Profile verloren (diese sind nicht auf/abwärtskompatibel).
- 1.0 (Initial Release)
- 1.1 (Changes: Enhanced OC Call Back, Update BIOS Code Base & MSI GESII Module, Improved USB compatibility & S4 resume function)
- 1.2 (Changes: Improved memory & VGA compatibility, adjust OC Genie for Refresh CPUs, Improved M-Flash compatibility, updated Intel RC code)
- 1.3 (Changes: Improved VGA, PS2 keyboard & CPU compatibility, Enhanced EIST function when use non turbo boost CPU)
- 1.4 (Changes: Removed 1024MB UMA option, fixed CPU fan down time, improved USB keyboard & memory compatibility, Enhanced MFlash function)
- 1.6 (Changes: Updated VBIOS, GOP driver & CPU microcode, Improved SAMSUNG M.2 & ASMedia SATA compatibility)
- 1.7 (Changes: Updated BIOS code to support 5th-Generation Intel Core Processors)
- 1.8 (Changes: Patched WHQL & LAN issues, updated BIOS code, improved VGA & Blu Ray ODD compatibility)
News & Reviews
00) HARDWARELUXX User Review http://www.hardwareluxx.de/community/f12/msi-z97m-gaming-live-review-done-1062683.html
01) ocaholic
02) Overclockers
03) PC Gameware UK
04) Modders-Inc
05) Gaming till disconnected
06) Profesional Review (ES)
07) PCLab.pl (PL)
08) Hardware.Info (Roundup, NL)
09) Overclockers Australia Forums (User Review: gazza30)
10) hardwarezone.com.sg (User Review: eminus)
11) Hepsniniyisi
12) LanOC (Roundup)
13) Arsernal Gamer
14) bit-tech.net
Hardwareluxx CPU-Kühler & RAM-Kompatibilitätsliste
1) CPU-Kühler
- Hersteller Modell @ Preisvergleich | Quelle | kompatibel | Einschränkungen / Anmerkungen
- Hersteller Modell @ Preisvergleich | Quelle | inkompatibel | Grund
- Prolimatech Megahalems (alle Modelle, ab Rev 2) | User: emissary42 | kompatibel
- Zero Infinity Phantom Knight | User: emissary42 | kompatibel
- Thermalright Archon SB-E | User: emissary42 | kompatibel
- --> Bitte helft mit sammeln!
2) RAM
- Corsair Dominator Platinum CMD16GX3M4A2666C10 | User: emissary42 | inkompatibel | 4x4GB funktionieren nicht @ XMP-Auto
- G.SKILL Trident F3-19200CL10D-8GBTDD | User: emissary42 | kompatibel
- G.SKILL TridentX F3-2400C9D-8GTXD | User: emissary42 | kompatibel
Wer mir die Arbeit abnehmen möchte, kann seinen Eintrag gern direkt in diesem Format posten. Danke.
Nützliche Links & Tipps (im Forum & im WWW)
1) Hardwareluxx
- http://www.hardwareluxx.de/communit...ews-links-bilder-reviews-z97-h97-1010600.html
- http://www.hardwareluxx.de/communit...table-guide-und-full-custom-liste-989828.html
- http://www.hardwareluxx.de/community/f11/intel-haswell-sockel-1150-geruechte-faq-infos-930594.html
- http://www.hardwareluxx.de/communit...l-sockel-1150-haswell-laberthread-962401.html
- http://www.hardwareluxx.de/communit...rgebnis-thread-kein-quatschthread-959285.html
- MSI Support @ Hardwareluxx (NEU)
2) WWW (international)
3) Tips & Tricks
- Werde ich bei Gelegenheit ergänzen. Hinweise bitte im Thread posten.
4) FAQ - Frequently Asked Questions
- --> Deine Frage hier!
WORK IN PROGRESS
