[Sammelthread] Futuremark 3DMark (2013) Benchmarkthread - Rangliste
SirOli - Windows 8.1 x64 - Intel 5960X@4,8 - Asus R5E - 4x 8GB Samsung DDR4-2133 - Gigabyte GTX TitanX @1526/4100 - FIRE STRIKE: 20342 - P20342
SirOli - Windows 8.1 x64 - Intel 5960X@4,8 - Asus R5E - 4x 8GB Samsung DDR4-2133 - Gigabyte GTX TitanX @1526/4100 - FIRE STRIKE EXTREME: 10251 - X10251
Update:
Naennon - Windows 8.1 x64 - Intel i7-5960X @ 4,5GHz - ASUS RVE - 4x 4GB DDR4-2800 - NVIDIA GTX Titan X @ 1.506/2.000 - FIRE STRIKE: 19654
NVIDIA GTX TITAN X video card benchmark result - Intel Core i7-5960X,ASUSTeK COMPUTER INC. RAMPAGE V EXTREME
Naennon - Windows 8.1 x64 - Intel i7-5960X @ 4,5GHz - ASUS RVE - 4x 4GB DDR4-2800 - NVIDIA GTX Titan X @ 1.506/2.000 - FIRE STRIKE EEXTREME: 10028
Macht kein Spaß hier gegen zu benchen mit euren fetten kisten :))
Update:
SirOli - Windows 8.1 x64 - Intel 5960X@4,4 - Asus R5E - 4x 8GB Samsung DDR4-2660 - Gigabyte GTX TitanX @1543/4100 - FIRE STRIKE EXTREME: 10338 - X10338
bitte gleich noch mal mit der korrekten taktung wiederholen! ;)
Bitte:
Update2:
SirOli - Windows 8.1 x64 - Intel 5960X@4,8 - Asus R5E - 4x 4GB Gskill DDR4-3000 - Gigabyte GTX TitanX @1560/4045 - FIRE STRIKE: 20579 - 20579
SirOli - Windows 8.1 x64 - Intel 5960X@4,8 - Asus R5E - 4x 4GB Gskill DDR4-3000 - Gigabyte GTX TitanX @1572/4045 - FIRE STRIKE EXTREME: 10605 - 10605
SirOli - Windows 8.1 x64 - Intel 5960X@4,8 - Asus R5E - 4x 4GB Gskill DDR4-3000 - Gigabyte GTX TitanX @1560/4045 - FIRE STRIKE Ultra: 5443 - 5443
6ender und windows 8 is unfair :heul:
aber trotzdem mal update:
danielh - Windows 7 x64 - Intel i7-3770K @ 4,9GHz - ASUS Maximus V Gene - 2x4GB DDR3-1600 - EVGA GTX980 Ti @ 1500/4100 - FIRE STRIKE: 16867 - NVIDIA GeForce GTX 980 Ti video card benchmark result - Intel Core i7-3770K Processor,ASUSTeK COMPUTER INC. MAXIMUS V GENE
danielh - Windows 7 x64 - Intel i7-3770K @ 4,9GHz - ASUS Maximus V Gene - 2x4GB DDR3-1600 - EVGA GTX980 Ti @ 1500/4100 - FIRE STRIKE EXTREME: 9109 - NVIDIA GeForce GTX 980 Ti video card benchmark result - Intel Core i7-3770K Processor,ASUSTeK COMPUTER INC. MAXIMUS V GENE
Windows 8.1 x64 - Intel i7 5960X @ 4,5Ghz - Rampage V X99 - 4x4GB DDR3200 Ripjaws DDR4 - 2 x Titan X @ 1506Mhz/4000Mhz - Fire Strike 27426 - 27426
Shaqiiii - Windows 8.1 x64 - Intel i7-3770K @ 4.6GHz - ASRock Z77 OC Formula - 2x4GB DDR3-1600 - 2 x R290 @ 1130/1250Mhz : ICE STORM: 184376 - CLOUD GATE: 31066 - FIRE STRIKE: 16722 http://www.3dmark.com/3dm/7387093
Physik score ist ganz schön hoch bei der Karte/Sys, da kommen die ganzen Punkte her :)
GTX980Ti @kennenlernphase..
TobiWahnKenobi - Windows 8.1 x64 - Intel i7-3770K @ 4,9GHz - ASROCK Z77 - 4x 4GB DDR3-2133 - NVIDIA GTX 980 Ti @ 1.550/2040 - FIRE STRIKE: 17148
NVIDIA GeForce GTX 980 Ti video card benchmark result - Intel Core i7-3770K Processor,ASRock Z77 Extreme4
TobiWahnKenobi - Windows 8.1 x64 - Intel i7-3770K @ 4,9GHz - ASROCK Z77 - 4x 4GB DDR3-2133 - NVIDIA GTX 980 Ti @ 1.550/2040 - FIRE STRIKE EXTREME: 9656
tobi
4.0ghz ? in deiner sig steht was von 4.7ghz. wie viel spannung braucht so ein 5960x für 4.7 eigtl ?
deine titan ist in deiner sig ebenfalls mit 1520 angegeben, hier lässt du 1300 laufen. :confused:
Scheint wohl ein wenig downgegraded zu haben, 32->16GB :wayne: Signaturen halt, werden nicht immer gepflegt ;)
sry das sind meine 7/14 einstellung 1300/2000 und speicher wurden wieder verkauft, hab jetzt 16GB @3200Mhz, die Cpu lasse ich moment auf 4Ghz laufen, werd aber noch einen run machen mit, 1520/2000 und 4,7 Ghz.
Nichts wofür man sich entschuldigen oder rechtfertigigen müsste ;) schönes System!
Update3: Löst alle alten Updates ab.
Single GPU
SirOli - Windows 8.1 x64 - Intel 5960X@4,8 - Asus R5E - 4x 4GB Gskill DDR4-3000 - Asus GTX TitanX @1551/4180 - FIRE STRIKE Ultra: 5514
Multi GPU
SirOli - Windows 8.1 x64 - Intel 5960X@4,8 - Asus R5E - 4x 4GB Gskill DDR4-3200 - 2* GTX TitanX @1536/4100 - FIRE STRIKE: 30087
SirOli - Windows 8.1 x64 - Intel 5960X@4,8 - Asus R5E - 4x 4GB Gskill DDR4-3200 - 2* GTX TitanX @1556/4150 - FIRE STRIKE EXTREME: 18838
SirOli - Windows 8.1 x64 - Intel 5960X@4,8 - Asus R5E - 4x 4GB Gskill DDR4-3200 - 2* GTX TitanX @1506/4000 - FIRE STRIKE Ultra: 9880
zu updatezwecken
Dennis50300 - Windows 7 x64 - AMD FX 8300 (95W TDP) - ASUS M5A97 R2.0 - 4x 8GB DDR3-1600 - 7870 DCII Asus - ICE STORM: 96300 (1.2) - CLOUD GATE: 16072 (1.1) - SKY DIVER: 16443 (1.0)- FIRE STRIKE: 5558 (1.1) - AMD Radeon HD 7870 video card benchmark result - AMD FX-8300,ASUSTeK COMPUTER INC. M5A97 R2.0
Nachdem ich nun den 15.6 Beta installiert habe und die neuere Version von 3DMark seit 6.Juni (v1.5.915) installiert habe, da hat sich nochmals einiges getan
Gruss Dennis50300
wow, von 770 auf 970 und soviele punkte mehr geholt. Nicht schlecht :)
Wenn ich mir die Benchmarks hier so ansehe von der gtx 980ti, das schaffe ich nicht. Ich bin aber auch kein OC Freak.. bei mir ist bei 15000 in Firestrike ende bei einem Boost von 1490 Mhz .. mir persöhnlich reicht das. Ich glaube aber es liegt garnicht an der grafikkarte sondern am xeon 1230v3 den ich besitze, ich glaube in 3dmark skaliert auch die cpu mit ein.. weil die grafikpower vom wert her garnicht so arg viel schlechter ist.
Meine nächste anschaffung wird wieder ein core i5, diesmal vielleicht sogar ein K Modell das ich bissl OC kann. Aber wesentlich wichtiger ist mir die igpu, dann hab ich wenigstens keine probleme am PC wenn meine GPU mal in reperatur ist.
Wie kann es sein, dass ich nur so wenig Punkte in Firestrike habe?
NVIDIA GeForce GTX 970 video card benchmark result - AMD FX-9370,ASRock 990FX Extreme9
9127 Punkte. Dabei lief die GPU auf 1430Mhz und der Speicher auf 4150Mhz.
Liegt es daran, dass ich nur PCI-E 2.0 habe? Oder generell an der AMD CPU?
Grafikkarte ist unter Wasser und hatte maximal 44 Grad, sollte also demnach nicht den Boost zurück nehmen. Läuft halt nur immer ins Powerlimit.
Bei Heaven Benchmark habe ich mit 1920x1080 8xAA Tessallation Extreme und Qualität Ultra auch nur 63,9FPS und 1609 Punkte.
Kann mir bitte wer helfen?
GTX770 auf GT970
alt:
=majortom= - Windows 7 x64 - Intel 3570K @ 4,5Ghz - Asrock Z77 pro3 - 2x 4GB DDR3-1600 - MSI GTX770@1320/3000 Mhz - FIRE STRIKE : 7349
neu:
=majortom= - Windows 8.1 x64 - Intel 3570K @ 4,5Ghz - Asrock Z77 pro3 - 2x 4GB DDR3-1600 - EVGA GTX970@1480/3500 Mhz - FIRE STRIKE : 10326
NVIDIA GeForce GTX 970 video card benchmark result - Intel Core i5-3570K Processor,ASRock Z77 Pro3
update, Wechsel von laut rauschender EVGA zur MSI
=majortom= - Windows 8.1 x64 - Intel 3570K @ 4,5Ghz - Asrock Z77 pro3 - 2x 4GB DDR3-1600 - MSI GTX970@1483/3500 Mhz - FIRE STRIKE : 10469
http://www.3dmark.com/3dm/7670877
