[Sammelthread] Philips BDM4065UC - 40" 4K (3840x2160) 60Hz
The Philips BDM4065UC utilises an unusual panel from a manufacturer we've not seen before. The panel is made by TP Vision, who are a subsidiary of TPV Technology and Philips. So effectively it's a Philips-own panel used here. It is Vertical Alignment (VA) technology and the panel part is the TPT400LA-K1QS1.N Rev: SC1A.
mhhm unbekanntes panel. dazu hat der tft in megagröße noch den alte vga ausgang. wtf?!
Gibt es schon irgendwelche Neuigkeiten bezüglich eines Releasezeitpunktes?
Ein Testbericht:
Philips BDM4065UC Review
Ein Auszug, in welchem es um die Skalierung geht:
The BDM4065UC is a very interesting option for desktop use. The quad HD 3840 x 2160 resolution is well suited to a screen as big as this and offers a comfortable pixel pitch and font size by default, without the need to do OS scaling. We had previously found the text size and pixel pitch a little too small when we tested the 31.5" sized Dell UP3214Q and certainly very tiny when we tested the 28" sized Samsung U28D590D. You can of course use various scaling methods to make 4k resolutions more usable on smaller screens, but it's not always easy to get something set up for all your uses. While some Operating systems scale well, others do not, and a lot of apps also have problems with the scaling. Here on the BDM4065UC you don't need to bother with scaling at all, you can just run the screen and operating system at it's normal settings without the text being too small. The pixel pitch of 0.2281 mm is very comparable to the 0.2331 mm of a 27" 2560 x 1440 resolution panel. This is perfectly fine for day to day use. With the high resolution and huge screen size you have plenty of room for multi-tasking and split screen working which is great news. For word processing, CAD/CAM, image editing, programming etc it's really a massive area to use.
Genau sowas wollte ich hören. Danke dafür.
Irgendwie befürchte ich ja so langsam einen Papiertiger Tiger, kein US-Release und kaum Verfügbarkeit bei uns :(
Wenn das noch länger geht haben wir neue AMD-Karten mit HDMI 2 eher im Handel als das Teil :p
Wenn sich den echt jemand von euch anschafft, bitte ich um Bilder vom Schreibtisch :d Im Ernst, ich finde das Gerät ja echt interessant, aber ich habe gerade einen 32" hier und das ist bei normalem Arbeitsabstand schon grenzwertig mit meiner Körpergröße :fresse: Ich hoffe es kommt noch mal ein kleineres 4K Gerät mit VA Panel, der 32" IPS geht wieder zurück, ich komm leider mit dem Schwarzwert einfach nicht klar...
Hatte auch erst nen LG34um65 und wollte eigentlich auf 4K umsteigen! Habe mir das ganze noch einmal im Fachgeschäft angeschaut und bin dann doch davon abgesprungen. Nachdem der Benq BL3200PT bei vielen User durch schlechte Qualität an den Händler zurück ging habe ich mein Glück direkt bei Samsung versucht auch mit dem von Hardtech genannten S32d850t der Bildschirm ist einfach ne Wucht. Habe einen einzige toten Pixel aber ansonsten kein BLB und einen wirklich hervorragenden Schwarzwert =)
Ich habe den Monitor seit 30.12.14 und bin Begeistert. :)
Die Größe ist zwar grenzwertig aber ich habe mich schnell daran gewöhnt. Ich hatte bisher 30" Dell mit 2560 x 1600, die wirken dagegen richtig winzig. Ich muß dazu sagen, das ich kein Gamer bin. Ich bin SW-Entwickler und will so viel Quellcode wie möglich im direkten Blick haben. Dafür ist der Philips hervorragend geeignet.
Einen ungewöhnlich hohen Input Leg kann ich nicht feststellen, die Maus reagiert ansatzlos wie bei jedem anderen Monitor auch. Ich wüsste allerdings nicht wie ich das messen sollte.
Zwei negative Punkte habe ich festgestellt:
1. Der Fuß bekommt von mir eine glatte 6 (Schulnote). Der Monitor ist damit in keiner Weise verstellbar und für mich zu Hoch, ist eher ein Fernsehfuß. Zum Glück hat er eine Vesa-Halterung (200 x 200) an die ich eine andere Halterung angebaut habe, womit ich den Monitor verstellen kann und somit ist dieses Problem für mich gelöst.
2. Ich habe den Monitor per DisplayPort angeschlossen. Jedes Mal wenn man den Monitor ausschaltet, werden alle Fenster auf 640 x 480 verkleinert in die linke obere Ecke geschoben (auch die Minimierten). Laut meinen Recherchen ist das aber wohl kein spezielles Problem des Monitors sondern ein Problem von Windows (7) in Verbindung mit DP. Gibt es mit andern Monitoren auch. Ich lasse ihn jetzt immer eingeschaltet und habe den Energiesparmodus heruntergesetzt, so funktioniert es. Evtl. gibt es dafür in Zukunft noch eine andere Lösung.
Ansonsten kann ich bisher nichts Negatives sagen, vor allem für den Preis.
Musste uns nur noch aufklären darüber woher Du ihn bezogen hast :-)
Ich habe ihn bei Alternate Niederlande für € 699,00 gekauft. War bisher auch der einzige Laden, wo er lieferbar war.
Welche Halterung hast Du gewählt?
Was mich abschreckt: Es wäre mein erster glänzender Monitor. Selbst beim Notebookkauf achte ich immer auf ein mattes Display. Ich hatte neulich das glossy Notebook meiner Frau auf dem Schreibtisch stehen und ich sah das dahinterliegende Fenster perfekt darin, wenn ich von der Seite schaute. Direkt von vorn war die Leuchtkraft des Displays stark genug, um die Reflektionen zu überstrahlen. Wie ist das beim Philips? Würde das stören, wenn man das große Fenster direkt im Rücken hat?
Siggi
Siggi
Ich habe von einem Dell-Monitor den Fuß genommen (mit einer Adapterplatte).
Es ist sehr schwierig eine vernünftige Tischhalterung zu bekommen, es gibt tausende Wand- und Deckenhalter und auch Tisch-Klemmhalter, aber einen einfachen, verstellbaren Fuß zu bekommen ist schwierig. Der Dell-Fuß passt optimal und ist in der Höhe, Neigung und Drehung verstellbar.
Ich habe auch Fenster im Hintergrund und habe in der Regel die Rolladen ein ganzes Stück unten, das hatte ich aber bei allen anderen Monitoren auch. Mich stört es nicht mehr als bei einem matten Bildschirm, aber da hat sicherlich jeder ein eigenes Empfinden.
Keine schlechte Idee. Ich liebe die Dell-Füße dafür, dass man die alten 30"er damit bis auf den Schreibtisch runterlassen kann. Obwohl ich mir schon eine 200er Vesa-Wandhalterung ausgesucht habe.
Ein Wandhalter ist bei mir leider nicht möglich aber ansonsten wahrscheinlich die beste Lösung.
Der Monitor ist übrigens sehr leicht, ohne Fuß hat er nur 8,5 kg.
Jetzt ist ja bald Mitte Januar, weiß man schon was Neues bezüglich Erscheinungsdatum?
Nope. Habe aber bei Caseking persönlich schon Interesse bekundet und ich soll eine Nachricht erhalten, wenn die etwas genaueres wissen! Scheint aber nicht mehr lange zu dauern!
Bei Caseking steht jetzt der 22.1 als Termin!
Sorry für den Doppelpost!
ich hab gestern auf "blauen Dunst" bei Caseking bestellt. Mal schauen ob die Liefern können.
Gleich mal noch die Adapterplatte für meine Vesa-Halterungen mitbestellen.
seht euch den Lagerbestand an, meiner geht gerade raus *freu*. Der 200x200 Vesa-Adapter ist heute auch gekommen. Von Berlin nach Berlin ... wenn ich Glück habe ist der morgen da und ich hab auch noch frei. Sehr gut.
@TGP
wird gemacht.
Anscheinend schaut es mit den Liefereiten besser aus. Ich werd warten bis er zumindest zur UVP verfuegbar ist.
Meiner ist auch unterwegs. Hoffentlich wird das zum Wochenende noch was!!!
Nice, ich bitte um Bilder :d Und hat jemand von euch ein Colorimeter? *auf HisN schiel*
