Quelle: guru3dDell is working to release a new 27" monitor with an Ultra-Thin Bezel, the monitor sits in their UltraSharp range and comes with a WHQD AH-IPS panel. The U2715H looks like it will be a replacement for the U2713HM, as opposed to replacing the U2713H screen.The monitor as stated is based on an AH-IPS panel with a 2560 x 1440 resolution. It has a 60Hz refresh rate at the IPS standard 6 – 8ms G2G response time (dependent on setting):
The monitor has 2x HDMI 1.4 ports (with MHL), DisplayPort 1.2, Mini DP 1.2 input and Mini DP 1.2 output. It also has five USB 3.0 ports (one with fast charging) plus 1x upstream and a 3.5mm audio output jack. Slowly phasing out, there are no VGA or DVI connections to be found with this model.
- 1000:1 contrast ratio
- 350 cd/m2 brightness
- 178/178 viewing angles
- W-LED backlight
- sRGB gamut and 16.7m colour depth.
The Dell U2715H will launch soon in Europe and the US. The price is TBA but in but in Hong Kong it is available for give or take $850. It will be a bit cheaper in the US and EU we think.![]()
TFT Central
Klingt gut, schmaler Bezel is immer gut. In HK ist er schon bei DELL gelistet, hoffe bei uns auch bald.
Dell UltraSharp 27 QHD Monitor
*edit*
Bei uns wohl auch. Zumindest die Support Seite: http://www.dell.com/support/home/de/de/debsdt1/product-support/product/dell-u2715h/diagnose
Der U2715H auf der US Seite
Handbuch
/ 2.000.000:1 / 5ms | eBay
