SAKSAK 800 D CASEMOD + Watercooled with Copper and Acrylic pipe
arg-ist
new case is an old friend CORSAİR 800D.
The original case
What I want to achieve are:
To modify 800D case
To instal watercooling1x loop with 2x rads (Push-pull)
To install liquid cooling via Copper and acrylic pipe.
To use a special distributor for water distribution as midplate, laser cutted.
To enlarge the case for radiator fans since it is not wide enough.
MB
ASUS R4 Black Edition
WB for MB
EK-FB KIT ASUS R4BE Nickel Plexi Clean CSQ
Cpu
Core i7 4820K 2011 3.7GHz 10MB
WB for CPU
EK-Supremacy Clean CSQ Nickel Plexi
Video card
2X ZOTAC GTX780 AMP! GDDR5 3GB 384BIT NVIDIA GEFORCE DX11.1
WB for Video
2X EK-FC TİTAN SE Nikel Plexi -Clean CSQ
RAM
AVEXİR CORE SERİES 8X4
Rezervuar
EK –X2 250mm
PSU
CORSAİR Prof. Ser. Gold AX1200 — 80 PLUS
Rad
1x Alphacool NexXxoS UT60 Full Copper 360mm
1x Alphacool NexXxoS Monsta 240
Pump
Swiftech MCP655™ Series 12 VDC Water Pumps - With Speed Control
Shroud
1x Koolance 4-Fan Radiator Shroud, Black
Fittings
30x Bitspower G1/4" Matte Black Enhance Dual Multi-Link For Acrylic Tube OD 12MM
Fans
12x CORSAIR Air Series SP120 High Performance Edition High Static Pressure 120mm Case fun
The case naked
Adding a backplate for the new case
The new place for MONSTA 240 and SWİFTECH 655 pump
OTHER WORKLOGS
Worklog http://www.hardwareluxx.de/community/f143/playdoh-silverstone-tj-07-acrylic-pipe-1012476.html
Worklog http://www.hardwareluxx.de/communit...w-edition-acrylic-tubing-upgrade-1027807.html
Worklog http://www.hardwareluxx.de/community/f143/12-angry-men-900-d-case-p1-1002736.html
Worklog http://www.hardwareluxx.de/community/f143/corsair-900-d-watercooled-mmt-case-997564.html
Worklog http://www.hardwareluxx.de/community/f143/jumbo-case-997157.html
Worklog http://www.hardwareluxx.de/community/f143/transformer-case-996669.html
Worklog http://www.hardwareluxx.de/community/f143/how-make-bench-case-old-atx-1-a-1032451.html
Worklog http://www.hardwareluxx.de/community/f143/4-way-hdd-switcher-1033308.html
Worklog http://www.hardwareluxx.de/community/f143/self-made-cosmos-ii-clear-panel-1034027.html#post22531803
Made an alu midplate for plexi water distrubutor.
Midplate and backplate mat black painted
to enlarge the case , fans were taken out of the case
I made a radiator shroud for fans
and used a self made lazer cutted rad grill on the shroud
Corsair 800 D has a 360 rad gril on the top.
I want to use an Alphacool UT 60 – 480 RAD on the top of the case . therfore ı added 4th
120 mm fangrill with drilling .
but there was a problem to mount the 480 rad . on the top of the case was a pit 5mm for 360 rads
these coused problems at the inside and outside.. ı solved these problem with a 120 mm gasket at the inside and a self made 5mm rubber 360 gasket at outside..
Alphacool UT 60 480 mounted on the topwith push-pull fans and Koollance shroud
480 mm rad mounted on the top
pull fans mounted with koolance shroud
And Monsta 240 mounted at his place.
One of Connection threads from Monsta , was used for draining with a single rotary 90 adapter and a mini valve of Bitspower.
becouse pull fanns of monsta was at outside of the case. , it was made an shroud onthe backcover.
and planning the way for cupper pipes from MB(White line)(blue acrylic)
and next planning of acrylic pipes (blue line)
and bending of copper pipes.
in and out pipes of 480 rad changed
New 5.25 cages with 60 mm depth instead of original 180 mm depht
Added CPU acrylic pipes
Looks pretty awesome. Can't wait for the final pics....
working a bit more with pipes of southbridge and (VRM / MOSFETs) modüle . changed angels of bending…
the green marked pipes must be riht angle and the the pipes blue marked must be paralel
and done…
and the hight of the pipes.the distance between MB and pipes was 100mm and it is downloaded to 50 mm
acrylic pipes of video cards added. ( only one videocard is at photo)
I wannt to make a BLACK plexi(glossy) backplate. And RED plexi gromets for cables.
and what ı wannt to do as backplate..
And done
and planning of plexi waterdistributor as mid plate.
And what ı want to do. Black plexi and blood red fluid with ROG logo.
And drawn with corel to cut with lazer.
To separate PSU from watercooling ,and to hide the cablles ı made a seperatör.
added a filport to the case.
illuminated relief rog logo
Added gromets for cables.
Hi
Distibution block looks great
but - could you please tell me how the water curcuit will run
so much i can see till now
i dont get the circle on the left of the graphics card
and on the other side in the CPU circle on some point i run into a dead end - is there more tubing to come?
regards Markus
Hi
regards Markus
This is the circuit .only a second gtx 780 added. with next updates you can see it better.
OK, I'm already corious about the next update :bigok:
maybe then I'll get rid of the knot inside my brain where you feed the outlet of the grafics card back inot the cooling circuit
regards
Markus
regards
Markus
with second Videocard added you can see the circuit. and ı must add, at the buttom of distr. there some pipes too, between distr., monsta 240 and pump.
you can see buttom here
update 25/09/2014
Becouse there is no place at 5.25 bay for SSD s and HDD, ı made special trays for them . I used 15X15mm Alu T Profil.
And trays mounted to HDD and SSD
And all mounted to the case.
The plexi Water distrubutor has 4 layers.
1- 5mm black plexi at buttom
2- 10mm clear plexi (with lazercutted water channels) in the middle
3- 5mm clear plex on the top i for fittings
4- 2mm black plexi as mask
First bonding acrylic sheets with cloroform. layers 2 and 3
Two layers bounded with cloroform
First leak test
And leak test passed with success.
Dont use metal drils
tapping and preparing for fittings
UPDATE 02/10/2014
Next step, bonding the buttom black plexi from the inside.
And bonding the top plexi as mask with logo
The black plexi mask at the top is 5mm larger from all sides to illuminate the main plexi with a strip led.
And with led strips to control
Acrylic tube fittings mounted to distributör.
The 2.nd leak test with green fluid. The fluid was a brite grenn primochill
but it seems as a dark pastel fluid becouse of black buttom plexi.(not illuminated)
quick illuminated to see the real color.
UPDATE 08/10/2014
ORGANIZING 5.25” DRIVE BAYS 1
The depht of my 5.25 drive bays is only 60 mm. Bu ı want to use it
1 - I want to use the ON- OF control panel of corsair 800D.
2- I want to use my Thermaltake media lab
3- I want to turn of the power of the HDD if it is necessary.
I could use my self built 4 way HDD switcher
But ı made a new controller for leds and HDD switcher together
I have 3 ledsrips in the case and 6 leds on blocks. I want turn of the leds strips and dimm if it is necessary . Therefore ı usued 5 K ohm ON-OF pottanciometers. And red leds to see the on- of positions.
And one 2 way ON-OF switch for HDD with a yellow led on
UPDATE : 23.10.2014
4 - I want t to use a fan controller , Lamptron FC5 V3, to control rad fans (13 fanns on 240rad and 480 rad - push-pul)
And control the fluid temps at rad outputs , with aquacomputer inline sensors on Lamptron
I will to monitor the pumps speed on lamptron and control the pumpspeed with FC5V3 (it has 30 watt outpoot per chanell)
But my old swiftech 655 has no tacho output to monitor accurately the pumps speed. İt must be modified .
First the tacho outpoot must be found on the PCB
scraped the coating off the little circle at PCB with a dremel till I see copper .
Soldered a 3 rd wire to monitor the pump speed
Changed the power cables and used a 3 pin female fan connector , to connect it to fan controller.
You can see the speed of pump on LCD Display and adjust the speed with knob at Lamptron FC5
V3
Something to add:
Swiftech 655 pump is working at
Nominal voltage 12 V DC
Nominal power (@ 12 V) 24 W
Nominal current (@ 12 V) 2 amps
Therefore you need a digital fan controller min 25 watt to control it over fan controller.
But to see only the speed of the pump,you cann use any digital fan controller.
T o do this you must add the yellow tacho cable of pump , to the yellow tacho kable of fan controller.
That is all.
The last tubings between pump-midplate-and 240 monsta done .
Pump isoliert
The bottom chamber is red illuminated. And controlled with a dimmer from panel , to vary the brightness of a light . I want a dark room..
You can dimm
Darker
And darker
And darker…
And you can shut of.
update 20.11.2014
recent addıtıons to the case…
There is a problem on most Mainboards if we cool it with MB Waterblock…
You must see this image
İnstead of the BLACK BEAUTY of rampege 4 extrem black edition.
I think , ıt is one of the best design
I planned to use the original cooler of the MB but painted .
But it was not all … cooler does not cover all the metal look . there is 5-6 mm space
between EL I/O shield and cooler .
therfore ı mounted an U shaped 2mm black plexi ,
and then mounted the cooler.
the results
UPDATE 20/08/2014
My firend wanted to see some logos on his Case.He likes the logos… I draw 3 logos for the case. And laser cutted all together. but the pieces were too small and there was too many parts.
I came home with a great plastic bag
Took quite long to classify..
A Repuclic of gamers logo (relief) and illuminated
And special logo for my friend to SLİ bridge .
his name is Salih SakSAK , I made a logo from the first letters of the name… SSS
(relief) and illuminated .
Copperpipe wow Nice idea ;)
update 28.11.2014
And a special CORSAIR logo to Corsair Case (Just finished)
As signature…
Sails in relief…
staged from the far away to the nearest
from small sail to the large..
.from left to the right..
.to give full sail effect.
Of corse illuminated
At my next corsair logo i ll try to make it relief and cambered… arg-ist
Sorry...
lately I neglected to add photos for this worklog. There are some photos before filling fluid
UPDATE 24.01.2015
The back side window was ready
With self cutted alu gril
It is time to make a front side window with alu and plexi.
First alu frame cutted.
UPDATE 06.02.2015
The backside window was ready with self made alu rad gril.
Front side window with acrylic is ready too . Acrylic (with protective tape) is mounted from the inside.
Font side window is mounted with 3 imbus screws M3 6mm at front and 2 imbus on the side.(green marked)
And acriylic is mounted with 8 M2 8mm phillips screws. (red marked)
And U-chanel rubber trim is not used at the edges.No glue no rubber trim.
Time to send them for powder coting.
Missing final photos added
Frontside and backside panel powdercoated and mounted.
and some final photos
I'll try to add better photos(sorry for the picture qualytie)
Grandfather at work(SELFIE)
FINAL
Hi
Most of members know my old worklog ı hope.
SAKSAK 800 D CASE MOD+ Watercooled with Copper and Acrylic pipe
I had used at this project
MB
All waterblocks EK
WB for MB
WB for CPU
WB for Video
Rezervuar
EK –X2 250mm
Rads
Fittings
Fluid
Primochill Liquid Utopia Fluid Dye Pack- BLOOD RED
Pump
I have used Rads Alphacool UT 60 and MONSTA ( FULL COPPER)
All waterblocks from EK ( FULL COPPER-and NICKEL COATED !!! )
Reservoir EK X2
Fittings Bitspower
Fluid Primochill
Hard tubing
There is nothing in the system as corrosive.
Can you please suggest me a better quality of these products.
And this are the results after 3 Months.
Who is to guilty at this business.
MANUFACTURERS...
OR
arg-ist….
Because ı believed , paid and used this products…
Is there anybody who have anything to say me… arg-ist
Hi you know the problems with my EK Nickel Coated Waterblocks,
This is one of the block. They are full correded at 4 months and nickel coating was robbed. You can see copper on nickel coated waterblocks.
And EK could do nothing for blocks…whic are used onl 4 months....
This is the answer of EK about the problem. Thanks !!! EK for your help…
I must do anything for waterblocks…
firstly cleared corrosion as chemically and mechanically
than Nickel coated again
“sadly you can't do anything but to replace corroded parts.” Was the answer of EK…
And this are the results from waterblocks….
EK said :
“It would be a good idea to find out what is the cause of it in order to avoid it happening in the future. “
I shall think two times when buying EK EN Waterblocks again..
You can also do so. arg-ist
Of course an new build and upgrade is coming so.on
