[Sammelthread] Asrock 890FX Deluxe5 (AMD 890FX / SB850)
Herstellerlink
Bezugsquellen
•Spezifikationen•
CPU
- Support for Socket AM3+ processors
- Support for Socket AM3 processors: AMD Phenom™ II X6 / X4 / X3 / X2 (except 920 / 940) / Athlon II X4 / X3 / X2 / Sempron processors
- Supports 8-Core CPU
- Supports UCC feature (Unlock CPU Core)
- Advanced V8 + 2 Power Phase Design
- Supports CPU up to 140W
- Supports AMD's Cool 'n' Quiet Technology
- FSB 2600 MHz (5.2 GT/s)
- Supports Untied Overclocking Technology
- Supports Hyper-Transport 3.0 (HT 3.0) Technology
Chipsatz
- Northbridge: AMD 890FX
- Southbridge: AMD SB850
- AMD Vision Black
Arbeitsspeicher
- Dual Channel DDR3 memory technology
- 4 x DDR3 DIMM slots
- Supports DDR3 1866(OC)/1800(OC)/1600(OC)/1333/1066/800 non-ECC, un-buffered memory
- Max. capacity of system memory: 32GB*
BIOS
- 32Mb AMI UEFI Legal BIOS with GUI support
- Supports "Plug and Play"
- ACPI 1.1 Compliance Wake Up Events
- Supports jumperfree
- SMBIOS 2.3.1 Support
- CPU, VCCM, NB, SB Voltage Multi-adjustment
Audio
- 7.1 CH HD Audio with Content Protection (Realtek ALC892 Audio Codec)
- Premium Blu-ray audio support
- Supports THX TruStudio PRO™
LAN
- PCIE x1 Gigabit LAN 10/100/1000 Mb/s
- Realtek RTL8111E
- Supports Wake-On-LAN
- Supports LAN Cable Detection
- Supports Energy Efficient Ethernet 802.3az
- Supports PXE
Steckplätze
- 3 x PCI Express 2.0 x16 slots (PCIE2/PCIE4 @ x16 mode; PCIE5 @ x4 mode)
- 2 x PCI Express 2.0 x1 slots
- 2 x PCI slots
- Supports ATI™ Quad CrossFireX™ , 3-Way CrossFireX™ and CrossFireX™
SATA3
- 6 x SATA3 6.0 Gb/s connectors by AMD SB850, support RAID (RAID 0, RAID 1, RAID 0+1 and RAID 5), NCQ, AHCI and "Hot Plug" functions
- 2 x SATA3 6.0 Gb/s connectors by Marvell SE9120, support NCQ, AHCI and "Hot Plug" functions
USB 3.0
- 2 x Rear USB 3.0 ports by NEC UPD720200, support USB 1.0/2.0/3.0 up to 5Gb/s
- 1 x Front USB 3.0 header (supports 2 USB 3.0 ports) by NEC UPD720200, supports USB 1.0/2.0/3.0 up to 5Gb/s
Anschluesse
- 8 x SATA3 6.0 Gb/s connectors
- 1 x ATA133 IDE connector (supports 2 x IDE devices)
- 1 x Floppy connector
- 1 x IR header
- 1 x COM port header
- 1 x IEEE 1394 header
- 1 x HDMI_SPDIF header
- 1 x Power LED header
- CPU/Chassis/Power FAN connector
- 24 pin ATX power connector
- 8 pin 12V power connector
- CD in header
- Front panel audio connector
- 2 x USB 2.0 headers (support 4 USB 2.0 ports)
- 1 x USB 3.0 header (supports 2 USB 3.0 ports)
- 1 x Dr. Debug (7-Segment Debug LED)
•Restliche Angaben•
ATX-Blende I/O Panel
- 1 x PS/2 Mouse Port
- 1 x PS/2 Keyboard Port
- 1 x Coaxial SPDIF Out Port
- 1 x Optical SPDIF Out Port
- 6 x Ready-to-Use USB 2.0 Ports
- 2 x Ready-to-Use USB 3.0 Ports
- 1 x eSATA3 Connector
- 1 x RJ-45 LAN Port with LED (ACT/LINK LED and SPEED LED)
- 1 x IEEE 1394 Port
- 1 x Clear CMOS Switch with LED
- HD Audio Jack: Side Speaker / Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone
Einzigartige Features
- ASRock Extreme Tuning Utility (AXTU)
- Instant Boot
- ASRock Instant Flash
- ASRock AIWI
- ASRock APP Charger
- SmartView
- ASRock XFast USB
- Hybrid Booster:
- CPU Frequency Stepless Control
- ASRock U-COP
- Boot Failure Guard (B.F.G.)
- Turbo 50 / Turbo 60 CPU Overclocking
- Turbo UCC
Smart Switch - 1 x Power Switch with LED
- 1 x Reset Switch with LED
Produktzubehör
- Quick Installation Guide, Support CD, I/O Shield
- Floppy/ATA 133 Cables
- 4 x SATA Data Cables (optional)
- 2 x SATA 1 to 1 Power Cables (optional)
- 1 x Front USB 3.0 Panel
- 4 x HDD Screws
- 6 x Chassis Screws
- 1 x Rear USB 3.0 Bracket
Hardware überwachung
- CPU Temperature Sensing
- Chassis Temperature Sensing
- CPU/Chassis/Power Fan Tachometer
- CPU Quiet Fan
- CPU/Chassis Fan Multi-Speed Control
- Voltage Monitoring: +12V, +5V, +3.3V, Vcore
Formfaktor
- ATX Form Factor: 12.0-in x 9.6-in, 30.5 cm x 24.4 cm
- All Solid Capacitor design (100% Japan-made high-quality Conductive Polymer Capacitors)
Betriebssystem
- Microsoft® Windows® 7 / 7 64-bit / Vista™ / Vista™ 64-bit / XP / XP 64-bit compliant
Zertifizierungen
- FCC, CE, WHQL
- ErP/EuP Ready (ErP/EuP ready power supply is required)
•Impressionen•
•UEFI•
KeBeNe's Slideshow
Die Fotos sollen erstmal nur einen kleinen Einblick in das UEFI liefern. Sobald AM3+ Prozessoren verfügbar sind, wird natürlich ein Update gemacht.
Aktuelle Version:
Code:
[b]2.00[/b]
[b]1.90[/b]
[b]1.80[/b]
[b][URL="http://www.pctreiber.net/asrock-bios-downloads?did=375"]1.70[/URL][/b] (PCTreiber Download!)
[b][URL="http://www.file-upload.net/download-3865857/890FXD51.63.html"]1.63[/URL][/b]
[b]1.60[/b]
[b][URL="http://wp1170450.wp199.webpack.hosteurope.de/ebay/890FXD51.45"]1.45[/URL][/b] Bereitgestellt von Arek!
[b]1.40[/b]
UEFI Download:
Code:
[URL="http://www.asrock.com/mb/download.de.asp?Model=890FX%20Deluxe5&o=BIOS"]Asrock.com[/URL]
[URL="http://www.asrock.com/mb/beta.asp?Model=890FX%20Deluxe5"]Asrock.com (Betasection)[/URL]
[URL="http://www.pctreiber.net/asrock-bios-downloads?category=177"]PCTreiber.net[/URL]
•Arbeitsspeicher•
Code:
[URL="http://www.asrock.com/mb/memory/890FX%20Deluxe5.pdf"]Asrock Memory QVL[/URL]
Memtest Stable also kompatibel:
[URL="http://preisvergleich.hardwareluxx.de/a610055.html"]Patriot Gamer 2[/URL]
[URL="http://preisvergleich.hardwareluxx.de/812173"]Patriot Viper 3[/URL]
[URL="http://preisvergleich.hardwareluxx.de/crucial-ballistix-sport-vlp-dimm-kit-32gb-pc3l-12800u-cl9-9-9-24-ddr3l-1600-bls4c8g3d1609es2lx0beu-bls4k8g3d1609es2lx0-a862502.html"]Crucial Ballistix Sport VLP 32GB[/URL]
•Reviews•
Code:
[URL="http://www.pureoverclock.com/article1267.html"]pureoverclock.com[/URL]
[URL="http://www.pctreiber.net/2011/asrock-890fx-deluxe5.html"]pctreiber.net[/URL]
[URL="http://www.overclockingstation.de/content/-asrock-deluxe-5-im-kurztest-a561.html"]overclockingstation.de[/URL]
[URL="http://www.ocinside.de/go_d.html?http://www.ocinside.de/html/results/mainboard_asrock_890fx_deluxe5_d.html"]www.ocinside.de[/URL]
•CPU Kühler•
kompatibel:
Prolimatech Genesis - 2 Lüfter
Scythe Mugen 2 - 1 Lüfter
Noctua NH-U12P SE2 - 2 Lüfter
be quiet! Dark Rock Pro C1 - 3 Lüfter
Noctua NH-D14
Alpenföhn Brocken - 2 Lüfter
Phanteks-PH-TC14PE - 2 Lüfter
•Wasserkühler•
NB: Anfi-tec UCD grande
SB: Anfi-tec NBSB-006
SPAWAs: Anfi-tec PWM-014
Spawa und NB montiert:
Da ich 99% meiner Zeit bei meiner Frau bin, und mein "dicker" Rechner, also der FX+7970 bei mir zuhause, zwar wassergekühlt super dupa, nur einstaubt, habe mir gedacht, stellt doch den PII+7850 nach Hause, und den großen hier hin. Leider ist nicht sehr viel Platz und der Brecher mit dem Radi auf der Seite etc. hätte hier nicht hingepasst.
Ausserdem habe ich trotz allem immer etwas Schiss bei Wakü Systemen und dazu kommt noch das ich durch meinen Job in meiner Freizeit keinen Bock und keine Zeit mehr zum Schrauben habe, geschweige denn die Wakü zu warten etc.
Jetzt habe ich Ruhe ....Zen....
True Words spoken from a whise Man :banana:
Wenn nicht schon im Gaming System so viel Kohle drin stecken würd...naja...der WZ-Rechner muss noch lautlos werden und mit freundin zieh ich eh zusamen...irgendwann...oder auch ned...
Ähm ja...Die Software funktioniert eigentlich ganz gut...aber im BIOS scheints immer alles volle möre zu laufen :banana:
Jau, das Problem sind auch nicht so die beiden 140er auf dem Genesis, die höre ich eigentlich so gut wie nicht obwohl die wohl auf 12 Volt laufen. Den kleinen miesen Shicer auf dem Spawa Kühler will ich mal zuleibe rücken :)
mmhh.... also mit der software tut sich auch nix. Sehr seltsam.
Sollte i.O. sein. Funktioniert alles wunderbar soweit. Man ist dsa ätzend wenn man von Wakü auf Lukü zurückgeht. Laut und warm alles. :kotz:
Cool & Quit ist an. Wie gesagt regeln sich die Lüfter auf der CPU und der kleine Spacko auf den Spawas nicht runter. Im Moment 57 Grad Prime InPlace Large FFTs bei 4,1 Ghz. LLC auf 1/4. Blöde Lukü.
Hab ich doch gesagt. ;) Ist nen feines Teil. Hast du denn jetzt die 950/1450 eingestellt bei der Graka?
Einfach im CCC alle Regler nach rechts und fertig :)
Habt ihr das auch das bei manuellen OC Einstellugen der HT Takt plötzlich auf 2000 herabgesenkt wird?
Kann man ihnm dann manuel wieder hochstellen? Oder wirds dann instabil oder so? Habe jetzt ne Super Lösung gefunden. 4,3 Ghz allcore und für mehr Takt lass ich ihn einfach als 6 Core laufen. Temp mässig macht das einiges aus wenn ein Modul nicht läuft.
Bzgl. der BIOS Lüftersteuerung habe ich das selbe Phanomän beobachtet. Ich kann einstellen, was ich will, es tut sich einfach nichts!
Aber ich habe ja meine ScytheKaze Master bzw. bald HM I...
Sonst mal den ASRock Support anfunken...?
Den Support habe ich heute morgen angefunkt, mal abwarten. Ich habe ne Bitefenix Recon aber mal davon abgesehen das alle 5 Lüfter an der Recon schon belegt sind, möchte ich doch dsa die Prozessorlüfter Geschichte je nach Workload eben vom Bios geregelt wird. Das funzte bei mir bisher mit jedem Brett. Kann doch nicht sein.
Bei Problemen mit Lüftersteuerung.
> AsRock Extrem Tuner starten
> FanControl
> Target Level 1
> Target Temp irgendso 44°
> Speichern
Dann sollte er es innerhalb einiger Sekunden übernehmen und es bleibt auch beim nächsten Start so.
Ich habe beobachtet, dass manchmal auf Höchstleistung die Kerne genauso runtergetaktet werden. Oder aber auf Ausbalanciert das Gegenteil.
(Ich habe über AMD Overdrive übertaktet, da so die PowerDownModi normal funktionieren).
Bei Problemen mit dem Stromsparmodi
> AMD Overdrive > GrundEinstellungen > Standard wählen > Übernehmen. (Danach wieder die gewünschten Settings erneut eingeben und speichern.
Bei Problemen mit dem Stromsparmodi Höchstleistung
> Systemsteuerung > Energieoptionen > Höchstleistung > Energiesparplaneinstellungen > Zurücksetzen. (Allenfalls die Option für die SSD die Option "Festplatten abschalten = nie" wieder eintragen und speichern, wenn nötig.)
Xtreme Tuner habe ich auch schon probiert, wurde ja schon vorgeschlagen, funktioniert auch nicht.
Hast Du an den Reglern gedreht, gespeichert, dann die gewünschten Werte eingetragen und wieder gespeichert?
Es könnte sein, dass sich da AMD Overdrive und die anderen Tools in die Quere kommen. Im AMD Overdrive hat's ja auch eine LüftersteuerungsAnpassung. Bei mir funktioniert alles und so steht im AO dann "manuell". Eigentlich logisch, da ein anderes Programm ja die Kontrolle übernimmt.
Dies also im Hinterkopf behalten, sollte man irgendwo anders was ändern, bzw. via AMD Overdrive die Grundeinstellungen abrufen, müssen allenfalls auch die Lüftersettings via ExtremeTuner angepasst werden.
Hab grad bemerkt, dass dafür bei mir trotz voran gefixter Höchstleistung in den Energiesettings die Einstellungen nicht bleiben. Nun hüpft also der Takt ständig von max zu 800 und zurück, im Sekundentakt. Ich muss also auch bei jedem Neustart dafür die EnergieSteuerung resetten und wieder die Festplatte zurücksetzen, wenn ich wegen Games dann auf Höchstleistung stelle, damit die Kerne nicht PingPong spielen. (Komisch, bei nem Warmstart bleiben nun die Settings erhalten. Mal schauen, wie's beim nächsten Kaltstart aussieht.)
So, ist ja klar. Support hat geantwortet. Ein 3 Pin Lüfter lässt sich an einem PWM Anschluss (CPU_FAN1) nicht regeln :shot:
Hat jemand von euch zufällig zwei 3Pin Lüfter via Y-Adapter an CPU_FAN2 angeschlossen und kann di edamit regeln? Also mit dem Temptarget meine ich. Müsste ja eigentlich gehen oder?
Was habt ihr denn bei "extremen" OC so an Spannungen anliegen?
Ich wolllte jetzt mal etwas mit dem HT Takt spielen.
CPU NB: 1,40 V
HT Link 1,35 V
Komisch ist das der NB Multi von 12, also 2400 NB Takt nicht übernommen wird laut CPU-Z. 2400HT stellt er ein, aber die NB bleibt bei 2200.
Also als Hexacore hab ich den 8350 jetzt mit 4,6Ghz am laufen.
Vcore Uefi: 1,475 Vcore Last: 1,432~1,440
LLC: 1/4
CPU-NB Spannung: 1,35 Volt
HT Link Spannung: 1,30 Volt
Prime Stabil gleich 2H bei 59° Max.
Ein Modul weg macht echt locker 10 Grad aus.
Axo, falls interessant. Am 3 Pin Anschluss können zwei Lüfter via Y-Adapter angeschlossen und wohl geregelt werden wenn ich das richtig verstanden habe.
Am 3pin kann o.5A = 6W entnommen werden.
Am 4pin dagegen 1A = 12W
Ich werde das bei Zeiten mal austesten.
Nabend Jungs. Ich muss euch was beichten :) Ich habe mir jetzt nen Säbelzahn als Unterlage besorgt. Aber nicht freiwillig. Ich befürchte das eine meiner Phasen abgeraucht ist. Optisch feststellen konnte ich es noch nicht aber mein PC lief nicht mehr korrekt. Falls es wichtiges Zeuch gibt für den Startpost werde ich das natürlich eintragen.
Du gehst und fremd??? :eek:
Aber das Sabertooth ist eigentlich auch ganz nett...;)
Welches ist es denn geworden? Schon mit PCIe 3.0?
