[Sammelthread] Dota 2 [Free To Play]
Vielleicht hättest du dir lieber den Artikel durchgelesen, als dich so aufzuregen. KDA fließt nicht ein, nur mit wem du gegen wen gewonnen hast. Generell bewertet ihr das Ranking alle über. Theoretisch müsste man ja nur mit Leuten gematcht werden, die ein ähnliches Ranking haben wie man selbst. Außer man stackt, dann ist es aber eh egal.
Ich habe den Artikel gelesen und mir ist bewusst, das die KDA nicht mit einfließt. Und nein, ich kann die als Ex-HoNler versichern, dass sich ein für alle sichtbares Ranking extrem schlecht auf die Community auswirkt...außerdem habe ich dotabuff nicht die Erlaubnis erteilt von mir ein 'Bewegungsprofil' zu veröffentlichen.
---------- Post added at 17:25 ---------- Previous post was at 16:41 ----------
I'll explain.
I've got experience with World of Warcraft, and a little addon called GearScore. It started very small, very obscure. But lo and behold, more people started downloading it. Soon enough, entire servers were using it. Players that did not have gear that'd count up to an arbitrary number would not be welcome, they would not be judged upon their skill, or their talents, or what kind of gear they've gotten, no, they'd be judged based on the amount of points that their gear gave them. It went so far that Blizzard limited the way the API worked so that it required a click on a person rather than auto-scanning, as well as releasing their own simpler version of rating in the form of average itemlevel, as the GearScore tool was becoming toxic to the community and needed moderation.
Now let's look at Heroes of Newerth. We have fully public stats there. To go a step further, people are even ranked in colour from game to game, you can easily discern who is the best and worst on the team. What did that game teach us about stats? That we can look up fun things, that we can compare ourselves to others, but that people who had no base on flaming before would now dive into your stats and try their hardest to make you feel miserable, restricting how you play by not letting the lowest ranked player play a carry, for example.
Personally, I play Dota 2 for a variety of reasons. I play it for the team element, competitive angle, the ability to make comebacks, the high variety of heroes, strategies, items, playstyles, etc. What I do not play Dota 2 for, is the ability to defend myself from people who will dive back into my stats and pull up something that is inferior to their own stats. I do not play Dota 2 so I can mute people every game I enter. I do not play Dota 2 so I can fight with other people over which lane I should take that game based on my DBR being lower than theirs.
So, what is the solution?
Private DBR and default settings to private. You want your stats, so you can have them on public. But do not force people who do not even know of Dotabuff to be affected by this. Do not force people who do not want anything to do with this rating to be involved with this. This should not be a decision forced down on others - it must be an option, and nothing else.
Quelle: Terrafros kommentiert Please stop crying about statistics
Oha, noch gar nicht entdeckt, die Option ... ich kann die Netzwerkqualität nur auf "an" und "aus" stellen... was ist jetzt was? und was hab ich für nachteile, wenn ich die niedrigere Einstellung nehme? :)
Ohne jetzt an dem Schalter rumgespielt zu haben würde ich jetzt mal vermuten, dass Dota2 da einfach nur die "Rates" ändert.
€dit:
Hab grad in einer privaten Lobby mit rumgespielt. Beim meinem net_graph waren up und down etwas geringer und lerp war bei 133 ms (also mit Netzwerkquali auf AUS)
€dit:
Ah, super, hört sich ja noch spielbar an. Dann muss ich das gleich mal mit der mobilen Verbindung testen :cool:
Wie spielt man eigentlich Troll Warlord?
Neues Patchnotes! (Update Notes - January 23, 2013)
Highlites schrieb:
- Added Troll Warlord!
- Added All Random to matchmaking!
- Added a privacy setting in the UI so that players can specify whether they want to allow external 3rd party websites to be able to access their match history (defaulted to private).
- Added tournament calendar view to the Watch tab!
GAMEPLAY
- The pathfinder now ignores obstructions that are due to units that are not visible to the pathing unit.
- Crystal Maiden: Fixed Freezing Field channeling ending if you get purged.
- Dazzle: Fixed Poison Touch slow and stun applying if BKB was used after it had been applied.
- Drow: Fixed Drow Illusions carrying the double bonus from Marksmanship
- Keeper of the Light: Fixed Chakra being castable on magic immune allies.
- Keeper of the Light: Fixed Manta dispelling Mana Leak.
- Lifestealer: Fixed Rage not removing certain buffs that BKB does (Empower, Haste, etc).
- Medusa: Fixed Mana Shield happening after Stout/Vanguard damage block rather than before.
- Meepo: Fixed Poof considering dead illusions as valid destinations.
- Morphling: Fixed Replicate dying if Morphling dies with Aegis.
- Timbersaw: Fixed Whirling Death sometimes taking too long to cast when used with Timber Chain.
- Timbersaw: Fixed Chakram cast time behavior.
- Visage: Fixed Attack and Defense type on level 3 Familiars.
- Warlock: Fixed Aghanim Warlock Golems not doing enough damage.
- Fixed MKB dealing bonus damage to towers.
- Fixed ground courier being able to block lanes and surround Roshan.
- Fixed being able to lifesteal more life than the target has.
- Fixed Diffusal Blade cooldown being 12 seconds instead of 8.
UI
- Added Practice vs Bots option in the Play menu.
- Least Played mode now eliminates each players' top 40 played heroes, up from 20.
- Added completion cost to shop item tooltips, displayed if the player has one or more components.
- Added tooltips to the shop category buttons.
- Fixed the Repick option disappearing too soon.
- Fixed bug where buffs would sometimes display an incorrect duration sweep.
- Bringing up the combat log will now hide the killcam.
- Fixed bug where sometimes spectators would, when inspecting a player, not see thier cosmetic items.
- Fixed bug where Dota 2 would not track changes in the Windows default audio device.
- When spectating a game in directed, hero chase, or player view, the mouse will no longer be locked to the window.
STORE
- Added new item sets for Lone Druid and Necrolyte.
BOTS
- Added Necrolyte bot.
- Added Witch Doctor bot.
- Sven will no longer War Cry when doing a casual retreat.
- Fixed Viper bot not harassing with his unique attack modifier.
- Fixed bug in Sandstorm avoidance that always made bots maximalliy avoid it.
- Adjusted the values so that bots are more willing to tanking creeps at high health/tankability ratings.
- Bots now take into account cleaving when determining what neutral camps they're willing to farm.
- Death Prophet bot will now use Carrion Swarm more when laning.
- Fixed bug that would cause bots to fountain-dive sometimes.
WORKSHOP
- Added a "Show Low-Res Model" checkbox that toggles between showing the low & high resolution LODs for imported models when in Loadout camera view.
- Now automatically switches to showing low-res models in the Day/Night camera views, and high-res models in the Portrait camera view (since that's how they're used by the game).
- Fixed "Other" submission type displaying a "failed to find content file" when submitting.
- Fixed Preview not resetting background properly when moving from Portrait to Day/Night view.
- Fixed Preview losing hero rotation when going to and from Portrait view.
- Fixed a case where the Add Wearable slot buttons didn't work for some slots on some heroes (like Sven).
Haha das ist der Untergang für Dotabuff und ihr neues Ratingsystem. Vor allem weil die default Einstellung auf privat ist :d
DotA 2
Fuck!
Ich bin die ganze Woche auf Lehrgang und hab nur meine 3G Verbindung zum www. Deshalb auch neulich die Frage nach dem Traffic ;) Ich habs heut mal getestet: 45 Min Dota ergaben etwa 65 MB Traffic. Ping lag bei noch spielbaren 150ms im Mittel.
Ja schönes Ding, und nun kommt Freitag ein Patch? Saustark :shot: :fresse:
DotA 2
1v1? Ey isch mach disch kaputt. Du Opfa :fresse:
Toller patch! Im nächsten noch den Wave Aoe/Range von Kotl nerfen, Spiked Carapace fixen (die DMG-Quelle stunnen (necros, bär, treants etc) und nicht den Helden, der die DMG Quelle kontrolliert) und das ist eine der besten Versionen überhaupt.
Hat jemand Interesse an einem Rare Sven Schwert (das aus den neuen Kisten) im Tausch gegen ein anderes Rare meiner Wahl? :d
Ja ich vielleicht.
Wie heißt das genau?
Claive of Unyielding Stone (ist im Shop nicht zu kaufen, dropt nur aus der Kiste)
Sieht schick aus und hab ich noch nicht.
Muss mal gucken, was ich so alles an Items habe.
Bin heute Abend ab 20 Uhr online, falls du willst, können wir dann mal gucken, ob ich was für dich habe!
Gerne, add mich dann einfach. Meine ID siehst du ja in der Signatur.
Ich werde es auch spielen :). Bis ich mich dann wieder aufrege wie unbalanced die randoms sind :wall:
Das Gegnerteam randomed meist immer ein tolles lineup und mein Team bekommt 5 Carrys :fresse2:
@dotabuff DBR Fiasko
We es interessiert: dotabuff.com holt sich die Statistiken über die offizielle WebAPI --> bis dato waren die Spielernamen mit den Helden verknüpft, d.h. Lion hat X Kills Y Assits Z Wards platziert .... UND Lion wurde gespielt von Fleischtorte. Ab kommenden Freitag wird eben diese Verknüpfung von Held mit Spielername aufgehoben, wenn mans in den Settings aktiviert lässt, d.h. die Statisken für Lion in einem bestimmten Spiel sind noch immer abrufbar, nur kann man jetzt nicht mehr den Spielernamen zuordnen.
=> 'Anonyme' Statistiken wird es immer noch geben, wie zB meistgespielter Held usw.
BTW, dotabuff.com ist ein Sub für elobuff.com, d.h. die gesammelten Daten&Statistiken und Ratings NUR gegen Bezahlung bekannt gibt
---------- Post added at 16:31 ---------- Previous post was at 16:29 ----------
€: ....was aber möglich ist, ist eine Metrik, die unabhängig von Spieler A gewinnt gegen B gewinnt gegen C funktioniert.
Die Wave wurde schon vor ein paar Wochen generft (Range), ist zwar immer noch ein nerviger Skill, aber kann mMn so bleiben.
Spiele Nyx zwar recht wenig, aber bei den Spiked Carapace stimme ich dir jetzt einfach mal zu. :d
AR werd ich sicher nur Solo spielen. Ich will im Stack meinen Mates nicht zumuten, das ich nen Hero zocken muss, den ich noch nie gespielt hab.
Ging ja neulich schon brachial in die Hose. Das erstmal "gerandomt" und direkt Vollkatastrophe :fresse:
DotaBuff ist mir eigentlich total Bums, aber ich werd meine Stats dann auch nicht verknüpfen/veröffentlichen lassen.
Hauptsache im Client selbst wird nicht noch ein Rating implimentiert. DANN hätten wir das HoN Szenario.
:fresse2:
Gestern Abend ganz kurioses Spiel gehabt...
Von den Wins her eigentlich recht ausgeglichenes Spiel (alle so um die 50 +/- 10). Im Gegnerteam gab es allerdings so nen Outworld Destroyer der entweder gehirnamputiert oder n Bot war... Rannte teilweise einfach in unsere Tower, war durchweg allein unterwegs und ließ sich so reihenweise von uns umnieten. Laut Gegnerteam hat der auch kein Wort geschrieben, reagierte auf nichts usw.
Sehr kurios, tat mir schon leid fürs Gegnerteam.
Bei meinen andern 3 Spielen gestern dachte ich mir mal wieder: Scheiß auf -ar, need -russian !
Das selbe kennt man doch auch von LoL :rolleyes:.
Mein persönliches Statement zu DOTA2 ist da eher negativ. Mir kommt das Spielgefühl total unflüssig und schwammig vor.
Aber wie in so vielen Sachen in Leben ist das vielleicht alles nur eine Frage der Gewohnheit :drool:.
Nicht vielleicht, sondern sehr warscheinlich. DotA ist eig. alles andere als schwammig und unflüssig o_O
