[Sammelthread] ASUS P8Z77-V / -PRO / -Deluxe / -Premium (Intel Z77)
- Sockel: LGA1155 - Chipsatz: Intel Z77 Sammelthread -
P8Z77 | Geizhals.at Deutschland
INHALTSVERZEICHNIS
1.Spezifikationen 1.Spezifikationen
ASUSTeK Computer Inc. - Motherboards - ASUS P8Z77V
- Zusammenfassung Spezifikationen / Features -
Prozessor / Sockel:
Intel® Socket 1155 for 3rd/2nd Generation Processors
Supports Intel® 22 nm CPU
Supports Intel® 32 nm CPU
Supports Intel® Turbo Boost Technology 2.0
* The Intel® Turbo Boost Technology 2.0 support depends on the CPU types.
Chipset:
Intel® Z77
Memory:
4 x DIMM, Max. 32GB, DDR3 2600(O.C.)/2400(O.C.)/2200(O.C.)/2133(O.C.)/2000(O.C.)/1866(O.C.)/1800(O.C.)/1600/1333 MHz Non-ECC, Un-buffered Memory
Dual Channel Memory Architecture
Supports Intel® Extreme Memory Profile (XMP)
* Hyper DIMM support is subject to the physical characteristics of individual CPUs.
* Refer to ASUS or user manual for the Memory QVL (Qualified Vendors Lists).
Graphic:
Integrated Graphics Processor
Multi-VGA output support : HDMI/DVI/RGB/DisplayPort ports
- Supports HDMI with max. resolution 1920 x 1200 @ 60 Hz
- Supports DVI with max. resolution 1920 x 1200 @ 60 Hz
- Supports RGB with max. resolution 2048 x 1536 @ 75 Hz
- Supports DisplayPort with max. resolution 2560 x 1600 @ 60 Hz
Supports Intel® HD Graphics, InTru™ 3D, Quick Sync Video, Clear Video HD Technology, Insider™
Multi-GPU Support:
Supports NVIDIA® Quad-GPU SLI™ Technology *1
Supports AMD Quad-GPU CrossFireX™ Technology
Supports AMD 3-Way CrossFireX™ Technology
Supports LucidLogix® Virtu™ MVP Technology *2
Expansion Slots:
2 x PCIe 3.0/2.0 x16 (x16 or dual x8) *3
1 x PCIe 2.0 x16 (x4 mode, black)
2 x PCIe 2.0 x1 *4
2 x PCI
Storage:
Intel® Z77 chipset :
2 x SATA 6Gb/s port(s), gray
4 x SATA 3Gb/s port(s), blue
Support Raid 0, 1, 5, 10
Supports Intel® Smart Response Technology, Intel® Rapid Start Technology, Intel® Smart Connect Technology *5
ASMedia® PCIe SATA controller : *6
2 x SATA 6Gb/s port(s), navy blue
LAN:
Intel® 82579V, 1 x Gigabit LAN Controller(s)
Intel® LAN- Dual interconnect between the Integrated LAN controller and Physical Layer (PHY)
Wireless Data Network:
Wi-Fi 802.11 b/g/n
Supports single band frequency 2.4GHz
Audio:
Realtek® ALC892 8-Channel High Definition Audio CODEC
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
Audio Feature :
- Absolute Pitch 192kHz/ 24-bit True BD Lossless Sound
- DTS Ultra PC II
- DTS Connect
- Optical S/PDIF out port(s) at back panel
USB Ports:
ASMedia® USB 3.0 controller : *7
2 x USB 3.0 port(s) (2 at back panel, blue)
Intel® Z77 chipset : *7
4 x USB 3.0 port(s) (2 at back panel, blue, 2 at mid-board)
10 x USB 2.0 port(s) (2 at back panel, black, 8 at mid-board)
Overclocking Features:
Overclocking Protection :
- ASUS C.P.R.(CPU Parameter Recall)
Special Features:
ASUS Dual Intelligent Processors 3 - SMART DIGI+ Power Control :
SMART DIGI+ :
- Smart DIGI+ Key- quickly delivers higher VRM frequency, voltage and current for superior CPU/iGPU/DRAM overclocking performance with one switch.
- Smart CPU Power Level (Intel® VRD 12.5 Future Power Design)- provides the best digital power saving conditions.
ASUS TPU :
- Auto Tuning
- TurboV
- GPU Boost
- TPU switch
ASUS EPU :
- EPU
- EPU switch
ASUS Digital Power Design :
- Industry leading Digital 12 Phase Power Design
(8 -phase for CPU, 4 -phase for iGPU)
- Industry leading Digital 2 Phase DRAM Power Design
- CPU Power Utility
- DRAM Power Utility
ASUS Wi-Fi GO!:
- Wi-Fi GO! Function: DLNA Media Hub, Smart Motion Control, Remote Desktop, Remote Keyboard & Mouse, File Transfer, Capture & Send *8
- Wi-Fi GO! Remote for portable Smartphone/Tablet, supporting iOS & Android systems
- Wi-Fi Engine for network sharing and connection: Client Mode, AP Mode
ASUS Exclusive Features :
- USB BIOS Flashback
- MemOK!
- AI Suite II
- Ai Charger+
- USB Charger+
- Anti-Surge
- ASUS UEFI BIOS EZ Mode featuring friendly graphics user interface
- Network iControl
- USB 3.0 Boost
- Disk Unlocker
ASUS Quiet Thermal Solution :
- Stylish Fanless Design Heat-sink solution
- ASUS Fan Xpert 2
ASUS EZ DIY :
- ASUS O.C. Tuner
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Back I/O Ports:
1 x PS/2 keyboard/mouse combo port(s)
1 x DVI-D
1 x D-Sub
1 x DisplayPort
1 x HDMI
1 x LAN (RJ45) port(s)
4 x USB 3.0
2 x USB 2.0
1 x Optical S/PDIF out
6 x Audio jack(s)
1 x WLAN connector(s) for ASUS wireless module
Internal I/O Ports:
1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s) (19-pin)
4 x USB 2.0 connector(s) support(s) additional 8 USB 2.0 port(s)
1 x TPM connector(s)
1 x COM port(s) connector(s)
4 x SATA 6Gb/s connector(s)
4 x SATA 3Gb/s connector(s)
1 x CPU Fan connector(s)
3 x Chassis Fan connector(s)
1 x Optional Fan connector(s)
1 x S/PDIF out header(s)
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x System panel(s)
1 x MemOK! button(s)
1 x TPU switch(es)
1 x EPU switch(es)
1 x Clear CMOS jumper(s)
1 x USB BIOS Flashback button(s)
Accessories:
User's manual
I/O Shield
2 x SATA 3Gb/s cable(s)
2 x SATA 6Gb/s cable(s)
1 x SLI bridge(s)
1 x Q-connector(s) (2 in 1)
1 x ASUS Wi-Fi GO! card(s)
1 x Wi-Fi Ring Moving Antenna(s)
BIOS:
64 Mb Flash ROM, UEFI AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI 2.0a, Multi-language BIOS,
ASUS EZ Flash 2, ASUS CrashFree BIOS 3, F12 PrintScreen, F3 Shortcut Function and ASUS DRAM SPD (Serial Presence Detect) memory information
Manageability:
WfM 2.0, DMI 2.0, WOL by PME, PXE, WOR by PME
Support Disc:
Drivers
ASUS Utilities
ASUS Update
Anti-virus software (OEM version)
Form Factor:
ATX Form Factor
12 inch x 9.6 inch ( 30.5 cm x 24.4 cm )
Note:
*1: With 2 PCIex16 graphics card.
*2: LucidLogix Virtu MVP supports Windows 7 operating systems.
*3: PCIe 3.0 speed is supported by Intel® 3rd generation Core™ processors.
*4: The PCIe x1_2 shares bandwidth with SATA6G_E12. SATA6G_E12 is enabled by default for system resource optimization.
*5: Supports on Intel® Core™ processor family with Windows 7 operating systems.
*6: These SATA ports are for data hard drivers only. ATAPI devices are not supported.
*7-1: Supports ASUS USB 3.0 Boost UASP Mode.
*7-2: The USB 3.0 ports only support Windows® 7 or later versions.
*8: Available with V1.01.00 or later.
*9: Due to Intel® chipset limitation, P8Z77, P8H77 and P8B75 series motherboards do not support Windows® Vista operating system.
CPUs für P8Z77-V:
ASUS - Mainboards- ASUS P8Z77-V
ASUSTeK Computer Inc. - Motherboards - ASUS P8Z77-V PRO
Prozessor / Sockel:
Chipset:
Intel® Z77
Memory:
Graphic:
Multi-GPU Support:
Expansion Slots:
2 x PCIe 2.0 x1 *4
2 x PCI
Storage:
LAN:
Wi-Fi 802.11 b/g/n
Audio:
Audio Feature :
- DTS Ultra PC II
- DTS Connect
USB Ports:
Special Features:
SMART DIGI+ :
ASUS TPU :
- Auto Tuning
- TurboV
- GPU Boost
- TPU switch
ASUS EPU :
- EPU
- EPU switch
- Industry leading Digital 16 Phase Power Design
(12 -phase for CPU, 4 -phase for iGPU)
- CPU Power Utility
ASUS Wi-Fi GO!:
- MemOK!
- AI Suite II
- Ai Charger+
- USB Charger+
- Anti-Surge
- Network iControl
- USB 3.0 Boost
- Disk Unlocker
- ASUS Fan Xpert 2
ASUS EZ DIY :
- ASUS O.C. Tuner
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Back I/O Ports:
1 x DVI-D
1 x D-Sub
1 x DisplayPort
1 x HDMI
4 x USB 3.0
2 x USB 2.0
6 x Audio jack(s)
Internal I/O Ports:
2 x USB 3.0 connector(s) support(s) additional 4 USB 3.0 port(s) (19-pin)
4 x Chassis Fan connector(s)
1 x System panel(s)
1 x TPU switch(es)
1 x EPU switch(es)
Accessories:
User's manual
ASUS Q-Shield
1 x SLI bridge(s)
BIOS:
Manageability:
Support Disc:
Drivers
ASUS Utilities
ASUS Update
Form Factor:
ATX Form Factor
Note:
CPUs für P8Z77-V Pro:
ASUS - Mainboards- ASUS P8Z77-V Pro
Tests (deutsch):
http://www.awardfabrik.de/mainboards/asus-p8z77-v-pro.html
ASUSTeK Computer Inc. - Motherboards - ASUS P8Z77-V Deluxe
Prozessor / Sockel:
Unterstützt Intel® 22 nm-Prozessoren
Unterstützt die Intel® Turbo Boost-Technologie 2
* Die Unterstützung der Intel® Turbo Boost-Technologie 2.0 ist vom Prozessor-Typ abhängig.
Chipsatz:
Intel® Z77
Arbeitsspeicher:
4 x DIMM, Max. 32GB, DDR3 MHz Non-ECC, Un-buffered Memory
Dual Channel-Speicherarchitektur
Unterstützt Intel® Extreme Memory Profile (XMP)
* Die Hyper DIMM-Unterstützung ist von den Merkmalen des jeweiligen Prozessors abhängig.
* Eine Liste freigegebener Speichermodule finden Sie auf der Webseite ASUS oder im Benutzerhandbuch.
Grafik:
Integrierter Grafikprozessor
Multi-VGA Ausgaben Unterstützung : HDMI/DisplayPort Schnittstellen
- Unterstützt HDMI mit einer max. Auflösung von 1920 x 1200 @ 60 Hz
- Unterstützt DisplayPort mit einer max. Auflösung von 2560 x 1600 @ 60 Hz
Multi-GPU-Unterstützung:
Unterstützt die AMD® Quad-GPU CrossFireX™-Technologie
Erweiterungsschächte:
1 x PCIe 2.0 x16 (x4 Modus, schwarz)
4 x PCIe 2.0 x1 *4
Speichersystem:
2 x SATA 6Gb/s-Schnittstellen, grau
4 x SATA 3Gb/s-Schnittstellen, blau
Unterstützen RAID 0, 1, 5, 10
Marvell® PCIe 9128 controller :
2 x SATA 6Gb/s-Schnittstellen, navy blue
2 x eSATA 6Gb/s-Schnittstellen, red
LAN:
Realtek® 8111F, 1 x Gigabit LAN Controller(s)
Dual Gigabit LAN controllers- 802.3az Energy Efficient Ethernet (EEE) appliance
Wi-Fi 802.11 a/b/g/n
Supports dual band frequency 2.4/5 GHz
Bluetooth:
Bluetooth V4.0
Bluetooth V3.0+HS
Audio:
Realtek® ALC898 8-Kanal High Definition Audio CODEC
- Unterstützt : Anschlusserkennung, und Multistreaming, Technologien sowie automatische Geräteerkennung an der Gehäusevorderseite
Audio Feature :
- Blu-ray audio layer Content Protection
- optischer S/PDIF-Ausgang an der Gehäuserückseite
- DTS Ultra PC II
- DTS Connect
USB-Schnittstellen:
4 x USB 3.0 Schnittstellen (4 an der Gehäuserückseite, blau)
4 x USB 3.0 Schnittstellen (2 an der Gehäuserückseite, blau, 2 intern)
8 x USB 2.0 Schnittstellen (4 an der Gehäuserückseite, schwarz, 4 intern)
Übertaktung:
Sicherheit beim Übertakten :
Besondere Features:
ASUS Dual Intelligent Processors Technologie 3 - SMART DIGI+ Power Control :
SMART DIGI+ :
ASUS TPU :
- Auto Tuning
- TurboV
- GPU Boost
- TPU-Taste
ASUS EPU :
- EPU
- EPU switch
- Industry leading Digital 20 Phase Power Design
(16 -phase for CPU, 4 -phase for iGPU)
- CPU Power Utility
ASUS Wi-Fi GO!:
- MemOK!
- AI Suite II
- Ai Charger+
- USB Charger+
- Anti-Surge
- ASUS UEFI BIOS (EZ-Modus) inkl. benutzerfreundlicher, grafischer Oberfläche
- ASUS SSD Caching
- Network iControl
- USB 3.0 Boost
- Disk Unlocker
- Stylish Fanless Design Heat-pipe solution
- ASUS Fan Xpert 2
ASUS EZ DIY :
- ASUS O.C. Tuner
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Code
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Anschlüsse (Rückseite):
1 x DisplayPort
1 x HDMI
2 x eSATA 6Gb/s
2 x LAN (RJ45) Schnittstelle
6 x USB 3.0
4 x USB 2.0
1 x S/PDIF-Ausgang (optisch)
6 x Audio-Anschlüsse
1 x Bluetooth V4.0 connector(s) for ASUS Wi-Fi GO! card
1 x USB BIOS Flashback Button(s)
interne Anschlüsse:
1 x USB 3.0-Anschluss unterstützt zusätzlich 2 USB 3.0-Schnittstellen (19-pin)
2 x USB 2.0-Anschlüsse unterstützen zusätzlich 4 USB 2.0-Schnittstellen
4 x SATA 6Gb/s-Schnittstellen
1 x Prozessorlüfteranschluss
4 x Gehäuselüfteranschlüsse
1 x S/PDIF-Ausgang
1 x 24-Pin EATX Netzanschluss
1 x 8-Pin ATX 12V Netzanschluss
1 x Audio-Anschluss an der Gehäusevorderseite (AAFP)
1 x MemOK!-Taste
1 x System panel(s)
1 x TPU-Taste
1 x EPU-Taste
1 x Clear BIOS-Taste
1 x Power-on button(s)
1 x Reset button(s)
Zubehör:
User's manual
ASUS Q-Shield
2 x SATA 3Gb/s-Kabel
4 x SATA 6Gb/s-Kabel
1 x SLI bridge(s)
2 x Wi-Fi Ring Moving Antenna(s)
BIOS :
Verwaltung:
Support CD:
Drivers
ASUS Utilities
ASUS Update
Formfaktor:
ATX Form Factor
12 " x 9.6 " ( 30.5 cm x 24.4 cm )
Anmerkung:
- CPU-Liste -
Grundsätzlich sind alle LGA1155 Sandy-Bridge CPUs kompatibel zum ASUS P8Z77-V Deluxe. Wer jedoch seinen Prozzi möglichst weit übertakten möchte,
der kommt an einem Modell mit dem Zusatz "K" im Namen nicht vorbei. Denn auschliesslich diese lassen einen höheren "Turbomulti" zu. Modelle ohne "K"
besitzen einen festen maximalen "Turbomulti" und sind daher für OC ungeeignet, da der Referenztakt nur von 100MHz auf maximal 105-110MHz
erhöht werden kann (kommt sonst zu Instabilitäten!).
CPUs für P8Z77-V Deluxe:
ASUS - Mainboards- ASUS P8Z77-V DELUXE
Tests (deutsch):
http://www.ocaholic.ch/xoops/html/modules/smartsection/item.php?itemid=733&sel_lang=german
http://www.hartware.net/review_1463.html
Bios History:
0801
0906
1015
1206
1401
1502
1504
1617
1709
1805
1908
2003
2104
1.Spezifikationen
ASUSTeK Computer Inc. - Motherboards - ASUS P8Z77-V Premium
CPU:
Intel® Socket 1155 for 3[SUP]rd[/SUP]/2[SUP]nd[/SUP] Generation Core™ i7/Core™ i5/Core™ i3/Pentium®/Celeron® Processors
* The Intel® Turbo Boost Technology 2.0 support depends on the CPU types.ChipsetIntel® Z77
Chipsatz:
Intel® Z77
Arbeitsspeicher:
4 x DIMM, Max. 32GB, DDR3 2800(O.C.)/2600(O.C.)/2400(O.C.)/2200(O.C.)/2133(O.C.)/2000(O.C.)/1866(O.C.)/1800(O.C.)/1600/1333/1066 MHz Non-ECC, Un-buffered Memory
Thunderbold:
ThunderboltVGA output support
Data transfer rate up to 10 Gbps
Daisy-chain up to 6 Thunderbolt devices
Grafik:
Multi-VGA output support : HDMI/DisplayPort/Thunderbolt ports
- Supports Thunderbolt with max. resolution 2560 x 1600 @ 60 Hz
Maximum shared memory of 1696 MB
Supports NVIDIA® 4-Way SLI™ Technology
Supports AMD 4-Way CrossFireX Technology
Supports LucidLogix® Virtu™ MVP Technology *[SUP]1[/SUP]
4 x PCIe 3.0/2.0 x16 (dual x16 or x16, x8, x8 or quad x8) *[SUP]2[/SUP]
2 x PCIe 2.0 x1
Speichersystem:
Intel® Z77 chipset : 2 x SATA 6Gb/s port(s), gray
3 x SATA 3Gb/s port(s), blue
1 x mini-SATA 3Gb/s port(s) with onboard 32GB SSD, black
Supports Intel® Smart Response Technology, Intel® Rapid Start Technology, Intel® Smart Connect Technology *[SUP]3[/SUP]
Marvell® PCIe 9230 controller :
4 x SATA 6Gb/s port(s), navy blue
Support Raid 0, 1, 10
ASMedia® PCIe SATA controller : *[SUP]4[/SUP]2 x eSATA 6Gb/s port(s), red
LAN:
Intel® 82583, 1 x Gigabit LAN Controller(s)
Bluetooth:
Bluetooth V4.0
Bluetooth V3.0+HS
Audio:
Realtek® ALC898 8-Channel High Definition Audio CODEC
Audio Feature :
- DTS Ultra PC II
- DTS Connect
USB-Schnittstellen:
Intel® Z77 chipset : *[SUP]5[/SUP]4 x USB 3.0 port(s) (2 at back panel, blue, 2 at mid-board)
Intel® Z77 chipset :6 x USB 2.0 port(s) (2 at back panel, black, 4 at mid-board)
Übertaktung:
Besondere Features:
ASUS Dual Intelligent Processors 3 - SMART DIGI+ Power Control :SMART DIGI+ :
ASUS TPU :
- Auto Tuning
- TurboV
- GPU Boost
- TPU switch
ASUS EPU :
- EPU
- EPU switch
- CPU Power Utility
ASUS Wi-Fi GO!:
- Wi-Fi GO! Function: DLNA Media Hub, Smart Motion Control, Remote Desktop, Remote Keyboard & Mouse, File Transfer, Capture & Send *[SUP]6[/SUP]
ASUS Exclusive Features :- USB BIOS Flashback
- AI Suite II
- Ai Charger+
- USB Charger+
- Anti-Surge
- ASUS SSD Caching II
- Network iControl
- USB 3.0 Boost
- Disk Unlocker
- ASUS Fan Xpert 2
ASUS EZ DIY : - ASUS O.C. Tuner
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Code
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
1 x Thunderbolt port(s)
1 x DisplayPort
1 x HDMI
2 x eSATA 6Gb/s
2 x LAN (RJ45) port(s)
4 x USB 3.0
2 x USB 2.0
6 x Audio jack(s)
interne Anschlüsse:
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
6 x SATA 6Gb/s connector(s)
3 x SATA 3Gb/s connector(s)
1 x mSATA connector(s) with 32GB SSD onboard
1 x CPU Fan connector(s) (4 -pin)
1 x CPU OPT Fan connector(s) (4 -pin)
1 x System panel(s) (Q-Connector)
1 x TPU switch(es)
1 x EPU switch(es)
1 x CPU/DRAM overvoltage jumper(s)
1 x Reset button(s)
1 x Clear CMOS button(s)
Zubehör:
User's manual
ASUS Q-Shield
4 x SATA 6Gb/s cable(s)
1 x 3-Way SLI bridge(s)
1 x 4-Way SLI bridge(s)
1 x SLI bridge(s)
1 x ASUS Front Panel USB 3.0 Box(es)
BIOS:
Verwaltung:
Support CD:
Drivers
ASUS Utilities
ASUS Update
Formfaktor:
ATX Form Factor
Anmerkung:
*1: LucidLogix Virtu MVP supports Windows 7 operating systems.
*2: PCIe 3.0 speed is supported by Intel® 3rd generation Core™ processors.
*3: Supports on Intel® Core™ processor family with Windows 7 operating systems.
*4: These SATA ports are for data hard drivers only. ATAPI devices are not supported.
*5: The USB 3.0 ports run at USB 3.0 speed rate under Windows® 7 or later versions.
*6: Available with V1.01.00 or later.
3.UEFI-Einblicke (ehemals Bios) 3.UEFI-Einblicke (ehemals Bios)
4.Downloads 4.Downloads
allgemein:
Hinweis:
Nach dem Download nicht vergessen die zip.-Datei zu entpacken.
UEFI-Update möglichst mit EZ-Flash durchführen. Näheres dazu siehe Handbuch.
Flash erfolgt grundsätzlich auf eigenes Risiko!
6.kompatible CPU-Kühler 6.kompatible CPU-Kühler
Alle Sockel 1156-Kühler könnten auf dem Z77 passen, da die Lochabstände 1156/1155 identisch sind! Vorausgesetzt sie kollidieren nicht mit Anbauten/Heatpipes
(fast) problemlos passende Luftkühler: :)
Be quiet! Dark Pro Advanced
EKL Brocken
Intel Boxed Kühler
Noctua NH-C12P SE14
Noctua NH-D14
Prolimatech Genesis (es kann möglicherweise zu Problemen mit dem Pcie x1 anschluß kommen, kleiner abstand zum kühler)
Thermalright HR-02 Macho (SE / Rev. A) - keine Probleme (neuere Revisionen mit Innenbefestigungsklammern)
Zalman CNPS11X Performa (auch bei Vollbestückung knapp passend)
Mit Einschränkungen !!! :
be quiet! Dark Rock Pro 2 (es sollten low Profile Ram verwendet werden)
Noctua NH-U14S (oberster PCIe Slot nur eingeschränkt nutzbar)
Scythe Mine 2 unter verwendung FSMB 4 Backplate und weiteren einschränkungen
Scythe Mugen II Revision B mit dem 1156er Kit Ram Bänke A1 und B1 nur noch mit low profil Ram bestückbar
Scythe Mugen 3 B
wenn nicht so hohe Arbeitsspeicher eingebaut sind, sonst bekommt man Probleme mit dem Lüfter oder den Lüfter-Haltklammern
Thermalright Archon SB-E u. Thermalright Archon - blockiert teilweise obersten Slot (PCIe x1), sonst keine Probleme
Thermalright HR-02 Macho wenn nicht so hohe Arbeitsspeicher eingebaut sind, sonst bekommt man Probleme mit dem Lüfter oder den Lüfter-Haltklammern
Thermalright HR-02 Macho 120 - keine Probleme bei Nutzung von Ram ohne hohe HS, andernfalls kann der erste Ramslot nicht genutzt werden
Thermalright Silver Arrow SBE SE -
Nur die 2 blauen RAM Slots lassen sich nutzen wenn der erste Lüfter normal sitzt, will man alle haben muss man ihn höher montieren, nur LP Ram Pci-e wird blockiert
Thermalright True Spirit 140 längere Pcie Karten auf Slot Pcie x1 sind nicht mehr verwendbar.
Wasserkühler und Flüssigkeitskühler
Antec H2o 620
Corsair H80
7.kompatibler RAM 7.kompatibler RAM
Corsair XMS3 PC3-16000U CL9
Corsair XMS3 Dominator Platinum DIMM Kit 8GB PC3-17066U CL9-11-10-27 (DDR3-2133) (CMD8GX3M2A2133C9) Achtung Ram hat Überhöhe !!
Corsair Dominator CMP16GX3M4X1866C9 4x4 Kit
Corsair XMS3 Dominator GT DIMM Kit 16GB PC3-17066U CL9-11-10-27 (DDR3-2133) (CMT16GX3M4X2133C9)
Corsair Vengeance Low Profile schwarz DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600)
Corsair Vengeance 2*8GB (CML16GX3M2A1600C10)
Corsair Vengeance Low Profile 16GB PC3-12800U CL9-9-9-24 (DDR3-1600) (CML16GX3M4A1600C9)
Corsair Vengeance Low Profile 16GB (DDR3-1600) CML16GX3M4A1600C9
Corsair Vengeance Low Profile 4x8GB CL10-10-10-27 (DDR3-1600) (CML32GX3M4A1600C10B)
Crucial Ballistix Sport CL9 2 x 8GB Crucial BLS8G3D1609DS1S00
Crucial Ballistix Tactical LP (8GB Single) mit Einschränkungen siehe Post 1233
GeIL Evo Corsa GOC38GB1866C9DC
G.Skill Ares F3-1600C9D-8GAO
G.Skill F3-1866C10D-16GAB
G.Skill Ares DIMM Kit 16GB PC3-14900U CL9-10-9-28 (DDR3-1866) (F3-1866C9Q-16GAB)
G.Skill Ares F3-2133C9Q-16GAB - CL9-11-10
G.Skill RipJaws-X DIMM Kit 8GB PC3L-12800U CL9-9-9-24
G.Skill RipJaws-X DIMM Kit 8GB PC3-17066U CL11-11-11-30 (DDR3-2133) (F3-17000CL11D-8GBXL)
G.Skill RipJaws 4x 4GB 1600MHz CL 9-9-9-24 @ 1.5V ~ F3-12800CL9Q-16GBRL
G.Skill RipJaws 16GB DDR3 F3-12800CL9Q-16GBRL
Hynix RAM DDR3-1333 | 2x 2048 MB | Typ: HTM325U6CFR8C
Kingston KHX1333C9D3B1K2/8G 2x4 GB (DDR-3-1333)
Kingston HyperX blu. DIMM XMP Kit 8GB PC3-12800U CL9-9-9-27 (DDR3-1600) (KHX1600C9D3B1K2/8GX)
Kingston HyperX Plug n Play DIMM Kit 8GB PC3-12800U CL9 (DDR3-1600) (KHX1600C9D3P1K2/8G)
Kingston HyperX DDR3-1600 16 GB Kit (Typ: KHX1600C9D3K4/16GX)
Patriot (PXD316G1866C9K, Viper Xtreme DIVISION2) DIMM 16 GB DDR3-1866 Kit
Muskin Stileto DDR3-1333
Samsung Green Series DIMM Kit 8GB PC3L-12800U CL11 LP (MV-3V4G3D)
TeamGroup Elite 4x4GB PC3-10667U CL9-9-9-24
Danke an alle die dazu Beitragen das die Liste der Kompatibilität länger wird ...:hail:
sonstige Links
Da immer wieder die Fragen nach den unterschieden der Boards untereinander aufkommen, habe ich mal ein PDF Tabelle online gestellt, wo ich mich bemüht habe die meisten Unterschiede zu markieren.
Viel Spass damit:
http://netload.in/dateiHl4LsFD9cy/Vergleichsliste Asus P8Z77 Boards.pdf.htm
Update: 13.08.2012 (Changelog siehe Spoiler)
Threadupdate-History:
- 27.04.2015: mehr kompatible Ram und Cpu Kühler hinzugefügt
- 08.01.2013: mehr kompatible Ram und Cpu Kühler hinzugefügt
- 13.08.2012: mehr kompatible Ram und Cpu Kühler hinzugefügt
- 05.07.2012: Bios History deluxe hinzugefügt
- 07.06.2012: Vergleichsliste gebaut und auf netload hochgeladen
- 04.06.2012: Tests hinzugefügt
- 03.06.2012: ein paar änderungen und P8Z77 Premium hinzugefügt
- 02.06.2012: Thread übernahme und aktualisierung der kompatiblen CPU Kühler sowie Arbeitsspeicher
- 19.04.2012: Sammelthread gestartet
:) Bei Gefallen des Threads darf der "Danke-Button" gerne gedrückt werden. :)
Naja, wenn die NB auf 700rpm bei 12V laufen wäre es mir recht egal, ob man sie regeln kann, wenn sie dann wirklich konstant laufen. :)
ne Frage ist der Sammelthread auch für das Asus P8Z77-V LE oder soll ich dafür eine extra Thread aufmachen?
Es geht speziell darum, ob das Mainboard Spulenfiepen verursacht. Ich besitze es schon in Combination mit einem 3570k@4Ghz und einer GTX680. Da alles auf WaKü ist mit Lüftern auf 600rpm ist der Rechner leise, aber ich höre im Idle dauerhaft ein Spulenfiepen und vom Ort her ungefähr um den CPU Sockel drum, und da sind ja auch vom Mainboard her Spulen soweit ich weiß.
wolte mal fragen wie gut die " Samsung Green " mit P8Z77-V.....empfehlung....oder doch die Corsair Vegance (CL8 1600 1,5v) in 8GB.?
Auf dem Maximus V Gene gehen die wirklich gut...
ich hab Probleme mit den Audio Einstellungen auf dem P8Z77-V Deluxe. Hab den aktuellen Audio HD Treiber 2.70 direkt von Realtek drauf.
Dort gibt es eine Einstellung, dass man sowohl die vorderen Buchsen (dort hab ich ein Headset), als auch gleichzeitig die hinteren Buchsen (dort ist ein Lautsprecher angeschlossen) aktivieren kann.
Ich höre aber immer nur auf den Buchsen/angeschlossenes Gerät die ich als "Standard" definiere, die anderen sind dann jeweils stumm.
Außerdem hab ich große Probleme mit den verschiedenen Einstellungen bzw. Auswahlmenüs. Ich fand das alles viel einfacher bei meinem vorigen PC mit XP, ich mein da kamen die Einstellungen vom Beriebssystem. man konnte einfach alles anhaken was man sehen wollte und konnte dann die Geräte die man brauchte mit einem Haken einschalten oder ausschalten.
Außerdem sehe ich bei dem neuen PC mit dem erwähnten ASUS Board im Gerätemanager noch zusätzlich einen "Intel-Display" Audio Treiber. Was ist denn das? Wofür braucht ein Display einen eigenen Audio-Treiber?
@Newschrauber
Genau die selbe Frage mit den Audiokanälen hab ich den Sammelthread auch schon gestellt, aber keine Antwort bekommen. Deswegen leb ich jetzt erstmal damit entweder auf Boxen zu hören, und wenn ich in TS gehe, das Audiokabel vom Headset rauszusuchen und in die Buchse zu stecken.
Kann man das P8Z77-V Deluxe über die Tastatur einschalten? Ich finde keine passende Option im UEFI.
Wg. Sound:
Ich wollte gerne über zwei der Jacks an der Rückseite simultan Sound ausgeben unter W7 (Headset und Speaker) und das Headset einfach leiser drehen, wenn ich es nicht nutze.
Ich habe dann über einen Registry-Hack einen der Jacks auf Speaker umgestellt oder Headset, wenn ich mich nicht täusche. Charmanterweise habe ich damit nun dieses Setup realisiert und beide Jacks werden parallel mit dem Speaker-Signal versorgt.
Den Ansatz hatte ich hier gefunden: Realtek HD Changing Jack output reassignments ( FIX ) - Windows 7 Forums
Ergänzend: http://www.reaper-x.com/2012/02/13/how-to-remap-retasking-realtek-onboard-jacks-ports/
Mit den Anschlussbuchsen vorne am PC hatte ich keine Freude - irgendwas an meinem Antec 1200 Gehäuse mag der Realtek nicht. Sobald der interne Header des Gehäuses aufgesteckt ist, habe ich den bekannten eingesteckt/ausgesteckt Pop-Up vom Realtek in Dauerschleife - mit Suchergebnissen zu diesem Thema kann man sich eindecken... habe den internen Header nun abgezogen und das Headset auch hinten angesteckt und lasse es dank Hack auch einfach dran. Die rein/raus-Orgie vom Realktek Manager war damit bei mir erledigt.
Habe ein interesantes Problem !
Neues System P8777-V ,Bios 1205, 1x Optische Laufwerke (DVR 215D v1.22)
Optisches Laufwerk wird im Bios erkannt aber kein Datenzugriff mit Win 7 64 beim Booten, Laufwerk im Bios ausgewählt ( Bootreihenfolge ) kein Datenzugriff. Alle Sata Ports getestet...kein Datenzugriff.
Also altes Win 7 64 angeschlossen , Optisches Laufwerk wird erkannt Treiber instaliert, Intel Storage erkennt das Laufwerk, Gerätemaneger erkennt auch, Laufwerksbuchstabe ist auch vergeben.......keine Datenzugriff, kein Autostart,keine Anzeige im Dateixplorer......?
Altes Sata LG DVD Leselaufwerk angeschlossen ....gleiches Problem. Sata Kabel Getauscht...gleiches Problem.
habe folgendes Problem bei meinem P8Z77-V-PRO:
Beim Kaltstart startet der PC für eine Sekunde, geht sofort wieder aus, um dann nach ca. 3 Gedenksekunden wieder richtig zu starten, also on-off-on. Das passiert nur nach dem ersten Kaltstart. Fahre ich den PC wieder runter, lasse ihn dann mehrere Stunden aus und mache ihn dann wieder an, so fährt er sofort wieder hoch. Es gibt keine Fehlermeldungen, das Win7 64 läuft absolut fehlerfrei. Was kann das sein? Ein Freund, der bis auf die GRAKa genau das gleiche System hat, hat diesen Phänomen nicht.
Mein System:
Asus P8Z77 V Pro Bios 1504
Intel 3770K
Corsair Vengeance LP 9-9-9-24(16 GB)
Systemplatte Samsung 830 (256GB)
Datenplatte WD Velociraptor 1TB
GRAKA Asus GTX 680 DCIIT
Viele Grüße
Matthias
Wenn du meinst der links am ATX Stecker ? Ja, das ist USB 3.0.
Die unten am Rand sind nur USB 2.0 Header.
Ja, den blauen meine ich. Diesen Anschluß habe ich vor ein paar Tagen mittels USB 3.0 Slotblende verfügbar gemacht und meine neue, externe 2 TB USB 3.0 von WD angeschlossen (WDBACW0020HBK). Was mich nun wundert ist das Windows 7 bei jedem Start meldet das die HDD höhere Geschwindigkeiten erreichen könnte.
Mache ich nun mit einer großen Datei ein Kopiertest (von einer Internen auf die Externe) fängt dieser mit rd 70 MB/sec und fällt im laufe der Kopiererei auf rd 50 MB/sec. Passen die Werte oder spinnt einfach Windows rum?
Komisch ist halt das Windows hier meldet das meine neue externe WD-Platte höhere Geschwindigkeiten erreichen könnte. Dabei ist die Platte USB 3.0.
Bei meiner externen USB3-Platte kommt dieser Hinweis nur nach dem einstecken in einen Front-USB2-Port, wenn ich diese aber in einen Front-USB3-Port einstecke kommt diese Meldung nicht.
Hast du auch diese Meldung nach dem Einstecken in einen der rückseitigen USB-Ports? Vllt liegts an der Slotblende.
Hey,
muss man den USB Stick in einem Bestimmten USB Slot haben um Screens im UEFI zu machen? Mein Stick wird im BIOS richtig erkannt und mit Name angezeigt, allerding kann eine keine Screenshots erstellen. Der Stick ist auf FAT32 formatiert.
Kann mir jemand helfen?
Habe bis jetzt nur die rückseitige Slotblende getestet. Finde es halt ein bissle komisch. Die Übetragungsraten kommen an USB 3.0 heran und der komplette "Strang" ist auch USB 3.0 und trotzdem die Meldung.....
Hey,
Ich nehme für den Stick (4 GB/FAT 32) immer USB 2.0, für USB 3.0 wird der Treiber vom OS geladen. Den angezeigten Stick mit der Maus anklicken/bestätigen dann OK klicken. So geht's bei mir, eben ausprobiert.
Hallo
ich habe so gut wie alles durchgelesen
und ich will nachher meinen PC neu bauen mit einem Deluxe Board
Frage
gibt es einen Unterschied wo ich die SSD anschliesse?
auf dem Board gibt es den Hinweis bei dem dunkelblauen Sata-Anschluss " SSD- Caaching"
das ist doch ein Marvell
und ich glaube bei Euch gelesen zu haben, da sollte die SSD nicht hin
wäre nett, mir gibt da jemand einen Tipp
lg
Rhia
---------- Post added at 15:11 ---------- Previous post was at 13:52 ----------
Sorry
mit der SuFu hab ich`s natürlich selber gefunden
Hallo liebe Threadleser,
ich habe eine Frage bezüglich des integrierten Bluetooth-Controllers, nachdem das Durchsuchen des Themas nicht den passenden Treffer gehabt hat wie erhofft (vielleicht ists auch schon zu spät) :).
Wie auch immer, hat es jemand schon geschafft, die blaue LED an der Rückseite zu deaktivieren? Habe im Bios schon Bluetooth und Wireleass Controler disabled, aber die LED will sich nicht abschalten lassen, selbst wenn der PC aus ist. Muss ja irgendwie die Möglichkeit geben, das auszuschalten, wenn der PC aus ist.
Danke schon mal.
Lan/Internet problem
Morgen an die Profies!
Ich habe mir vor 2 Wochen einen neuen Rechner mit diesem Board besorgt: MB Asus P8Z77-V PRO Intel Z77 So.1155 Dual Channel DDR3 ATX Retail.
Nun tritt bei mir folgendes Problem auf:
Ich habe zwischen durch immer massive einbrüche im Down und Upload merke es vorallem im Teamspeak wo ich kurzzeitig einfach nichts verstehe.
Habe bis jetzt gegen meinen Provider ermittelt aber da auf meinem alten Rechner alles wunderbar läuft und laut provider meint alles ist in ordnung schließe ich dies nun aus.
Nun denke ich das es nur noch Mainboard (software/hardeware) bzw vllt dem windows? liegen kann?
Mainboard treiber habe ich vor zwei wochen von der asus Seite geladen.
Vieleicht jemand eine Lösung parat?
Desweitern zu dieser Lüfter sache:
Ich benütze ein Aerocool xpredator Gehäuse + i7-3770k Prozessor+ Thermalright Silver Arrow SB-E
Beim ersten mal Starten musst ich diese Fan controll im bios deaktivieren.
Nun sag die Asus software immer noch das mein prozessor lüfter zu wenig dreht, habe einen Prozessor belastungstest gemacht und die Temperatur ging nicht über 45 grad im normal betrieb habe ich etwa 32grad.
Sollte ich hier nun noch etwas ändern oder kann ich das so einfach laufen lassen?
Danke für eure Hilfe
Longman
Das Problem mit dem Upload und Download kann an der Asus Software liegen.
Da gibt es seine Funktion die heißt glaube ich Netcontrol oder so ähnlich, sobald ich diese deinstalliert habe hatte ich wider vollen Downloadspeed.
Müsste in der AIsuite sein. Oder du schaust in der Windows Systemsteuerung bei Programme und Funktionen ob du sie von dort deinstallieren kannst.
Bin sowieso kein Fan der Asus Software, deshalb hab ich sie erst garnicht installiert.
Ständige Abstürze
ich rauf mir die Haare
ja, habs im weisen Sata angeschlossen
das passt
aber, nach dem zusammenbau hat alles super funktioniert
Win 7 64 drauf alles gut
nach einer Stunde der erste Absturz
seitdem in regelmässigen Abstände
manchmal, eher selten erscheint die Meldung
Asus Anti-Surge was triggered to protect system from unstable power supply unit
das Netzteil hat hier im Board jemand überprüft das sollte es nicht sein
Uefi Version
1206
ursprünglich 1015
p8z77 Deluxe
i7 3770
G.Skill F3-12800CL9q-16GBXL
hier im Forum habe ich gelesen man soll Anti-Surge abschalten
wo wird das gemacht ich finde es nicht
bin nur ein altes Weib und nicht mehr auf dem Laufenden
ich weiss es gibt neuere Update Versionen
da habe ich aber wiederum gelesen, dass dann keine TV-Karten funktionieren
kann mir jemand helfen
Merci
Rhia
---------- Post added at 17:50 ---------- Previous post was at 17:10 ----------
ok
Anti-Surge habe ich gefunden und abgeschaltet
eine externe Festplatte hat mich ein Absturz schon gekostet
Aber das Problem ist dadurch ja nicht gelöst?
---------- Post added at 18:37 ---------- Previous post was at 17:50 ----------
Mist schon wieder abgestürzt, trotz Abschaltung
sofortiger selbständiger Neustart aber er bleibt mit Code 00 hängen
dann muss ich ihn komplett vom Strom nehmen
dann kann ich wieder starten, manchmal normal, manchmal mit Fehlermeldung
oder soll ich dafür einen eigenen Thread aufmachen
lg
Rhia
Thermaltake atx 12v 2.2 & EPS12V 700w W 0106
Asus P8Z77-V Deluxe
CPU – Intel i7 3770
Artic Cooling Freezer 13 Pro
Samsung SSD 830 Series 256GB
3x Western Digital AV-GP 2000GB
1x Western 3000GB
3 HDD sind noch abgeschaltet im Bios
2 optische Sata Laufwerke
Win7 SP1 Prof64
Ich bin mit meinem Latein am Ende
Wenn er nun abstürzt startet er in er Regel wieder von selbst
Jetzt Uefi (Bios) 1504
Es gibt ein AsusDiagnoseprogramm, da ist kein Fehler ersichtlich
Hat keiner eine Idee?
Guten Morgen
PHC ist mir leider kein Begriff
RST = Rapid Storage Treiber?
ich denke ich installiere mal alle neuen Treiber von der Asus Seite
Check mal deinen Speicher mit Memtest86 durch, ev. erst mal mit einem Modul starten und dann Modul für Modul und Steckplatz für Steckplatz prüfen.
ok ich hatte beschlossen ein neues NT zu holen
erst hab ich aber noch die Software von der SSD installiert, da hatte ich wohl was falsches gelesen sie nicht zu installieren
im Moment ist er seit 2 Std. ruhig, ich wart schon immer das es schwarz wird
ich installiere jetzt alle neuen Treiber, wenn das nix nützt geht Oma in die Knie und holt die Riegel raus
Memtest86 muss auf eine BootCD?
und dann nach jedem Ausbau wieder mit der CD booten?
---------- Post added at 13:25 ---------- Previous post was at 11:10 ----------
puh
das war es wohl, da kann ich mich nur an meine eigene Nase nehmen
irgendwas falsch interpretiert
und da ich nie die mitgelieferten CDs installiere bei Festplatten.........................................
seit ich das Programm auf der CD von der SSD Samsung installiert habe
läuft das System wohl stabil, zumindest hatte ich bis jetzt keinen Absturz mehr
Danke für die Hilfe
Rhia
Ähnliche Themen
