Wie kann ich eine SATA III Festplatte an ein SATA II Motherboard anschließen?
zwerg100
Schaut bei mir jeweils so aus:
Kann ich den Thermal Sensor einfach an die unteren beiden Kontakte der 6gb/s anschließen?
Also du musst keinen Thermal Sensor anschließen, dass die Festplatte funktioniert
Nein, auch beim Mac nicht. Aber:
Wenn kein Thermal Sensor angeschlossen wird, wird dein Mac immer mit voller Lüfterdrehzahl laufen. Da es bei Festplatten für den Thermal Sensor leider keinen Standard gibt, kannst du dir nur eine Festplatte vom selben (Festplatten-)Hersteller kaufen wie schon vorher drin war.
Upgrading the hard drive in an iMac is a DIY project that has always been a difficult, though not impossible, task. With the advent of the late 2009 edition iMacs, there’s a new twist that limits how you can upgrade the iMac’s hard drive.
iMacs have always had a temperature sensor for their internal hard drive. The Mac operating system monitors hard drive temperature and adjusts the internal fans to ensure optimal airflow to keep the hard drive, as well as the rest of the iMac’s inner workings, cool.
Up until the late 2009 model iMacs, the temperature probe for the hard drive was mounted to the hard drive’s cover. When you upgraded the hard drive, all you needed to do was to re-attach the temperature sensor to the new hard drive’s case and you were ready to go.
That changed with the 2009 21.5-inch and 27-inch iMacs. The temperature sensor that was attached to the external case is gone. In its place is a cable that connects directly to a set of pins on the hard drive, and reads the temperature from the temperature probe that is built into almost all hard drives. Sounds like a better system, and it is, at least as far as gathering accurate temperatures from the iMac’s hard drive.
The problem is that there is no standard for which pins to use on a hard drive for the temperature sensor. In fact, the cable Apple uses must be custom made for each brand of hard drive Apple puts in the late 2009 iMacs.
For the end user, this means that if you decide to upgrade the iMac’s hard drive yourself (something we don’t actually recommend for the average user), you can only use a hard drive from the same manufacturer. If your iMac came with a Seagate drive, you can use only a Seagate drive for a replacement. Likewise, if it came with a Western Digital drive, you can only replace it with another Western Digital drive.
If you use a drive from a different manufacturer, there is a very good chance that the temperature sensor will not operate. In order to compensate, your iMac will set its internal fans to the maximum RPM, creating a nerve-wracking noise that will not be pleasant to be near.
€dit:
Vieleicht etwas verwirrend, daher kurz und knapp: Die Festplatte wird funktionieren aber dein Mac wird sich dann anhören wie ein Fön.
Kann man so ein Kabel nicht irgendwo kaufen?
Oder mit ner Software den Lüfter regulieren?
---------- Post added at 17:32 ---------- Previous post was at 17:21 ----------
Habs schon in Google gefunden ;)
Danke trotzdem;)
