[Sammelthread] Battlefield 3
Is normal, wenn ma nen Gameserver hat.
Jedenfalls, wenns da Regeln gibt wie noch Basekamp usw.
und den auch gut Administrieren will. Da kommt ma teilweise kaum
zum zocken am Anfang. Wenn sich dann ma Stammspieler gefunden
haben schaut des wieder anders aus, sofern er mit diesen gefüllt ist.
Von jemanden, der auf der Geforce Lan war....
I just got back from the GeForce LAN that was held in Oakland and thought I would share some of my thoughts after getting to play lots and lots of BF3 on the latest build they had there. Hope this brain dump helps to ease the wait for 10/25, if only for a little bit.
General Gameplay/Interface
  • Let me start off by saying that the build we played at the GeForce LAN was light years ahead of the Beta. It's the theme that will probably run through the rest of this post; it was a great relief to see how much work DICE has put into polishing BF3 up for the final release. Off the top of my head, asides from few bugs (noted at the end), I didn't run into any of the glitches people were having in the Beta(such as rubbernecking or map glitches.)
  • Chat interface. FIXED. The chat text now blends in and matches the rest of the GUI. It is in the same location but that black background is no longer there; the chat is overlayed on the screen just like in previous Battlefield games.
  • Squad screen. FIXED. Pictures of the new squad screen have obviously already popped up on Reddit, and I can't really add anything asides from confirming that it looks exactly as it does in the pictures. However, there still isn't a "Join Squad" option that lets you populate an empty squad. You click "find Squad" and it automatically puts you in a squad just like Beta, although based off the new design it seems like they will have full squad join functionality in the final build (Crash7800, can you back a brother up?).
  • 3D spotting was quite a bit more refined in this build than it was in the Beta. If you spotted someone and then they got behind cover(buildings or vegitation/rocks), their on-screen 3D spot dissappears immediately. No more firing at doritos in the foliage.
  • Minimap. FIXED! The minimap has been vastly improved and is almost on par with the map found in BF2. It's a nice, full minimap now: you can see all the flags, your teammates, empty vehicles...etc. The only thing that seemed like a minor issue is that the zoom levels seemed funky on some maps (like Operation Firestorm) and there wasn't an option to set whether the map would rotate with the player or remain locked onto the compass.
  • Rocks can no longer be shot through. (LULZ)
  • The Options menu is now accessible while dead or alive.
  • The kill cam screen seems to have been shortened in duration, although this could have just been on TDM.
  • There are customizable camo options available for the picking now. From what I could see there were a few solid color uniforms (Black, Blue, Green, Tan, Grey), a few different types of camoflouge (desert/forest/urban), and a few special ones like the SPECACT uniforms and one named the "Dr. Pepper" camo which I can only assume will be tied into a marketing blitz just like the SPECACT stuff was tied in with them during BC2. Each camo "selection" had a corresponding Russian and US version so that you would never be able to put on the same uniform as the opposing team.
  • Hit detection seemed vastly improved. Granted, we were in a LAN environment, but I believe the BF3 servers were actually being hosted down in LA (7 hours away). TDM and 32-player Rush were silky smooth but there was still some weird lag on the 64-player conquest maps. It was fairly rare though, so maybe it was just actual internet traffic issues.
  • There was a notification now for you to press "Q" if you needed ammo/medic that appeared to pop up automatically if you needed either of those things.
  • The new in-game icons that show up over teammates, dead players, and dead players who need a revive have been completely overhauled. They are thicker and a bit brighter; the end effect is that they are much more noticeable.
  • They bumped up the points you receive for completing team objectives. Off the top of my head, neutralizing a flag nets you 200 points, and capping it gives you an additional 250 points. MCOM attacking/defending saw a similar boost.
Weapons
  • The damage model for the weapons, on the whole, feels much more polished than the Beta. The damage glitch where people would take more damage due to sprinting is noticably gone and the gun play now feels much more balanced and even.
  • Firing an unsuppressed weapon marks you on the enemy's minimap for a few seconds; there is now a tangible benefit to rocking the silencer. Most of the teams in the 4v4 TDM tourney had silencers on everything because of this fact.
  • The SUNFIRE TACTICAL LIGHT OF THE GODS has been toned down just a bit. I'd say the circle of light is maybe 20-30% smaller? I didn't run into too many people using it.
  • UMP45: Definitely toned down. I didn't play with it much but there weren't lots of people running around with it, even on some of the tight CQB maps that were played in TDM. It looks like it still packs a punch at close range but loses power quickly at range.
  • M39 EMR: Pretty sexy, didn't play with it a lot but it seemed like a slightly better version of the SKS.
  • SKS/MK11: Seemed like they were toned down from their god-like powers in the Beta, although it's very possible this is as a result of the fixes to the damage model that DICE made. (See above)
  • Bolt Action Snipers: Seems like the bolt action animation has been tweaked to make it harder to quickscope like you could in BC2 and the Beta.
  • T-UGS (Recon Emitter): Now works as advertised with people popping up on your mini-map who are moving within the range of the emitter.
  • SOFLAM: Didn't try it. Sorry :'(
  • Javelin: Worked like a ground version of the stinger missile, it didn't pack much of a punch against heavy armor. Only played with it a few times. Locks on, fire and forget.
  • Mortars: \o\ \o/ /o/. These things are a complete blast. You place them on the ground just like a T-UGS or the Mobile Spawn Point. Once placed, your minimap expands and a ret appears on the minimap that you can drag around for a set range. Click, fire, wash, rinse, repeat. At first they seemed like they would be OP but they have a lag time and a margin of error that prevented utter domination. I can see some really interesting tactics being developed for this in competition. It's perfect for bombarding a squad that is camping a certain area. More info down here.
  • M16A4: This 3-round burst varient of the classic workhorse was a ton of fun to play with. Combined with the "Heavy Barrel" attachment it seemed to be really solid at long range.
  • KH2002: This was the other assault rifle that wasn't in the Beta. It had a nice burst mode and seemed suited for medium-range engagements.
  • T88: Didn't play but one round with it: didn't even fire it. No info. Sorry :'(
  • M1911: Pretty sexy. Packs a punch. Has the most varients of all the pistols (Regular, Suppressed, Tac Light, Suppressed AND Tac Light). Good times.
  • M44 Scoped: Sniped a few dudes on Firestorm with this, seems like a great weapon to finish people off at medium range. However, the firing speed was slow.
  • SG552: Decent engineer weapon. Didn't play with it much. No info. Sorry :'(
Maps
  • Damavand Peak. (TDM). They only had this map playing during the TDM 4v4 tournament (unless I missed something?). It took place in a fun quarry area that had lots of industrial machinery and massive dump trucks (TONKA TRUCKS!) all over. Tight infantry action. I tried to peek around to see the rest of the map beyond where the TDM area was and it looks really big. Awesome vibe.
  • Grand Bazaar. (TDM). Again, I only played this one in the 4v4 tournament on TDM. There was a mosque, a market area, and then some streets and backalleys that were intertwined to make a really layered TDM map. It was obvious that DICE really put time in to give each of these maps character; Grand Bazaar had a unique sense of place. Can't wait to see 32p Conquest on it.
  • Operation Firestorm. (TDM, 64p Conquest, 32p Rush). First things first: this map is huge. Hell, each side starts off with something like SIX heavy armor vehicles on each side at their main spawns. Rush was just the 64p conquest map, but you fought from the US spawn across four stages to the RU spawn. TDM took place at one of the flags and involved three warehouses and a crate yard that had a lot of awesome terrain for tight TDM combat.
  • Caspian Border. (64p Conquest). Not much to say here. The fences were fixed so that jeeps no longer get stuck on them. I didn't manage to take down the massive antenna, although you are now able to take down the radio tower that sits at the "Hilltop" spawn; it falls over on to the rocky area behind the flag.
  • Operation Metro (TDM, 32p Rush). There were a few minor changes to the map in regards to shrubbery placement. Asides from that, it seemed just like it did in the Beta. TDM takes place all through the last stage of Rush: the "Apartments" area. It looked like fun, but they were having issues with it on TDM so they took it out of the tournament rotation.
Bugs/Complaints
  • The only two recurring bugs I noticed both involved the ret. The first one happened quite often when I switched back to my main assault rifle after being scoped in on the M320 grenade launcher. I would get the grenade launcher ret from BF2 overlayed on top of the normal ret from the rifle.
  • The second reticle bug was one that I noticed happening a few times in the Beta. I would unsight from my iron sights only to not have my normal white reticle pop back up. Switching to pistol and then back again usually fixed it. Hopefully this gets fixed.
  • The only design complaint I had with the new build is that for some reason they've change the medic pack icon on the minimap and in-game to this funky-looking band aid instead of the standard "Red Cross" in BF2 and BC2. It looks really dumb and isn't intuitive in the least bit.
TL ; DR, DICE fixed most bugs and issues, game is super polished, the Beta woes are no more. The (almost) final build is looky QUITE SEXY. 10/25 can't come soon enough.
(Quelle: reddit.com)
UVP bzw Origin sind alle Spiele auf 59,99$ bzw Euro
Origin - Search Results
Edit: ach mist, direkt verlinken geht nicht
Wer so kaputt ist und bei Origin kauft... :stupid: :rolleyes:
In meinem Mediamarkt, sind die Spiele Preise seit Jahren konstant.
EA Titel kosten normal 49,99€, am ersten Tag aber 39€ oder 44,99€
Desweitern sind alle Titel min. 1 Tag eher da, also Wozu soll ich irgendwo anders bestellen.
Jetzt mal Ernsthaft, es ist doch grenzenlose Dummheit wenn ich bei Origin für 55€ BF3 kaufe und ich netmal eine DVD bekomme :fresse: Und ich sich dann über hohe Preise aufregt
Mal unabhängig vom Geld ,was mir Latte ist die paar euros ,das man vielleicht andere Beweggründe hat da zubestellen
Sent from my iPhone4
... das man vielleicht andere Beweggründe hat da zubestellen
Ja, welche denn?
Das Game hat man - auch beim Kauf der Retail - so oder so bei Origin und kann es sich jederzeit installieren.
:P
Ein wirklichen Vorteil sehe ich absolut nicht.
Gutschein ,was bei mir aber nicht zutrifft ,ich bin den 27-28 den ganzen Tag unterwegs und weiß nicht ob ich die zeit und Lust finde zu ein MM oder Saturn zugehen ,schicken per Post fällt auch flach ,niemand Zuhause ,da ist mir ein Download sehr angenehm ,hätte morgens gestartet und spät abends hätte ich das Spiel ,aber da ich ab den 21.10 das Spiel downloaden kann ,ist es für mich noch einfacher
Das ist für mich ein Vorteil
seinen arsch nicht aus dem haus bewegen zu müssen und trotzdem 100pro am releasetag spielen zu können ;)
ist doch scheißegal, jeder soll kaufen wo er will und dann kostet es halt soviel wie es halt kostet.
Wenn man ins Kino geht gibt man pro Film auch 8-15 Euro aus.. für 90-120 Minuten...
Da sind 40-60 Euro für ein Spiel an sich noch ok .. verstehe die Diskussion nicht.
Was gut ist, soll doch auch gut bezahlt werden.. sonst gibt es das nicht mehr lange.
Genau, das habe ich schon bei bfbc2 gemerkt denn es war mein erstes richtiges Online Spiel und ich hab ca 500 Std gespielt,
ein guter MP ist das was mich antreibt, ich freu mich wenn ich auch mal deinen Server besuchen darf?
Battlefield 3 Limited Edition ORIGIN CDKEY with Back To Karkand Pack - CD-Keys Direct
naja ... english only ... zumindest nicht russisch ... ist für die 29 euro die ich bezahlt hab für mich ok, spiele eh immer shooter auf englisch ^_^
Da wäre aber das auf jedenfall günstiger & besser gewesen:
http://www.procon-hosting.com/modules.php?name=store&op=details&ids=25
Vor allem 29 Euro für einen RU key wäre mir zu teuer... gibt schon für 16,99 den gleichen
wo wir schon grade wieder bei der "wo am besten bestellen" diskussion sind ^^
...die russenkeys fallen für mich jetzt eigentlich flach, da nicht 100% sicher ob ich dann auch auch englisch spielen kann xD
jetzt hab ich bei amazon.com bf3 als downloadvariante gefunden
Amazon.com: Battlefield 3 - Limited Edition: Pc: Video Games
was haltet ihr davon? hat da eventuiell jemand erfahrung mit?
bzw. gäbs irgendeinen grund, der dagegen spricht diese version von hier aus(deutschland) zu bestellen und spielen?
was mich etwas stutzig gemacht hatte ist die notwendigkeit das game über den amazon download manager zu laden. wie läuft das dann mit der einbindung in origin ab? oder bekomm ich auch einfach nen key zugeschickt, den ich über origin aktivire?
und zu guter letzt wird der dollar preis einfach in euro umgerechnet? also 50$ = ca.36€?
oder kommt auch bei einer downloadvariante noch deutsche mehrwertsteuer/zollgebüren drauf?
Mit english only hätte ich kein Problem, aber eine russische Version will ich nicht, würds zwar verstehn aber nichts lesen können :d
Aber sollte die Version aus MM oder Saturn am Release wirklich nur 40€ kosten hol ich sie mir lieber dort und zahl paar Euro drauf und erspare mit Stunden der Downloadqual über Origin :fresse2:
verstehe jetzt nicht warum du nicht einfach bei procon für 33,99 mit allen dlc's kaufst und fertig...
Warum auf so umständlichen Weg über amazon.com gehen wenn es hier günstiger geht.
das isn ami-key ... verschickt wird er am 25.10 ... also kein RU key ...
das mit procon hab ich erst nach dem Kauf entdeckt, allerdings sind mir 4 euro für nen kit, das ich eh freispielen kann, zuviel. Wo es doch sooooo viele Uniformen gibt! :p
also wem das an uniformen net reicht :p
weiß ich bei dem denn mit sicherheit, dass das kein russen key ist^^?
andere seiten haben ja auch erst als multilangage angeboten und nachdem EA ein wenig rumgemuckt hat die angaben gändert.
english only wär für mich auch kein ding aber russische menüführung möcht ich dann nicht umbedingt riskieren xD
und ob 33€ oder 36€(von amazon) ist dann auch nciht mehr der riesen untershcied wenn ich mir dafür sicher sein kann nen wirklich englischen key zu bekommen, ohne noch irgendwelche dateien zu überschreiben ;)
edit:
das isn ami-key ...
wo steht das denn genau? hab auf der seite vom angebot jetzt nichtmal den vermerk zu multilanguage gefunden.
in den FAQ steht zwar, dass alle keys multi sind, aber wie gesagt anscheinend hat EA die lokalisierung ja wohl auf die herkunft des keys beschränkt Oo
....letztendlich wird man völlige gewissheit erst am release haben^^ bzw 1-2 tage später ob modifizierte files funktionieren. Aber ich weiß nicht ob ich solange warten kann xD
http://www.procon-hosting.com/modules.php?name=store&op=category&ids=25
lesen hilft (FAQ)
ach und wenn du eh schon bei 36 euro + kreditkarten umrechnungskurs + auslandseinsatz bist, dann geh doch zum MM / saturn für 39 euro und stell dir die box innen Schrank und entlaste deinen DSL Provider ^_^
aso okay! Wenigstens ein ami key! sonst hätte ich an deiner stelle sofort storniert :d
Bei procon ist ess trotzdem ein gutes Angebot aufgrund dessen, dass alle dlc's sofort vorhanden sind und auch das Map-pack mit dabei ist.
Außerdem ist es ein multilingualer key...das war für mich ausschlaggebend :)
@sepl: Ja soll zu 100% ein deutscher key sein. Er verdient halt selber nicht viel dabei, deswegen ist es so günstig als bei anderen händlern...
Wieso muss man bei 'nem Spiel, mit dem man wahrscheinlich mind. 50+ Stunden Spaß hat sparen, wenn man sich gleichzeitig teure Hardware kauft? Versteh' ich nicht...
lesen hilft (FAQ)
ja die faq hab ich gelesen (hab ich ja auch noch editiert ;) )
und mit dem umrechnungskurs war ja genau meine frage. also wieviel etwa noch zu den 50$ hinzukommen oder ob das einfach nach aktuellem kurs umgerechnet und abgebucht wird
...mein dsl provider ist momentan die rwth aachen, die können das ab :P
Ähnliche Themen
Antworten
2K
Aufrufe
59K
